Skip Headers
Oracle9i Database Platform Guide
Release 2 (9.2) for Windows
Part No. B10163-01
Go To Table Of Contents
Contents
Go To Index
Index
Previous Next
A Getting Started with Your Documentation
Your Oracle documentation set is provided in both HTML and PDF formats on two CDs, both included in your CD Pack and labeled as follows:
Use the first CD-ROM to browse the library from the CD or copy files directly to a local system. Use the second CD-ROM to install the documentation library with Oracle Universal Installer. The contents of the library are the same on both discs.
The library includes a Web-based search tool that enables you to search for information about a particular product, parameter, file name, procedure, error message, or other area of interest. The search tool also makes it possible to construct a "virtual book" drawn from the complete documentation library, but consisting only of topics and procedures relevant to your needs. The library also includes a comprehensive Master Index, as well as lists of SQL and PL/SQL keywords, initialization parameters, catalog views, and data dictionary views.
Instructions for installing the library and viewing its contents are in three README files at the root level of the documentation CD-ROMs:
The contents of the three files are identical; only the format differs.
The Online Documentation Library CD-ROMs are not shipped with Oracle9i release 2 (9.2.0.2) for 64-bit Windows. For information on how to access Oracle9i documentation, see "Oracle9i release 2 (9.2.0.2) for 64-bit Windows Documentation".
The following guides are not included on Oracle9i Online Documentation Library CD-ROM for Windows:
Previous Next
Oracle Logo
Copyright © 2003 Oracle Corporation
All rights reserved
Contents
Go To Index
Index
