Oracleâ E-Business Suite Certified Configuration Installation Guide
Release 11i (11.5.8) for HP 9000 Series HP-UX 11.11 Part No. B10710-01 |
Copyright © 2003, Oracle Corporation. All Rights Reserved.
Oracle is a registered trademark of Oracle Corporation. Other names may be trademarks of their respective owners.
Installation Guide
March 2003
Part No. B10710-01
This document provides instructions for setting up and installing Oracle E-Business Suite Certified Configuration. You can also use the procedures in this document to recover a system after system failure. If a vendor preinstalls the system, refer to the Oracle E-Business Suite Certified Configuration Getting Started Guide to configure your system.
This guide includes the following topics:
The Oracle E-Business Suite Certified Configuration consists of the following main components:
Oracle Applications 11i
Oracle Database Certified Configuration
Oracle Internet Directory (OID)
Online Analytical Processing (OLAP)
You can install each component independently of the other components.
Before you can deploy Oracle E-Business Suite Certified Configuration components, you must fulfill the certified operating system and hardware requirements that this guide specifies. This guide provides instructions on performing the following tasks:
Run setup.sh to install the auxiliary E-Business Suite Outsourcing (ebso) scripts to your machine and update the operating system.
Run setup_oap.sh to install OAP tools and utilities.
Install the volume manager software and configure disk group vg00.
Run the ocheck validation script to make sure you have the proper operating environment.
The Oracle E-Business Suite Certified Configuration release 11.5.8 distribution contains zip files for the default GOLD environment. The default GOLD environment consists of the IGOLD, DGOLD, SGOLD and IOLAP components. These components are deployed using /admin/ebso/install/deploy.sh. You can use the default GOLD naming, or you can specify a new name for your environment. You can update (rename) the environment at a later time.
Before you begin, gather the following information:
Customer short code - This is a four-character code uniquely identifying the customer on the system.
Environment type - Test, Development, Stage, or Production.
The name of your environment determines the database system identifier (SID), mount points, and user names and groups. You can deploy each component as one of the following four environment types: Test, Development, Stage, or Production. Each environment type has its own set of port numbers.
The name of an environment consists of six characters. The first letter must be the initial letter of the type of environment that you want to deploy, for example, (T)est, (D)evelopment, (S)tage, or (P)roduction. The next four characters represent the unique customer short code. And the last letter identifies the software component.
The following are possible configuration options:
Oracle Applications 11i consists of the following five tiers:
Database
Concurrent Processing
Admin
Web
Forms
The letter i uniquely identifies an Oracle Applications 11i environment. The deployment process will combines the letter i with the first letter of the environment type to form the database system identifier (SID), mount points, and user names and groups.
Table 1 provides examples of users, groups, passwords, and directory structure for the IGOLD environment:
Table 1 IGOLD Example
User Name/ Password |
Group | Home Directory | Description |
origold/origold
dbigold
/igold/oracle
Oracle Owner |
apigold/apigold
aaigold
/igold/applmgr
Apps Owner |
Table 2 provides examples of users, groups, passwords, and directory structure for the TEST environment, where the customer short code is abcd:
Table 2 TABCDI Example
ortabcdi/
dbtabcdi
/tabcdi/oracle
Oracle Owner |
aptabcdi/aptabcdi
aatabcdi
/tabcdi/applmgr
Apps Owner |
An Oracle Applications 11i environment consists of the mount points in Table 3.
Table 3 Oracle Applications 11i Mount Points
| Type | Mount Points | Size |
| Oracle
/mount_point/oracle
3 GB |
/mount_point/oradata
25 GB | |
/mount_point/arch
3 GB | |
/mount_point/backup
(Created in the Production Environment type only) |
30 GB | |
| Apps
/mount_point/applmgr
25 GB |
/mount_point/applcsf
3 GB |
The installation options are as follows:
Single node – An installation where all five tiers are on the same machine.
Multi-node – An installation where the five tiers are spread across two or more machines.
Full environment – An installation where you create all the mount points. Oracle intends this for single-node installations or multi-node installations, where you install the Database tier and one or more of the Apps tiers on the same machine.
Partial environment – An installation where you can only install the Oracle mount points or the Apps mount points. The intent of this is to save disk space for multi-node installations.
Database version - An installation where the Database tier can either be Release 8.1.7.4 or Release 9.2.0.2.
The Oracle Database Certified Configuration is essentially the Oracle code tree from Oracle Applications 11i, but it has separate naming conventions and an empty seed database.
The letter d uniquely identifies an Oracle Database Certified Configuration environment. The deployment process combines the letter d with the first letter of the environment type to form the database system identifier (SID), mount points, and user names and groups.
Table 4 provides examples of users, groups, passwords, and directory structure for the DGOLD environment and the TEST environment, where the customer short code is abcd:
Table 4 Oracle Database Certified Configuration Variable Examples
| Environment |
| DGOLD | ordgold/
dbdgold
/dgold/oracle
Oracle Owner |
| TABCDD | ortabcdd/ortabcdd
dbtabcdd
/tabcdd/oracle
Oracle Owner |
An Oracle Database Certified Configuration environment consists of the mount points in Table 5.
Table 5 Oracle Database Certified Configuration Mount Points
| Oracle
/mount_point/oracle
3 GB |
25 GB | |
/mount_point/arch
3 GB | |
/mount_point/backup
30 GB |
The only installation option is Database version, in which you can select Release 8.1.7.4 or Release 9.2.0.2.
The Oracle Internet Directory has separate naming conventions.
The letter s uniquely identifies an Oracle Internet Directory environment. The deployment process combines the letter s with the first letter of the environment type to form the database system identifier (SID), mount points, and user names and groups.
Table 6 provides examples of users, groups, passwords, and directory structure for the SGOLD environment and the TEST environment, where the customer short code is abcd:
Table 6 OID Variable Examples
| Environment |
| SGOLD | orsgold/orsgold
dba
/sgold/oracle
Oracle Owner |
| TABCDS | ortabcds/ortabcds
dba
/tabcds/oracle
Oracle Owner |
An Oracle Internet Directory environment consists of the mount points in Table 7.
Table 7 Oracle Internet Directory Mount Points
| Oracle
/mount_point/oracle
3 GB |
25 GB | |
/mount_point/arch
3 GB | |
/mount_point/backup
30 GB |
The Online Analytical Processing (OLAP) has separate naming conventions.
The letter x uniquely identifies an OLAP environment. The deployment process combines the letter x with the first letter of the environment type to form the database system identifier (SID), mount points, and user names and groups.
Table 8 provides examples of users, groups, passwords, and directory structure for the IOLAP environment and the TEST environment, where the customer short code is abcd:
Table 8 OLAP Variable Examples
| Environment |
| IOLAP | oriolap/
dba
/iolap/oracle
Oracle Owner |
| TABCDX | ortabcdx/ortabcdx
dba
/tabcdx/oracle
Oracle Owner |
An OLAP environment consists of the OLAP mount point, /mount_point, which is 3 GB.
To avoid conflicts, you cannot have two environments of the same environment type on one machine.
Also, Oracle Applications 11i and Oracle Database Certified Configuration environments share the same port list, which means that you cannot have these components with the same environment type on one machine.
The following components are common to all platforms of the Oracle E-Business Suite Certified Configuration:
Table 9 Oracle E-Business Suite Certified Configuration Components
| Main Component | Key Subcomponents |
| Oracle Applications Release 11i (11.5.8) | Oracle Applications Manager 2.1
Oracle Database 8.1.7.4 or 9.2.0.2 Oracle Developer 6i P11 Oracle Discoverer 4.1.44 Oracle iSetup 11i Oracle JInitiator 1.1.8.16 Oracle Login Server 3.0.9.8.2 Oracle Portal 3.0.9.8.2 Oracle9i Application Server 1.0.2.2.2 Web Applications Desktop Integrator 8.3.0.0 Sun JDK 1.3.1_02 |
| Oracle Database Certified Configuration | Oracle Database 8.1.7.4 or 9.2.0.2 |
| Oracle Internet Directory 3.0.1 | Oracle Database 9.0.1.4 |
| OLAP | Oracle Express Server Multi-Language Edition (MLE) 6.3.4
Oracle Financial and Sales Analyzer Server (MLE) 6.4.0 |
| Tools and Utilities | Cloning utility
NLS Toolkit Ocheck validation tool Oracle Outsourcing custom application Oracle Outsourcing database accounts Database and system administration scripts |
| Oracle Automation Platform (OAP) | Oracle Enterprise Manager Intelligent Agent 9.0.1
Support Agent 1.0 Unified Serviceability Interface 1.0 Patch Tracking System (PTS) client 2.9.1.1 AutoVerify 2.2.13 APPSAUTO |
This section contains information on minimum operating system, hardware, and configuration requirements. You must make sure that you fulfill these requirements before you deploy Oracle E-Business Suite Certified Configuration. This section includes the following topics:
The minimum operating system requirements for the Oracle E-Business Suite Certified Configuration are as follows:
Kernel parameters set to the specifications in Table 10
Table 10 Kernel Parameters for HP-UX
| Parameter | Value | Description |
| eqmemsize | 512 | Space reserved for equivalently mapped entry |
| max_async_ports | 150 | Maximum Async Ports |
| max_thread_proc | 256 | Maximum number of thread processes |
| maxdsiz | 0x4BC00000 | Maximum data segment size |
| maxfiles | 2048 | Maximum number of files |
| maxfiles_lim | 2048 | hard file limit per process |
| maxssiz | 0x10000000 | Maximum segment size |
| maxssiz_64bit | 0x10000000 | Maximum segment size (64 bit) |
| maxswapchunks | 12539 | Maximum swap chunks |
| maxuprc | 3686 | Maximum processes per user |
| maxusers | 512 | Maximum number of users |
| maxvgs | 80 | Maximum number of volume groups configured by cvm on system |
| msgmax | 32768 | Maximum message size |
| msgmnb | 65535 | Maximum number of bytes on queue |
| msgmni | 4096 | Number of message queue identifiers |
| msgseg | 32767 | Number of message segments in a message queue |
| msgssz | 128 | Message segment size in bytes |
| msgtql | 32767 | Number of system message header |
| nflocks | 4096 | Maximum number of file locks available to system |
| nstrtel | 200 | Maximum number of telnet sessions |
| nswapdev | 25 | Maximum number of swap devices |
| semmni | 4098 | Number of semaphore identifiers |
| semmns | 8192 | Maximum number of semaphores |
| semmnu | 4112 | Number of undo structures in the system |
| semume | 64 | Maximum number of undo entries per process |
| shmmax | 0x40000000 | Maximum size per shared memory segment (bytes) |
| shmmni | 1024 | Number of shared memory identifiers |
| shmseg | 128 | Shared memory segments per process |
| swchunk | 4096 | Size of each chunk created on service devices or file systems |
| unlockable_mem | 2000 | Amount of non-lockable memory |
Software packages in Table 11
Table 11 System Software Packages for HP-UX
| Product | Version | Description |
| B3901BA | B.11.11.04 | HP C/ANSI C Developer's Bundle for HP-UX 11.i (S800) |
| B3913DB | C.03.33.01 | HP aC++ Compiler (S800) |
| B5456CA | C.01.18.05 | HP-UX Development Kit for Java* |
| B8110AA | 1.2.2.11.01 | Java 2 SDK for HP-UX (700/800), PA1.1 +PA2.0 Add On |
| B9788AA | 1.3.1.02.00 | Java 2 SDK 1.3 for HP-UX (700/800), PA1.1 +PA 2.0 Add On |
| BUNDLE11i | B.11.11.0102.2 | Required Patch Bundle for HP-UX 11i, February 2001 |
| expect | 5.33 | expect
Note: |
| HPUX11i-OE-Ent | B.11.11.0203 | HP-UX Enterprise Operating Environment Component |
| HPUXBase64 | B.11.11 | HP-UX 64-bit Base OS |
| HPUXBaseAux | B.11.11.0203 | HP-UX Base OS Auxiliary |
| RAID-00 | B.11.11.01 | PCI RAID; Supptd HW=A5856A |
| sudo | 1.6.6 | Utility to execute commands as another user. |
| tcl | 8.2.1 | tcl
| tk | 8.2.1 | tk
| unzip | 5.42 | unzip
Note: Should be installed in the |
| X11MotifDevKit | B.11.11.01 | HP-UX Developer's Toolkit - X11, Motif, and Imake |
| zip | 2.3 | zip
The software patches in Table 12
Table 12 Patches
| Patch No. | Version | Description |
| GOLDAPPS11i | B.11.11.0112.6 | Gold Applications Patches for HP-UX 11i, December 2001 |
| GOLDBASE11i | B.11.11.0112.6 | Gold Base Patches for HP-UX 11i, December 2001 |
| HWEnable11i | B.11.11.0203.5 | Hardware Enablement Patches for HP-UX 11i, March 2002 |
| PHCO_24402 | 1.0 | Libc cumulative header file patch |
| PHCO_25226 | 1.0 | Initialized TLS, Psets, Mutex performance |
| PHCO_26061 | 1.0 | Kernel configuration commands patch |
| PHCO_26331 | 1.0 | Mountall cumulative patch |
| PHCO_26466 | 1.0 | Pthread additive perf enhancement & fixes |
| PHCO_27434 | 1.0 | Libc cumulative patch |
| PHKL_25233 | 1.0 | Select(2) and poll(2) hang |
| PHKL_25389 | 1.0 | Core PM, vPar, Psets Cumulative Patch |
| PHKL_25468 | 1.0 | Eventport (/dev/poll) pseudo driver
| PHKL_25729 | 1.0 | Signals, threads enhancement, Psets Enablement |
| PHKL_25993 | 1.0 | Thread nostop for NFS, rlimit, Ufalloc fix |
| PHKL_25994 | 1.0 | Thread NOSTOP, Psets Enablement, Ufalloc |
| PHKL_25995 | 1.0 | Eventport syscalls; socket close(2); ufalloc |
| PHKL_26468 | 1.0 | Shared mutex synchronization support patch |
| PHKL_27092 | 1.0 | Thread NOSTOP, Abort; Psets |
| PHKL_27278 | 1.0 | Mmap io, VM-JFS ddlock, thread perf, user limit |
| PHKL_27502 | 1.0 | MO 4k sector size; FIFO; Event Port; perf |
| PHNE_25642 | 1.0 | Cumulative ARPA Transport patch |
| PHNE_26388 | 1.0 | ONC/NFS General Release/Performance Patch |
| PHNE_26728 | 1.0 | Cumulative STREAMS Patch |
| PHNE_27063 | 1.0 | Cumulative ARPA Transport patch |
| PHSS_24302 | 1.0 | Linker startup code / SLLIC ELF support |
| PHSS_24638 | 1.0 | HP aC++ -AA runtime libraries (aCC A.03.33) |
| PHSS_25092 | 1.0 | X Font Server SEP2001 Periodic Patch |
| PHSS_25263 | 1.0 | Xserver cumulative patch - Xvfb for HP-UX 11.11 |
| PHSS_25881 | 1.0 | X/Motif Runtime JAN2002 Periodic Patch |
| PHSS_25985 | 1.0 | ANSI C compiler General patch |
| PHSS_25986 | 1.0 | +04/PBO compiler |
| PHSS_26263 | 1.0 | Ld(1) and linker tools cumulative patch |
| PHSS_26971 | 1.0 | Japanese TrueType font patch |
| PHSS_26973 | 1.0 | Korean TrueType fonts patch |
| PHSS_26975 | 1.0 | Chinese-S TrueType fonts patch |
| PHSS_26977 | 1.0 | Chinese-T TrueType fonts patch |
| PHSS_27425 | 1.0 | X/Motif Runtime Patch |
Existing file system sizing as shown in Table 13
Table 13 Sizing
| Directory | File size |
/admin
10 GB |
/oem
2 GB |
/stage
20 GB |
/tmp
1 GB |
The minimum hardware requirements for the Oracle E-Business Suite Certified Configuration are as follows:
2 CPUs
450 MHz speed
900 CPU power factor (port-specific)
Note: To calculate CPU power factor, multiply the number of processors with the speed of the processors:CPU power factor = CPU count * speed |
2 GB of physical memory
2 GB disk swap space
2 internal 36 GB drives
230 GB free disk space on external disk storage, RAID 0+1 configuration (Recommended)
Table 14 lists the space needed for each environment deployment type.
Table 14 Deployment Sizing
| Deployment Type | Production Environment | Other Environments |
| Oracle E-Business Certified Configuration | 90 GB | 60 GB |
| OID | 61 GB | 31 GB |
| OLAP | 3 GB | 3 GB |
Note: The recommended 230 GB provides enough space to deploy approximately three environments. To deploy more than two, verify that you have sufficient free disk space for each deployment. |
2 Network Interface Cards (NIC), 10/1000 Mbps
Before you stage the installation environment, make sure that the host name and domain are set for your host. Also, make sure that the ports in Appendix B of the Oracle E-Business Suite Certified Configuration Getting Started Guide Release 11i (11.5.8) for UNIX are available.
Perform the following procedure to stage the HP 9000 Series HP-UX 11.11 environment:
Log in as the root user.
Copy the auxiliary Oracle E-Business Suite Outsourcing (ebso) files to the /admin/ebso directory from an NFS mount location or from the CD-ROM.
To install from an NFS mount location, enter the following commands:
# mkdir /stage # mount psd-sun.us.oracle.com:/image/1158/HP_UX/CD/Start_Here\
/stage # cd /stage/admin/ebso/install # ./setup.sh
When prompted for the location of the EBSO_HOME, press Enter to accept the default value, /admin/ebso.
Unmount the /stage directory, using the following commands:
# cd / # umount /stage
To install from CD-ROM, insert the Start_Here CD-ROM into the CD-ROM drive, and start the install, using the following commands:
# pfs_mount cd_raw_device /cdrom
# cd /cdrom/oap/install
# ./setup.sh
Unmount the CD-ROM, using the following commands:
# cd / # pfs_umount /cdrom
The Outsourcing Automation Platform (OAP) distribution contains files for installing the following products:
APPSAUTO
AutoVerify
OEM Intelligent Agent
PTS Client
Serviceability
Support Agent
After you perform the procedure in the Staging the Installation Environment section, you can install the OAP distribution from an NFS mount location or from the CD-ROM.
# mount psd-sun.us.oracle.com:/image/1158/HP_UX/CD/Start_Here/oap\
/stage # cd /stage/install # ./setup_oap.sh
When prompted for the location of the OAP_HOME, press Enter to accept the default value, /admin.
To install from CD-ROM, insert the Start_Here CD-ROM into the CD-ROM drive and start the install, using the following commands:
# cd /mnt/cdrom/oap/install # ./setup_oap.sh
When prompted for the location of the OAP_HOME, press Enter to accept the default value, /admin. Then, return to the root directory and eject the CD-ROM.
You can install Oracle E-Business Suite Certified Configuration on existing hardware with an existing operating system, if the hardware and operating system meet the minimum requirements. The media kit includes the validation script, ocheck, that checks the hardware and operating system before you install Oracle E-Business Suite Certified Configuration.
The validation script, ocheck, checks your system for the minimum Oracle E-Business Suite Certified Configuration requirements listed in the Minimum Requirements section.
To verify if your system meets Oracle E-Business Suite Certified Configuration requirements, run ocheck from /admin/ebso/ocheck directory as the root user. You can run ocheck with or without capturing the output in a log file, as follows:
To run the ocheck script without capturing the output in a log file, use the following syntax:
# ./ocheck -product ebiz -preinstall -prettyprint
To run the ocheck script while generating a log file, use the following syntax, substituting a log file name for output_filename:
# ./ocheck -product ebiz -preinstall -prettyprint -o output_filename
To run the ocheck script for the Oracle Database Certified Configuration, substitute the keyword rdbms for the keyword ebiz in the two examples above.
Note: ocheck does not check external disks and does not verify that VERITAS is installed. |
Perform the following tasks to create the Oracle E-Business Suite Certified Configuration:
Log out of the system, and then log back in as the root user.
Verify that you set the EBSO_HOME environment variable.
Perform one of the following tasks:
Deploy the image from an NFS mount location, using the following commands:
# mkdir /stage # mount psd-sun.us.oracle.com:/image/1158/HP_UX/NFS /stage
Deploy from CD-ROM, making sure that you mounted the /stage partition with 20 GB of available space in order to unload the contents of the CD-ROM.
Run the deploy.sh script, using the following commands:
# cd /admin/ebso/install # ./deploy.sh
The following menu appears:
1. Deploy EBiz CC 11i 2. Deploy DB CC with seed database 3. Deploy OLAP 4. Deploy Oracle Internet Directory 5. Quit Please enter action:
Enter the number corresponding to the action that you want to perform.
At the prompt, enter the mount point where you want to deploy the software.
If you selected option 1 or 2 in step 5, then follow the directions in the corresponding section below; otherwise, go to step 8:
Option 1 - Deploy Ebiz CC 11i
If you selected this option, you will see the following prompt.
Choose deployment option all, oracle or apps [all]:
Enter the keyword all, oracle, or apps, depending on whether you want to deploy both the database and apps, just the database, or just the apps, respectively.
Depending on your entry follow the directions in Table 15 for each entry type.
Table 15 Ebiz CC 11i Deployment Instructions
| Entry | Instructions |
all
The following prompt appears:
Is this a multinode environment? (y/n) [n]: If you want to configure one or more database, concurrent processing, admin, web, and forms tiers on different servers, enter If you enter Enter the 5 hostnames to configure multi-node delimited by comma: Enter the host names of five tiers for the nodes that you are deploying in the following order, without spaces and without the domain: database_host,concurrent_processing_host,admin_host,\ After entering the five host names the following prompt appears: Configure multi-node using Enter The following prompt appears: Select database release 817 or 920 [817]: Enter either 817 or 920 for Release 8.1.7 or 9.2.0, respectively. Then go to step 8. |
apps
Enter the 5 hostnames to configure multi-node delimited by comma: Enter the host names of five tiers for the nodes that you are deploying in the following order, without spaces and without the domain: database_host,concurrent_processing_host,admin_host,\ After entering the five host names the following prompt appears: Configure multi-node using Enter Go to step 8. |
oracle
Select database release 817 or 920 [817]: Enter either 817 or 920 for Release 8.1.7 or 9.2.0, respectively. Go to step 8. |
Option 2 - Deploy DB CC with seed database
If you selected this option, the following prompt appears:
Enter 817 or 920 for Release 8.1.7 or 9.2.0, respectively, then go to step 8.
When the following menu appears, enter 1 or 2:
1. Proceed to read /stage 2. Load CD distribution to /stage 3. Quit Please enter action:
1 if you want to deploy from an NFS location or if you previously uploaded the CD-ROM contents to /stage.
2 if you want to perform an initial deployment directly from the CD-ROM.
When the following menu appears, enter the number corresponding to the action that you want to perform.
1. Create vg00 volume group on local storage array and start the install 2. Use existing vg00 volume group and start the install 3. Install over network attached storage 4. Install on existing users and mount points 5. Quit Please enter action:
Table 16 describes under what conditions you should perform each action and what additional steps you need to take to accomplish the action.
Table 16 Installation Actions
| Action | Condition |
| 1 | If the vg00 volume group does not already exist. A volume group is a grouping of physical disk partitions. vg00 must exist before you create logical volumes for mounting file systems. When prompted, enter the external storage device (For example, sdb).
| 2 | If the vg00 volume group already exists.
| 3 | If you want to NFS mount the directories. Depending on the product that you are deploying, enter the mount points for some or all of the following, when prompted:
| 4 | If the apmount_point and ormount_point users and the corresponding Apps mount points already exist.
The script then deploys the environment you selected. The log files are written to the log directory under EBSO_HOME.
Our goal is to make Oracle products, services, and supporting documentation accessible, with good usability, to the disabled community. To that end, our documentation includes features that make information available to users of assistive technology. This documentation is available in HTML format, and contains markup to facilitate access by the disabled community. Standards will continue to evolve over time, and Oracle Corporation is actively engaged with other market-leading technology vendors to address technical obstacles so that our documentation can be accessible to all of our customers. For additional information, visit the Oracle Accessibility Program Web site at http://www.oracle.com/accessibility/.
JAWS, a Windows screen reader, may not always correctly read the code examples in this document. The conventions for writing code require that closing braces should appear on an otherwise empty line; however, JAWS may not always read a line of text that consists solely of a bracket or brace.
This documentation may contain links to Web sites of other companies or organizations that Oracle Corporation does not own or control. Oracle Corporation neither evaluates nor makes any representations regarding the accessibility of these Web sites.
