Skip Headers
Oracle Application Server Reports Services Publishing Reports to the Web
10g (9.0.4)
Part Number B10314-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
C
Batch Registering Reports in OracleAS Portal
If you have a number of reports that you wish to register in OracleAS Portal, it is often preferable to register them as a group in a batch script rather than individually in the OracleAS Portal user interface. Likewise, if you have a large number of reports that you wish to unregister, a batch script is more efficient.
C.1 Batch Registering Report Definition Files
To batch register reports in OracleAS Portal, you need to perform the following steps:
  1. Run rwconverter to Generate a SQL Script
  2. Run the Script in SQL*Plus
C.1.1 Run rwconverter to Generate a SQL Script
To generate a SQL script that you can execute in SQL*Plus to register your reports, do the following:
  1. From the operating system prompt (DOS or UNIX), enter the rwconverter command with the keywords to batch register the report definition files.
    See Also:
    Appendix A, "Command Line Options"
    For information on the rwconverter keywords.
    To successfully create a script file with the necessary load functions, you specify the DTYPE, STYPE, SOURCE, and DEST options. To create a functional package in OracleAS Portal, you will need to specify the P_SERVERS, P_PRIVILEGE, P_TYPES, P_FORMATS in addition to the options used to create the script file.
    Following is an example rwconverter command line on Microsoft Windows:
    rwconverter.exe dtype="register" stype="rdffile"
    source="(security.rdf,earnings.rdf,acc_pay.rdf)" dest="(output.sql)"
    p_owner="PORTAL_APP" p_servers="(repserver,acct_server)"
    p_description="restricted report" p_privilege="(SCOTT,JABERS,ACCT)"
    p_availability="production" p_types="(Cache,printer)"
    p_formats="(HTMLCSS,PDF)" p_printers="(sales_printer,acct_printer)"
    p_pformTemplate="public.finance_template"
    p_trigger="Is begin IF UPPER(DESTYPE) = ''PRINTER'' AND
    EMPNAME = ''SMITH'' THEN RETURN(TRUE); ELSE RETURN(FALSE); END IF; end;"
    The above command line would generate a SQL script file named output.sql that contains the following:
    SET SERVEROUTPUT ON
    VAR STATUS NUMBER;
    EXEC :STATUS := RWWWVREG.REGISTER_REPORT (P_NAME=>'Security',
    P_OWNER=>'PORTAL_APP', P_SERVERS=>'repserver,acct_server',
    P_FILENAME=>'security.rdf', P_DESCRIPTION=>'restricted report',
    P_PRIVILEGE=>'SCOTT,JABERS,ACCT', P_AVAILABILITY=>'production'
    P_TYPES=>'Cache,printer', P_FORMATS=>'HTMLCSS,PDF)',
    P_PRINTERS=>'sales_printer,acct_printer
    P_PFORMTEMPLATE=>'public.finance_template' P_PARAMETERS=>'(P_LASTNAME)
    (P_SSN)', P_TRIGGER=>'Is begin IF UPPER(DESTYPE) = ''PRINTER'' AND
    EMPNAME = ''SMITH''THEN RETURN(TRUE); ELSE RETURN(FALSE); END IF; end;');
    EXEC :STATUS := RWWWVREG.REGISTER_REPORT (P_NAME=>'Earnings',
    P_FILENAME=>'earnings.rdf', P_DESCRIPTION=>'restricted report',
    P_TYPES=>'Cache,printer)', P_FORMATS=>'HTMLCSS,PDF)',
    P_PRINTERS=>'sales_printer,acct_printer',
    P_PFORMTEMPLATE=>'public.finance_template',
    P_TRIGGER='Is begin IF UPPER(DESTYPE) = ''PRINTER'' AND EMPNAME = ''JABERS''
    EXEC :STATUS := RWWWVREG.REGISTER_REPORT (P_NAME=>'Acc_pay',
    P_FILENAME=>'acc_pay.rdf', P_DESCRIPTION=>'restricted report',
    P_TYPES=>'Cache,printer', P_FORMATS=>'HTMLCSS,PDF',
    p_printers=>'sales_printer,acct_printer',
    EMPNAME = ''JABERS''THEN RETURN(TRUE); ELSE RETURN(FALSE); END IF; end;');
    For more information about the contents of this SQL script file, refer to PL/SQL Batch Registering Function.
  2. Check the reports.log file, which is typically written to the current working directory, for errors that may have occurred during the conversion process. If the reports.log file was not generated, then no errors were encountered by rwconverter.
  3. You can now optionally edit the system and user parameter values as desired. For example, the first RWWWVREG function in the sample script above generated an additional parameter called P_PARAMETERS. This occurred because the security.rdf file contains two user-defined parameters, P_LASTNAME and P_SSN:
    P_PARAMETERS=>'(P_LASTNAME)(P_SSN)',
    In this case, you can optionally define the default, low, and high values, or a list of values for each user parameter if you want to restrict the values the user may enter at runtime. Similarly, if you want to restrict system parameters, such as COPIES, to limit the number of copies a user can make, you do so by using the P_PARAMETERS parameter. The edited P_PARAMETERS keyword might look like the following:
    P_PARAMETERS=>'(P_LASTNAME, LOV=LASTNAME_LOV)(P_SSN)(COPIES,
    DEFAULT=1,LOW=1,HIGH=2)'
    This revised code segment imposes the following restrictions on the report:
    • The P_LASTNAME user parameter is limited to the values listed in the LASTNAME_LOV list of values.
    • A user-supplied value for P_SSN is required.
    • The default value of the COPIES system parameter is one and the number of printed copies must be in a range from 1 to 2.
  4. Save and close the output.sql file.
C.1.2 Run the Script in SQL*Plus
To actually register your reports in OracleAS Portal, you must run the script generated for you by rwconverter:
  1. Start SQL*Plus and connect to the OracleAS Portal schema that you want to own the packaged procedures.
  2. From the SQL*Plus command prompt, execute the script you created with rwconverter:
    @ output.sql
    The script will execute and create packages in OracleAS Portal for each report listed in the script with the specified parameters.
  3. Log in to OracleAS Portal as a user with RW_ADMINISTRATOR privileges.
  4. Click the Corporate Documents tab.
  5. Click Builder.
  6. Click the Administer tab.
  7. In the Oracle Reports Security portlet, click Oracle Reports Security Settings.
  8. In the Reports Definition File Access portlet, enter the P_NAME of one of the reports you batch registered in your SQL script.
  9. Click Edit. The Manage Component page is displayed.
  10. Click Edit at the bottom of the page to edit the parameters of the report.
  11. Review and edit the parameters as desired.
  12. Click OK.
  13. Click Close.
  14. Repeat steps 8 through 13 for each report that you batch registered with your script.
C.2 Batch Removing Report Packages
To remove many reports from OracleAS Portal at once, do the following:
  1. In a text editor, create a SQL script file (e.g., rmv_rdfs.sql) that contains one RWWWVREG.DEREGISTER_REPORT function call for each report definition file package that you want to remove. For example:
    VAR STATUS NUMBER;
    EXEC :STATUS := RWWWVREG.DEREGISTER_REPORT (P_NAME=>'Security');
    EXEC :STATUS := RWWWVREG.DEREGISTER_REPORT (P_NAME=>'Earnings');
    EXEC :STATUS := RWWWVREG.DEREGISTER_REPORT (P_NAME=>'Acc_pay');
    P_NAME is the name of the report definition file package you want to remove from OracleAS Portal.
  2. Start SQL*Plus and log in to the OracleAS Portal schema that owns the reports' packaged procedures.
  3. From the SQL*Plus command prompt, execute the script you created in the first step:
    @ rmv_rdfs.sql
    The script will execute and remove the packages from OracleAS Portal for each report listed in the script.
    This procedure will not remove the report definition files from the file system. It only unregisters the reports making them unavailable from OracleAS Portal. If you want to remove the files, you must delete them from the file system.
C.3 PL/SQL Batch Registering Function
The SQL script that rwconverter generates for you to batch register reports in Oracle Application Server consists mainly of calls to the RWWWVREG.REGISTER_REPORT function. The syntax of RWWWVREG.REGISTER_REPORT is as follows:
Function Rwwwvreg.register_report(
  p_owner varchar2,
  p_name varchar2,
  p_servers varchar2,
  p_filename varchar2,
  p_description varchar2,
  p_privileges varchar2,
  p_availability varchar2,
  p_types varchar2,
  p_formats varchar2,
  p_printers varchar2,
  p_pdformTemplate varchar2,
  p_parameters varchar2,
  p_trigger varchar2)
  return number;
    --  =0 : succeeded;
    --  !=0 : failed;
The table below describes each of the parameters taken by RWWWVREG.REGISTER_REPORT.
Table C-1 RWWWVREG.REGISTER_REPORT parameters
Parameter Description
P_OWNER
Is the DB Provider name. The default is the current Oracle Application Server DB Provider that you are connected to when you start the SQL*PLUS script.
For example:
P_NAME
Is the name used to identify the report in OracleAS Portal.
P_NAME corresponds to the Name field in the Create Report Definition File Access wizard.
For example:
P_NAME=>'Earnings'
P_SERVERS
Is the names of the Reports Servers on which the report definition files defined in the P_SERVERS parameter have access privileges. The list of Reports Servers is comma delimited.
P_SERVERS corresponds to the Reports Servers field in the Create Report Definition File Access wizard and the Edit Report Definition File page.
For example:
P_SERVERS=>'repserver,acct'
Note: The Reports Servers you list for P_SERVERS must already be registered in OracleAS Portal. For more information, refer to Chapter 11, "Deploying Reports in OracleAS Portal".
P_FILENAME
Is the name of the report definition file that is being registered.
P_FILENAME corresponds to the Oracle Reports File Name in the Create Report Definition File Access wizard and the Edit Report Definition File page.
For example:
P_DESCRIPTION
Is a description of the report.
P_DESCRIPTION corresponds to the Description field in the Create Report Definition File Access wizard and the Edit Report Definition File page.
For example:
P_PRIVILEGE
Is the users or roles given privileges to run the report definition file defined in P_FILENAME. This list is comma delimited.
P_PRIVILEGE corresponds to the Grantee list on the Access tab of the Manage Component page for the report. Note that you must uncheck Inherit Privileges from Portal DB Provider in order to see the Grantee list.
For example:
P_PRIVILEGE=>'SCOTT,JABERS,PORTAL90'
P_AVAILABILITY
Is the name of the availability calendar that determines when the report definition file defined in the P_FILENAME parameter will be available for processing.
P_AVAILABILITY corresponds to the Availability Calendar Name field in the Create Report Definition File Access wizard and the Edit Report Definition File page.
For example:
Note: The availability calendar must already exist in OracleAS Portal. For more information about creating an availability calendar, see Chapter 11, "Deploying Reports in OracleAS Portal".
P_TYPES
Is the destination types to which the report definition file defined in the P_FILENAME parameter can be sent (e.g., cache, printer). This list is comma delimited.
P_TYPES corresponds to the Types multiple select box in the Create Report Definition File Access wizard and the Edit Report Definition File page.
For example:
P_TYPES=>'CACHE,printer'
P_FORMATS
The destination formats to which the report definition file defined in the P_FILENAME parameter can be sent (e.g., HTML, PDF). This list is comma delimited.
P_FORMATS corresponds to the Formats multiple select box in the Create Report Definition File Access wizard and the Edit Report Definition File page.
For example:
P_PRINTERS
The printers to which the report definition file defined in the P_FILENAME parameter can print. This list is comma delimited.
P_PRINTERS corresponds to the Printers multiple select box in the Create Report Definition File Access wizard and the Edit Report Definition File page.
For example:
Note: The printers you list for P_PRINTERS must already be registered in OracleAS Portal. For more information, refer to Chapter 11, "Deploying Reports in OracleAS Portal".
P_PFORMTEMPLATE
Is the parameter form template that determines the page style of the Runtime Parameter Form.
P_PFORMTEMPLATE corresponds to the Parameter Form Template field in the Create Report Definition File Access wizard and the Edit Report Definition File page.
For example:
P_PARAMETERS
Is the user and system parameters' default, high, and low values, or list of values name.
Note: The P_PARAMETERS parameter does not have a corresponding rwconverter option. Hence, if you want to batch import user parameter values, ranges, or lists of values, you must manually edit the SQL script generated by rwconverter.
P_PARAMETERS corresponds to the (parameter) Name, LOV, Low Value, and High Value fields in the Create Report Definition File Access wizard and the Edit Report Definition File page.
The default corresponds to the value set in the Runtime Parameter Form for the specified parameter.
For example:
P_PARAMETERS=>'(P_LASTNAME, LOV=LASTNAME_LOV) (P_SSN)(COPIES, DEFAULT=1,LOW=1,HIGH=2)'
where:
P_LASTNAME, P_SSN, and COPIES are parameter names.
LOV is the name of the list of values.
DEFAULT is the default value.
LOW is the low value in a range of values.
HIGH is the high value in a range of values.
P_TRIGGER
Is the validation trigger written in PL/SQL that returns a boolean statement (e.g., true (succeeded) or false (failed)).
P_TRIGGER corresponds to the text box in the Create Report Definition File Access wizard and the Edit Report Definition File page.
For example:
EMPNAME = ''SMITH''
THEN
RETURN(TRUE);
ELSE
RETURN(FALSE);
END IF;
end;'
Oracle
Copyright © 2003 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
