Oracle® Enterprise Manager Metric Reference Manual
10g Release 1 (10.1) Part No. B12015-01 |
There are various metrics which can be used to monitor Forms Services.
The Load category provides information about the present Load generated by Forms processes.
This metric is calculated from the total amount of CPU being used by all the Forms processes.
By default, the thresholds for this metric are not defined The value for the thresholds can be edited as required.
The following table shows how often the metric's value is collected and compared against the default thresholds. The 'Consecutive Number of Occurrences Preceding Notification' column indicates the consecutive number of times the comparison against thresholds should hold TRUE before an alert is generated.
Table 7-1 Metric Summary Table
| Target Version | Evaluation and Collection Frequency | Upload Frequency | Operator | Default Warning Threshold | Default Critical Threshold | Consecutive Number of Occurrences Preceding Notification | Alert Text |
| All Versions | Every Minute | After Every 12 Samples | > | Not Defined | Not Defined | 1 | CPU Utilization is %value%%% |
This metric is calculated from the total amount of private and shared memory being used by all the Forms processes.
By default, this metric has a critical threshold of 90 and a warning threshold of 80. A critical alert is generated when the metric value exceeds the critical threshold value 1 time. A warning alert is generated when the metric value exceeds the warning threshold value 1 time. The value for the thresholds can be edited as required.
Table 7-2 Metric Summary Table
| All Versions | Every Minute | After Every 12 Samples | > | 80 | 90 | 1 | Memory Utilization is %value%%% |
This metric reports the total number of Forms sessions being monitored by Enterprise Manager.
The following table shows how often the metric's value is collected.
| Target Version | Collection Frequency |
The Response category provides information about the responsiveness of the Forms Servlet.
This metric displays the response time in milliseconds for the Oracle Forms Servlet.
By default, this metric has a critical threshold of 1000 and a warning threshold of 500. A critical alert is generated when the metric value exceeds the critical threshold value 1 time. A warning alert is generated when the metric value exceeds the warning threshold value 1 time. The value for the thresholds can be edited as required.
Table 7-3 Metric Summary Table
| All Versions | Every Minute | After Every 12 Samples | > | 500 | 1000 | 1 | The Forms Listener response time is unacceptable. |
By default, this metric has a critical threshold of 0 indicating that the Forms Servlet is unreachable. A critical alert is generated when the metric value equals the critical threshold value once. It is advisable that this threshold be left at the default value.
Table 7-4 Metric Summary Table
| All Versions | Every Minute | After Every 12 Samples | =
Not Defined | 0 | 1 | The Forms instance is not accessible. |
