Skip Headers
Oracle 9i Reports Release Notes (Patch 1)
Release 2 (9.0.2)
Part Number B10221-01
Go To Table Of Contents
Contents
Go to previous page Go to next page
1
Patch Release 1
This chapter describes the changes that occurred in Patch Release 1 of Oracle9i Reports.
1.1 reports.sh (UNIX)
On UNIX, this patch will overwrite reports.sh. If you have modified your current reports.sh file, you should save it and, after the patch is installed, merge your modifications into the version of reports.sh installed with the patch. The version installed with the patch contains some required changes.
1.2 rwlpr.sh on Solaris Version 2.8
On Solaris Version 2.8, quotation marks around the printer name are no longer accepted. As a result, you must alter the shell script, rwlpr.sh, for printing on Solaris. The code segment below illustrates the change:
#either LPR or LP Command was found
if [ -x $PRNCMDPATH ]
then
  if [ `basename $PRNCMDPATH` = "lpr" ]
  then
    if [ `/usr/bin/uname -r` = "5.8" ]
    then
      $PRNCMDPATH `echo $@ | tr -d "\""`
    else
      $PRNCMDPATH "$@"
    fi
  else
   # parse and Fix the command Line as Required by lp
   then
     getLpCommandLine `echo $@ | tr -d "\""`
   else
     getLpCommandLine "$@"
   fi
   $PRNCMDPATH
  fi
  # exit with the command's exit code , This will tell the
  # server Print module if the command completed successfully
  # or not.
  exit $?
fi
done
1.3 Dynamic Environment Switching
In the past, the Reports Server could only serve reports that were compatible with the environment in place when the Reports Server was started. For example, reports had to be compatible with the value of the NLS_LANG parameter at the time the Reports Server was started. This restriction meant that you needed to have one Reports Server running for each language you wanted to process. The new environment switching feature eliminates this restriction by enabling one instance of the Reports Server to serve reports with any arbitrary environment settings, including language.
To use this new feature, you only need to add some elements to your Reports Server's configuration file.
1.3.1 environment Element
The environment element defines the characteristics (i.e., environment variables) that you want to use to establish a particular runtime environment. By referencing the environment element's id, you invoke its settings. You can reference an environment element id from:
Below is an example of an environment that you might want to invoke for the defaultEnvId element.
<environment id="JP">
  <envVariable name="NLS_LANG" value="Japanese_Japan.JA16SJIS"/>
  <envVariable name="NLS_CURRENCY" value="¥"/>
  <envVariable name="DISPLAY" value="MyServer.MyCompany.com:0.0"/>
</environment>
Usage Notes
1.3.2 defaultEnvId Attribute
defaultEnvId is an optional attribute of the engine element in your Reports Server configuration file. It specifies the default environment with which the Reports Server starts an engine. The attribute takes an id that is associated an environment element in another part of the server configuration file (ORACLE_HOME\reports\conf\<server_name>.conf):
<engine id="rwEng" initEngine="1" minEngine="0" maxEngine="10" engLife="50"
maxIdle="30" defaultEnvId="JP"/>
The value JP identifies an environment element also specified in the server configuration file. The initial engines will be spawned with the environment settings specified in this environment element. For more information on the environment element, refer to Section 1.3.1, "environment Element".
Usage Notes
1.3.3 Examples
The following examples illustrate the usage of the dynamic environment switching feature:
Example 1
Suppose that you need to run reports in Japanese from your Reports Server. An environment conducive to running reports in Japanese would include:
To begin, you would have to add an environment element to your Reports Server configuration file that looks something like the following:
</environment>
Once the environment element is in place, you could request a report with Japanese output using the following URL:
http://<yourWebServer>:<port>/reports/rwservlet?SERVER=<yourreportsserver>
&REPORT=Japanese.rdf&USERID=<username>/<passwd>@db&DESFORMAT=htmlcss
&DESTYPE=cache&ENVID=JP
When the URL is submitted to the Reports Server, it detects the optional ENVID parameter and matches the specified id (in this case, JP) to the corresponding id in its configuration file. If the Reports Server already has an engine running with these characteristics, it will reuse the existing engine to process the job. If not, then it spawns an engine using the current environment plus the three environment variables specified in the JP environment element. If spawning a new engine would cause the Reports Server to exceed its maxEngines setting, the Reports Server shuts down an engine before starting a new one. An engine may be shut down even though it has not exceeded its engLife setting.
Once the Reports Server has an engine with the correct environment running, the job is processed by that engine and the output is routed to the specified DESTYPE.
envid is an optional parameter. If you do not pass this parameter with the job, the Reports Server processes the request using an engine started with the defaultEnvId environment. If defaultEnvId is not specified for the engine element in your Reports Server configuration file, then the engine will inherit the settings with which the Reports Server instance was started.
The Reports Server may forward the request to another server on the cluster in cases where it cannot handle the request at that time. Even though the job may be routed to another server on the cluster, the target server will reuse or spawn an engine with the required environment to process this job.
Example 2
The following example illustrates how to use this environment switching feature to run an Arabic report on the same Reports Server that was used to run the Japanese report in Example 1.
Add another environment element to the Reports Server configuration file as shown below:
<environment id="AR">
<envVariable name="NLS_LANG" value="Arabic_United Arab Emirates.AR8ISO8859P6"/>
<envVariable name="NLS_CALENDAR" value="Arabic Hijrah "/>
</environment>
The Arabic report has to be submitted to the Reports Server with the following command line:
&REPORT=Arabic.rdf&USERID=<username>/<passwd>@db&DESFORMAT=htmlcss
&DESTYPE=cache&ENVID=AR
Since the job is submitted with envid=AR, the Reports Server finds or starts an engine with the environment specified by element AR in the Reports Server configuration file. The job is processed by the new engine and the output is distributed to the specified destination.
Example 3
The following example illustrates how the environment switching feature could be used in conjunction with a JSP report, i.e., without the Reports Servlet.
Suppose that you have the following environment elements in the Reports Server configuration file:
<environment id="UK">
<envVariable name="NLS_LANG" value="AMERICAN_UNITED KINGDOM.WE8ISO8859P1"/>
</environment>
<environment id="US">
<envVariable name="NLS_LANG" value="AMERICAN_AMERICA.WE8ISO8859P1"/>
</environment>
If your JSP report uses a format mask such as the following, it means the currency, grouping, and decimal symbols can change according to the environment:
<rw:field id="sal" src="sal" formatMask="L999G999D999"/>
To run the report using the UK symbols for currency, grouping, and decimal, you would use the following URL:
http://myserver:port/test/myjsp?userid=scott/tiger@orcl&envid=uk
Note: You could place envid=uk into a key in the cgicmd.dat file.
Usage Notes
1.4 engineResponseTimeOut Parameter
A new, optional attribute, engineResponseTimeOut, has been added to the engine element in the Reports Server configuration file. This attribute enables you to specify the maximum amount of time (in minutes) for an engine to update the status of the job while running a report in your environment. If it takes longer than this amount of time to update the job status for some reason (e.g., due to the engine hanging or a long blocking SQL query), the Reports Server terminates the job.
engineResponseTimeOut has also been added as a new command line parameter for RWSERVLET, RWCLIENT, and RWCGI. From the command line, it overrides the value specified in the engine attribute for that particular job request only.
1.5 Spaces in HTML Output
Bug number: 2441615
By default, spaces are now replaced with &nbsp in HTML and HTMLCSS report output. This new default behavior eliminates alignment issues for number values that are right aligned. If you do not want spaces replaced with &nbsp in your HTML and HTMLCSS output, then you must set REPORTS_NO_HTML_SPACE_REPLACE to YES. If you want to return to the default behavior of replacing spaces with &nbsp, then REPORTS_NO_HTML_SPACE_REPLACE must not be set at all.
As part of this change, the previous functionality of the DELIMITER command line argument for HTML and HTMLCSS output is removed. DELIMITER is still used with the DELIMITED DESFORMAT as in previous releases.
1.6 DelimitedData DESFORMAT
Bug number: 1211760
A new destination format (DESFORMAT) is available in this patch that resolves a bug (1211760) with the earlier delimited formatting functionality.
1.6.1 Using DelimitedData
Customers who had problems running large volume reports with DESFORMAT=Delimited should now use DESFORMAT=DelimitedData.
To use the DelimitedData DESFORMAT for the Generate to File > XML menu option in Reports Builder, set the following environment variable in the operating system:
REPORTS_OVERRIDE_FILEGENXML = Yes
This setting overrides the XML generation functionality in the Reports Builder with the new DelimitedData behavior. In Oracle9iAS Reports Services Release 9.0.4, both formats will be available natively inside Reports Builder, but, in this patch, you must toggle this environment variable to switch between the two behaviors.
1.6.2 Modifying DelimitedData Output
The new DelimitedData driver runs off of the data model and operates in much the same way as the XML driver, which is already available in the product. Since the driver runs off of the data model, any formatting changes defined in the layout are not reflected in the DelimitedData output. You can set the following column properties (Tools > Property Inspector) to alter column names and exclude columns from the DelimitedData output file:
The DelimitedData functionality also honors the DELIMITED, CELLWRAPPER, NUMBERFORMAT, and DATEFORMAT command line arguments just as the original Delimited functionality did. Refer to the command line documentation in the Reports Builder online help for details on these arguments.
1.6.3 Known Issues
This feature has the following known issues:
1.7 JVM Parameters for the Reports Server and Engine
A new parameter, jvmoptions, has been added to the Reports Server to allow you to set options in the server's Java Virtual Machine (JVM). For example, you could use the following command line to start the Reports Server with a 512Mb heap space:
rwserver server=<servername> jvmoptions=-Xmx512M
Multiple options can be passed, in which case the options must be enclosed in quotes:
rwserver server=<servername> jvmoptions="-Xmx256M -Xms=128M"
Similarly, the jvmoptions parameter can be included in the engine configuration section of the server configuration file, and the engine will pass these options when it invokes a JVM.
Oracle
Copyright © 2003 Oracle Corporation.
All Rights Reserved.
Contents
