| Oracle9i Installation Guide Release 2 (9.2.0.2) for hp OpenVMS Alpha Part Number B10508-01 |
This appendix lists the procedure and steps to install and configure Apache Server for HP OpenVMS Alpha. The following topics are included:
After you configure the Oracle HTTP Server, perform the following tasks to ensure a successful startup:
Each of these tasks is explained below. Once you have completed them, you can test the installation by starting the Oracle HTTP Server.
After the installation, run SYS$UPDATE:AUTOGEN.COM (AUTOGEN) to evaluate your system parameters and make adjustments based on your hardware configuration and system workload. On the Oracle HTTP Server for OpenVMS, AUTOGEN will probably increase the page file size and the number of swap file pages.
If the disk quota is too low, the Oracle HTTP Server will not start. Either raise the disk quota for the user account ORACLE, or grant the account the EXQUOTA privilege, thus allowing it to bypass disk quota restrictions. Use the following commands:
$ SHOW QUOTA/USER=[server-uic]/DISK=device-name $ SET PROCESS/PRIVILEGES=EXQUOTA node-name::ORACLE
When the Oracle HTTP Server for OpenVMS is started, the following login files are executed:
Check these files to make sure that any SET TERMINAL/INQUIRE statements are executed only in INTERACTIVE mode. For example:
$ IF F$MODE() .eqs "INTERACTIVE" then $ SET TERMINAL/INQUIRE
Failure to do so might result in ill-formed HTML intermittently being returned to clients. This problem might also appear when executing CGI scripts.
Now you will manually start the Oracle HTTP Server to verify the installation and configuration of the server. Enter the following command:
$APACHECTL START
You can test the installation using your web browser. Replace host.domain in the following URL with the information for the Oracle HTTP Server you just installed:
HTTP://host.domain:<port>
If this is a new installation, the browser should display the standard introductory page with the following bold text at the top:
"If you see this, it means that the installation of the Apache web server software on this system successful."
The Apache logo is displayed at the bottom.
You can also use TELNET on the local host to test the installation. Use the following procedure:
$ TELNET 0 80
The following text is displayed:
%TELNET-I-TRYING, Trying ... 127.0.0.1 %TELNET-I-SESSION, Session 01, host localhost, port 80 -TELNET-I-ESCAPE, Escape character is ^]
HEAD / HTTP/1.0
Text similar to the following is displayed:
HTTP/1.1 200 OK Date: Tue, 23 May 2000 17:05:05 GMT Server: Apache/1.3.12 (OpenVMS) Last-Modified: Mon, 22 May 2000 15:33:27 GMT ETag: "33dfec-681-39295347" Accept-Ranges: bytes Content-Length: 1665 Connection: close Content-Type: text/html %TELNET-S-REMCLOSED, Remote connection closed -TELNET-I-SESSION, Session 01, host localhost, port 80
If you do not receive a response from the Oracle HTTP Server, check the following:
APACHE$ROOT:[000000]APACHE$SERVER.LOG APACHE$ROOT:[LOGS]ERROR_LOG
To startup the Oracle HTTP Server, enter the following command:
$ APACHECTL startup
To stop the Oracle HTTP Server, enter the following command:
$ APACHECTL stop
The server log file for APACHE$WWW is written to:
APACHE$SPECIFIC:[000000]APACHE$SERVER.LOG
You should have prior experience tuning the performance of the OpenVMS operating system. For general information on OpenVMS performance, see the OpenVMS Performance Management Manual at the following URL:
http://www.openvms.compaq.com:8000/73final/6491/6491pro.html
Recommendations for improving performance on a Oracle HTTP Server are provided below and in the Release Notes:
The following table shows sample values for the ORACLE Account from a working and exercised Oracle HTTP Server with a light to moderate load. These values are presented as an example of a system performing well within its context. If you should experience performance difficulties, refer to this table for guidelines in making adjustments. For heavier loads, we point out which values, in our experience, need to be increased as load increases. Keep in mind that no one set of values will be appropriate for all situations.
To change the quotas for the Oracle Account SYSUAF, use the system manager account and run the AUTHORIZE utility. For example:
$ SET DEFAULT SYS$SYSTEM $ RUN AUTHORIZE UAF> SHOW ORACLE Username: ORACLE Owner: APACHE WEBSERVER ... Maxjobs: 0 Fillm: 100 Bytlm: 64000 Maxacctjobs: 0 Shrfillm: 0 Pbytlm: 0 Prclm: 8 DIOlm: 150 WSdef: 2000 ... UAF> MODIFY ORACLE/FILLM=300/PRCLM=20 %UAF-I-MDFYMSG, user record(s) updated UAF> EXIT $
After you install the server and have been running it, look in the log file for errors of the "cannot open" variety. Errors of this type often indicate you need to modify system parameters. Try the following:
If a browser installation stalls, then this could be an indication that the number of global pages or global sections is too low. Run AUTOGEN to evaluate the number of global pages and global sections that you need. Some browsers might need more.
A large number of .LOG and .PID files can amass over time in the directories APACHE$ROOT:[0000000] and APACHE$ROOT:[LOGS]. Purging these files can become a burden on application or system managers.
System managers should manually use explicit SET DIRECTORY/VERSION commands on these two directories.
The installation procedure creates a file named HTTPD.CONF and places it in APACHE$ROOT:[CONF]. The HTTPD.CONF file stores information that the Oracle HTTP Server uses to set up the server environment. HTTPD.CONF has been tailored to use OpenVMS syntax, but its overall functionality is essentially identical to HTTPD.CONF on the UNIX platform.
HTTPD.CONF contains an explanation for each line that it can execute. You can refer to these explanations when customizing the file for your environment. You can also refer to any generally available Apache documentation on HTTPD.CONF.
Note the following about HTTPD.CONF on OpenVMS:
Perform the following steps to configure Apache to run while using an account other than the 'oracle' account:
User <username>
username. Make sure that the username is exactly the same as the entry in the httpd.conf file.
Following is a list of the modules included in the Oracle HTTP Server for OpenVMS distribution kit. The list shows the directives supported in each module. All supported modules and directives function as documented by the Apache Software Foundation at the following web site:
HTTP_CORE.C
AccessConfig
AccessFileName
AllowOverride
AuthName
AuthType
BindAddress
CoreDumpDirectory
DefaultType
<Directory>
<DirectoryMatch>
DocumentRoot
ErrorDocument
ErrorLog
<Files>
<FilesMatch>
HostnameLookups
IdentityCheck
<IfDefine>
<IfModule>
Include
KeepAlive
KeepAliveTimeout
<Limit>
<LimitExcept>
LimitRequestBody
LimitRequestFields
LimitRequestLine
Listen
ListenBacklog
<Location>
<LocationMatch>
LogLevel
MaxClients
MaxKeepAliveRequests
MaxRequestPerChild
MaxSpareServers
MinSpareServers
NameVirtualHost
Options
PidFile
Port
Require
ResourceConfig
RLimitCPU
RLimitMEM
RLimitNPROC
Satisfy
SendBufferSize
ServerAdmin
ServerAlias
ServerName
ServerPath
ServerRoot
ServerSignature
ServerTokens
ServerType
StartServers
TimeOut
UseCanonicalName
User
VirtualHost
MOD_ACCESS.C
MOD_ACTIONS.C
MOD_ALIAS.C
MOD_ASIS.C
MOD_AUTH.C
MOD_AUTOINDEX.C
AddAlt
AddAltByEncoding
AddAltyByType
AddDescription
AddIcon
AddIconByEncoding
AddIconByType
DefaultIcon
FancyIndexing
HeaderName
IndexIgnore
IndexOptions
IndexOrderDefault
ReadmeName
MOD_CGI.C
MOD_DIR.C
MOD_ENV.C
MOD_IMAP.C
MOD_INCLUDE.C
MOD_INFO.C
MOD_LOG_CONFIG.C
MOD_MIME.C
AddCharset
AddEncoding
AddHandler
AddLanguage
AddType
DefaultLanguage
ForceType
RemoveHandler
SetHandler
TypesConfig
MOD_NEGOTIATION.C
MOD_SETENVIF.C
MOD_SO.C
MOD_STATUS.C
MOD_UNIQUE_ID.C
MOD_USERDIR.C
The server documentation from the Apache Software Foundation at the following web site:
provides most of the information needed to run your Oracle HTTP Server for OpenVMS. Information specific to the OpenVMS operating system is provided below.
The following modules are not included in this version of the Oracle HTTP Server for OpenVMS kit:
MOD_AUTH_ANON
MOD_AUTH_DB
MOD_AUTH_DBM
MOD_AUTH_DIGEST
MOD_CERN_META
MOD_DIGEST
MOD_EXAMPLE
MOD_EXPIRES
MOD_HEADERS
MOD_ISAPI
MOD_JSERVE
MOD_LOG_AGENT
MOD_LOG_REFERER
MOD_MIME_MAGIC
MOD_MMAP_STATIC
MOD_PEARL
MOD_PROXY
MOD_REWRITE
MOD_SPELING
MOD_SSL
MOD_USERTRACK
MOD_VHOST_ALIAS
The following directives are not supported:
AgentLog
AllowCONNECT
Anonymous
Anonymous_Authoritative
Anonymous_LogEmail
Anonymous_MustGiveEmail
Anonymous_NoUserID
Anonymous_VerifyEmail
AuthDBAuthoritative
AuthDBGroupFile
AuthDBMAuthoritative
AuthDBMGroupFile
AuthDBUserFile
AuthDBMUserFile
AuthDigestFile
CacheDefaultExpire
CacheDirLength
CachedirLevels
CacheForceCompletion
CacheGcInterval
CacheLastModifiedFactor
CacheMaxExpire
CacheRoot
CacheSize
CheckSpelling
CookieExpires
CookieTracking
Example
ExpiresActive
ExpiresByType
ExpiresDefault
Header
Metadir
MetaFiles
MetaSuffix
MimeMagicFile
MMapFile
NoCache
ProxyBlock
ProxyDomain
ProxyPass
ProxyPassReverse
ProxyReceiveBufferSize
ProxyRemote
ProxyRequests
ProxyVia
RefererIgnore
RefererLog
RewriteBase
RewriteCond
RewriteEngine
RewriteLock
RewriteLog
RewriteLogLevel
RewriteMap
RewriteOptions
RewriteRule
ScriptInterpreterSource
VirtualDocumentRoot
VirtualDocumentRootIP
VirtualScriptAlias
VirtualScriptAliasIP
This section describes the HTTPD command line options supported on the Oracle HTTP Server. Before you can use them you must first define HTTPD as a symbol, as follows:
$ HTTPD :== $APACHE$ROOT:[000000]APACHE_HTTPD.EXE_ALPHA
Then you can use the following format to enter a command line option:
$ HTTPD -option
where -option is one of the following command line options:
-v: Displays the HTTPD version and its build date.
-"V": Displays the HTTPD base version, its build date, and a list of compile settings that influence the behavior and performance of the server.
-h: Displays a list of the HTTPD options.
-l: Displays a list of all modules compiled into the server.
"L": Displays a list of directives with expected arguments and places where the directive is valid.
The following example shows how to enter the L option to list the available configuration directives:
$ HTTPD -"L"
The term virtual host refers to the practice of maintaining a single server to serve pages for multiple virtual hosts. Both IP-based and name-based virtual host support are available on the Oracle HTTP Server for OpenVMS.
For more information, see the Apache Software Foundation documentation at the following web site:
http://www.apache.org/docs/vhosts/index.html
Dynamic shared object support provides a method to format code so that it will load into the address space of an executable program at run time. This functionality is supported on OpenVMS. For more information, see the Apache Software Foundation documentation at the following web site:
http://www.apache.org/docs/dso.html
The Oracle HTTP Server for OpenVMS supports the ability to use file handlers explicitly. For more information, see the Apache Software Foundation documentation at the following web site:
http://www.apache.org/docs/handler.html
The MOD_NEGOTIATION module provides content negotiation. This module lets you specify language variants of HTML files. To specify language variants on OpenVMS, use an underscore instead of a period before the language extension.
For example:
filename.html.fr is the French variant of filename.html.
filename.html_fr is the French variant of filename.html.
http://www.apache.org/docs/content-negotiation.html
You can use the standard Apache API to write your own modules that will run on the Oracle HTTP Server for OpenVMS. For more information, see the Apache Software Foundation documentation at the following web site:
http://www.apache.org/docs/misc/API.html
The suEXEC feature provides the ability to run CGI programs under user IDs different from the user ID of the calling web server. This is not supported by the Oracle HTTP Server for OpenVMS.
All file formats are supported. However, the Web browser status bar will not show page loading progress for logical or VFC format files larger than 8 K.
Page loading progress relies on an accurate byte count. Accurate byte count is not readily available for files in logical or VFC format. For files in these formats, the Oracle HTTP Server must count the bytes as the files load. The counting process can slow performance, so it has been turned off in this situation.
In general, users who are running the Oracle HTTP Server for OpenVMS can specify either UNIX-style file names or OpenVMS-style file names. The Oracle HTTP Server usually displays UNIX-style file names.
The ODS-5 volume structure, introduced in HP OpenVMS Alpha Version 7.2-1, supports long file names, allows the use of a wider range of characters within file names, and preserves case within file names. However, the DEC C RTL that is shipped with HP OpenVMS Alpha Version 7.2-1 does not provide full support for extended file names on ODS-5 devices. This lack of full support imposes certain restrictions on users running the Oracle HTTP Server for HP OpenVMS Alpha.
Because mixed UNIX-style and OpenVMS-style extended file names are not yet supported by the DEC C RTL, you might be required to use UNIX-style syntax when interacting with the Oracle HTTP Server. An example would be appending additional directories or a file name to a root.
The following examples illustrate mixed UNIX-style and OpenVMS-style file names that are not supported in HP OpenVMS Alpha Version 7.2-1:
doc/foo.bar.bar ./tmp/foo.bar.b^_ar ~foo^.bar
You can, however, modify the last example so that it will work as an OpenVMS extended file name that has a tilde (~) as the first character. Precede the leading tilde (~) with the Extended File Specifications escape character (^). For example:
^~foo^.bar
For more information about using the tilde (~) in OpenVMS extended file names, see the OpenVMS Guide to Extended File Specifications at the following web site:
http://caedmon.zko.dec.com/72final/6536/6536pro.html
Mixed UNIX-style and OpenVMS-style file names will be supported in a future release of the DEC C RTL for HP OpenVMS Alpha.
When performing a File Transfer Process (FTP) operation, ensure that the Access Control List (ACL) for the target directory on the Oracle HTTP Server allows FTP access, as follows:
When transferring new files:
$ SET SECURITY/ACL=(IDENTIFIER=yourFTPname,ACCESS=READ+WRITE) [directory]
When replacing existing files:
$ SET SECURITY/ACL=(IDENTIFIER=yourFTPname,ACCESS=READ+WRITE) [directory]*.*
The Oracle HTTP Server for OpenVMS creates the following logical names, which are listed with their descriptions in table Table D-2.
An OpenVMS Cluster is a group of OpenVMS systems that work together as one virtual system. The Oracle HTTP Server runs in an OpenVMS Cluster so you can take advantage of the resource sharing that increases the availability of services and data. Keep the following points in mind:
To define clusterwide versus individual configuration files, APACHE$ROOT uses the following concealed logical names:
When reading a file, the server first looks for a system-specific version of the file in APACHE$SPECIFIC:[directory]. If it does not find one, then it looks for a clusterwide file in APACHE$COMMON:[directory].
To avoid confusion, always use the appropriate concealed logical name to specify the file that you want to edit. For example, to edit a clusterwide version of HTTPD.CONF, refer to:
$ EDIT APACHE$COMMON:[CONF]HTTPD.CONF
If you referred to:
$ EDIT APACHE$ROOT:[CONF]HTTPD.CONF
then the server would open the clusterwide file but save it as a system-specific version. The latest version of HTTPD.CONF would then be visible only to the individual node on which it was saved.
Within HTTPD.CONF itself, you should make this distinction whenever you refer to a path or to a file location. This improves performance and ensures that the server will return a complete directory listing. For example, you should specify APACHE$COMMON or APACHE$SPECIFIC (instead of APACHE$ROOT) with Directory directives.
The following extract, from the HTTPD.CONF file, refers to APACHE$COMMON because the content for the default web page is in the clusterwide directories.
DocumentRoot "/apache$common/htdocs"...<Directory "/apache$common/htdocs">Options Indexes FollowSymLinks Multiviews AllowOverride None Order allow,deny Allow from all</Directory>
If there were content for one specific node in a cluster, the APACHE$SPECIFIC logical name would be used.
In a mixed-architecture cluster, do not use a cluster alias IP address with the Oracle HTTP Server. Because the VAX systems will not have the Oracle HTTP Server running, they will not be able to service HTTP requests.
Common Gateway Interface (CGI) programs execute within the DCL shell on the Oracle HTTP Server for OpenVMS. Please note the following OpenVMS specific information.
By default, an environment logical symbol takes the form that is designated by the name of the environment logical. You can determine how environment logicals are set when the server executes a CGI program.
You can define the APACHE$PREFIX_DCL_CGI_SYMOBLS_WWW logical name to prefix all environment logical symbols with "WWW_". By default, no prefix is used.
The APACHE$CGI_MODE logical name controls how CGI environment logicals are defined in the executing CGI program, as follows:
APACHE$CGI_MODE option
where option can have one of the following values at a time:
0 Default. Environment logicals are defined as local symbols and are truncated at 970 (limitable with DEC C).
1 Environment logicals are defined as local symbols unless they are greater than 970 characters. If the environment value is greater than 970 characters, it is defined as a multi-item logical.
2 Environment logicals are defined as logicals. If the environment value is greater than 512 characters, it is defined as a multi--item logical.
APACHE$DCL_ENV is a foreign symbol that lets you define CGI environment logical, as follows:
APACHE$DCL_ENV [-c] [-d] [-e env-file]
where:
-c Default. Indicates create environment logicals.
-d Indicates delete environment logicals.
-e env-file Specifies an alternate environment file. The environment file does not need to be specified by the caller because the parent derives it (it can be easily determined by default).
The following example deletes the environment and then recreates it:
Example: diff_mode_cgi.com $ APACHE$DCL_ENV -d $ Define APACHE$PREFIX_DCL_CGI_SYMBOLS_WWW 1 $ APACHE$DCL_ENV -c
CGI scripts that reference input to the Oracle HTTP Server must refer to APACHE$INPUT.
On OpenVMS, CGI images execute within a DCL process. You cannot execute CGI images directly.
Use the following logicals to debug CGI scripts:
Logical Name: Description
APACHE$DEBUG_DCL_CGI: If defined, this system logical name enables APACHE$VERIFY_DCL_CGI and APACHE$SHOW_CGI_SYMBOL.
APACHE$VERIFY_DCL_CGI: If defined, this system logical name provides information for troubleshooting DCL command procedure CGIs by forcing a SET VERIFY before executing any DCL CGI. Enabled by APACHE$DEBUG_DCL_CGI.
APACHE$SHOW_CGI_SYMBOL: If defined, this system logical name provides information for troubleshooting the CGI environment by dumping all of the symbols and logicals (job/process) for a given CGI. Enabled by APACHE$DEBUG_DCL_CGI.
To display a graphics file with a CGI command procedure, use the APACHE$DCL_BIN foreign symbol in the following format:
APACHE$DCL_BIN [-s bin-size] bin-file
where:
-s: bin-size specifies the actual or approximate file size in bytes. Bin-size is automatically determined if the image file is larger than 32768 K (default value). If the image file is smaller than 32768 K, then you can provide an approximate (or actual) size. This will boost performance.
bin-file: Specifies the file to be displayed.
For example:
$ SAY := WRITE SYS$OUTPUT $ SAY "Content-type: image/gif" $ SAY "" $ APACHE$DCL_BIN APACHE$ROOT:[ICONS]APACHE_PB.GIF $ EXIT
Running the Oracle HTTP Server on OpenVMS 3ñ19
The Oracle HTTP Server for OpenVMS is a non-privileged, user-mode, socket-based network application. TMPMBX and NETMBX are the only privilege requirements. The server runs under its own unique UIC and user account (ORACLE).
The Oracle HTTP Server runs as a single job which consists of:
and
Subprocesses are created to service incoming HTTP requests and to execute CGI scripts.
Because the server runs as a single job, the OpenVMS security profile for each process is identical, and no enhanced mechanism is required for these processes to communicate with one another. Resource utilization is controlled by a single user account (ORACLE) where pooled quotas are defined.
The Oracle HTTP Server performs three operations that require additional privilege:
By default, the server binds to port 8080 (HTTP).
The server provides a replacement for the getpwnam C RTL routine to allow the server to fetch default path information for other users (required by MOD_UTIL and MOD_USERDIR).
Two protected, shareable images are installed at startup to allow the server to perform these functions:
The APACHE$PRIVILEGED.EXE image provides exec-mode services for binding to privileged sockets and fetching user default path information. Access to these services is limited to processes running under the ORACLE username and is controlled by the APACHE$PLV_ENABLE_APACHE$WWW logical name. This logical name is defined as:
"APACHE$PLV_ENABLE_APACHE$WWW" = "3,80,1023"
The "3,80,1023" string represents three parameters where:
When a call to either service is made, the service code:
The APACHE$FIXBG.EXE_ALPHA image provides a kernel-mode service for manipulating the carriage-control attribute for BG devices that are owned by the calling process. No special access control exists on this service. This function can also be performed using a setsocketopt C RTL run-time call, but it is not supported by all TCP/IP stack vendors, which is the reason this service exists. This service does not enable privileges, but executes in kernel mode.
The Oracle HTTP Server runs under the ORACLE username and UIC and is started as a detached, network process. During startup, protected images are installed and logical names are placed in the system logical name table. Shutdown is accomplished by sending a KILL signal to the master process and its subprocess.
These actions require enhanced privileges (DETACH, SYSNAM, WORLD, and so forth) and are usually performed from a suitably privileged account.
All of the server files reside under its root directories that are pointed to by the APACHE$ROOT logical name. During installation, file protection is set to (S:RWED, O:RWED, G, W). During configuration, all files are set to be owned by ORACLE.
Server extensions, such as CGI scripts run within the context of the Oracle HTTP Server process or its subprocesses. These extensions have complete control over the server environment. You can configure the server to allow execution of arbitrary user scripts, but standard practice is to limit such activity to scripts that are written by completely trusted users. The Oracle HTTP Server includes directives that allow a web administrator to control script execution and client access. The use of these directives is described in numerous books and is not duplicated here.
The Oracle HTTP Server for OpenVMS does not currently support the suEXEC method of executing scripts under the username that owns the script. Many sites use this feature to allow execution of arbitrary, user-written scripts without the fear of compromising the server environment.
This section provides open source license acknowledgments and license references.
This product includes software developed by the Apache Software Foundation (http://www.apache.org/). You can view the license at the following web site:
http://www.openvms.compaq.com/openvms/products/ips/apache/apache_license.txt
This product also includes software that is developed by Hewlett-Packard.
![]() Copyright © 2003 Oracle Corporation. All Rights Reserved. |
