Skip Headers
Oracle® Transparent Gateway for DRDA Installation and User’s Guide
10g Release 1 (10.1.0.2.0) for Microsoft Windows
Part Number B12010-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous Next
B Sample Files
This appendix contains sample files of gateway initialization and Oracle Net tnsnames.ora and listener.ora files.
B.1 Sample Gateway Initialization File
The following sample Gateway Initialization File (inithoa1.ora) needs customization. For information on customizing this file, refer to "Configuring the Host" in Chapter 10, " Configuring the Gateway". Also refer to Appendix C.
# HS specific parameters
FDS_CLASS=TG4DRDA_DB2MVS
#TRACE_LEVEL=255
#LOG_DESTINATION=DB2.log
#ORACLE_DRDA_TCTL=debug.tctl
HS_COMMIT_POINT_STRENGTH=255
HS_NLS_DATE_FORMAT=YYYY-MM-DD
HS_LANGUAGE=AMERICAN_AMERICA.WE8ISO8859P1
HS_RPC_FETCH_REBLOCKING=off
HS_RPC_FETCH_SIZE=32767
HS_FDS_FETCH_ROWS=20
# DRDA specific parameters
DRDA_CONNECT_PARM=DRDACON1
DRDA_REMOTE_DB_NAME=DB2V7R1
DRDA_PACKAGE_COLLID=ORACLE
DRDA_PACKAGE_NAME=G2DRSQL
DRDA_PACKAGE_CONSTOKEN=A92617CB3FE54701
DRDA_RECOVERY_USERID=ORADRDA
DRDA_RECOVERY_PASSWORD=ORADRDA
DRDA_ISOLATION_LEVEL=CS
#DRDA_PACKAGE_OWNER=ORADRDA
#DRDA_DISABLE_CALL=TRUE
B.2 Sample Oracle Net tnsnames.ora File
For information on tailoring your tnsnames.ora file for the gateway, refer to the instructions for "Configuring Oracle Net ".
ipc-ora=(DESCRIPTION=
             (ADDRESS=
                 (PROTOCOL=IPC)
                 (KEY=ORCL)
             (CONNECT_DATA=(SID=ORA101))
            (HS=)
ipc-gw=(DESCRIPTION=
           (ADDRESS=
               (PROTOCOL=IPC)
               (KEY=ORCL)
           (CONNECT_DATA=(SID=drdahoa1))
				           (HS=)
B.3 Sample Oracle Net listener.ora File
For information on tailoring your listener.ora file for the gateway, refer to the instructions in "Configuring Oracle Net ".
# Sample listener.ora file for the Transparent Gateway for IBM DRDA
# Version Date: Jan-01-2002
# Filename: Listener.ora
LISTENER =
  (ADDRESS_LIST =
        (ADDRESS= (PROTOCOL= IPC)(KEY= ORCL))
SID_LIST_LISTENER =
  (SID_LIST =
    (SID_DESC=
      (SID_NAME=drdahoa1)
      (ORACLE_HOME=C:\Oracle\GTWHome)
      (PROGRAM=g4drsrv)
STARTUP_WAIT_TIME_LISTENER = 0
CONNECT_TIMEOUT_LISTENER = 10
TRACE_LEVEL_LISTENER = OFF
This sample listener.ora resides in the %ORACLE_HOME%\network\admin directory. If your listener uses the Oracle Net TCP/IP adapter instead of the IPC adapter, then replace these lines under the LISTENER keyword:
        (ADDRESS=
           (PROTOCOL=IPC)
           (KEY=ORCL)
with
        (ADDRESS=
           (PROTOCOL=TCP)
           (HOST=your_IP_node_name)
           (PORT=your_port_number)
