Skip Headers
Oracle Transparent Gateway for iWay Installation and User's Guide
Release 9.2.0.4 for IBM z/OS (OS/390)
Part Number B10580-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
B
OSDI Subsystem Command Reference
OSDI provides a set of system commands for defining and controlling instances of Oracle products. This appendix is the primary reference for all OSDI commands.
The topics in this appendix include:
Command Types and Processing
Commands are broadly divided into two groups: definition and operating.
  1. Definition commands are used to create and manipulate data structures that describe service groups and services.  These commands commonly appear in the subsystem configuration file.
  2. Operating commands are used to manage execution of services.
Three mechanisms exist for issuing OSDI commands:
  1. Subsystem configuration file - processed during subsystem initialization.
  2. OS/390 system operator command interfaces - system consoles, TSO SDSF, SYS1.PARMLIB (COMMNDxx), Netview, and others.
  3. OSDI program interface - used internally by Oracle products.
When an OSDI command is issued using an OS/390 system operator command interface, the target subsystem is specified by using the command prefix associated with the subsystem.  When the program interface is used to issue an OSDI command, the target is identified by its subsystem name rather than a command prefix.  Commands in the configuration file always apply to the subsystem (service group) being initialized, and they must omit the prefix.
Commands generally result in synchronous response messages ranging from simple acknowledgment to multiline displays.  Responses to commands that are issued via system operator facilities are normally directed to the issuing console.  Various operating commands can result in subsequent, asynchronous messages.  These messages are not necessarily directed to the console or session that issued the original command.
System Symbols in Commands
In order to meet the requirement that the particulars of a service (that runs on multiple systems in a sysplex) can be tailored by system, OS/390 system symbols (alphanumeric names prefixed with the ampersand character, "&") can be used in the specification of certain OSDI command parameters.  These command parameters resolve to system-specific or IPL-specific values set by OS/390 or by the installation.  If a command parameter can include system symbols, then this capability is noted in the parameter description.
Definition Commands
Definition commands are used to create, modify, and display the data structures of the service group.  An initial set of commands in the configuration file directs the building of these structures during subsystem initialization.  Subsequent definition commands can be used to add new service definitions, modify existing definitions, and so forth.  The overall data structure persists for the life of the IPL.
The definition commands operate only on data structures.  They do not directly affect the operation of services.
Three definition commands are supported:
Structures
The definition commands operate on the following structures:
The various parts of these structures are generally referred to as attributes.  Definition commands use keywords to identify attributes being set or modified.
Service Group Definition Commands
The Service Group Definition commands are described in the following paragraphs.
DEFINE
DEFINE SERVICEGROUP must be the first command issued to a newly-initialized subsystem.  Normally it appears in the configuration file just after the bootstrap (INIT) record.  DEFINE SERVICEGROUP must be processed successfully in order for any other OSDI commands or functions to be usable.
The command structure for defining a service group is shown in the following example:
DEFINE SERVICEGROUP
   [ SSID( string ) ]
   [ DESCRIPTION( string ) ]
   [ MODE( LOCAL | SYSPLEX | *SYS ) ]
   [ SYSTEMS( sysname [ sysname... ] | *ALL ) ]
Define Parameters
SSID: Specifies the 1-character to 4-character OS/390 subsystem name associated with the service group.  If coded, then it must match the subsystem identifier specified in the IEFSSNxx parmlib member or the SETSSI operator command.  This parameter defaults to the correct value.  It is therefore coded only to confirm that the correct configuration file is in use.  String cannot contain system symbols.
DESCRIPTION: Specifies an arbitrary text string of up to 64 characters that appears in certain displays that are associated with the service group.  This can be used to supply installation-specific identification for the service group.  The default value is 'Service Group ssn' where ssn is the subsystem name.  String can contain system symbols but should not contain non-printable characters or control characters.
MODE: This parameter is not yet supported.
SYSTEMS: This parameter is not yet supported.
ALTER
ALTER SERVICEGROUP is used to modify attributes of a service group.  It can be included in the configuration file, and it can be issued after initialization.  Not all attributes can be altered.  The subsystem ID, for example, is constant for the life of the IPL.
The command structure for altering a service group is shown in the following example:
ALTER SERVICEGROUP
    [ MODE( LOCAL | SYSPLEX ) ]
Alter Parameters
DESCRIPTION: Specifies an arbitrary text string of up to 64 characters that appears in certain displays that are associated with the service group.  This can be used to supply installation-specific identification for the service group.  String can contain system symbols but should not contain non-printable or control characters.
SHOW
SHOW SERVICEGROUP is used to display the current definition of the service group.  It can be included in the configuration file, and it can be issued after initialization.  The command for displaying a service group definition is shown in the following example:
SHOW SERVICEGROUP
   [ LONG ]
Show Parameters
LONG: Specifies that the name, type, and description of each service in the service group be included in the display.
Service Definition Commands
The Service Definition commands are described in the following paragraphs.
DEFINE
DEFINE SERVICE is used to create a structure for executing an installed Oracle product.  It can be included in the configuration file, and it can be issued after initialization.  After a service is defined, it can be started, stopped, and so forth by using operating commands.
The command structure for defining a service is shown in the following example:
DEFINE SERVICE
     name
     TYPE( string )
     PROC( string )
   [ PARM( string ) ]
   [ MAXAS( number ) ]
   [ SID( string ) ]
   [ JOBNAME( string ) ]
   [ JOBACCT( string ) ]
   [ MODE( SYSPLEX | LOCAL ) ]
   [ SYSTEMS( sysname [ sysname... ] | *SVG ) ]
Define Parameters
name: Specifies the name of the service.  The name is used in other commands that operate on the service or its definition and by program functions that interact with the service.  It must be 1 character to 8 characters long, must consist of upper case alphabetic, numeric, and/or national characters, and must begin with an alphabetic character.  It must be unique within the service group.  name cannot contain system symbols.
Unless you specify JOBNAME, name is used as the job identifier when the service is started.  In this case, name must not be the same as any subsystem name in your system.
TYPE: Specifies the Oracle product being configured.  String is a 1-character to 4-character alphabetic and/or numeric identifier that designates an installed Oracle for OS/390 product managed under this architecture.  Current supported values are ORA (Oracle database), GTW (Oracle Gateway), and NET (Oracle Net).  String cannot contain system symbols.
PROC: Specifies the member name in a system JCL procedure library used to start an address space for the service.  Usually this is a procedure that is created during installation of the associated Oracle for OS/390 product.  String cannot contain system symbols.
DESCRIPTION: Specifies an arbitrary text string of up to 64 characters that appears in certain displays associated with the service.  This can be used to supply installation-specific identification for the service.  The default value is 'Service svc Type type', where svc is the service name and type is the type.  String can contain system symbols but should not contain non-printable or control characters.
PARM: The PARM for a gateway service specifies the name of an OS/390 data set containing service initialization parameters.  These are OS/390-specific parameters and are described in the section "Step 3: Edit the PARMLIB Members" in Chapter 5, "Configuring the Gateway".
MAXAS: Specifies the maximum number of address spaces that can be started for the service.  This is meaningful only for a database (TYPE(ORA)) service.  If specified for any other type, then number must be 1.  For a database service, number must be between 1 and 255 inclusive.  The default for this parameter is 1.  The value cannot include system symbols.
SID: Specifies a unique identifier for the service that is used in client-supplied or application-supplied service addressing.  String is a 1-character to 8-character identifier that conforms to the same rules as those for service names.  The value that is supplied must be unique within the OS/390 image: it cannot duplicate the SID of any other service in this or any other service group.  This parameter defaults to the service name.  If you accept the default, then the service name must be unique within the OS/390 image.
If you migrate an MPM-based gateway to OSDI and are supporting pre-OSDI local client applications, then you probably want SID to match the subsystem name that you were using with MPM.
JOBNAME: Specifies an OS/390 jobname to use when starting address spaces for the service.  String is either a 1-character to 8-character identifier that conforms to OS/390 jobname requirements, or it is a 1-character to 5-character identifier followed by an asterisk.  The asterisk form can be used with multiple address space services to provide unique jobnames.  It is replaced with a 3-digit address space counter (001, 002, and so on) as each address space is started.  The jobname should conform to any rules or requirements specific to your installation.  This parameter has no default.  If you omit this parameter, then service address spaces are started without a jobname but with the service name as the address space identifier.  System symbols cannot be used in this parameter.
JOBACCT: Specifies an installation-specific string containing job accounting fields.  String can be from 1 character to 64 characters.  If it contains characters other than alphabetic, numeric, and national characters, then it must be enclosed in single apostrophes.  Use this parameter if your installation requires job accounting data to be included with started tasks (STCs).  If this parameter is omitted or is specified as a null string (a pair of adjacent apostrophes), then no job accounting data is supplied when service address spaces are started.  String can include system symbols.
ALTER
ALTER SERVICE is used to modify attributes of a defined service.  It can be included in the configuration file and it can be issued after initialization.  The name, type, maximum address spaces, and SID of a service cannot be altered.
OSDI does not prohibit altering the definition of a running service.  This enables some useful capabilities, but it may also be harmful if misused.  For example, changing the JCL procedure of a running multiple address space service would have unpredictable consequences when additional auxiliary address spaces are started.
The command structure for altering a service is shown in the following example:
ALTER SERVICE
      name
    [ PROC( string ) ]
    [ PARM( string ) ]
    [ MAXAS( number ) ]
Alter Parameters
name: Specifies the name of the service to be altered.  It must be the name of an existing service in the service group.  Name cannot contain system symbols.
The name of a service cannot be altered.
DESCRIPTION: Specifies an arbitrary text string of up to 64 characters that appears in certain displays associated with the service.  This can be used to supply installation-specific identification for the service.  String can contain system symbols but should not contain non-printable characters or control characters.
PROC: Specifies the member name in a system procedure library that is used to start an address space for the service.  Usually this is a procedure that is created during installation of the associated Oracle for OS/390 product.  String cannot contain system symbols.
Altering PROC while a multiple address space or multiple system service is running can have unpredictable effects.
PARM: Specifies a parameter string that is passed to the service when an address space is started.  Requirements for this string depend on the service type and are discussed in the associated Oracle for OS/390 product documentation.  The value specified can contain system symbols.
Altering PARM while a multiple address space or multiple system service is running can have unpredictable effects.
MAXAS: Specifies the maximum number of address spaces that can be started for the service.  This is meaningful only for a database (TYPE(ORA)) service.  MAXAS is accepted on an ALTER SERVICE command only when the service is not active.  If the service is active, is starting, or is stopping, then an ALTER SERVICE command with MAXAS specified will be rejected.
JOBNAME: Specifies a jobname to use when starting service address spaces, as discussed under DEFINE SERVICE.  You can nullify (remove) a service jobname specification by coding JOBNAME('').  The value that is specified cannot contain system symbols.
JOBACCT: Specifies job accounting data that is to be included when service address spaces are started, as discussed under DEFINE SERVICE.  You can nullify (remove) job accounting data by coding JOBACCT('').  The value that is specified can contain system symbols.
SHOW
The SHOW SERVICE command is used to display the current definition of a service.
The command for displaying a service definition is shown in the following example:
SHOW SERVICE
     name
Show Parameters
name: Specifies the name of the service whose definition is to be displayed.  It must be the name of an existing service in the service group.  Name cannot contain system symbols.
Operating Commands
Operating commands manage the execution of services.  They are normally issued via the OS/390 command interface, either automatically (for example, COMMNDxx member of SYS1.PARMLIB) or by a real operator.  They might also be issued through the OSDI program interface by a management component such as Oracle Enterprise Manager Agent.  Operating commands are also permitted in the service group configuration file.
Available Commands
The following operating commands are provided:
All of the operating commands take a service name as the first positional parameter.  This service name must be the name of a defined service.
Commands
Commands are described in the following paragraphs.
START
The START command initiates execution of an address space for a specified service.  For a database service, this can be the first address space (service not previously started) or an auxiliary address space (service previously started and initialized successfully but not yet at its maximum address spaces).  For other types of services, the service must not already be running.
The command structure for starting a service is shown in the following example:
START
    name
   [ PARM( string ) ]
START Parameters
name: Name specifies the name of the service to start.  It must be a defined service whose current state is inactive or, if active, then it must not already have its maximum address spaces running.
PARM: Specifies a parameter string that is passed to the service when an address space is started.  This overrides any PARM value established by DEFINE or ALTER SERVICE.  Requirements for this string depend on the service type and are discussed in Chapter 6, "Oracle Net"String can contain system symbols.
A PARM override must not be used when starting auxiliary address spaces for a database service.
DISPLAY
The DISPLAY command displays execution status information for services.  OSDI displays the current operating state of the service.  If the service state is "active" or "drained", then the command is also posted to the running service for further processing at the discretion of the service.
The command structure for displaying a service is shown in the following example:
DISPLAY
     name
   [ LONG ]
DISPLAY Parameters
name: Specifies the name of the service to be displayed.
LONG: Specifies that a more detailed display is desired.  This provides information about each active address space of the service.
DRAIN
The DRAIN command places a running service in a quiescent state in which it no longer accepts new connection (bind) requests.  Existing connections or sessions are not affected.  The command is also posted to the running service for further discretionary processing.  This command has no effect when the service is not running.
The command structure for draining a service is shown in the following example:
DRAIN
     name
DRAIN Parameters
name: Specifies the name of the service to be made quiescent.  This must be the name of a running service whose current state is active.
RESUME
The RESUME command reverses the effect of a drain, allowing a service to begin accepting new connection requests.  This command is also posted to the running service for further discretionary processing.  This command has no effect when the service is not running.
The command structure for resuming a service is shown in the following example:
RESUME
     name
RESUME Parameters
name: Specifies the name of the service to be resumed.  This must be the name of a running service whose current state is drained.
STOP
The STOP command requests termination of a running service.  The normal mode of STOP changes the service state to stopping and posts the stop request to the service.  It is up to the service to comply, presumably after allowing current requests to complete and performing required cleanup.  A FORCE option causes the service address space(s) to be terminated involuntarily.  The FORCE form of STOP requires that a normal STOP be issued first.  This command has no effect when the service is not running.
The command structure for stopping a service is shown in the following example:
STOP
     name
   [ FORCE ]
STOP Parameters
name: Specifies the name of the service to be stopped.  This must be the name of a running service whose current state is active, drained, or (if the FORCE option is specified) stopping.
FORCE: Specifies that an involuntary stop is requested.
KILL
The KILL command terminates a dedicated task.  This is a useful command to terminate an idle gateway session into EDA.  The iWay Server holds resources (files, locks, or storage) while a session is active.  In order to release the resources due to long idle dblink session, you could use the OSDI DISPLAY command to identify the desired idle session and then use this KILL command to terminate the dedicated task (in other words, the gateway session into EDA).  The command structure for killing a service is shown in the following example:
KILL SESSION(kkkkkkkk)
Where kkkkkkkk is the 8-digit (hex) session key.
Example:
F service_name,D SESS JOB(*)
MIR0503I Sess=00050010, Job=RSTETAK3, TCB=007B0E78, AS=001, User=SCOTT
MIR0500I Command processed
F service_name,KILL SESSION(00050010)
OSDI Command Keyword Abbreviations
The abbreviated or alternate forms that can be used for OSDI command verbs and parameter keywords are as follows:
ALTER             ALT
DEFINE            DEF
DESCRIPTION       DESC
DISPLAY           DIS, D
DRAIN             DR
FORCE             (none)
JOBACCT           ACCT
JOBNAME           JOB
LONG              L
MAXAS             MXA
MODE              MD
PARM              P
PROCEDURE         PROC
RESUME            RES
SERVICE           SRV, SVC
SERVICEGROUP      SVG, SG
SHOW              SH
SID               IDENTIFIER, ID
SSID              (none)
START             ST, S
STOP              P
SYSTEMS           SYS
TYPE              TY
Oracle
Copyright © 1995, 2003 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
