Skip Headers
Oracle® Developer Suite Release Notes
10g (9.0.4) for Windows, Linux, Solaris, and HP-UX
Part No. B10668-05
  Go To Table Of Contents
Contents
Go To Index
Index
Previous Next
7 Oracle Discoverer Administrator
This chapter discusses issues and workarounds for Oracle Discoverer Administrator (Discoverer Administrator). The chapter includes the following topics:
7.1 General Issues and Workarounds
This section describes general issues and their workarounds for Oracle Discoverer Administrator.
7.1.1 "Cannot find a required file: dcmresus.msb." When Trying to Launch Oracle Discoverer 9.0.2 after Installing 9.0.4
If you install Oracle Discoverer Administrator 9.0.4 on the same computer as Discoverer Administrator 9.0.2, the following error message will be displayed if you attempt to start Discoverer Administrator 9.0.2 from the Windows Start menu:
Cannot find a required file : dcmresus.msb.
The message is displayed because of a problem loading certain libraries on a computer with multiple Oracle homes. The same message will also be displayed if you attempt to start Discoverer Administrator 9.0.2 by double-clicking on dis51adm.exe in Windows Explorer.
To work around this problem, do one of the following:
  • Workaround 1: Run Discoverer Administrator 9.0.2 from the Windows command line, as follows:
    1. From the Windows Start menu, choose Command Prompt to display the Command Prompt window.
    2. Enter the following at the command prompt:
      902_oracle_home\discoverer902\bin\dis51adm.exe
      where 902_oracle_home is the directory in which Discoverer Administrator 9.0.2 was installed.
  • Workaround 2: Run Discoverer Administrator 9.0.2 from a batch file, as follows:
    1. Open a new file in a text editor (for example, Notepad).
    2. Enter the following in the new text file:
      dis51adm.exe
    3. Save the file in the directory 902_oracle_home\discoverer902\bin, and give the file a .bat suffix (for example, startdiscoadmin902.bat).
    4. To start Discoverer Administrator 9.0.2, you can do either or both of the following:
      • Double click the new .bat file in Windows Explorer.
      • Replace the existing shortcut to Discoverer Administrator 9.0.2 in the Programs menu with a shortcut to the new .bat file.
The above workarounds assume that you have already used the Oracle Home Selector (typically required for any computer with multiple Oracle homes).
7.1.2 ORA-3113 Errors when Using Heterogeneous Data Services with Oracle Discoverer Administrator
If you are accessing data from a non-Oracle data source using Discoverer Administrator (for example to create a business area) and ORA-3113 errors are displayed, do one of the following:
  • Use a more recent version of the Oracle database (version 9.0.1.4 or later).
  • Contact Oracle Support to determine the availability of patches for earlier versions of the Oracle database.
7.1.3 JOB_QUEUE_INTERVAL Settings and Oracle Applications Users
The Oracle Discoverer Administrator Administration Guide recommends setting the JOB_QUEUE_INTERVAL parameter to 600. However, 600 is only suitable if you are not using Discoverer with Oracle Applications. If you are using Discoverer with Oracle Applications, keep the JOB_QUEUE_INTERVAL parameter set to the default value of 90.
7.1.4 Recommended Update for Batch Repository Created with Oracle Discoverer 9.0.2
The BATCHUSR.SQL script (located in oracle_home\discoverer\sql) creates a schema in which to store the results of scheduled workbooks (referred to as the batch repository user in earlier versions of Discoverer).
The BATCHUSR.SQL script (located in oracle_home\discoverer\sql) has changed between Discoverer 9.0.2 and 9.0.4.
The updated BATCHUSR.SQL script provides two benefits:
  • The script tightens the database security surrounding the creation and management of the scheduled workbook results schema. The script simply removes certain privileges that were found to be unnecessary.
  • The script increases the size limit for the SQL statement used by scheduled workbooks from 32KB to 64KB. The increased size limit reflects the increased limit supported by the Oracle database. The increase specifically benefits users who receive the error message "Exceeded Maximum query size" when scheduling a workbook.
The above updates are non-destructive and do not affect any currently scheduled workbooks.
Oracle recommends that all customers using an EUL created with Discoverer 9.0.2 apply these fixes. Simply connect to the database as a database administrator (for example, SYSTEM) and run the BATCHUSR.SQL script.
No action is required for customers using an EUL created with Discoverer 9.0.4, because you will use the updated BATCHUSR.SQL script when you create the scheduled workbook results schema.
7.2 Platform-specific Issues and Workarounds
There are currently no known platform-specific issues.
7.3 Configuration Issues and Workarounds
There are currently no known configuration issues.
7.4 Administration Issues and Workarounds
There are currently no known administration issues.
7.5 Useful Information
This section describes useful information for Oracle Discoverer Administrator.
7.5.1 Upgrading from Oracle Discoverer 3.1
If you are upgrading from Oracle Discoverer 3.1, the Oracle Discoverer Administrator Administration Guide documents the requirement to upgrade the EUL to Discoverer 4.1 as an intermediate step.
For the purposes of this upgrade, if you are not already in possession of Oracle Discoverer Administration Edition 4.1, it will be made available on the Oracle Technology Network (http://otn.oracle.com).
7.5.2 Manually Editing the End User Layer Tables
Do NOT manually edit the End User Layer (EUL) tables or their contents (for example by using SQL*Plus), unless specifically directed to do so by Oracle Support or Development. Manual editing of the EUL tables is not supported and any manual changes can result in a corrupt EUL.
7.5.3 Availability of HWOnline files
Previous versions of Oracle Discoverer shipped with the files HWOnline.htm and Memo.doc, which were used to demonstrate "drill out" functionality. To reduce disk space requirements and installation time, these files and instructions for their use will be made available from the Oracle Technology Network (http://otn.oracle.com).
7.5.4 Setting Oracle Discoverer Registry Variables for Use by Oracle Discoverer EUL Command Line for Java Commands
When using some of the commands provided by the Oracle Discoverer EUL Command Line for Java, you might want to explicitly set certain Discoverer registry variables, as shown below:
Command Discoverer Registry Variable
-export
  • ArchiveCacheFlushInterval
  • FormatXML ExportJoinFromMaster
refresh_object
  • DefaultPreserveDisplayPropertyForRefresh
  • EnableTriggers
-import
  • FormatXML
-connect -apps_user
  • AppsFNDNAM
  • AppsGWYUID
-load
  • SetNULLItemHeadingOnBulkLoad
  • MaxNumberJoinPredicates
all commands
  • SqlTrace
On Windows platforms, Discoverer registry variables are stored in the Windows Registry. On Linux, Solaris, and HP-UX platforms, Discoverer registry variables are stored in the .reg_key.dc file.
To set these Discoverer registry variables, do one of the following:
  • For Windows only: Specify values for registry variables as required by editing the Windows Registry using regedit or regedt32.
  • For Windows, Linux, Solaris, and HP-UX: Specify values for registry variables as required by entering the following at a command prompt:
    dis51pr -setadminpref registry_variable_name value
For more information about Discoverer registry variables (including descriptions, default values and allowable values), see:
  • Oracle Discoverer Administrator Administration Guide
  • Oracle Application Server Discoverer Configuration Guide
7.5.5 Additional Oracle Discoverer Registry Variables
The following Discoverer registry variables are available, in addition to those documented in the Oracle Discoverer Administrator Administration Guide and the Oracle Application Server Discoverer Configuration Guide:
Category Discoverer registry variable Description Default Valid Values
Database DefaultPreserve DisplayProperty ForRefresh When refreshing, specifies whether an updated item description is discarded and replaced with the original description, or whether the updated description is retained 0
  • 0 = Use updated description
  • 1 = Use original description
Database EnableTriggers Specifies whether database triggers are disabled.
For example, Discoverer attempts to make a database call for every new column found during a refresh. If this value is set to 0, Discoverer will not make the database call.
0
  • 0 = Disable database triggers
  • 1 = Enable database triggers
Database ExportJoinFrom Master When exporting a business area, specifies whether joins from the master folder are also exported. 0
  • 0 = Do export joins from Master Folder
  • Any value other than 0 = Do not export joins from the Master Folder
Database SetNULLItem HeadingOnBulk Load When performing a bulk load, specifies whether item headings are set to the same value as item display names, or set to null. 0
  • 0 = Set item headings to item display names
  • 1 = Set item headings to null
7.5.6 Required Privileges For the Scheduled Workbook Results Schema
7.5.6.1 How to grant the SELECT privilege on the synonym v$parameter to enable you to run scheduled workbooks
To run scheduled workbooks, the scheduled workbook results schema requires SELECT privilege on the synonym v$parameter. SELECT privilege on the synonym v$parameter is gained by having SELECT privilege on the underlying view v_$parameter.
However, the v_$parameter view does not have public access and is owned by the SYS user. Therefore, to grant SELECT privilege on v_$parameter (and, by extension, on the v$parameter synonym) to the scheduled workbook results schema, you must log in as the SYS user and explicitly grant the privilege.
For more information about the scheduled workbook results schema, see the section "How to specify the owner of the tables containing scheduled workbooks results" in chapter 7 of the Oracle Discoverer Administrator Administration Guide.
How you grant the SELECT privilege on v_$parameter will depend on the version of the Oracle database that you are using, as follows:
  • If you using an Oracle9i database:
    1. Start SQL*Plus (if it is not already running) and connect as the SYS user (or as a user to which the SYSDBA privilege has been granted).
      For example, if SQL*Plus is already running, you might type the following at the command prompt:
      SQL> CONNECT SYS/sys_pw@database AS SYSDBA;
      where sys_pw is the password of the SYS user. If you are unable to login as the SYS user or are unsure about the SYS password, see your database administrator.
    2. Type the following at the command prompt:
      SQL> grant SELECT on v_$parameter to user;
      where user is the name of the scheduled workbook results schema.
  • If you are using a version of the Oracle database earlier than Oracle9i:
    1. On the database server computer, start the DBA facility and login as the SYS user (for example, on a Windows computer, choose Run... from the Windows Start menu and enter SVRMGRL).
    2. In the DBA facility, enter connect internal.
    3. Enter the following at the command prompt:
To verify that the scheduled workbook results schema has been granted SELECT privilege on v_$parameter:
  1. Start SQL*Plus (if it is not already running) and connect as the scheduled workbook results schema.
    SQL> CONNECT user/user_pw@database;
    where user is the user name of the scheduled workbook results schema and user_pw is the password of the scheduled workbook results schema.
    SQL> select count (*) from v$parameter;
    If SELECT privilege on the v_$parameter view has been successfully granted to the scheduled workbook results schema, SQL*Plus displays the number of rows from the v$parameter synonym.
    If SELECT privilege on the v_$parameter view has not been successfully granted to the scheduled workbook results schema, SQL*Plus displays the message:
    ORA - 01031 Insufficient privileges
7.5.7 Running the Oracle Discoverer EUL Command Line for Java (Linux, Solaris, and HP-UX only)
To run the Oracle Discoverer EUL Command Line for Java on Linux, Solaris, or HP-UX, a number of environment variables must be set correctly. You can either set the environment variables explicitly using the discwb.sh script or implicitly using the eulapi script, as described below:
  • to explicitly set the environment variables before issuing Discoverer EUL Command Line for Java commands, enter the following at the command line prompt from which you will be issuing those commands:
    oracle_home_path/discoverer/discwb.sh
    Subsequently, you can enter Discoverer EUL Command Line for Java commands as follows:
    java -jar oracle_home_path/discoverer/lib/eulbuilder.jar -command_list
    For example, to refresh a folder called "Sales1", you might enter the following:
    java -jar oracle_home_path/discoverer/lib/eulbuilder.jar -connect jchan/12345@my_database -refresh_folder Sales1
  • to implicitly set the environment variables when you run Discoverer EUL Command Line for Java commands, use the eulapi script in the directory oracle_home_path/bin to run commands. For example, to refresh a folder called "Sales1", you might enter the following:
    oracle_home_path/bin/eulapi -connect jchan/12345@my_database -refresh_folder Sales1
    Hint: To avoid entering oracle_home_path/bin each time you run the eulapi script, run discwb.sh first.
7.5.8 Oracle Discoverer and Real Application Clusters (RAC)/Transparent Application Failover (TAF)
Oracle Discoverer's support for Transparent Application Failover (TAF) on a Real Application Cluster (RAC) computer requires a failover mode of "select", as shown in the example tnsnames.ora entry below:
NAME =
   (DESCRIPTION=
       (ADDRESS=
           (PROTOCOL=tcp)
           (HOST=servername)
           (PORT=1521))
       (CONNECT_DATA=
       (SERVICE_NAME= NAME)
       (FAILOVER_MODE=
               (TYPE=select)
               (METHOD=basic)
               (RETRIES=4)
               (DELAY=15))))
Oracle Corporation recommends that you should initially set RETRIES and DELAY to the values given in the example above (that is, 4 and 15 respectively). However, you may need to increase these values for your own computer.
In certain rare scenarios, end users may see an error message if failover occurs. When they acknowledge the error message, their sessions will continue as normal. A fix for these scenarios is planned for release as a patch to the 9.0.4 release.
7.5.9 Installing the Lineage workbook for use with Oracle Warehouse Builder
The Oracle Warehouse Builder (OWB) Discoverer bridge is documented in "Warehouse Builder Bridges: Transfer Parameters and Considerations" in Chapter 22 "Integrating Warehouse Builder Metadata with Other BI Products" of the Oracle Warehouse Builder User's Guide (10g Release 1 (10.1), Part No. B12146-01).
Before you can use the Lineage workbook you must have first generated your Discoverer EUL using OWB and Discoverer Bridge. Discoverer Bridge will generate a Discoverer import file (.eex) that contains references to the folder and item lineage held within OWB. You can then load this .eex file into your Discoverer EUL. Please note that the Lineage workbook will only work with a business area generated in this way.
  1. Login to Oracle Discoverer Administrator as the Discoverer EUL schema owner.
  2. Import the lineage.eex file.
  3. Login to SQL*Plus as the Discoverer EUL schema owner.
    For example:
    > SQLPLUS myeul/myeul@myconnection
  4. Run the lineage.sql file.
    For example:
    SQL> start d:\<ORACLE_HOME>\discoverer\lineage.sql
    This script will ask you to input and verify the following:
    • the OWB URL Machine Name.Domain Name:Port
      For example, http://myserver.us.mycompany.com:7777
    • the OWB Virtual path to mod_plsql (the default is pls)
      For example, pls
    • the OWB Database Access Descriptor DAD (the default is portal30)
      For example, portal30
    • the OWB Browser schema
      For example, myowbinstall
    • the OWB Host name (that is, the name of the machine that runs the OWB repository)
      For example, myserver
      Note that the name must be exactly the same as used in the OWB browser registration.
    • the OWB SID (that is, the database instance name)
      For example, ASdB
    • the OWB Schema where the OWB repository resides
      For example, owbrep
  5. Login to OracleAS Discoverer Plus, OracleAS Discoverer Viewer, or Oracle Discoverer Desktop as the EUL schema owner and open the Lineage workbook.
If you export and re-import the EUL, you will need to re-run lineage.sql.
If you have previously imported EUL5.eex, you will already have the Lineage workbook saved in the database. If this is the case, all you need to do is run lineage.sql.
7.5.10 Using the Discoverer workbook dump utility
Discoverer Administrator includes a workbook dump utility (d51wkdmp.exe) that enables you to inspect the EUL elements used by a workbook without having to open the workbook in Discoverer Desktop. This utility is particularly useful if you are unable to open a workbook (for example, because of missing joins).
To analyze a workbook, run the d51wkdmp.exe file from a command prompt window. The d51wkdmp.exe file is located in the %ORACLE_HOME%\bin directory.
The syntax for using the workbook dump utility is:
d51wkdmp <Workbook_Name> <Output_File> <DB|FS> <Connect_String> <Eul_Schema> -f
The parameters are described in more detail in the table below:
Parameter Mandatory or Optional Description
<Workbook_Name> Mandatory Name of the workbook to be examined (including the path, if the workbook is stored in the filesystem).
<Output_File> Mandatory The file to write the output to.
<DB|FS> Mandatory DB = opens the workbook from the database
FS = opens the workbook from the filesystem
<Connect_String> Mandatory A username, password and database SID combination e.g. user/passwd@database
<Eul_Schema> Mandatory The name of the database user that owns the EUL tables.
-f Optional Use this parameter to output further details about EUL objects that the workbook uses, including whether the elements can be found in the specified EUL.
Note the following:
  • If a connect string or workbook name includes spaces, enclose the connect string or workbook name in double quotation marks.
  • Specify the parameters in the order shown above.
  • You can only analyze a workbook stored in the database if the workbook is owned by the username you specify in the connect string.
  • The case of the eul_schema parameter must be correct. In other words, if the EUL is owned by user SDC, you must enter "SDC". If you enter "sdc", the following error message is displayed:
    "Connect Error - EUL schema is not accessible. Default or specified schema containing EUL tables is inaccessible"
The examples below use the Video Tutorial Workbook that is shipped as part of the Discoverer tutorial to illustrate the output of the workbook dump utility.
Example 1: The following command outputs the content of the Video Tutorial Workbook to the video.txt file. In this example, the -f option is not used.
d51wkdmp "Video Tutorial Workbook" video.txt DB disco/disco@orcl.world disco
The content of the video.txt file is as follows:
Sheet Number 1
 Sheet Name = Tabular Layout
 Sheet Unique Name = {8690F66A-B9C8-11D1-ADB2-0080C7CDEA89}
 Query(s) used =
 Query 1
  Items :-
  EUL Item - Video Analysis Information.Calendar Year
  EUL Item - Video Analysis Information.Department
  EUL Item - Video Analysis Information.Region
  Calculation - Profit SUM
  Sort On   EUL Item - Video Analysis Information.Region
  Filters :-
  EUL Filter - Video Analysis Information.Department is Video Rental or Video Sale
Sheet Number 2
 Sheet Name = Crosstab Layout
 Sheet Unique Name = {8690F66B-B9C8-11D1-ADB2-0080C7CDEA89}
 Query(s) used =
 Query 2
  Items :-
  Filters :-
Example 2: The following command outputs the content of the Video Tutorial Workbook to the video.txt file. In this example, the -f option is used.
d51wkdmp "Video Tutorial Workbook" video.txt DB disco/disco@orcl.world disco -f
EUL Item Reference
   IoId = 16
   Id = 100177
   Identifier = REGION
   Name = Region
   Folder Identifier = DC_VIDEO_ANALYSIS_INFORMATION
   Folder Name = Video Analysis Information
   *** Found in EUL by Identifier ***
  EUL Item Reference
   IoId = 24
   Id = 100153
   Identifier = DEPARTMENT
   Name = Department
  EUL Item Reference
   IoId = 32
   Id = 100175
   Identifier = PROFIT
   Name = Profit
  EUL Private Item
   Id = -105
   Name = Profit SUM
   Identifier = 1
   Desc = Total profit for one store, one product in one day
   DataType = 2
   Placement = 1
   Hidden = 0
   IsACalc = 0
   IOFormula = [1,1]([6,32])    DisplayFormula = SUM(Profit)
  EUL Item Reference
   IoId = 41
   Id = 100139
   Identifier = CALENDAR_YEAR
   Name = Calendar Year
  EUL Filter Reference
   Id = 100218
   Identifier = DEPARTMENT_IS_VIDEO_RENTAL_OR_VIDEO_SALE
   Name = Department is Video Rental or Video Sale
  EUL Sort Item Reference
   Item =   EUL Item - Video Analysis Information.Region
   Identifier = 14
   Direction = 1
  Query Request QR1
   Distinct = 1
   Axis Item Usage -   Name =   EUL Item - Video Analysis Information.Calendar Year
   Axis Item Usage -   Name =   EUL Item - Video Analysis Information.Department
   Axis Item Usage -   Name =   EUL Item - Video Analysis Information.Region
   Measure Item Usage -  Name =   Calculation - Profit SUM
   Sort Item Usage -  Name =   Sort On   EUL Item - Video Analysis Information.Region
   Filter Usage -  Name =   EUL Filter - Video Analysis Information.Department is Video Rental or
 Video Sale
   Identifier = 58
 Sheet Number 1
  Sheet Identifier = 7
  Query(s) used =
  Query 1
   Items :-
   Filters :-
  Query Request QR2
   Distinct = 1
 Video Sale
   Identifier = 95
 Sheet Number 2
  Sheet Identifier = 12
  Query(s) used =
  Query 2
   Items :-
   Filters :-
7.6 Documentation Errata
This section describes known errors in the documentation.
7.6.1 Item Class Wizard: Choose Attributes dialog description
The "Notes" section in the Item Class Wizard: Choose Attributes dialog description on page 24-78 of the Oracle Discoverer Administrator Administration Guide should contain an extra bullet point as shown below:
  • A one-to-one relationship must exist between the item used for the list of values and the item used for the sort order
7.6.2 Correction to /export (EUL Objects) Example
The example provided for the /export (EUL Objects) command on page 21-20 of the Oracle Discoverer Administrator Administration Guide should read as follows:
To export two business areas named "Test BA" and "Final BA", residing in an EUL named "eul_sales", into a file named export.eex, and write to a log file named export.log, enter:
dis51adm.exe /connect me/mypassword /export export.eex /business_area "Test BA" /business_area "Final BA" /all /eul eul_sales /log export.log
7.6.3 Missing '-jar' in Example Syntax given for Running Oracle Discoverer EUL Command Line for Java commands
The examples in sections 1.7 and 1.9 of the Oracle Discoverer EUL Command Line for Java User's Guide are missing the "-jar" part of the command line syntax. When running the command line for Java, use the following syntax:
java –jar eulbuilder.jar -command list
7.6.4 About Scheduled Workbooks and Compatibility Between the Current Version of Oracle Discoverer and Previous Releases
The section "About scheduled workbooks and compatibility between the current version of Discoverer and previous releases" on page 7-15 of the Oracle Discoverer Administrator Administration Guide contains the following statement:
In this case you must install the new version of the batch PL/SQL package (EUL5_BATCH_USER) using the SQL script batchusr.sql.
The above statement should read:
In this case you must install the new version of the batch PL/SQL package (EUL5_BATCH_REPOSITORY) using the SQL script batchusr.sql.
7.6.5 <ORACLE_HOME>\discoverer\util should read <ORACLE_HOME>\discoverer\sql
All references in the Oracle Discoverer Administrator Administration Guide and the Oracle Discoverer Administrator Tutorial to files located in the <ORACLE_HOME>\discoverer\util directory should instead specify the <ORACLE_HOME>\discoverer\sql directory.For example, the path <ORACLE_HOME>\discoverer\util\eul5_id.sql should read <ORACLE_HOME>\discoverer\sql\eul5_id.sql.
