Skip Headers
Oracle Application Server Reports Services Publishing Reports to the Web
10g (9.0.4)
Part Number B10314-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
15
Creating Advanced Distributions
When you wish to define an advanced distribution for your report, you can design the distribution by developing a distribution XML file. This file can specify which section or sections of a report should go to what destination via what format of output. In one distribution XML file, you can specify many different destinations, including custom (pluggable) destinations you design.
This chapter provides information on creating a distribution XML file and some example use cases. It includes the following main sections:
15.1 Distribution Overview
Although distribution XML files are not required for specifying the distribution of report output, they are useful for complex distributions. For example, there may be times when you want to publish the output of one report in a variety of ways. You might want to send an executive summary of a report to senior management while mailing detailed breakdowns to individual managers. In this case, you might produce a single report with two report sections: a portrait-sized summary section and a landscape-sized detail section. You would associate the detail section with a data model group that lists the managers, then alter the destination on each instance of the group to send each department's output to its related manager.
The distribution XML file tames distribution complexity by enabling you to define multiple outputs for a given report in one XML file, then call that file from a command line or URL.
15.2 Introduction to Distribution XML Files
15.2.1 The distribution.dtd File
When you create a distribution XML file, you follow the syntax defined in the distribution.dtd file located in the following directory (Windows and UNIX use the same path):
ORACLE_HOME\reports\dtd
As you look through the following sections, it may be useful to you to print the distribution.dtd file and refer to it as various elements and attributes are described.
information provided in distribution XML file is case sensitive. The user must preserve case of various elements and attributes as specified in the distribution.dtd file.
The distribution.dtd file lists all elements that are valid within a distribution XML file. Each of these elements have attributes. Attributes that come with default values need not be specified, unless you wish to override the default.
You can create a dynamic distribution by introducing variable values into many different attributes. Variable values reference columns that are present in the report that is using the distribution XML file.
15.2.2 Using Variables Within Attributes
You can use variables within attributes by entering &column_name or &<column_name> in the place of a static value.
The ampersand (&) and less-than symbol (<) have specific meanings in XML, but they are also required symbols for certain Oracle Reports Developer command line options (for example, lexical parameters require the ampersand symbol). To avoid conflict with the XML meanings of these symbols when you set up variables, specify the encoded version of the ampersand (&amp;) and less-than and greater-than symbols (&lt; and &gt;). For example:
Here is what the variable looks like improperly coded in an XML file:
<mail id="a1" to="&<manager>@mycompany.com" ...
Here is what the variable looks like properly coded in an XML file:
<mail id="a1" to="&amp;&lt;manager&gt;@mycompany.com" ...>
There is no special requirement for the greater-than symbol (>) used with variables, but for consistency, we recommend that you use the encoded version (&gt;).
The variable syntax you use depends on whether the value is expressed by itself or in combination with other values or strings. For example, a value for a "to" attribute in a mail element might be expressed as either:
<mail id="a2" to="&amp;email" ...>
OR
<mail id="a3" to="&amp;&lt;first_name&gt;.&amp;&lt;last_name&gt;@myco.com ...>
In the first example (id="a2"), the variable's referenced column (email) contains a full e-mail address and does not require additional information. The second example (id="a3") uses a combination of variable values (first_name and last_name) and static text to construct an e-mail address (static text is the period after first_name and @myco.com). In both cases, you will get dynamic e-mail addressing. The example you use will depend on whether the variable contains all the information you need or requires additional information in order to be complete.
For even more complex layouts, you can also reference report columns you created with PL/SQL formulas. For example, in your report you may define the PL/SQL column:
PL/SQL formula CF_MAILID: return(:first_name||'.'||:last_name)
You'd reference this column in the distribution XML file as:
to="&amp;&lt;CF_MAILID&gt;@mycompany.com"
15.3 Elements of a Distribution XML File
The elements of a distribution XML file include:
Most of these elements have attributes that define the behavior of the element. The following sections describe the distribution XML file elements and their associated attributes. Distribution XML File Examples provides use cases that demonstrate the distribution XML file elements and attributes in action.
15.3.1 destinations
Example
<destinations>
[One or more distribution specifications]
</destinations>
Required/Optional
Required. You must have no more or less than one destinations element in your distribution XML file.
Description
The destinations element opens and closes the content area of the distribution XML file. In terms of the distribution XML file's tagging hierarchy, all the other elements are subordinate to the destinations element.
The destinations element has the following sub-elements:
Each of these is discussed in the following subsections.
15.3.2 foreach
Example
<foreach>
   <mail id="a1" to="my_addressee@mycompany.com" subject="Fourth Quarter
   Results">
     <attach format="pdf" name="dept_&amp;department_ID&gt;.pdf"
     srcType="report" instance="this">
        <include src="mainSection"/>
     </attach>
   </mail>
</foreach>
OR
<mail id="a4" to="recipient@mycompany.com" subject="Regional Results">
    <foreach>
        <attach format="pdf" name="report.pdf" srcType="report" instance="all">
        </attach>
    </foreach>
</mail>
Required/Optional
Optional. You can have as many foreach elements as you require.
Description
Use the foreach element to burst your distribution against a repeating group. You can use foreach only when the associated report definition file (either RDF, JSP, or XML) has its "Repeat On" property for the section that will be burst set to an appropriate group. The foreach element specifies that the distribution defined between its open and close parameters should be performed for each repeating group.
The Repeat On property can be set for a report section (Header, Main, and Trailer) to associate a data model break group to a section. By setting the Repeat On property for a section, you can generate multiple instances of a section, or a repeating section.
When you implement bursting and distribution in a report, you can generate section-level distribution by setting the Repeat On property for a section to a data model break group, which generates an instance of the section for each column record of that break group. Then, you can distribute each instance of the section as appropriate (for example, to individual managers in the MANAGER group).
If you set the Repeat On property for more than one of the Header, Main, and Trailer sections of a report, all Repeat On property values must be set to the same data model break group. If the Repeat On property for any one of the Header, Main, and Trailer sections is set to a different data model break group, Oracle Reports raises any of the following messages:
REP-0069: Internal Error
REP-57054: In-Process job terminated: Terminated with error
REP-594: No report output generated.
The foreach element has the following sub-elements:
You can also use the foreach element as a sub-element of the mail element, as depicted in the second example provided at the start of this section. (In this example, assuming that mainSection repeats on G_DEPARTMENT_ID, the example will produce a single attachment with all the instances of the report's mainSection in a single file.)
The foreach element works closely with the instance attribute of the attach and file elements. While foreach specifies that the distribution should be performed according to record groups, instance specifies whether the burst groups should be distributed in one file (instance="all") or distributed as separate files: one file for each group instance (instance="this").
When used with the mail element, foreach can mean different things according to its position relative to the mail element:
15.3.3 mail
Example
<mail id="a1" to="jsmith@foo.com" subject="Results">
   <body srcType="text">
     Attached are quarterly results.
   </body>
   <attach srcType="report">
      <include src="headerSection"/>
   </attach>
</mail>
OR
   <foreach>
     <attach format="pdf" name="report.pdf" srcType="report" instance="this">
     </attach>
   </foreach>
</mail>
Required/Optional
Optional. You can have as many mail elements as you require.
Description
Use the mail element to specify distributions via an outgoing SMTP-based mail server. Use it to specify the recipients, the subject, and the priority of the e-mail.
The mail element has three sub-elements:
Between an open and close mail element, there can be only one body sub-element and anywhere from zero to multiple attach and foreach sub-elements.
The mail element also has a set of related attributes. These are expressed within the mail tag. For example, the id, to, and subject attributes are expressed:
<mail id="a1" to="jsmith@foo.com" subject="Recent Hires">
Table 15-1 lists and describes the attributes associated with the mail element.
Table 15-1 Attributes of the mail element
Attribute Valid values Description
id
string
Required. A keyword, unique within a given distribution XML file, that identifies a particular mail element. This can be a combination of a text string and one or more numbers, for example id="a1". The id value must always start with an alpha character.
to
string
Required. Variable values allowed. The recipient(s) of the e-mail. Contains the full, formal e-mail address, for example:
to="jsmith@foo.com"
Multiple recipients must be separated with commas.
Can also contain variable values that reference columns used in the associated report. See Section 15.2.2 for more information.
cc
string
Optional. Variable values allowed. The recipient(s) to receive a copy of the e-mail.
bcc
string
Optional. Variable values allowed. The recipient(s) to receive a blind copy of the e-mail.
from
string
Optional. Variable values allowed. The sender of the e-mail.
replyTo
string
Optional. Variable values allowed. The e-mail account where replies should be sent.
subject
string
Default: Mail Sent from &amp;Report
Optional. Variable values allowed. The subject of the e-mail. In the absence of a specified subject, the subject line will read: Mail Sent from [Name of Report]
priority
highest|high|normal|low|lowest
Default: normal
The e-mail's delivery priority.
returnReceipt
true|false
Default: false
Indication of whether the replyto individual or account should be notified when the e-mail is received.
organization
string
Optional. Variable values allowed. The name of the organization distributing the e-mail, for example:
organization="Region 10 Sales"
Or
organization="&amp;department_name"
For the mail element to work properly, the Reports Server must know which outgoing SMTP mail server to send mail to. You specify this information in the Reports Server configuration file (server_name.conf). This file has a pluginParam element where you can enter the name of a mail server. For example:
<pluginParam name=mailServer>smtp01.mycorp.com</pluginParam>
For more information, see Configuring OracleAS Reports Services.
15.3.4 body
Example
On Windows
   <body srcType="file">
      <include src="c:\mail\body.html"/>
   </body>
</mail>
On UNIX
      <include src="/mail/body.html"/>
   </body>
</mail>
Required/Optional
Optional. You can have a maximum of one body element associated with a given mail element.
Description
The body element acts as a sub-element to the mail element. It specifies the content (or body) of the e-mail. With body, you can type a text string between the open and close body tag or use an include sub-element to specify either an external file, a report, or a section of a report. For example:
    </body>
Or
        <include src="d:/reports/admin/results.html"/>
    </body>
Or
<mail id="a1" to="&amp;&lt;first_name&gt;.&amp;&lt;last_name&gt;@myco.com"
subject="Quarterly Results">
    <body srcType="report" format="html">
    </body>
Body has three attributes: srcType, format, and instance. They are described in Table 15-2.
Table 15-2 Attributes of the body sub-element of mail
srcType
file|report|text
Default: report
The source for content of an e-mail. The content is displayed in the body of the e-mail. In the absence of a specified srcType, the default is used.
format
html|htmlcss|ascii
Default: html
Required when srcType is report with a format other than html, the default; otherwise format is optional. The format of the content.
instance
this|all
Default: all
Used when the foreach element is also present. With a grouped report that is burst into separate reports, instance specifies whether the groups will be broken into separate content according to each group instance (this) or all contained within the same content (all).
15.3.5 attach
Example
    </body>
    <foreach>
        <attach format="html" name="contacts.htm" srcType="report"
        instance="all">
        </attach>
    </foreach>
</mail>
Required/Optional
Optional. You can have as many attach elements as you require with a mail element. Note that attach is also a sub-element of foreach, and foreach requires that at least one of its sub-elements be used (out of mail,file,printer,destype,and attach).
Description
Attach specifies attachments to the e-mail. Additionally, attach must have at least one include sub-element, and can have more than one if srcType="report". Attach attributes are listed and described in Table 15-3.
Table 15-3 Attributes of the attach sub-element of mail
format
pdf|html|htmlcss|rtf|
ascii|xml|dflt
Default: pdf
Required when srcType is report and the report format is other than pdf, the default; otherwise format is optional. The format of the attached material, for example format="htmlcss".
name
string
Optional. Variable values allowed. The filename of the attached material. Can also contain variable values that reference columns used in the associated report. See Section 15.2.2 for more information.
srcType
file|report|text
Default: report
The source of the attachment, either a file, a report, or text.
instance
this|all
Default: all
Using these attributes in conjunction with the foreach element, you can design a destination that will repeat on a group instance and generate an e-mail for each group attachment. For example:
<foreach>
     <mail id="a2" to="first.name@myco.com,second.name@myco.com,
     third.name@myco.com, fourth.name@myco.com" subject="Department Summaries">
           Attached is the breakdown of department summaries for the last
           quarter.
        </body>
        <attach format="htmlcss" name="deptsum.html" srcType="report"
        instance="this">
             <include src="report"/>
           </attach>
       </mail>
</foreach>
By moving the location of the foreach element, you can generate one e-mail with multiple attachments: a separate one for each group instance.
<mail id="a2" to="first.name@myco.com,second.name@myco.com, third.name@myco.com,
           quarter.
    </body>
    <foreach>
        instance="this">
        </attach>
    </foreach>
</mail>
15.3.6 include
Example
<mail id="a1" to="jsmith@foo.com" subject="Q4">
    </body>
    <attach srcType="report" format="pdf">
    </attach>
</mail>
Or
    </body>
    <attach srcType="report" format="htmlcss">
    </attach>
</mail>
Or
    </body>
    <attach srcType="file">
        <include src="d:/management/reports/current/Q4.htm"/>
    </attach>
</mail>
Required/Optional
Required when used with body and attach when srcType is report or file, but not when srcType is text. Also required for file, printer, and destype. In the instances where it is required, you must have one and can have more than one includes.
Description
The include element is available for use with the body, attach, file, printer, and destype elements. It specifies the file, report, or report section to be included in the body of an e-mail, as an attachment to an e-mail, in the content of a file, in the printer output, or in the content of a custom destination type.
If you want to specify more than one section, but not the entire report, enter an include for each required section. For example:
    </body>
    </attach>
</mail>
If the preceding body or attach element has srcType of file, the subsequent include can specify the file either with a directory path and filename or with just the filename, provided the file is located in a directory listed in the REPORTS_PATH environment variable. For example:
<mail id="a1" to="jsmith@foo.com">
        <include src="q4sales.pdf"/>
      </body>
</mail>
If you do specify a path, use the appropriate standard for your platform. For example:
On Windows:
<include src="c:\management\reports\current\Q4.htm"/>
On UNIX:
<include src="/management/reports/current/Q4.htm"/>
No other XML elements are placed between an include element's open and close tags; however, include does have one attribute: src, described in Table 15-4.
Table 15-4 Attributes of the include sub-element when used with mail's body or attach
src
(path and) filename
report
headerSection
mainSection
trailerSection
Required. The source of material specified in the preceding attach, body, file, printer, or destype element.
Because the distribution XML file is called when you run a specific report, there is no need to specify the report's name or location in the src attribute when src="report".
When the preceding body or attach element specifies a file srcType, provide the directory path and filename or just a filename, provided the file is located in a directory listed in the REPORTS_PATH environment variable.
When the preceding body or attach element specifies a report srcType, specify the entire report (report) or provide the section(s) of the report to be included in the body or to be attached (e.g., headerSection,mainSection, and/or trailerSection).
15.3.7 file
Example
On Windows
<file id="a7" name="c:\management\reports\report.pdf"
format="pdf">
</file>
On UNIX
<file id="a7" name="/management/reports/report.pdf" format="pdf">
</file>
Or
<foreach>
     <file id="a7" name="section&amp;&lt;department_id&gt;.pdf" format="pdf"
     instance="this">
     </file>
</foreach>
Required/Optional
Optional. You can have as many file elements as you require.
Description
Use the file element to specify distributions to a file. File elements have one sub-element: include. There must be at least one include sub-element and there may be more between an open and close file element.
When used with the foreach element and the instance="this" attribute, the file element can distribute each group instance of a grouped report to separate files. For example, if you group a report on department_id, and there are four departments, you can use the foreach/file/instance="this" combination to generate four files, each with a separate department's report. In this case, the file entry in the distribution XML file might look like this:
<foreach>
<file id="a3" name="dept_&amp;&lt;department_id&gt;.pdf" format="pdf"
instance="this">
<include="report"/>
</file>
</foreach>
In this example, all report sections (header, main, and trailer) must repeat on the same group instance (e.g., department_id).
File elements also have a set of related attributes. These are expressed within the file tag. For example, the "id" and "name" file attributes are expressed:
Windows:
<file id="a7" name="d:\reports\2001\q4sales.pdf">
UNIX:
<file id="a7" name="/reports/2001/q4sales.pdf">
Table 15-5 lists and describes the attributes associated with a file element.
Table 15-5 Attributes of the file element
id
string
Required. A keyword, unique within a given distribution XML file, that identifies a particular file element. This can be a combination of a text string and one or more numbers, for example id="a1". The id value must always start with an alpha character.
name
string
Required. Variable values allowed. The location and filename of the destination file. Enter a directory path. Include the filename. For example:
Windows: name="d:\reports\file.pdf"
UNIX: name="reports/file.pdf
format
pdf|html|htmlcss|rtf|ascii|xml|bitmap
Default: pdf
The destination file format, for example:
format="htmlcss"
instance
this|all
Default: all
Used when the foreach element is also present. With a grouped report that is burst into separate reports, instance specifies whether the groups will be broken into separate files according to each group instance (this) or all contained within the same file (all).
15.3.8 printer
Example
On Windows
<printer id="a1" name="\\server_name\printer_name" copies="5">
</printer>
On UNIX
<printer id="a1" name="alias_to_registered_printer" copies="5" instance="all">
</printer>
Required/Optional
Optional. You can have as many printer elements as you require.
Description
Use the printer element to specify distributions to a printer. Printer elements have one sub-element: include. There must be at least one include sub-element and there may be more between an open and close printer element.
When used with the foreach element and the instance="this" attribute, the printer element can distribute each group instance of a grouped report to a separate print job. For example, if you group a report on department_id, and there are four departments, you can use the foreach/printer/instance="this" combination to generate four printed reports, each containing a separate department's report. In this case, the printer entry in the distribution XML file might look like this:
<foreach>
    <printer id="a7" name="\\server_name\printer_name" instance="this">
         <include="report"/>
    </printer>
</foreach>
Table 15-6 lists and describes the attributes associated with a printer element.
Table 15-6 Attributes of the printer element
id
string
name
string
Required. Variable values allowed. The destination printer. How you enter this information differs between Windows and UNIX.
For Windows, specify the printer server name and the printer name. For example:
For UNIX, specify the alias assigned to a registered printer. For example:
name="sales_printer"
copies
string
Default: 1
Number of copies of each report or each report group instance to print.
instance
this|all
Default: all
Used when the foreach element is also present. With a grouped report that is burst into separate reports, instance specifies whether the groups will be broken into separate printed reports according to each group instance (this) or all contained within the same printed report (all).
15.3.9 destype
Example
<destype id="acustom1" name="fax">
     <property name="number" value="914925551212"/>
</destype>
Required/Optional
Optional. You can have as many destype elements as you require.
Description
Use the destype element to specify distribution to a custom destination, such as to a fax machine or an FTP site. You also use destype to specify distribution to a portal created with OracleAS Portal. The destype element allows for the use of two sub-elements: property and include. At least one include is required.
The inclusion of a custom destination type requires that you have a defined distribution handler in place to usher report content to the custom output destination.
Build a custom destination type via the OracleAS Reports Services Destinations API. Look for upcoming information about Reports APIs on the Oracle Technology Network, (http://otn.oracle.com).
When used with the foreach element and the instance="this" attribute, the destype element can distribute each group instance of a grouped report to a separate destype instance (e.g., a separate fax). For example, if you group a report on department_id, and there are four departments, you can use the foreach/printer/instance="this" combination to generate four destype instances, each containing a separate department's report. In this case, the destype entry in the distribution XML file might look like this:
<foreach>
     <destype id="a9" name="fax" instance="this">
        <include="report"/>
        <property name="number" value="&amp;&lt;fax_number&gt;"/>
     </destype>
</foreach>
Custom destination types also have a set of related attributes. These are expressed within the destype tag. For example, the "id", "name", and "instance" destype attributes are expressed:
<foreach>
     <destype id="a1" name="name_of_destination_type" instance="all">
</foreach>
Table 15-7 lists and describes the attributes associated with a destype element.
Table 15-7 Attributes of the destype element
id
string
name
string
Required. The name of the custom destination. For example, for a fax, this might be:
name="fax"
For a portal built with OracleAS Portal:
name="oraclePortal"
instance
this|all
Default: all
Used when the foreach element is also present. With a grouped report that is burst into separate reports, instance specifies whether the groups will be broken into separate destype instances according to each group instance (this) or all contained within the same destype instance (all).
For example, if you custom destination type is a fax, instance="this" would mean a separate fax for each group instance, and instance="all" would mean one fax for all groups.
OracleAS Reports Services supports the creation and use of custom destination types (pluggable destinations) in the Reports Services environment. One way it does this is by allowing you to include calls to custom destinations in your distribution XML file. The distribution XML file provides a way to define custom destinations through property name/value pairs used in conjunction with the destype element.
15.3.10 property
Example
<foreach>
    <destype id="custom1" name="fax" instance="all">
  </destype>
</foreach>
Required/Optional
Optional. You can have as many properties as you require under a destype element.
Description
The property element allows for the inclusion of name/value pairs expressed in terms recognized by a custom destination type (destype). Properties are merely passed along to the destination handler. They serve no function within Reports Services. How you specify properties is entirely dependent on the requirements of your custom destination.
15.4 Distribution XML File Examples
This section provides examples, from simple to complex, of distribution XML elements. They are organized according to the main distribution.dtd elements:
15.4.1 foreach Examples
The examples in this section include:
15.4.1.1 Single E-Mail with Report Groups as Separate Attachments
In this example, each attachment contains the corresponding instance from the header, main, and trailer sections. That is, if the report is grouped on department_id, and the first department is department 10, the first attachment will be a report with header, main, and trailer sections all containing department 10 information. This example is valid only if the header, main, and trailer sections repeat on the same group instance, in this case department_id.
<mail id="a1" to="managers@mycompany.com" subject="New Hires">
    <foreach>
        <attach format="html" srcType="report" instance="this">
        </attach>
    </foreach>
</mail>
First of all, assume in this example that "managers@mycompany.com" goes to a mailing list that distributes to each department manager. If there are four departments: 10, 20, 30, and 40, the first attachment will contain header, main, and trailer sections corresponding to department 10; the second to 20; and so on. This example will yield one e-mail per recipient, each with four attachments.
15.4.1.2 Separate E-Mail for Each Group Instance
In this example, each recipient will receive a separate e-mail for each grouped report. For example, if the report is grouped on department_id, and there are four departments, one recipient will receive four e-mails, each with a separate department's report attached.
<foreach>
    <mail id="weeklies" to="managers@mycompany.com">
        <attach format="htmlcss" srcType="report" instance="this">
        </attach>
    </mail>
</foreach>
15.4.1.3 Separate E-Mails with Separate Sections as Attachments
In this example, different sections repeat on different groups. The distribution is set up so that each recipient will receive a separate e-mail with attachment for each grouped main section and for each grouped trailer section.
<foreach>
    <mail id="a6" to="managers@mycompany.com" subject="Personnel Reports">
        <attach format="pdf" name="attach.pdf" srcType="report" instance="this">
        </attach>
        <attach format="rtf" name="attach.rtf" srcType="report" instance="this">
           <include src="trailerSection"/>
        </attach>
    </mail>
</foreach>
15.4.1.4 Separate File for Each Section
In this example, a separate file is generated for each group instance. Groups repeat on department_id. Each file is named with the relevant department ID.
<foreach>
     <file id="a10" name="department_&amp;&lt;department_id&gt;.pdf"
     instance="this">
     </file>
</foreach>
Assuming that there are four departments, 10 through 40, this example will result in the creation of four files, named in turn department_10.pdf, department_20.pdf, and so on.
The format attribute is not included in the file element because it is not required when the srcType is file or text. It is required when the srcType is report.
If you do not specify unique filenames through the use of variable values (see Section 15.2.2), in this example, each successively created file will overwrite the previously created file. That is, the department.pdf file for department 20 will overwrite the department.pdf file for department 10, and so on, until there is only one file left, department.pdf, with information from the last department report created (e.g., department 40).
15.4.1.5 Separate Print Run for Each Report
The way you specify a printer name differs between Windows and UNIX. The first example is for Windows. The second is for UNIX.
15.4.1.5.1 Windows
In this example, assuming that the report is grouped on department_id, a report will be printed for each department.
<foreach>
     </printer>
</foreach>
15.4.1.5.2 UNIX
<foreach>
    <printer id="a7" name="printer_alias" instance="this">
    </printer>
</foreach>
15.4.2 mail Examples
15.4.2.1 E-Mail with a Whole Report as the Body
The report will comprise the content of this e-mail. That is, when recipients open this e-mail, they will see the report.
<mail id="a5" to="managers@mycompany.com" subject="Quarterly Report">
    </body>
</mail>
15.4.2.2 E-Mail with a Section of a Report as the Body
A section of a report will comprise the content of this e-mail. That is, when recipients open this e-mail, they will see a section of the report.
<mail id="a6" to="employees@mycompany.com">
     </body>
</mail>
The subject attribute is not included in this mail element, so the default subject will be used: Mail Sent From &amp;Report. At runtime, the variable &amp;Report will be replaced with the name of the report.
15.4.2.3 E-Mail with Two Report Sections as the Body
Two sections of a report will comprise the body of this e-mail. That is, when recipients open this e-mail, they'll see two sections, headerSection and mainSection, joined together in one report.
<mail id="emp_addresses" to="employees@mycompany.com" subject="Employee Address
List">
    </body>
</mail>
15.4.2.4 E-Mail with External File as Body and Report as Attachment
The contents of the body for this email will be an external file, and the report will go along as an attachment. The path to the file is expressed differently for Windows and UNIX.
15.4.2.4.1 Windows
<mail id="XQRSN" to="accounting@mycompany.com" subject="Salaries"
    </body>
    <attach format="pdf" name="salaries.pdf" srcType="report">
    </attach>
</mail>
15.4.2.4.2 UNIX
     </body>
    </attach>
</mail>
15.4.2.5 E-Mail with Whole Report and Grouped Sections Attached
In this example, recipients receive one e-mail with multiple attachments: one attachment for each group instance and an additional attachment that contains the entire report. If the report is grouped on department_id and there are four departments, recipients will receive five attachments: one for each department and one whole report.
<mail id="grx90" to="sales@mycompany.com">
    Attached you will find the summary report and breakdown by department of
    weekly totals.
    </body>
    <attach format="rtf" name="myAttach.rtf" srcType="report">
    </attach>
    <foreach>
       <attach format="pdf" name="myattach.pdf" srcType="report"
       instance="this">
        </attach>
     </foreach>
</mail>
15.4.2.6 E-Mail to Relevant Manager and Department
In this example, the manager for department 10 gets department 10's report; the manager for department 20 gets department 20's report; and so on. For this tag set to be valid, the variable must refer to a column that is included in the "repeat on" group used with the attached section. That is, if the section repeats on G_department_id, manager must be a column in that group.
<foreach>
    <mail id="mgr1090" to="&amp;&lt;manager&gt;@mycompany.com">
        </attach>
    </mail>
</foreach>
15.4.3 file Examples
Whenever you burst and distribute grouped reports to files, be sure to specify filenames with variable values based on the repeating group or some other variable information. Otherwise, you run the risk of having each successive file that is created overwrite the previously created file. For example, if you specify an output filename of department.pdf, and you output separate instances of each department's report, the second department.pdf file will overwrite the first department.pdf file; the third will overwrite the second; an so on. You will end up with only one report, that of the final department to be output. Instead, with grouped reports that you want to output separately according to each group instance, use variable values to specify filenames, for example: name="department_&amp;&lt;department_id&gt;.pdf".
15.4.3.1 File for Whole Report
This example will yield one file named report.pdf that contains the entire report.
15.4.3.1.1 Windows
<file id="a1" name="c:\reports\report.pdf" format="pdf">
</file>
15.4.3.1.2 UNIX
<file id="a1" name="/reports/report.pdf" format="pdf">
</file>
15.4.3.2 File for Combined Report Sections
This example will yield one file named sections.pdf that contains a report consisting of the header section and the main section of the report.
<file id="a2" name="sections.pdf" format="pdf">
      <include="headerSection"/>
       <include="mainSection"/>
</file>
15.4.3.3 File for Each Group of Combined Sections
In this example, a separate file will be created for each repeating group. Each file will contain a report that combines the relevant group main and trailer sections. The main and trailer sections must repeat on the same group, and the variable file name must refer to a column contained within the "repeat on" group. That is, if the report repeats on department_id, and you have four departments, 10 through 40, then one file will contain the main and trailer sections of department 10; the next will contain the main and trailer sections of department 20; and so on. The variable value under name must refer to a column that is within the G_department_id group.
<foreach>
     <file id="file9" name="department_&amp;&lt;department_id&gt;.pdf"
     instance="this">
     </file>
</foreach>
15.4.3.4 File for Each Report Group Instance
In this example, assuming the report is grouped on department_id and there are four departments, 10 through 40, you will end up with four files respectively named: department_10.pdf, department_20.pdf, department_30.pdf, and department_40.pdf.
<foreach>
     <file id="a20" name="department_&amp;&lt;department_id&gt;.pdf"
     instance="this">
     </file>
</foreach>
15.4.4 printer Examples
The way printer names are specified, differs between Windows and UNIX. Each example demonstrates both ways.
15.4.4.1 Print Whole Report
In this example, the entire report will be sent to the specified printer.
15.4.4.1.1 Windows
<printer id="a80" name="\\neptune\prtr20">
</printer>
15.4.4.1.2 UNIX
<printer id="a80" name="10th_floor_printer">
</printer>
15.4.4.2 Print Two Sections of a Report
In this example, two sections of a report will be sent to the printer.
15.4.4.2.1 Windows
<printer id="a1" name="\\neptune\prtr20">
</printer>
15.4.4.2.2 UNIX
<printer id="a1" name="10th_floor_printer">
</printer>
15.4.4.3 Print Grouped Report
In this example, one report will be printed. The report will be grouped by, for example, department_id. For this to work, all sections of the report must repeat on the same group.
15.4.4.3.1 Windows
<foreach>
    <printer id="prt20" name="\\neptune\prtr20" instance="all">
    </printer>
</foreach>
15.4.4.3.2 UNIX
<foreach>
    <printer id="prt20" name="10th_floor_printer" instance="all">
    </printer>
</foreach>
15.4.4.4 Print Combined Sections for Each Group Instance
This example will yield a number of print jobs: one for each group instance. The combined sections must repeat on the same group. If the report repeats on department_id, and you have four departments, 10 through 40, you will end up with four print jobs: one for department 10; one for department 20; and so on. The main and trailer sections must both repeat on department_id.
15.4.4.4.1 Windows
<foreach>
    <printer id="prt20" name="\\neptune\prtr20" instance="this">
    </printer>
</foreach>
15.4.4.4.2 UNIX
<foreach>
     <printer id="prt20" name="10th_floor_printer" instance="this">
     </printer>
</foreach>
15.4.4.5 Print Relevant Instance of a Report to Its Relevant Printer
For this example to work, the repeat on group must contain a column of printer names appropriate to the host platform (e.g., the printer_name column must contain an appropriate printer alias on UNIX and a printer server/name combination on Windows). For example, if the report is grouped by department_id, then G_department_id must also have a printer_name column. Assuming the printer_names are tied to departments, then department 10's report would be printed on department 10's printer; department 20's report would be printed on department 20's printer; and so on.
<foreach>
    <printer id="a60" name="&amp;printer_name" instance="this">
    </printer>
</foreach>
Each group instance equals a separate print job. Each print job goes to the relevant department's printer
15.5 Using a Distribution XML File at Runtime
The method for using a distribution XML file at runtime is essentially the same whether you use it in a URL or a command line. Use the commands:
distribute=yes destination=filename.xml
Where filename is the name of the distribution XML file. You are required to specify either the relative or absolute path of the XML file. For example, for Windows, you might specify:
distribute=yes destination=c:\ORACLE_HOME\reports\distribution\filename.xml
For UNIX, you might specify:
distribute=yes destination=ORACLE_HOME/reports/distribution/filename.xml
The paths in these examples are used for illustrative purposes only. There is no requirement for where you store your distribution XML files. You can store them wherever you like.
In some cases, Microsoft Internet Explorer ignores the mimetype of a URL's return stream and instead sets the type by looking at the URL. This can be a problem when you are using the distribution feature of OracleAS Reports Services because your URL might end with the destination parameter, for example:
...distribute=yes destination=c:\oracle\reports\distribution\mydist.xml
In this scenario, your URL ends with the extension .xml and Internet Explorer treats the return stream as XML, when in fact it is HTML. As a result, you will receive a browser error. To work around this issue, you should never use recognized file extensions at the end of a URL. In the example above, you could switch the positions of the distribute and destination parameters in your URL.
For detailed information on running reports from command lines and URLs and using the cgicmd.dat file, see Chapter 13, "Running Report Requests".
15.6 Defining Custom/Pluggable Destinations
You can define a custom pluggable destination that can be used by Oracle Reports during distribution. The following examples illustrate the outlined destinations:
Fax destination
You can specify the destination as per the generic tag structure in the distribution XML file as follows:
Example 15-1 Generic Fax Destination
<destype id="faxdest" name="fax">
     <property name="number" value="123456789"/>
</destype>
oraclePortal Destination
You can specify the destination as per the generic tag structure in the distribution XML file as outlined in Example 15-2.
Example 15-2 illustrates a sample structure for DESTYPE=ORACLEPORTAL. When you push a report output to Portal using DESTYPE=ORACLEPORTAL, the report output will be created in the PAGEGROUP folder.
See Also:
Command Line Options
For more information on the properties outlined in the examples.
Example 15-2 Simple Portal Destination
<destinations>
    <destype id="customforPortal" name="oraclePortal">
       <property name="outputpage" value="sample_report"/>
       <property name="statuspage" value="Reports_Status"/>
       <property name="desformat" value="pdf"/>
       <property name="pagegroup" value="REPORTS_OUTPUT"/>
       <property name="itemtitle" value="MyReport"/>
    </destype>
</destinations>
You can specify the custom destination in accordance with the generic destype tag structure for a pluggable destination. Alternatively, for ease of use, you can specify a custom, more specific tag structure.
Refer to destype=oraclePortal for more information on the limitation with using the oraclePortal destination.
Example 15-3 Custom Fax Destination
<fax id="faxdest" number="123456789">
</fax>
These tags are unknown to the distribution.dtd, therefore, they need to be mapped to the generic destype tag structure specified in the distribution.dtd.
Reports runtime cannot process the <fax> tag structure as illustrated here because the <fax> tag is not a standard destination specified in the distribution.dtd file. The custom tag structure must therefore be converted to the generic format as shown in Example 15-1.
Use the distribution.xsl file to transform user-defined custom tags in the distribution XML file to a format required by Reports runtime. Reports can understand only the generic destype tag structure for any pluggable destination.
The distribution.xsl file is an XML style sheet, located on both Windows and UNIX at ORACLE_HOME\reports\conf\distribution.xsl. You can modify this file by adding a template for translating your destype tag format to the required format defined in the distribution.dtd file.
To achieve this, you must specify a template for the fax destination in the distribution.xsl file. The template will be used to convert the <fax> tag structure to the generic destype structure. Your distribution.xsl entry might look like this:
<xsl:output doctype-system="distribution.dtd"/>
<xsl:template match = "/">
    <xsl:apply-templates match = "destinations" />
</xsl:template>
<xsl:template match="destinations">
    <destinations>
    The Standard mail/file/printer/destype and foreach must be copied to the
    transformed xml. The foreach tag must be copied only if it is specified with
    file/mail/printer/destype tags.
        <xsl:copy-of select="mail"/>
        <xsl:copy-of select="file"/>
        <xsl:copy-of select="printer"/>
        <xsl:copy-of select="destype"/>
        <xsl:copy-of select="foreach"/>
        <!-- apply template for the sample FAX destination -->
        <xsl:apply-templates match = "fax" />
    </destinations>
</xsl:template>
     Sample Transformation Template for a FAX destination specified in the
     distribution.xml file
    <fax id="FAXDEST" number="123456789">
    </fax>
<xsl:template match="fax">
    <!-- create a new destype element -->
    <xsl:element name="destype">
        create an ID attribute and copy the value from the ID given for the fax
        destination
    <xsl:attribute name="id">
        <xsl:value-of select="@id"/>
    </xsl:attribute>
    <!-- create a Name attribute with a fax as it's value -->
    <xsl:attribute name="name">fax</xsl:attribute>
    create a Property Attribute with name / value attribute pairs property tag
    is created for number attribute. Similarly create more property tags for any
    other attribute you add to the FAX destination
<xsl:element name="property">
        <xsl:attribute name="name">number</xsl:attribute>
        <xsl:attribute name="value">
           <xsl:value-of select="@number"/>
        </xsl:attribute>
</xsl:element>
        <!-- copy the include tag as it is -->
        <xsl:copy-of select="include"/>
    </xsl:element>
    <!-- end of template -->
</xsl:template>
</xsl:stylesheet>
All you need to do after you modify the XSL file is save it back to the same location under the same file name. Reports will automatically look for this XSL file when resolving distributions.
15.7 Limitations with using distribution
15.7.1 destype=oraclePortal
From Oracle9i Reports Release 2 (9.0.2) onwards, Reports Server supports OracleAS Portal as a destination. By using DESTYPE=ORACLEPORTAL, you can push a report to an output page specified in OracleAS Portal.
See Also:
Command Line Options and the Reports Builder Online Help for more information on the DESTYPE command line keyword.
However, there are a few limitations in using this destination:
15.7.2 XML and delimited outputs
Using reference parameters for report bursting (i.e., by specifying instance=this) is not supported for DESFORMAT=XML and DESFORMAT=DELIMITED. If used, it results in the following error message:
REP-34310 "Reference parameter not allowed in distribution list for XML
destination files"
However, these formats can be used in distribution without specifying a reference parameter.
Oracle
Copyright © 2003 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
