Oracle® Enterprise Manager Metric Reference Manual
10g Release 1 (10.1) Part No. B12015-01 |
Oracle Enterprise Manager can be used to manage OracleAS Wireless Server. You can also use Enterprise Manager to view Oracle Wireless Server metrics that have been collected by the Oracle Management Agent.
This metric category includes metrics that denote the current number of active OracleAS Wireless users.
This metric category includes metrics that denote the number of active OracleAS Wireless sessions.
This metric category includes metrics that denote the average response time during the last five minutes.
This metric denotes the average response time during the last five minutes.
The following table shows how often the metric's value is collected and compared against the default thresholds. The 'Consecutive Number of Occurrences Preceding Notification' column indicates the consecutive number of times the comparison against thresholds should hold TRUE before an alert is generated.
Table 18-1 Metric Summary Table
| Target Version | Evaluation and Collection Frequency | Upload Frequency | Operator | Default Warning Threshold | Default Critical Threshold | Consecutive Number of Occurrences Preceding Notification | Alert Text |
| All Versions | Every 5 Minutes | After Every Sample | > | 200 | 500 | 4 | Wireless device request response time is %value% of baseline. |
This metric category includes metrics that denote the (Up or Down) status of OracleAS Wireless Server.
This metric denotes the (Up or Down) status of the OracleAS Wireless Server.
Table 18-2 Metric Summary Table
| All Versions | Every 5 Minutes | After Every Sample | =
Not Defined | 0 | 1 | Wireless status is down |
This metric category includes metrics that denote the number of services invoked during the last five minutes.
This metric denotes the Up or Down status (1 is Up; 0 is Down). The aggregated values are plotted to indicate the percentage of time OracleAS Wireless is Up. It also indicates the Up and Down intervals.
