Skip Headers
Oracle® Transparent Gateway for DRDA Installation and User’s Guide
10g Release 1 (10.1.0.2.0) for Microsoft Windows
Part Number B12010-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous Next
G Sample Applications
This appendix contains sample applications that can be used with the gateway:
G.1 DB2INS
DB2INS is a sample DB2 stored procedure that inserts a row into a DB2 table.  This procedure uses the SIMPLE linkage convention.
/* This DB2 stored procedure inserts values for the DNAME and LOC    */
/* columns of DB2 user table SCOTT.DEPT.                             */
/* The SCOTT.DEPT table is defined to DB2 as                         */
/*       DEPTNO INTEGER, DNAME CHAR(14), LOC VARCHAR(13).            */
/* This procedure receives 3 input parameters from the calling       */
/* program which contain the values to insert for DEPTNO, DNAME, and */
/* LOC.                                                              */
/* The linkage convention used for this stored procedure is SIMPLE.  */
/* The output parameter for this procedure contains the SQLCODE from */
/* the INSERT operation.                                             */
/* The entry in the DB2 catalog table SYSIBM.SYSPROCEDURES for this  */
/* stored procedure might look like this:                            */
/* INSERT INTO SYSIBM.SYSPROCEDURES                                  */
/*   (PROCEDURE, AUTHID, LUNAME, LOADMOD, LINKAGE, COLLID, LANGUAGE, */
/*    ASUTIME, STAYRESIDENT, IBMREQD, RUNOPTS, PARMLIST)             */
/* VALUES                                                            */
/*   ('DB2INS',  ' ', ' ', 'DB2INS', ' ', 'DB2DEV', 'C', '0', ' ',   */
/*    'N', ' ', 'A INT IN, B CHAR(14) IN, C VARCHAR(13) IN,          */
/*    D INT OUT, E CHAR(10) OUT');                                   */
#pragma runopts(plist(os))
#include <stdlib.h>
  EXEC SQL INCLUDE SQLCA;
/* Declare C variables for SQL operations on the parameters.  These  */
/* are local variables to the C program which you must copy to and   */
/* from the parameter list provided to the stored procedure.         */
  EXEC SQL BEGIN DECLARE SECTION;
  long dno;               /* input parm - DEPTNO */
  char dname[15];         /* input parm - DNAME  */
  char locale[14];        /* input parm - LOC    */
  EXEC SQL END DECLARE SECTION;
main(argc,argv)
  int argc;
  char *argv[];
/* Copy the input parameters into the area reserved in the local     */
/* program for SQL processing.                                       */
   dno = *(int *) argv[1];
   strcpy(dname, argv[2]);
   strcpy(locale, argv[3]);
/* Issue SQL INSERT to insert a row into SCOTT.DEPT                  */
 EXEC SQL INSERT INTO SCOTT.DEPT VALUES(:dno, :dname, :locale);
/* Copy SQLCODE to the output parameter list.                        */
   *(int *) argv[4] = SQLCODE;
G.2 ORAIND
ORAIND is a sample host program that calls a DB2 stored procedure (DB2INS) to insert a row into a DB2 table.
/* This sample ProC program calls DB2 stored procedure DB2INS to     */
/* insert values into the DB2 user table SCOTT.DEPT.  This calling   */
/* program uses embedded PL/SQL to call the stored procedure.        */
#include <stdio.h>
        VARCHAR         username[20];
        VARCHAR         password[20];
        int             dept_no;
        char            dept_name[14];
        VARCHAR         location[13];
        int             code;
        char            buf[11];
        int             x;
main()
/* Setup Oracle user id and password                                  */
  strcpy(username.arr, "SCOTT");          /* copy the username */
  username.len = strlen(username.arr);
  strcpy(password.arr, "TIGER");          /* copy the password */
  password.len = strlen(password.arr);
  EXEC SQL WHENEVER SQLERROR GOTO sqlerror;
/* Logon to Oracle                                                   */
  EXEC SQL CONNECT :username IDENTIFIED BY :password;
  printf("\nConnected to ORACLE as user: %s\n", username.arr);
  /* Delete any existing rows from DB2 table */
  EXEC SQL DELETE FROM SCOTT.DEPT@GTWLINK;
  EXEC SQL COMMIT;
/*------------------------ begin pl/sql block -----------------------*/
/* Insert 1 row into DB2 table SCOTT.DEPT by invoking DB2 stored     */
/* procedure DB2INS.  The DB2 stored procedure will perform the      */
/* INSERT.                                                           */
/* SCOTT.DEPT table is defined on DB2 as:                            */
/*    DEPTNO    INTEGER;                                             */
/*    DNAME     CHAR(14);                                            */
/*    LOC       VARCHAR(13);                                         */
  EXEC SQL EXECUTE
  BEGIN
     :dept_no := 10;
     :dept_name := 'GATEWAY';
     :location := 'ORACLE';
     DB2INS@GTWLINK(:dept_no, :dept_name, :location, :code);
  END;
  END-EXEC;
/*------------------------- end pl/sql block ------------------------*/
/* Check the SQLCODE returned from the stored procedures INSERT.     */
  if (code == 0)
    printf("DB2INS reports successful INSERT\n");
  else
    printf("DB2INS reports error on INSERT.\nSQLCODE=%d\n",code);
    goto sqlerror;
/* Verify row insertion.  Query the data just inserted.              */
   EXEC SQL SELECT deptno, dname, loc INTO
      FROM SCOTT.DEPT@GTWLINK WHERE deptno = 10;
   printf("\nData INSERTed was:\n");
   printf("\ndeptno = %d, dname = %s, loc = %s\n",
          dept_no, dept_name, location.arr);
/* Logoff from Oracle                                                */
  EXEC SQL COMMIT RELEASE;
  printf("\n\nHave a good day\n\n");
  exit(0);
  sqlerror:
    printf("\n% .70s \n", sqlca.sqlerrm.sqlerrmc);
    EXEC SQL WHENEVER SQLERROR CONTINUE;
    EXEC SQL ROLLBACK RELEASE;
    exit(1);
