Skip Headers
Oracle Transparent Gateway for iWay Installation and User's Guide
Release 9.2.0.4 for IBM z/OS (OS/390)
Part Number B10580-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
G
Installation Reference
This appendix documents additional installation information that is referenced in the installation sections.  The following topics are included:
Choosing Data Set Name Qualifiers
Step 1 of the primary Oracle9i for OS/390 installation setup and initialization process creates the first of several OS/390 data sets.  Later in the installation, you can specify the high-level and second-level data set name qualifiers that are used for subsequently created data sets.  Refer to Appendix A, "Data Set Names and Space Allocations", for a list of the data sets and their default space allocations.
Oracle Corporation recommends that you use the same qualifiers for all of the installation-related data sets.  At this time, you need to choose and use the qualifiers that were selected in "Setup and Initialization Steps" .
While choosing qualifiers, remember the following requirements:
Data Set Name Qualifier Rules
The following two rules concern the value that was entered for Target Data Set Name Qualifiers on panel OR@PRIM during the installation process:
These two rules allow for Oracle data sets with high-level and second-level qualifiers, as in the following examples:
aaaaaaaa
aaaaaaaa.bbbbbbbb.cccccccc
aaaaaaaa.bb.cc.dd.ee.ff.gg
where the initial values on panel ORINIP00 are seen in these examples as:
Table G-1 Data Set Name Qualifier Rules
High-Level Qualifier Second-Level Qualifier
aaaaaaaa
not included in the example
aaaaaaaa
bbbbbbbb.cccccccc
aaaa
bbbbbbbb.cccccccc
aaaaaaaa
bb.cc.dd.ee.ff.gg
OR@INST Panel Options
Options 1 through 5 on installation panel OR@INST are:
Option 1
Option 2
Option 3
Option 4
Option 5
Option 6
Option 7
Option 8
Option 9
Oracle
Copyright © 1995, 2003 Oracle Corporation.
All Rights Reserved.
Contents
Go To Index
Index
