Skip Headers
Oracle 9i Reports Release Notes (Patch 1)
Release 2 (9.0.2)
Part Number B10221-01
Go To Table Of Contents
Contents
Go to previous page
6
Oracle Express Pluggable Data Source
This chapter describes how to configure and use the Express Pluggable Data Source with Oracle9i Reports Developer.
6.1 Before You Begin
To use the Express Pluggable Data Source within Oracle9i Reports Developer, you must connect to a supported Express Server version, which are versions 6.2.x and 6.3.x. When you install Reports9i, SNAPI 9.0.1 is automatically installed to enable connections to these Express Server versions.
Before creating reports using Express data, verify that you have completed all the necessary configuration steps. See the configuration topics in the Help system by searching for "configuring the Express data source."
In the Help topic called "About Configuring the Express Data Source," it mentions that the Express Connection Editor is installed with Reports. This is no longer the case, and you must take the appropriate steps to ensure that you can connect to Express Server, either by using the Express Connection Editor to create connection files or by creating them manually. See the section "Preparing for Express Connections" later in this document.
6.2 Preparing for Express Connections
6.2.1 Creating connection files
To create reports of Express data, you must be able to connect to an appropriate Express Server instance. To connect to an instance of Express Server, you use a connection file, which is a simple text file with the XCF extension. Each connection file defines a single connection to Express Server. A file called xconnect.ini specifies where connection files are located.
You can create connection files manually or you can use a utility called the Express Connection Editor to assist you in creating these files. The following list outlines the ways to create and use connection files, which are explained in detail below.
6.2.2 Related information
This document includes samples of three types of connection files in a later section.
For complete information on connecting to Express Server and on the Express Connection Editor, consult the following sources:
6.2.3 Using an already installed version of the Express Connection Editor
If you already have the Express Connection Editor installed, then you can simply use that version to create an XCF with which you can connect to Express Server. You might not have to create any XCF files, if the appropriate ones have already been created. Use the following procedure to use the already installed Express Connection Editor with Oracle9i Reports.
To use an existing Express Connection Editor installation:
  1. Navigate to the /olap subdirectory in the Oracle home directory for Oracle9i Reports Developer.
  2. Within the /olap subdirectory, create a subdirectory called ecf901.
  3. To the newly created ecf901 subdirectory, copy the xconnect.ini file from the installation directory of the Express Connection Editor.
  4. Open the xconnect.ini from the ecf901 subdirectory in a text editor. Ensure that the ConnectionPath setting points to whatever directory or directories hold the connection files that you plan to use for connecting to Express Server from Oracle9i Reports Developer. Use these files or use the Express Connection Editor to create other connection files.
Tip: Use semicolons to separate multiple directory specifications for ConnectionPath, if you want to store connection files in multiple locations.
6.2.4 Downloading a file from OTN to install just the Express Connection Editor
If you do not already have the Express Connection Editor installed, then you can download the necessary files. Use the following procedure to download the file and install the Express Connection Editor.
To download a file and install the Express Connection Editor:
  1. In a Web browser, access the Oracle Technology Network (http://otn.oracle.com).
  2. Navigate to the Oracle9i Reports Developer area.
  3. Download the file with which you can install the Express Connection Editor.
  4. Unzip the downloaded file and use the setup.exe file to run the installation program to install just the Express Connection Editor.
Important: Ensure that you install the Express Connection Editor in the same Oracle home directory into which Oracle9i Reports Developer is installed.
Once the Express Connection Editor is installed, you can use it to create connection files.
6.2.5 Install just the Express Connection Editor from the Express Client CD
If you do not already have the Express Connection Editor installed, then you can use the Express Connection Editor that is supplied with the Express Client products. You can obtain a CD for the Express Client products or download a file that contains them. Use the following procedure to install just the Express Connection Editor.
To install just the Express Connection Editor:
  1. Run the installation program by using the Express Client CD or by accessing the Express Server area of the Oracle Technology Network (http://otn.oracle.com/software/products/exp_server/htdocs/winsoft.html) and following the directions there.
  2. In the appropriate location in the installation program, specify the same Oracle home directory into which Oracle9i Reports is installed.
  3. Select a custom installation.
  4. Select the Oracle Express Connection Editor in the Available Product Components page.
  5. Complete the other pages of the installation as appropriate.
6.2.6 Create the files manually using a text editor
If you do not already have the Express Connection Editor installed and you do not want to install it, then you can create XCF files manually using a text editor. You must also create the xconnect.ini file, which specifies the location of the XCF files.
To create an XCF file manually:
  3. In this document, locate the sample file that is closest to the XCF file that you need to create.
  4. Open a text editor such as Microsoft Notepad.
  5. Either cut and paste the text from this document or type the text of the XCF file into the text editor.
  6. Edit the settings of the file as appropriate, using the information that is provided in the section "XCF file settings," later in this document.
  7. Save your changes, giving the file any name that you want and including the XCF extension. Ensure that you save the file into the /olap/ecf901 subdirectory in the Oracle home directory for Oracle9i Reports Developer.
  8. Begin the process of creating the xconnect.ini file by creating an empty document in a text editor such as Microsoft Notepad.
  9. Edit the file to contain the following contents, substituting the name of the Oracle home directory for Oracle9i Reports Developer for ORACLE_HOME:
    [General]
    ConnectionPath=d:\ORACLE_HOME\olap\ecf901;
  1. Save your changes, naming the file xconnect.ini. Ensure that you save the file into the /olap/ecf901 subdirectory in the Oracle home directory for Oracle9i Reports Developer.
6.2.7 XCF file settings
The following table briefly describes the main settings in any XCF file. The next table describes the settings that apply only to connections through Oracle Express Relational Access Manager. All these settings are described in more detail in the Help system for the Express Connection Editor and in the Oracle Express Database Administration Guide.
Table 6-1 XCF File Settings
Setting Description
ConnectionType
Enter the type of connection:
  • 1 for connections for Oracle Express Relational Access Manager.
  • 0 for all other connections.
ServerDescription
Enter the description for this connection. The description is visible to users when they choose which connection to make to Express Server. Therefore, you should make the description no more than approximately 40 characters.
ServerVersion
Enter 1 for Express Server 6.x. No other values are applicable to connections from Oracle9i Reports Developer.
ServerType
ServerLogin
See the list that follows this table for a description of this setting.
ServerString
Enter the name of the server machine on which Express Server 6.x is running.
Note: The Express Connection Editor includes more than just the server machine name in the connection file, which is unnecessary for connections from Oracle9i Reports Developer.
The following list describes the values for the ServerLogin setting. For this setting, you enter the authentication type for this connection:
The following table briefly describes the Oracle Express Relational Access Manager settings in a connection file, which appear after the main settings that are described in the previous table.
Table 6-2 Oracle Express Relational Access Manager Settings
Setting Description
ConnectionType
Enter 0. No other values are applicable to connections from Oracle9i Reports.
MasterDB
Enter the name of the Relational Access Manager database to attach initially. You must specify only the database file name. You can get the database name in either of the following ways:
  • In the Express Relational Access Administrator, it is the Express Database Name that is displayed in the Database tab.
  • In the .RDC file, it is specified as the DBName in the [DBInfo] section.
This database must reside in a folder that is included in the path list in ServerDBPath. You can check the ServerDBPath in the I/O Management sheet of the Express Instance Manager.
PromptforExpressID
Enter 1 to prompt for an Express user ID before making the connection or 0 to not prompt. This setting applies only when PersonalConfig is set to 1.
ServerScript
Enter the complete file name (including the full path) of the remote database configuration file on the server. This file specifies information such as the location of code and data databases. Using UNC (Universal Naming Convention) syntax allows multiple users to use the same connection to access the data without having to map the same drive letter to that location. UNC syntax is \\ServerName\ShareName\ followed by any subfolders and/or files.
PersonalConfig
Enter 1 to create and attach a personal database with read/write access so that you can use many Oracle Sales Analyzer features such as custom measures. Enter 0 to not create this database. To enable this setting, you must have a account on the Express Server system. If this setting is 0, then you log in as a guest. This setting applies only with direct connections to Express Server 6.x. This setting does not applies when ServerLogin is set to 0.
6.2.8 Sample connection files
This section provides samples of three types of connection files. You can use these samples as the basis for creating connection files manually.
Sample for connecting without using authentication
The following text shows a sample XCF file for connecting to Express Server without using authentication.
[Express]
ConnectionType=0
ServerDescription=expservername ExpSrv6.3.0.2 without authentication
ServerVersion=1
ServerType=1
ServerLogin=0
ServerString=expservername
Sample for connecting with using authentication
The following text shows a sample XCF file for connecting to Express Server using authentication.
[Express]
ConnectionType=0
ServerDescription= expservername ExpSrv6.3.0.2 with authentication
ServerVersion=1
ServerType=1
ServerLogin=-1
Sample for connecting with Oracle Express Relational Access Manager
The following text shows a sample XCF file for connecting through Oracle Express Relational Access Manager (RAM).
[Express]
ConnectionType=1
ServerDescription=expservername ExpSrv6.3.0 with RAM
ServerVersion=1
ServerType=1
ServerLogin=-1
ServerString= expservername
[Relational Access Manager]
ConnectionType=0
MasterDB=d:\RAM\dram.db
PromptForExpressID=0
ServerScript=d:\RAM\ram.rdc
PersonalConfig=0
6.3 Known Issues
Go to previous page
Oracle
Copyright © 2003 Oracle Corporation.
All Rights Reserved.
Contents
