Skip Headers
Oracle Reports Building Reports
10g (9.0.4)
Part Number B10602-01
Go To Table Of Contents
Contents
Go To Index
Index
Go to previous page Go to next page
26
Building a Nested Matrix Report
Figure 26-1 Nested matrix report output
Text description of nestmat_fin.gif follows.
In the example nested matrix report shown above, the cross product is capable of displaying every possible value for three dimensions - two down (YEAR and DEPTNO) and one across (JOB). This method does not include rows that have null values because there is a break group within the cross product group in the data model. This chapter describes how to create a nested matrix with and without a break group inside of the cross product group so that you can see the difference in the output.
Concepts
Example Scenario
Suppose that you want to create a report that cross tabulates salaries by year and department, and by job function. The result would be a matrix with job functions listed across the top, years and departments down the side, and sums of salaries in the cells. Thus, you could quickly determine the sum of all of the salaries for clerks in department 20 and compare that value to the one for all clerks in some other department.
To see a sample nested matrix report, open the examples folder named nestedmatrix, then open any of the Oracle Reports examples named nested1b.rdf, nested3b.rdf, or nested4b_brk.rdf. For details on how to access them, see "Accessing the example reports" in the Preface.
Table 26-1 Features demonstrated in this example
Feature Location
Create a nested matrix report with a single-query data model
Section 26.2, "Create a single-query matrix"
Create a nested matrix report with a multiple-query data model
Section 26.3, "Create a multiple-query matrix"
Create a nested matrix report with multiple queries and a break within the cross product group
Section 26.4, "Create a multiple-query matrix with a break"
Format monetary values
Section 26.5, "Format monetary values"
26.1 Prerequisites for this example
To build the example in this chapter, you must have access to the EMP and DEPT schema, which is provided by default with the Oracle9i database. The userid and password for accessing this schema is scott/tiger.
26.2 Create a single-query matrix
You can build a matrix report with a single-query in the data model. A single-query data model typically performs better than a multiple-query data model.
When you are creating a single-query report, such as this one, you can use the Report Wizard to create the data model and layout simultaneously.
To create a data model and layout:
  1. Launch Reports Builder (or, if already open, choose File > New > Report).
  2. In the Welcome or New Report dialog box, select Use the Report Wizard, then click OK.
  3. If the Welcome page displays, click Next.
  4. On the Report Type page, select Create Paper Layout Only, then click Next.
  5. On the Style page, type a Title for your report, select Matrix, then click Next.
  6. On the Data Source page, click SQL Query, then click Next.
  7. On the Data page, enter the following SELECT statement in the Data Source definition field:
    SELECT TO_CHAR (HIREDATE, 'YY') YEAR, DEPTNO, JOB,
    SUM (SAL) FROM EMP
    GROUP BY TO_CHAR(HIREDATE, 'YY'), DEPTNO, JOB
    ORDER BY TO_CHAR(HIREDATE, 'YY'), DEPTNO, JOB
    You can enter this query in any of the following ways:
    • Copy and paste the code from the provided text file called nested1b_code.txt into the Data Source definition field.
    • Click Query Builder to build the query without entering any code manually.
    • Type the code in the Data Source definition field.
    If you are not already connected to a database, you will be prompted to connect to the database when you click Next. Ensure that you connect to a database that has the appropriate schema for this example. Section 26.1, "Prerequisites for this example" describes the sample schema requirements for this example.
  1. On the Rows page:
    • Click YEAR in the Available Fields list and click the right arrow (>) to move this field to the Matrix Row Fields list.YEAR should appear under Level 1.
Figure 26-2 First matrix row in the Report Wizard
Text description of nestmat_row1.gif follows.
Figure 26-3 Second matrix row in Report Wizard
Text description of nestmat_row2.gif follows.
Figure 26-4 Paper Design view for the nested matrix report
Text description of nestmat_out1.gif follows.
You can set alignment and format monetary values directly in the Paper Design view. Simply click the item, then click the appropriate toolbar button (if you run the mouse over these buttons, hint text displays). If the Paper Design view and the Object Navigator are displayed side-by-side, notice that when you select an item in one, the selection is reflected in the other.
26.3 Create a multiple-query matrix
You can build a matrix report with multiple queries in the data model. A multiple-query data model is typically easier to conceptualize and code than a single-query, but the single-query data model typically performs better.
26.3.1 Create a new report manually
In this case, it is easier to create the data model and layout separately. Hence, we will create an empty report first, then add the queries, and then create the layouts.
To create a blank report:
  1. Choose File > New > Report.
  2. Select Build a new report manually, then click OK.
26.3.2 Create a data model with a cross product and data links
When you create a matrix report with multiple queries, it is typically easier to create all of the queries with the Data Wizard first and then create the cross product group and the necessary links in the Data Model view.
To create the queries:
  1. In the Data Model view, choose Insert > Query to display the Data Wizard.
  2. If the Welcome page displays, click Next.
  3. On the Query page, type Q_Year for the Query name, then click Next.
  4. On the Data Source page, select SQL Query, then click Next.
  5. On the Data page, enter the following SELECT statement:
    SELECT DISTINCT TO_CHAR (HIREDATE, 'YY') YEAR
    FROM EMP
    • Copy and paste the code from the provided text file called nested4b_code.txt into the Data Source definition field.
  1. Click Next.
  1. On the Groups page, click Next.
  2. Click Finish to display the data model for your report in the Data Model view.
  3. Repeat the steps above for a second query, but this time name your query Q_Dept and use the following SELECT statement:
    SELECT DISTINCT DEPTNO
    FROM EMP
    You can enter these queries in any of the following ways:
  1. Again, repeat the steps above for a third query, but this time name your query Q_Job and use the following SELECT statement:
    SELECT DISTINCT JOB
    FROM EMP
  1. Again, repeat the steps above for a fourth query, but this time name your query Q_Salary and use the following SELECT statement:
    SELECT TO_CHAR(HIREDATE, 'YY') YEAR,  DEPTNO,  JOB,
    SUM(SAL) FROM EMP
Figure 26-5 Data model with four queries
Text description of nestmat_dm1.gif follows.
Tip:
The order of the queries is significant in this case. Q_Dept must appear to the right of or below Q_Year in order for the values of DEPTNO to be nested inside of the values of YEAR in the output.
To create the cross product group:
  1. In the Data Model view, click the Cross Product tool in the tool palette.
  2. Drag a box around G_YEAR, G_DEPTNO, and G_JOB. When you release the mouse button, the cross product group is created. Ensure that it completely surrounds all three groups.
Figure 26-6 Data Model with four queries and a cross product group
Text description of nestmat_dm2.gif follows.
To add the data links:
  1. In the Data Model view, click the Data Link tool in the tool palette.
  2. Click and drag from the YEAR column in the G_YEAR group to the YEAR1 column in the G_YEAR1 group.
  3. Repeat steps 1 and 2, but this time drag the link between the DEPTNO column in G_DEPTNO and DEPTNO1 in G_YEAR1.
  4. Again, repeat steps 1 and 2, but this time drag the link between the JOB column in G_JOB and JOB1 in G_YEAR1.
Figure 26-7 Nested matrix data model
Text description of nestmat_dm3.gif follows.
  1. Optionally, move the data model objects around to appear like the above figure.
26.3.3 Create the layout with the Report Wizard
Once your data model is complete, you need to create a layout for the data objects to display in the report output.
To create the layout:
  1. In the Data Model view, right-click on the canvas, then choose Report Wizard.
  2. In the Report Wizard, on the Report Type page, select Create Paper Layout only.
  3. On the Style page, select Matrix.
  4. On the Groups page, ensure that all of the groups from your data model appear in the Displayed Groups list. G_1 should be Matrix, G_YEAR and G_DEPTNO should be Down, G_JOB should be Across, and G_YEAR1 should be Down.
Figure 26-8 Groups page of the Report Wizard
Text description of nestmat_dispgrp.gif follows.
  1. On the Fields page, ensure that only the following columns appear in the Displayed Fields list:
    • YEAR
    • DEPTNO
    • JOB
    • SUM_SAL
Figure 26-9 Fields page of the Report Wizard
Text description of nestmat_dispfields.gif follows.
  1. On the Labels page, change the labels and field widths as follows:
    Fields Labels Width
    SUM_SAL
    <none>
    10
    YEAR
    4
    JOB
    10
  2. On the Template page, make sure Beige is selected under Predefined Template, then click Finish to display your report output in the Paper Design view. It should look like this:
Figure 26-10 Paper Design view for the nested matrix output
Text description of nestmat_out2.gif follows.
26.4 Create a multiple-query matrix with a break
If you compare the single-query nested matrix output in Figure 26-4, "Paper Design view for the nested matrix report" to the multiple-query output in Figure 26-10, "Paper Design view for the nested matrix output", you notice that the multiple-query case displays all of the departments for every year while the single-query case does not. In the single-query case, only those departments that actually have values in their matrix cells are displayed in the output. To achieve a similar result with multiple queries, you need to have a parent/child relationship between the groups containing YEAR and DEPTNO.
26.4.1 Create a new report manually
26.4.2 Create a data model with a cross product and data links
  3. On the Query page, type Q_Dept for the Query name, then click Next.
    FROM EMP
    • Copy and paste the code from the provided text file called nested3b_brk_code.txt into the Data Source definition field.
  • Click Next.
    1. On the Groups page, click YEAR in the Available Fields list and click the right arrow (>) to move this field to the Group Fields list, then click Next.
    2. On the Totals page, click Next.
    3. Click Finish to display the data model for your report output in the Data Model view.
    4. Choose Insert > Query and follow the steps above to create another query named Q_Job and use the following SELECT statement:
      SELECT DISTINCT JOB
      FROM EMP
    1. Again, choose Insert > Query and follow the steps above to create a third query named Q_Salary and use the following SELECT statement:
      SUM(SAL) FROM EMP
    Figure 26-11 Data model with three queries
    Text description of nestmat_dm4.gif follows.
    Figure 26-12 Data Model with three queries and a cross product group
    Text description of nestmat_dm5.gif follows.
    Figure 26-13 Nested matrix data model
    Text description of nestmat_dm6.gif follows.
    26.4.3 Create the layout with the Report Wizard
    Figure 26-14 Groups page of the Report Wizard
      • YEAR
      • DEPTNO
      • JOB
      • SUM_SAL
    Figure 26-15 Fields page of the Report Wizard
      Fields Labels Width
      SUM_SAL
      <none>
      10
      YEAR
      4
      JOB
      10
    1. On the Template page, make sure Beige is selected under Predefined Template, then click Finish to display your report output in the Paper Design view. It should look like this:
    Figure 26-16 Paper Design view for the final nested matrix report output
    Text description of nestmat_out3.gif follows.
    26.5 Format monetary values
    To make your matrix report more readable, you should format the monetary values.
    To format monetary values:
    1. On the first page of the report, click one of the cell values. Notice that all of the values are immediately selected, indicating that you can change their properties simultaneously.
    2. Click the Currency button in the toolbar. A currency symbol immediately appears next to all of the values.
    3. Click the Add Decimal Place button in the toolbar twice. Two decimal places are added to the right of the decimal point.
    4. Resize the fields. Click and drag the rightmost handle of the cell value under the SALESMAN label about 0.5 inches to the left. After you complete this operation, the department summaries from the second page should move onto the first page.
    5. Shift-click on the SALESMAN label.
    6. Click the Align Right button in the toolbar.
    7. Click in an open area of the Paper Design view to deselect all of the objects.
    Figure 26-17 Nested matrix report output with formatted monetary values
    26.6 Summary
    Congratulations! You have successfully created three nested matrix reports. You now know how to:
    For more information on any of the wizards, views, or properties used in this example, refer to the Reports Builder Online Help, which you can access in two ways:
  • Go to previous page Go to next page
    Oracle
    Copyright © 2002, 2003 Oracle Corporation.
    All Rights Reserved.
    Contents
    Go To Index
    Index
