Skip Headers
Oracle® Spatial User’s Guide and Reference
10g Release 1 (10.1)
Part No. B10826-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous Next
12 Spatial Operators
This chapter describes the operators that you can use when working with the spatial object data type. For an overview of spatial operators, including how they differ from spatial procedures and functions, see Section 1.9. Table 12-1 lists the main operators.
Table 12-1 Main Spatial Operators
Operator Description
SDO_FILTER
Specifies which geometries may interact with a given geometry.
SDO_JOIN
Performs a spatial join based on one or more topological relationships.
SDO_NN
Determines the nearest neighbor geometries to a geometry.
SDO_NN_DISTANCE
Returns the distance of an object returned by the SDO_NN operator.
SDO_RELATE
Determines whether or not two geometries interact in a specified way. (See also Table 12-2 for convenient alternative operators for performing specific mask value operations.)
SDO_WITHIN_DISTANCE
Determines if two geometries are within a specified distance from one another.
Table 12-2 lists operators, provided for convenience, that perform an SDO_RELATE operation of a specific mask type.
Table 12-2 Convenience Operators for SDO_RELATE Operations
SDO_ANYINTERACT
Checks if any geometries in a table have the ANYINTERACT topological relationship with a specified geometry.
SDO_CONTAINS
Checks if any geometries in a table have the CONTAINS topological relationship with a specified geometry.
SDO_COVEREDBY
Checks if any geometries in a table have the COVEREDBY topological relationship with a specified geometry.
SDO_COVERS
Checks if any geometries in a table have the COVERS topological relationship with a specified geometry.
SDO_EQUAL
Checks if any geometries in a table have the EQUAL topological relationship with a specified geometry.
SDO_INSIDE
Checks if any geometries in a table have the INSIDE topological relationship with a specified geometry.
SDO_ON
Checks if any geometries in a table have the ON topological relationship with a specified geometry.
SDO_OVERLAPBDYDISJOINT
Checks if any geometries in a table have the OVERLAPBDYDISJOINT topological relationship with a specified geometry.
SDO_OVERLAPBDYINTERSECT
Checks if any geometries in a table have the OVERLAPBDYINTERSECT topological relationship with a specified geometry.
SDO_OVERLAPS
Checks if any geometries in a table overlap (that is, have the OVERLAPBDYDISJOINT or OVERLAPBDYINTERSECT topological relationship with) a specified geometry.
SDO_TOUCH
Checks if any geometries in a table have the TOUCH topological relationship with a specified geometry.
The rest of this chapter provides reference information on the operators, listed in alphabetical order.
SDO_ANYINTERACT
Format
SDO_ANYINTERACT(geometry1, geometry2);
Description
Checks if any geometries in a table have the ANYINTERACT topological relationship with a specified geometry. Equivalent to specifying the SDO_RELATE operator with 'mask=ANYINTERACT'.
See the section on the SDO_RELATE operator in this chapter for information about the operations performed by this operator and for usage requirements.
Keywords and Parameters
Value Description
geometry1 Specifies a geometry column in a table. The column must be spatially indexed.
Data type is SDO_GEOMETRY.
geometry2 Specifies either a geometry from a table or a transient instance of a geometry. (Specified using a bind variable or SDO_GEOMETRY constructor.)
Returns
The expression SDO_ANYINTERACT(geometry1,geometry2) = 'TRUE' evaluates to TRUE for object pairs that have the ANYINTERACT topological relationship, and FALSE otherwise.
Usage Notes
See the Usage Notes for the SDO_RELATE operator in this chapter.
For an explanation of the topological relationships and the nine-intersection model used by Spatial, see Section 1.8.
Examples
The following example finds geometries that have the ANYINTERACT relationship with a query window (here, a rectangle with lower-left, upper-right coordinates 4,6, 8,8). (The example uses the definitions and data described in Section 2.1 and illustrated in Figure 2-1.)
SELECT c.mkt_id, c.name
  FROM cola_markets c
  WHERE SDO_ANYINTERACT(c.shape,
            SDO_GEOMETRY(2003, NULL, NULL,
              SDO_ELEM_INFO_ARRAY(1,1003,3),
              SDO_ORDINATE_ARRAY(4,6, 8,8))
            ) = 'TRUE';
    MKT_ID NAME
         2 cola_b
         1 cola_a
         4 cola_d
SDO_CONTAINS
Format
SDO_CONTAINS(geometry1, geometry2);
Description
Checks if any geometries in a table have the CONTAINS topological relationship with a specified geometry. Equivalent to specifying the SDO_RELATE operator with 'mask=CONTAINS'.
Value Description
Returns
The expression SDO_CONTAINS(geometry1,geometry2) = 'TRUE' evaluates to TRUE for object pairs that have the CONTAINS topological relationship, and FALSE otherwise.
Usage Notes
Examples
The following example finds geometries that have the CONTAINS relationship with a query window (here, a rectangle with lower-left, upper-right coordinates 2,2, 4,6). (The example uses the definitions and data described in Section 2.1 and illustrated in Figure 2-1.) In this example, only cola_a contains the query window geometry.
  FROM cola_markets c
  WHERE SDO_CONTAINS(c.shape,
              SDO_ORDINATE_ARRAY(2,2, 4,6))
            ) = 'TRUE';
    MKT_ID NAME
         1 cola_a
SDO_COVEREDBY
Format
SDO_COVEREDBY(geometry1, geometry2);
Description
Checks if any geometries in a table have the COVEREDBY topological relationship with a specified geometry. Equivalent to specifying the SDO_RELATE operator with 'mask=COVEREDBY'.
Value Description
Returns
The expression SDO_COVEREDBY(geometry1,geometry2) = 'TRUE' evaluates to TRUE for object pairs that have the COVEREDBY topological relationship, and FALSE otherwise.
Usage Notes
Examples
The following example finds geometries that have the COVEREDBY relationship with a query window (here, a rectangle with lower-left, upper-right coordinates 1,1, 5,8). (The example uses the definitions and data described in Section 2.1 and illustrated in Figure 2-1.) In this example, only cola_a is covered by the query window geometry.
  FROM cola_markets c
  WHERE SDO_COVEREDBY(c.shape,
              SDO_ORDINATE_ARRAY(1,1, 5,8))
            ) = 'TRUE';
    MKT_ID NAME
         1 cola_a
SDO_COVERS
Format
SDO_COVERS(geometry1, geometry2);
Description
Checks if any geometries in a table have the COVERS topological relationship with a specified geometry. Equivalent to specifying the SDO_RELATE operator with 'mask=COVERS'.
Value Description
Returns
The expression SDO_COVERS(geometry1,geometry2) = 'TRUE' evaluates to TRUE for object pairs that have the COVERS topological relationship, and FALSE otherwise.
Usage Notes
Examples
The following example finds geometries that have the COVERS relationship with a query window (here, a rectangle with lower-left, upper-right coordinates 1,1, 4,6). (The example uses the definitions and data described in Section 2.1 and illustrated in Figure 2-1.) In this example, only cola_a covers the query window geometry.
  FROM cola_markets c
  WHERE SDO_COVERS(c.shape,
              SDO_ORDINATE_ARRAY(1,1, 4,6))
            ) = 'TRUE';
    MKT_ID NAME
         1 cola_a
SDO_EQUAL
Format
SDO_EQUAL(geometry1, geometry2);
Description
Checks if any geometries in a table have the EQUAL topological relationship with a specified geometry. Equivalent to specifying the SDO_RELATE operator with 'mask=EQUAL'.
Value Description
Returns
The expression SDO_EQUAL(geometry1,geometry2) = 'TRUE' evaluates to TRUE for object pairs that have the EQUAL topological relationship, and FALSE otherwise.
Usage Notes
Examples
The following example finds geometries that have the EQUAL relationship with a query window (here, a rectangle with lower-left, upper-right coordinates 1,1, 5,7). (The example uses the definitions and data described in Section 2.1 and illustrated in Figure 2-1.) In this example, cola_a (and only cola_a) has the same boundary and interior as the query window geometry.
  FROM cola_markets c
  WHERE SDO_EQUAL(c.shape,
              SDO_ORDINATE_ARRAY(1,1, 5,7))
            ) = 'TRUE';
    MKT_ID NAME
         1 cola_a
SDO_FILTER
Format
SDO_FILTER(geometry1, geometry2);
Description
Uses the spatial index to identify either the set of spatial objects that are likely to interact spatially with a given object (such as an area of interest), or pairs of spatial objects that are likely to interact spatially. Objects interact spatially if they are not disjoint.
This operator performs only a primary filter operation. The secondary filtering operation, performed by the SDO_RELATE operator, can be used to determine with certainty if objects interact spatially.
Value Description
Returns
The expression SDO_FILTER(geometry1,geometry2) = 'TRUE' evaluates to TRUE for object pairs that are non-disjoint, and FALSE otherwise.
Usage Notes
SDO_FILTER is the only operator that can be used with data that is indexed using more than two dimensions. The operator considers all dimensions specified in the spatial index.
The operator must always be used in a WHERE clause and the condition that includes the operator should be an expression of the form SDO_FILTER(arg1, arg2) = 'TRUE'.
geometry2 can come from a table or be a transient SDO_GEOMETRY object (such as a bind variable or SDO_GEOMETRY constructor).
If geometry1 and geometry2 are based on different coordinate systems, geometry2 is temporarily transformed to the coordinate system of geometry1 for the operation to be performed, as described in Section 6.7.1.
In previous releases, the SDO_FILTER operator required a third parameter. Effective with Oracle Spatial release 10.1, the operator has only two parameters. For backward compatibility, any keywords for the third parameter that were supported in the previous release will still work; however, the use of those keywords is discouraged and is not supported for new uses of the operator.
Examples
The following example selects the geometries that are likely to interact with a query window (here, a rectangle with lower-left, upper-right coordinates 4,6, 8,8). (The example uses the definitions and data from Section 2.1.)
  FROM cola_markets c
  WHERE SDO_FILTER(c.shape,
    ) = 'TRUE';
    MKT_ID NAME
         2 cola_b
         1 cola_a
         4 cola_d
The following example selects the GID values from the POLYGONS table where the GEOMETRY column objects are likely to interact spatially with the GEOMETRY column object in the QUERY_POLYS table that has a GID value of 1.
SELECT A.gid
  FROM Polygons A, query_polys B
  WHERE B.gid = 1
  AND SDO_FILTER(A.Geometry, B.Geometry) = 'TRUE';
The following example selects the GID values from the POLYGONS table where the GEOMETRY column object is likely to interact spatially with the geometry stored in the aGeom variable.
Select A.Gid
  FROM Polygons A
  WHERE SDO_FILTER(A.Geometry, :aGeom) = 'TRUE';
The following example selects the GID values from the POLYGONS table where the GEOMETRY column object is likely to interact spatially with the specified rectangle having the lower-left coordinates (x1,y1) and the upper-right coordinates (x2, y2).
Select A.Gid
  FROM Polygons A
  WHERE SDO_FILTER(A.Geometry, sdo_geometry(2003,NULL,NULL,
                                   sdo_elem_info_array(1,1003,3),
                                   sdo_ordinate_array(x1,y1,x2,y2))
                   ) = 'TRUE';
The following example selects the GID values from the POLYGONS table where the GEOMETRY column object is likely to interact spatially with any GEOMETRY column object in the QUERY_POLYS table. In this example, the ORDERED optimizer hint is used and the QUERY_POLYS (geometry2) table is specified first in the FROM clause, because multiple geometries from geometry2 are involved (see the Usage Notes).
SELECT /*+ ORDERED */
  A.gid
  FROM query_polys B, polygons A
  WHERE SDO_FILTER(A.Geometry, B.Geometry) = 'TRUE';
Related Topics
SDO_INSIDE
Format
SDO_INSIDE(geometry1, geometry2);
Description
Checks if any geometries in a table have the INSIDE topological relationship with a specified geometry. Equivalent to specifying the SDO_RELATE operator with 'mask=INSIDE'.
Value Description
Returns
The expression SDO_INSIDE(geometry1,geometry2) = 'TRUE' evaluates to TRUE for object pairs that have the INSIDE topological relationship, and FALSE otherwise.
Usage Notes
Examples
The following example finds geometries that have the INSIDE relationship with a query window (here, a rectangle with lower-left, upper-right coordinates 5,6, 12,12). (The example uses the definitions and data described in Section 2.1 and illustrated in Figure 2-1.) In this example, only cola_d (the circle) is inside the query window geometry.
  FROM cola_markets c
  WHERE SDO_INSIDE(c.shape,
              SDO_ORDINATE_ARRAY(5,6, 12,12))
            ) = 'TRUE';
    MKT_ID NAME
         4 cola_d
SDO_JOIN
Format
SDO_JOIN(table_name1, column_name1, table_name2, column_name2, params,
preserve_join_order) RETURN SDO_ROWIDSET;
Description
Value Description
table_name1 Name of the first table to be used in the spatial join operation. The table must have a column of type SDO_GEOMETRY.
Data type is VARCHAR2.
column_name1 Name of the spatial column of type SDO_GEOMETRY in table_name1. A spatial R-tree index must be defined on this column.
table_name2 Name of the second table to be used in the spatial join operation. (It can be the same as or different from table_name1.) The table must have a column of type SDO_GEOMETRY.
column_name2 Name of the spatial column of type SDO_GEOMETRY in table_name2. A spatial R-tree index must be defined on this column.
params Optional parameter string of keywords and values; available only if mask=ANYINTERACT. Determines the behavior of the operator. See Table 12-3 in the Usage Notes for information about the available keywords.
Data type is VARCHAR2. Default is NULL.
preserve_join_order Optional parameter to specify if the join order is guaranteed to be preserved during processing of the operator. If the value is 0 (the default), the order of the tables might be changed; if the value is 1, the order of the tables is not changed.
Data type is NUMBER. Default is 0.
Returns
SDO_JOIN returns an object of SDO_ROWIDSET, which consists of a table of objects of SDO_ROWIDPAIR. Oracle Spatial defines the type SDO_ROWIDSET as:
CREATE TYPE sdo_rowidset as TABLE OF sdo_rowidpair;
Oracle Spatial defines the object type SDO_ROWIDPAIR as:
CREATE TYPE sdo_rowidpair AS OBJECT
   (rowid1  VARCHAR2(24),
    rowid2  VARCHAR2(24));
In the SDO_ROWIDPAIR definition, rowid1 refers to a rowid from table_name1, and rowid2 refers to a rowid from table_name2.
Usage Notes
SDO_JOIN is technically not an operator, but a table function. (For an explanation of table functions, see PL/SQL User's Guide and Reference.) However, it is presented in the chapter with Spatial operators because its usage is similar to that of the operators, and because it is not part of a package with other functions and procedures.
This function is recommended when you need to perform full table joins.
The geometries in column_name1 and column_name2 must have the same SRID (coordinate system) value and the same number of dimensions.
Table 12-3 shows the keywords for the params parameter.
Table 12-3 params Keywords for the SDO_JOIN Operator
Keyword Description
mask The topological relationship of interest.Valid values are 'mask=<value>' where <value> is one or more of the mask values valid for the SDO_RELATE operator (TOUCH, OVERLAPBDYDISJOINT, OVERLAPBDYINTERSECT, EQUAL, INSIDE, COVEREDBY, CONTAINS, COVERS, ANYINTERACT, ON), or FILTER, which checks if the MBRs (the filter-level approximations) intersect. Multiple masks are combined with the logical Boolean operator OR (for example, 'mask=inside+touch'); however, FILTER cannot be combined with any other mask.
If this parameter is null or contains an empty string, mask=FILTER is assumed.
distance Specifies a numeric distance value that is added to the tolerance value (explained in Section 1.5.5) before the relationship checks are performed. For example, if the tolerance is 10 meters and you specify 'distance=100 unit=meter', two objects are considered to have spatial interaction if they are within 110 meters of each other.If you specify distance but not unit, the unit of measurement associated with the data is assumed.
unit Specifies a unit of measurement to be associated with the distance value (for example, 'distance=100 unit=meter'). See Section 2.6 for more information about unit of measurement specification. If you specify unit, you must also specify distance.Data type is VARCHAR2. Default = unit of measurement associated with the data. For geodetic data, the default is meters.
Examples
The following example joins the COLA_MARKETS table with itself to find, for each geometry, all other geometries that have any spatial interaction with it. (The example uses the definitions and data from Section 2.1.) In this example, rowid1 and rowid2 correspond to the names of the attributes in the SDO_ROWIDPAIR type definition. Note that in the output, cola_d (the circle in Figure 2-1) interacts only with itself, and not with any of the other geometries.
SELECT a.name, b.name FROM cola_markets a, cola_markets b,
  TABLE(SDO_JOIN('COLA_MARKETS', 'SHAPE', 'COLA_MARKETS', 'SHAPE',
    'mask=ANYINTERACT')) c
  WHERE c.rowid1 = a.rowid AND c.rowid2 = b.rowid ORDER BY a.name;
NAME                             NAME
cola_a                           cola_a
cola_a                           cola_b
cola_a                           cola_c
cola_b                           cola_a
cola_b                           cola_b
cola_b                           cola_c
cola_c                           cola_a
cola_c                           cola_b
cola_c                           cola_c
cola_d                           cola_d
10 rows selected.
Related Topics
SDO_NN
Format
SDO_NN(geometry1, geometry2, param [, number]);
Description
Uses the spatial index to identify the nearest neighbors for a geometry.
Value Description
geometry2 Specifies either a geometry from a table or a transient instance of a geometry. The nearest neighbor or neighbors to geometry2 will be returned from geometry1. (geometry2 is specified using a bind variable or SDO_GEOMETRY constructor.)
param Determines the behavior of the operator. The available keywords are listed in Table 12-4. If you do not specify this parameter, the operator returns all rows in increasing distance order from geometry2.
number If the SDO_NN_DISTANCE ancillary operator is included in the call to SDO_NN, specifies the same number used in the call to SDO_NN_DISTANCE.
Table 12-4 lists the keywords for the param parameter.
Table 12-4 Keywords for the SDO_NN Param Parameter
Keyword Description
sdo_batch_size Specifies the number of rows to be evaluated at a time when the SDO_NN expression may need to be evaluated multiple times in order to return the desired number of results that satisfy the WHERE clause. Available only when an R-tree index is used. If you specify sdo_batch_size=0 (or if you omit the param parameter completely), Spatial calculates a batch size suited to the result set size. See the Usage Notes and Examples for more information.
For example: 'sdo_batch_size=10'
sdo_num_res If sdo_batch_size is not specified, specifies the number of results (nearest neighbors) to be returned. If sdo_batch_size is specified, this keyword is ignored; instead, use the ROWNUM pseudocolumn to limit the number of results. See the Usage Notes and Examples for more information.
Data type is NUMBER. Default = 1.
For example: 'sdo_num_res=5'
unit If the SDO_NN_DISTANCE ancillary operator is included in the call to SDO_NN, specifies the unit of measurement: a quoted string with unit= and an SDO_UNIT value from the MDSYS.SDO_DIST_UNITS table. See Section 2.6 for more information about unit of measurement specification.
For example: 'unit=KM'
Returns
This operator returns the sdo_num_res number of objects from geometry1 that are nearest to geometry2 in the query. In determining how near two geometry objects are, the shortest possible distance between any two points on the surface of each object is used.
Usage Notes
The operator is disabled if the table does not have a spatial index or if the index has been built on more than two dimensions.
The operator must always be used in a WHERE clause, and the condition that includes the operator should be an expression of the form SDO_NN(arg1, arg2, '<some_parameter>') = 'TRUE'.
The operator can be used in two ways:
Specify the sdo_batch_size keyword if any geometries in the table might be nearer than the geometries specified in the WHERE clause. For example, assume that a RESTAURANTS table contains different types of restaurants, and you want to find the two nearest Italian restaurants to your hotel. The query might look like the following:
SELECT r.name FROM restaurants r WHERE
   SDO_NN(r.geometry, :my_hotel, 'sdo_batch_size=10') = 'TRUE'
   AND r.cuisine = 'Italian' AND ROWNUM <=2;
If the sdo_batch_size keyword is not specified in this example, only the two nearest restaurants are returned, regardless of their CUISINE value; and if the CUISINE value of these two rows is not Italian, the query may return no rows. The ROWNUM <=2 clause is necessary to limit the number of results returned to no more than 2 where CUISINE is Italian.
The sdo_batch_size value can affect the performance of nearest neighbor queries. A good general guideline is to specify the number of candidate rows likely to satisfy the WHERE clause. Using the preceding example of a query for Italian restaurants, if approximately 20 percent of the restaurants nearest to the hotel are Italian and if you want 2 restaurants, an sdo_batch_size value of 10 will probably result in the best performance. On the other hand, if only approximately 5 percent of the restaurants nearest to the hotel are Italian and if you want 2 restaurants, an sdo_batch_size value of 40 would be better.
You can specify sdo_batch_size=0, which causes Spatial to calculate a batch size that is suitable for the result set size. However, the calculated batch size may not be optimal, and the calculation incurs some processing overhead; if you can determine a good sdo_batch_size value for a query, the performance will probably be better than if you specify sdo_batch_size=0.
If the sdo_batch_size keyword is specified, any sdo_num_res value is ignored. Do not specify both keywords.
Specify the number parameter only if you are using the SDO_NN_DISTANCE ancillary operator in the call to SDO_NN. See the information about the SDO_NN_DISTANCE operator in this chapter.
If this operator is used with geodetic data, the data must be indexed with an R-tree spatial index. If this operator is used with geodetic data and if the R-tree spatial index is created with 'geodetic=false' specified, you cannot use the unit parameter.
If two or more objects from geometry1 are an equal distance from geometry2, any of the objects can be returned on any call to the function. For example, if item_a, item_b, and item_c are nearest to and equally distant from geometry2, and if SDO_NUM_RES=2, two of those three objects are returned, but they can be any two of the three.
If the SDO_NN operator uses a partitioned spatial index (see Section 4.1.6), the requested number of geometries is returned for each partition that contains candidate rows based on the query criteria. For example, if you request the 5 nearest restaurants to a point and the spatial index has 4 partitions, the operator returns up to 20 (5*4) geometries. In this case, you must use the ROWNUM pseudocolumn (here, WHERE ROWNUM <=5) to return the 5 nearest restaurants.
SDO_NN is not supported for spatial joins.
In some situations the SDO_NN operator will not use the spatial index unless an optimizer hint forces the index to be used. This can occur when a query involves a join; and if the optimizer hint is not used in such situations, an internal error occurs. To prevent such errors, you should always specify an optimizer hint to use the spatial index with the SDO_NN operator, regardless of how simple or complex the query is. For example, the following excerpt from a query specifies to use the COLA_SPATIAL_IDX index that is defined on the COLA_MARKETS table:
SELECT /*+ INDEX(c cola_spatial_idx) */
  c.mkt_id, c.name, ... FROM cola_markets c, ...;
However, if there is an index associated with the column predicate in the WHERE clause, be sure that this index is not used by specifying the NO_INDEX hint for that index. For example, if there was an index named COLA_NAME_IDX defined on the NAME column, you would need to specify the hints in the preceding example as follows:
SELECT /*+ INDEX(c cola_spatial_idx) NO_INDEX(c cola_name_idx) */
(Note, however, that there is no index named COLA_NAME_IDX in the example in Section 2.1.)
For detailed information about using optimizer hints, see Oracle Database Performance Tuning Guide.
Examples
The following example finds the two objects from the SHAPE column in the COLA_MARKETS table that are nearest to a specified point (10,7). (The example uses the definitions and data from Section 2.1.)
 c.mkt_id, c.name  FROM cola_markets c  WHERE SDO_NN(c.shape,
   sdo_geometry(2001, NULL, sdo_point_type(10,7,NULL), NULL,
   NULL),  'sdo_num_res=2') = 'TRUE';
    MKT_ID NAME
         2 cola_b
         4 cola_d
The following example uses the sdo_batch_size keyword to find the two objects (ROWNUM <=2), with a NAME value less than 'cola_d', from the SHAPE column in the COLA_MARKETS table that are nearest to a specified point (10,7). The value of 3 for sdo_batch_size represents a best guess at the number of nearest geometries that need to be evaluated before the WHERE clause condition is satisfied. (The example uses the definitions and data from Section 2.1.)
SELECT /*+ INDEX(c cola_spatial_idx) */ c.mkt_id, c.name
   FROM cola_markets c
   WHERE SDO_NN(c.shape,  sdo_geometry(2001, NULL,
      sdo_point_type(10,7,NULL), NULL,  NULL),
      'sdo_batch_size=3') = 'TRUE'
   AND c.name < 'cola_d' AND ROWNUM <= 2;
    MKT_ID NAME
         2 cola_b
         3 cola_c
See also the more complex SDO_NN examples in Section C.3.
Related Topics
SDO_NN_DISTANCE
Format
SDO_NN_DISTANCE(number);
Description
Returns the distance of an object returned by the SDO_NN operator. Valid only within a call to the SDO_NN operator.
Value Description
number Specifies a number that must be the same as the last parameter passed to the SDO_NN operator.
Returns
This operator returns the distance of an object returned by the SDO_NN operator. In determining how near two geometry objects are, the shortest possible distance between any two points on the surface of each object is used.
Usage Notes
SDO_NN_DISTANCE is an ancillary operator to the SDO_NN operator. It returns the distance between the specified geometry and a nearest neighbor object. This distance is passed as ancillary data to the SDO_NN operator. (For an explanation of how operators can use ancillary data, see the section on ancillary data in the chapter on domain indexes in Oracle Data Cartridge Developer's Guide.)
You can choose any arbitrary number for the number parameter. The only requirement is that it must match the last parameter in the call to the SDO_NN operator.
Use a bind variable to store and operate on the distance value.
Examples
The following example finds the two objects from the SHAPE column in the COLA_MARKETS table that are nearest to a specified point (10,7), and it finds the distance between each object and the point. (The example uses the definitions and data from Section 2.1.)
   c.mkt_id, c.name, SDO_NN_DISTANCE(1) dist
   FROM cola_markets c
      'sdo_num_res=2', 1) = 'TRUE' ORDER BY dist;
    MKT_ID NAME                                   DIST
         4 cola_d                           .828427125
         2 cola_b                           2.23606798
Note the following about this example:
Related Topics
SDO_ON
Format
SDO_ON(geometry1, geometry2);
Description
Checks if any geometries in a table have the ON topological relationship with a specified geometry. Equivalent to specifying the SDO_RELATE operator with 'mask=ON'.
Value Description
Returns
The expression SDO_ON(geometry1,geometry2) = 'TRUE' evaluates to TRUE for object pairs that have the ON topological relationship, and FALSE otherwise.
Usage Notes
Examples
The following example finds geometries that have the ON relationship with a query window (here, a rectangle with lower-left, upper-right coordinates 4,6, 8,8). (The example uses the definitions and data described in Section 2.1 and illustrated in Figure 2-1.) This example returns no rows because there are no line string geometries in the SHAPE column.
  FROM cola_markets c
  WHERE SDO_ON(c.shape,
            ) = 'TRUE';
no rows selected
Format
SDO_OVERLAPBDYDISJOINT(geometry1, geometry2);
Description
Checks if any geometries in a table have the OVERLAPBDYDISJOINT topological relationship with a specified geometry. Equivalent to specifying the SDO_RELATE operator with 'mask=OVERLAPBDYDISJOINT'.
Value Description
Returns
The expression SDO_OVERLAPBDYDISJOINT(geometry1,geometry2) = 'TRUE' evaluates to TRUE for object pairs that have the OVERLAPBDYDISJOINT topological relationship, and FALSE otherwise.
Usage Notes
Examples
The following example finds geometries that have the OVERLAPBDYDISJOINT relationship with a line string geometry (here, a horizontal line from 0,6 to 2,6). (The example uses the definitions and data described in Section 2.1 and illustrated in Figure 2-1.) In this example, only cola_a has the OVERLAPBDYDISJOINT relationship with the line string geometry.
  FROM cola_markets c
  WHERE SDO_OVERLAPBDYDISJOINT(c.shape,
            SDO_GEOMETRY(2002, NULL, NULL,
              SDO_ELEM_INFO_ARRAY(1,2,1),
              SDO_ORDINATE_ARRAY(0,6, 2,6))
            ) = 'TRUE';
    MKT_ID NAME
         1 cola_a
Format
SDO_OVERLAPBDYINTERSECT(geometry1, geometry2);
Description
Checks if any geometries in a table have the OVERLAPBDYINTERSECT topological relationship with a specified geometry. Equivalent to specifying the SDO_RELATE operator with 'mask=OVERLAPBDYINTERSECT'.
Value Description
Returns
The expression SDO_OVERLAPBDYINTERSECT(geometry1,geometry2) = 'TRUE' evaluates to TRUE for object pairs that have the OVERLAPBDYINTERSECT topological relationship, and FALSE otherwise.
Usage Notes
Examples
The following example finds geometries that have the OVERLAPBDYINTERSECT relationship with a query window (here, a rectangle with lower-left, upper-right coordinates 4,6, 8,8). (The example uses the definitions and data described in Section 2.1 and illustrated in Figure 2-1.) In this example, cola_a, cola_b, and cola_d have the OVERLAPBDYINTERSECT relationship with the query window geometry.
  FROM cola_markets c
  WHERE SDO_OVERLAPBDYINTERSECT(c.shape,
            ) = 'TRUE';
    MKT_ID NAME
         2 cola_b
         1 cola_a
         4 cola_d
SDO_OVERLAPS
Format
SDO_OVERLAPS(geometry1, geometry2);
Description
Checks if any geometries in a table overlap (that is, have the OVERLAPBDYDISJOINT or OVERLAPBDYINTERSECT topological relationship with) a specified geometry. Equivalent to specifying the SDO_RELATE operator with 'mask=OVERLAPBDYDISJOINT+OVERLAPBDYINTERSECT'.
Value Description
Returns
The expression SDO_OVERLAPS(geometry1,geometry2) = 'TRUE' evaluates to TRUE for object pairs that have the OVERLAPBDYDISJOINT or OVERLAPBDYINTERSECT topological relationship, and FALSE otherwise.
Usage Notes
Examples
The following example finds geometries that overlap a query window (here, a rectangle with lower-left, upper-right coordinates 4,6, 8,8). (The example uses the definitions and data described in Section 2.1 and illustrated in Figure 2-1.) In this example, three of the geometries in the SHAPE column overlap the query window geometry.
  FROM cola_markets c
  WHERE SDO_OVERLAPS(c.shape,
            ) = 'TRUE';
    MKT_ID NAME
         2 cola_b
         1 cola_a
         4 cola_d
SDO_RELATE
Format
SDO_RELATE(geometry1, geometry2, param);
Description
Uses the spatial index to identify either the spatial objects that have a particular spatial interaction with a given object such as an area of interest, or pairs of spatial objects that have a particular spatial interaction.
This operator performs both primary and secondary filter operations.
Value Description
param Uses the mask keyword to specify the topological relationship of interest. This is a required parameter.
Valid mask keyword values are one or more of the following in the nine-intersection pattern: TOUCH, OVERLAPBDYDISJOINT, OVERLAPBDYINTERSECT, EQUAL, INSIDE, COVEREDBY, CONTAINS, COVERS, ANYINTERACT, ON. Multiple masks are combined with the logical Boolean operator OR, for example, 'mask=inside+touch'; however, see the Usage Notes for an alternative syntax using UNION ALL that may result in better performance. See Section 1.8 for an explanation of the nine-intersection relationship pattern.
For backward compatibility, any additional keywords for the param parameter that were supported in the previous release will still work; however, the use of those keywords is discouraged and is not supported for new uses of the operator.
Returns
The expression SDO_RELATE(geometry1,geometry2, 'mask = <some_mask_val>') = 'TRUE' evaluates to TRUE for object pairs that have the topological relationship specified by <some_mask_val>, and FALSE otherwise.
Usage Notes
The operator must always be used in a WHERE clause, and the condition that includes the operator should be an expression of the form SDO_RELATE(arg1, arg2, 'mask = <some_mask_val>') = 'TRUE'.
Unlike with the SDO_GEOM.RELATE function, DISJOINT and DETERMINE masks are not allowed in the relationship mask with the SDO_RELATE operator. This is because SDO_RELATE uses the spatial index to find candidates that may interact, and the information to satisfy DISJOINT or DETERMINE is not present in the index.
Although multiple masks can be combined using the logical Boolean operator OR, for example, 'mask=inside+coveredby', better performance may result if the spatial query specifies each mask individually and uses the UNION ALL syntax to combine the results. This is due to internal optimizations that Spatial can apply under certain conditions when masks are specified singly rather than grouped within the same SDO_RELATE operator call. For example, consider the following query using the logical Boolean operator OR to group multiple masks:
SELECT a.gid
  FROM polygons a, query_polys B
  WHERE B.gid = 1
  AND SDO_RELATE(A.Geometry, B.Geometry,
                   'mask=inside+coveredby') = 'TRUE';
The preceding query may result in better performance if it is expressed as follows, using UNION ALL to combine results of multiple SDO_RELATE operator calls, each with a single mask:
SELECT a.gid
      WHERE B.gid = 1
                   'mask=inside') = 'TRUE'
UNION ALL
SELECT a.gid
      WHERE B.gid = 1
                   'mask=coveredby') = 'TRUE';
Examples
The following examples are similar to those for the SDO_FILTER operator; however, they identify a specific type of interaction (using the mask keyword), and they determine with certainty (not mere likelihood) if the spatial interaction occurs.
The following example selects the geometries that have any interaction with a query window (here, a rectangle with lower-left, upper-right coordinates 4,6, 8,8). (The example uses the definitions and data from Section 2.1.)
  FROM cola_markets c
  WHERE SDO_RELATE(c.shape,
      SDO_ORDINATE_ARRAY(4,6, 8,8)),
    'mask=anyinteract') = 'TRUE';
    MKT_ID NAME
         2 cola_b
         1 cola_a
         4 cola_d
The following example selects the GID values from the POLYGONS table where the GEOMETRY column objects have any spatial interaction with the GEOMETRY column object in the QUERY_POLYS table that has a GID value of 1.
SELECT A.gid
  WHERE B.gid = 1
                   'mask=ANYINTERACT') = 'TRUE';
The following example selects the GID values from the POLYGONS table where a GEOMETRY column object has any spatial interaction with the geometry stored in the aGeom variable.
Select A.Gid
  FROM Polygons A
  WHERE SDO_RELATE(A.Geometry, :aGeom, 'mask=ANYINTERACT') = 'TRUE';
The following example selects the GID values from the POLYGONS table where a GEOMETRY column object has any spatial interaction with the specified rectangle having the lower-left coordinates (x1,y1) and the upper-right coordinates (x2, y2).
Select A.Gid
  FROM Polygons A
  WHERE SDO_RELATE(A.Geometry, sdo_geometry(2003,NULL,NULL,
                                   sdo_ordinate_array(x1,y1,x2,y2)),
The following example selects the GID values from the POLYGONS table where the GEOMETRY column object has any spatial interaction with any GEOMETRY column object in the QUERY_POLYS table. In this example, the ORDERED optimizer hint is used and QUERY_POLYS (geometry2) table is specified first in the FROM clause, because multiple geometries from geometry2 are involved (see the Usage Notes).
  A.gid
  WHERE SDO_RELATE(A.Geometry, B.Geometry, 'mask=ANYINTERACT') = 'TRUE';
Related Topics
SDO_TOUCH
Format
SDO_TOUCH(geometry1, geometry2);
Description
Checks if any geometries in a table have the TOUCH topological relationship with a specified geometry. Equivalent to specifying the SDO_RELATE operator with 'mask=TOUCH'.
Value Description
Returns
The expression SDO_TOUCH(geometry1,geometry2) = 'TRUE' evaluates to TRUE for object pairs that have the TOUCH topological relationship, and FALSE otherwise.
Usage Notes
Examples
The following example finds geometries that have the TOUCH relationship with a query window (here, a rectangle with lower-left, upper-right coordinates 1,1, 5,7). (The example uses the definitions and data described in Section 2.1 and illustrated in Figure 2-1.) In this example, only cola_b has the TOUCH relationship with the query window geometry.
  FROM cola_markets c
  WHERE SDO_TOUCH(c.shape,
            ) = 'TRUE';
  FROM cola_markets c
    MKT_ID NAME
         2 cola_b
SDO_WITHIN_DISTANCE
Format
SDO_WITHIN_DISTANCE(geometry1, aGeom, params);
Description
Uses the spatial index to identify the set of spatial objects that are within some specified distance of a given object (such as an area of interest or point of interest).
Value Description
geometry1 Specifies a geometry column in a table. The column has the set of geometry objects that will be operated on to determine if they are within the specified distance of the given object (aGeom). The column must be spatially indexed.
aGeom Specifies the object to be checked for distance against the geometry objects in geometry1. Specify either a geometry from a table (using a bind variable) or a transient instance of a geometry (using the SDO_GEOMETRY constructor).
params A quoted string containing one or more keywords (with values) that determine the behavior of the operator. The remaining items (distance, querytype, and unit) are potential keywords for the params parameter.
distance Specifies the distance value. If a coordinate system is associated with the geometry, the distance unit is assumed to be the unit associated with the coordinate system. This is a required keyword.
querytype Set 'querytype=FILTER' to perform only a primary filter operation. If querytype is not specified, both primary and secondary filter operations are performed (default).
unit Specifies the unit of measurement: a quoted string with unit= and an SDO_UNIT value from the MDSYS.SDO_DIST_UNITS table (for example, 'unit=KM'). See Section 2.6 for more information about unit of measurement specification.
Data type is NUMBER. Default = unit of measurement associated with the data. For geodetic data, the default is meters.
Returns
The expression SDO_WITHIN_DISTANCE(arg1, arg2, arg3) = 'TRUE' evaluates to TRUE for object pairs that are within the specified distance, and FALSE otherwise.
Usage Notes
Distance between two extended objects (nonpoint objects such as lines and polygons) is defined as the minimum distance between these two objects. The distance between two adjacent polygons is zero.
The operator must always be used in a WHERE clause and the condition that includes the operator should be an expression of the form:
SDO_WITHIN_DISTANCE(arg1, arg2, 'distance = <some_dist_val>') = 'TRUE'
The geometry column must have a spatial index built on it. If the data is geodetic, the spatial index must be an R-tree index.
SDO_WITHIN_DISTANCE is not supported for spatial joins. See Section 4.2.1.3 for a discussion on how to perform a spatial join within-distance operation.
Examples
The following example selects the GID values from the POLYGONS table where the GEOMETRY column object is within 10 distance units of the geometry stored in the aGeom variable.
SELECT A.GID
FROM POLYGONS A
WHERE
SDO_WITHIN_DISTANCE(A.Geometry, :aGeom, 'distance = 10') = 'TRUE';
The following example selects the GID values from the POLYGONS table where the GEOMETRY column object is within 10 distance units of the specified rectangle having the lower-left coordinates (x1,y1) and the upper-right coordinates (x2, y2).
SELECT A.GID
FROM POLYGONS A
WHERE
SDO_WITHIN_DISTANCE(A.Geometry, sdo_geometry(2003,NULL,NULL,
The following example selects the GID values from the POLYGONS table where the GID value in the QUERY_POINTS table is 1 and a POLYGONS.GEOMETRY object is within 10 distance units of the QUERY_POINTS.GEOMETRY object.
SELECT A.GID
FROM POLYGONS A, Query_Points B
WHERE B.GID = 1 AND
SDO_WITHIN_DISTANCE(A.Geometry, B.Geometry, 'distance = 10') = 'TRUE';
See also the more complex SDO_WITHIN_DISTANCE examples in Section C.2.
Related Topics
