Skip Headers
Oracle9i Installation Guide
Release 2 (9.2.0.2) for hp OpenVMS Alpha
Part Number B10508-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
2
Release Information
This chapter provides information specific to this release of Oracle9i for HP OpenVMS.  The following sections are included:
Product Set
The following components are included on the product CD-ROM:
Oracle9i
Oracle Net
Changes and Enhancements
In order to take full advantage of the latest OpenVMS CPU and compiler optimizations in Oracle software products, Oracle9i Release 2 (9.2.0.2) and associated Oracle9i Release 2-based products will require HP OpenVMS AlphaServers with EV56 or later generation CPUs.  AlphaServers with earlier generation CPUs will see a performance degradation.  Refer to Note 181307.1 on MetaLink for a list of affected models and for instructions on how to identify the CPU model number.
The following changes and enhancements are unique to this release of Oracle9i for HP OpenVMS:
2349006 - CHANGE CALL TO SYS$CREPRC TO HAVE PRC$M_IMGDMP SET
In releases prior to Oracle9i Release 2 (9.2.0.2), when one of the background processes terminated abruptly with an access violation, no useful information was readily available regarding the cause for termination.  For troubleshooting, certain actions needed to be taken, and the crash needed to be reproduced.  Starting with this release, by default, an image dump will be created when a background process aborts.  If you do not want this feature enabled, you can turn it off using the following commands:
$ define/system ORA_<SID>_<PROCESS_NAME>_DMP FALSE
$ <start the instance and open the database>
Example:
$ define/system ORA_PROD_LMD0_DMP FALSE
$ sqlplus/nolog
SQL> connect / as sysdba
SQL> startup
Please note that this change has no effect on normal daily production behavior.  Oracle Corporation recommends that you do not define the dump logical.
Oracle9i Release 2 Dependency on ODS-5 Disk Structure
In general, ODS-5 format allows VMS to support Microsoft Windows file naming formats.  Longer file names, additional character support, and the ability to have lowercase and mixed-case file names are some of the features supported on ODS-5 disks.
The disks on which the Oracle code tree resides must be formatted in Files-11 On-Disk Structure Level 5 (ODS-5) format.  This is the disk to which the VMS logicals ora_root, ora_rootdir, and oracle_home will point.  The directory that is referenced by these logicals is the parent directory for all Oracle RDBMS software, such as APACHE, CTX, INSTALL, NETCONFIG, RDBMS, UTIL, and so forth.  The disks on which Oracle database files reside can be formatted as either ODS-2 or ODS-5.
Caution:
Oracle Corporation STRONGLY urges you to read the OpenVMS Guide to Extended File Specifications PRIOR to changing the structure of any disk.  This guide discusses ODS-2 and ODS-5 formats in much more detail and has important information that you must understand and follow.
Oracle Note 205630.1 can be viewed at Oracle MetaLink.  Alternatively, use the search function and search for "ODS-5" for more information.
Precautions
Checking Disk Format
To check the current disk format, use the following DCL command:
$ SHOW DEVICE/FULL <device-name>
The Volume Status: will display the current ODS level.  The default when initializing disks is ODS-2.
Changing Disk Format
If you plan to reformat an existing (in use) disk from ODS-2 to ODS-5 format, then do the following:
  1. Make at least one VMS backup of the disk.
  2. Use the Set Volume command:
    $ SET VOLUME /STRUCTURE_LEVEL=5  <device-name>
    Example:
    $ SET VOLUME/STRUCTURE_LEVEL=5  $2$DKC100:
Formatting a New Disk
If you plan to use a new (empty) disk, then use the Initialize command to format the new disk to ODS-5 format, as follows:
$ INITIALIZE/STRUCTURE=5 <device-name>: <volume-label>
Example:
INITIALIZE/STRUCTURE=5 $2$DKC100: TESTVOL
Oracle9i Release 2 New Directory Structure
Beginning with this release, the directory structure of Oracle9i for HP OpenVMS closely resembles that of Oracle9i on UNIX systems.  Database Administrators will more quickly become familiar with Oracle9i as the platform by being able to make file locations more consistent and predictable.
Initialization Parameters in Oracle9i Release 2 That Have Been Desupported
ALWAYS_ANTI_JOIN
ALWAYS_SEMI_JOIN
JOB_QUEUE_INTERVAL
OPTIMIZER_PERCENT_PARALLEL
HASH_MULTIBLOCK_IO_COUNT
DB_BLOCK_LRU_LATCHES
DB_BLOCK_MAX_DIRTY_TARGET
SORT_MULTIBLOCK_READ_COUNT
DB_FILE_DIRECT_IO_COUNT
GC_DEFER_TIME
GC_RELEASABLE_LOCKS
GC_ROLLBACK_LOCKS
LM_LOCKS
LM_RESS
USE_INDIRECT_DATA_BUFFERS
Initialization Parameters in Oracle9i Release 2 That Are Becoming Obsolete
ROLLBACK_SEGMENTS
FAST_START_IO_TARGET
TRANSACTIONS_PER_ROLLBACK_SEGMENT
LOG_CHECKPOINT_INTERVAL
DB_BLOCK_BUFFERS
BUFFER_POOL_KEEP
BUFFER_POOL_RECYCLE
Known Restrictions
RMAN Runs Only Over TCP/IP
The connection to both the catalog and the database must be a TCP/IP connection.
OpenVMS
OpenVMS always performs its I/O asynchronously.  Several init.ora parameters that mimic asynchronous behavior are not needed on OpenVMS.  Refer to the Oracle9i Administrator's Guide, section 1.5.3 for the list of parameters that are not supported on OpenVMS.
PORTAL
With some limitations, Oracle9i for HP OpenVMS with iAS mid tier (with VMS back end database configuration) is supported.  For information about iAS support, contact:
http://infodec_us@oracle.com/
The following items are not supported:
RAC Guard and RAC High Availability Extensions
RAC Guard and RAC High Availability Extensions are not supported in this release due to the lack of cluster failover in the Operating System.
RAC Management Pack
RAC Management Pack is not supported in this release.
LDAP
LDAP (OID) is currently not supported.  This feature is a candidate for support in future releases.
iFS and Ultra Search
iFS and Ultra Search are not supported due to the lack of third party software called INSO filter.
EJB BEANS
Oracle9i for HP OpenVMS does not support EJB on the server.  If customers have iAS in mid tier, however, they can still use the database on OpenVMS in order to use EJB.
Oracle
Copyright © 2003 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
