Skip Headers
Oracle Application Server Reports Services Publishing Reports to the Web
10g (9.0.4)
Part Number B10314-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
A
Command Line Options
This appendix contains descriptions and examples of command line options that can be used with one or more of the following commands: rwclient, rwrun, rwbuilder, rwconverter, rwservlet, rwcgi, and rwserver. Each option description includes a table that indicates which commands can use which option keywords.
For examples of using command line options in your runtime URL, see Running Report Requests.
The following topics are discussed in this appendix:
A.1 Command Overview
This section provides a brief description of the commands whose keywords/options are discussed in this appendix, including:
Each command description includes a list of the keywords that can be used with it. In the command line, you must use the keyword along with its option. When you enter a command line, you can use the keywords in any order.
A.1.1 rwclient
The rwclient command parses and transfers a command line to the specified (or default) Reports Server. All file names and paths specified in rwclient refer to files and directories on the server machine, except for files specified in the CMDFILE keyword. In this case, the CMDFILE specified will be read and appended to the original command line (of which CMDFILE is a part) before being sent to the Reports Server. The runtime engine will not re-read the CMDFILE.
Keywords used with rwclient
The brackets surrounding each keyword in this list are there to create a separation between keywords and has no other significance.
rwclient [ACCESSIBLE] [ARRAYSIZE] [AUTHID] [AUTOCOMMIT] [BACKGROUND] [BCC]
[BLANKPAGES] [BUFFERS] [CACHELOB] [CC] [CELLWRAPPER] [CMDFILE][COLLATE] [COPIES]
[CUSTOMIZE] [DATEFORMATMASK] [DELIMITED_HDR] [DELIMITER] [DESFORMAT] [DESNAME]
[DESTINATION] [DESTYPE] [DISTRIBUTE] [ENGINERESPONSETIMEOUT] [EXPIRATION]
[EXPRESS_SERVER] [FROM] [JOBNAME] [JOBTYPE] [LONGCHUNK] [MODE] [MODULE|REPORT]
[NONBLOCKSQL] [NOTIFYFAILURE][NOTIFYSUCCESS][NUMBERFORMATMASK] [OLAP_CON]
[ONFAILURE] [ONSUCCESS] [ORIENTATION] [OUTPUTIMAGEFORMAT] [PAGESIZE] [PDFCOMP]
[PDFEMBED] [READONLY] [RECURSIVE_LOAD] [REPLYTO] [REPORT|MODULE] [ROLE]
[RUNDEBUG] [SCHEDULE] [SERVER][SQLTRACE][SUBJECT][SUPPRESSLAYOUT][TOLERANCE]
[TRACEFILE] [TRACEMODE] [TRACEOPTS] [USERID]
Examples
Example 1:
Running a paper report to a browser (cache)
rwclient server=myrepserv report=test.rdf userid=scott/tiger@mydb DESFORMAT=pdf
DESTYPE=cache
Example 2:
Sending a report output to a file
rwclient server=myrepserv report=test.rdf userid=scott/tiger@mydb desformat=pdf
DESTYPE=file DESNAME=c:\mydir\test
Example 3:
Sending a report output to a printer
DESTYPE=printer DESNAME=myprinter
Example 4:
Sending a report output via e-mail
DESTYPE=mail DESNAME="emp1@comp.com, emp2@comp.com" cc="emp3@comp.com"
bcc="mgr@comp.com" replyto="me@comp.com" from="me@comp.com"
Example 5:
Sending a report output to WebDAV (any WebDAV server or OracleAS Portal WebDAV)
desformat=htmlcss DESTYPE=webdav
DESNAME="http://myusername:mypassword@mywebdavserv.com/mydir/test.html"
Example 6:
Sending a report output to OracleAS Portal
DESTYPE=oracleportal desformat=PDF PAGEGROUP=mypagegrp OUTPUTPAGE=reports_output
ITEMTITLE=pushtoportal STATUSPAGE=result
Example 7:
Sending an XML PDS report output to a file
rwclient server=myrepserv report=myxmlpdstest.rdf destype=file desformat=PDF
desname=c:\mydir\my.pdf
Example 8:
Sending a JDBC PDS report output to a file
rwclient server=myrepserv report=myjdbcpdstest.rdf destype=file desformat=PDF
desname=c:\mydir\myxml.pdf p_jdbcpds=sybuser/sybpwd@server1.mydomain.com:1300
Example 9:
Distributing a report output to multiple destinations:
rwclient server=myrepserv report=test.rdf userid=scott/tiger@mydb DISTRIBUTE=yes
DESTINATION=c:\mydistribute.xml
Example 10:
Running scheduled reports
rwclient server=myrepserver report=test.rdf SCHEDULE="every first fri of month
from 15:53 Oct 23, 1999 retry 3 after 1 hour" destype=file desformat=pdf
desname=test.pdf
Example 11:
Using a secured Reports Server
destype=file desname=test.pdf AUTHID=myadmin/myadmin
Example 12:
Running a report with e-mail notification
rwclient server=myrepserver report=test.rdf userid=scott/tiger@mydb destype=file
desformat=pdf desname=test.pdf NOTIFYSUCCESS="emp@comp.com"
NOTIFYFAILURE="admin@comp.com"
Example 13:
Running a report that specifies a URL to be fetched with the URL engine:
desformat=pdf desname=test.pdf JOBTYPE=rwurl
URLPARAMETER="http://www.oracle.com"
Example 14:
Running a report with the traceopts enabled
desformat=pdf desname=test.pdf TRACEOPTS=trace_prf TRACEMODE=trace_replace
A.1.2 rwrun
The rwrun command runs a report using the OracleAS Reports Services in-process server. When you run a .rep file, the PL/SQL is already compiled and will not be recompiled. If you are running an .rdf file, the PL/SQL is automatically recompiled, if necessary. It becomes necessary if the report wasn't compiled and saved from Reports Builder or the platform or version on which you were running the report is incompatible with the platform on which it was last compiled and saved.
Keywords used with rwrun
rwrun [ACCESSIBLE] [ARRAYSIZE] [AUTHID] [AUTOCOMMIT] [BCC] [BLANKPAGES]
[BUFFERS] [CACHELOB] [CC] [CELLWRAPPER] [CMDFILE] [COLLATE] [COPIES] [CUSTOMIZE]
[DATEFORMATMASK] [DELIMITED_HDR] [DELIMITER] [DESFORMAT] [DESNAME] [DESTINATION]
[DESTYPE] [DISTRIBUTE] [EXPRESS_SERVER] [FROM] [LONGCHUNK] [MODE]
[MODULE|REPORT] [NONBLOCKSQL] [NOTIFYFAILURE][NOTIFYSUCCESS][OLAP_CON]
[PAGESTREAM] [PDFCOMP] [PDFEMBED] [PRINTJOB] [READONLY] [RECURSIVE_LOAD]
[REPLYTO] [REPORT|MODULE] [ROLE] [RUNDEBUG] [SAVE_RDF]
[SQLTRACE][SUBJECT][SUPPRESSLAYOUT][TRACEFILE] [TRACEMODE] [TRACEOPTS] [USERID]
Examples
Example 1:
Customizing a report
rwrun userid=scott/tiger@mydb report=emp.rdf  CUSTOMIZE=empcustomize.xml
destype=file desformat=pdf desname=emp.pdf
Example 2:
rwrun report=test.rdf userid=scott/tiger@mydb desformat=pdf destype=cache
Example 3: Sending report output to a file
rwrun report=test.rdf userid=scott/tiger@mydb desformat=pdf DESTYPE=file
DESNAME=c:\mydir\test.pdf
Example 4:
rwrun report=test.rdf userid=scott/tiger@mydb desformat=pdf DESTYPE=printer
DESNAME=myprinter
Example 5:
rwrun report=test.rdf userid=scott/tiger@mydb desformat=pdf DESTYPE=mail
DESNAME="emp1@comp.com, emp2@comp.com"cc="emp3@comp.com"bcc="mgr@comp.com"
Example 6:
rwrun report=test.rdf userid=scott/tiger@mydb desformat=htmlcss DESTYPE=webdav
Example 7:
rwrun report=test.rdf userid=scott/tiger@mydb DESTYPE=oracleportal desformat=PDF
PAGEGROUP=mypagegrp OUTPUTPAGE=reports_output ITEMTITLE=pushtoportal
STATUSPAGE=result
Example 8:
rwrun report=myxmlpdstest.rdf destype=file desformat=PDF desname=c:\mydir\my.pdf
Example 9:
rwrun report=myjdbcpdstest.rdf destype=file desformat=PDF
Example 10:
rwrun report=test.rdf userid=scott/tiger@mydb DISTRIBUTE=yes
Example 11:
rwrun report=test.rdf userid=scott/tiger@mydb desformat=pdf destype=file
Example 12:
rwrun report=test.rdf userid=scott/tiger@mydb destype=file desformat=pdf
desname=test.pdf NOTIFYSUCCESS="emp@comp.com" NOTIFYFAILURE="admin@comp.com"
Example 13:
A.1.3 rwbuilder
The rwbuilder command invokes Reports Builder. When you include a REPORT|MODULE keyword with the rwbuilder command at the command prompt, then press Enter, Reports Builder opens with the specified report highlighted in the Object Navigator. When no report is specified, Reports Builder opens with a Welcome dialog offering you the choice of opening an existing report or creating a new one.
Keywords used with rwbuilder
rwbuilder [ACCESSIBLE] [ARRAYSIZE] [AUTOCOMMIT] [BLANKPAGES] [BUFFERS]
[CACHELOB] [CMDFILE] [EXPRESS_SERVER] [LONGCHUNK] [MODULE|REPORT] [NONBLOCKSQL]
[OLAP_CON] [ONFAILURE] [ONSUCCESS] [OUTPUTIMAGEFORMAT] [PAGESIZE] [PRINTJOB]
[READONLY] [REPORT|MODULE] [RUNDEBUG] [SAVE_RDF][SQLTRACE] [SUPPRESSLAYOUT]
[TRACEFILE] [TRACEMODE] [TRACEOPTS] [USERID] [WEBSERVER_DEBUG] [WEBSERVER_
DOCROOT] [WEBSERVER_PORT]
Example: rwbuilder report=myrep.rdf userid=scott/tiger@mydb
A.1.4 rwconverter
The rwconverter command enables you to convert one or more report definitions or PL/SQL libraries from one storage format to another. For example, you can use rwconverter to:
In some cases, rwconverter will automatically compile the report's PL/SQL as part of the conversion process. Provided your conversion destination is not a .rex file, rwconverter automatically compiles PL/SQL under the following conditions:
In all other situations, you must compile the report's PL/SQL yourself (e.g., using Program >> Compile >> All in Reports Builder).
Fonts are mapped when a report is opened by Reports Builder or Reports Runtime, not during the conversion.
Keywords used with rwconverter
rwconverter [BATCH] [CMDFILE] [CUSTOMIZE] [DEST] [DTYPE] [DUNIT] [FORMSIZE]
[NOTIFYFAILURE] [OVERWRITE] [PAGESIZE] [SOURCE] [STYPE] [USERID] [P_OWNER] [P_
SERVERS] [P_NAME] [P_DESCRIPTION] [P_PRIVILEGE] [P_AVAILABILITY] [P_TYPES] [P_
FORMATS] [P_PRINTERS] [P_PFORMTEMPLATE] [P_TRIGGER] [RECURSIVE_LOAD][UPGRADE_
PLSQL]
Example: rwconverter scott/tiger@mydb stype=rdffile source=inven1.rdf
dtype=xmlfile dest=inven1_new.xml
A.1.5 rwservlet
rwservlet translates and delivers information between either a Web server or a J2EE Container (for example, OC4J) and the Reports Server, enabling you to run a report dynamically from your Web browser. Optionally, it can use the In-Process Server, which reduces the maintenance and administration of the Reports Server by providing a means for starting the server automatically, whenever it receives the first request from the client.
When you use the rwservlet command to run a JSP, you can use all keywords applicable to rwservlet. For more information on running a JSP with rwservlet, see Running Report Requests.
Keywords used with rwservlet
rwservlet [ACCESSIBLE] [ARRAYSIZE] [AUTHID] [AUTOCOMMIT] [BACKGROUND][BCC]
[BLANKPAGES] [BUFFERS] [CACHELOB] [CC] [CELLWRAPPER] [CMDKEY] [CONTENTAREA*]
[COLLATE] [COPIES] [CUSTOMIZE] [DATEFORMATMASK] [DELAUTH] [DELIMITED_HDR]
[DELIMITER] [DESFORMAT] [DESNAME] [DESTINATION] [DESTYPE] [DISTRIBUTE]
[ENGINERESPONSETIMEOUT] [EXPIRATION] [EXPIREDAYS] [EXPRESS_SERVER] [FROM]
[GETJOBID] [GETSERVERINFO] [HELP] [ITEMTITLE] [JOBNAME] [JOBTYPE] [KILLJOBID]
[LONGCHUNK] [MIMETYPE] [MODE] [MODULE|REPORT] [NONBLOCKSQL] [NOTIFYFAILURE]
[NOTIFYSUCCESS] [OLAP_CON] [ONFAILURE] [ONSUCCESS] [ORIENTATION] [OUTPUTFOLDER*]
[OUTPUTIMAGEFORMAT] [OUTPUTPAGE] [PAGEGROUP] [PAGESIZE] [PAGESTREAM] [PARAMFORM]
[PARSEQUERY] [PDFCOMP] [PDFEMBED] [READONLY] [RECURSIVE_LOAD] [REPLACEITEM]
[REPLYTO] [REPORT|MODULE] [ROLE] [RUNDEBUG] [SCHEDULE] [SERVER] [SHOWAUTH]
[SHOWENV] [SHOWMAP][SHOWJOBID] [SHOWJOBS] [SHOWMYJOBS]
[SITENAME*][SQLTRACE][STATUSFORMAT] [STATUSFOLDER*] [STATUSPAGE] [SSOCONN]
[SUBJECT][SUPPRESSLAYOUT][TOLERANCE] [TRACEMODE] [TRACEOPTS] [URLPARAMETER]
[USERID]
* maintained for backward compatibility with Oracle9iAS Portal Release 1 and/or Oracle WebDB Release 2.2.
The following keywords are commands rather than keyword-value pairs, i.e., commands are entered by themselves without a corresponding value: SHOWENV, SHOWJOBS, SHOWMAP, SHOWMYJOBS, KILLJOBID, PARSEQUERY, DELAUTH, GETJOBID, and GETSERVERINFO.
Examples
http://myiasFoot 1.mycomp.com:7779Foot 2/reports/rwservlet?server=myrepserver+report=myrep
o.rdf+desname=sample.pdf+desformat=pdf+destype=file
http://myias.mycomp.com:7779/reports/rwservlet?server=myrepserver+authidFoot 3=myrepu
ser/myreppassword+report=myrepo.rdf+desname=sample.pdf+desformat=pdf+destype=fil
e
Example 1:
http://myias.mycomp.com:7779/reports/rwservlet?server=myrepserv+report=test.rdf+
userid=scott/tiger@mydb+desformat=pdf+DESTYPE=cache
Example 2:
userid=scott/tiger@mydb+desformat=pdf+DESTYPE=file+DESNAME=c:\mydir\test.
Example 3:
userid=scott/tiger@mydb+desformat=pdf+DESTYPE=printer+DESNAME=myprinter
Example 4:
userid=scott/tiger@mydb+desformat=pdf+DESTYPE=mail+DESNAME="emp1@comp.com,emp2@c
omp.com"+CC="emp3@comp.com"+BCC="mgr@comp.com"+REPLYTO="me@comp.com"+FROM=me@com
p.com"
Example 5:
userid=scott/tiger@mydb+desformat=htmlcss+DESTYPE=webdav+DESNAME="http://myusern
Example 6:
userid=scott/tiger@mydb+destype=oracleportal+desformat=PDF+PAGEGROUP=mypagegrp+O
UTPUTPAGE=reports_output+ITEMTITLE=pushtoportal+STATUSPAGE=result
Example 7:
http://myias.mycomp.com:7779/reports/rwservlet?server=myrepserv+report=myxmlpdst
est.rdf+destype=file+desformat=PDF+DESNAME=c:\mydir\my.pdf
Example 8:
http://myias.mycomp.com:7779/reports/rwservlet?server=myrepserv+report=myjdbcpds
test.rdf+destype=file+desformat=PDF+desname=c:\mydir\myxml.pdf+p_
Example 9:
userid=scott/tiger@mydb+DISTRIBUTE=yes+DESTINATION=c:\mydistribute.xml
Example 10:
http://myias.mycomp.com:7779/reports/rwservlet?server=myrepserver+report=test.rd
f+SCHEDULE="every first fri of month from 15:53 Oct 23, 1999 retry 3 after 1
hour"+destype=file+desformat=pdf+desname=test.pdf
Example 11:
userid=scott/tiger@mydb+desformat=pdf+destype=file+desname=test.pdf+AUTHID=myadm
in/myadmin
Example 12:
Using a key file
http://myias.mycomp.com:7779/report/rwservlet?key1
where
key1=key defined in the cgicmd.dat file (the keyname should be the first parameter)
or
http://myias.mycomp.com:7779/report/rwservlet?server=myrepserv+userparam=12+CMDK
EY*=keyname
*when used with cmdkey, it can be anywhere in the URL
Example 13:
Running a report with a Parameter Form
http://myias.mycomp.com:7779/rwservlet?server=myrepserver+report=test.rdf+userid
=scott/tiger@mydb+destype=cache+desformat=htmlcss+PARAMFORM=yes
Example 14:
=scott/tiger@mydb+destype=file+desformat=pdf+desname=test.pdf+NOTIFYSUCCESS="emp
@comp.com"+NOTIFYFAILURE="admin@comp"
Example 15:
=scott/tiger@mydb+destype=file+desformat=pdf+desname=test.pdf+JOBTYPE=rwurl+URLP
Example 16:
=scott/tiger@mydb+destype=file+desformat=pdf+desname=test.pdf+TRACEOPTS=trace_
prf+TRACEMODE=trace_replace
A.1.6 rwcgi
Like rwservlet, rwcgi (the Common Gateway Interface (CGI) translates and delivers information between either a Web server or a J2EE Container (for example, OC4J) and the Reports Server, enabling you to run a report dynamically from your Web browser.
With Oracle Reports 10g, rwcgi is deprecated (maintained only for backward compatibility); instead, use JSPs or servlets (rwservlet).
Keywords used with rwcgi
rwcgi [ACCESSIBLE] [ARRAYSIZE] [AUTHID] [AUTOCOMMIT] [BACKGROUND][BCC]
[BLANKPAGES] [BUFFERS] [CACHELOB] [CC] [CELLWRAPPER] [COLLATE] [CONTENTAREA*]
[COPIES] [CUSTOMIZE] [DATEFORMATMASK] [DELAUTH][DELIMITED_HDR] [DELIMITER]
[FROM][GETJOBID][ITEMTITLE] [JOBNAME] [JOBTYPE][KILLJOBID][LONGCHUNK] [MIMETYPE]
[MODE] [MODULE|REPORT] [NONBLOCKSQL] [NOTIFYFAILURE] [NOTIFYSUCCESS] [OLAP_CON]
[ONFAILURE] [ONSUCCESS] [ORIENTATION] [OUTPUTFOLDER*] [OUTPUTIMAGEFORMAT]
[PARAMFORM][PARSEQUERY][PDFCOMP][PDFEMBED] [READONLY] [RECURSIVE_LOAD]
[REPLACEITEM] [REPLYTO] [REPORT|MODULE] [ROLE][RUNDEBUG][SCHEDULE][SERVER]
[SHOWENV][SHOWMAP][SHOWJOBID][SHOWJOBS] [SHOWMYJOBS] [SHOWAUTH] [SITENAME*]
[SQLTRACE] [STATUSFOLDER*] [STATUSPAGE] [SUBJECT][SUPPRESSLAYOUT][TOLERANCE]
Examples
http://mywebserver.comFoot 4:7779Foot 5/cgi-bin/rwcgi.exeFoot 6?server=myrepserver+report=myrepo
http://mywebserver.com:7779/cgi-bin/rwcgi.shFoot 7?server=myrepserver+authidFoot 8=myrepus
er/myreppassword+report=myrepo.rdf+desname=sample.pdf+desformat=pdf+destype=file
Example 1:
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserv+report=test.rdf+u
serid=scott/tiger@mydb+DESFORMAT=pdf+DESTYPE=cache
Example 2:
Example 3:
Example 4:
emp2@comp.com+CC=emp3@comp.com"+BCC="mgr@comp.com"+REPLYTO="me@comp.com+from=me@
comp.com"
Example 5:
Sending report output to WebDAV (any WebDAV server or OracleAS Portal WebDAV)
serid=scott/tiger@mydb+desformat=htmlcss+DESTYPE=webdav+DESNAME="http://myuserna
Example 6:
serid=scott/tiger@mydb+DESTYPE=oracleportal+desformat=PDF+PAGEGROUP=mypagegrp+OU
Example 7:
Sending XML PDS report output to a file
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserv+report=myxmlpdste
st.rdf+DESTYPE=file+desformat=PDF+desname=c:\mydir\my.pdf
Example 8:
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserv+report=myjdbcpdst
Example 9:
Distributing report output to multiple destinations
Example 10:
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserver+report=test.rdf
Example 11:
serid=scott/tiger@mydb+desformat=pdf+destype=file+desname=test.pdf+AUTHID=myadmi
n/myadmin
Example 12:
Using a key file
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?key1
where key1=key defined in the cgicmd.dat file (the keyname should be the first parameter)
or
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserv+userparam=12+CMDK
EY=key1
Example 13:
+userid=scott/tiger@mydb+destype=cache+desformat=htmlcss+PARAMFORM=yes
Example 14:
+userid=scott/tiger@mydb+destype=file+desformat=pdf+desname=test.pdf+NOTIFYSUCCE
SS="emp@comp.com"+NOTIFYFAILURE="admin@comp.com"
Example 15:
+userid=scott/tiger@mydb+destype=file+desformat=pdf+desname=test.pdf+JOBTYPE=rwu
rl+URLPARAMETER="http://www.oracle.com"
Example 16:
+userid=scott/tiger@mydb+destype=file+desformat=pdf+desname=test.pdf+TRACEOPTS=t
race_prf+TRACEMODE=trace_replace
A.1.7 rwserver
The rwserver command invokes the Reports Server. The Reports Server processes client requests, which includes ushering them through its various services, such as authentication and authorization checking, scheduling, caching, and distribution (including distribution to custom or pluggable output destinations). Reports Server also spawns runtime engines for generating requested reports, fetches completed reports from the Reports cache, and notifies the client that the job is ready.
Keywords used with rwserver
rwserver[AUTHID] [AUTOSTART] [BATCH] [SERVER] [SHUTDOWN] [TRACEOPTS] [INSTALL]
[UNINSTALL][JVMOPTIONS]
Example: rwserver -install myrepserver batch=yes autostart=yes
A.2 Command Line Syntax
Following is the syntax for a command line, where keyword=value is a valid command line option:
rwclient REPORT|MODULE=runfile USERID=username/password@database
[ [keyword=]value|(value1, value2, ...) ] SERVER=server_name
Keywords must be specified and can be used in any order following the command.
A.3 General Usage Notes
A.4 Command Line Keywords
A.4.1 ACCESSIBLE
Table A-1 indicates which commands can use the ACCESSIBLE keyword.
Table A-1 Commands that can use ACCESSIBLE
rwclient rwrun rwbuilder rwconverter rwservlet rwcgi rwserver
yes
yes
yes
no
yes
yes
no
Description
Use ACCESSIBLE to specify whether accessibility-related features offered through Oracle Reports are enabled (YES) or disabled (NO) for PDF output.
Syntax
ACCESSIBLE={YES|NO}
Values
Default
NO
A.4.2 ARRAYSIZE
Table A-2 indicates which commands can use the ARRAYSIZE keyword.
Table A-2 Commands that can use ARRAYSIZE
yes
yes
yes
no
yes
yes
no
Description
Use ARRAYSIZE to specify the size (in kilobytes) for use with Oracle9i array processing. Generally, the larger the array size, the faster the report will run.
Syntax
ARRAYSIZE=n
Values
n A number from 1 through 9999 (no comma is used with thousands). This means that Reports Runtime can use this number of kilobytes of memory per query in your report.
Default
10
Usage Notes
ARRAYSIZE can be used when running JSP-based Web reports from the command line.
A.4.3 AUTHID
Table A-3 indicates which commands can use the AUTHID keyword.
Table A-3 Commands that can use AUTHID
yes
yes
no
no
yes
yes
yes
Description
Use AUTHID to specify the user name and the password to be used to authenticate users to the restricted Reports Server. User authentication ensures that the users making report requests have access privileges to run the requested report.
Syntax
AUTHID=username/password
Values
username/password Any valid user name and password created in OracleAS Portal. See your DBA to create new users accounts in OracleAS Portal.
Default
None
Usage Notes
A.4.4 AUTOCOMMIT
Table A-4 indicates which commands can use the AUTOCOMMIT keyword.
Table A-4 Commands that can use AUTOCOMMIT
yes
yes
yes
no
yes
yes
no
Description
Use AUTOCOMMIT to specify whether database changes (for example, CREATE) should be automatically committed to the database. Some non-Oracle databases (for example, SQL Server) require that AUTOCOMMIT=YES.
Syntax
AUTOCOMMIT={YES|NO}
Values
Default
Usage Notes
AUTOCOMMIT can be used when running JSP-based Web reports from the command line.
A.4.5 AUTOSTART
Table A-5 indicates which commands can use the AUTOSTART keyword.
Table A-5 Commands that can use AUTOSTART
no
no
no
no
no
no
yes
Description
Use AUTOSTART to specify that the Reports Server will automatically start after initial installation and after a reboot, without requiring a user logon.
Syntax
AUTOSTART={YES|NO}
Values
Default
NO
Usage Notes
The AUTOSTART keyword is only recognized on Microsoft Windows platforms.
A.4.6 BACKGROUND
Table A-6 indicates which commands can use the BACKGROUND keyword.
Table A-6 Commands that can use BACKGROUND
yes
no
no
no
yes
yes
no
Description
BACKGROUND specifies whether a report on the server should be run synchronously (NO) or asynchronously (YES).
The BACKGROUND system parameter is deprecated in Oracle Reports. BACKGROUND is used only on the command line.
Syntax
BACKGROUND={YES|NO}
Values
Default
NO
Usage Notes
If BACKGROUND=YES is used with rwbuilder or rwrun, a warning is issued and the keyword is ignored.
A.4.7 BATCH
Table A-7 indicates which commands can use the BATCH keyword.
Table A-7 Commands that can use BATCH
no
no
no
yes
no
no
yes
Description
For all relevant commands, the BATCH option tells the server to run in no-UI mode. How it is used across commands is similar in that no UI is produced by the application when running from a command line that includes BATCH=YES. For example, for rwserver this allows the server to be run from scripts and remote agents so that no server dialog comes up while it is running.
With rwconverter, BATCH suppresses all terminal input and output in order to convert reports/libraries without user intervention. With rwserver, BATCH turns the server window dialog off (YES) or on (NO) to display or suppress process messages.
Syntax
BATCH={YES|NO}
Values
Default
NO
Usage Notes
A.4.8 BCC
Table A-8 indicates which commands can use the BCC keyword.
Table A-8 Commands that can use BCC
yes
yes
no
no
yes
yes
no
Description
Use BCC to specify e-mail recipient(s) of a blind courtesy copy (that is, one in which the names of specified recipients are not visible (published) to other recipients).
A blind copy is one in which the names of specified recipients are not visible (published) to other recipients.
Syntax
BCC=emailid | ("emailid","emailid", ...)
Values
emailid A valid e-mail address in the form someone@foo.com.
Default
None
Usage Notes
A.4.9 BLANKPAGES
Table A-9 indicates which commands can use the BLANKPAGES keyword.
Table A-9 Commands that can use BLANKPAGES
yes
yes
yes
no
yes
yes
no
Description
Use BLANKPAGES to specify whether to suppress blank pages when you print a report. Use this keyword when there are blank pages in your report output that you do not want to print.
Syntax
BLANKPAGES={YES|NO}
Values
Default
YES
Usage Notes
BLANKPAGES is especially useful if your logical page spans multiple physical pages (or panels), and you wish to suppress the printing of any blank physical pages.
A.4.10 BUFFERS
Table A-10 indicates which commands can use the BUFFERS keyword.
Table A-10 Commands that can use BUFFERS
yes
yes
yes
no
yes
yes
no
Description
Use BUFFERS to specify the size of the virtual memory cache in kilobytes. You should tune this setting to ensure that you have enough space to run your reports, but not so much that you are using too much of your system's resources.
Syntax
BUFFERS=n
Values
n A number from 1 through 9999 (note that thousands are not expressed with any internal punctuation, e.g., a comma or a decimal point). For some operating systems, the upper limit might be lower.
Default
640
Usage Notes
A.4.11 CACHELOB
Table A-11 indicates which commands can use the CACHELOB keyword.
Table A-11 Commands that can use CACHELOB
yes
yes
yes
no
yes
yes
no
Description
Use CACHELOB to specify whether to cache retrieved ORACLE large object or objects in the temporary file directory on the Reports Server (specified in the environment variable REPORTS_TMP or by the tempDir property of the engine element in the Reports Server configuration file, server_name.conf; note that a tempDir setting overrides a REPORTS_TMP setting.).
Syntax
CACHELOB={YES|NO}
Values
Default
YES
Usage Notes
A.4.12 CC
Table A-12 indicates which commands can use the CC keyword.
Table A-12 Commands that can use CC
yes
yes
no
no
yes
yes
no
Description
Use CC to specify e-mail recipient(s) of a courtesy copy.
Syntax
Values
Default
None
Usage Notes
A.4.13 CELLWRAPPER
Table A-13 indicates which commands can use the CELLWRAPPER keyword.
Table A-13 Commands that can use CELLWRAPPER
yes
yes
no
no
yes
yes
no
Description
Use CELLWRAPPER to specify the character or characters that displays around the delimited cells in your report output.
Syntax
CELLWRAPPER=value
Values
value Any alphanumeric character or string of alphanumeric characters.
Table A-14 Valid Values - General
Value Description
A double quotation mark displays on each side of the cell
A single quotation mark displays on each side of the cell
Table A-15 Valid Values - Reserved
Value Description
tab
A tab displays on each side of the cell
space
A single space displays on each side of the cell
return
A new line displays on each side of the cell
none
No cell wrapper is used
Table A-16 Valid Values - Escape Sequences based on the ASCII Character set
Value Description
\t
\n
Default
None
Usage Notes
A.4.14 CMDFILE
Table A-17 indicates which commands can use the CMDFILE keyword.
Table A-17 Commands that can use CMDFILE
yes
yes
yes
yes
no
no
no
Description
Use CMDFILE to call a file that contains one report's command line options. The file called must be an ASCII file, either .txt or any other ASCII-type file.
CMDFILE differs from the cgicmd.dat file, in that CMDFILE can contain one command line for one report, where the cgicmd.dat file can contain multiple key-identified commands for multiple reports. Additionally, the CMDFILE keyword can be used along with other arguments in a command line; while, when you use the key argument associated with cgicmd.dat, it is the only argument that appears in the command line.
The CMDFILE keyword enables you to run a report without specifying a large number of options each time you invoke a run command.
Syntax
CMDFILE=filename
Values
filename Any valid command file name.
Default
None
Usage Notes
A.4.15 CMDKEY
Table A-18 indicates which commands can use the CMDKEY keyword.
Table A-18 Commands that can use CMDKEY
no
no
no
no
yes
no
no
Description
Use CMDKEY to call a key-identified command line in the cgicmd.dat file. For example:
http://yourwebserver/reports/rwservlet?cmdkey=key& ...
Syntax
CMDKEY=key
Values
key The name of any key associated with a command line specified in the cgicmd.dat file.
Default
None
Usage Notes
A.4.16 COLLATE
Table A-19 indicates which commands can use the COLLATE keyword.
Table A-19 Commands that can use COLLATE
yes
yes
no
no
yes
yes
no
Description:
Use Collate to control the collating behavior when a report is output to a printer.
For example, printing three copies of a three page document with COLLATE set to YES would result in output similar to the following:
1 2 3|1 2 3| 1 2 3
The order specified is the page numbers being printed. This behavior is similar to selecting the Collate check box in the Print dialog box.
Printing three copies of a three page document with COLLATE set to NO would result in output similar to the following:
1 1 1| 2 2 2| 3 3 3
Syntax
COLLATE={YES|NO}
Values
Default
YES
A.4.17 CONTENTAREA
Table A-20 indicates which commands can use the CONTENTAREA keyword.
Table A-20 Commands that can use CONTENTAREA
yes
yes
no
no
yes
yes
no
Description
Use CONTENTAREA to specify the Oracle9iAS Portal Release 1 content area to which report output should be pushed. This keyword is maintained for backward compatibility with Oracle9iAS Portal Release 1; for backward compatibility with Oracle WebDB Release 2.2, see SITENAME. Beginning with OracleAS Portal Release 2, use PAGEGROUP.
Syntax
CONTENTAREA=name
Values
name The name (internal name) of any valid Oracle9iAS Portal Release 1 content area.
Default
None
Usage Notes
A.4.18 COPIES
Table A-21 indicates which commands can use the COPIES keyword.
Table A-21 Commands that can use COPIES
yes
yes
no
no
yes
yes
no
Description
Use COPIES to specify the number of copies of the report output to print.
Syntax
COPIES=n
Values
n Any valid integer from 1 through 9999 (note that thousands are not expressed with any internal punctuation, e.g., a comma or a decimal point).
Default
Taken from the Initial Value property of the COPIES parameter (the Initial Value was defined in Reports Builder at design time).
Usage Notes
A.4.19 CUSTOMIZE
Table A-22 indicates which commands can use the CUSTOMIZE keyword.
Table A-22 Commands that can use CUSTOMIZE
yes
yes
no
yes
yes
yes
no
Description
Use CUSTOMIZE to specify an Oracle Reports XML file to be run against the current report. The XML file contains customizations (for example, changes to the layout or data model) that change the report definition in some way.
Syntax
CUSTOMIZE=filename.xml | (filename1.xml, filename2.xml, ...)
Values
filenamen.xml The names of the files that contain a valid XML report definition, with path information prefixed to the name(s) if necessary. (if the files are not located in a path specified in the REPORTS_PATH registry or SourceDir property for the engine element).
For more information on customizing reports at runtime with XML customization files, see Customizing Reports with XML.
Default
None
Usage Notes
A.4.20 DATEFORMATMASK
Table A-23 indicates which commands can use the DATEFORMATMASK keyword.
Table A-23 Commands that can use DATEFORMATMASK
yes
yes
no
no
yes
yes
no
Description
Use DATEFORMATMASK to specify how date values display in your delimited report output.
Syntax
DATEFORMATMASK=mask
Values
mask Any valid date format mask.
Default
None
Usage Notes
A.4.21 DELAUTH
Table A-24 indicates which commands can use the DELAUTH keyword.
Table A-24 Commands that can use DELAUTH
no
no
no
no
yes
yes
no
Description
Use DELAUTH to delete rwservlet or rwcgi user ID cookies.
Syntax
http://yourwebserver/reports/rwservlet/delauth[?][server=servername][&authid=use
rname/password]
Values
See Syntax.
Default
None
Usage Notes
A.4.22 DELIMITED_HDR
Table A-25 indicates which commands can use the DELIMITED_HDR keyword.
Table A-25 Commands that can use DELIMITED_HDR
yes
yes
no
no
yes
yes
no
Description
Use DELIMITED_HDR to turn off boilerplate text (such as the report header) when running a report with DESFORMAT=DELIMITED or DESFORMAT=DELIMITEDDATA.
Syntax
DELIMITED_HDR={YES|NO}
Values
Default
YES
Usage Notes
This keyword can be used only if you have specified DESFORMAT=DELIMITED or DESFORMAT=DELIMITEDDATA.
A.4.23 DELIMITER
Table A-26 indicates which commands can use the DELIMITER keyword.
Table A-26 Commands that can use DELIMITER
yes
yes
no
no
yes
yes
no
Description
Use DELIMITER to specify the character or characters to use to separate the cells in your report output.
Syntax
DELIMITER=value
Values
value Any alphanumeric character or string of alphanumeric characters, such as:
a
Table A-27 Valid Values - General
Values Description
A comma separates each cell
A period separates each cell
Any of these reserved values:
Table A-28 Valid Values - Reserved
Values Description
tab
A tab separates each cell
space
A space separates each cell
return
A new line separates each cell
none
No delimiter is used
Table A-29 Valid Values - Escape Sequence based on the ASCII Character set
Values Description
\t
\n
Default
Tab
Usage Notes
A.4.24 DESFORMAT
Table A-30 indicates which commands can use the DESFORMAT keyword.
Table A-30 Commands that can use DESFORMAT
yes
yes
no
no
yes
yes
no
Description
Use DESFORMAT to specify the format for the job output. Use DESFORMAT to specify the printer driver to be used when DESTYPE is FILE and DESNAME=filename.
Syntax
DESFORMAT=desformat
Values
Any valid destination format not to exceed 1 kilobyte in length. Examples of valid values for this keyword are listed and described in Table A-31.
Table A-31 Valid values for DESFORMAT
Value Description
DELIMITED
The report output is sent to a file that can be read by standard spreadsheet utilities, such as Microsoft Excel. If you do not specify a delimiter (via the DELIMITER keyword), the default delimiter is a TAB. See Usage Notes.
DELIMITEDDATA
Provides the same functionality as DELIMITED, and is used when you have problems running large volume reports with DESFORMAT=DELIMITED. See Usage Notes.
HTML
This report output is sent to a file that is in HTML format.
HTMLCSS
This report output is sent to a file that includes style sheet extensions.
PDF
This report output is sent to a file that is in PDF format and can be read by a PDF viewer, such as Adobe Acrobat. PDF output is based upon the currently configured printer for your system. The drivers for the currently selected printer are used to produce the output; you must have a printer configured for the machine on which you are running the report.
POSTSCRIPT
This report output is sent to a file that is in PostScript format.
PRINTER DEFINITION
The printer definition to use when formatting the report when DESTYPE=FILE and DESNAME=filename:
If MODE=BITMAP, this is the name of the printer.
If MODE=CHARACTER, this is the character-mode printer definition file (.prt file), such as hpl, hplwide, dec, decwide, decland, dec180, dflt, or wide. Ask your System Administrator for a list of valid printer definitions.
RTF
The report output is sent to a file that can be read by word processors (such as Microsoft Word). When you open the file in Microsoft Word, you must choose View > Page Layout to view all the graphics and objects in your report.
XML
This report output is saved as an XML file. This report can be opened and read in an XML-supporting browser, or your choice of XML viewing application.
Default
Taken from the Initial Value property of the DESFORMAT parameter (the Initial Value was defined in Reports Builder at design time). When you run a report via Reports Builder and DESFORMAT is blank or dflt, then the current printer driver (specified in File > Printer ) is used. If a Printer Name has not been selected using the drop down list, then Reports Builder defaults to PostScript.
Usage Notes
A.4.25 DESNAME
Table A-32 indicates which commands can use the DESNAME keyword.
Table A-32 Commands that can use DESNAME
yes
yes
no
no
yes
yes
no
Description
Use DESNAME to specify the name of the cache, file, printer, OracleAS Portal, or e-mail ID (or distribution list) to which the report output will be sent.
Syntax
DESNAME=desname
Values
desname Any valid cache destination, file name, printer name, e-mail ID, or OraclePortal, not to exceed 1K in length. For printer names, you can optionally specify a port. For example:
DESNAME=printer,LPT1:
DESNAME=printer,FILE:
Default
Taken from the Initial Value property of the DESNAME parameter (the Initial Value was defined in Reports Builder at design time). If DESTYPE = FILE and DESNAME is an empty string, then it defaults to reportname.lis at runtime.
Usage Notes
A.4.26 DEST
Table A-33 indicates which commands can use the DEST keyword.
Table A-33 Commands that can use DEST
no
no
no
yes
no
no
no
Description
Use DEST to specify the name(s) of the converted reports or libraries.
Syntax
DEST={dest_name|(dest_name1, dest_name2, ...)|pathname}
Values
dest_name Any valid report/library name or filename, or a list of valid report/library names of filenames enclosed in parentheses and separated by commas (e.g., (qanda,text,dmast)).
Default
If the DEST keyword is not specified, rwconverter uses the following default names:
Usage Notes
A.4.27 DESTINATION
Table A-34 indicates which commands can use the DESTINATION keyword.
Table A-34 Commands that can use DESTINATION
yes
yes
no
no
yes
yes
no
Description
Use the DESTINATION keyword to specify the name of an XML file that defines the distribution for the current run of the report.
XML based distribution files must have the.xml extension.
Syntax
DESTINATION=filename.xml
Values
filename.xml The name of an XML file that defines a report or report section distribution.
Default
None
Usage Notes
To enable the DESTINATION keyword, you must specify DISTRIBUTE=YES on the command line. If both these keywords are specified, DESTYPE, DESNAME, and DESFORMAT are ignored if they are also specified.
For more information about creating advanced distributions, see Chapter 15, "Creating Advanced Distributions".
A.4.28 DESTYPE
Table A-35 indicates which commands can use the DESTYPE keyword.
Table A-35 Commands that can use DESTYPE
yes
yes
no
no
yes
yes
no
Description
Use DESTYPE to specify the type of device that will receive the report output. If you have created your own pluggable destination via the Oracle Reports Destination API, this is how the destination you created gets called.
Syntax
DESTYPE={CACHE|LOCALFILE|FILE|PRINTER|SYSOUT|MAIL|ORACLEPORTAL|FTP|WEBDAV|name_of_pluggable_destination}
Values
Table A-36 lists and describes the valid values for the DESTYPE keyword.
Table A-36 Valid values for the DESTYPE keyword
Value Description
CACHE
Sends the output directly to the Reports Server cache.
LOCALFILE
Valid only for rwclient, rwcgi, and rwservlet. Sends the output to a file on the client machine, synchronously or asynchronously.
FILE
Sends the output to the file on the server named in DESNAME.
PRINTER
Sends the output to the printer on the server named in DESNAME. You must have a printer that the OracleAS Reports Services can recognize installed and running.
SYSOUT
Valid only for rwcgi. Sends the output to the client machine's default output device and forces a synchronous call.
MAIL
Sends the output to the mail users specified in DESNAME. You can send mail to any mail system that works with SMTP.
Note: The configuration file rwbuilder.conf must include the pluginParam mailServer with the outgoing mail server name. This applies in both Windows and Solaris environment
ORACLEPORTAL
Valid for rwservlet, rwcgi, and rwclient.
Sends the output to OracleAS Portal. Relevant keywords include CONTENTAREA*, EXPIREDAYS, ITEMTITLE, OUTPUTFOLDER*, OUTPUTPAGE, PAGEGROUP, REPLACEITEM, SCHEDULE, SITENAME*,STATUSFOLDER*,STATUSPAGE.
FTPFoot 1
Valid for rwservlet,rwclient,rwcgi,and rwrun. Sends the output to the specified FTP server.
WEBDAVFoot 2
Valid for rwservlet,rwclient,rwcgi,and rwrun. Sends the output to the specified WebDAV URL so that the report can be published directly.
If you have created your own pluggable destination via the Oracle Reports Destination API, this is what you use to call the destination you created.
1 For more information about this pluggable destination, see the Oracle Reports Plugin Exchange on OTN (http://otn.oracle.com/products/reports/pluginxchange/content.html)
2 For more information about this pluggable destination, see the Oracle Reports Plugin Exchange on OTN (http://otn.oracle.com/products/reports/pluginxchange/content.html)
Default
Taken from the Initial Value property of the DESTYPE parameter (the Initial Value was defined in Reports Builder at design time).
Usage Notes
A.4.29 DISTRIBUTE
Table A-37 indicates which commands can use the DISTRIBUTE keyword.
Table A-37 Commands that can use DISTRIBUTE
yes
yes
no
no
yes
yes
no
Description
Use DISTRIBUTE to enable or disable distributing the report output to multiple destinations, as specified by the distribution list defined in the report distribution definition (defined in Reports Builder at design time) or a distribution XML file.
Syntax
DISTRIBUTE={YES|NO}
Values
Default
NO
Usage Notes
The DISTRIBUTE keyword works in close association with the DESTINATION keyword. DISTRIBUTE must have a value of YES for the DESTINATION keyword to take effect. If both these keywords are specified, DESTYPE, DESNAME, and DESFORMAT are ignored if they are also specified.
For more information about creating advanced distributions, see Creating Advanced Distributions.
A.4.30 DTYPE
Table A-38 indicates which commands can use the DTYPE keyword.
Table A-38 Commands that can use DTYPE
no
no
no
yes
no
no
no
Description
Use DTYPE to specify the format to which to convert the reports or libraries.
Syntax
DTYPE={PLDFILE|PLLFILE|RDFFILE|REPFILE|REXFILE|TDFFILE|XMLFILE|JSPFILE|REGISTER}
Values
The following values apply:
Default
REPFILE
Usage Notes
A.4.31 DUNIT
Table A-39 indicates which commands can use the DUNIT keyword.
Table A-39 Commands that can use DUNIT
no
no
no
yes
no
no
no
Description
Use DUNIT to specify the destination unit of measurement to which the report should be converted. If specified, DUNIT must differ from the SOURCE report's unit of measurement. If unspecified, the SOURCE report's unit of measurement is used.
Syntax
DUNIT={CENTIMETER|CHARACTER|INCH|POINT}
Values
Default
Null (the report's unit of measurement is used).
A.4.32 ENGINERESPONSETIMEOUT
Table A-40 indicates which command can use the ENGINERESPONSETIMEOUT keyword.
Table A-40 Commands that can use ENGINERESPONSETIMEOUT
yes
no
no
no
yes
yes
no
Description
Use ENGINERESPONSETIMEOUT to specify the maximum amount of time (in minutes) for an engine to update the status of the job while running a report in your environment. If it takes longer than this amount of time to update the job status for some reason (e.g., due to the engine hanging or a long blocking SQL query), then Reports Server terminates the job.
This parameter overrides the engineResponseTimeOut attribute of the engine element in the Reports Server configuration file. Refer to engine for further information about the engine element.
Syntax
ENGINERESPONSETIMEOUT=number
Values
number A number of minutes (e.g., 5).
Default
None
A.4.33 EXPIRATION
Table A-41 indicates which command can use the EXPIRATION keyword.
Table A-41 Commands that can use EXPIRATION
yes
no
no
no
yes
yes
no
Description
Use EXPIRATION to define how long report output can exist in cache before it is deleted.
See Reusing Report Output from Cache for more information on duplicate job detection.
Syntax
EXPIRATION=time_string
Values
time_string Is in one of two formats:
Default
None
A.4.34 EXPIREDAYS
Table A-42 indicates which commands can use the EXPIREDAYS keyword.
Table A-42 Commands that can use EXPIREDAYS
no
no
no
no
yes
yes
no
Description
Use EXPIREDAYS to specify the number of days after which the Oracle Reports output pushed to Oracle9iAS Portal Release 1 should be expired.
Syntax
EXPIREDAYS={PERMANENT|1 day|2 days|3 days|7 days|14 days|31 days|60 days|90 days|120 days}
Values
Default
None
Usage Notes
A.4.35 EXPRESS_SERVER
Table A-43 indicates which commands can use the EXPRESS_SERVER keyword.
Table A-43 Commands that can use EXPRESS_SERVER
yes
yes
yes
no
yes
yes
no
Description
Use EXPRESS_SERVER to specify the Express Server to which you want to connect.
Syntax
EXPRESS_SERVER="server=server/domain=domain/user=userid/password=passwd"
Syntax with RAM
EXPRESS_SERVER="server=server/domain=domain/user=userid/password=passwd/ramuser=ramuserid/rampassword=rampasswd/ramexpressid=ramexpid/ramserverscript=ramsscript/rammasterdb=ramdb/ramconnecttype=ramconn"
Values
A valid connect string enclosed in double quotes (") where:
Table A-44 Connect String Values
Values Description
server
The Express Server string (for example, ncacn_ip_tcp:olap2-pc/sl=x/st=x/ct=x/sv=x/). See below for more details on the server string.
domain
The Express Server domain.
user
The user ID to log on to the Express Server.
password
The password for the user ID.
ramuser
The user ID to log into the RDBMS.
rampassword
The password for the RDBMS.
ramexpressid
The Oracle Sales Analyzer database user ID. This is required for Oracle Sales Analyzer databases only.
ramserverscript
The complete file name (including the full path) of the remote database configuration file (RDC) on the server. This file specifies information such as the location of code and data databases. Using UNC (Universal Naming Convention) syntax allows multiple users to use the same connection to access the data without having to map the same drive letter to that location. UNC syntax is \\ServerName\ShareName\ followed by any subfolders or files.
rammasterdb
The name of the Relational Access Manager database to attach initially. You must specify only the database file name. This database must reside in a directory that is included in the path list in ServerDBPath for Express Server. You can check the ServerDBPath in the File I/O tab of the Express Configuration Manager dialog box.
ramconnecttype
The type of Express connection. Always specify 0 for a direct connection.
Parameters
The server value contains four parameters that correspond to settings that are made in the Oracle Express Connection Editor and stored in connection (XCF) files. All four parameters are required and can be specified in any order. Table A-45 describes the parameters and their settings:
Table A-45 Settings for parameters used with EXPRESS_SERVER's server value
Parameter Description Setting
sl
Server Login
-2: Host (Domain Login)
-1: Host (Server Login)
0: No authentication required
1: Host (Domain Login) and Connect security
2: Host (Domain Login) and Call security
3: Host (Domain Login) and Packet security
4: Host (Domain Login) and Integrity security
5: Host (Domain Login) and Privacy security
Note: Windows NT uses all the settings. UNIX systems use only the settings 0, -1, and -2. See the Express Connection Editor Help system for information on these settings.
st
Server Type
:1: Express Server
ct
Connection Type
0: Express connection
sv
Server Version
1: Express 6.2 or greater
Default
None
Usage Notes
A.4.36 FORMSIZE
Table A-46 indicates which commands can use the FORMSIZE keyword.
Table A-46 Commands that can use FORMSIZE
no
no
no
yes
no
no
no
Description
Use FORMSIZE to specify the size of the Runtime Parameter Form for the converted report in terms of the destination unit of measurement (specified using DUNIT).
Syntax
FORMSIZE=width x height
Values
width/height Any valid values in the specified unit of measurement.
Default
None
Usage Notes
A.4.37 FROM
Table A-47 indicates which commands can use the FROM keyword.
Table A-47 Commands that can use FROM
yes
yes
no
no
yes
yes
no
Description
Use FROM to specify the e-mail address of the sender of an e-mail.
Syntax
FROM=emailid
Values
emailid Any valid e-mail address in the form someone@foo.com.
Default
loginid@machine_name
Usage Notes
Related keywords include BCC,CC, FROM, REPLYTO, and SUBJECT. Note that DESNAME is used to specify the main recipient(s) of the e-mail.
A.4.38 GETJOBID
Table A-48 indicates which commands can use the GETJOBID keyword.
Table A-48 Commands that can use GETJOBID
no
no
no
no
yes
yes
no
Description
Use GETJOBID to retrieve the result output of the Reports Server job with job ID n.
Syntax
http://yourwebserver/reports/rwservlet/getjobidn[?][server=server_
name][&authid=username/password]
Values
See Syntax.
Default
None
Usage Notes
A.4.39 GETSERVERINFO
Table A-49 indicates which commands can use the GETSERVERINFO keyword.
Table A-49 Commands that can use GETSERVERINFO
no
no
no
no
yes
no
no
Description
Use GETSERVERINFO to display Reports Server information. You can choose the format (HTML or XML) in which the information is returned via &statusformat.
Syntax
http://yourwebserver/reports/rwservlet/getserverinfo[?][server=server_
name][&authid=username/password][&statusformat={html|xml}]
Values
See Syntax.
Default
None
Usage Notes
A.4.40 HELP
Table A-50 indicates which commands can use the HELP keyword.
Table A-50 Commands that can use HELP
no
no
no
no
yes
yes
no
Description
Use HELP to display a help topic that lists the keywords you can use with the rwservlet command. For example:
http://yourwebserver/reports/rwservlet/help?command=keyword
Syntax
or
Values
See Syntax.
Default
None
A.4.41 INSTALL
Table A-51 indicates which commands can use the INSTALL keyword
Table A-51 Commands that can use INSTALL
no
no
no
no
no
no
yes
Description
Use INSTALL to configure an instance of the Reports Server on Microsoft Windows as a service. This keyword does not work on UNIX platforms.
Syntax
INSTALL reports_server_name
Values
reports_server_name A valid name for the Reports Server instance.
Default
None
Usage Notes
A.4.42 ITEMTITLE
Table A-52 indicates which commands can use the ITEMTITLE keyword.
Table A-52 Commands that can use ITEMTITLE
yes
yes
no
no
yes
yes
no
Description
Use ITEMTITLE to specify the display name Oracle9iAS Portal Release 1 should use for Oracle Reports output. The name will display in Oracle9iAS Portal Release 1 and link to Oracle Reports output.
Syntax
ITEMTITLE=title
Values
title Any text. Put quotation marks around the value if the value has any character spaces in it or you are specifying the option in the cgicmd.dat file.
Default
The report file name
Usage Notes
A.4.43 JOBNAME
Table A-53 indicates which commands can use the JOBNAME keyword.
Table A-53 Commands that can use JOBNAME
yes
no
no
no
yes
yes
no
Description
Use JOBNAME to specify the name for a job to appear in Reports Queue Manager. It is treated as a comment and has nothing to do with running the job. If JOBNAME is not specified, then Reports Queue Manager shows the report name as the job name.
Syntax
JOBNAME=string
Values
Any job name.
Default
None
Usage Notes
JOBNAME can be used when running JSP-based Web reports from the command line.
A.4.44 JOBTYPE
Table A-54 indicates which commands can use the JOBTYPE keyword.
Table A-54 Commands that can use JOBTYPE
yes
no
no
no
yes
yes
no
Description
Use JOBTYPE to specify the type of job to be processed by the server. You can enter any type of job, as long as the Reports Server has an engine to process it.
Syntax
JOBTYPE=jobtype
Values
jobtype A job for which the Reports Server has an engine.
Default
REPORT
A.4.45 JVMOPTIONS
Table A-55 indicates which commands can use the JVMOPTIONS keyword.
Table A-55 Commands that can use JVMOPTIONS
no
yes
yes
yes
no
no
yes
Description:
Use JVMOPTIONS to set options for either Reports Runtime, Reports Builder, Reports Converter, or Reports Server's Java Virtual Machine (JVM). For example, you could use the following command line to start the Reports Server with a 512Mb heap space:
rwserver server= servername jvmoptions=-Xmx512M
You could also use the following command line to start Reports Builder with a 512Mb heap space:
rwbuilder jvmoptions=-Xmx512M
Multiple options can be passed, in which case the options must be enclosed in quotes:
rwserver server= servername jvmoptions="-Xmx256M -Xms=128M"
rwbuilder jvmoptions="-Xmx256M -Xms=128M"
Syntax
JVMOPTIONS={options in the Reports Runtime, Reports Builder, Reports Converter, or Reports Server's JVM}
Default
-Xmx256M
The value set using the jvmoptions keyword will override the value in the REPORTS_JVM_OPTIONS environment variable, if set.
A.4.46 KILLJOBID
Table A-56 indicates which commands can use the KILLJOBID keyword.
Table A-56 Commands that can use KILLJOBID
no
no
no
no
yes
yes
no
Description
Use KILLJOBID to kill a Reports Server job with the specified job ID n.
Syntax
http://yourwebserver/reports/rwservlet/killjobidn[?][server=server_
name][&authid=username/password][&statusformat={html|xml|xmldtd}]
Values
See Syntax.
Default
None
Usage Notes
A.4.47 LONGCHUNK
Table A-57 indicates which commands can use the LONGCHUNK keyword.
Table A-57 Commands that can use LONGCHUNK
yes
yes
yes
no
yes
yes
no
Description
LONGCHUNK is the size (in kilobytes) of the increments in which Reports Builder retrieves a LONG column value. When retrieving a LONG value, you might want to retrieve it in increments rather than all at once because of memory size restrictions. LONGCHUNK applies only to Oracle databases.
Syntax
LONGCHUNK=n
Values
Default
10
Usage Notes
LONGCHUNK can be used when running JSP-based Web reports from the command line.
A.4.48 MIMETYPE
Table A-58 indicates which commands can use the MIMETYPE keyword.
Table A-58 Commands that can use MIMETYPE
no
no
no
no
yes
yes
no
Description
Use MIMETYPE to override the MIME type assigned by the Reports Server when it returns output for the Web. In most cases, the default MIME type is correct, but, in cases where it is not, you can override it with this keyword. For example:
mimetype=application/vnd.ms-excel
Syntax
MIMETYPE=string
Values
string A valid MIME type specification.
Default
None
Usage Notes
OracleAS Reports Services does not verify the string you enter for MIMETYPE. You must ensure yourself that the string is correct for the returned report output.
A.4.49 MODE
Table A-59 indicates which commands can use the MODE keyword.
Table A-59 Commands that can use MODE
yes
yes
no
no
yes
yes
no
Description
Use MODE to specify whether to run the report in character mode or bitmap. This enables you to run a character-mode report from Reports Builder.
Syntax
MODE={BITMAP|CHARACTER|DEFAULT}
Values
Default
DEFAULT
A.4.50 MODULE|REPORT
Table A-60 indicates which commands can use the MODULE|REPORT keyword.
Table A-60 Commands that can use MODULE|REPORT
yes
yes
yes
no
yes
yes
no
Description
Use MODULE or REPORT to specify the name of the report to run.
Syntax
Values
runfile Any valid runfile (that is, a file with an extension of .rep,.rdf,.jsp, or .xml).
Default
None
Usage Notes
A.4.51 NONBLOCKSQL
Table A-61 indicates which commands can use the NONBLOCKSQL keyword.
Table A-61 Commands that can use NONBLOCKSQL
yes
yes
yes
no
yes
yes
no
Description
Use NONBLOCKSQL to specify whether to allow other programs to execute while data is fetched from the database.
Syntax
NONBLOCKSQL={YES|NO}
Values
Default
YES
Usage Notes
NONBLOCKSQL can be used when running JSP-based Web reports from the command line.
A.4.52 NOTIFYFAILURE
Table A-62 indicates which commands can use the NOTIFYFAILURE keyword.
Table A-62 Commands that can use NOTIFYFAILURE
yes
yes
no
no
yes
yes
no
Description
Use NOTIFYFAILURE to specify the recipient(s) of a notification e-mail should a report request fail. Use this keyword when you configure your Reports Server to use the notification class. For more information, see the notification discussion in Configuring OracleAS Reports Services.
Syntax
NOTIFYFAILURE=emailid|(emailid,emailid,...)
Values
Default
None
Usage Notes
A.4.53 NOTIFYSUCCESS
Table A-63 indicates which commands can use the NOTIFYSUCCESS keyword.
Table A-63 Commands that can use NOTIFYSUCCESS
yes
yes
no
no
yes
yes
no
Description
Use NOTIFYSUCCESS to specify the recipient(s) of a notification e-mail should a report request succeed. Use this keyword when you configure your Reports Server to use the notification class. For more information, see the notification discussion in Configuring OracleAS Reports Services.
Syntax
NOTIFYSUCCESS=emailid|(emailid,emailid,...)
Values
Default
None
Usage Notes
A.4.54 NUMBERFORMATMASK
Table A-64 indicates which commands can use the NUMBERFORMATMASK keyword.
Table A-64 Commands that can use NUMBERFORMATMASK
yes
yes
no
no
yes
yes
no
Description
Use NUMBERFORMATMASK to specify how number values display in your delimited report output.
Syntax
NUMBERFORMATMASK=mask
Values
Any valid number format mask.
Default
None
Usage Notes
A.4.55 OLAP_CON
Table A-65 indicates which commands can user the OLAP_CON keyword.
Table A-65 Commands that can use OLAP_CON
yes
yes
yes
no
yes
yes
no
Description
OLAP_CON specifies the Oracle OLAP (on-line analytical processing) connection string to connect to a database that contains multidimensional Oracle OLAP data.
Syntax
OLAP_CON=userid/password/hostname/SID/portnumber
Values
A valid OLAP connection string where:
For example:
OLAP_Con="user1/secret1/mypc.us.oracle.com/mySID/9201
A.4.56 ONFAILURE
Table A-66 indicates which commands can use the ONFAILURE keyword.
Table A-66 Commands that can use ONFAILURE
yes
yes
yes
no
yes
yes
no
Description
Use ONFAILURE to specify whether you want a COMMIT or ROLLBACK performed if an error occurs and the report fails to complete.
Syntax
ONFAILURE={COMMIT|ROLLBACK|NOACTION}
Values
Default
Usage Notes
A.4.57 ONSUCCESS
Table A-67 indicates which commands can use the ONSUCCESS keyword.
Table A-67 Commands that can use ONSUCCESS
yes
yes
yes
no
yes
yes
no
Description
Use ONSUCCESS to specify that either a COMMIT or ROLLBACK should be performed when a report is finished running.
Syntax
ONSUCCESS={COMMIT|ROLLBACK|NOACTION}
Values
Default
Usage Notes
A.4.58 ORIENTATION
Table A-68 indicates which commands can use the ORIENTATION keyword.
Table A-68 Commands that can use ORIENTATION
yes
yes
no
no
yes
yes
no
Description
ORIENTATION controls the direction in which the pages of the report will print.
Syntax
ORIENTATION={DEFAULT|LANDSCAPE|PORTRAIT}
Values
DEFAULT Use the current printer setting for orientation.
LANDSCAPE Landscape orientation (long side at top and bottom).
PORTRAIT Portrait orientation (short side at top and bottom).
Default
DEFAULT
Usage Notes
A.4.59 OUTPUTFOLDER
Table A-69 indicates which commands can use the OUTPUTFOLDER keyword.
Table A-69 Commands that can use OUTPUTFOLDER
yes
yes
no
no
yes
yes
no
Description
Use OUTPUTFOLDER to specify the name of the Oracle WebDB Release 2.2 or OracleAS Portal folder to push Oracle Reports output. This keyword is maintained for backward compatibility with Oracle WebDB Release 2.2 and Oracle9iAS Portal Release 1. Beginning with OracleAS Portal 10g (9.0.4), use OUTPUTPAGE.
Syntax
OUTPUTFOLDER=folder
Values
folder Any valid folder name (internal name) used in Oracle WebDB Release 2.2 or Oracle9iAS Portal Release 1.
Default
Oracle_Reports_Output
Usage Notes
A.4.60 OUTPUTIMAGEFORMAT
Table A-70 indicates which commands can use the OUTPUTIMAGEFORMAT keyword.
Table A-70 Commands that can use OUTPUTIMAGEFORMAT
yes
yes
yes
no
yes
yes
no
Description
Use OUTPUTIMAGEFORMAT to choose the format for images in your report output.
Syntax
OUTPUTIMAGEFORMAT={PNG|JPEG|JPG|GIF|BMP}
Values
Usage Notes
Examples
Example 1
The following command lines generate PNG images with HTML output:
rwclient server=my_rep_server report=images.rdf destype=file desformat=html
desname=images.html userid=user_id outputimageformat=PNG
rwrun report=images.rdf destype=file desformat=html desname=images.html
Similarly when DESFORMAT=pdf, images are embedded in PNG format in the generated PDF document.
Example 2
An error is displayed if an invalid value is specified for the OUTPUTIMAGEFORMAT. The following command lines generate an error message:
desname=images.html userid=user_id outputimageformat=ABCD
The invalid image format ABCD generates the following error message:
REP-35000: The image output format specified is not supported.
A.4.61 OUTPUTPAGE
Table A-71 indicates which commands can use the OUTPUTPAGE keyword.
Table A-71 Commands that can use OUTPUTPAGE
yes
yes
no
no
yes
yes
no
Description
Use OUTPUTPAGE to specify the name of the Oracle Reports page to push a report output information to. For backward compatibility with earlier versions (Oracle WebDB Release 2.2 and Oracle9iAS Portal Release 1), see OUTPUTFOLDER.
Syntax
OUTPUTPAGE=page
Values
page Any valid page name (internal name) used in Oracle9iAS Portal Release 1.
Default
Usage Notes
A.4.62 OVERWRITE
Table A-72 indicates which commands can use the OVERWRITE keyword.
Table A-72 Commands that can use OVERWRITE
no
no
no
yes
no
no
no
Description
Use OVERWRITE to specify whether to overwrite existing files with the converted files.
Syntax
OVERWRITE={YES|NO|PROMPT}
Values
Default
NO
A.4.63 P_AVAILABILITY
Table A-73 indicates which commands can use the P_AVAILABILITY keyword.
Table A-73 Commands that can use P_AVAILABILITY
no
no
no
yes
no
no
no
Description
Use P_AVAILABILITY to specify the name of the availability calendar that determines when the reports specified will be available for processing. This keyword is only used when DTYPE=REGISTER.
Syntax
P_AVAILABILITY=calendar_name
Values
calendar_name Any valid availability calendar name.
Default
None
Usage Notes
The availability calendar must exist in OracleAS Portal before running the SQL*PLUS script. If it does not, an invalid package may be created.
A.4.64 P_DESCRIPTION
Table A-74 indicates which commands can use the P_DESCRIPTION keyword.
Table A-74 Commands that can use P_DESCRIPTION
no
no
no
yes
no
no
no
Description
Use P_DESCRIPTION to specify the text that provides additional information about the report. This keyword is only used when DTYPE=REGISTER.
Syntax
P_DESCRIPTON=description_text
Values
description_text Any text string.
Default
None
A.4.65 P_FORMATS
Table A-75 indicates which commands can use the P_FORMATS keyword.
Table A-75 Commands that can use P_FORMATS
no
no
no
yes
no
no
no
Description
Use P_FORMATS to specify the allowable destination formats for the specified reports. This keyword is only used when DTYPE=REGISTER.
Syntax
P_FORMATS=destination_format|(destination_format1,destination_format2,...)
Values
destination_format Any valid destination format (e.g., HTML), or a list of valid destination formats enclosed by parentheses with a comma separating the names (e.g., HTMLCSS,PDF,RTF).
Default
None
A.4.66 P_NAME
Table A-76 indicates which commands can use the P_NAME keyword.
Table A-76 Commands that can use P_NAME
no
no
no
yes
no
no
no
Description
Use P_NAME to specify the report name displayed in OracleAS Portal. This keyword is only used when DTYPE=REGISTER.
Syntax
P_NAME=report_name
Values
report_name Any report name.
Default
If P_NAME is not specified, the PL/SQL function is populated with the report definition file name.
Usage Notes
A.4.67 P_OWNER
Table A-77 indicates which commands can use the P_OWNER keyword.
Table A-77 Commands that can use P_OWNER
no
no
no
yes
no
no
no
Description
Use P_OWNER to specify the OracleAS Portal DB Provider that owns a report's package, which is created when the report definition files are registered. This keyword is only used when DTYPE=REGISTER.
Syntax
P_OWNER=portal_dbprovider
Values
portal_dbprovider Any valid OracleAS Portal DB Provider name.
Default
The name of the OracleAS Portal DB Provider to which you are connected when you run the SQL*PLUS script file.
A.4.68 P_PFORMTEMPLATE
Table A-78 indicates the commands that can use the P_PFORMTEMPLATE keyword.
Table A-78 Commands that can use P_PFORMTEMPLATE
no
no
no
yes
no
no
no
Description
Use P_PFORMTEMPLATE to specify the name of the OracleAS Portal template that determines the style of the Runtime Parameter Form. This keyword is only used when DTYPE=REGISTER.
Syntax
P_PFORMTEMPLATE=template_name
Values
template_name Any valid OracleAS Portal template name.
Default
None
A.4.69 P_PRINTERS
Table A-79 indicates the commands that can use the P_PRINTERS keyword.
Table A-79 Commands that can use P_PRINTERS
no
no
no
yes
no
no
no
Description
Use P_PRINTERS to specify the allowable printers for the specified reports. This keyword is only used when DTYPE=REGISTER.
Syntax
P_PRINTERS=printer_name
Values
printer_name Any valid printer (e.g., PRT1), or a list of valid printers enclosed by parentheses with a comma separating the names (e.g., (PRT1,PRT2,PRT3)).
Default
None
Usage Note
Access to the printer(s) should already exist in OracleAS Portal before running the SQL*Plus script.
A.4.70 P_PRIVILEGE
Table A-80 indicates which commands can use the P_PRIVILEGE keyword.
Table A-80 Commands that can use P_PRIVILEGE
no
no
no
yes
no
no
no
Description
Use P_PRIVILEGE to specify the users or roles who have access privileges to run the specified reports. This keyword is only used when DTYPE=REGISTER.
Syntax
P_PRIVILEGE=user_name
Values
user_name Any user name or role that OracleAS Portal can recognize (e.g., SCOTT), or a list of user names or roles enclosed by parentheses with a comma separating the names (e.g., (SCOTT,JABERS,PMARTIN)).
Default
None
A.4.71 P_SERVERS
Table A-81 indicates which commands can use the P_SERVERS keyword.
Table A-81 Commands that can use P_SERVERS
no
no
no
yes
no
no
no
Description
Use P_SERVERS to specify the names of the restricted Reports Servers that can run the report. This keyword is only used when DTYPE=REGISTER.
Syntax
P_SERVERS=tnsname
Values
tnsname Any valid TNS name of the Reports Server (e.g., repserver), or a list of valid Reports Server TNS names enclosed by parentheses with a comma separating the names (e.g., repserver, acct_server, sales_server).
Default
None
Usage Notes
Access to the Reports Server(s) should already exist in OracleAS Portal.
A.4.72 P_TRIGGER
Table A-82 indicates the commands that can use the P_TRIGGERS keyword.
Table A-82 Commands that can use P_TRIGGER
no
no
no
yes
no
no
no
Description
Use P_TRIGGER to specify the PL/SQL function that is executed when parameter values are specified on the command line and when users accept the Runtime Parameter Form. The function must return a boolean value (TRUE or FALSE). For example:
P_TRIGGER=Is begin IF UPPER(DESTYPE) = 'PRINTER' AND EMPNAME = 'SMITH' THEN
RETURN(TRUE); ELSE RETURN(FALSE); END IF; end;
Syntax
P_TRIGGER=plsql_function
Values
plsql_function Any valid PL/SQL function that returns a boolean value.
Default
None
A.4.73 P_TYPES
Table A-83 indicates which commands can use the P_TYPES keyword.
Table A-83 Commands that can use P_TYPES
no
no
no
yes
no
no
no
Description
Use P_TYPES to specify the allowable destination types for the specified reports. This keyword is only used when DTYPE=REGISTER.
Syntax
P_TYPES=destination_type
Values
destination_type Any valid destination type (e.g., CACHE), or a list of valid destination types enclosed by parentheses with a comma separating the names (e.g., CACHE,MAIL,PRINTER).
Default
None
A.4.74 PAGEGROUP
Table A-84 indicates which commands can use the PAGEGROUP keyword.
Table A-84 Commands that can use PAGEGROUP
yes
yes
no
no
yes
yes
no
Description
Use PAGEGROUP to specify the name of the Oracle9iAS Portal Release 1 page group to which report output should be pushed. For backward compatibility with earlier versions, see SITENAME (for Oracle WebDB Release 2.2) and CONTENTAREA (for Oracle9iAS Portal Release 1). The page group must be created in Oracle9iAS Portal Release 1 before you can use this keyword.
Syntax
PAGEGROUP=pagegroup
Values
pagegroup Any valid page group name (internal name) used in Oracle9iAS Portal Release 1.
Default
Usage Notes
A.4.75 PAGESIZE
Table A-85 indicates which commands can use the PAGESIZE keyword.
Table A-85 Commands that can use PAGESIZE
yes
yes
yes
yes
yes
yes
no
Description
Use PAGESIZE to set the dimensions of the physical page (that is, the size of the page that the printer outputs). The page must be large enough to contain the report. For example, if a frame in a report expands to a size larger than the page dimensions, then the report is not run.
Syntax
PAGESIZE=width x height
Values
Any valid page dimensions of the form: page width x page height, where page width and page height are more than zero. The maximum width and height depends which unit of measurement was set in Reports Builder (Edit > Preferences > General tab). For inches, the maximum width and height is 512 inches. For centimeters, it is 1312 centimeters. For picas, it is 36,864 picas.
Default
For bitmap, 8.5 x 11 inches. For character mode, 80 x 66 characters. If the report was designed for character mode and is being run or converted on bitmap, then the following formula is used to determine page size if none is specified: (default page size * character page size)/default character page size. For example, if the character page size is 80 x 20, then the bit-mapped page size would be:
( (8.5 * 80)/80) x ((11 * 20)/66) = (680/80) x (220/66) = 8.5 x 3.33.
Usage Notes
A.4.76 PAGESTREAM
Table A-86 indicates which commands can use the PAGESTREAM keyword.
Table A-86 Commands that can use PAGESTREAM
yes
yes
no
no
yes
yes
no
Description
PAGESTREAM enables or disables page streaming (pagination) for the report when formatted as HTML or HTMLCSS output, using the navigation controls set by either of the following:
Syntax
PAGESTREAM={YES|NO}
Values
Default
NO
A.4.77 PARAMFORM
Table A-87 indicates which commands can use the PARAMFORM keyword.
Table A-87 Commands that can use PARAMFORM
no
no
no
no
yes
yes
no
Description
Use PARAMFORM to specify whether to display the Runtime Parameter Form when you execute a report via CGI or a servlet. PARAMFORM is used only to supply parameters to paper layout reports, not Web source reports.
Syntax
PARAMFORM=YES|NO|HTML
Values
Default
NO
Usage Notes
A.4.78 PARSEQUERY
Table A-88 indicates which commands can use the PARSEQUERY keyword.
Table A-88 Commands that can use PARSEQUERY
no
no
no
no
yes
yes
no
Description
Use PARSEQUERY to parse an rwservlet query and display the constructed Reports Server command line.
Syntax
http://yourwebserver/reports/rwservlet/parsequery[?][server=servername][&authid=
username/password]
Values
See Syntax.
Default
None
Usage Notes
A.4.79 PDFCOMP
Table A-89 indicates which commands can use the PDFCOMP keyword.
Table A-89 Commands that can use PDFCOMP
yes
yes
no
no
yes
yes
no
Description
Use PDFCOMP to specify whether PDF output should be compressed.
Syntax
PDFCOMP=value|{YES|NO}
Values
Default
6
A.4.80 PDFEMBED
Table A-90 indicates which commands can use the PDFEMBED keyword.
Table A-90 Commands that can use PDFEMBED
yes
yes
no
no
yes
yes
no
Description
Use PDFEMBED to specify whether Oracle Reports will embed the Type1 PostScript font file(s) specified in the uifont.ali file into PDF output.
Syntax
PDFEMBED={YES|NO}
Values
Default
YES
A.4.81 PRINTJOB
Table A-91 indicates which commands can use the PRINTJOB keyword.
Table A-91 Commands that can use PRINTJOB
no
no
yes
no
no
no
no
Description
Use PRINTJOB to specify whether the Print Job dialog box should be displayed before running a report.
Syntax
PRINTJOB={YES|NO}
Values
Default
NO
Usage Notes
A.4.82 READONLY
Table A-92 indicates which commands can use the READONLY keyword.
Table A-92 Commands that can use READONLY
yes
yes
yes
no
yes
yes
no
Description
Use READONLY to request read consistency across multiple queries in a report. When accessing data from Oracle 9i, read consistency is accomplished by a SET TRANSACTION READ ONLY statement.
Refer to Oracle9i SQL documentation (available on the Oracle Technology Network, (http://otn.oracle.com) for more information on SET TRANSACTION READ ONLY.
Syntax
READONLY={YES|NO}
Values
YES Requests read consistency.
NO Do not provide read consistency.
Default
NO
Usage Notes
A.4.83 RECURSIVE_LOAD
Table A-93 indicates which commands can use the RECURSIVE_LOAD keyword.
Table A-93 Commands that can use RECURSIVE_LOAD
yes
yes
no
yes
yes
yes
no
Description
Use RECURSIVE_LOAD to specify whether to validate external references in program units when running a report. If any of the references become invalid, the program unit is automatically recompiled. Setting RECURSIVE_LOAD to NO is useful when running your report against a different database than the one against which its PL/SQL was originally compiled.
Syntax
RECURSIVE_LOAD={YES|NO}
Values
Default
YES
A.4.84 REPLACEITEM
Table A-94 indicates which commands can use the REPLACEITEM keyword.
Table A-94 Commands that can use REPLACEITEM
yes
yes
no
no
yes
yes
no
Description
Use REPLACEITEM to specify that the current report output being pushed to Oracle9iAS Portal Release 1 should replace an earlier version of the same item stored in the same output target.
Syntax
REPLACEITEM={YES|NO}
Values
Default
None
Usage Notes
A.4.85 REPLYTO
Table A-95 indicates which commands can use the REPLYTO keyword.
Table A-95 Commands that can use REPLYTO
yes
yes
no
no
yes
yes
no
Description
Use REPLYTO to specify the e-mail address to which replies should be sent when the sender wants replies to go to someone other than the sender (specified by the FROM keyword).
Syntax
REPLYTO=emailid
Values
emailid A valid e-mail address in the form of someone@foo.com.
Default
None
Usage Notes
Related keywords include BCC,CC,FROM,REPLYTO, and SUBJECT. Note that DESNAME is used to specify the main recipient(s) of the e-mail.
A.4.86 REPORT|MODULE
See MODULE|REPORT.
A.4.87 ROLE
Table A-96 indicates which commands can use the ROLE keyword.
Table A-96 Commands that can use ROLE
yes
yes
no
no
yes
yes
no
Description
Use ROLE to specify the database role to be checked for the report at runtime. This keyword is useful for giving you the ability to run reports that query database tables to which you would not normally have access privileges.
Syntax
ROLE={rolename[/rolepassword]}
Values
Default
None
Usage Notes
ROLE can be used when running JSP-based Web reports from the command line.
A.4.88 RUNDEBUG
Table A-97 indicates which commands can use the RUNDEBUG keyword.
Table A-97 Commands that can use RUNDEBUG
yes
yes
yes
no
yes
yes
no
Description
Use RUNDEBUG to specify that you want extra runtime checking for logical errors in the report. RUNDEBUG checks for things that are not errors but might result in undesirable output, and displays these as warnings at runtime, before displaying the report output. Using RUNDEBUG to run a report in debug mode is not the same as debugging a report using the PL/SQL Interpreter.
RUNDEBUG checks for the following:
Syntax
RUNDEBUG={YES|NO}
Values
Default
YES
Usage Notes
RUNDEBUG can be used when running JSP-based Web reports from the command line.
A.4.89 SAVE_RDF
Table A-98 indicates which commands can use the SAVE_RDF keyword.
Table A-98 Commands that can use SAVE_RDF
no
yes
yes
no
no
no
no
Description
Use SAVE_RDF to specify a filename for a combined RDF file and XML customization file. This keyword is useful when you combine an existing RDF file with a Oracle Reports XML customization file using the CUSTOMIZE keyword, and you wish to save the combination to a new RDF file.
Syntax
SAVE_RDF=filename.rdf
Values
filename.rdf Any valid file name.
Default
None
Usage Notes
You can use SAVE_RDF with a JSP file, but only the paper layout part, not the Web source.
A.4.90 SCHEDULE
Table A-99 indicates which commands can use the SCHEDULE keyword.
Table A-99 Commands that can use SCHEDULE
yes
no
no
no
yes
yes
no
Description
Use SCHEDULE to set the day, time, and frequency a report should be run. The default is to run the report once, now. Time values are expressed according to a 24-hour day (i.e., one o'clock is expressed 13:00). To eliminate the need for quoting the scheduling command, use underscores (_) instead of spaces. You can also specify an expiration for a report job after a number of runs or on a particular date/time. For example, use:
SCHEDULE=every_first_fri_of_month_from_15:53_Oct_23,_1999_retry_3_after_1_hour_
expires_on_15:53_Oct_23,_2003
SCHEDULE=last_weekday_before_15_from_15:53_Oct_23,_1999_retry_after_1_hour_
expires_after_100
Or:
SCHEDULE="every first fri of month from 15:53 Oct 23, 1999 retry 3 after 1 hour
expires on 15:53 Oct 23, 2003"
SCHEDULE="last weekday before 15 from 15:53 Oct 23, 1999 retry after 1 hour
expires after 100"
Syntax
SCHEDULE=string
where the string is:
[FREQ from] TIME [retry {n} after LEN expires {on|after} time|n]
Table A-100 lists and explains the values used in this string.
Table A-100 Values for string used with the SCHEDULE keyword
FREQ
hourly | daily | weekly | monthly | {every {LEN | DAYREPEAT}} | {last {WEEKDAYS | weekday | weekend} before {n}+}
LEN
{n}+ {minute[s] | hour[s] | day[s] | week[s] | month[s]}
DAYREPEAT
{first | second | third | fourth | fifth} WEEKDAYS of month
WEEKDAYS
mon | tue | wed | thu | fri | sat | sun
TIME
now | CLOCK [DATE]
CLOCK
h:m | h:mm | hh:m | hh:mm
DATE
today | tomorrow | {MONTHS {d | dd} [,year]}
MONTHS
jan | feb | mar | apr | may | jun | jul | aug | sep | oct | nov | dec
EXPIRES
on {today | tomorrow | {MONTHS {d | dd} [,year]}}|after n
Default
None
A.4.91 SERVER
Table A-101 indicates which commands can use the SERVER keyword.
Table A-101 Commands that can use SERVER
yes
no
no
no
yes
yes
yes
Description
Use SERVER to specify the name of the Reports Server you want to use to run this report.
Syntax
SERVER=servername
Values
The server name or a TNS service entry name if you're using a 6i compatible server.
Default
The server name specified in the REPORTS_SERVER environment variable for rwcgi.
Usage Notes
A.4.92 SHOWAUTH
Table A-102 indicates which commands can use the SHOWAUTH keyword.
Table A-102 Commands that can use SHOWAUTH
no
no
no
no
yes
yes
no
Description
Use SHOWAUTH to display the Reports Server logon page and runs the report .
Syntax
http://yourwebserver/reports/rwservlet/showauth[?][server=servername][&authid=us
ername/password]][&nextpage=run report URL][&authtype={s|d}]
Values
See Syntax.
Default
None
Usage Notes
A.4.93 SHOWENV
Table A-103 indicates which commands can use the SHOWENV keyword.
Table A-103 Commands that can use SHOWENV
no
no
no
no
yes
yes
no
Description
Use SHOWENV to display the rwservlet configuration file (rwservlet.properties).
Syntax
http://yourwebserver/reports/rwservlet/showenv[?][server=servername][&authid=use
rname/password]
Values
See Syntax.
Default
None
Usage Notes
A.4.94 SHOWJOBID
Table A-104 indicates which commands can use the SHOWJOBID keyword.
Table A-104 Commands that can use SHOWJOBID
no
no
no
no
yes
no
no
Description
SHOWJOBID shows the status of the Reports Server job with job ID n.
Syntax
http://yourwebserver/reports/rwservlet/showjobidn[?][server=server_
Values
See Syntax.
Default
None
Usage Notes
A.4.95 SHOWJOBS
Table A-105 indicates which commands can use the SHOWJOBS keyword.
Table A-105 Commands that can use SHOWJOBS
no
no
no
no
yes
yes
no
Description
Use SHOWJOBS to display a Web view of Reports Server queue status.
Syntax
http://yourwebserver/reports/rwservlet/showjobs[n][?][server=server_
name][&authid=username/password][&queuetype=current | past |
future][&startrow=start_position_in_job_queue][&count=number_of_jobs_to_
display][&statusformat={html|xml|xmldtd}]
Values:
See Syntax
Default
None
Usage Notes
A.4.96 SHOWMAP
Table A-106 indicates which commands can use the SHOWMAP keyword.
Table A-106 Commands that can use SHOWMAP
no
no
no
no
yes
yes
no
Description
Use SHOWMAP to display rwservlet key mappings.
Syntax
http://yourwebserver/reports/rwservlet/showmap[?][server=servername][&authid=use
rname/password]
Values
See Syntax.
Default
None
Usage Notes:
A.4.97 SHOWMYJOBS
Table A-107 indicates which commands can use the SHOWMYJOBS keyword.
Table A-107 Commands that can use SHOWMYJOBS
rwclient rwrun rwbuilder rwconverter rwservlet rwcgi rwserver
no
no
no
no
yes
no
no
Description
Use SHOWMYJOBS to display the Reports Server queue status for a particular user.
Syntax
http://yourwebserver/reports/rwservlet/showmyjobs[?][server=server_
Values
See Syntax.
Default
None
Usage Notes
A.4.98 SHUTDOWN
Table A-108 indicates which commands can use the SHUTDOWN keyword.
Table A-108 Commands that can use SHUTDOWN
no
no
no
no
no
no
yes
Description
Use SHUTDOWN to shut down a previously running server. You must also use AUTHID to supply a user name and password.
Syntax
SHUTDOWN={NORMAL|IMMEDIATE}
Values
NORMAL or IMMEDIATE
Default
NORMAL
Usage Notes
The user of the SHUTDOWN keyword must be an Oracle Reports Administrative user. If the server has security enabled, it will query the security API to determine the user's role eligibility to execute the shutdown (in other words, the user must be an Oracle Reports Administrative user). If security is not enabled, then the user must nonetheless be an Oracle Reports Administrative user defined for that server.
A.4.99 SITENAME
Table A-109 indicates which commands can use the SITENAME keyword.
Table A-109 Commands that can use SITENAME
yes
yes
no
no
yes
yes
no
Description
Use SITENAME to specify the name of the WebDB site to push a report's output to. This keyword is maintained for backward compatibility with Oracle WebDB Release 2.2; for backward compatibility with Oracle9iAS Portal Release 1, see CONTENTAREA. Beginning with OracleAS Portal Release 2, use PAGEGROUP.
Syntax
SITENAME=name
Values
name Any valid site name used in Oracle WebDB Release 2.2.
Default
Usage Notes
A.4.100 SOURCE
Table A-110 indicates which commands can use the SOURCE keyword.
Table A-110 Commands that can use SOURCE
no
no
no
yes
no
no
no
Description
Use SOURCE to specify the report/library or list of reports/libraries to be converted. The rwconverter command requires that you specify a source report or library.
Syntax
SOURCE={source_name|(source_name1, source_name2, ...)}
Values
Any valid report/library name or filename, or a list of valid report/library names or filenames enclosed in parentheses and separated by commas (e.g., (qanda, test, dmast)).
Default
None
Usage Notes
A.4.101 SQLTRACE
Table A-111 indicates which commands can use the SQLTRACE keyword.
Table A-111 Commands that can use SQL_TRACE
yes
yes
yes
no
yes
yes
no
Description
Use SQLTRACE to specify whether to perform SQL tracing on your report without modifying the report definition.
Syntax
SQLTRACE=[YES|NO]
Values
Default
NO
A.4.102 SSOCONN
Table A-112 indicates which commands can use the SSOCONN keyword.
Table A-112 Commands that can use SSOCONN
no
no
no
no
yes
no
no
Description
Use SSOCONN to specify one or more connect strings to use to connect to one or more data sources in a Single Sign-On environment.
Syntax
SSOCONN=key[/type[/conn_str]][,key[/type[/conn_str]]]
For example:
ssoconn=mykey/OracleDB/userid
Values
The following information describes the variable values expressed in the SSOCONN syntax:
Default
None
Usage Notes
A.4.103 STATUSFOLDER
Table A-114 indicates which commands can use the STATUSFOLDER keyword.
Table A-114 Commands that can use STATUSFOLDER
yes
yes
no
no
yes
yes
no
Description
Use STATUSFOLDER to specify the name of the Oracle WebDB Release 2.2 or Oracle9iAS Portal Release 1 folder to push status information into. If this is omitted, a new folder is created called Oracle_Reports_Status. This keyword is maintained for backward compatibility with Oracle WebDB Release 2.2 and Oracle9iAS Portal Release 1. Beginning with OracleAS Portal Release 2, use STATUSPAGE.
Syntax
STATUSFOLDER=folder
Values
Default
Usage Notes
A.4.104 STATUSFORMAT
Table A-115 indicates which commands can use the STATUSFORMAT keyword.
Table A-115 Commands that can use STATUSFORMAT
no
no
no
no
yes
no
no
Description
Use STATUSFORMAT to specify the format for the Web view of Reports Server queue status.
Syntax
http://yourwebserver/rwservlet/showjobs?server=server_name&statusformat={html|xml|xmldtd}
Values
Default
Usage Notes
Use STATUSFORMAT in conjunction with the SHOWJOBS and SHOWMYJOBS keywords.
A.4.105 STATUSPAGE
Table A-116 indicates which commands can use the STATUSPAGE keyword.
Table A-116 Commands that can use STATUSPAGE
yes
yes
no
no
yes
yes
no
Description
Use STATUSPAGE to specify the name of the Oracle9iAS Portal Release 1 page to push job status information into. If this is omitted, a new page is created called Oracle_Reports_Status. For backward compatibility with earlier versions (Oracle WebDB Release 2.2 and Oracle9iAS Portal Release 1), see STATUSFOLDER.
Syntax
STATUSPAGE=page
Values
Default
Usage Notes
A.4.106 STYPE
Table A-117 indicates which commands can use the STYPE keyword.
Table A-117 Commands that can use STYPE
no
no
no
yes
no
no
no
Description
Use STYPE to specify the format of the report(s) or libraries to be converted.
Syntax
STYPE={PLDFILE|PLLFILE|RDFFILE|REXFILE|XMLFILE|JSPFILE}
Values
Use any one of the following values:
Default
RDFFILE
Usage Notes
When DTYPE=REGISTER, choose RDDFILE,REXFILE,XML, or JSPFILE for STYPE.
A.4.107 SUBJECT
Table A-118 indicates which commands can use the SUBJECT keyword.
Table A-118 Commands that can use SUBJECT
yes
yes
no
no
yes
yes
no
Description
Use SUBJECT to specify the subject line of an e-mail.
Syntax
SUBJECT=any text
Values
Any text.
Default
None
Usage Notes
A.4.108 SUPPRESSLAYOUT
Table A-119 indicates which commands can use the SUPPRESSLAYOUT keyword.
Table A-119 Commands that can use SUPPRESSLAYOUT
yes
yes
yes
no
yes
yes
no
Description
Use SUPPRESSLAYOUT to specify whether to suppress the formatting of the paper layout at runtime. The keyword allows users to control whether the paper layout in a report is executed at runtime. The most common use of this keyword is to increase the performance of JSP reports. Since a JSP report may have a paper layout and reference objects in it via an <rw:include> tag, Oracle Reports formats the paper layout before running the JSP section of the report. To improve the performance of single source JSP reports that store both paper and Web layouts but do not reference paper layout objects, set SUPPRESSLAYOUT=YES on the command line.
If there is an <rw:include> tag, then no output will be created for the tag.
Syntax
SUPPRESSLAYOUT=[YES|NO]
Values
Default
NO
A.4.109 TOLERANCE
Table A-120 indicates which commands can be used with the TOLERANCE keyword.
Table A-120 Commands that can use TOLERANCE
yes
no
no
no
yes
yes
no
Description
Use TOLERANCE to set the maximum acceptable time (in minutes) for reusing a report's cached output when a duplicate job is detected. Setting the time tolerance on a report reduces the processing time when duplicate jobs are found.
Syntax
TOLERANCE=time_string
Values
time_string Can be in one of two formats:
Default
None
Usage Notes
A.4.110 TRACEFILE
Table A-121 indicates which commands can use the TRACEFILE keyword.
Table A-121 Commands that can use TRACEFILE
yes
yes
yes
no
no
no
no
Description
TRACEFILE is the name of the file in which trace information is logged.
See Report Trace for additional information about how tracing works with Oracle Reports.
Syntax
TRACEFILE=tracefile
Values
Default
None
Usage Notes
A.4.111 TRACEMODE
Table A-122 indicates which commands can use the TRACEMODE keyword.
Table A-122 Commands that can use TRACEMODE
yes
yes
yes
no
yes
yes
no
Description
TRACEMODE specifies whether to append new trace information to existing information in the file specified by TRACEFILE, or overwrite the entire file.
Syntax
TRACEMODE={TRACE_APPEND|TRACE_REPLACE}
Values
Default
TRACE_APPEND
Usage Notes
A.4.112 TRACEOPTS
Table A-123 indicates which commands can use the TRACEOPTS keyword.
Table A-123 Commands that can use TRACEOPTS
yes
yes
yes
no
yes
yes
yes
Description
TRACEOPTS indicates the tracing information that you want to be logged in the trace file when you run the report.
Syntax
TRACEOPTS={TRACE_ALL|TRACE_APP|TRACE_BRK|TRACE_DBG|TRACE_DST|TRACE_ERR|TRACE_EXC|TRACE_INF|TRACE_LOG|TRACE_PLS|TRACE_PRF|TRACE_SQL|TRACE_STA|TRACE_TMS|TRACE_WRN}
Values
Default
TRACE_ALL
Usage Notes
A.4.113 UNINSTALL
Table A-124 indicates which commands can use the UNINSTALL keyword.
Table A-124 Commands that can use UNINSTALL
no
no
no
no
no
no
yes
Description
Use UNINSTALL to remove an instance of the Reports Server from Microsoft Windows. This process removes the Reports Server service from the system. This keyword is ignored on UNIX.
Syntax
UNINSTALL reports_server_name
Values
reports_server_name The name of an existing Reports Server instance
Default
None
Usage Notes
If you use BATCH=YES with INSTALL, then none of the prompts and dialogs that normally display during the removal process will appear.
A.4.114 UPGRADE_PLSQL
Table A-121 indicates which commands can use the UPGRADE_PLSQL keyword.
Table A-125 Commands that can use UPGRADE_PLSQL
no
no
no
yes
no
no
no
Description
Use UPGRADE_PLSQL to specify whether to upgrade any PL/SQL code in the report to the latest version required by Oracle Reports Developer.
Syntax
UPGRADE_PLSQL=[YES|NO]
Values
Default
YES
A.4.115 URLPARAMETER
Table A-126 indicates which commands can use the URLPARAMETER keyword.
Table A-126 Commands that can use URLPARAMETER
yes
no
no
no
yes
yes
no
Description
Use URLPARAMETER to specify the URL that is to be fetched with the URL engine.
Syntax
URLPARAMETER=http://webserver_name/pagename.html
Values
Any valid URL.
Default
None
Usage Notes
This keyword is relevant when the jobType parameter of the job element in the Reports Server configuration file is rwurl, and a URL engine is in place.
A.4.116 USERID
Table A-127 indicates which commands can use the USERID keyword.
Table A-127 Commands that can use USERID
yes
yes
yes
yes
yes
yes
no
Description
Use USERID only if you're not using Single Sign-On. Use USERID to specify your Oracle user name and password, with an optional database name for accessing a remote database. If the password is omitted, then a database logon form opens automatically before the user is allowed to run the report.
If you want users to log on to the database, then omit the password portion of the USERID keyword from the report request. If you want users to log on every time they run report requests, then use the Oracle Reports key mapping file, cgicmd.dat, to specify the runtime command, and include the %D option in the relevant key mapping entry.
For information on using the cgicmd.dat file, see Running Report Requests.
Syntax
userid=username[/password][@database]
Values
username Username assigned by the database administrator.
password Password for the username.
database The name of the database you are accessing.
Default
None
Usage Notes
A.4.117 WEBSERVER_DEBUG
Table A-128 indicates which commands can use the WEBSERVER_DEBUG keyword.
Table A-128 Commands that can use WEBSERVER_DEBUG
no
no
yes
no
no
no
no
Description
Use WEBSERVER_DEBUG for JSP debugging. It creates the stderr.log and stdout.log files under the docroot/port# directory, and leaves temporary JSP files under docroot/port#/default and log files under docroot/port#/log for your inspection.
Syntax
WEBSERVER_DEBUG={YES|NO}
Values
YES Create debugging files.
NO Do not create debugging files.
Default
NO
Usage Notes
A.4.118 WEBSERVER_DOCROOT
Table A-129 indicates which commands can use the WEBSERVER_DOCROOT keyword.
Table A-129 Commands that can use WEBSERVER_DOCROOT
no
no
yes
no
no
no
no
Description
Use WEBSERVER_DOCROOT to set the Reports Builder document root directory. All files you reference in your JSP, such as images, HTML, and the like, should be relative to this directory. By setting the document root to your working directory, you avoid having to copy these files around.
Syntax
WEBSERVER_DOCROOT=REPORTS_TMP/docroot
For example:
WEBSERVER_DOCROOT=c:/temp/docroot
Values
The directory to the document root folder in your Oracle Reports temporary folder.
Default
None
Usage Notes
A.4.119 WEBSERVER_PORT
Table A-130 indicates which commands can use the WEBSERVER_PORT keyword.
Table A-130 Commands that can use WEBSERVER_PORT
no
no
yes
no
no
no
no
Description
Use WEBSERVER_PORT to specify the port number an internal Web server listens to. You can specify a port number (e.g., 3002) or a range of port numbers (e.g., 3100-3200). If a single port number is specified, Oracle Reports tries to start the internal Web server listening on that port. If that port is in use, it tries to get the next available port. If a range of port numbers is specified, Oracle Reports tries to look for a free port in that range.
Syntax
WEBSERVER_PORT=port num
Values
port num Any valid port number or range of port numbers.
Default
Port = 3000
Range of ports = 3000-3010.
Usage Notes
1 Oracle Application Server instance
2 Port where the Reports servlet is running
3 Secured server only
4 Web server running the CGI scripts
5 Web server listener port
6 Web server installed on the Windows operating system
7 Web server installed on any UNIX operating system
8 Secured server only
Go to previous page Go to next page
Oracle
Copyright © 2003 Oracle Corporation.
All Rights Reserved.
Go To Table Of Contents
Contents
Go To Index
Index
