Oracle9i Enterprise Edition System Administration Guide
Release 2 (9.2.0.1.0) for OS/390
Part Number A97313-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
B
Operating System Dependent Variables
This appendix contains the OS/390-specific allowed, default, and maximum values for Oracle initialization and storage parameters. For a complete discussion of these parameters, refer to the Oracle9i Database Reference. To find out which parameters described in Oracle9i Database Reference are supported or not supported by Oracle9i for OS/390, refer to the Oracle9i Enterprise Edition Installation Guide for OS/390.
The topics in this appendix include:
Initialization Parameters with OS/390-Specific Defaults or Limits
Table B-1 Initialization Parameters
Parameter  Default  Maximum  Minimum
COMMIT_POINT_STRENGTH
N/A
N/A
DB_BLOCK_SIZE
4096
32768
4096
DB_FILE_MULTIBLOCK_READ_COUNT
Derived
256
LOG_BUFFER
16384
Limited by address space size
N/A
NLS_LANGUAGE
AMERICAN
N/A
N/A
NLS_TERRITORY
AMERICA
N/A
N/A
PROCESSES
Derived
N/A
SORT_AREA_SIZE
65536
Limited by available session memory
N/A
TRANSACTIONS_PER_ROLLBACK_SEGMENT
34
N/A
Note: N/A means that the platform-specific value is the same as the generic value.
You can separate the keywords with commas or blanks.
Database Limits
Except for control files, Oracle database files (including log, tablespace, and other files) are limited to 4 gigabytes each in size. Control files are limited to 20,000 logical blocks of size DB_BLOCK_SIZE.
A maximum of 255 redo log files can be specified for a database.
A database can contain up to 65, 534 datafiles over all tablespaces. A single tablespace is limited to 4094 datafiles.
SQL Language Parameters
CREATE CONTROLFILE
Table B-2 CREATE CONTROL FILE Parameters
MAXDATAFILES
32
65534*
N/A
MAXINSTANCES
15
N/A
MAXLOGFILES
32
256
N/A
MAXLOGMEMBERS
N/A
MAXLOGHISTORY
100
65534
N/A
*Specifying MAXDATAFILES larger than 40,000 requires using a database default blocksize (DB_BLOCK_SIZE INITORA parameter value) of 8K or larger.
CREATE DATABASE
Table B-3 CREATE DATABASE Parameters
DATAFILE
Refer to "Oracle Database Files"
N/A
16K or one VSAM control area, whichever is larger
LOGFILE
N/A
N/A
MAXDATAFILES
32
65534*
N/A
MAXINSTANCES
15
N/A
MAXLOGFILES
32
256
MAXLOGMEMBERS
N/A
MAXLOGHISTORY
N/A
N/A
N/A
Storage Parameters
The maximum values for DATAFILE, MINEXTENTS, NEXT, OPTIMAL, and PCTINCREASE are all limited by file size, which is limited by the size of the disk device.
Oracle
Copyright © 2002 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
