Skip Headers
Oracle® Enterprise Manager Metric Reference Manual
10g Release 1 (10.1)
Part No. B12015-01
  Go To Table Of Contents
Contents
Previous Next
34 OVF Transfer Application
You can use Enterprise Manager to view metrics for the Oracle Voicemail and Fax transfer application.
34.1 Response
This category contains metrics about the response of the Oracle Voicemail and Fax transfer application.
34.1.1 Status
This metric shows the status of the Oracle Voicemail and Fax transfer application.
34.1.1.1 Metric Summary
The following table shows how often the metric's value is collected and compared against the default thresholds. The 'Consecutive Number of Occurrences Preceding Notification' column indicates the consecutive number of times the comparison against thresholds should hold TRUE before an alert is generated.
Table 34-1 Metric Summary Table
Target Version Evaluation and Collection Frequency Upload Frequency Operator Default Warning Threshold Default Critical Threshold Consecutive Number of Occurrences Preceding Notification Alert Text
All Versions Every 3 Minutes After Every Sample =
Not Defined 0 1 Transfer Application is down
34.1.1.2 User Action
Specific to your site.
