Oracle® Database Installation Guide
10g Release 1 (10.1) for UNIX Systems: AIX-Based Systems, hp HP-UX, hp Tru64 UNIX, Linux, and Solaris Operating System Part No. B10811-05 |
![]() Previous |
![]() Next |
During installation, the Installer assigns port numbers to components from a set of default port numbers. This appendix lists the default port numbers and describes how to change the assigned port after installation. It includes information about the following topics:
The following table lists the port ranges used by components that are configured during the installation. By default, the first port in the range is assigned to the component, if it is available.
To change the Oracle Enterprise Manager Agent HTTP port, edit the following files:
$ORACLE_HOME/host_sid/sysman/config/emoms.properties
Modify the following parameter in the file:
oracle.sysman.eml.mntr.repAgentUrl=http\://host.domain\:1830/emd/main
$ORACLE_HOME/host_sid/sysman/config/emd.properties
EMD_URL=http://host.domain:1830/emd/main
The following sections describe how to change the Oracle Enterprise Manager Database Control ports.
Changing the HTTP Port
To change the HTTP port, edit the following files:
Modify the following parameters in the file:
oracle.sysman.emSDK.svlt.ConsoleServerPort=5500 oracle.sysman.emSDK.svlt.ConsoleServerHTTPSPort=5500
REPOSITORY_URL=http://host.domain:5500/em/upload/ emdWalletSrcUrl=http://host.domain:5500/em/wallets/emd
$ORACLE_HOME/oc4j/j2ee/OC4J_DBConsole_host_sid/config/http-web-site.xml
Modify the port attribute of the web-site element:
<web-site port="5500" ...>
Changing the RMI Port
To change the RMI port, modify the port attribute of the rmi-server element in the $ORACLE_HOME/oc4j/j2ee/OC4J_DBConsole_host_sid/config/rmi.xml file:
<rmi-server port="5520"...>
Changing the JMS Port
To change the JMS port, modify the port attribute of the jms-server element in the $ORACLE_HOME/oc4j/j2ee/OC4J_DBConsole_host_sid/config/jms.xml file:
<jms-server port="5540"...>
The following sections describe how to change the iSQL*Plus ports.
oracle.sysman.db.isqlplusUrl=http\://host.domain\:5560/isqlplus/dynamic oracle.sysman.db.isqlplusWebDBAUrl=http\://host.domain\:5560/isqlplus/dynamic
$ORACLE_HOME/oc4j/j2ee/isqlplus/config/http-web-site.xml
<web-site port="5560" ...>
To change the RMI port, modify the port attribute of the rmi-server element in the $ORACLE_HOME/oc4j/j2ee/isqlplus/config/rmi.xml file:
<rmi-server port="5580"...>
To change the JMS port, modify the port attribute of the jms-server element in the $ORACLE_HOME/oc4j/j2ee/isqlplus/config/jms.xml file:
<jms-server port="5600"...>
The following sections describe how to change the Ultra Search ports.
To change the HTTP port, modify the port attribute of the web-site element in the $ORACLE_HOME/oc4j/j2ee/OC4J_SEARCH/config/http-web-site.xml file:
<web-site port="5620"...>
To change the RMI port, modify the port attribute of the rmi-server element in the $ORACLE_HOME/oc4j/j2ee/OC4J_SEARCH/config/rmi.xml file:
<rmi-server port="5640"...>
To change the JMS port, modify the port attribute of the jms-server element in the $ORACLE_HOME/oc4j/j2ee/OC4J_SEARCH/config/jms.xml file:
<jms-server port="5660"...>
