Skip Headers
Oracle® Transparent Gateway for DRDA Installation and User's Guide
10g Release 1 (10.1) for UNIX
Part No. B12009-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous Next
14 Developing Applications
The Oracle Transparent Gateway for DRDA allows applications written for the Oracle Database server to access tables in a DRDA database. This access can be virtually transparent by using synonyms or views of the DRDA tables accessed by a database link. However, fundamental SQL, datatype, and semantic differences exist between the Oracle Database server and DRDA databases. Read this chapter to learn about these differences.
This chapter provides information that is specific to this release of the Oracle Transparent Gateway for DRDA, including the following sections:
Gateway Appearance to Application Programs
An application that is written to access information in a DRDA database interfaces with an Oracle integrating server. When developing applications, keep the following information in mind:
Fetch Reblocking
The Oracle Database server supports fetch reblocking with the HS_RPC_FETCH_REBLOCKING parameter.
When the value of this parameter is set to ON (the default), the array size for SELECT statements is determined by the HS_RPC_FETCH_SIZE value. The HS_RPC_FETCH_SIZE parameter defines the number of bytes sent with each buffer from the gateway to the Oracle Database 10g server. The buffer might contain one or more qualified rows from the DRDA Server. This feature can provide significant performance enhancements, depending upon your application design, installation type, and workload.
The array size between the client and the Oracle Database 10g server is still determined by the Oracle application.
Refer to Chapter 12, "Configuring the Gateway", for more information.
Using Oracle Stored Procedures with the Gateway
The gateway stored procedure support is an extension of Oracle stored procedures. An Oracle stored procedure is a schema object that logically groups together a set of SQL and other PL/SQL programming language statements to perform a specific task. Oracle stored procedures are stored in the database for continued use. Applications use standard Oracle PL/SQL to call stored procedures.
Oracle stored procedures can be located in a local instance of the Oracle Database server and in a remote instance. Figure 14-1, "Calling Oracle Stored Procedures in a Distributed Oracle Environment" illustrates two stored procedures: oraproc1 is a procedure stored in the ORA1 Oracle instance, while oraproc2 is a procedure stored in the ORA2 Oracle instance.
Figure 14-1 Calling Oracle Stored Procedures in a Distributed Oracle Environment
Description of 14_01.gif follows
To maintain location transparency in the application, a synonym can be created:
CREATE SYNONYM oraproc2 FOR oraproc2@ora2;
After this synonym is created, the application no longer needs to use the database link specification to call the stored procedure at the remote Oracle instance.
In Figure 14-1, the second statement in oraproc1 is used to access a table in the ORA2 instance. In the same way, Oracle stored procedures can be used to access DB2 tables through the gateway.
Using DRDA Server Stored Procedures with the Gateway
The procedural feature of the gateway enables invocation of native DRDA Server stored procedures. In other words, the stored procedure is no longer defined in the Oracle Database server, but instead, is defined to the DRDA Server (for example., DB2/OS390). Again, standard Oracle PL/SQL is used by the Oracle application to run the stored procedure.
After the stored procedure is defined to the DRDA Server (for example., DB2/OS390), the gateway is able to use the existing DRDA Server definition to run the procedure. The gateway does not require special definitions to call the DB2 stored procedure.
In Figure 14-2, an Oracle application calls the empproc stored procedure that is defined to the DRDA Server (for example., DB2/OS390).
Figure 14-2 Running DRDA Server Stored Procedures
Description of 14_02.gif follows
From the perspective of the application, running the DB2 stored procedure is no different from invoking a stored procedure at a remote Oracle Database server instance.
Oracle Application and DRDA Server Stored Procedure Completion
As an example, suppose an Oracle Application attempts to invoke a stored procedure in a DB2/OS390 database. In order for an Oracle application to call a DB2 stored procedure, it is first necessary to create the DB2 stored procedure on the DB2 system by using the procedures documented in the IBM reference document for DB2 for OS/390 SQL.
After the stored procedure is defined to DB2, the gateway is able to access the data using a standard PL/SQL call. For example, an employee name, JOHN SMYTHE, is passed to the DB2 stored procedure REVISE_SALARY. The DB2 stored procedure retrieves the salary value from the DB2 database in order to calculate a new yearly salary for JOHN SMYTHE. The revised salary that is returned in RESULT is used to update the EMP table of an Oracle Database server:
DECLARE
  INPUT VARCHAR2(15);
  RESULT NUMBER(8,2);
BEGIN
  INPUT := 'JOHN SMYTHE';
  REVISE_SALARY@DB2(INPUT, RESULT);
  UPDATE EMP SET SAL = RESULT WHERE ENAME = INPUT;
END;
When the gateway receives a call to run a stored procedure on the DRDA Server (for example, DB2/OS390), it first does a lookup of the procedure name in the server catalog. The information that defines a stored procedure is stored in different forms on each DRDA Server. For example, DB2/OS390 V5.0 uses the table SYSIBM.SYSPROCEDURES, while DB2/OS390 V6.1 uses the table SYSIBM.SYSROUTINES and SYSIBM.SYSPARMS, and DB2/400 uses the table QSYS2.SYSPROCS and QSYS2.SYSPARMS. The gateway has a list of known catalogs to search, depending upon the DRDA Server that is being accessed.
The search order of the catalogs is dependent on whether the catalogs support Location designators (such as LUNAME in SYSIBM.SYSPROCEDURES), and Authorization or Owner IDs (such as AUTHID in SYSIBM.SYSPROCEDURES or OWNER in SYSIBM.SYSROUTINES).
Some DRDA Servers allow blank or public Authorization qualifiers. If the DRDA Server currently that is connected supports this form of qualification, the gateway will apply those naming rules when searching for a procedure name in the catalog.
The matching rules will first search for a Public definition, and then an Owner qualified procedure name. For more detailed information, refer to the IBM reference document for DB2 for OS/390 SQL.
Procedural Feature Considerations with DB2
The following are special considerations for using the procedural feature with the gateway:
  • DB2 stored procedures do not have the ability to coordinate, commit, and rollback activity on recoverable resources such as IMS or CICS transactions. Therefore, if the DB2 stored procedure calls a CICS or IMS transaction, then it is considered a separate unit of work and does not affect the completion of the stored procedure. This means that if you are running a DB2 stored procedure from an Oracle application, and if this procedure calls a CICS or IMS transaction, then the gateway cannot recover from any activity that occurred within the CICS or IMS transaction.
    For example, the CICS transaction could roll back a unit of work, but this does not prevent the gateway from committing other DB2 work contained within the DB2 stored procedure.
    Likewise, if the DB2 stored procedure updated an irrecoverable resource such as a VSAM file, then the gateway would consider this activity separate from its own recoverable unit of work.
  • PL/SQL records cannot be passed as parameters when invoking a DB2 stored procedure.
  • The gateway supports the SIMPLE linkage convention of DB2 stored procedures.
    The SIMPLE linkage convention means that the parameters that are passed to and from the DB2 stored procedure cannot be null.
Database Link Behavior
A connection to the gateway is established through a database link when it is first used in an Oracle session. In this context, connection refers to both the connection between the Oracle integrating server and the gateway, and to the DRDA network connection between the gateway and the target DRDA database. The connection remains established until the Oracle session ends. Another session or user can access the same database link and get a distinct connection to the gateway and DRDA database.
Connections to the DRDA database can be limited in an APPC configuration in a parallel session limit, or by other factors, such as memory, gateway parameters, or DRDA Server resources. In a TCP/IP configuration, only resource limits (such as memory) or limits on the number of connections by the DRDA Server will limit the number of connections between the gateway and the DRDA Server.
Oracle Database Server SQL Construct Processing
One of the most important features of the Oracle Open Gateways family of products is providing SQL transparency to the user and to the application programmer. Foreign SQL constructs can be categorized into four areas:
Compatible SQL Functions
The Oracle integrating server automatically forwards to the DRDA database compatible SQL functions–that is, SQL constructs with the same syntax and meaning on both the Oracle Database server and the DRDA database. These SQL constructs are forwarded unmodified. All of the compatible functions are column functions. Functions that are not compatible are either translated to an equivalent DRDA SQL function or are compensated (post-processed) by the Oracle Database server after the data is returned from the DRDA database.
Translated SQL Functions
Translated functions have the same meaning but different names between the Oracle integrating server and the DRDA database, but all applications must use the Oracle function name. These SQL constructs that are supported with different syntax (such as different function names) by the DRDA database, are automatically translated by the Oracle Database server and then forwarded to the DRDA database. The Oracle integrating server (in a manner that is transparent to your application) changes the function name before sending it to the DRDA database.
Compensated SQL Functions
Some advanced SQL constructs that are supported by the Oracle Database server may not be supported in the same manner, if at all, by the DRDA database. Compensated functions are those SQL functions that are not recognized by the DRDA Server. If a SELECT statement containing one of these functions is passed from the Oracle integrating server to the gateway, then the gateway removes the function before passing the SQL statement to the DRDA Server. The gateway passes the selected DRDA database rows to the Oracle integrating server. The Oracle integrating server then applies the function.
Post-Processing
The Oracle Database server can compensate for a missing or incompatible function by automatically excluding the incompatible SQL construct from the SQL request that is forwarded to the DRDA database. The Oracle Database server then retrieves the necessary data from the DRDA database and applies the function. This process is known as post-processing.
The gateway attempts to pass all SQL functions to DRDA databases. But when a DRDA database does not support a function that is represented in the computation, then the gateway changes that function. For example, if a program requests:
SELECT COS(X_COOR) FROM TABLE_X;
from a DB2/OS390 database, which does not support the meaning of COS, then the gateway changes the SELECT statement to:
SELECT X_COOR FROM TABLE_X;
All data in the X_COOR column of TABLE_X is passed from the DB2/OS390 database to the Oracle integrating server. After the data is moved to the Oracle integrating server, the COS function is performed.
If you are performing operations on large amounts of data that are stored in a DRDA database, then keep in mind that some functions require post-processing.
Native Semantic SQL Functions
Some SQL functions that are normally compensated may also be overridden, via the Native Semantics facility. If a SQL function has been enabled for Native Semantics, then the function may be passed on to the DRDA database for processing, instead of being compensated (post-processed). If a SQL function is enabled for Native Semantics and is therefore passed on the DRDA database for processing, then we describe the operation by saying that the SQL function was processed natively in the DRDA database. Refer to "Native Semantics" for more information.
DB2/OS390 SQL Compatibility
The ways that the Oracle Database server and gateway handle SQL functions for a DB2/OS390 database are shown in the following table:
Table 14-1 DB2/OS390 SQL Compatibility, by Oracle SQL Function
Oracle SQL Function Compatible Translated Compensated Native Semantics Candidate
ABS
Yes Yes
ACOS
Yes Yes
ADD_MONTHS
Yes
ASCII
Yes Yes
ASIN
Yes Yes
ATAN
Yes Yes
ATAN2
Yes Yes
AVG
Yes
CAST
Yes Yes
CEIL
Yes Yes
CHARTOROWID
Yes
CHR
Yes Yes
CONCAT
Yes
CONVERT
Yes Yes
COS
Yes Yes
COSH
Yes Yes
COUNT(*)
Yes
DECODE
Yes Yes
DUMP
Yes Yes
EXP
Yes Yes
FLOOR
Yes Yes
GREATEST
Yes Yes
HEXTORAW
Yes Yes
INITCAP
Yes Yes
INSTR
Yes Yes
INSTRB
Yes Yes
LAST_DAY
Yes
LEAST
Yes Yes
LENGTH
Yes Yes
LENGTHB
Yes Yes
LN
Yes Yes
LOG
Yes Yes
LOWER
Yes Yes
LPAD
Yes Yes
LTRIM
Yes Yes
MAX
Yes
MIN
Yes
MOD
Yes Yes
MONTHS_BETWEEN
Yes
NEW_TIME
Yes
NEXT_DAY
Yes
NLS_INITCAP
Yes Yes
NLS_LOWER
Yes Yes
NLS_UPPER
Yes Yes
NLSSORT
Yes Yes
NVL
VALUE
NVL2
Yes Yes
POWER
Yes Yes
RAWTOHEX
Yes Yes
REPLACE
Yes Yes
REVERSE
Yes Yes
ROUND
Yes Yes
ROWIDTOCHAR
Yes
RPAD
Yes Yes
RTRIM
Yes Yes
SIGN
Yes Yes
SIN
Yes Yes
SINH
Yes Yes
SOUNDEX
Yes
SQRT
Yes Yes
STDDEV
Yes Yes
SUBSTR
Yes Yes
SUBSTRB
Yes Yes
SUM
Yes
SYSDATE
Yes
TAN
Yes Yes
TANH
Yes Yes
TO_CHAR
Yes
TO_DATE
Yes
TO_LABEL
Yes
TO_MULTI_BYTE
Yes
TO_NUMBER
DECIMAL
Yes
TO_SINGLE_BYTE
Yes
TRANSLATE
Yes Yes
TRIM
STRIP Yes Yes
TRUNC
Yes Yes
UID
Yes
UPPER
Yes
USER
Yes
USERENV
Yes
VARIANCE
Yes Yes
VSIZE
Yes Yes
DB2/Universal Database SQL Compatibility
The ways that the Oracle Database server and gateway handle SQL functions for a DB2/UDB database are shown in the following table:
Table 14-2 DB2/Universal Database SQL Compatibility, by Oracle SQL Function
ABS
Yes
Yes
ACOS
Yes Yes
ADD_MONTHS
Yes
ASCII
Yes Yes
ASIN
Yes Yes
ATAN
Yes Yes
ATAN2
Yes Yes
AVG
Yes
CAST
Yes Yes
CEIL
Yes
Yes
CHARTOROWID
Yes
CHR
Yes
Yes
CONCAT
Yes
CONVERT
Yes Yes
COS
Yes
Yes
COSH
Yes Yes
COUNT(*)
Yes
DECODE
Yes Yes
DUMP
Yes Yes
EXP
Yes
Yes
FLOOR
Yes
Yes
GREATEST
Yes Yes
HEXTORAW
Yes Yes
INITCAP
Yes Yes
INSTR
Yes Yes
INSTRB
Yes Yes
LAST_DAY
Yes
LEAST
Yes Yes
LENGTH
Yes Yes
LENGTHB
Yes Yes
LN
Yes
Yes
LOG
Yes Yes
LOWER
LCASE
Yes
LPAD
Yes Yes
LTRIM
Yes Yes
MAX
Yes
MIN
Yes
MOD
Yes
Yes
MONTHS_BETWEEN
Yes
NEW_TIME
Yes
NEXT_DAY
Yes
Yes
NLS_INITCAP
Yes Yes
NLS_LOWER
Yes Yes
NLS_UPPER
Yes Yes
NLSSORT
Yes Yes
NVL
VALUE
NVL2
Yes Yes
POWER
Yes
Yes
RAWTOHEX
Yes Yes
REPLACE
Yes
Yes
REVERSE
Yes Yes
ROUND
Yes
Yes
ROWIDTOCHAR
Yes
RPAD
Yes Yes
RTRIM
Yes Yes
SIGN
Yes
Yes
SIN
Yes
Yes
SINH
Yes Yes
SOUNDEX
Yes
SQRT
Yes
Yes
STDDEV
Yes Yes
SUBSTR
Yes Yes
SUBSTRB
Yes Yes
SUM
Yes
SYSDATE
Yes
TAN
Yes
Yes
TANH
Yes Yes
TO_CHAR
Yes
TO_DATE
Yes
TO_LABEL
Yes
TO_MULTI_BYTE
Yes Yes
TO_NUMBER
DECIMAL
Yes
TO_SINGLE_BYTE
Yes
TRANSLATE
Yes Yes
TRIM
Yes Yes
TRUNC
Yes
Yes
UID
Yes
UPPER
UCASE
Yes
USER
Yes
USERENV
Yes
VARIANCE
Yes Yes
VSIZE
Yes Yes
DB2/400 SQL Compatibility
The ways that the Oracle Database server and gateway handle SQL functions for a DB2/400 database are shown in the following table:
Table 14-3 DB2/400 SQL Compatibility, by Oracle SQL Function
ABS
ABSVAL
Yes
ACOS
Yes Yes
ADD_MONTHS
Yes
ASCII
Yes Yes
ASIN
Yes Yes
ATAN
Yes Yes
ATAN2
Yes Yes
AVG
Yes
CAST
Yes Yes
CEIL
Yes Yes
CHARTOROWID
Yes
CHR
Yes Yes
CONCAT
Yes
CONVERT
Yes Yes
COS
Yes
Yes
COSH
Yes
Yes
COUNT(*)
Yes
DECODE
Yes Yes
DUMP
Yes Yes
EXP
Yes
Yes
FLOOR
Yes Yes
GREATEST
Yes Yes
HEXTORAW
Yes Yes
INITCAP
Yes Yes
INSTR
Yes Yes
INSTRB
Yes Yes
LAST_DAY
Yes
LEAST
Yes Yes
LENGTH
Yes Yes
LENGTHB
Yes Yes
LN
Yes
Yes
LOG
Yes Yes
LOWER
Yes Yes
LPAD
Yes Yes
LTRIM
Yes Yes
MAX
Yes
MIN
Yes
MOD
Yes Yes
MONTHS_BETWEEN
Yes
NEW_TIME
Yes
NEXT_DAX
Yes
NLS_INITCAP
Yes Yes
NLS_LOWER
Yes Yes
NLS_UPPER
Yes Yes
NLSSORT
Yes Yes
NVL
VALUE
NVL2
Yes Yes
POWER
Yes Yes
RAWTOHEX
Yes Yes
REPLACE
Yes Yes
REVERSE
Yes Yes
ROUND
Yes Yes
ROWIDTOCHAR
Yes
RPAD
Yes Yes
RTRIM
Yes Yes
SIGN
Yes Yes
SIN
Yes
Yes
SINH
Yes
Yes
SOUNDEX
Yes
SQRT
Yes
Yes
STDDEV
Yes
Yes
SUBSTR
Yes Yes
SUBSTRB
Yes Yes
SUM
Yes
SYSDATE
Yes
TAN
Yes
Yes
TANH
Yes
Yes
TO_CHAR
Yes
TO_DATE
Yes
TO_LABEL
Yes
TO_MULTI_BYTE
Yes
TO_NUMBER
Yes Yes
TO_SINGLE_BYTE
Yes
TRANSLATE
Yes Yes
TRIM
Yes Yes
TRUNC
Yes Yes
UID
Yes
UPPER
TRANSLATE
Yes
USER
Yes
USERENV
Yes
VARIANCE
VAR
Yes
VSIZE
Yes Yes
DB2/VM SQL Compatibility
The ways that the Oracle Database server and gateway handle SQL functions for a DB2/VM database are shown in the following table:
Table 14-4 DB2/VM SQL Compatibility, by Oracle SQL Function
ABS
Yes Yes
ACOS
Yes Yes
ADD_MONTHS
Yes
ASCII
Yes Yes
ASIN
Yes Yes
ATAN
Yes Yes
ATAN2
Yes Yes
AVG
Yes
CAST
Yes Yes
CEIL
Yes Yes
CHARTOROWID
Yes
CHR
Yes Yes
CONCAT
Yes
CONVERT
Yes Yes
COS
Yes Yes
COSH
Yes Yes
COUNT(*)
Yes
DECODE
Yes Yes
DUMP
Yes Yes
EXP
Yes Yes
FLOOR
Yes Yes
GREATEST
Yes Yes
HEXTORAW
Yes Yes
INITCAP
Yes Yes
INSTR
Yes Yes
INSTRB
Yes Yes
LAST_DAY
Yes
LEAST
Yes Yes
LENGTH
Yes Yes
LENGTHB
Yes Yes
LN
Yes Yes
LOG
Yes Yes
LOWER
Yes Yes
LPAD
Yes Yes
LTRIM
Yes Yes
MAX
Yes
MIN
Yes
MOD
Yes Yes
MONTHS_BETWEEN
Yes
NEW_TIME
Yes
NEXT_DAY
Yes
NLS_INITCAP
Yes Yes
NLS_LOWER
Yes Yes
NLS_UPPER
Yes Yes
NLSSORT
Yes Yes
NVL
VALUE
NVL2
Yes Yes
POWER
Yes Yes
RAWTOHEX
Yes Yes
REPLACE
Yes Yes
REVERSE
Yes Yes
ROUND
Yes Yes
ROWIDTOCHAR
Yes
RPAD
Yes Yes
RTRIM
Yes Yes
SIGN
Yes Yes
SIN
Yes Yes
SINH
Yes Yes
SOUNDEX
Yes
SQRT
Yes Yes
STDDEV
Yes Yes
SUBSTR
Yes Yes
SUBSTRB
Yes Yes
SUM
Yes
SYSDATE
Yes
TAN
Yes Yes
TANH
Yes Yes
TO_CHAR
Yes
TO_DATE
Yes
TO_LABEL
Yes
TO_MULTI_BYTE
Yes
TO_NUMBER
Yes Yes
TO_SINGLE_BYTE
Yes
TRANSLATE
Yes Yes
TRIM
Yes Yes
TRUNC
Yes Yes
UID
Yes
UPPER
Yes Yes
USER
Yes
USERENV
Yes
VARIANCE
Yes Yes
VSIZE
Yes Yes
Native Semantics
Because some of the advanced SQL constructs that are supported by the Oracle Database server may not be supported in the same manner (if at all) by the DRDA database, the Oracle Database server compensates for the missing or incompatible functionality by post-processing the DRDA database data with Oracle Database server functionality (Refer to the previous section, "Oracle Database Server SQL Construct Processing" for more information). This feature provides maximum transparency, but may impact performance. In addition, new versions of a particular DRDA database may implement previously unsupported functions or capabilities, or they may change the supported semantics in such a manner as to make them more compatible with Oracle Database server functions.
Some of the DRDA Servers also provide support for user-defined functions. The user may choose to implement Oracle Database server functions natively (in other words, in the DRDA database), thus allowing the DRDA Server to pass the function on to the underlying database implementation (for example, DB2). Native Semantics provides a method of allowing specific capabilities to be processed natively by the DRDA Server.
Various considerations must be taken into account when enabling the Native Semantic feature of a particular function because Native Semantics has advantages and disadvantages, which are typically a trade-off between transparency and performance. One such consideration is transparency of data coercion. The Oracle Database server provides coercion (implicit data conversion) for many SQL functions. This means that if the supplied value for a particular function is not correct, then Oracle will coerce the value (change it to the correct value type) before processing it. However, with the Native Semantic feature enabled, the value (exactly as provided) will be passed through to the DRDA Server for processing. In many cases, the DRDA Server will not be able to coerce the value to the correct type and will generate an error.
Another consideration involves the compatibility of parameters to a particular SQL function. For instance, the Oracle Database server implementation of SUBSTR allows negative values for the string index, whereas most DRDA Server implementations of SUBSTR do not allow negative values for the string index. However, if the application is implemented to invoke SUBSTR in a manner that is compatible with the DRDA Server, then the function will behave the same in either the Oracle Database server or the DRDA Server.
Another consideration is that the processing of a function at the DRDA Server may not be desirable due to resource constraints in that environment.
Refer to the "DRDA_CACHE_TABLE_DESC" parameter for details on enabling or disabling these capabilities. Refer to the Oracle Database SQL Reference for the Oracle Database server format of the following capabilities.
SQL Functions That Can Be Enabled
The following list contains SQL functions that are disabled (OFF) by default. They can be enabled (turned ON) as an option:
Table 14-5 List of SQL Functions That Can Be Enabled
ABS ACOS ASCII ASIN
ATAN ATAN2 CAST CEIL
CHR CONVERT COS COSH
DECODE DUMP EXP FLOOR
GREATEST HEXTORAW INITCAP INSTR
INSTRB LEAST LENGTH LENGTHB
LN LOG LOWER LPAD
LTRIM MOD NLS_INITCAP NLS_UPPER
NLS_LOWER NLSSORT NVL2 POWER
RAWTOHEX REPLACE REVERSE ROUND
RPAD RTRIM SIGN SIN
SINH SQRT STDDEV SUBSTR
SUBSTRB TAN TANH TO_NUMBER
TRANSLATE TRIM TRUNC UPPER
VARIANCE VSIZE
SQL Functions That Can Be Disabled
The following list shows the SQL functions that are enabled (ON) by default. They can be disabled (turned OFF) as an option:
  • GROUPBY
  • HAVING
  • ORDERBY
  • WHERE
ORDERBY controls sort order, which may differ at various sort locations. For example, with ORDERBY ON, a DB2 sort would be based on EBCDIC sorting order, whereas with ORDERBY OFF, an Oracle sort would be based on ASCII sorting order.
The other three functions, GROUPBY, HAVING, and WHERE, can take additional processing time. If you need to minimize the use of expensive resources, you should choose the settings of these functions so that the processing is performed on the cheaper resource.
SQL Set Operators and Clauses
The clauses WHERE and HAVING are compatible for all versions of the DRDA Server, meaning that they are passed unchanged to the DRDA Server for processing. Whether clauses GROUP BY and ORDER BY are passed to the DRDA Server, or compensated by the Oracle Database server, is determined by the Native Semantics Parameters (see the previous section).
The set operators UNION and UNION ALL are compatible for all versions of the DRDA Server, meaning that they are passed unchanged to the DRDA Server for processing. The set operators INTERSECT and MINUS are compensated on all versions of the DRDA Server except DB2/UDB. For DB2/UDB, INTERSECT is compatible and MINUS is translated to EXCEPT.
DRDA Datatype to Oracle Datatype Conversion
To move data between applications and the database, the gateway binds data values from a host variable or literal of a specific datatype to a datatype understood by the database. Therefore, the gateway maps values from any version of the DRDA Server into appropriate Oracle datatypes before passing these values back to the application or Oracle tool.
The following table lists the datatype mapping and restrictions. The DRDA Server datatypes that are listed in the table are general. Refer to documentation for your DRDA database for restrictions on datatype size and value limitations.
Table 14-6 Datatype Mapping and Restrictions
DRDA Server
Oracle External Criteria
CHAR(N) CHAR(N) < = 255
VARCHAR (N) VARCHAR2(N)
LONG
< = 2000
2000 < N < = 32740
LONG VARCHAR(N) VARCHAR2(N) < = 2000
LONG VARCHAR(N) LONG 2000 < N < = 32740
CHAR(N) FOR BIT DATA RAW(N) < = 255
VARCHAR(N) FOR BIT DATA RAW(N) 1 < = N < = 255
VARCHAR(N) FOR BIT DATA LONG RAW(N) 255 < N < = 32740
LONG VARCHAR(N) FOR BIT DATA RAW(N 1 < = < = 255
LONG VARCHAR(N) FOR BIT DATA LONG RAW(N) 255 < N < = 32740
DATE DATE Refer to Performing Date and Time Operations
TIME CHAR(8) See Performing Date and Time Operations
TIMESTAMP CHAR(26) See Performing Date and Time Operations
GRAPHIC CHAR(2N) N <= 127
VARGRAPHIC VARCHAR2(2N)
LONG
N <= 1000
1000 <= N <= 16370
LONG VARGRAPHIC VARCHAR2(2N)
LONG
N <= 1000
1000 <= N <= 16370
Floating Point Single FLOAT(21) n/a
Floating Point Double FLOAT(53) n/a
Decimal (P, S) NUMBER(P,S) n/a
Performing Character String Operations
The gateway performs all character string comparisons, concatenations, and sorts using the datatype of the referenced columns, and determines the validity of character string values passed by applications using the gateway. The gateway automatically converts character strings from one datatype to another and converts between character strings and dates when needed.
Frequently, DRDA databases are designed to hold non-character binary data in character columns. Applications executed on DRDA systems can generally store and retrieve data as though it contained character data. However, when an application accessing this data runs in an environment that uses a different character set, inaccurate data might be returned.
With the gateway running on the host, character data retrieved from a DB2/400, DB2/OS390, or DB2/VM host is translated from EBCDIC to ASCII. When character data is sent to DB2/400, DB2/OS390, or DB2/VM from the host, ASCII data is translated to EBCDIC. When the characters are binary data in a character column, this translation causes the application to receive incorrect information or errors. To resolve these errors, character columns on DB2/400, DB2/OS390, or DB2/VM that hold non-character data must be created with the FOR BIT DATA option. In the application, the character columns holding non-character data should be processed using the Oracle datatypes RAW and LONG RAW. The DESCRIBE information for a character column defined with FOR BIT DATA on the host always indicates RAW or LONG RAW.
Converting Character String Datatypes
The gateway binds character string data values from host variables as fixed-length character strings. The bind length is the length of the character string data value. The gateway performs this conversion on every bind.
The DRDA VARCHAR datatype can be from 1 to 32740 bytes in length. This datatype is converted to an Oracle VARCHAR2 datatype if it is between 1 and 2000 characters in length. If it is between 2000 and 32740 characters in length, it is converted to an Oracle LONG datatype.
The DRDA VARCHAR datatype can be no longer than 32740 bytes, which is much shorter than the maximum size for the Oracle LONG datatype. If you define an Oracle LONG datatype larger than 32740 bytes in length, you receive an error message when it is mapped to the DRDA VARCHAR datatype.
Performing Graphic String Operations
DB2 GRAPHIC datatypes store only double-byte string data. Sizes for DB2 GRAPHIC datatypes typically have maximum sizes which are half that of their Character counterparts. For example, the maximum size of a CHAR may be 255 characters, whereas the maximum size of a GRAPHIC may be 127 characters.
Oracle does not have a direct matching datatype, and the gateway therefore converts between Oracle Character datatypes and DB2 Graphic datatypes. Oracle character datatypes may contain single, mixed, or double-byte character data. The gateway converts the string data into appropriate double-byte-only format depending upon whether the target DB2 column is a Graphic type and whether gateway initialization parameters are set to perform this conversion. For more configuration information, refer to Appendix C, "DRDA-Specific Parameters" and Appendix D, "National Language Support".
The implementation of date and time data differs significantly in IBM DRDA databases and the Oracle Database server. The Oracle Database server has a single date datatype, DATE, that can contain both calendar date and time of day information.
IBM DRDA databases support the following three distinct date and time datatypes:
DATE is the calendar date only.
TIME is the time of day only.
TIMESTAMP is a numerical value combining calendar date and time of day with microsecond resolution in the internal format of the IBM DRDA database.
Processing TIME and TIMESTAMP Data
There is no built-in mechanism that translates the IBM TIME and TIMESTAMP data to Oracle DATE data. An application must process TIME datatypes to the Oracle CHAR format with a length of eight bytes. An application must process the TIMESTAMP datatype in the Oracle CHAR format with a length of 26 bytes.
An application reads TIME and TIMESTAMP functions as character strings and converts or subsets portions of the string to perform numerical operations. TIME and TIMESTAMP values can be sent to an IBM DRDA database as character literals or bind variables of the appropriate length and format.
Processing DATE Data
Oracle and IBM DATE datatypes are mapped to each other. If an IBM DATE is queried, then it is converted to an Oracle DATE with a zero (midnight) time of day. If an Oracle DATE is processed against an IBM DATE column, then the date value is converted to the IBM DATE format, and any time value is discarded.
Character representations of dates are different in Oracle format and IBM DRDA format. When an Oracle application SQL statement contains a date literal, or conveys a date using a character bind variable, the gateway must convert the date to an IBM DRDA compatible format.
The gateway does not automatically recognize when a character value is going to be processed against an IBM DATE column. Applications are required to distinguish character date values by enclosing them with Oracle TO_DATE function notation. For example, if EMP is a synonym or view that accesses data on an IBM DRDA database, then instead of this SQL statement:
SELECT * FROM EMP WHERE HIREDATE = '03-MAR-81'
you must use:
SELECT * FROM EMP WHERE HIREDATE = TO_DATE('03-MAR-81')
In a programmatic interface program that uses a character bind variable for the qualifying date value, you must use this SQL statement:
SELECT * FROM EMP WHERE HIREDATE = TO_DATE(:1)
The above SQL notation does not affect SQL statement semantics when the statement is executed against an Oracle table. The statement remains portable across Oracle and IBM DRDA-accessed data stores.
The TO_DATE function is not required for dates in any of the following formats:
  • YYYY-MM-DD (ISO/JIS)
  • DD.MM.YYYY (European)
  • MM/DD/YYYY (USA)
For example:
SELECT * FROM EMP WHERE HIREDATE = '1981-03-03'
The TO_DATE requirement also does not pertain to input bind variables that are in Oracle date 7-byte binary format. The gateway recognizes such values as dates.
Performing Date Arithmetic
The following forms of SQL expression generally do not work correctly with the gateway:
date + number
number + date
date - number
date1 - date2
The date and number addition and subtraction (date + number, number + date, date - number) forms are sent through to the DRDA Server, where they are rejected. The supported servers do not allow number addition or subtraction with dates.
Because of differing interpretations of date subtraction in the supported servers, subtracting two dates (date1 - date2) gives results that vary by server.
Avoid date arithmetic expressions in all gateway SQL until date arithmetic problems are resolved.
Dates
Date handling has two categories: two-digit year dates, which are treated as occurring 50 years before or 50 years after the year 2000, and four-digit year dates, which are not ambiguous with regard to the year 2000. Oracle Corporation recommends that you set the Oracle Database 10g server and gateway default HS_NLS_DATE_FORMAT parameter to a format including a four-digit year.
Use one of the following methods to enter twenty-first century dates:
  • The TO_DATE function
    Use any date format including a four character year field. Refer to the Oracle Database SQL Reference for the available date format string options.
    For example, TO_DATE('2008-07-23', 'YYYY-MM-DD') can be used in any SELECT, INSERT, UPDATE, or DELETE statement.
  • The HS_NLS_DATE_FORMAT parameter
    The HS_NLS_DATE_FORMAT parameter defines a default format for the Oracle Database server explicit TO_DATE functions without a pattern and for implicit string to date conversions.
    For example, with HS_NLS_DATE_FORMAT defined as 'YYYY-MM-DD', '2008-07-23' can be used in any SELECT, INSERT, UPDATE, or DELETE statement.
HS_NLS_DATE_FORMAT Support
The following table lists the four patterns that can be used for the HS_NLS_DATE_FORMAT.
DB2 Date Format Pattern Example
EUR DD.MM.YYYY 30.10.1994
ISO YYYY-MM-DD 1994-10-30
JIS YYYY-MM-DD 1994-10-30
USA MM/DD/YYYY 10/30/1994
The Oracle default format of 'DD-MON-YY' is not allowed with DB2. As a result, the gateway local date exit is provided to change the Oracle default date format of 'DD-MON-YY' or 'DD-MON-RR' to the DB2 ISO format of 'YYYY-MM-DD' before passing the date to DB2.
The following example demonstrates the most efficient way to enter and select date values in the twenty-first century:
ALTER SESSION SET HS_NLS_DATE_FORMAT = 'YYYY-MM-DD';
INSERT INTO EMP (HIREDATE) VALUES ('2008-07-23');
SELECT * FROM EMP WHERE HIREDATE = '2008-07-23';
UPDATE EMP SET HIREDATE = '2008-07-24'
DELETE FROM EMP WHERE HIREDATE = '2008-07-24';
Oracle TO_DATE Function
The Oracle TO_DATE function is preprocessed in SQL INSERT, UPDATE, DELETE, and SELECT WHERE clauses. TO_DATE functions in SELECT result lists are not preprocessed.
The TO_DATE function is often needed to provide values to update or compare with date columns. Therefore, the gateway replaces the information included in the TO_DATE clause with an acceptable value before the SQL statement is sent to DB2.
Except for the SELECT result list, all TO_DATE functions are preprocessed and turned into values that are the result of the TO_DATE function. Only TO_DATE(literal) or TO_DATE(:bind_variable) is allowed. Except in SELECT result lists, the TO_DATE(column_name) function format is not supported.
The preprocessing of the Oracle TO_DATE functions into simple values is useful in an INSERT VALUES clause because DB2 does not allow functions in the VALUES clause. In this case, DB2 receives a simple value in the VALUES list. All forms of the TO_DATE function (with one, two, or three operands) are supported.
Performing Numeric Datatype Operations
IBM versions of the DRDA Server perform automatic conversions to the numeric datatype of the destination column (such as integer, double-precision floating point, or decimal). The user has no control over the datatype conversion, and this conversion can be independent of the datatype of the destination column in the database.
For example, if PRICE is an integer column of the PRODUCT table in an IBM DRDA database, then the update shown in the following example inaccurately sets the price of an ice cream cone to $1.00 because the IBM DRDA Server automatically converts a floating point to an integer:
UPDATE PRODUCT
SET PRICE = 1.50
WHERE PRODUCT_NAME = 'ICE CREAM CONE    ';
Because PRICE is an integer, the IBM DRDA Server automatically converts the decimal data value of 1.50 to 1.
Mapping the COUNT Function
The Oracle Database server supports the following four operands for the COUNT function:
  • COUNT(*)
  • COUNT(DISTINCT colname)
  • COUNT(ALL colname)
  • COUNT(colname)
The default is COUNT(ALL colname).
IBM versions of the DRDA Server support only two operands for the COUNT function:
  • COUNT(*)
When an Oracle application issues a COUNT(colname) or a COUNT(ALL colname), the gateway translates the request to COUNT(*), which is compliant DRDA Server SQL syntax. COUNT(*) includes null values whereas COUNT(colname) or COUNT(ALL colname) does not.
To prevent null rows from being counted, when using COUNT(colname) or COUNT(ALL colname) against a DRDA Server, use the following commands:
SELECT COUNT(colname) FROM EMP WHERE colname IS NOT NULL
or
SELECT COUNT(ALL colname) FROM EMP WHERE colname IS NOT NULL
Performing Zoned Decimal Operations
A zoned decimal field is described as packed decimal on an Oracle Database server. However, an Oracle application such as a Pro*C program can insert into a zoned decimal column using any supported Oracle numeric datatype. The gateway converts this number into the most suitable datatype. Data can be fetched from a DRDA database into any Oracle datatype, provided that it does not result in a loss of information.
Passing Native SQL Statements through the Gateway
The passthrough SQL feature allows an application developer to send a SQL statement directly to the DRDA Server without the statement being interpreted by the Oracle Database server. DBMS_HS_PASSTHROUGH.EXECUTE_IMMEDIATE SQL passthrough statements that are supported by the gateway are limited to nonqueries (INSERT, UPDATE, DELETE, and DDL statements) and cannot contain bind variables. The gateway can run native SQL statements using DBMS_HS_PASSTHROUGH.EXECUTE_IMMEDIATE.
DBMS_HS_PASSTHROUGH.EXECUTE_IMMEDIATE is a built-in gateway function. This function receives one input argument and returns the number of rows affected by the SQL statement. For DDL statements, the function returns zero.
DBMS_HS_PASSTHROUGH.EXECUTE_IMMEDIATE are reserved names of the gateway and are used specifically for running native SQL.
This release of Oracle Transparent Gateway for DRDA enables retrieval of result sets from queries issued with passthrough. The syntax is different from the DBMS_HS_PASSTHROUGH.EXECUTE_IMMEDIATE function. Refer to "Retrieving Results Sets Through Passthrough" for more information.
Using DBMS_HS_PASSTHROUGH.EXECUTE_IMMEDIATE
Using the DBMS_HS_PASSTHROUGH.EXECUTE_IMMEDIATE function
To run a passthrough SQL statement using DBMS_HS_PASSTHROUGH.EXECUTE_IMMEDIATE, use the following syntax:
number_of_rows = DBMS_HS_PASSTHROUGH.EXECUTE_IMMEDIATE@dblink ('native_DRDA_sql');
where:
number_of_rows  is a variable that is assigned the number of rows affected by the passthrough SQL completion. For DDL statements, a zero is returned for the number of rows affected.
dblink  is the name of the database link used to access the gateway.
native_DRDA_sql  is a valid nonquery SQL statement (except CONNECT, COMMIT, and ROLLBACK). The statement cannot contain bind variables. Native SQL statements that cannot be dynamically prepared are rejected by the DRDA Server. The SQL statement passed by the DBMS_HS_PASSTHROUGH.EXECUTE_IMMEDIATE function must be a character string. For more information regarding valid SQL statements, refer to the SQL Reference for the particular DRDA Server.
Examples
  1. Insert a row into a DB2 table using DBMS_HS_PASSTHROUGH.EXECUTE_IMMEDIATE:
    DECLARE
      num_rows integer;
    BEGIN
    num_rows:=DBMS_HS_PASSTHROUGH.EXECUTE_IMMEDIATE@dblink
    ('INSERT  INTO SCOTT.DEPT VALUES (10,''PURCHASING'',''PHOENIX'')');
    END;
  2. Create a table in DB2 using DBMS_HS_PASSTHROUGH.EXECUTE_IMMEDIATE:
    DECLARE
      num_rows integer;
    BEGIN
      ('CREATE TABLE MYTABLE (COL1 INTEGER, COL2 INTEGER, COL3 CHAR(14),
      COL4 VARCHAR(13))');
    END;
Oracle Transparent Gateway for DRDA provides a facility to retrieve results sets from a SELECT SQL statement entered through passthrough. Refer to Oracle Database Heterogeneous Connectivity Administrator's Guide for additional information.
Example
DECLARE
  CRS binary_integer;
  RET binary_integer;
  VAL VARCHAR2(10)
BEGIN
  CRS:=DBMS_HS_PASSTHROUGH.OPEN_CURSOR@gtwlink;
  DBMS_HS_PASSTHROUGH.PARSE@gtwlink(CRS,'SELECT NAME FROM PT_TABLE');
BEGIN
  RET:=0;
  WHILE (TRUE)
  LOOP
    RET:=DBMS_HS_PASSTHROUGH.FETCH_ROW@gtwlink(CRS,FALSE);
    DBMS_HS_PASSTHROUGH.GET_VALUE@gtwlink(CRS,1,VAL);
    INSERT INTO PT_TABLE_LOCAL VALUES(VAL);
  END LOOP;
  EXCEPTION
    WHEN NO_DATA_FOUND THEN
      BEGIN
        DBMS_OUTPUT.PUT_LINE('END OF FETCH');
        DBMS_HS_PASSTHROUGH.CLOSE_CURSOR@gtwlink(CRS);
      END;
    END;
END;
Oracle Data Dictionary Emulation on a DRDA Server
The gateway optionally augments the DRDA database catalogs with data dictionary views modeled after the Oracle data dictionary. These views are based on the dictionary tables in the DRDA database, presenting that catalog information in views familiar to Oracle users. The views created during the installation of the gateway automatically limit the data dictionary information presented to each user based on the privileges of that user.
Using the Gateway Data Dictionary
The gateway data dictionary views provide users with an Oracle-like interface to the contents and use of the DRDA database. Some of these views are required by Oracle products. The gateway supports the DB2/OS390, DB2/400, and DB2/UDB catalog views. DB2/VM catalog views are not available.
You can query the gateway data dictionary views to see the objects in the DRDA database and to determine the authorized users of the DRDA database. Many Oracle catalog views are supported by the Oracle Transparent Gateway for DRDA. Refer to Appendix A for descriptions of Oracle DB2 catalog views. These views are completely compatible with the gateway.
Using the DRDA Catalog
Each DRDA database has its own catalog tables and views, which you might find useful. Refer to the appropriate IBM documentation for descriptions of these catalogs.
Defining the Number of DRDA Cursors
You can define any number of cursors depending on your application requirements. Oracle Corporation recommends that you use the default value of 100. However, if the default is not appropriate for your application, there are two points to consider when defining the number of cursors for your installation:
  1. Each cursor requires an additional amount of storage and additional management.
  2. If you change DRDA_PACKAGE_SECTIONS, you must rebind the package.
The parameter DRDA_PACKAGE_SECTIONS is specific to the DRDA package. This parameter defines the number of sections (open cursors at the IBM database). Refer to Appendix C, "DRDA-Specific Parameters" for more information about setting the DRDA_PACKAGE_SECTIONS parameter.
