Skip Headers
Oracle Transparent Gateway for IBM DRDA Installation and User's Guide
Release 9.2.0.1.0 for UNIX
Part Number A96194-02
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
E
Configuration Worksheet
The following table is a worksheet that lists all of the parameter names and the reasons you will need them for configuring the Gateway and the Communications Interfaces (SNA and TCP/IP).  Use the worksheet to gather the specific information you need before beginning the configuration process.
Table E-1 List of Parameters Needed to Configure the Gateway
Reason Name of Parameter Needed Your Specific Parameters Here
For: Gateway's Oracle Home
ORACLE_HOME
___________________________________________
For: Gateway's System ID
ORACLE_SID
For: Primary Service Definition
SNA Network Name
Control Point Name
For: Connection Properties Address
Remote Network Address
Remote SAP Address
For: System Identification: Local Node Name and Remote Node Name
For Each: Network Name
Control Point Name
Local Node ID
Remote Node ID
For: Creating a Local LU Definition:
LU Alias
LU Name
For: General APPC Mode Definition
Mode Name
For: APPC Mode Limits
Parallel Session Limit
Minimum Contention Winner Limit
Partner Min Contention Winner Limit
Automatic Activation Limit
For: APPC Mode Characteristics
Pacing Send Count
Pacing Receive Count
Max Send RU Size
For: Remote LU Definition, General Properties
Appropriate Connection name
LU ALias
Network Name
Uninterpreted Network Name
For: Remote LU Properties Options
Any Security Options needed
For: Remote collection ID
DRDA_PACKAGE_COLLID
For: Remote package name
DRDA_PACKAGE_NAME
For: Creating CPI-C Symbolic Destination Names (Side Information Profiles), general information
Appropriate Name for each Side Information Profile
Appropriate Mode
For: Partner Information in CPI-C Name Properties
TP Name
Partner LU Name Alias
For: Configuring TCP/IP
Local Hostname, Domain Name
IP Address
Network Mask
Name Server IP Address
Destination Hostname or IP Address
Destination Service Port Number
For: Recovery user ID
DRDA_RECOVERY_USERID
For: Recovery Password
DRDA_RECOVERY_PASSWORD
For: Remote Database Name
DRDA_REMOTE_DB_NAME
For: Connection Parameter
DRDA_CONNECT_PARM
For: Owner ID of DRDA package
DRDA_PACKAGE_OWNER
For: DB Name used with Oracle server
HS_DB_NAME
For: DB Domain used with Oracle server
HS_DB_DOMAIN
The user ID that is used to bind or rebind the DRDA package must have the appropriate privileges on the remote database as described in Chapter 5, "Configuring the DRDA Server".  Your database administrator will need to provide these privileges.
Oracle
Copyright © 2001, 2002 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
