| Oracle9i Warehouse Builder User's Guide Release 9.2 Part Number B10996-01 |
The Warehouse Builder provides a set of pre-built views for both the Design and Runtime Repositories. These views are called the Warehouse Builder Public Views. Use these views to access to data stored in these repositories. This appendix contains a catalog of the Public Views and their descriptions.
Warehouse Builder Design Repository Public Views
Warehouse Builder Runtime Repository Public Views
The design repository contains all of the design metadata. Use these Public Views to access data about the design of your system. These views are used by Warehouse Builder Browser to provide metadata reporting.
| Column Name | Data Type | Description |
LANGUAGE_ID |
VARCHAR2(255) |
ID of the language |
LANGUAGE_NAME |
VARCHAR2(64) |
Name of the language |
ISBASELANGUAGE |
VARCHAR2(1) |
Is it a base language (e.g. EN, FR, etc.)? |
The Runtime Repository contains all of the deployment and execution audit data. Use these Public Views to access this data. These views are used by Runtime Audit Browser to provide audit reporting.
| Column Name | Type | Description |
map_run_id |
Number (22) |
Internal key to audit_map_run. |
target_name |
Varchar2 (2000) |
Name of mapping operator representing target table. |
![]() Copyright © 2001, 2003 Oracle Corporation. All Rights Reserved. |
