Skip Headers
Oracle9i Application Server Certified Configuration Deployment and Cloning Guide
Release 2.0.6 for Linux x86
Part No. B10953-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous Next
B Component Port Numbers
This appendix lists the port numbers of your Oracle9i Application Server Certified Configuration (Oracle9iAS CC).
This appendix covers the following topic:
Port Numbers
The following table lists Oracle9iAS CC ports by component names. The port number range is used during Oracle9iAS installation. If the default port number is not available, then the Installer will use the next available port from the range available to the component.
Table B-1 Oracle9iAS Port Usage Sorted by Component
Component Default Port Number Port Number Range
Oracle9iAS Clickstream Intelligence
Oracle9iAS Clickstream Collector Server 6675 Fixed
Oracle9iAS Clickstream Execution Engine 6676 Fixed
Oracle9iAS Clickstream Intelligence Viewer Same as Oracle HTTP Server Same as Oracle HTTP Server
Oracle9iAS Clickstream Runtime Administrator Same as Oracle HTTP Server Same as Oracle HTTP Server
Oracle9iAS Containers for J2EE (OC4J)
OC4J AJP 3001 3001-3100
OC4J RMI 3101 3101-3200
OC4J JMS 3201 3201-3300
OC4J HTTP Listener 3301 3301-3400
Oracle9iAS Discoverer
IIOP 16001 16001-16020
Oracle9iAS Forms Services
Oracle HTTP Server
Oracle HTTP Server non-SSL 7777 7777-7877
Oracle HTTP Server SSL 4443 4443-4543
Oracle HTTP Server Listen non-SSL 7777 7777-7877
Oracle HTTP Server non-SSL- Oracle9iAS Web Cache is installed and configured 7778 7777-7877
Oracle HTTP Server- SSL Oracle9iAS Web Cacheis installed and configured 4444 4443-4543
Oracle HTTP Server JServ Servlet Engine 8007 8007-8107
Oracle HTTP Server Oracle Notification Service Requested Port 6003 6003-6099
Oracle HTTP Server- Oracle Notification Service Local Port 6100 6100-6199
Oracle HTTP Server Oracle Notification Service Remote Port 6200 6200-6299
Oracle HTTP Server Java Object Cache 7000 7000-7010
Oracle9iAS Clickstream Intelligence Collector Agent 6666 6666-6674
Oracle9iAS Portal
Oracle9iAS Portal
Oracle9iAS Single Sign-On 7777 7777-7877
Oracle9iAS Reports Services
3000 3000-3010
SQL*Net For Developer6i Backward Compatibility Only 1950 1950-1960
Visigenics CORBA Reports 9i 14000 14000-14010
Oracle9iAS Unified Messaging
5100-5200 5100-5200
IMAP4 143 Fixed
IMAP4 SSL 993 Fixed
POP3 110 Fixed
POP3 SSL 995 Fixed
SMTP 25 Fixed
NNTP 119 Fixed
NNTP SSL 563 Fixed
Oracle9iAS Web Cache HTTP Listen non-SSL 7777 7777-7877
Oracle9iAS Web Cache HTTP Listen SSL 4443 4443-4543
Oracle9iAS Web Cache Administration 4000 4000-4030
Oracle9iAS Wireless
Oracle9iAS Wireless
Oracle9iAS Wireless Integration Server 5555 Fixed
Oracle Enterprise Manager
Oracle Enterprise Manager Application Server Administration Service 1810, 1811 1812-1820
Oracle Enterprise Manager Intelligent Agent 1748, 1754, 1808, 1809 Fixed
Oracle Management Server 7771, 7772, 7773 7771-7773
Oracle Internet Directory
Oracle Internet Directory- non-SSL 389 4031-4040
Oracle Internet Directory- SSL 636 4031-4040
Oracle Internet File System
Oracle Internet File System Domain Controller and Nodes 53140 Fixed
Oracle Internet File System Domain Controller 53140 Fixed
Main Oracle Internet File System Node 53141, 53142 53141-53142
Oracle Internet File System HTTP Node 53143, 53144 53143-53144
LDAP non-SSL Same as Unified Messaging Same as Unified Messaging
LDAP SSL Same as Unified Messaging Same as Unified Messaging
AFP 548 Fixed
FTP 21 2100-2110
NFS 2049 4048-4049 for Mount Server
IMAP Same as Oracle Internet Directory Same as Oracle Internet Directory
IMAP4 SSL Same as Oracle Internet Directory Same as Oracle Internet Directory
Servlet 13138 13138-13140
SMTP Same as Unified Messaging Same as Unified Messaging
SMB 139 Fixed
CUP 4180 4180-4200
Oracle Net Listener
TNS 1521 Fixed
