Skip Headers
Oracle Application Server Reports Services Publishing Reports to the Web
10g (9.0.4)
Part Number B10314-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
3
Configuring OracleAS Reports Services
When you install Oracle Application Server, OracleAS Reports Services is configured automatically for you. There will likely be adjustments you wish to make to customize your environment, but you will not be required to set up the entire environment, or even most of it.
This chapter is included largely for reference, should you wish to introduce customizations or have a better understanding of the default configuration. It lists services-related configuration files and describes in detail the content of most of them. It includes the following main sections:
Another aspect of configuration is the setting of environment variables. These are set for you automatically during installation. For reference, environment variables are discussed in Appendix B, "Reports-Related Environment Variables".
3.1 OracleAS Reports Services Configuration Files
This section identifies the various configuration files associated with OracleAS Reports Services. In most cases, you can leave these files untouched. Because they control many aspects of your server environment, you could put that environment at risk if you change a file in some unsupported way. Always keep a back-up of the current version of any configuration file you plan to change.
The configuration files associated with OracleAS Reports Services relate to the Reports Server and the Reports Servlet. They are listed and described in Table 3-1:
The paths specified in Table 3-1 are the same for both Windows and UNIX environments, though they are expressed here using the Windows backslash convention (\).
Table 3-1 OracleAS Reports Services Configuration Files
Component Configuration File
Reports Server
ORACLE_HOME\reports\conf\server_name.conf
Use this XML file to define initial values for the Reports Server Cache, the Reports Engine, and security; to register valid destination types; to specify the information to be logged; and to set other server-related values.
This file is automatically created when you start up the server. If you want to rename your server and wish to keep custom configuration settings you've entered into this file, you must first rename this file to the new server name, then rename the server. Otherwise, the server will create its own new default configuration file.
You'll find more information about this file in the section Configuring Reports Server.
Reports Server
ORACLE_HOME\reports\dtd\rwserverconf.dtd
This file contains data type definitions for server_name.conf and rwbuilder.conf elements and attributes. Data type definitions lists all elements allowed in an associated XML file, the attributes associated with those elements, and default values for those attributes.
You'll find more information about this file in Reports Server Configuration Elements (rwserverconf.dtd).
Reports Server Reports Builder
ORACLE_HOME\reports\conf\rwbuilder.conf
Use this XML file to configure the Reports Server that is embedded in Reports Builder and Reports Runtime. All run requests must go through Reports Server, meaning that Reports Builder requires a server to run reports. Reports Builder automatically starts a Reports Server to handle its requests. When you run a report from the Builder, this file provides the configuration for the in-process server instance that is invoked. Like the server_name.conf file, this file relies on the rwserverconf.dtd file for its data type definitions, though several elements do not apply, including the compatible, persistFile, and security elements.
Because this file shares most configuration elements found in server_name.conf, you'll find the information you need for configuring this file in Configuring Reports Server.
Reports Servlet
ORACLE_HOME\reports\conf\rwservlet.properties
Among other things, this file is where you specify the location and filename of the Reports Servlet key map file (cgicmd.dat) and specify whether you will use the Reports Servlet's in-process server.
You'll find more information about this file in Configuring the Reports Servlet.
3.2 Configuring Reports Server
The Reports Server component of OracleAS Reports Services is configurable via the XML files server_name.conf and rwbuilder.conf, located in the following directory (on both Windows and UNIX):
ORACLE_HOME\reports\conf\server_name or rwbuilder.conf
Both files are supported by the rwserver.template file, which contains default server configuration values on both Windows and UNIX.
The rwserver.template file is located in the following directory, ORACLE_HOME\reports\conf\.
The server_name.conf file is the default server configuration file. The rwbuilder.conf file configures the server instance used in-process by Reports Builder.
The server_name.conf and rwbuilder.conf files are nearly identical. The only difference between them is that rwbuilder.conf does not use the compatible, persistFile, or security configuration elements, described later in this section, and server_name.conf does.
Both of these files are created automatically, under the following circumstances:
To explain the syntax and values allowed in these files we'll look at the rwserverconf.dtd file, located in the following directory (on both Windows and UNIX):
3.2.1 Reports Server Configuration Elements (rwserverconf.dtd)
The following example of rwserverconf.dtd illustrates how it is used to configure various aspects of the Reports Server.
Copyright 2003 Oracle Corp.
500 Oracle Parkway, Redwood Shores, CA 94065, U.S.A.  All rights reserved.
This is the DTD defining the Reports Server Version 9i Configuration file
(XML) format/syntax.
<!ELEMENT server (compatible?,
                  cache?,
                  engine+,
                  security*,
                  destination*,
                  job+,
                  notification*,
                  log?,
                  jobStatusRepository?,
                  trace?,
                  connection?,
                  queue?,
                  persistFile?,
                  identifier?,
                  environment*,
                  pluginParam*)>
<!ATTLIST server
  version         CDATA         #IMPLIED>
<!ELEMENT cache (property*)>
<!-- class specifies fully qualified java class name which implements
     oracle.reports.cache.Cache interface -->
<!ATTLIST cache
  class           CDATA         "oracle.reports.cache.RWCache">
<!ELEMENT engine (property*)>
<!-- class specifies full qualified java class name which starts engine -->
<!ATTLIST engine
  id              ID            #REQUIRED
  class           CDATA         #REQUIRED
  classPath       CDATA         #IMPLIED
  initEngine      CDATA         "1"
  maxEngine       CDATA         "1"
  minEngine       CDATA         "0"
  engLife         CDATA         "50"
  maxIdle         CDATA         "30"
  callbackTimeOut CDATA         "60000"
  jvmOptions      CDATA         #IMPLIED
  engineResponseTimeOut CDATA   "0"
  defaultEnvId    CDATA         #IMPLIED>
<!ELEMENT security (property*)>
<!-- class specifies full qualified java class name which implements
     oracle.reports.server.Security interface -->
<!ATTLIST security
  id             ID             #REQUIRED
  class          CDATA          #REQUIRED>
<!ELEMENT destination (property*)>
<!-- class specifies full qualified java class name which subclass
     oracle.reports.server.Destination abstract class -->
<!ATTLIST destination
  destype        ID             #REQUIRED
<!ELEMENT job EMPTY>
<!ATTLIST job
  jobType         CDATA         "report"
  engineId        IDREF         #REQUIRED
  securityId      IDREF         #IMPLIED>
<!ELEMENT notification (property*)>
<!ATTLIST notification
  id              CDATA         "mailNotify"
<!ELEMENT log EMPTY>
<!ATTLIST log
  option          (allJobs|succeededJobs|failedJobs|noJob) "noJob">
<!ELEMENT jobStatusRepository (property*)>
     oracle.reports.server.JobRepository interface -->
<!ATTLIST jobStatusRepository
  class           CDATA         "oracle.reports.server.JobRepositoryDB">
<!ELEMENT queue EMPTY>
<!ATTLIST queue
  maxQueueSize         CDATA        "10000">
<!ELEMENT connection (orbClient*, cluster?)>
<!ATTLIST connection
  maxConnect      CDATA        "20"
  idleTimeOut     CDATA        "10">
<!ELEMENT orbClient EMPTY>
<!ATTLIST orbClient
  id              ID           #REQUIRED
  publicKeyFile   CDATA        #REQUIRED>
<!ELEMENT cluster EMPTY>
<!ATTLIST cluster
  privateKeyFile  CDATA        #REQUIRED>
<!ELEMENT persistFile EMPTY>
<!ATTLIST persistFile
  fileName        CDATA        #IMPLIED>
<!ELEMENT trace EMPTY>
<!ATTLIST trace
  traceFile       CDATA        #IMPLIED
  traceOpts       (trace_prf|trace_brk|trace_app|trace_pls|trace_sql|
                   trace_tms|trace_dst|trace_log|trace_err|trace_inf|
                   trace_dbg|trace_wrn|trace_sta|trace_exc|trace_all) "trace_
all"
  traceMode       (trace_replace|trace_append) "trace_replace"
  traceModule     (all|server|engine) "all">
<!ELEMENT compatible EMPTY>
<!ATTLIST compatible
  version         (6i)        "6i">
<!ELEMENT identifier (#PCDATA)>
<!ATTLIST identifier
  confidential     (yes|no)    "yes"
  encrypted        (yes|no)    "no">
<!ELEMENT environment (envVariable*)>
<!ATTLIST environment
  id              ID          #REQUIRED>
<!ELEMENT envVariable EMPTY>
<!ATTLIST envVariable
  name            CDATA       #REQUIRED
  value           CDATA       #IMPLIED>
<!ELEMENT pluginParam (#PCDATA)>
<!ATTLIST pluginParam
  name            ID               #REQUIRED
  type            (text|file|url)  "text">
<!ELEMENT property EMPTY>
<!ATTLIST property
  value            CDATA       #REQUIRED
  confidential     (yes|no)    "no"
The rwserverconf.dtd file provides the following elements for configuring the Reports Server:
Note that these are XML elements, and XML is case sensitive.
Additionally, when you add any of these elements to the server configuration file (server_name.conf), you will save yourself potential error messages from any XML editor if you use the order of the elements shown in the rwserverconf.dtd (ORACLE_HOME\reports\dtd\). The configuration file will work regardless of the order, but it will not work if you fail to follow the case specified in rwserverconf.dtd.
These elements along with their related attributes and sub-elements are discussed in the following subsections.
3.2.1.1 server
Example
<server>
[One or more configuration specifications]
</server>
Required/Optional
Required. You can have a maximum of one open and close server element in a given configuration file.
Description
The server element opens and closes the content area of the server configuration file. In terms of the file's hierarchy, all the other elements are subordinate to the server element.
3.2.1.2 compatible
Example
<compatible version="6i"/>
Required/Optional
Optional. You can have a maximum of one compatible element in your server configuration file.
Description
The compatible element is available for backward compatibility with Reports 6i clients (RWCLI60, RWCGI60, RWQMU60.EXE, RWRQM60.EXE, RWRQV60.EXE, 6i Forms ). When compatible is set to 6i, Reports Server will make use of an executable file, named rwproxy, that listens for requests from a 6i client and forwards them to a 9i server.
Compatible has one attribute: version, described in Table 3-2.
Table 3-2 Attributes of the compatible element
Attribute Valid values Description
version
6i
Setting version to 6i enables Reports 6i clients to run under Oracle Reports. When version is set to 6i, versions earlier than 6i may also run under Oracle Reports, but they are not certified to do so and are not supported by Oracle.
If you use the compatible element, you must also have an entry for Reports Server in the tnsnames.ora file as you would have had for the 6i version of Reports Server. The installer configures the tnsnames.ora file for the default Reports Server, i.e., rep_machine_name.
The tnsnames.ora file is located in the following directory on your Oracle Application Server:
ORACLE_HOME/network/admin
For example:
testsvr.world = (ADDRESS=
(PROTOCOL=tcp)
(HOST=testhost.mydomain.com)
(PORT=1950)
You can bypass this requirement by turning compatibility off. To turn compatibility off, remove the compatible element from the Reports Server configuration file.
If compatible is set to 6i, and you have a TNS entry for Reports Server in your tnsnames.ora file, you should include the cluster name if the server is a member of a cluster. If you use a cluster name, you should exclude the default domain that was specified in the sqlnet.ora file. For example:
myserver.world (standalone server with default domain world)
myserver.cluster1 (server part of cluster1)
myserver.cluster1.world (invalid entry)
3.2.1.3 cache
Example
<cache class="oracle.reports.cache.RWCache">
<property name="cacheSize" value="50"/>
<property name="cacheDir" value="D:\orawin\reports\server\cache"/>
</cache>
Required/Optional
Optional. You can have a maximum of one cache element in your server configuration file. If no cache element is specified, the default is used (oracle.reports.cache.RWCache).
Description
The cache element is available for specifying the Java class that defines the server's cache implementation. You can use the default cache Java class or develop your own implementation through the OracleAS Reports Services Cache API.
Look for information about the OracleAS Reports Services APIs on the Oracle Technology Network, (http://otn.oracle.com).
The cache element has one attribute: class, described in Table 3-3.
Table 3-3 Attributes of the cache element
class
see the Description column
Default: oracle.reports.cache.RWCache
A fully qualified Java class that implements the oracle.reports.cache.Cache interface.
You can also enter from zero to multiple properties under the cache element. Properties are name/value pairs recognized and understood by the implementation class you register under cache. For example, if you use the default cache Java class that is provided with OracleAS Reports Services, your configuration entry might look like this:
</cache>
In the preceding example, cacheSize is measured in megabytes, and cacheDir, which points to the location of the cache, is specified for a Windows platform. On UNIX, use UNIX standards, for example:
<property name="cacheDir" value="$ORACLE_HOME/reports/server/cache"/>
The default cache Java class also provides the following properties:
3.2.1.4 engine
Example
<engine id="rwEng" class="oracle.reports.engine.EngineImpl" initEngine="1"
maxEngine="5" minEngine="1" engLife="50" maxIdle="15" callbackTimeOut="60000">
<property name="sourceDir" value="D:\orawin\reports\myReport"/>
<property name="tempDir" value="D:\orawin\reports\myTemp"/>
</engine>
Required/Optional
Required. You must have at least one engine element in your configuration file, and you can have more than one.
Description
The engine element identifies the fully qualified Java class that starts an engine and provides a number of attributes that set operational controls on the engine. You can use the default engine provided with OracleAS Reports Services (oracle.reports.engine.EngineImpl) or develop your own implementation through the OracleAS Reports Services Engine API. As an example of a custom engine, you may have developed an engine to execute an operating system command should an event occur in your database.
Look for upcoming information about Oracle Reports APIs on the Oracle Technology Network, (http://otn.oracle.com)
The engine element has several attributes, described in Table 3-4.
Table 3-4 Attributes of the engine element
id
string
A keyword, unique within a given configuration XML file, that identifies a particular engine element. This can be a text string or a number, for example:
id="rwEng"
class
Default: oracle.reports.engine.EngineImpl
A fully qualified Java class that implements two interfaces: oracle.reports.engine.Engine and oracle.reports.engine.EngineInterface.
classPath
string
The directory path to the Java class specified in the class attribute. To specify the directory, use the conventions required by the server platform, for example:
Windows:
classPath="%ORACLE_HOME%\myEngine.jar"
UNIX:
classPath="$ORACLE_HOME/myEngine.jar"
initEngine
number
Default: 1
The number of engines you want Reports Server to start at initialization.
maxEngine
number
Default: 1
The maximum number of this type of engine that can run on the server.
minEngine
number
Default: 0
The minimum number of this type of engine that is maintained by the server.
engLife
number
Default: 50
The number of jobs the engine can run before the engine is terminated, and, if necessary, a new engine is started. This feature is available to thwart memory leaks.
maxIdle
number
Default: 30
The number of minutes of allowable idle time before the engine is shut down, provided the current number of engines is higher than minEngine.
For example, if minEngine is 0, maxIdle is 30, and one engine has been running but unused for 30 minutes, that engine will shut down. If, under the same conditions, minEngine is 1, the active engine will not shut down, even if it has been idle for 30 minutes.
callbackTimeOut
number
Default: 60000
The number of milliseconds of allowable waiting time between when the server launches an engine and the engine calls the server back.
If the machine that hosts the server is very fast, you can reduce this number for faster performance.
defaultEnvId
string
Is an optional attribute. It specifies the default environment with which Reports Server starts an engine. The attribute takes an id that is associated with an environment element in the server configuration file.
If you specify defaultEnvId, Reports Server starts an engine with the environment variables specified in the referenced environment element plus whatever environment variables that Reports Server is running under.
If you do not specify defaultEnvId, Reports Server spawns engines with the environment settings in force at startup time.
For more information refer to Dynamic Environment Switching.
number
Default: null (no timeout)
The maximum amount of time (in minutes) for an engine to update the status of the job while running a report in your environment. If it takes longer than this amount of time to update the job status for some reason (e.g., due to the engine hanging or a long blocking SQL query), Reports Server terminates the job.
jvmOptions
string
The Java Virtual Machine (JVM) options to be used by Reports Server when it starts an engine in the JVM. For example, you can use this attribute to specify the starting heap size and maximum heap size for the JVM, additional classpath entries, and so on.
The Reports Engine running in the server environment ignores the value in the REPORTS_JVM_OPTIONS environment variable. You need to add the value of the environment variable to jvmoptions attribute in order to let the Reports Engine pick up the JVM options.
keepConnection
YES|NO
Default: YES
The keepConnection property is used by the default runtime engine implementation, i.e., oracle.reports.engine.EngineImpl
YES The default runtime engine retains the existing database connection information
NO The default runtime engine discards the existing database connection information and reconnects with the userid specified for the job
The keepConnection property does not affect reports deployed using either rwbuilder or rwrun.
This property will be migrated if a server_name.conf file used in previous versions (e.g., 9.0.2.x) runs in the current environment.
You can also enter from zero to multiple properties under the engine element. The only requirement is that they be name/value pairs recognized by the Java class that implements the Reports Engine. For example, if you use the default engine Java class that is provided with OracleAS Reports Services, your engine configuration entry might look like this:
</engine>
In this example, sourceDir and tempDir are set up for a Windows environment (UNIX would be sourceDir="ORACLE_HOME/reports/myReport" and tempDir="ORACLE_HOME/reports/myTemp"). The sourceDir property identifies the default directory you will use for report definition files. It overrides path information specified in the REPORTS_PATH environment variable.
The tempDir property identifies the name and location of the temporary directory OracleAS Reports Services will use for its temporary files. If this value is unspecified for a default engine, OracleAS Reports Services will use the temporary directory specified in the REPORTS_TMP environment variable. If REPORTS_TMP is also not specified, OracleAS Reports Services will use your operating system's default temporary directory.
The classPath attribute is not specified because this configuration uses the default engine class.
3.2.1.5 security
Example
<security id="rwSec" class="oracle.reports.server.RWSecurity">
<!--property name="securityUserid" value="portal_db_username/portal_
password@portal_db_connection" confidential="yes" encrypted="no"/-->
<property name="oidEntity" value="oidentity_name"/>
</security>
In releases prior to 10g (9.0.4), the security element was specified differently. In 10g (9.0.4) and later releases, the old property specification, securityUserid, is still provided but commented out. You only need to use securityUserid if you want to connect to an OracleAS Portal instance other than the default instance, which is installed with the Oracle Application Server infrastructure.
Required/Optional
Optional. If you do not enter a security element in the configuration file, Reports Server is not secure. You can have from zero to multiple security elements in your configuration file.
Description
The security element identifies the fully qualified Java class that controls server access. You can use the default security class provided with OracleAS Reports Services, which relies on security features available through OracleAS Portal (included with Oracle Application Server), or develop your own implementation through the Reports Server Security API.
Look for information about Oracle Reports APIs on the Oracle Technology Network, (http://otn.oracle.com).
Security attributes are described in Table 3-5.
Table 3-5 Attributes of the security element
id
string
A keyword, unique within a given configuration XML file, that identifies a particular security element. This can be a text string or a number, for example:
id="rwSec"
class
Default: oracle.reports.server.RWSecurity
A fully qualified Java class that implements Reports Server Security Java interface (oracle.reports.server.Security). The default relies on security features available through OracleAS Portal (included with Oracle Application Server).
You also have the option of entering multiple properties under the security element. The only requirement is that they be name/value pairs recognized by the Java class that implements Reports Server security. For example, if you use the default security Java class that is provided with OracleAS Reports Services, your security configuration entry might look like this:
</security>
In this example, the oidEntity property illustrates the configuration for 10g (9.0.4) and later. The value of oidEntity is set by the Installer upon installation. Reports Server uses this entity to connect to the Oracle Internet Directory. Components of the Oracle Application Server can all connect to the Oracle Internet Directory, but each component may have different privileges in the directory. Hence, each component needs to identify itself via its own entity name to the Oracle Internet Directory when it connects. The OracleAS Reports Services entity is of the following format:
reportsApp_hostname_GUID
For example:
reportsApp_testhost.mydomain.com_BBEFDCDAC2343600E0340800020C7BBCC
The commented out property, securityUserid, illustrates the old method of specifying security. securityUserid provides the connection information to enable the Reports Server access to OracleAS Portal security features. The property attributes confidential and encrypted are available for encrypting the information within the property. Once the confidential="yes" and encrypted="no" attributes are entered, the property value will be encrypted automatically by Reports Server after you restart the server. When you next open the configuration file, the password information will be scrambled, and encrypted will be set to yes. If you forget the password you entered in the configuration file, you can delete the property and reenter it with new values, making sure to set encrypted to no.
For securityUserid database connection strings, both the thin (testhost.mydomain.com:1521:iasdb) and Oracle Call Interface (scott/tiger@ordb) JDBC formats are supported.
When setting up security in a clustered environment, each cluster member should use the same security policy to prevent users from experiencing unexpected behavior.
3.2.1.6 destination
Example
<destination destype="oraclePortal"
class="oracle.reports.server.DesOraclePortal">
<property name="portalUserid" value="portal_db_username/portal_
password@portal_db_connection" confidential="yes" encrypted="no"/>
</destination>
Required/Optional
Optional. If you do not enter a destination element in the server configuration file, the provided destination classes will be used (printer, mail, file, cache, and OracleAS Portal--which is an exception in that it requires an entry in the server configuration file so that you may specify the userid and password the server will use to log in to the portal). You can have from zero to multiple destination elements in your server configuration file.
Description
Use the destination element to register destination types with the server. There is no need, with the exception of OracleAS Portal, to register provided (default) destinations, such as printers, e-mail, files, or cache. You must register the destination types you create through the OracleAS Reports Services Destinations API.
Configuring destinations is discussed in detail in Chapter 7, "Configuring Destinations for OracleAS Reports Services".
Destination attributes are listed and described in Table 3-6.
Table 3-6 Attributes of the destination element
destype
string
Identifies the destination type, for example:
destype="printer"
class
See the Description column
A fully qualified Java class that is a subclass of Reports Server Destination Java class (oracle.reports.server.Destination). Allowable values include:
oracle.reports.server.DesMail
oracle.reports.server.DesFile
oracle.reports.server.DesPrinter
You also have the option of entering multiple properties under the destination element. The only requirement is that they be name/value pairs recognized by the Java class that is a subclass of the Reports Server Destination Java class. For example:
</destination>
In this example, the property provides connect information to enable Reports Server to access OracleAS Portal. The confidential and encrypted attributes are included to automatically invoke encryption on the portalUserid value the next time Reports Server is started.
For portalUserid database connection strings, both the thin (testhost.mydomain.com:1521:iasdb) and Oracle Call Interface (scott/tiger@ordb) JDBC formats are supported.
Should your destination implementation require additional information, specify the information in the pluginParam element.
3.2.1.7 job
Example
<job jobType="report" engineId="rwEng" securityId="rwSec"/>
Required/Optional
Required. You must have at least one job element and can have more than one.
Description
The job element works in collaboration with the engine and security elements. Use job to identify a job type and specify which engine and which security implementation should be used with that type of job. For example, you may have developed an engine to execute an operating system command should an event occur in your database. Using OracleAS Reports Services's event-driven publishing API, you identify the event as a specific job type. When the event occurs, the job type information is sent to Reports Server, which looks up the job type under the job element in its configuration file, and follows the direction provided in the element's attributes to the engine (and, if applicable, security implementation) specified for that type of job.
Attributes of the job element are listed and described in Table 3-7.
Table 3-7 Attributes of the job element
jobType
string
Default: report
Describes the type of job to be processed by the server. You can enter any type of job, as long as Reports Server has an engine to process it.
engineId
ID reference
References the ID entered for the engine that will process this job type. Available IDs are specified under the engine element in the server configuration file using the id attribute. The id is a unique keyword (that you devise) within a given configuration XML file that identifies a particular engine.
securityId
ID reference
References the ID entered for the security mechanism that will be applied to this job type. Available IDs are specified under the security element in the server configuration file.
3.2.1.8 notification
Example
<notification id="tellMe02" class="oracle.reports.server.MailNotify"/>
Required/Optional
Optional. If you do not enter a notification element in the configuration file, the notification function is disabled. You can have from zero to multiple notification elements in your configuration file.
Description
Use the notification element to specify a Java class that defines the type of notification that should be sent when a job succeeds or fails. You can use the default notification class, which provides for notification via e-mail, or design your own with the Oracle Reports Notification API.
Look for upcoming information about Oracle Reports APIs on the Oracle Technology Network, (http://otn.oracle.com).
Attributes of the notification element are listed and described in Table 3-8.
Table 3-8 Attributes of the notification element
id
string
Default: mailNotify
A keyword, unique within a given configuration XML file, that identifies a particular notification element. This can be a text string or a number, for example:
id="tellMe01"
class
Default: oracle.reports.server.MailNotify
A fully qualified Java class that implements the Reports Server Notification Java class oracle.reports.server.Notification.
If you use the default email notification implementation, use the pluginParam element to specify the outgoing SMTP mail server to be used to send the mail. Use the runtime commands notifysuccess and notifyfailure to specify the email address where notification should be sent (for more information, see Appendix A, "Command Line Options"). For example, you can include these commands in your runtime URL:
notifysuccess=recipient's e-mail address&notifyfailure=recipient's e-mail
address
With the default e-mail implementation, you can specify only one address for each type of notification. You can specify one or both types of notification. You can send notification each to the same address or each to a different addresses.
A notification element in the server configuration file might look like this:
<notification id="mailNotify" class="oracle.reports.server.MailNotify>
<property name="succNoteFile" value="succnote.txt"/>
<property name=failNoteFile value="failnote.txt"/>
<notification/>
With the default notification implementation, it's not necessary to specify a path to the success or failure text files, provided they're in the default location: ORACLE_HOME\reports\templates. Otherwise, enter the directory path along with the filenames according to the requirements of the platform that hosts the server.
3.2.1.9 log
Example
<log option="allJobs"/>
Required/Optional
Optional. You can have a maximum of one log element in your server configuration file.
Description
The log element is available for backward compatibility. It invokes the generation and population of a reports log file. The log file is automatically generated and stored in the following path (the path is the same for Windows and UNIX):
ORACLE_HOME\reports\server_name\rwserver.log
The log element has one attribute: option, described in Table 3-9.
Table 3-9 Attributes of the log element
option
allJobs
succeededJobs
failedJobs
noJob
Default: noJob
Describes the type of jobs to be included in the log, in addition to default server activities that are logged. Choose from:
allJobs: all jobs will be logged
succeededJobs: only jobs that ran successfully will be logged
failedJobs: only jobs that failed will be logged
noJob: no jobs will be logged
3.2.1.10 jobStatusRepository
Example
<jobStatusRepository class="oracle.reports.server.JobRepositoryDB">
<property name="repositoryConn" value="scott/tiger@orcl" confidential="yes"
encrypted="no"/>
</jobStatusRepository>
Required/Optional
Optional. You can have a maximum of one jobStatusRepository element in your server configuration file.
Description
The jobStatusRepository element specifies the Java class that implements a job status repository. It provides an additional means (over the persistFile element) of storing job status information.
The persistFile is a binary file and, therefore, cannot be used to publish job status information within your application. The jobStatusRepository provides a means of including status information in your application by providing additional ways of storing it.
The default class, oracle.reports.server.JobRepositoryDB, stores information in a database. Use the Oracle Reports APIs to create your own implementation of the Reports Server Job Repository interface (oracle.reports.server.JobRepository) that stores information wherever you wish.
Look for information about OracleAS Reports Services APIs on the Oracle Technology Network, (http://otn.oracle.com).
The jobStatusRepository element has one attribute: class, described in Table 3-10.
Table 3-10 Attributes of the jobStatusRepository element
class
Default: oracle.reports.server.JobRepositoryDB
A fully qualified Java class that implements the Reports Server Job Repository Java class (oracle.reports.server.JobRepository).
The jobStatusRepository element allows for zero or multiple properties for passing options into the repository. The only requirement is that the class you specify in the server configuration file must recognize the name/value pairs you introduce.
The jobStatusRepository element might look like this in your server configuration file:
<property name="repositoryConn" value="scott/tiger@ORCL" confidential="yes"
encrypted="no"/>
In this example, the value for the repositoryConn property is the login for access to the database that stores the repository. The confidential and encrypted attributes are used to invoke encryption on the login information once Reports Server is restarted.
For repositoryConn database connection strings, both the thin (testhost.mydomain.com:1521:iasdb) and Oracle Call Interface (scott/tiger@ordb) JDBC formats are supported.
3.2.1.11 trace
Example
<trace traceFile="neptune.trc" traceOpts="trace_prf|trace_dbg|trace_wrn"
traceMode="trace_append" traceModule="server"/>
Required/Optional
Optional. You can have a maximum of one trace element in your server configuration file.
Description
Use the trace element to create a file for tracing your report's execution and to specify the objects and activities you want to trace. The trace element controls tracing only for the server and the engine.
Tracing for the servlet and JSP are configured in the servlet configuration file, rwservlet.properties, discussed in Configuring the Reports Servlet. Tracing for an individual report can be built into the Reports Runtime command line, discussed in Appendix A, "Command Line Options".
Trace attributes are listed and described in Table 3-11.
Table 3-11 Attributes of the trace element
traceFile
*.trc
Default: server_name.trc
The filename of the trace file. If no path is specified, the trace file will be in the following directory on both Windows and UNIX:
ORACLE_HOME/reports/logs/server_name/
traceOpts
see Table 3-12
Default: trace_all
This attribute defines the activities that will be traced. You can have one or more traceOpt values. For example:
<traceOpts="trace_prf|trace_brk">
Separate values with a vertical bar (|).Valid values are listed and described in Table 3-12.
traceMode
trace_replace
trace_append
Default: trace_replace
Defines whether new trace information will either overwrite the existing trace file (trace_replace), or be added to the end of the trace, leaving existing trace information intact (trace_append).
traceModule
all
server
engine
By default, tracing tracks both server and engine events. Tracing engine events can cause performance problems in some cases. Use traceModule to track only server events (server), only engine events (engine), or both (all). For example:
<trace traceOpts="trace_all" traceModule="server"/>
If traceModule is not specified, the both server and engine traces are turned on.
Table 3-12 Valid values for the traceOpts attribute
Value Description
trace_prf
Logs server and engine profile
trace_brk
Lists debug breakpoints
trace_app
Logs information on all report objects
trace_pls
Logs information on all PL/SQL objects
trace_sql
Logs information on all SQL
trace_tms
Enters a timestamp for each entry in the trace file
trace_dst
Lists distribution lists
Use this value to determine which report section was sent to which destination.
trace_log
Duplicates log information in your trace file
If you have specified a log element in your server configuration file, in addition to using the trace element, this value will cause information that is sent to the log file to also be sent to the trace file.
trace_err
Lists server error messages
trace_inf
This is a catch-all option that dumps any information not covered by the other options into the trace file
trace_dbg
Logs debug information
trace_wrn
Lists server warning messages
trace_sta
Provides server and engine state information, such as initialize, ready, run, and shut-down
trace_all
Logs all possible server and engine information in the trace file
trace_exc
Lists all exceptions
When you specify multiple trace elements, separate them with vertical bars. For example:
3.2.1.12 connection
Example
<connection maxConnect="50" idleTimeOut="20">
<orbClient id="RWClient" publicKeyFile="clientpub.key"/>
<cluster publicKeyFile="%ORACLE_HOME%\reports\server\serverpub.key"
privateKeyFile="%ORACLE_HOME%\reports\server\serverpri.key"/>
</connection>
Required/Optional
Optional. If you do not specify a connection element in your server configuration file, default values will be used (see Table 3-13). You can have a maximum of one connection element in your server configuration file.
Description
The connection element defines the rules of engagement between the server and the clients connected to it.
Connection attributes are listed and described in Table 3-13.
Table 3-13 Attributes of the connection element
maxConnect
Number
Default: 20
The maximum number of requests that the server can service simultaneously. Requests in excess of the maxConnect value return a Java exception.
idleTimeOut
Number
Default: 15
Allowable amount of time in minutes the connection can be idle.
In addition to its attributes, connection has two sub-elements: orbClient and cluster.
Use orbClient to provide the name of the public key file that the client will use to connect to Reports Server. Reports Server uses the public key to verify the signature sent by the client when it tries to connect to Reports Server. Reports Server only accepts clients whose signature can be verified through this public key. You can have from zero to multiple orbClient sub-elements in your server configuration file.
The orbClient element attributes are listed and described in Table 3-14.
Table 3-14 Attributes of the orbClient element
id
string
Default: RWClient
Identifies the Reports Client to be served by the public and private key.
publicKeyFile
filename.key
Default: clientpub.key
Identifies the public key file that the client will use to connect to Reports Server. Reports Server uses the public key to verify the signature sent by the client when it tries to connect to Reports Server. Reports Server only accepts clients whose signature can be verified through this public key. The default file is stored in the rwrun.jar file.
OracleAS Reports Services provides default client public and private key files, clientpub.key and clientpri.key. These key files are in place for all components of OracleAS Reports Services You can regenerate public and private key files to replace the default key pair. To do this, at the command prompt use the following command:
Microsoft Windows
rwgenkey.bat path_and_client_public_key_file_name
             path_and_client_private_key_file_name
UNIX
rwgenkey.sh path_and_client_public_key_file_name path_and_client_private_key_
file_name
If you regenerate these keys, you can specify the public key file locations with the publicKeyFile attribute, and replace the private key file in ORACLE_HOME\jlib\zrclient.jar. To do this, you must unjar the file, place the regenerated private key into it, and rejar the file.
Use the cluster sub-element to specify the public and private key files to be used for all cluster members. You can have zero or one cluster element in your server configuration file.
For more information on server clusters, see Chapter 12, "Clustering Reports Servers".
For servers to be members of the same cluster, they must share the same extended cluster name and public and private keys. This means that their extended cluster names (e.g., serverA.clus, serverB.clus--in this case, .clus is the extended cluster name) should be the same, and the same public and private key files should be specified in each cluster member's server configuration file (server_name.conf).
The default server public and private keys are stored in ORACLE_HOME\reports\jlib\rwrun.jar on both Windows and UNIX. However, there is no need to jar the newly-generated public and private keys that will be used for the cluster. Put them anywhere, and specify the absolute path and filename for them in the server configuration file.
3.2.1.13 queue
Example
<queue maxQueueSize="1000"/>
Required/Optional
Optional. You can have a maximum of one queue element in your server configuration file. If you have no queue element, the default, 1000, will remain in effect.
Description
Use the queue element to specify the maximum number of jobs that can be held in each of the reports queues. OracleAS Reports Services has three queue components:
The queue element provides the allowable value for each of these components.
This element is applicable only to the completed job queue. Thus, if the number of jobs exceeds the specified maximum value, that completed job queue will automatically purge its oldest jobs. The scheduled job queue and the in-progress job queue remain unaffected.
You can also use Reports Queue Manager to manually reduce the number of jobs held in the queue.
For more information, see the Reports Queue Manager online help.
The queue element has one attribute: maxQueueSize, described in Table 3-15.
Table 3-15 Attributes of the queue element
maxQueueSize
Number
Default: 1000
The maximum number of jobs that can be held in a given reports job queue.
3.2.1.14 persistFile
Example
<persistFile filename="neptune.dat"/>
Required/Optional
Optional. If you do not specify a file, the server will create one of its own with the default name server_name.dat. You can have a maximum of one persistFile element.
Description
The persistFile element identifies the file that records all job status. It is used by Reports Server to restore the server to the status it held before shutdown.
It is named persistFile because the file remains intact, or persists, even when the server is brought down and restarted.
The server persistent file is created automatically the first time you start the server or the first time you start the server after the current server persistent file has been deleted or renamed. If you want to rename this file but continue using it, enter the new name in the server configuration file before you actually rename the file, then restart the server.
The persistFile element has one attribute, fileName, described in Table 3-16.
Table 3-16 Attributes of the persistFile element
fileName
string
Default: server_name.dat
The name and, optionally, the path of the server persistent file. You can leave the path off if the file is kept in its default directory:
ORACLE_HOME\reports\server\
The path is the same for Windows or UNIX.
3.2.1.15 identifier
Example
<identifier confidential="yes"
encrypted="yes">fpoiVNFvnlkjRPortn+sneU88=NnN</identifier>
Required/Optional
Optional. You can have a maximum of one identifier element in your server configuration file.
Description
The identifier element is automatically written to the configuration file when you first log in to Reports Queue Manager as an administrator. The first login sets the Reports Queue Manager's administrator user ID and password. That information is encrypted and written to the server configuration file, then used for authentication for all future Queue Manager logins.
If you forget the Queue Manager login or need to change it, delete it and reenter it in Reports Server configuration file in the following format:
<identifier confidential="yes" encrypted="no">username/password</identifier>
You should immediately start Reports Server after making this change. Doing so automatically encrypts the user name and password and resets encrypted to yes. It will look something like this:
This user name and password is also used for accessing rwservlet Web commands, such as getjobid, getserverinfo, showjobs, and showenv when DIAGNOSTIC=NO in the rwservlet.properties file. When DIAGNOSTIC=NO, Web commands are disabled for everyone except those administrators who have this user name and password.
For more information on Reports Queue Manager, see the Reports Queue Manager online help. For more information on rwservlet.properties, refer to Configuring the Reports Servlet.
3.2.1.16 pluginParam
Example
<pluginParam name="mailServer">smtp01.mycorp.com</pluginParam>
Required/Optional
Optional. You can have as many pluginParam elements as you require.
Description
The pluginParam element works in cooperation with all pluggable components of OracleAS Reports Services. This includes the engine, security, cache, destination, and jobstatusRepository components. Any one of these may need access to a mail server, an FTP URL, or some other type of plugin parameter. The pluginParam element provides a means of specifying plugins that can be used by all pluggable components. This spares you the task of including this information in the class definition of the pluggable component and allows you to rapidly and easily change the source of the plugin.
For example, your custom pluggable engine and destination Java classes may both need access to a proxy server. Instead of hard-coding access to the server in both of these classes, you can merely call the type of plugin parameter you need, for example proxy, and point to its location under pluginParam in the server configuration file.
You can put in any plugin parameter and name it in any way as long as it is a plugin supported or required by the pluggable component, and the pluggable component knows its name.
The pluginParam attributes are listed and described in Table 3-17.
Table 3-17 Attributes of the pluginParam element
name
string
The name of the plug-in parameter.
type
text
file
url
Default: text
Describes the type of plugin being specified.
For text, put in the string that is required to identify the named plugin parameter, for example, the name of a mail server. Text means the content of the pluginParam element is text, so the getPluginParam() method will return the exact content specified in the element.
For file, put in the directory path and filename of the plugin parameter file. Use the standards for specifying directory paths appropriate to Reports Server's host machine (either Windows or UNIX). File means that the content of the pluginParam element is a filename, and the getPluginParam() method will return the content read from the file specified.
For url, put in the full, absolute URL required by the plugin parameter, for example, the full URL to an FTP site. URL means the content of the pluginParam element is a URL, and the getPluginParam() method will return the content read from that URL. The URL you use must reside on the same side of the firewall as OracleAS Reports Services.
Note that when you have a default type (text), it is not necessary to specify it in the pluginParam string. The example that heads this section doesn't specify a type because the plugin parameter, a mail server name, is the default type, text.
3.2.1.17 environment
Example
<environment id="JP">
  <envVariable name="NLS_LANG" value="Japanese_Japan.JA16SJIS"/>
  <envVariable name="NLS_CURRENCY" value="¥"/>
  <envVariable name="DISPLAY" value="MyServer.MyCompany.com:0.0"/>
</environment>
Required/Optional
Optional. You can have as many environment elements as you require.
Description
The environment element defines the characteristics (i.e., environment variables) that you want to use to establish a particular runtime environment. You may include as many environment elements as you need (e.g., one for each language/territory you need to support). Inside an environment element, you can add as many envVariable elements as required.
By referencing the environment element's id, you invoke its settings. You can reference an environment element id from:
The environment attributes are listed and described in Table 3-18.
Table 3-18 Attributes of the environment element
id
string
The name of the environment.
The environment element has one sub-element, envVariable. Each envVariable is specified as a name-value pair. They can be either standard environment variables or user-defined environment variables.
The envVariable element attributes are listed and described in Table 3-19.
Table 3-19 Attributes of the envVariable element
name
string
Is the name of the environment you wish to use (e.g., NLS_LANG).
value
string
Is the value you want to assign to the environment variable identified with the name attribute.
3.2.2 Dynamic Environment Switching
In the past, Reports Server could only serve reports that were compatible with the environment in place when Reports Server was started. For example, reports had to be compatible with the value of the NLS_LANG parameter at the time Reports Server was started. This restriction meant that you needed to have one Reports Server running for each language you wanted to process. The new environment switching feature eliminates this restriction by enabling one instance of Reports Server to serve reports with any arbitrary environment settings, including language.
To use this feature, you first need to add an environment element to your Reports Server configuration file to establish a particular runtime environment. Once you have an environment element established, you can switch to its settings in either one of the following ways:
Below is an example of an environment element:
</environment>
You could invoke this environment element from an engine element as follows:
<engine id="rwEng" initEngine="1" minEngine="0" maxEngine="10" engLife="50"
maxIdle="30" defaultEnvId="JP"/>
The value JP identifies the environment element created previously in the Reports Server configuration file. The initial engines will be spawned with the environment settings specified in this environment element. For more information on the environment element, refer to engine.
3.2.2.1 Examples
The following examples illustrate the usage of the dynamic environment switching feature:
Example 1
Suppose that you need to run reports in Japanese from your Reports Server. An environment conducive to running reports in Japanese would include:
To begin, you would have to add an environment element to your Reports Server configuration file that looks something like the following:
</environment>
Once the environment element is in place, you could request a report with Japanese output using the following URL:
http://yourWebServer:port/reports/rwservlet?server=yourreportsserver
&report=Japanese.rdf&userid=username/passwd@db&desformat=htmlcss
&destype=cache&envid=jp
When the URL is submitted to Reports Server, it detects the optional ENVID parameter and matches the specified id (in this case, JP) to the corresponding id in its configuration file. If Reports Server already has an engine running with these characteristics, it will reuse the existing engine to process the job. If not, then it spawns an engine using the current environment plus the three environment variables specified in the JP environment element. If spawning a new engine would cause Reports Server to exceed its maxEngines setting, Reports Server shuts down an engine before starting a new one. An engine may be shut down even though it has not exceeded its engLife setting.
Once Reports Server has an engine with the correct environment running, the job is processed by that engine and the output is routed to the specified DESTYPE.
envid is an optional parameter. If you do not pass this parameter with the job, Reports Server processes the request using an engine started with the defaultEnvId environment. If defaultEnvId is not specified for the engine element in your Reports Server configuration file, then the engine will inherit the settings with which the Reports Server instance was started.
Reports Server may forward the request to another server on the cluster in cases where it cannot handle the request at that time. Even though the job may be routed to another server on the cluster, the target server will reuse or spawn an engine with the required environment to process this job.
Example 2
The following example illustrates how to use this environment switching feature to run an Arabic report on the same Reports Server that was used to run the Japanese report in Example 1.
Add another environment element to the Reports Server configuration file as shown below:
<environment id="AR">
 <envVariable name="NLS_LANG" value="Arabic_United Arab Emirates.AR8ISO8859P6"/>
 <envVariable name="NLS_CALENDAR" value="Arabic Hijrah "/>
</environment>
The Arabic report has to be submitted to Reports Server with the following command line:
&report=arabic.rdf&userid=username/passwd@db&desformat=htmlcss
&destype=cache&envid=ar
Since the job is submitted with envid=AR, Reports Server finds or starts an engine with the environment specified by element AR in the Reports Server configuration file. The job is processed by the new engine and the output is distributed to the specified destination.
Example 3
The following example illustrates how the environment switching feature could be used in conjunction with a JSP report, i.e., without the Reports Servlet.
Suppose that you have the following environment elements in the Reports Server configuration file:
<environment id="UK">
 <envVariable name="NLS_LANG"  value="AMERICAN_UNITED KINGDOM.WE8ISO8859P1"/>
</environment>
<environment id="US">
 <envVariable name="NLS_LANG" value="AMERICAN_AMERICA.WE8ISO8859P1"/>
</environment>
If your JSP report uses a format mask such as the following, it means the currency, grouping, and decimal symbols can change according to the environment:
<rw:field id="sal" src="sal" formatMask="L999G999D999"/>
To run the report using the UK symbols for currency, grouping, and decimal, you would use the following URL:
http://myserver:port/test/myjsp?userid=scott/tiger@orcl&envid=uk
Note: You could place envid=uk into a key in the cgicmd.dat file.
3.2.2.2 Usage Notes
3.2.3 Connecting to OracleAS Portal
By default, Reports Server can only use portal users to connect to OracleAS Portal. It cannot use an ordinary userid, such as scott/tiger, unless you first assign appropriate privileges to its schema.
To assign the appropriate privileges to a schema other than the portal schema, you need to run the following script from SQL*Plus as an OracleAS Portal user:
ORACLE_HOME/portal/admin/plsql/wor/rwgrant.sql
Once the script is loaded, it prompts you to enter the connection string for the new schema (e.g., repapp/repapp@orcl). The script then assigns the appropriate privileges to this new schema. You will then be able to specify this connection string in the Reports Server configuration file to connect to OracleAS Portal.
3.3 Configuring the Reports Servlet
Configure the Reports Servlet with a file named rwservlet.properties, located in the following path (Windows and UNIX use the same path):
You may notice that the servlet uses components you may have become familiar with if you used to employ a CGI implementation.
Use the Reports Servlet configuration file for:
The entries in this configuration file are not case sensitive.
For Windows, note that the servlet configuration file uses double backslashes (\\) in lieu of single backslashes to specify a directory path. The first slash "escapes" the second, which would otherwise have another meaning in this file. For example, in a Windows-based Reports Servlet file, the path:
d:\orawin\reports\conf\filename.ext
Becomes:
d:\\orawin\\reports\\conf\\filename.ext
For UNIX, use that platform's standard for specifying directory paths, for example:
orawin/reports/conf/filename.ext
3.3.1 Specifying the Location of the Key Map File
Your report runtime command line may include information you do not want to expose to your users. Additionally, it may be comprised of a long string of options that is difficult to remember or makes for an ungainly URL.
You have the option of entering a report's command line options in a key map file (cgicmd.dat), then limiting the exposed runtime command to the name of the particular key section in this file that holds the required options.
The key map file is discussed in Chapter 13, "Running Report Requests". Use the Reports Servlet configuration file to list the location of this file.
For example:
KeyMapFile=d:\\orawin\\reports\\conf\\cgicmd.dat
This example uses the default filename and location. An entry for the location and filename of the key map file doesn't appear by default in the servlet configuration file because the servlet already knows what to look for and where to look for it. If you use a file with a different name and/or different location, you must include a KeyMapFile parameter in your servlet configuration file that includes the directory path and filename.
3.3.2 Reloading the Key Map File
Use the RELOAD_KEYMAP parameter to specify whether the key map file (cgicmd.dat) should be reloaded each time the servlet receives a request.
For example:
RELOAD_KEYMAP=yes
This is useful if you frequently make changes to the map file and want the process of loading your changes to be automatic. Runtime performance will be affected according to how long it takes to reload the file.
Typically, this parameter is set to no in a production environment and yes in a testing environment.
3.3.3 Hiding Web Command Output
You may want to provide an authentication mechanism for an unsecured Reports Server so that only an administrator (based on the authid) can run a Web command, like showenv, showjobs, etc. By setting DIAGNOSTIC=NO in the rwserver.properties file, you can provide just such an authentication mechanism. This authentication information is also used for administrative tasks, for example, stopping the Reports Server from the command line.
Setting DIAGNOSTIC=NO only works for non-secured Reports Server. For secure Reports Server users, Reports Server verifies the user's privileges based on the entries in Oracle Internet Directory.
To disable Web command display for an unsecured Reports Server
  1. Start a Reports Server.
  2. Set DIAGNOSTIC=NO in the rwservlet.properties file.
  3. Access the Reports Server from rwservlet, by using any of the Web commands, for example, getserverinfo. You must pass an authid here.
    For example:
    http://yourwebserver:portnum/reports/rwservlet/getserverinfo?server=aks+auth
    id=scott/tiger
    The Reports Server will save this authid in the following directory: ORACLE_HOME/reports/conf/server_name.conf file under the <identifier> element. The <identifier> element is set in the Reports Server configuration file by the first Web command call if it is not defined in the server configuration file and the values are automatically encrypted when the Reports Server is started. The format to preset the <identifier> element in the Reports Server configuration file is:
    The clear text of username and password will be encrypted by Reports Server once it starts up, and the encrypted atttribute is changed to yes to indicate the content is encrypted.
    Refer to identifier, for more information on the <identifier> element.
    Now, any access to the reports server for using the Web commands will have to pass the same authid. If the authid is not passed, then you will get the following error:
    REP-52262: Diagnostic output is disabled.
To modify the administrator username and / or password:
  1. Open the Reports Server configuration file, i.e.,server_name.conf.
  2. Modify the <identifier> element:
    <identifier encrypted="no"confidential="yes">admin_name/admin_
    Tip:
    You can specify the administrator username/password in the <identifier> element in the rwserver.template file. This ensures that you can pass the same authid for any Reports Server that you start up.
3.3.4 Selecting Login Dialog Boxes
The servlet configuration file offers a number of parameters dealing with templates for userid/password dialog boxes that should open when a user logs in to a database or runs a secure report. Generally, these parameters point to various templates to be used for setting up your login screens. You can customize these templates with your company logo, linked buttons, and/or any other HTML you care to use.
The DBAUTH and SYSAUTH parameters are for specifying the location and filename of the HTML templates to be used for individual login screens. By default, the file names are rwdbauth.htm and rwsysauth.htm, respectively.
For example, the following entry points to the template for the database login screen:
DBAUTH=rwdbauth.htm
SYSAUTH points to a login screen for a secure report. For example:
SYSAUTH=rwsysauth.htm
It isn't necessary to enter the path to a template when it is stored in the default template directory:
3.3.5 Setting Up Trace Options for the Reports Servlet and JSPs
Trace has been added to the OracleAS Reports Services environment to allow the logging of many different types of runtime information on various OracleAS Reports Services components.
Tracing for Reports Server is configured in the server configuration file, server_name.conf, discussed in Section 3.2.1.11. Tracing for an individual report can be built into the Reports Runtime command line, discussed in Command Line Options.
If you wish to track and log runtime information on the Reports Servlet and JSPs, use the TRACEOPTS parameter in the servlet configuration file. You can enter from zero to multiple trace options. Separate each option with a vertical bar.
For example:
TRACEOPTS=trace_prf|trace_pls|trace_dbg
All available trace options are listed and described in Table 3-12.
Additionally, you can use the TRACEFILE and TRACEMODE parameters.
Use TRACEFILE to specify the filename of the trace file. For example:
TRACEFILE=myrwservlet.trc
The default name is rwservlet.trc. If no path is specified, the trace file will be in the following directory on both Windows and UNIX:
ORACLE_HOME\reports\logs
Use TRACEMODE to define whether new trace information will either overwrite the existing trace file (trace_replace), or be added to the end of the trace, leaving existing trace information intact (trace_append). TRACEMODE replaces or appends to the tracing information that has accumulated since the startup of the Oracle Application Server Containers for J2EE container that contains rwservlet. For example:
TRACEMODE=trace_append
The default for TRACEMODE is trace_replace.
3.3.6 Specifying the character encoding for reports output using rwservlet
From Oracle Reports 10g (9.0.4) onwards, you can specify non-ASCII escaped characters in the request URL or in the Parameter Form input. You must specify the character encoding in the rwservlet.properties file before you can apply it. This is to ensure that rwservlet uses the required encoding when parsing the parameter value.
You can set the value of DEFAULTCHARSET in the rwservlet.properties file to either:
Example
DEFAULTCHARSET=JA16EUC.
3.3.7 Disallowing HTML code specified in the URL from being executed in a browser
Any HTML code included as part of the report request URL might lead to a security compromise as it causes certain browsers to execute any script or code in the URL. From Oracle Reports 10g (9.0.4) onwards, HTML code is not allowed as part of the URL command.
To disallow HTML code as part of the URL command, a new property ALLOWHTMLTAGS is introduced in the rwservlet.properties file. This property is set to NO by default, disallowing any HTML code to be entered in the URL when running a report.
Valid Values:
YES Allows HTML code in the URL
Setting ALLOWHTMLTAGS=YES allows malicious HTML code to be executed by certain browsers.
NO Disallows any HTML code in the URL
Default:
NO
3.3.8 Specifying the pool size for concurrent connections to rwservlet
You may want to define the number of users who can connect and submit job requests simultaneously to rwservlet. To do so, you must set the value of the CONNECTION_POOLSIZE property in the rwservlet.properties file.
Default Value
500
Minimum Value
0 (not recommended)
Set the value of CONNECTION_POOLSIZE keeping in mind the number of active users expected to make concurrent job requests. For example, set this value to 250 if you expect around 100 concurrent active users.
The value set (for example, 100) is the number of active users simultaneously making job requests and not the number of users connected to the system without submitting requests.
3.3.9 Customizing the Appearance of Server Error Messages
OracleAS Reports Services provides a template for server error messages. These messages are generated automatically, according to cause. The template provides the visual setting within which the error message is displayed.
You may wish to customize the appearance of error messages, for example with your company logo, or with an icon you plan to associate with errors. You may wish to add buttons that link your users to a help system, your company home page, or back to the last browser window. You can do this by providing your own HTML framework for automatically generated error messages.
The entry in the servlet configuration file is for pointing to the name and location of your error message template.
By default, the entry is:
ERRORTEMPLATE=rwerror.htm
It isn't necessary to enter the path to the error message template when it is stored in the default template directory:
3.3.10 Specifying an In-Process Server
If you choose to run the Reports Server within the same process as the Reports Servlet, you indicate that with the SERVER_IN_PROCESS parameter. To run the Reports Server as an in-process server, specify the following in the servlet configuration file:
SERVER_IN_PROCESS=yes
Enter no if you do not want the Reports Server to run within the same process as the Reports Servlet.
The pros and cons of running an in-process server are explored in Chapter 1, "Understanding the OracleAS Reports Services Architecture".
3.3.11 Identifying the Default Reports Server
The Reports Servlet uses the SERVER parameter to identify the default Reports Server. If a server name is not specified, for example, in the runtime URL, the default server specified here is used. Enter the name of your default Reports Server in the servlet configuration file.
For example:
SERVER=server_name
If the default Reports Server is a member of a server cluster, use the cluster name:
SERVER=server_name.cluster_name
If you use a combination of the server name and cluster name in your URL, requests sent to the default server will go to this specific machine. If this machine is down, an error message will be returned and the report will not be run. By specifying just the cluster name in the URL, requests will be sent to a random cluster member, and fowarded to another if the target machine doesn't have an idle engine.
If you don't specify a SERVER parameter in rwservlet.properties, the default server name is rep_machine_name.
3.3.12 Pointing to Dynamically Generated Images
Optionally, you can use the IMAGE_URL parameter to specify where the reports' dynamically generated images can be accessed.
For example:
IMAGE_URL=http://server_or_web_server_name.domain_name:port/reports/rwservlet
This parameter is in place for JSPs that do not run via the Reports Servlet. It ensures that dynamically generated images, such as charts, will be viewable only by the person who runs the report. JSPs, and other report types, that run through the Reports Servlet have this protection automatically.
3.3.13 Setting Expiration for Database and System Authentication Cookies
Use the COOKIEEXPIRE parameter to set the lifetime (in minutes) of the database and system authentication cookie. For example:
COOKIEEXPIRE=20
The default is 30.
Cookies save encrypted user names and passwords on the client-side when users first authenticate themselves. When the server receives a cookie from the client, the server compares the time saved in the cookie with the current system time. If the time is longer than the number of minutes defined in COOKIEEXPIRE, the server rejects the cookie and returns to the client the authentication form along with an error message. Users must re-authenticate to run the report.
3.3.14 Setting an Encryption Key for the Database and System Authentication Cookies
Use ENCRYPTIONKEY to specify the encryption key to be used to encrypt the user name and password of the database and system authentication cookies. The encryption key can be any character string. For example:
ENCRYPTIONKEY=egbdf
3.3.15 Adding Formatting to Diagnostic/Debugging Output
The DIAGBODYTAGS and DIAGHEADTAGS parameters are available for including additional HTML encoding in the <body> and <head> tags in the output files associated with diagnostic and debugging output.
DIAGBODYTAGS defines the entire <body> tag; while DIAGHEADTAGS defines tags to appear between the open and close <head>/</head> tags.
You can use these to include formatting options to make diagnostic and debugging output easier to read. For example:
DIAGBODYTAGS=<BODY [additional HTML encoding]>
DIAGHEADTAGS=<HEAD>[additional HTML encoding]</HEAD>
3.3.16 Defining the rwservlet Help File
A HELP keyword is available with the rwservlet command for bringing up a servlet-related help topic. The help file is invoked when you specify the following URL:
http://your_web_server/your_servlet_path/rwservlet/help
For more about the HELP keyword, see Appendix A, "Command Line Options".
We provide a default help file for the servlet, ORACLE_HOME\reports\templates\help.htm, which will be displayed if you leave this parameter undefined. You may want to supply a help file of your own. To do this, specify the name and location URL of your servlet help file with the HELPURL parameter in the servlet configuration file. For example:
HELPURL=http://your_web_server/your_help_file_path/helpfile.htm
3.3.17 Specifying the Use of OracleAS Single Sign-On
If you plan to take advantage of OracleAS Reports Services' Single Sign-On capability, you must ensure the SINGLESIGNON parameter is set to YES in the servlet configuration file. SINGLESIGNON is set to YES by default upon installation.
For more information, refer to Enabling and Disabling OracleAS Single Sign-On.
3.4 Configuring the URL Engine
Reports Server includes a URL engine that can take the contents of any URL and distribute them. The URL engine allows you to leverage the powerful scheduling and distribution capabilities of Reports Server to distribute content from any publicly available URL to various destinations such as e-mail, OracleAS Portal, and WebDav. Since Reports Server's destinations are pluggable, you can also add your own custom destinations for the URL content.
Furthermore, if you use the URL engine in conjunction with Reports Server's event-based APIs, database events can trigger the content distribution. For example, suppose you have created a JSP report for high fidelity Web publishing of data stored in a table containing employee expense data. You could then use the URL engine and the event-based API to e-mail that JSP whenever the expense application stores new or updated employee expense data in the table.
If the URL engine is not activated, you can activate it by doing the following:
  1. Add an engine element for the URL engine to the server configuration file. For example, your engine element might be as follows:
    <engine id="rwURLEng"
                 class="oracle.reports.engine.URLEngineImpl"
                 initEngine="1"
                 maxEngine="1"
                 minEngine="0"
                 engLife="50"
                 maxIdle="30"
  2. Add a job element that associates the appropriate job types with the URL engine to the server configuration file. For example, your job element might be as follows:
    <job  jobType="urlEngine"
             engineId="rwURLEng"
  3. Stop and restart Reports Server.
    When you restart your Reports Server with these new elements, you should see the number of engines increase accordingly in the Reports Server status message box. In the above example, the number of engines would increase by one (the value of initEngine) when you restart Reports Server.
To learn about sending requests to the URL engine, refer to Chapter 13, "Running Report Requests".
3.5 Entering Proxy Information
Some features of OracleAS Reports Services support retrieving or sending information through a firewall. For example, the URL engine, the XML data source, the Text data source, and the mail destination features all retrieve or send information through the firewall. For these features to function properly, Reports Server requires certain proxy information. In the interests of simplicity, you store the necessary proxy information in a single location and point to it from the Reports Server configuration file. To configure your Reports Server with proxy information, you do the following:
  1. Add the pluginParam element to the server configuration file and have it point to the proxy information file (e.g., proxyinfo.xml). For example, your pluginParam element might be as follows:
    <pluginParam name="proxy" type="file">proxyinfo.xml</pluginParam>
    You can optionally specify a path for the proxy information file. By default, this file is located in ORACLE_HOME/reports/conf.
  2. Update the proxy information file with the necessary proxy values for your configuration. For example, proxyinfo.xml might contain the following:
    <proxyInfo>
       <proxyServers>
         <proxyServer name="xyz.abc.com" port="80" protocol="http"/>
         <proxyServer name="www-proxy1.xyz.abc.com" port="80" protocol="ftp"/>
         <proxyServer name="www-prox21.xyz.abc.com" port="80" protocol="https"/>
       </proxyServers>
       <bypassProxy>
         <domain>*.abc.com</domain>
       </bypassProxy>
    </proxyInfo>
    Refer to the default proxy information file, ORACLE_HOME/reports/conf/proxyinfo.xml, for additional information.
3.6 Configuring Reports Server with the Oracle Process Manager and Notification Server and Oracle Enterprise Manager
The best way to start, shutdown, monitor, and manage Reports Server is through the Oracle Process Manager and Notification Server (OPMN) and Oracle Enterprise Manager. OPMN provides a centralized mechanism for initializing, maintaining, and shutting down your Oracle Application Server components, including Reports Server. Oracle Enterprise Manager, included with Oracle Application Server, provides managing and monitoring services to OracleAS Reports Services. You can conveniently monitor your Reports Servers through Oracle Enterprise Manager and, if the process crashes for any reason, OPMN restarts Reports Server for you automatically.
During installation of Oracle Application Server, Reports Servers are automatically configured in OPMN and registered with Oracle Enterprise Manager. If you add any Reports Servers after installing Oracle Application Server, you should register the new server(s) in two places:
To register a new Reports Server in both opmn.xml and targets.xml, run the following command line:
On UNIX:
ORACLE_HOME/bin/addNewServerTarget.sh reports_server_name
On Windows:
ORACLE_HOME\bin\addNewServerTarget.bat reports_server_name
You can add a Reports Server to OPMN using addNewServerTarget.sh (UNIX) or addNewServerTarget.bat (Windows). However, to view the Reports Server on the Enterprise Manager page, you must restart OPMN by using the following commands:
opmnctl stopall
opmnctl startall
3.6.1 opmn.xml
Components are configured with OPMN in the opmn.xml file located in ORACLE_HOME/opmn/conf. To configure Reports Server through OPMN, you need the following in opmn.xml:
3.6.1.1 Process Module
The module tag is included by default in opmn.xml and tells OPMN that it needs to load a particular module. In the case of Reports Server, the OracleAS Reports Services module must be loaded. This module is loaded with the following information by default in opmn.xml:
<module path="/private/oraclehome/opmn/lib/libopmnreports">
  <module-id id="ReportsServices"/>
</module>
3.6.1.2 Standalone Reports Server Specification
In the case of the standalone Reports Server, the Reports Server is running in its own component. Therefore, you must specify a separate component for Reports Server. For example:
<ias-component id="<RSName>" status="enabled" id-matching="false">
  <process-type id="ReportsServer" module-id="ReportsServices">
    <process-set id="<RSName>" restart-on-death="true" numprocs="1">
      <environment>
        <variable id="PATH" value="your_shell_path"/>
      </environment>
      <module-data>
        <category id="general-parameters">
          <data id="batch"  value="yes"/>
        </category>
        <category id="restart-parameters">
          <data id="reverseping-timeout"  value="120"/>
        </category>
      </module-data>
      <dependencies>
        <OID infrastructure="true"/>
        <database infrastructure-key="portal"/>
        <managed-process ias-component="OC4J" process-type="OC4J_BI_Forms"
           process-set="default_island" autostart="true"/>
        <managed-process ias-component="HTTP_Server"
           process-type="HTTP_Server" process-set="HTTP_Server"
           autostart="true"/>
        <managed-process ias-component="WebCache" process type="WebCache"
          process_set="WebCache" autostart="true"/>
      </dependencies>
      <start timeout="120" retry="3"/>
      <stop timeout="120"/>
      <restart timeout="120"/>
      <ping timeout="30" interval="30"/>
    </process-set>
  </process-type>
</ias-component>
The timeout values in the above example are all in number of seconds.
The key segments of this specification for Oracle Reports are described below.
<ias-component id="<RSName>" ...>
This tag specifies the name of Reports Server. It must match the Reports Server internal name from targets.xml.
See Also:
Chapter 19, "Managing and Monitoring OracleAS Reports Services"
For more information about targets.xml.
This tag defines the process for the named Reports Server and associates it with the OracleAS Reports Services process module.
This tag defines the process characteristics for the named Reports Server. It indicates whether Reports Server should be restarted when it crashes. It also specifies the number of Reports Servers started for this process set, which has to be 1 because the process-set id identifies a single Reports Server name.
The first tag specifies the value for the PATH environment variable for the process. This variable must be set for the start script to find uname. This environment element is not needed on the Microsoft Windows platform.
</category>
This group of tags gathers together all of the data (parameters) common to the process. In this particular example, it provides a way to specify that the BATCH parameter be sent to Reports Server. batch=yes|no is an option to the start and stop commands of Reports Server. If it is not configured, this option is not passed in to Reports Server.
</category>
This group of tags indicates the restart parameters category, which defines parameters to be used in detecting whether the process has failed and needs to be restarted. If a notification is not received within the specified reverseping-timeout period, then the process is considered failed and will be restarted.
<dependencies>
This tag delimits the list of components upon which Reports Server depends. For example, Reports Server typically depends upon, among other things, the Oracle HTTP Server and Oracle Application Server Containers for J2EE.
OPMN uses dependencies to determine whether to start a process. Like module-data and environment blocks, dependencies blocks can be defined for multiple elements within opmn.xml. OPMN creates an aggregate dependency list at the process set level that contains all of the dependencies defined at or above it. If duplicate dependencies are defined at different levels, then duplicate checks on that dependency are made before starting a process.
OPMN has two primary types of dependencies: external and internal. External dependencies are resources not managed by OPMN (the database, Oracle Internet Directory, and OracleAS Single Sign-On). For external resources, an external program performs the check on the resource. Internal dependencies are OPMN-managed processes, which may include processes managed by a remote OPMN instance. Internal dependencies are indicated in the list by the managed-process tag.
OPMN maintains a cache of dependency states that contains the last known state of each dependency and the time it was last checked. A single cache entry exists for each dependency with identical attributes, even if that dependency is specified in multiple locations (i.e., for different process sets). A cache timeout parameter for each dependency allows users to specify how long to use its state in the cache. Likewise, a general timeout parameter for each dependency determines how long OPMN should wait for a status update before aborting the dependency check and the process start.
Dependencies are checked in the order in which you declare them. The traversal of this list of dependencies concludes either when the full sequence of checks completes successfully (the resource is available) or when one of the checks fails (the resource is not available or the check timed out).
The following example tags illustrate a typical list of dependencies for Reports Server:
      autostart="true"/>
      process-type="WebCache" process-set="WebCache"
      autostart="true"/>
The OID tag indicates that Reports Server uses the default Oracle Internet Directory instance for this Oracle Application Server installation.
The database tag points to the OracleAS Portal instance used by Reports Server.
The first managed-process tag specifies the Oracle Application Server Containers for J2EE instance used by Reports Server. The second managed-process tag indicates the Oracle HTTP Server instance.
See Also:
For more information about opmn.xml and its contents:
  • Oracle Application Server 10g Administrator's Guide
3.6.1.3 In-Process Reports Server Specification
In the case of the in-process Reports Server, the Reports Server is running inside the OC4J component. If you are using the in-process Reports Server, then, within the OC4J component, you must specify the Reports Server data. For example:
<ias-component id="OC4J">
  <process-type id="OC4J_BI_Forms">
    <module-data>
      <category id="urlping-parameters">
        <data id="/reports/rwservlet/pingserver?start=auto" value="200"/>
      </category>
    </module-data>
    <process-set .../>
  </process-type>
</ias-component>
The key segments of this specification are described below.
urlping-parameters is a category that identifies all of the URLs to be pinged by the OC4J module. The protocol used for pinging is AJPv1.3.
/reports/rwservlet/pingserver?start=auto is the URL to be pinged by the OC4J module. In the context of the in-process Reports Server, pinging this URL allows OPMN to determine whether the Reports Server application is responsive. If it is unresponsive, OPMN restarts the corresponding OC4J process.
value=200 specifies a valid HTTP code (200) that is expected in response to the ping request. If the response HTTP code matches the value configured here, OPMN considers the application healthy and responsive. Otherwise, OPMN restarts the OC4J process.
3.7 DISPLAY and Printer Dependencies on UNIX
In previous releases of OracleAS Reports Services on UNIX, you had to set the DISPLAY environment variable for Reports Server. Previous releases required DISPLAY to use the windowing system display surface for creating images and getting pixel resolution. This dependency is removed in OracleAS Reports Services 10g (9.0.4).
Additionally, previous releases required a valid printer on UNIX for fonts. When no valid printer was available, OracleAS Reports Services used the screen fonts, which again required setting the DISPLAY environment variable. In Release 10g (9.0.4), OracleAS Reports Services includes a default screen printer surface, ScreenPrinter, that emulates a screen or printer for fonts in the absence of an available printer. As a result, OracleAS Reports Services does not require a printer on UNIX as of OracleAS Reports Services 10g (9.0.4).
By default, the environment variable REPORTS_DEFAULT_DISPLAY is set to YES, which specifies that OracleAS Reports Services should:
If you wish to revert to the old behavior from previous releases, you can set REPORTS_DEFAULT_DISPLAY=NO.
See Also:
Appendix B, "Reports-Related Environment Variables"
For more information on Oracle Reports environment variables.
3.7.1 ScreenPrinter
The PostScript printer driver screenprinter.ppd provides surface resolution for images and specifies font information. This driver is the first entry in uiscreenprint.txt. The file locations (UNIX only) are:
uiscreenprint.txt : ORACLE_HOME/guicommon9/tk90/admin
screenprinter.ppd : ORACLE_HOME/guicommon9/tk90/admin/PPD
ScreenPrinter is used for:
If, when generating report output, there is no valid printer queue available (not found from TK_PRINTER,ORACLE_PRINTER,PRINTER, or uiprint.txt), the surface based on screenprinter.ppd will be created and used to get font information. You can modify the Fonts section of screenprinter.ppd to include new fonts, and modify the DefaultResolution field to change the resolution (DefaultResolution is 96).
If you do add new fonts, ensure that the new AFM files are placed in the AFM directory.
The font look up algorithm on UNIX is:
if a valid printer available then
  look up font information from the printer
else
 create a screenPrinter surface
 look up font information from ScreenPrinter
 if ScreenPrinter creation fails then
    REP-1800 : Formatter Error if REPORTS_DEFAULT_DISPLAY is set
  else
    use Screen Fonts
In certain multi-byte languages like Chinese, you may want to use screen fonts. However, this would necessitate setting the DISPLAY variable for running the report.
To revert to DISPLAY and use screen fonts (old font look up algorithm):
  • Set REPORTS_DEFAULT_DISPLAY=NO
  • Remove the screenprinter.ppd entry in the uiscreenprint.txt file.
See Also:
For more information about fonts and printing on UNIX.
3.7.2 Advanced Imaging Support
The quality of images contributes considerably to the overall appearance of a report, particularly for a Web report. You may prefer different image formats in your report output depending on the needs of your project. For example, an aeronautical firm might prefer the higher quality of JPEG or PNG images in their Web reports instead of GIF images. On the other hand, if you are building a Web portal, you might prefer GIF images because of their smaller size and faster download. Similarly, you may wish to import images of these various formats into your report.
Depending on the format of your output, you may choose from a variety of formats for your images.
Table 3-20 Image Format Options by Output Type
Report Output Available Image Format Choices
HTML,HTMLCSS
PNG, JPEG, JPG, GIF
PDF
PNG, JPEG, JPG, GIF
RTF
PNG, JPEG, JPG, BMP
As you choose your image format, you should take into account the quality and size considerations. Typically, the higher the quality of the image format, the greater the size. For example, PNG and JPEG are higher quality than GIF, but they may also require more storage space.
To enable advanced imaging, you must set the REPORTS_DEFAULT_DISPLAY environment variable to YES. The REPORTS_DEFAULT_OUTPUTIMAGEFORMAT environment variable lets you choose the default image type. Users can override the default choice for images with the OUTPUTIMAGEFORMAT command line keyword. For example:
rwclient server=my_rep_server report=images.rdf destype=file desformat=html
desname=images.html userid=scott/tiger outputimageformat=PNG
Enabling advanced imaging also allows you to import images of these same formats into your report.
Enabling advanced imaging means that you can no longer use the old CGM and OGD formats in outputs of type HTML or HTMLCSS. If you require these formats for input sources, you should set REPORTS_DEFAULT_DISPLAY to NO. This limitation does not apply on the Windows platform.
See Also:
For more information on environment variables.
For more information on command line keywords.
3.8 Setting the default printer for an in-process server
The in-process server does not recognize the default printer of a user currently logged on to Windows. This is because the service that runs the in-process server is logged on as the Local System. Therefore, you might face the following issues:
To work around the issue:
  1. Open the Windows registry using a registry editor (e.g., regedit.exe).
    Create a backup of the registry before editing it.
  2. Navigate to the following key:
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows
  3. Copy the string value of Device for this key. For example:
    \\MOWGLI\sierra,winspool,Ne02:
  4. Navigate to the following key:
    HKEY_USERS\.DEFAULT\Software\Microsoft\Windows NT\CurrentVersion\Windows
  5. Paste the Device value copied from HKEY_CURRENT_USER (the string value of Device for this key will be empty).
    This workaround must be applied everytime you alter the value of the Default Printer.
Go to previous page Go to next page
Oracle
Copyright © 2003 Oracle Corporation.
All Rights Reserved.
Go To Table Of Contents
Contents
Go To Index
Index
