Skip Headers
Oracle® Transparent Gateway for IBM DRDA Installation and User's Guide
Release 9.2.0.1.0 for MS Windows
Part Number A96195-01
Go To Table Of Contents
Contents
Go To Index
Index
Previous Next
E
Configuration Worksheet
Information That You Need in Order to Configure the Gateway and the Communications Interfaces (SNA Server and TCP/IP)
Table E-1 List of Parameters Needed to Configure the Gateway
Reason Name of Parameter Needed Your Specific Parameters Here
For: Gateway's Oracle Home
  • ORACLE_HOME
__________________________
For: Gateway's System ID
  • ORACLE_SID
For: SNA Server Definition
  • SNA Subdomain
  • SNA Service
For: Primary Service Definition
  • Network Name
  • Control Point Name
For: SNA Server Link Service
  • Appropriate Link Service Identification (example: DLC 80202 Link Service)
For: Link Service Properties
  • Appropriate Network Adapter information (example: IBM Auto 16/4 Token-Ring Adapter)
For: Creating a General Connection Definition
  • Appropriate Connection Type (Example: 802.2)
  • Connection Name
For: Connection Properties Address
  • Remote Network Address
  • Remote SAP Address
For: System Identification: Local Node Name and Remote Node Name
  • For each: Network Name
  • Local Node ID
  • Remote Node ID
For: DLC values possible change of default values __________________________
For: Creating a Local LU Definition:
  • LU Alias
  • LU Name
For: General APPC Mode Definition
  • Mode Name
For: APPC Mode Limits
  • Parallel Session Limit
  • Minimum Contention Winner Limit
  • Partner Min Contention Winner Limit
  • Automatic Activation Limit
For: APPC Mode Characteristics
  • Pacing Send Count
  • Pacing Receive Count
  • Max Send RU Size
For: Remote LU Definition, General Properties
  • Appropriate Connection name
  • LU ALias
  • Network Name
  • Uninterpreted Network Name
For: Remote LU Properties Options
  • Any Security Options needed
For: Creating CPI-C Symbolic Destination Names (Side Information Profiles), general information
  • Appropriate Name for each Side Information Profile
  • Appropriate Mode
For: Partner Information in CPI-C Name Properties
  • TP Name
  • Partner LU Name Alias
For: Configuring TCP/IP
  • Local Hostname, Domain Name
  • IP Address
  • Network Mask
  • Name Server IP Address
  • Destination Hostname or IP Address
  • Destination Service Port Number
For: Recovery user id
  • DRDA_RECOVERY_USERID
For: Recovery Password
  • DRDA_RECOVERY_PASSWORD
For: Remote Database Name
  • DRDA_REMOTE_DB_NAME
For: Connection Parameter
  • DRDA_CONNECT_PARM
For: Remote collection ID
DRDA_PACKAGE_COLLID
___________________________
For: Remote package name
DRDA_PACKAGE_NAME
For: Owner ID of DRDA package
DRDA_PACKAGE_OWNER
For: DB Name used with Oracle server
HS_DB_NAME
For: DB Domain used with Oracle server
HS_DB_DOMAIN
The user ID that is used to bind or rebind the DRDA package must have the following privileges on the remote database; your database administrator will need to provide these.
  • package privileges of BIND, COPY, and EXECUTE
  • collection privilege of CREATE IN
  • system privileges of BINDADD and BINDAGENT
Previous Next
Oracle Logo
Copyright © 2001, 2002 Oracle Corporation
All rights reserved
Contents
Go To Index
Index
