Skip Headers
Oracle® Database Administrator's Reference
10g Release 1 (10.1) for UNIX Systems: AIX-Based Systems, Apple Mac OS X, hp HP-UX, hp Tru64 UNIX, Linux, and Solaris Operating System
Part No. B10812-06
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
F Administering Oracle Database on Solaris
This appendix contains information about administering Oracle Database on Solaris.
Intimate Shared Memory
On Solaris systems, Oracle Database uses Intimate Shared Memory (ISM) for shared memory segments because it shares virtual memory resources between Oracle processes. ISM causes the physical memory for the entire shared memory segment to be locked automatically.
On Solaris 8 and Solaris 9 systems, dynamic/pageable ISM (DISM) is available. This enables Oracle Database to share virtual memory resources between processes sharing the segment, and at the same time, enables memory paging. The operating system does not have to lock down physical memory for the entire shared memory segment.
Oracle Database automatically decides at startup whether to use ISM or DISM, based on the following criteria:
Regardless of whether Oracle Database uses ISM or DISM, it can always exchange the memory between dynamically sizable components such as the buffer cache, the shared pool, and the large pool after it starts an instance. Oracle Database can relinquish memory from one dynamic SGA component and allocate it to another component.
Because shared memory segments are not implicitly locked in memory, when using DISM, Oracle Database explicitly locks shared memory that is currently in use at startup. When a dynamic SGA operation uses more shared memory, Oracle Database explicitly performs a lock operation on the memory that comes in use. When a dynamic SGA operation releases shared memory, Oracle Database explicitly performs an unlock operation on the memory that is freed, so that it becomes available to other applications.
Oracle Database uses the oradism utility to lock and unlock shared memory. The oradism utility is automatically set up during installation. You do not need to perform any configuration tasks to use dynamic SGA.
Oracle recommends that you do not set the LOCK_SGA parameter to true in the server parameter file on Solaris systems. If you do, Oracle Database 10g does not start up.
The process name for the oradism utility is ora_dism_sid, where sid is the system identifier. When using DISM, this process is started during instance startup, and automatically quits when the instance is shut down.If a message appears in the alert log saying that the oradism utility is not set up correctly, verify that the oradism utility is located in the $ORACLE_HOME/bin directory and that it has superuser privileges.
