Skip Headers
Oracle Enterprise Manager Administrator’s Guide
Release 9.2.0
Part Number A96670-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
9
Enterprise Security Management
This chapter describes the component of Oracle Enterprise Manager used to administer Enterprise User Security for the Advanced Security Option. The chapter explains use of Enterprise Manager within a simple scenario in which an Oracle Internet Directory Server is used as the central repository for users in a large organization. It contains the following sections
Overview of Enterprise Security Manager
Oracle Enterprise Security Manager provides an easy-to-use graphical interface to administer enterprise user security and access control for large numbers of databases in your enterprise environment through the Oracle Internet Directory server. You use Oracle Enterprise Security Manager to perform the following tasks:
You start this Enterprise Security Manager via the MS Windows Start menu, or by issuing the "esm" command on a UNIX command line. Upon logging in, Enterprise Security Manager appears as shown in Figure 9-1, "Enterprise Security Manager", given that the Directory contains at least the Oracle9i Default Oracle Context.
Figure 9-1 Enterprise Security Manager
Text description of screen0.gif follows.
Enterprise Security Manager manages one Directory Server, identified at the top of the main application tree. It has a series of menu operations that apply to this Directory Server.
Users are managed in the Directory using Enterprise Security Manager. The application shows the directory to which it is connected and allows you to add, delete and browse Users in that Directory. Enterprise Security Manager may also be used to manage Oracle Contexts in the Directory. An Oracle Context is an area of structured information in the Directory recognizable to Oracle8i and Oracle9i products as well as an administrator hierarchy for management of the data in Oracle Contexts for different Oracle product areas.
This chapter is presented in two parts; Administering U.0sers and Administering Oracle Contexts. It will use the example the "AppsOnline" Application Service Provider to illustrate both facets of Enterprise User Security management.
Introduction to Directory Servers
A Directory Server may be used a general purpose means to centralize definitions of user and server access information over an entire network. As well as storing naming information, the Directory may be employed to centralize password definitions, digital certificates and application authorizations for the users that it defines. This is possible, in the particular case of Oracle Internet Directory, as it allows for secured access and modification of sensitive information held in the Directory such as passwords or application authorizations.
This chapter shall use as its example an Application Service Provider called, "AppsOnline". AppsOnline has a large set of Oracle9i Databases that it uses to host different types of Application Software for its customers. AppsOnline needs to manage administrative access to these databases for its IT staff.
Figure 9-2 AppsOnline Hierarchy
Text description of appsonli.gif follows.
AppsOnline maintains Oracle9i databases upon which are hosted three types of Application for its customers; Human Resources, Inventory and Billing. One customer, "TaxTime.com" subscribes to AppsOnline for its Human Resources Applications. A second customer, "CelticTravel.com" subscribes to the company for its Billing Applications. A third company, "UKMusic.com" subscribes to the company for its Inventory Management Applications.
AppsOnline dedicates some of its databases to each customer and manages these databases on behalf of the customer. The company has used an Oracle Internet Directory to hold information about their own employees, the databases on which they host Applications, and the customers for whom they provide a service. In the course of their business, they may wish to manage administrative access to their databases by their IT employees and manage access rights to information in these databases based upon each type of customer Application that they support.
This chapter will illustrate how Oracle Enterprise Manager may be used in this example scenario.
Entailing and Configuring Your Enterprise Security Environment
Task 1: Configure an Oracle Internet Directory
Oracle9i Enterprise User Security is based wholly around an Oracle Internet Directory. The Directory Server must be properly installed and configured before Enterprise Manager may be used to manage Enterprise User Security. The following stages of Oracle Internet Directory configuration must be complete before proceeding
  1. Either an Oracle8i or Oracle9i Internet Directory is installed, running and accessible over both standard LDAP and Secure Sockets Layer enabled LDAP (LDAP/SSL). For more information please refer to the Oracle Internet Directory Administrators Guide.
  2. The Oracle Internet Directory has been configured to support Oracle9i Directory Schema Objects and contains an Oracle9i Default Oracle Context. In the case of a version 9i Oracle Internet Directory these requirements may already be in place. However, the Oracle9i Directory Schema Objects and Default Oracle Context may be configured on the Directory Server using The Oracle Net Configuration Assistant. For more information please refer to the Oracle Net Configuration Assistant Administrators Guide.
Task 2: Install Oracle Enterprise Manager
Oracle Enterprise Manager is automatically installed with the Oracle9i Enterprise Edition Server Install and includes all necessary functionality for Enterprise User Security. Oracle Enterprise Manager is also installed by default with the Oracle9i Infrastructure Install at the same time as Oracle Internet Directory. Oracle Enterprise Manager may also be installed separately in its own ORACLE_HOME using the custom install option.
Task 3: Configure Oracle Enterprise Manager for Enterprise User Security
Oracle Enterprise Manager may be used to manage Enterprise User Security in two modes of operation. The Oracle9i Enterprise Manager Console may be used to connect to the Oracle9i Management Server (OMS) and discover a Directory Server to manage. Alternatively, a dedicated application called, "Enterprise Security Manager" may be launched from the same ORACLE_HOME as Enterprise Manager and used to connect directly to the Directory Server. In either mode of operation functionality is identical. Only the latter mode, using the Enterprise Security Manager application, will be used in this chapter.
Enterprise Security Manager does not require any special configuration for it to run. However all Oracle Databases in the enterprise that need to avail of Enterprise User Security should be accessible over Oracle Net from the Enterprise Manager ORACLE_HOME.
Task 4: Start Oracle Enterprise Security Manager
To launch Enterprise Security Manager from the Enterprise Manager ORACLE_HOME, enter the following at the command line:
> esm
This will cause the Directory Log On box to appear
Figure 9-3 Directory Login Dialog
Text description of logon.gif follows.
Task 5: Log On To the Directory
Enterprise Security Manager offers three ways to connect to a Directory Server by selecting the appropriate option in the Log On Box. These options are listed in the table below
Table 9-1 Directory Connection Methods
Authentication Type Description
Password Authentication
Uses Simple Authentication requiring a distinguished name or a known directory nickname and a password
SSL Client Authentication
Uses two-way SSL Authentication in which both the client and server use Oracle Wallets containing digital certificates. The subsequent connection will then be encrypted.
Native Authentication
Applies only to Microsoft Windows NT or Windows 2000 and uses Operating System level authentication to log on to a Microsoft Active Directory
For example, Password Authentication may be selected when using the orcladmin Oracle Internet Directory super user name and password to log on.
Administering Users
Enterprise Security Manager may be used to Create Users in the Directory. This is done by selecting "Create Enterprise User..." from the Operations Menu.
Figure 9-4 Operations Menu
Text description of menu0.gif follows.
The Create User Window will appear in which to enter the name and location of the new User in the Directory.
Oracle Wallets
Oracle wallets are data structures that contain a user private key, a user certificate, and a set of trust points (the list of root certificates the user trusts). Enterprise Security Manager functionality pertaining to Oracle Wallets will only appear in the Create User or Edit User screens when running in an ORACLE_HOME that has been configured for this purpose to use Oracle PKI Products. First, you must generate a Certificate Signing Authority for Enterprise Security Manager. This is done by running "esm -genca" on the command line. The following example displays the expected output from running this utility.
> esm -genca
Generating CA Private Key. Please Wait..
Enter a Wallet Administrator Password to protect access
to your CA private key: test_password
A CA has been created for Enterprise Security Manager.
You must remember your Wallet Administrator Password. It is required
by Enterprise Security Manager to generate new Oracle Wallets.
When you use invoke esm -genca to generate a new CA for Enterprise Security Manager, a default identity will be created for your CA using 'ORACLE' as the value for all X500 name components of the CA certificate.
You may define your own individual values to be used for the CA identity by editing the ORACLE_HOME/sysman/admin/esmca.properties file.
You must run esm -genca again after modifying this file.
Specifying a new User Name
Figure 9-5 Create User Property Sheet: User Naming Page
Text description of user0.gif follows.
The following fields are mandatory for creation of a new User in the Directory:
Table 9-2 Create User Property Sheet: User Naming Page Mandatory Fields
Field Description
Base
The entry point in the Directory at which the new User will be created
First name
First half (Christian Name) of the new User's full name
Surname
Second half (Surname) of the new User's full name
User ID
The Logon identifier that the user may use to access databases and applications
The following additional fields are not mandatory for creation of a new User in the Directory but may be recorded for the new User if desired.
Table 9-3 Create User Dialog: Non-mandatory Fields
Field Description
Apply Suffix
This is the current value of any common user ID suffix that is always applied to the end of the User ID for a new User. For example, <User ID>.us.acme.com
Email Address
The email address to record in the Directory for the new User, if desired.
cn=
This is the Common Name component (cn=) of the Distinguished Name of the new User in the Directory. By default it is set to the full name of the new User, however you can override the value if you wish to force a particular value for the "cn=" portion of the User's Distinguished Name.
Specifying a Directory Base
All Users in the Directory must exist at a particular "Base" within the Directory. The Base can be any existing Directory Entry such as Country Entry (e.g "c=US") or an Organization Entry (e.g "o=Acme, c=US". Many Users would typically share the same Base. This Base identifies all the Users contained under it as belonging to the same high level organization.
The Base at which to create a new User can be entered in the Base field in the Create User screen. However, you may explore the entire Directory to choose a suitable Base by clicking on the Browse... button. The Browse Directory dialog will appear.
Figure 9-6 Browse Directory Dialog
Text description of user5.gif follows.
The Browse Directory screen lets you navigate the directory by drilling down into each entry from the top of the Directory Tree. When a Directory Entry is selected its Distinguished Name is placed in the Selection field. To accept the selected Distinguished Name choose the OK button. This value will then be returned as the selected Base for a new Directory User.
This value will be preserved for all subsequent operations that create or search for Users in the Directory. However you may change it as many times as you like.
Specifying a new User Password
The second Tab Panel of the New User screen allows you to set an initial password for the new User in the Directory. This will be the new User's initial password for:
Figure 9-7 Create User Property Sheet: Password Page
Text description of user1.gif follows.
When Entering a password you may choose to accept a default first time password for the new User or manually enter the first time password for the new User. In either case, the new User must change their own password immediately after its first use.
Specifying an Initial Enterprise Role Assignment
Enterprise Roles are discussed later in this Chapter. At the time of User creation you may select any previously configured Enterprise Roles and grant them to the new User.
Figure 9-8 Create User Property Sheet: Enterprise Roles
Text description of user2.gif follows.
To select one or more Enterprise Roles to grant to the new User at this time choose Add... in the Enterprise Roles page of the Create User screen. The Add Enterprise Roles Page will appear from which you can choose any Enterprise Roles in your Oracle Context to assign to the new User.
Figure 9-9 Add Enterprise Roles Dialog
Text description of user3.gif follows.
Specifying an Oracle Wallet
An Oracle Wallet containing a new Digital Certificate, Private Key and Certificate Trustpoints may be generated for the new User in an encrypted binary format. The Oracle Wallet will be stored with the new User in the Directory Server as part of the Directory Entry for the User.
This functionality is only available AFTER you have run the esm -genca command in your environment
Figure 9-10 Create User Property Sheet: Wallet
Text description of user4.gif follows.
The Distinguished Name under which the new User will be created is used by default as the Distinguished Name for the Digital Certificate to be contained in the new User's Oracle Wallet. It is always good practice to let the Distinguished Names of User Certificates correspond to their Distinguished Names in the Directory. However, you may edit the Distinguished Name to be used for the Certificate before generating the Wallet by editing the contents of the Issued For: field.
An Oracle Wallet will be created when you click on the Generate Wallet... button.
Browsing Users in the Directory
Enterprise Security Manager allows you to browse all Users that are currently stored in the Directory. This is done by selecting the All Users page from the Directory at the top of the main application tree
Figure 9-11 All Users Page
Text description of screen2.gif follows.
To Search for one or more users the directory, the Search Criteria must be set and the Search Now button used to perform a new search for Users based upon the given Search Criteria. The All Users page will refresh to show the results of this search. There are three factors to User Search Criteria:
Table 9-4
Search Criteria Affect on the Search
Base
This is the Base Entry in the Directory at which the search will be performed. Any Users returned in the search will exist under this Base in the Directory.
Include Subtrees
This determines whether to show all Users in the Directory anywhere under the selected Base or to only show those Users that exist specifically at that Base location in the Directory.
Show Names Containing
This limits the entire search to contain only those Users whose Directory Entries have a Common Name that starts with a specified pattern. This is useful if the exact name or Base of the desired User is not known.
For example, the Search Criteria may be set to search this Directory for a User given only that the Base is dc=oracle, dc=com and the first name is "Larry"
Figure 9-12 Base Search Criteria
Text description of screen3.gif follows.
After searching for Users in the Directory, any one user can be chosen from the list and edited. This is achieved either by selecting the User from the list in the All Users page and choosing the Edit... button or by double clicking on that User in the list.
Figure 9-13 Editing a User
Text description of screen5.gif follows.
When a User in the Directory is selected for Edit, its password, Enterprise Role assignments and Oracle Wallet can be modified in the same way as discussed during creation of a new User in the Directory.
An Oracle Context is a top level Entry in the Directory underneath which is contained the data used by any Directory aware Oracle product. Enterprise Security Manager allows you to manage database and security related information in the Directory under an Oracle Context.
Users do not need to be contained in the Directory within an Oracle Context. It is assumed that the Directory may define its Users for a wide variety of purposes. Oracle does not require that Users in a Directory to be created within an Oracle Context though it is still possible to do so.
Oracle Context Versions
An Oracle Context in the Directory may either be a version 8i or version 9i Oracle Context. For Enterprise User Security there is some functionality that can only be managed using a 9i Oracle Context, for example, "Password Authenticated Global Users". Enterprise Manager for Oracle9i may be used to manage version 9i Oracle Contexts as well version 8i Oracle Contexts in the Directory.
Oracle Enterprise Security Manager displays in its main application tree all the Oracle Contexts that exist in the Directory Server. It will display both version 9i and version 8i Oracle Contexts, should they exist. In the example below Enterprise Security Manager is connected to an Oracle Internet Directory that has been configured to support the Oracle9i Directory Schema and an Oracle9i Default Oracle Context.
Specifying Properties of an Oracle Context
An Oracle Context has a number of general properties that can be viewed and managed in the General page when an Oracle Context is selected on the tree:
Figure 9-14 Viewing an Oracle Context Properties
Text description of screen4.gif follows.
Table 9-5 Context Property Description
Directory Location
This is the Directory Base of the Oracle Context. In the case of the Default Oracle Context this value is empty as the Directory Base is the root of the Directory tree
Version
This identifies whether the Oracle Context supports 8i or 9i functionality
Common User Search Bases
This is the list of Base locations in the Directory at which Users may commonly exist. Identifying a list of User Search Bases allows you to quickly browse the users at those Directory Locations and also indicates to 9i Databases in the Oracle Context where they may find Directory Users that connect to them.
User ID
This is the name of the Attribute in a User Entry that determines the value of that Users's User ID. User Entries have many different attributes. This setting controls the User ID with which Users can authenticate to Oracle9i databases, Directory Servers or Directory enabled Applications. Its default value is, "cn", the Common Name of the Directory User.
Application GUID
This is the name of the Attribute in a User Entry in which unique Application GUID values will exist. It cannot be modified in this release
Password Policy
This is the Password Policy syntax used by Oracle9i database when authenticating Password Authenticated Global Users. It cannot be modified in this release.
Specifying User Search Bases
User Search Bases can be added to or removed from a version 9i Oracle Context using the Oracle Context General page.
This functionality is not available in version 8i Oracle Contexts.
To remove a User Search Base from the Oracle Context:
  1. Select a Search Base in the Common User Search Bases List and choose Remove... The Search Base will be removed from the List.
  2. Choose Apply; the User Search Base will be removed from the Oracle Context in the Directory
To add a new User Search Base to an Oracle Context:
  1. Choose Add... The Common User Search Bases screen will appear.
Figure 9-15 User Search Base Dialog
  • Navigate the Directory to select a desired Directory Entry as a User Search Base. You may also edit the contents of the Selection field in this screen to manually define the User Search Base.
  • Choose OK in the Common User Search Bases screen. The selected Entry will be added to the list of User Search Bases in the Oracle Context General Page.
  • Choose Apply; the User Search Base will be added to the Oracle Context in the Directory
    Specifying Oracle Context Administrators
    An Oracle Context may define sets of Directory Users that are enabled as different categories of Administrator. Each category has varying levels of privilege for operations within an Oracle Context. Some administrator categories are only available to version 9i Oracle Contexts and some are available to both version 8i and version 9i Oracle Contexts. The Administrator Categories for an Oracle Context are as follows:
    Table 9-6 Oracle Context Administrator Categories
    Administrator Category Definition Version 9i Version 8i
    Full Context Management
    All possible Administrator privileges for all product areas in the Oracle Context
    YES
    NO
    Directory User Management
    Ability to view Directory User password reminders
    YES
    NO
    Database Security Management
    Ability to manage all Enterprise Domains and Enterprise Roles in the Oracle Context
    YES
    YES
    Database Registration
    Ability only to register a new database in the Oracle Context
    YES
    YES
    Oracle Net Management
    Ability to manage Oracle Net objects in the Oracle Context
    YES
    NO
    Oracle Context Administrators are managed using the Administrators Page of an Oracle Context selected on the main application tree.
    Figure 9-16 Oracle Context: Administrators Page
    Text description of screen6.gif follows.
    To remove a User from a list of Oracle Context Administrators:
    1. Choose the type of Administrator to remove from the Categories combo box. The list of Administrators will refresh to show those of the type that you have selected.
    2. Select a User by clicking on that User in the list of Administrators.
    3. Choose Remove. The selected User will be removed from the list.
    4. Choose Apply; the User will be removed as an Oracle Context Administrator of the category that you have selected.
    To add a new User a list of Oracle Context Administrators:
    1. Choose Add... The Add Users screen will appear. This page is used to locate and select one or more Users in the Directory. There are three components to the page. At the top is a Directory Search Tree. In the middle are Search Criteria controls that identify the Users to be returned by the search. At the bottom of the page is the result of the search from which one or more desired Users may be selected.
    Figure 9-17 User Search Results
    Text description of screen7.gif follows.
  • Set the "Include Subtrees" Search Criteria option. The effect of selecting this option will be to search for Users not only as the specified Base but also in all possible levels underneath that Base in the Directory.
  • Enter any known User Name in the Show Names Containing field to which Users returned by the search must conform. The effect of using the Show Names Containing field is to limit the search only to Users in the Directory who have a Common Name value that is or starts with the specified text.
  • Choose Search Now. If there are any Users in the Directory at the Base you have selected that match your Search Criteria they will be listed in the screen.
  • Select the desired User either by clicking on the it in the list and choosing OK or by double clicking on it. Multiple Users can be selected from the list by selecting a range of Users and choosing OK. The new Users will then appear in the list of Administrators under the category that you have selected.
  • Choose Apply; the new Administrators will be added to the Oracle Context in the Directory under the category that you have selected.
    This screen is used at all points in Enterprise Security Manager where it is necessary to choose one or more Users from the Directory.
    Accessible Domains
    When an Oracle Context is selected in the main application tree you may manage the list of Enterprise Domains within that Oracle Context whose databases may accept password authenticated connections from users that have their "Database Access Restriction" enabled. To add an Enterprise Domain to the list choose "Add.." and select one of the current Enterprise Domains from the resulting dialog. To remove an Enterprise Domain from the list, select it in the Accessible Domains page and choose "Remove..."
    A "Database Access Restriction" may be applied to whole subtree of Users in the Directory when it is selected under the "Users, by Search Base" tree under an Oracle Context. With this option is set, all users under that subtree may only use their passwords to access databases that exist in Enterprise Domains that have been included in the list of Accessible Domains for the Oracle Context.
    The default condition for any Enterprise Domain is not to be a member of the Accessible Domains for its Oracle Context. By identifying any Enterprise Domain to be one of the Accessible Domains and also by electing certain Users to have a Database Access Restriction, you are enforcing that it is only certain known databases that may access those Users' database logon settings in the Directory.
    This feature is only available to version 9 Oracle Contexts.
    Managing Database Security
    The Directory may be used as a central repository that controls authentication and authorization on multiple databases for Users. Enterprise Security Manager allows you to manage an Oracle Context in the Directory for the purpose of database security.
    Oracle8i or 9i Databases are published to the Directory within an Oracle Context using the Oracle Database Configuration Assistant. For more information see the Oracle DBCA Guide. Once databases have been published to the Directory, Enterprise Security Manager may be used to mange User access to those databases. This is achieved using the following Objects in the Oracle Context:
    Table 9-7 Oracle Context Objects
    Object in the Oracle Context Description
    Database
    This is a Directory Entry representing a published database.
    Enterprise Domain
    This is a grouping of databases published in the Directory upon which a common User access model for database security can be implemented
    Enterprise Role
    This is an Authorization that spans multiple databases within an Enterprise Domain. It is an "Enterprise Level" Role to which can be granted individual roles on each of the databases in an Enterprise Domain.
    Enterprise Security Manager displays Databases and Enterprise Domains in its main application tree. Using our example of the AppsOnline Application Service provider, each of the company's databases have been published into the 9i Default Oracle Context in the Directory.
    Registering a Database with an Oracle Context
    You register a database with an Oracle Context by selecting Register Database from the Enterprise Security Manager Operations menu. Selecting this menu option displays the Register Database dialog (shown in the following figure).
    Figure 9-18 Register Database Dialog
    Text description of regdb.gif follows.
    In addition to selecting the Oracle Context in which the database will reside, database registration also entails supplying the requisite connect information, as shown in the figure above. From this dialog, you can specify a database in one of three ways:
    Figure 9-19 Security Manager Application Tree
    Text description of screen8.gif follows.
    In this example AppsOnline manages Oracle9i databases that host Applications for three customers; "UKMusic.com", "CelticTravel.com" and "TaxTime.com". Applications for UKMusic are hosted using databases INV11i-1 and INV11i-2. Applications for CelticTravel are hosted using databases BILL11i-1 and BILL11i-2. Applications for TaxTime are hosted using databases HR11i-1, HR11i-2, HR11i-3 and HR11i-4.
    Given that the types of application hosted for each customer are different, only those databases that are used to support a common application type implement the same security model for their User Access. AppsOnline has decided to define three Enterprise Domains, one for each customer that it services.
    Administering Databases
    After a database has been published to an Oracle Context in the Directory, Enterprise Security Manager may be used to view and modify security characteristic of that database.
    Managing Database Administrators
    An Database Administrator is a Directory User that only has privileges to modify that Database in the Oracle Context. Database Administrators may be managed using the Administrators Page when a Database is selected under an Oracle Context in the main application tree.
    To remove a User from the list of Database Administrators:
    1. Select a User by clicking on that User in the list of Administrators.
    2. Choose Remove. The selected User will be removed from the list.
    3. Choose Apply; the User will be removed as an Database Administrator for that database in the Oracle Context.
    To add a new User to the list of Enterprise Domain Administrators:
    1. Choose Add... The Add Users screen will appear. This page is used to locate and select one or more Users in the Directory as discussed earlier. Select one or more desired users from the Directory to add as Database Administrators. The new Users will then appear in the in the Administrators Page.
    2. Choose Apply; the new Administrators will be added to the database in the Oracle Context.
    Managing Database Schema Mappings
    Database Schema Mappings allow databases that are registered in the Directory to accept connections from users without having any dedicated database schemas for them. For example, when user SCOTT connects to a database there must actually exist a database schema called "SCOTT" for that log on to be successful. This becomes difficult to maintain if there are thousands of Users and perhaps hundreds of databases in a very large enterprise.
    Users that exist in the Directory do not need to have dedicated schemas on every Oracle8i or 9i database to which they might connect.
    A database may use a "Schema Mapping" to share one database schema between any number of Users that exist in the Directory. The Schema Mapping is a pair of values; the Base in the Directory at which Users exist and the name of the database schema that they will use.
    Figure 9-20 Database Schema Mappings
    Text description of intdir.gif follows.
    Database Schema Mappings may be managed using the Database Schema Mappings Page when a database is selected under an Oracle Context in the main application tree. This page contains a list of database schema name and Directory Base pairs.
    Figure 9-21 Database Schema Mapping Page
    Text description of screen16.gif follows.
    To remove a Mapping from the list of Database Schema Mappings n the Enterprise Domain:
    1. Select a Mapping by clicking on that Mapping in the list.
    2. Choose Remove. The selected Mapping will be removed from the list.
    3. Choose Apply; the Mapping will be removed from the Enterprise Domain and no longer used by any databases in the Enterprise Domain.
    To add a new Mapping to the list of Database Schema Mappings in the Enterprise Domain:
    1. Choose Add... The Add Database Schema Mappings screen will appear. This page is used to locate and select one Base in the Directory and pair it with a database schema name to make a Database Schema Mapping. There are two components to the page. There is a Directory Search Tree from which to select a Base and a field in which to enter a schema name.
    Figure 9-22 Add Database Schema Mappings
    Text description of screen15.gif follows.
  • Navigate the Directory to select a desired Directory Entry as a Base for the Database Schema Mapping. This may be any Directory Entry but should be above the subtree of Users in the Directory for which you want t o perform the mapping. You may also edit the contents of the Selection field in this screen to manually define this Base.
  • Enter the name of the database schema for which this Mapping will be made and choose OK. This must be a valid name for a schema that already exists on that database.The new Database Schema Mapping will then appear in the Database Schema Mappings Page.
  • Choose Apply; the new Database Schema Mapping will be added to the selected database in the Oracle Context.
    Administering Enterprise Domains
    An Oracle Context will always contain at least one Enterprise Domain called, "OracleDefaultDomain". The OracleDefaultDomain is part of the Oracle Context when it is first created in the Directory. When a new database is registered into an Oracle Context it automatically becomes a member of the OracleDefaultDomain in that Oracle Context. You may create and remove your own Enterprise Domains but you cannot remove the OracleDefaultDomain from an Oracle Context.
    To create a new Enterprise Domain:
    An Enterprise Domain can be created in an Oracle Context either from the Operations Menu or by using a Right Mouse Button click on an Oracle Context selected in the main application tree:
    Figure 9-23 Creating an Enterprise Domain
    Text description of screen9.gif follows.
    The Create Enterprise Domain screen will appear.
    Figure 9-24 Create Enterprise Domain Dialog
    Text description of screen10.gif follows.
    1. Choose the Oracle Context in which the Enterprise Domain is to be created from the Oracle Context drop down list. If the Create Enterprise Domain screen has been invoked using a Right Mouse Button click from an Oracle Context in the main application tree then the name of that Oracle Context will already be selected.
    2. Enter the name of the new Enterprise Domain in the Domain Name filed.
    3. Choose OK. The new Enterprise Domain will be created in the Oracle Context and appears on the main application tree.
    To remove an Enterprise Domain:
    1. Click on the Enterprise Domain to remove in the main application tree.
    2. Choose Remove Enterprise Domain either from the Operations Menu or by using a Right Mouse Button Click on the Enterprise Domain in the main application tree.
    Figure 9-25 Remove Enterprise Domain Menu Option
    Text description of screen11.gif follows.
  • Enterprise Security Manager will ask you to confirm the operation before the Enterprise Domain is removed from the Oracle Context.
    You cannot remove an Enterprise Domain from an Oracle Context if that Enterprise Domain still contains any Enterprise Roles.
    Specifying Database Membership of an Enterprise Domain
    Database membership of an Enterprise Domain in the Oracle Context may be managed using the Databases Page when an Enterprise Domain is selected on the main application tree:
    Figure 9-26 Security Manager Databases Page
    Text description of screen12.gif follows.
    To remove a database from an Enterprise Domain:
    1. Select a database in the list and choose Remove... The database will be removed from the list.
    2. Choose Apply; the database will be removed from the Enterprise Domain in the Oracle Context.
    To add a database to an Enterprise Domain:
    You may only add databases as members of an Enterprise Domain that exist in the same Oracle Context as the Enterprise Domain. An Enterprise Domain cannot contain as its members, databases published in a different Oracle Context. Neither can any database in an Oracle Context be added as a member of two Enterprise Domains.
    1. Choose Add... The Add Databases screen will appear. This screen lists all the databases in the Oracle Context
    Figure 9-27 Add Databases Dialog
    Text description of screen13.gif follows.
  • Select a database to add as a new member of the Enterprise Domain.
  • Choose OK in the Add Databases screen. The selected database will be added to the list of databases in the Databases Page.
  • Choose Apply; the new database will be added to the Enterprise Domain in the Oracle Context.
    Managing Database Security Options for an Enterprise Domain
    The Databases Page may be used to manage database security options that will apply to all the databases that are members of the Enterprise Domain. These options are as follows:
    Table 9-8
    Database Security Option Description
    Enable Current User Database Links
    Any pair of databases will only allow use of Current User Database Links if they exist in an Enterprise Domain in which this setting is enabled.
    User Authentication
    All databases in the Enterprise Domain will enforce the type of authentication that its clients must use based on this property. Its values are:
    • Password Authentication only.
    • Oracle Net SSL Authentication only using Oracle Wallets.
    • Either Password or Oracle Net SSL Authentication.
    Managing Enterprise Domain Administrators
    An Enterprise Domain Administrator is a Directory User that only has privileges to modify the content of that Enterprise Domain. Enterprise Domain Administrators may be managed using the Administrators Page when an Enterprise Domain is selected under an Oracle Context in the main application tree.
    To remove a User from the list of Enterprise Domain Administrators:
    3. Choose Apply; the User will be removed as an Enterprise Domain Administrator for that Enterprise Domain in the Oracle Context.
    1. Choose Add... The Add Users screen will appear. This page is used to locate and select one or more Users in the Directory as discussed earlier. Select one or more desired users from the Directory to add as Enterprise Domain Administrators. The new Users will then appear in the Administrators Page.
    2. Choose Apply; the new Administrators will be added to the Enterprise Domain in the Oracle Context.
    Managing Enterprise Domain Database Schema Mappings
    Database Schema Mappings may be managed for each database in an Oracle Context as discussed earlier. Schema Mappings may also be performed for each Enterprise Domain in an Oracle Context using the Database Schema Mappings Page with an Enterprise Domain selected in the main application tree. These Mappings apply to all databases that are members of the Enterprise Domain. Therefore, each database in the Enterprise Domain must have a schema of the same name used in the Mapping.
    Figure 9-28 Matching Database and Schema Names Used in the Mappings
    Text description of screen14.gif follows.
    To remove a Mapping from the list of Database Schema Mappings in the Enterprise Domain:
    1. Choose Add... The Add Database Schema Mappings screen will appear. This page is used to locate and select one Base in the Directory as discussed earlier. Enter a new Database Schema Mapping to add to the Enterprise Domain.
    2. Choose Apply; the new Database Schema Mapping will be added to the Enterprise Domain selected in the Oracle Context.
    Administering Enterprise Roles
    An Enterprise Domain within an Oracle Context may contain one or more Enterprise Roles.
    In the example discussed earlier, AppsOnline has created three Enterprise Domains that group the databases it uses to serve each of its customers. This permits the company to define Enterprise Roles for each Enterprise Domain. An Enterprise Role is a set of Oracle Role based authorizations across on or more databases in an Enterprise Domain.
    A simple Enterprise Role is defined by AppsOnline for DBA privileges on its databases in the "Tax Time" Enterprise Domain:
    Figure 9-29 "Tax Time" Enterprise Domain
    Text description of taxtime.gif follows.
    Creating a new Enterprise Role:
    An Enterprise Role can be created in an Enterprise Domain either from the Operations Menu or by using a Right Mouse Button click on an Enterprise Domain selected in the main application tree:
    Figure 9-30 Enterprise Role Creation
    Text description of screen17.gif follows.
    The Create Enterprise Role dialog appears.
    Figure 9-31 Create Enterprise Role Dialog
    Text description of screen18.gif follows.
    1. Choose the Oracle Context containing the Enterprise Domain in which the new Enterprise Role is to be created from the Oracle Context drop down list. If the Create Enterprise Role screen has been invoked using a Right Mouse Button click from an Enterprise Domain selected in the main application tree, then the name of that Oracle Context will already be selected.
    2. Choose the Enterprise Domain in which the new Enterprise Role is to be created from the Enterprise Domain list. If the Create Enterprise Role screen has been invoked using a Right Mouse Button click from an Enterprise Domain selected in the main application tree, then the name of that Enterprise Domain will already be selected.
    3. Enter the name of the new Enterprise Role in the Role Name filed.
    4. Choose OK. The new Enterprise Role will be created in the Enterprise Domain and appears on the main application tree.
    Removing an Enterprise Role:
    1. Click on the Enterprise Role to remove in the main application tree.
    2. Choose Remove Enterprise Role either from the Operations Menu or by using a Right Mouse Button Click on the Enterprise Domain in the main application tree.
    Figure 9-32 Removing an Enterprise Role
    Text description of screen19.gif follows.
  • Enterprise Security Manager will ask you to confirm the operation before the Enterprise Role is removed from the Enterprise Domain.
    Specifying Database Global Role Membership of an Enterprise Role
    Database Role membership of an Enterprise Role in an Enterprise Domain may be managed using the Database Global Roles Page when an Enterprise Role is selected on the main application tree. This page lists the names of each Global Role that belongs to the Enterprise Role along with the name of the database on which that Global Role exists.
    Figure 9-33 Database Global Roles Page
    Text description of screen20.gif follows.
    When populating an Enterprise Role with different database roles it is only possible to reference roles on databases that are configured to be "Global Roles" on those databases. A Global Role on a database is identical to a normal Role, except that the administrator of the database has elected it only to be authorized via the Directory. A database administrator cannot locally grant and revoke Global Roles to users of the database.
    Removing a Database Global Role from an Enterprise Role:
    1. Select a Global Role in the list and choose Remove... The Global Role will be removed from the list.
    2. Choose Apply; the Global Role will be removed from the Enterprise Role in the Enterprise Domain.
    Adding a Global Role to an Enterprise Role:
    1. Choose Add... The Add Database Global Roles screen will appear. This screen lists all the databases in the Enterprise Domain from which Global Roles may be selected to add to this Enterprise Role
    Figure 9-34 Add Global Database Roles Dialog Text description of screen21.gif follows.
    1. Select a database from which to obtain Global Roles. A screen will appear in which you must enter logon details to authenticate to the database and fetch Global Roles. Typically this would be a DBA logging on to that database.
    Figure 9-35 Database Logon
    Text description of screen22.gif follows.
    The name of the database appears in the Service field by default.You may use this name to connect to the database if your ORACLE_HOME has LDAP enabled as it Oracle Net Naming method or if this name appears as a TNS alias in your local Oracle Net configuration. Otherwise you may overwrite the content of the Service field with any other TNS alias configured for that database or by a connect string in the format:
    <host>:<port>:<oracle sid>
    For example, "cartman:1521:broncos"
    1. Choose OK. Enterprise Security Manager will connect to the given database and fetch the list of Global Roles supported on that database. The list of values, if any, will appear in the Add Database Global Roles screen.
    Figure 9-36 Add Global Database Roles Dialog
    Text description of screen23.gif follows.
  • Select on or more of the Global Roles from the list of returned values and choose OK. These Global Roles will then appear in the Database Global Roles Page
  • Choose Apply; the new Global Roles will be added to the Enterprise Role in the Enterprise Domain.
    Managing Enterprise Role Grantees
    An Enterprise Role Grantee is a Directory User to whom has been granted an Enterprise Role and therefore all database Global Roles contained within that Enterprise Role. Enterprise Role Grantees may be managed using the Enterprise Users Page when an Enterprise Role is selected under an Enterprise Domain in the main application tree.
    Removing a User from the List of Enterprise Role Grantees:
    1. Select a User by clicking on that User in the list of Grantees.
    3. Choose Apply; the User will be removed as a Grantee for that Enterprise Role in the Enterprise Domain.
    Adding a New User to the list of Enterprise Role Grantees:
    1. Choose Add... The Add Users screen will appear. This page is used to locate and select one or more Users in the Directory as discussed earlier. Select one or more desired users from the Directory to add as Enterprise Role Grantees. The new Users will then appear in the Enterprise Users Page
    Figure 9-37 Enterprise Users Page
    Text description of screen24.gif follows.
  • Choose Apply; the new Grantees will be added to the Enterprise Role in the Enterprise Domain.
    Enterprise Role Grantees will also appear in the Enterprise Users tree under a selected Enterprise Role. A User selected on this tree can be edited as discussed in Part 1.
    Figure 9-38 Enterprise Role Grantees
    Text description of screen25.gif follows.
    Command Line Tool
    In addition to the graphical user interface, Enterprise Security Manger also provides a full-featured command line interface that allows you to perform security administration operations from other applications or from custom scripts.
    Command line operations are invoked using the "esm" control utility. For example:
    esm -cmd [operation] [options]
    esm -cmd help [operation]
    A complete list of operations and options, including definitions and usage syntax, is available online by invoking the tool's online help from the command line.
    >esm -cmd help
    The following example shows the help output.
    Example 9-1 Command Line Help Output
    Usage :
    Operations :
    [search, createUser, deleteUser, createWallet, createDomain, deleteDomain, createRole,
    deleteRole, grantEnterpriseRole, revokeEnterpriseRole, addGlobalRole, removeGlobalRole,
    addContextAdministrator, removeContextAdministrator, addPasswordAccessibleDomain,
    removePasswordAccessibleDomain, addDomainAdministrator, removeDomainAdministrator,
    addDomainDatabase, removeDomainDatabase, addDatabaseAdministrator,
    removeDatabaseAdministrator, createMapping, removeMapping]
    Options :
    (* mandatory)
    -U         SSL Authentication Mode - Should be SIMPLE / SSL / NATIVE
    -h         LDAP Server *
    -p         LDAP Server Port *
    -D         Bind DN (required for SIMPLE Login)
    -w         Bind Password (required for SIMPLE Login)
    -W         Wallet Location (required for SSL Login)
    -P         Wallet Password (required for SSL Login)
    -dn        DN * (for user, domain, enterprise role, context or database)
    -objectType Type of Object for search [user | database | domain | enterpriseRole |
    context | schemaMapping | database | domainDatabase | fullContextAdministrator |
    directoryUserAdministrator | oracleNetAdministrator | databaseSecurityAdministrator |
    databaseRegistrationAdministrator | databaseAdministrator | domainAdministrator]
    -firstname          User First Name
    -lastname           User Last Name
    -userID             User ID
    -password           User Directory Authentication Password
    -wcheck             User Wallet Check (true / false)
    -context            Oracle Context DN
    -userDN             User DN (required for assign / revoke operations)
    -domainDN          Domain DN (required for assign / revoke operations)
    -adminType          Administrator Type [context | user | databaseSecurity |
    databaseInstall
    | network]
    -databaseRoleDN     Database Global Role (in format <Database
    DN>,GlobalRole=<GlobalRoleDN)>
    -databaseDN         Database DN (required for assign / revoke operations)
    -walletPwd          Wallet Password (required for Wallet creation)
    -rootPwd            Root Password (required for Wallet Creation)
    -target             Mapping Target Schema
    -value              Mapping Directory Entry
    -level              Mapping Level [1 (Entry)| 0 (Subtree)]
    You may also display help pertaining to a specific Enterprise Security Manager operation by specifying the exact operation along with the help command:
    esm -cmd help <operation>
    Help for specific operations provides a usage sample. For example, executing "esm -cmd help createUser" from the command line displays the following help text:
    Usage :
    Operations :
    createUser
    Options :
    (* mandatory)
    -h                  LDAP Server *
    -dn                 User DN *
    -firstname          User First Name *
    -lastname           User Last Name *
    -userID             User ID
    Example :
    esm -cmd createUser -U SIMPLE -D orcladmin -w welcome -h dlsun1279.us.oracle.com -p 389
    -dn
    cn=TestUser -firstname Test -lastname User -userID RM -password testpass -wcheck false
    An example of how the command line tool can be used is provided with your Enterprise Manager installation. The shell script "esmdemo" is located in the ORACLE_HOME/sysman/admin directory and showcases Enterprise Security Manager command line usage. Running this script performs sample operations using the command line tool. View the contents of this script to see working examples of how the command line tool can be used.
  • Go to previous page Go to next page
    Oracle
    Copyright © 1996, 2002 Oracle Corporation.
    All Rights Reserved.
    Contents
    Go To Index
    Index
