Skip Headers
Oracle 9i Reports Release Notes (Patch 1)
Release 2 (9.0.2)
Part Number B10221-01
Go To Table Of Contents
Contents
Go to previous page Go to next page
4
UI Issues and Work Arounds
This chapter describes user interface issues and their work arounds for Oracle9i Reports Developer.
4.1 Source Control (Windows only)
To enable the use of Oracle Source Control Management with Oracle9i Reports Developer, you must set a number of registry variables. Oracle Source Control Management provides a Start menu item that will update the registry variables for you:
Oracle 9i Developer Suite-> ORACLE_HOME -> Oracle 9i Software Configuration Manager -> Use as Source Control For Forms/Reports
This menu item runs a file named drsc61.reg. By running this file, you are updating the registry variables required by Oracle9i Reports Developer.
4.1.1 Check In/Check Out Restriction
If you are using the source control integration feature in Reports Builder, you should not select the check out after check in option. Doing so will result in the report being placed in Read-only mode. To avoid this problem, you should always perform check ins and checkouts as separate operations.
4.2 Some Languages Not Appearing Correctly in Web Source View
In the Web Source view of the Report Editor, the following languages may appear garbled: Japanese, Thai, Arabic, and Hebrew. To work around this issue, you can set the font names for Reports Builder in uifont.ali as follows:
[rwbuilder]
.....ja16sjis="MS Gothic"
.....ar8mswin1256="Courier New"
4.3 Find/Replace in Web Source View for Asian Languages Causes Crash
When performing a Find/Replace operation in the Web Source view of the Report Editor and running in an Asian language (for example, Japanese) on Windows, the Reports Builder crashes. This problem does not occur on UNIX.
4.4 Documentation Errata
This section describes known errors or omissions in the documentation.
Oracle
Copyright © 2003 Oracle Corporation.
All Rights Reserved.
Contents
