Skip Headers
Oracle® Procedural Gateway and Tools for IBM MQSeries Installation and User's Guide
Release 9.2.0.1.0 for UNIX
Part No. A96196-01
Go To Table Of Contents
Contents
Go To Index
Index
Previous Next
4
Pre-installation
This chapter guides you through the basic concepts and pre-installation steps for Oracle9i Procedural Gateway for IBM MQSeries.  The following topics provide information about Oracle9i Procedural Gateway for IBM MQSeries, environment variables settings, and starting Oracle Universal Installer:
Preinstallation Tasks
The preinstallation tasks for the Oracle9i Procedural Gateway for IBM MQSeries are divided into the following parts:
MQSeries Software
  1. Determine where the MQSeries queue manager is running.
    • Local Machine
      If the MQSeries queue manager is running on a local machine, then the queue manager is running on the same machine where you intend to install the gateway product set.
    • Remote Machine
      If the MQSeries queue manager is running on a remote machine, then the queue manager is running on a different machine, not the machine where you intend to install the gateway product set.
  2. Verify that the MQSeries software is already installed.  If the MQSeries server software resides on a different machine than the gateway, then the MQSeries client software must be installed on the gateway machine.
  3. Identify the name of the MQSeries queue manager.
  4. Identify the MQSeries client channel definition.
If the queue manager resides on a different machine than the gateway, then the MQSeries client software is used to access the remote queue manager.  A channel definition is required for this configuration.
Setting Environment Variables
Before installing Oracle9i Procedural Gateway for IBM MQSeries on UNIX platforms, the following environment variables must be set:
  • ORACLE_HOME
  • ORACLE_SID
  • DISPLAY
  • TMP
    Verify that the values that you assign to the environment variables, which are listed in this section, are less than 42 characters long.  Longer values might generate errors such as ÒWord too longÓ during installation.
ORACLE_HOME
ORACLE_HOME is the root directory in which Oracle software is installed.
Oracle9i Procedural Gateway for IBM MQSeries cannot share the same ORACLE_HOME directory with other Oracle products.  If you have installed other Oracle products, then Oracle9i Procedural Gateway for IBM MQSeries must be installed in a different ORACLE_HOME directory.  Refer to "Preventing Conflicts Between ORACLE_HOME Directories".
Be sure to avoid installing Oracle9i Procedural Gateway for IBM MQSeries in an ORACLE_HOME directory containing other Oracle products, including the database.  Such an installation could overwrite shared components, causing the products to malfunction.
To prevent a conflict between the software in an existing ORACLE_HOME directory and Oracle9i Procedural Gateway for IBM MQSeries, you must remove all references to the existing ORACLE_HOME directory.  The following steps describe removing these references.
  1. Unset your existing ORACLE_HOME variable by using one of the following commands.
    • C shell:
      prompt> unsetenv ORACLE_HOME
    • Bourne/Korn shell:
      prompt> export ORACLE_HOME=
  2. Edit the following environment variables so that they do not use the existing ORACLE_HOME value:
Table 4-1 Setting Environment Variables for a New ORACLE_HOME Directory
Environment Variable Platforms
PATH AIX-based Systems, HP 9000 Series HP-UX, and Sun Solaris
CLASSPATH AIX-based Systems, HP 9000 Series HP-UX, and Sun Solaris
LD_LIBRARY_PATH Sun Solaris
LIBPATH AIX-based Systems
SHLIB_PATH HP 9000 Series HP-UX
Verify that the C compiler is in your PATH before you start the installation.
Setting ORACLE_HOME
Set the ORACLE_HOME environment variable by using one of the following commands:
  • C shell
    prompt> setenv ORACLE_HOME <full path>
  • Bourne/Korn shell
    prompt> ORACLE_HOME=<full path>
ORACLE_SID
ORACLE_SID is used for the SID of the gateway.  If the IBM MQSeries manager runs on the same machine as the gateway, set the value of the ORACLE_SID environment variable to pg4mqs92.  If the IBM MQSeries manager runs on a different machine than the gateway, set the value of the ORACLE_SID environment variable to pg4mqc92.
Setting ORACLE_SID
Set the ORACLE_SID environment variable by using one of the following commands:
  • C shell
    prompt> setenv ORACLE_SID pg4mqs92
    or
    prompt> setenv ORACLE_SID pg4mqc92
  • Bourne/Korn shell
    prompt> ORACLE_SID=pg4mqs92
    promtp> export ORACLE_SID
    or
    prompt> ORACLE_SID=pg4mqc92
DISPLAY
Setting the DISPLAY environment variable enables you to run the Oracle Universal Installer remotely from a local work station.  On the system where you run the Oracle Universal Installer, set DISPLAY to the system name or IP address of your local workstation.
If you get an Xlib error when starting the Oracle Universal Installer such as ÒFailed to connect to serverÓ, ÒConnection refused by serverÓ, or ÒCan't open displayÓ, then run the commands on your local workstations as follows:
On Server where the Installer is Running
  • C shell
    prompt> setenv DISPLAY hostname:0.0
  • Borne or Korn shell
    prompt> export DISPLAY=hostname:0.0
In Session on Your Workstation
  • C shell
    prompt> xhost +server_name
TMP
During installation, Oracle Universal Installer uses a temporary directory for swap space.  This directory must meet the "Hardware Requirements".  The installation might fail if you do not have sufficient space.  The Oracle Universal Installer checks for the TMP environment variable to locate the temporary directory.  If this environment variable does not exist, then the installer uses the /tmp directory.
The following example demonstrates how to set the  TMP environment variable.
  • C shell
    prompt> setenv TMP <full path>
  • Bourne/Korn shell
    prompt> TMP=<full path>
    prompt> export TMP
About Oracle Universal Installer
Oracle9i Procedural Gateway for IBM MQSeries uses Oracle Universal Installer to configure environment variables and to install components.  The Oracle Universal Installer guides you through each step of the installation process, so you can choose configuration options for a customized product.
The Oracle Universal Installer includes features that perform the following tasks:
oraInventory Directory
The Oracle Universal Installer creates the oraInventory directory the first time it is run on your computer.  The oraInventory directory keeps an inventory of products that the Oracle Universal Installer installs on your computer as well as other installation information.  If you have previously installed Oracle products, then you may already have an oraInventory directory.
  • When a UNIX group name is specified, it grants that group the permission to write to the oraInventory directory.  If another group attempts to run the Oracle Universal Installer, then they must have permission to write to the oraInventory directory.  If they do not have permission the installation will fail.
  • Be sure the user running the Oracle Universal Installer has permission to write to the oraInventory directory and all its files.  This is required to run the installer.
  • The location of oraInventory is defined in /etc/oratab/oraInst.loc for HP 9000 Series HP-UX and AIX-Based Systems.
  • The location of oraInventory is defined in /var/opt/oraInst.loc for Sun Solaris.
  • The latest log file is oraInventory_location/logs/installActions.log.  Log file names of previous installation sessions take the form installActionsdatetime.log.
  • Do not delete or manually alter the oraInventory directory or its contents.  Doing so can prevent the Oracle Universal Installer from locating products that you have installed on your system.
Starting Oracle Universal Installer
Perform the following steps to launch Oracle Universal Installer, which installs Oracle9i Procedural Gateway for IBM MQSeries:
  1. Stop all Oracle processes and services (for example, the Oracle database).
  2. Mount the installation CD-ROM.
    The Oracle Product Installation CD-ROM is in RockRidge format.  To begin installation, insert the CD.
    To manually mount or unmount the CD-ROM, you must have root privileges.  Unmount the CD-ROM before removing it from the drive.
    To manually mount the CD-ROM, perform the following tasks:
    1. Insert the Oracle9i Procedural Gateway for IBM MQSeries CD-ROM into the CD-ROM drive.
    2. Log in as the root user.
    3. Create the CD-ROM mount point directory.
      prompt> mkdir <mount_point>
    4. Mount the CD-ROM drive on the mount point directory and exit the root account:
      prompt> mount options <device_name> <mount_point>
      prompt> exit
    The following examples show how to mount the CD-ROM manually on /cdrom:
    Platform Command Example
    AIX-Based Systems
    prompt> mkdir /cdrom
    prompt> mount -o ro -V cdrfs <device_name> /mnt/cdrom
    prompt> exit
    HP 9000 Series HP-UX Note: Add the following line to the /etc/pfs_fstab file:
    /dev/dsk/c5t2d0./cdrom pfs-rrip xlat=unix 0 0
    where /dev/dsk/c5t2d0 is the CD-ROM device file and
    pfs-rripxlat=unix 0 0 indicates the CD-ROM is in
    Rockridge extention.
    prompt> nohup /usr/sbin/pfs_mountd &
    prompt> nohup /usr/sbin/pfsd &
    Note: Insert CD-ROM in tray.
    prompt> /usr/sbin/pfs_mount /cdrom
    prompt> exit
    Sun Solaris
    prompt> mount -r -F hsfs <device_name> /cdrom
    prompt> exit
    For AIX-Based System users only.
    Before installing the gateways from the CD-ROM, become root and run rootpre.sh.
    1. Log in as root and change directory to the CD-ROM mount point.
      prompt> su root
      prompt> cd <mount_point>
    2. Run rootpre.sh and exit root account.
      prompt> ./rootpre.sh
      prompt> exit
  3. Run Oracle Universal Installer from the CD-ROM.
    Be sure you are not logged in as the root user when you start the Oracle Universal Installer.  If you are, then only the root user will have permissions to manage Oracle9i Procedural Gateway for IBM MQSeries.
    1. Log in as the Oracle9i Procedural Gateway for IBM MQSeries user.
    2. Start the Oracle Universal Installer by entering:
      prompt> <mount_point>/runInstaller
This launches Oracle Universal Installer through which you can install Oracle9i Procedural Gateway for IBM MQSeries.
Previous Next
Oracle Logo
Copyright © 2001, 2002 Oracle Corporation
All rights reserved
Contents
Go To Index
Index
