| Oracle9i Warehouse Builder Public API Release 9.2 |
| PREV NEXT | FRAMES NO FRAMES | ||||||||
Datatype represents a scalar datatype.Activity is the interface that defines the unit of execution
within a give process.ActivityType is a interface which describes the Activity TypesAtomicDerivationSource is a tagging interface that
indicates that a particular class can be the source of an atomic
Intelligence Object Derivation.Attribute interface represents a named, typed, holder of data,
contained within a data entity or a function.AttributeGroup interface represents a named custom grouping of
attributes.AttributeGroupOwner interface represents an abstract attribute
groups container.BaseLocation interface is the interface for all design level entities which
hold locations.BaseProcess is the interface that defines the base
functionality of all process interfaces namely ProcessFLow and SubProcess
.Datatype instance.
BusinessArea is a component of an Intelligence Module that
collects together Query Objects and IO Function definitions that are relevant
to a specific business interest.BusinessAreaShortcut represents a shortcut within a Business
Area to an Intelligence Object (either a Query Object or an IO Function).CannotSwitchConnModeException is an exception that is thrown
when the connection to OWB repository could not be switched into the desired
mode.CannotSwitchConnModeException with no detail
message.
CannotSwitchConnModeException with the specified
detail message.
CheckConstraint interface represents a CHECK integrity
constraint.ClassDefinitionManager is a factory class that can be used to
obtain ClassDefinition objects, from the class names.ClassDefNotFoundException is thrown when the definition of
a class cannot be found be the OWB typing system.CollectiveDerivationSource is a tagging interface that
indicates that a particular class can be the source of a collective
Intelligence Object Derivation.Column interface represents a relational data entity colum.ColumnOwner interface represents an abstract, ordered column
container.CompilableObject interface represents a Compilable Object.CompilationResult interface represents CompilationResult.Component is a large-grained metadata object, which usually
aggregates multiple objects.ComponentDeletedException is an exception that is thrown when
the an object cannot be accessed because another user already deleted that
object.ComponentDeletedException with no detail
message.
ComponentDeletedException with the specified
detail message.
ConnectionFailureException is an exception that is thrown when
the connection to OWB repository fails to be established.ConnectionFailureException with no detail
message.
ConnectionFailureException with the specified
detail message.
LogicalConnector interface represents a logical connector between
an owning Location and a referenced Location.containsKey is a boolean checkup to see if this set of property definitions
includes the definition for the key.
CopyMoveManager contains operations to handle Component Copy/Move operations.AttributeGroupOwner.
Snapshot of components, Any invalid component on which Snapshot
can not be taken would fail whole operation.
Snapshot for a given component.
Cube is a logical multi-dimensional design object, which
contains a set of measures, and a set of dimensions.CubeDimensionUses.Datafile interface represents a physical file available to the
run time schema for use as the source of data for an external table.Datatype represents a datatype.DataTyped interface represents a typed metadata object.DatatypeSet represents a collection of dataypes, usualy
defining the valid dataypes for a language or for a schema.DatatypeSetManager class provides access to the supported
datatype sets.DeployServiceManager contains operations (e.g.DerivationException is an exception that is thrown whenever
the derivation process detects an error.DerivationException with no detail message.
DerivationException with the specified
detail message.
Dimension is a logical multi-dimensional design object,
which is often composed of one or more hierarchies, and one or more levels.Domain interface provides an extensible hierarchy
for defining value domains for properties/attributes in OWB.DomainManager class provides methods to create domains.DrillItem represents an item within a Drill Level.DrillLevel represents a group of query items that can be
drilled to or from within a drill path.DrillPath represents a drill path between Query Items within
a Query Object.EnumerationDomain interface defines a list of element values.ExpressionValidationInfo is an interface that specifies
the functionality for retrieving information about an expression
property validation.ExternalTable interface represents an Oracle database external table.ExternalTableColumn interface represents a external data entity column.Field interface represents a flat file entity field.AttributeGroupOwner.
Language object with the
given name.
FlatFile interface exposes the metadata for a logical flat file.FlatFileModule is a specialized Module which can contain FlatFiles.Datatype instance.
Folder is a special type of Component, which
can contain other components.ForeignKey interface represents a data entity foreign key
constraint.GatewayModule is a specialized Module, which represents a
logical Oracle gateway module.GeneratedScripts interface represents the generated scripts.GenerationServiceManager is a singleton class that manages
the validation and the compilation processes.AttributeGroupOwner.
this parameter is bound to.
Component for this object.
DatatypeSet for this Language.
LanguageManager.
LibraryManager
String objects representing the
names of all supported languages.
Language objects representing all
getPropSheet Retrieve the property sheet of a property type.
Snapshot objects existing in repository.
Snapshot within a time period, All Snapshot created between fromDate
toDate.
Snapshot with respect to time stamp.
Snapshot object with given name
This traversal implies Snapshot to Object paradigm.
Snapshot instances created by specified user.
Snapshot objects containing this Snapshotable.
Hierarchy is a logical structure that uses ordered levels as
means of organizing data.ImportServiceManager contains operations to handle importing metadata.IncompatibleTargetException is an exception that is thrown
whenever the user tries to paste a component into an incompatible target component.IncompatibleTargetException with no detail message.
IncompatibleTargetException with the specified
detail message.
IncompatibleTypesException is thrown by the reconcile service when the target type cannot be reconciled with the source type .Index interface represents a relational data entity index .IndexColumn interface represents a relational data entity IndexColumn.IndexPartitionOwner interface represents an abstract, ordered column
container.Datatype instance.
IntelligenceModule is a specialized Module, which represents
a collection of intelligence objects that define an instance of an EUL.IntelligenceObject is a tagging interface that indicates that
a particular class can be included in a Business Area.InvalidFormatException is an exception that is usually
thrown when the value being set to a property does not satisfy the required
format of the property (e.g.InvalidFormatException with no detail message.
InvalidFormatException with the specified
detail message.
InvalidReconcileStrategyException is thrown by the reconcile service when the reconcile strategy passed is not valid.InvalidSourceException is thrown by the reconcile service if the source object is not a valid reconcile source.InvalidTargetException is thrown by the reconcile service if the target object is not a valid reconcile target.IODerivationSource is a tagging interface that indicates that
a particular class can be the source of an Intelligence Object Derivation.IODerivationTarget is a tagging interface that indicates that
a particular class can be the target of an Intelligence Object Derivation.ItemClass defines a List Of Values for one or more
Query Items.Join represents a join from the current Query Object to
another Query Object.JoinComponent represents a component of a Join.KeyOwner interface represents an abstract keys container.Level represents a collection of dimension values that share
similar characteristics.LevelAttribute represents an attribute of the level.LevelIdentifier represents an identifier for the level, which
is composed of one or more level attributes.LibraryManager class provides access to the OWB built-in
global libraries.Datatype represents a scalar datatype.Location is a specialized BaseLocation, which can contain connectors.LockException is an exception that is thrown when
the lock for an object cannot be obtained because another user already
locked that object.LockException with no detail
message.
LockException with the specified
detail message.
Map is the interface that provides housekeeping for the
map operators within a map.MapAttribute is the interface that describes an
attribute group of an operator.MapAttributeGroup is the interface that describes an
attribute group of an operator.MapConnectionFailureException is an exception that is thrown whenever
a mapping connection between 2 mappables is attempted, and there is
a connection validation error.NameSpaceException with the specified
detail message.
MapDatatypeSet represents the valid dataypes allowed in
OWB maps.MapHelper is a code-generated interface that defines
strong-typed methods for specific operator types.MapOperator is the interface that describes an
operator within a map.MapOperatorHelper is a code-generated interface that defines
strong-typed methods for specific operator types.MapOperatorMatchingStrategy is the interface that
provides the matching strategy constants for reconciling with
map operators.Mappable is the interface that describes a mappable
object in a map, that can be connected to other mappable objects.MappingPropertyDatatypeSet contains the definitions of
all valid dataypes that can be assumed by mapping property values.MappingPropertyOwnerList implements a list of "named"
PropertyOwners.Datatype instance.
MappingPropertyOwnerList.
MapUtiltity is a static class which provides
static utility methods to help with mapping.MapUtilityGen is a code-generated class that implements
strong-typed methods for specific operator types.MatchingStrategy represents the strategy to be used by the reconcile service to match objects in the source and target.MatchingStrategyNotFoundException is thrown when the matching strategy specified by its name during reconcile invocation cannot be found.MaterializedView interface represents a relational database materialized view.Snapshot exceptions.Measure interaface represents a Cube measure.Messages interface represents messages.Module is a logical data entity container.NameSpaceException is an exception that is thrown whenever
the name being set on an object is not allowed due to a namespace constraint
violation.NameSpaceException with no detail message.
detail message.
NoSuchProjectException is an exception that is thrown whenever
the user tries to establish a current working project by passing the name
of a nonexistent project.NoSuchProjectException with no detail message.
NoSuchProjectException with the specified
detail message.
NoSuchPropertyException is an exception that is thrown whenever
the user tries to get or set a nonexistent property.NoSuchPropertyException with no detail message.
NoSuchPropertyException with the specified
detail message.
OracleDatatypeSet represents the valid dataypes allowed in
Oracle database and supported in OWB.OracleModule is a specialized Module, which represents a
logical Oracle database module.OWBCollection is an arbitrary grouping mechanism.OWBException is a runtime exception that usually signals either
a non-recoverable error, or an error the caller would normally not know how
to handle.OWBException with no detail message.
OWBException with the specified
detail message.
Partition interface represents a relational data entity index .PartitionKey interface represents a relational data entity index .PLSQLDatatypeSet represents the valid dataypes allowed in
PL/SQL language.ProcessActivityParameter Interface that encapsule an object that
can own several Parameter instances to create a signature.ProcessActivityParameterOwner Interface that encapsule an object that
can own several Parameter instances to create a signature.ProcessData an empty Interface.ProcessDatatypeSet represents the valid dataypes allowed in
OWB Process Flows.Process is a logical design for Process flow object
which is often composed of one or more Activities and Transitions.ProcessFlowModule is a specialized Module, which represents a
logical Process Flow module.ProcessFlowPackage is a container object for processflows.
