Skip Headers
Oracle Collaboration Suite Installation Guide
Release 1 Version 9.0.3 for AIX-Based Systems and HP Tru64 UNIX
Part Number B10292-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
D
Installing Oracle Collaboration Suite Clients
The Oracle Collaboration Suite Client CD-ROM contains the client products.
This appendix contains the following topics:
Oracle Outlook Connector 3.4
System Requirements for Oracle Outlook Connector
Table D-1 contains the Oracle Outlook Connector system requirements.
Table D-1 System Requirements
Requirement Value
Operating Systems
  • Windows NT 4.0
  • Windows 98
  • Windows 2000
  • Windows XP Professional
Administrative privileges are required to install Oracle Outlook Connector on Windows NT, 2000, and XP.
Disk Space
Free disk space equivalent to approximately 60% of the user's IMAP4 mailbox size
RAM
Refer to the RAM requirements of your Microsoft Outlook client.
Outlook
  • Outlook 98
  • Outlook 2000
  • Outlook 2002
Calendar server
Oracle Calendar server 5.5 included with Oracle Collaboration Suite
E-mail Servers
SMTP server for outgoing mail included with Oracle Collaboration Suite.  Any IMAP4-compliant mail server such as Oracle9iAS included with Oracle Collaboration Suite.  Other third-party IMAP4 servers may offer different levels of Outlook e-mail support due to variations in their implementation of the IMAP4 protocol.
Conduits for PDA Synchronization
  • PocketMirror 2.04 or 3.0 (3.0 recommended)
  • PocketJournal
  • Desktop To Go 2.5
  • Desktop To Go 2.509 (for Outlook 2002 only)
  • PSIWIN 2.3 or 2.31
  • ActiveSync 3.0, 3.1 or 3.5
  • HotSync Manager 4.0 (for Windows XP only)
Preinstallation Requirements for Oracle Outlook Connector
Installing Oracle Outlook Connector
  1. Exit all Windows applications before installing Outlook Connector.
  2. Double-click the OC_03040_WIN.exe file.  Follow the on-screen installation instructions.
    To avoid conflict between POP3 and IMAP4 protocols, Microsoft's Internet Mail or Exchange service providers should not be set up in the same profile as Outlook Connector if both are configured to connect to the same e-mail server.
Silent Installation of Oracle Outlook Connector
When run in silent mode, the Oracle Outlook Connector installer consults a preset configuration file for all the information normally provided by the user through the install dialogs.  Available with Oracle Outlook Connector is a sample file, called ctoc.ini.  Use this file as a template, changing the values of its parameters to suit your installation.  For more details on the parameters available, see Table D-2.  Any parameters for which you do not supply a value and that do not have default values are prompted for at first startup.
To install Oracle Outlook Connector from the command line without requiring any user interaction, run the product self-extracting executable with the -s option, and specify the configuration file to use with the -cfg option.
For example, where both the installer and configuration file exist in the root directory of drive C:, and the installer file name is OC_03040_WIN.exe:
C:\> OC_03040_WIN.exe -s -cfg ctoc.ini
Two optional flags can also be specified:
If you need more information on large-scale deployments of Oracle Outlook Connector, contact Oracle Consulting.
Oracle Outlook Connector Silent Installation Configuration File Parameters
Table D-2 contains a list of the available parameters for Oracle Outlook Connector silent installation, organized alphabetically by section.  Listed default values are applied when the value of the parameter in question is blank or the parameter is left out of the configuration file completely.
All lines beginning with a semicolon (;) in the configuration file are comments not read by the installer.
Table D-2 Oracle Outlook Connector Silent Installation Configuration Parameters
Component Parameter Accepted Values Default Description
[Calendar]
AccountName
A valid calendar server user name
None
Specifies this user's calendar account name.
[Calendar]
DomainID
A valid Domain ID
None
Specifies the Domain ID representing your organization.  The [Calendar] UseDNS and [Calendar] HostName parameters must also be specified.
[Calendar]
HostName
A valid host name, or list of names in the format: host1;host2; hostN.  For example: scooter;kermit
None
Specifies the host name or network address of the Calendar Domain Service host or hosts.  The [Calendar] UseDNS and [Calendar] DomainID parameters must also be specified.
[Calendar]
NoAccount
0 (configure a calendar server connection using the [Calendar] parameters)
1 (skip configuring the calendar server connection and ignore any values set by other parameters in the [Calendar] section)
0
Specifies that this user has no calendar server account, and ignores any values set by other parameters in the [Calendar] section.
[Calendar]
Password
The valid password for this user's calendar account
None
Specifies this user's calendar password.
[Calendar]
Port
0 (use the default)
A valid port
None
Specifies the port to use to connect to the calendar server specified by the [Calendar] ServerName parameter.
[Calendar]
ServerName
A valid host name, followed by a comma, followed by a valid node-ID.  For example: kermit,1200
None
Specifies the host name or network address of the calendar server, and the node-ID to connect to, if desired.
[Calendar]
UseDNS
Use Calendar Domain Service
[E-Mail]
AccountName
A valid user name
None
The account name of this user on the IMAP4 server
[E-Mail]
DisplayName
Any alphanumeric string
None
Sets the name to be displayed for all e-mail this user sends
[E-Mail]
EmailAddress
A valid e-mail address
None
Specifies the current user's e-mail address
[E-Mail]
Imap4ServerName
A valid host name
None
The host name or network address of the IMAP4 e-mail server
[E-Mail]
ImapNoAccount
0 (configure an IMAP4 server connection using the other IMAP4 configuration parameters in the [E-Mail] section)
1 (skip configuring the IMAP4 server connection and ignore any values set by other IMAP4 configuration in the [E-Mail] section)
Specifies that this user has no IMAP4 account, and ignores any values set by other IMAP4 configuration parameters in the [E-Mail] section
[E-Mail]
ImapPort
A valid port
143
The port for the IMAP4 server
[E-Mail]
ImapSameAsCTime
0 (Do not use the same values set for the calendar server account name and password)
1 (Use the same values set for the calendar server account name and password)
0
Instructs the installer to use the same user name and password specified by the [Calendar] AccountName and [Calendar] Password parameters for the IMAP4 server.  If this parameter is set to 1, the installer ignores any values set in the [E-Mail] AccountName and [E-Mail] Password parameters.
[E-Mail]
ImapSSL
0 (Do not use SSL)
1 (Use SSL)
0
Instructs the installer to use Secure Sockets Layer (SSL) for all communications with the IMAP4 e-mail server
[E-Mail]
Organization
None
Specifies the current user's organization, to be included with outgoing e-mail.  Optional.
[E-Mail]
Password
The valid password for this user's e-mail account
None
The password for this user on the IMAP4 server
[E-Mail]
ReplyTo
None
Specifies the destination e-mail address that mail is sent to when a user replies to mail sent by the current user.  Optional.
[E-Mail]
SmtpAccount
A valid host name
None
Specifies the host name or network address of the SMTP e-mail server
[E-Mail]
SmtpAuthentication
0 (No authentication required)
1 (User name and password required)
0
Instructs the installer that the specified SMTP e-mail server requires a username and password
[E-Mail]
SmtpNoAccount
0 (configure an SMTP server connection using the other SMTP configuration parameters in the [E-Mail] section)
1 (skip configuring the SMTP server connection and ignore any values set by other SMTP configuration in the [E-Mail] section)
0
Specifies that this user has no SMTP account, and ignores any values set by other SMTP configuration parameters in the [E-Mail] section
[E-Mail]
SmtpPassword
The valid password for the current user account
None
Specifies the password to use when connecting to the SMTP e-mail server, if the [E-Mail] SMTPAuthentication parameter is set to 1
[E-Mail]
SmtpPort
A valid port
25
The port for the SMTP server
[E-Mail]
SmtpSameAsImap
0 (Do not use the same values set for the IMAP4 server account name and password)
1 (Use the same values set for the IMAP4 server account name and password)
0
Instructs the installer to use the same user name and password specified by the [E-Mail] AccountName and [E-Mail] Password parameters for the SMTP server.  If this parameter is set to 1, the installer ignores any values set in the [E-Mail] SmtpAccount and [E-Mail] SmtpPassword parameters
[E-Mail]
SmtpServerName
A valid user name on the SMTP server
None
Specifies the account name to use when connecting to the SMTP e-mail server, if the [E-Mail] SMTPAuthentication parameter is set to 1
[E-Mail]
SmtpSSL
0 (Do not use SSL)
1 (Use SSL)
0
Instructs the installer to use Secure Sockets Layer (SSL) for all communications with the SMTP e-mail server
[General]
CompanyName
None
Specifies the name of the company employing the registered user.
[General]
InstallPath
A valid path name
<current drive>:\Program Files\Oracle\Outlook Connector
Specifies the path in which to install Oracle Outlook Connector.
[General]
UserName
None
Specifies the name of the registered user.  Also used as default values for the [Calendar] AccountName and [E-Mail] DisplayName parameters.
[Install]
ShowError
0 (Hide error messages)
1 (Show error messages)
0
Displays error messages encountered during the installation
[Install]
ShowOutput
0 (Hide output)
1 (Show output)
0
Displays the output of the Oracle Outlook Connector installer as it progresses through the silent installation
[Install]
ShowSuccess
0 (Hide success message)
1 (Show success message)
0
Displays a status message when installation is completed successfully
[Install]
ShutdownOutlook
0 (Do not shut down Outlook automatically)
1 (Shut down Outlook automatically)
0
Instructs the installer to close Outlook automatically before installing Oracle Outlook Connector, if Outlook is running.  Outlook must not be running in order for the installer to function correctly
[MAPIProfile]
Name
Specifies the profile in which to add Oracle Outlook Connector.  If the profile name specified does not already exist, the installation creates a new profile with this name and adds Oracle Outlook Connector to that profile.
[Off-line]
Path
A valid path
A default path determined according the current platform and profile name
Specifies a location for the current user's offline storage
[Off-line]
Use
0 (Offline access disabled)
1 (Offline access enabled)
0
Instructs the installer to enable offline access and synchronization for the current user
[Settings]
DisableCfgUI
0 (Show the configuration dialog box normally)
1 (Hide the configuration dialog box)
0
Hides the Oracle Outlook Connector configuration dialog box normally available through the Windows' Mail control panel, so that users cannot modify their sign-in and offline settings
[Settings]
DisablePwd
0 (Allow password saving)
1 (Disable password saving)
0
Instructs the installer to ignore passwords set for the calendar, IMAP4 and SMTP server, and requires the current user to provide an account password at each login
[Settings]
ForceReboot
0 (No reboot)
1 (Force reboot)
0
Instructs the installer to restart the operating system after the first part of the installation (copying files and installing Oracle Outlook Connector as a service provider)
[Settings]
HideCTimePwdMenu
0 (Show the Change Password option)
1 (Hide the Change Password option)
0
Hides the Change Password option in the Tools menu, to prevent users from changing their calendar server passwords through Outlook
[Settings]
NoServerMail
0 (Enable connections to mail servers normally)
1 (Skip connections to both IMAP4 and SMTP servers)
2 (Skip connection to the IMAP4 server)
3 (Skip connection to the SMTP server)
0
Skips connecting to the IMAP4 and SMTP servers.  Use this parameter if you want to use another service provider such as Microsoft's Internet E-Mail for mail instead of Oracle Outlook Connector
[Settings]
ShowSrvIcon
0 (Do not show the unavailable servers icon)
1 (Show the unavailable servers icon)
0
Shows a small information icon in the lower right corner of the main Outlook window when a calendar or mail server is unavailable
Deinstalling Oracle Outlook Connector
To remove Oracle Outlook Connector:
  1. Choose Add/Remove Programs from the Control Panel.
  2. Choose Oracle Outlook Connector and click Add/Remove.
Oracle CorporateTime 6.0.3 for Windows
System Requirements for Oracle CorporateTime for Windows
Table D-3 contains the Oracle CorporateTime for Windows system requirements.
Table D-3 System Requirements
Requirement Value
Operating Systems
  • Windows 98
  • Windows ME
  • Windows NT
  • Windows 2000
If you are installing Oracle CorporateTime on a Windows NT computer, you must install Microsoft Windows Service Pack 6 or higher.
Administrative privileges are required to install Oracle CorporateTime on Windows NT, 2000, and XP.
Disk Space
8 MB
RAM
16 MB minimum
Calendar server
Installing Oracle CorporateTime for Windows
This section describes how to install Oracle CorporateTime for Windows.
Windows NT, 2000, and XP require you to have administrative privileges on your computer in order to install Oracle CorporateTime.
  1. Log in with administrative privileges if you are installing on Windows NT, 2000, or XP.
  2. Run the self-extracting executable win_0600003_583_en.exe and follow the on-screen instructions.
  3. If there is a previous version of Oracle CorporateTime 6.0 on the computer, the new version is installed over it.  If there is a previous version of Oracle CorporateTime on the computer, you are prompted whether you want to remove it or leave it on the computer.
Silent Installation of Oracle CorporateTime for Windows
Silent installation is also available for Oracle CorporateTime 6.0.3 for Windows.  Contact Oracle Consulting Services for more information.
Deinstalling Oracle CorporateTime for Windows
To remove Oracle CorporateTime for Windows:
  2. Choose Oracle CorporateTime 6.0 and click Add/Remove.
Oracle CorporateTime 5.2.3 for Macintosh
System Requirements for Oracle CorporateTime for Macintosh
Table D-4 contains the Oracle CorporateTime for Macintosh system requirements.
Table D-4 System Requirements
Requirement Value
Operating Systems
Mac OS 8.6 to 9.2.2, Mac OS X 10.0.4 to 10.1.5
Disk Space
10 MB minimum
RAM
8 MB
Calendar server
Installing Oracle CorporateTime for Macintosh
Mac OS 8.6 to 9.2
This section describes how to install Oracle CorporateTime for Mac OS 8.6 to 9.2.
  1. Ensure that you have administrative privileges.
  2. Ensure that the CarbonLib file is installed in the Extensions folder of your active System Folder to run the installer.
  3. Double-click mac_0502003_en.hqx and follow the on-screen instructions.
    The installer extracts the application and copies the Readme.htm file into the destination folder you have selected.  It also extracts all shared libraries to the Extensions folder and CorporateTime Help to the Help folder of your active System Folder.
    If your CarbonLib file is prior to version 1.6, it is updated.  Restart the computer for the new file version to take effect.
  4. Double-click the Oracle CorporateTime icon to start the application when installation is completed.
Mac OS X
This section describes how to install Oracle CorporateTime for Mac OS X.
  2. Double-click mac_0502003_en.hqx and follow the on-screen instructions.
    The installer extracts the application and copies the Readme.htm file into the destination folder you have selected.  It also extracts all shared libraries to the /Library/CFMSupport/ folder and the CorporateTime Help folder to the /Library/Documentation/Help/ folder.
  3. Double-click the Oracle CorporateTime icon to start the application when installation is completed.
Deinstalling Oracle CorporateTime for Macintosh
Mac OS 8.6 to 9.2
This section describes how to deinstall Oracle CorporateTime for Mac OS 8.6 to 9.2.
  1. To remove Oracle CorporateTime, you must delete the following components:
    • Shared libraries and ACE plug-ins
    • Help
    • Preferences
    • Oracle CorporateTime application
  2. To remove the shared libraries and ACE plug-ins, go to your hard disk and open the System folder.  Open the Extensions folder and delete the following files:
    • CSTACipher1EncrLib
    • CSTLightEncrLib
    • CSTSimpleCompLib
    • CSTStdAuthLib
    • CSTRuntime
  3. To remove the Help, go to your hard disk and open the System folder.  Open the Help folder, select the CorporateTime Help folder and delete it.
  4. To remove your Preferences, go to your hard disk and open the System folder.  Open the Preferences folder, select the CorporateTime Preferences file and delete it.
  5. To remove the Oracle CorporateTime application, go to your hard disk and open the Applications (Macintosh OS 9) folder.  Select the CorporateTime folder and delete it.
Mac OS X
This section describes how to deinstall Oracle CorporateTime for Mac OS X.
    • Help
    • Preferences
  2. To remove the shared libraries and ACE plug-ins, go to your hard disk and open the Libraries folder.  Open the CFMSupport folder and delete the following files:
    • CSTLightEncrLib
    • CSTSimpleCompLib
    • CSTStdAuthLib
    • CSTRuntime
  3. To remove the Help, go to your hard disk and open the Library folder.  Open the Documentation folder, and then open the Help folder.  Select the CorporateTime Help folder and delete it.
  4. To remove your Preferences, go to your hard disk and open the Users folder and go to the User folder that has your name on it.  Open the Library folder, and then open the Preferences folder.  Select the CorporateTime 5.2.3.plist file and the CorporateTime Preferences file and delete them.
  5. To remove the Oracle CorporateTime application, go to your hard disk and open the Applications folder.  Select the CorporateTime folder and delete it.
Oracle CorporateTime 5.0.2 for Motif
System Requirements for Oracle CorporateTime for Motif
Table D-5 contains the Oracle CorporateTime for Motif system requirements.
Table D-5 System Requirements
Requirement Value
Operating Systems
  • Solaris 2.6, Solaris 7, and Solaris 8.  SPARC only.
  • Red Hat Linux 6.1, 6.2, and 7.x
  • Linux X86 2.2.x kernel or later
  • Debian 2.2
  • Caldera OpenLinux 2.3
Note: If you use Debian release 2.2, an extra library is required.  The library is called libstdc++2.9-glibc2.1 and is available on the Oracle Collaboration Suite CD-ROM or from Debian at:
http://packages.debian.org/stable/oldlibs/libstdc++2.9-glibc2.1.html
If you have apt configured you can use: apt-get install libstdc++2.9-glibc2.1.
Netscape Navigator or Netscape Communicator release 4.0 or higher is required to use the Oracle CorporateTime online Help.  The directory that contains the Netscape executable must be set in your path.
Disk Space
26 MB
RAM
15 to 20 MB
Installing Oracle CorporateTime for Motif
This section describes how to install Oracle CorporateTime for Motif.
  1. Unpack the distribution archive in a directory.  /usr/local is the example directory used in the following instructions.
    • Solaris
      cd /usr/local
      gtar zxvf /tmp/motif_0502000_734_solaris_en.tar.gz
    • Linux
      cd /usr/local
      gtar zxvf /tmp/motif_0502000_734_linux_en.tar.gz
    ctime, ctime support libraries, html-help, and readme.htm are extracted into a new directory called CorporateTime.
  2. Change to the CorporateTime directory.
    cd CorporateTime
  3. Set the environment variable CTIME_ROOT so that it points to /usr/local/CorporateTime, the directory that has been created.
  4. Add the /usr/local/CorporateTime directory to your path.
  5. Run /usr/local/CorporateTime/ctime.sh.
Deinstalling Oracle CorporateTime for Motif
To deinstall Oracle CorporateTime for Motif, remove the CorporateTime directory:
rm -rf /usr/local/CorporateTime
Oracle CorporateSync 3.0.2 for Palm, Windows Edition
System Requirements for Oracle CorporateSync 3.0.2 for Palm, Windows Edition
Table D-6 contains the Oracle CorporateSync 3.0.2 for Palm, Windows Edition system requirements.
Table D-6 System Requirements
Requirement Value
Operating Systems
  • Windows 98
  • Windows 2000
  • Windows ME
  • Windows XP
  • Windows NT 4.0
Disk Space
20 MB
RAM
64 MB
Calendar server
Palm Desktop
Palm Desktop 3.1 or higher
Device
Any Palm-compatible device running Palm OS 3.3 to 4x.  If you are running an older version of Palm Desktop, check your manufacturer's site for updates.
Installing Oracle CorporateSync 3.0.2 for Palm, Windows Edition
This section describes how to install Oracle CorporateSync 3.0.2 for Palm, Windows Edition.
If you have a previous version of CorporateSync installed, Oracle Corporation recommends that you perform a synchronization before you install CorporateSync for Palm, Windows Edition.
  1. Ensure that you have deinstalled any previous versions of CorporateSync (2.1.1 or lower) on your desktop, and any version of the CS Setup utility on your mobile device.
    If you have a Beta version of CorporateSync 3.0 for Palm, you can install the release version over it.
  2. Run the csyncpalm0300020.1670win_en_rtm.exe setup program provided with the distribution package and follow the on-screen InstallShield instructions.
  3. Accept the license agreement and choose an installation directory.
  4. Choose an installation type.  If you choose Custom, there is no difference between "This feature will be installed on local hard drive" and "This feature, and all subfeatures, will be installed on your local hard drive".
  5. Select the conduits you want to install.
  6. Enter your user information, including user name, password, calendar server, and node ID.
  7. Follow the additional on-screen instructions to complete the installation.
Deinstalling Oracle CorporateSync 3.0.2 for Palm, Windows Edition
To remove Oracle CorporateSync:
  2. Choose Oracle CorporateSync 3.0 and click Add/Remove.
Oracle CorporateSync 3.0.2 for Pocket PC
System Requirements for Oracle CorporateSync 3.0.2 for Pocket PC
Table D-7 contains the Oracle CorporateSync 3.0.2 for Pocket PC system requirements.
Table D-7 System Requirements
Requirement Value
Operating Systems
  • Windows 98
  • Windows 2000
  • Windows ME
  • Windows XP
  • Windows NT 4.0
Disk Space
20 MB
RAM
64 KB
Calendar server
Pocket PC
Pocket PC (Windows CE 3.0) with MIPS, SH3 or ARM processor
Device
  • HPC 2000
  • Compaq iPAQ
  • HP Jornada 5x
  • HP Jornada 7x
  • Handheld PC
  • Pocket PC 2002
If you are running an older version of Microsoft ActiveSync, check your manufacturer's site for updates.
Installing Oracle CorporateSync 3.0.2 for Pocket PC
This section describes how to install Oracle CorporateSync 3.0.2 for Pocket PC.
If you have a previous version of CorporateSync installed, Oracle Corporation recommends that you perform a synchronization before you install CorporateSync for Pocket PC.
  2. Ensure that ActiveSync is installed on your computer.
  3. Run the csyncppc0300020.1760win_en_rtm.exe setup program provided with the distribution package and follow the on-screen InstallShield instructions.
  4. Accept the license agreement and choose an installation directory.
  5. Choose an installation type.  If you choose Custom, there is no difference between "This feature will be installed on local hard drive" and "This feature, and all subfeatures, will be installed on your local hard drive".
  6. Select the conduits you want to install.
  7. Ensure that you install Oracle CorporateSync Helper files when prompted by the application.
  8. Enter your user information, including user name, password, calendar server, and node ID.
  9. Follow the additional on-screen instructions to complete the installation.
Deinstalling Oracle CorporateSync 3.0.2 for Pocket PC
  3. To remove CorporateSync's Helper files from your mobile device, choose Add/ Remove Programs from the Control Panel.
  4. Choose Control Panel > CorporateSync Helper > Add/Remove Programs on your mobile device.
  5. Click Remove.
Oracle CorporateSync 2.1.4 for Palm, Macintosh Edition
System Requirements for Oracle CorporateSync 2.1.4 for Palm, Macintosh Edition
Table D-8 contains the Oracle CorporateSync 2.1.4 for Palm, Macintosh Edition system requirements.
Table D-8 System Requirements
Requirement Value
Operating Systems
Mac OS 7.1.2 up to version 9.2.2
Disk Space
8 MB
RAM
64 MB recommended
Calendar server
Palm
Palm MacPac version 2x
Device
Any Palm compatible device running Palm OS 3.3 to 3.5x
Installing Oracle CorporateSync 2.1.4 for Palm, Macintosh Edition
This section describes how to install Oracle CorporateSync 2.1.4 for Palm, Macintosh Edition.
  1. If you already have data in your Palm Desktop, perform a HotSync before installing CorporateSync.
  2. Run the mac_Csync_0201004_en.hqx setup program provided with the distribution package and follow the on-screen InstallShield instructions.  If you have an evaluation copy of CorporateSync, contact Oracle Corporation for information on obtaining a permanent copy.  If you have a previous version installed on your computer, the installer automatically locates it and overwrites it.
  3. This installation replaces the Palm Desktop with your calendar application Entry information.  If you have data in the Palm Desktop, the installer moves it to a folder called Disabled Conduits.
  4. Turn on the Palm organizer and place it in its cradle.
  5. Press the HotSync button on the front of the Palm organizer cradle.  The CS Setup application is installed on your Palm organizer.
    You may get error messages in the HotSync log indicating that CS Setup cannot be located.  Ignore these messages.
  6. If the HotSync Manager is running, the installer prompts you to close it.
  7. Click Yes to exit the HotSync Manager.
  8. Click the HotSync icon in your HotSync folder and select HotSync Manager.
  9. From the HotSync menu, choose Conduit Settings.  A list of items to synchronize appears.  Choose how you want Calendar Events, Tasks, and Addresses to be synchronized by double clicking each item.  A dialog box appears with the following choices:
    • Synchronize the files: Synchronizes all information that exists on both the Palm organizer and in Oracle Calendar.
    • Macintosh overwrites hand-held: Information in the Calendar Agenda overwrites Events, Tasks, or Addresses on the Palm organizer.
    • Do Nothing: The specified Entry type is not synchronized.
  10. Select a user name from the top of the Conduit Settings dialog box.  If there is only one user name, it is selected automatically.
  11. CorporateSync is now installed but no Entry information has been synchronized.
Deinstalling Oracle CorporateSync 2.1.4 for Palm, Macintosh Edition
This section describes how to deinstall Oracle CorporateSync 2.1.4 for Palm.
  1. Remove the following conduits in the HotSync Conduits folder:
    • Calendar Addresses
    • Calendar Events
    • Calendar Tasks
  2. Remove the CTime Sync Read Me folder in the HotSync Conduits folder.
  3. Remove the Unison Library shared library from the active (Macintosh OS 8.x to 9.x) system folder's Extension folder.
Oracle FileSync for Windows
In addition to using the networking protocols or client applications native to the Windows operating system, Windows users can install and use Oracle FileSync, which synchronizes all file changes between a local computer and Oracle Files.
Installing Oracle FileSync for Windows
Oracle FileSync is a Windows client that enables users to keep files synchronized between their local computer and Oracle Files.
  1. Save and exit all Windows applications.
    If you have a previous release of Oracle FileSync software installed, deinstall it by using the Add/Remove Programs applet in the Control Panel.
  2. Log in to Oracle Files and navigate to:
    AllPublic/Users/Users-S/system-data/downloads
  3. Double-click FileSync.exe to run the installation program.
  4. Follow the on-screen instructions and accept the defaults.  The application is installed in:
    c:\Program Files\Oracle\Oracle 9iFS FileSync
  5. To start the FileSync application, select Oracle FileSync from the Windows Start > Programs menu.
  6. You can also download Oracle FileSync by clicking the Oracle FileSync link on the Oracle Files Welcome page.
Oracle
Copyright © 2002 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
