Oracle® E-Business Suite Certified Configuration Getting Started Guide
Release 11i (11.5.9) for AIX Based Systems, hp-ux PA-RISC (64-bit), Linux x86, and Solaris Operating System (SPARC 32-bit) Part No. B12138-01 |
This reference chapter contains information about the following topics:
Table A-1, Table A-2, Table A-3, and Table A-4 list the port numbers assigned to specific ports of Oracle Applications Release 11i (11.5.9) in the environments Test (TEST), Development (DEV), Stage (STAGE), and Production (PROD):
Table A-1 Oracle Applications 11i Environment Port Numbers
| Port | TEST | DEV | STAGE | PROD |
| Forms Start Port | 10501 | 10701 | 10901 | 10001 |
| JTF Fulfillment Server Port | 10502 | 10702 | 10902 | 10002 |
| iMeeting Collaboration Server Port | 10503 | 10703 | 10903 | 10003 |
| iMeeting Recording Server Port | 10504 | 10704 | 10904 | 10004 |
| iMeeting Monitor Port | 10505 | 10705 | 10905 | 10005 |
| Map Viewer Servlet Port | 10506 | 10706 | 10906 | 10006 |
| OEM Web Utility Port | 10507 | 10707 | 10907 | 10007 |
| VisiBroker OrbServer Agent Port | 10508 | 10708 | 10908 | 10008 |
| MCSA Server Port | 10509 | 10709 | 10909 | 10009 |
| Listener Port | 10510 | 10710 | 10910 | 10010 |
| RPC Port | 10511 | 10711 | 10911 | 10011 |
| MCSA Dispatcher Port | 10512 | 10712 | 10912 | 10012 |
| Forms Port | 10513 | 10713 | 10913 | 10013 |
| Reports Port | 10514 | 10714 | 10914 | 10014 |
| Web Port | 10515 | 10715 | 10915 | 10015 |
| Web Servlet Port | 10516 | 10716 | 10916 | 10016 |
| Web PL/SQL Port | 10517 | 10717 | 10917 | 10017 |
| Metric Server Data Port | 10518 | 10718 | 10918 | 10018 |
| Metric Server Req Port | 10519 | 10719 | 10919 | 10019 |
| Oproc Manager Port | 10520 | 10720 | 10920 | 10020 |
| VisiBroker Gatekeeper Port | 10552 | 10752 | 10952 | 10052 |
| Forms Servlet Port Range | 20500-20519 | 20700-20719 | 20900-20919 | 20000-20019 |
| OACORE Servlet Port Range | 20520-20529 | 20720-20729 | 20920-20929 | 20020-20029 |
| Discoverer Servlet Port Range | 20530-20539 | 20730-20739 | 20930-20939 | 20030-20039 |
| Web Xmls Port Range | 20540-20549 | 20740-20749 | 20940-20949 | 20040-20049 |
Table A-2 Oracle Internet Directory Environment Port Numbers
| OID Server Port | 10537 | 10737 | 10937 | 10037 |
| OID Database Listener Port | 10583 | 10783 | 10983 | 10083 |
| OID Apache Port | 10584 | 10784 | 10984 | 10084 |
| OID Apache Servlet Port | 10585 | 10785 | 10985 | 10085 |
Table A-3 Express Server Environment Port Numbers
| Express TCP Port | 10523 | 10723 | 10923 | 10023 |
| Express XSD Port | 10524 | 10724 | 10924 | 10024 |
| Express XSA Port | 10525 | 10725 | 10925 | 10025 |
| Express XSM Port | 10526 | 10726 | 10926 | 10026 |
| Express XCA Port | 10527 | 10727 | 10927 | 10027 |
| Express RO Port | 10528 | 10728 | 10928 | 10028 |
| Express Apache Port | 10550 | 10750 | 10950 | 10050 |
| Express Apache Servlet Port | 10551 | 10751 | 10951 | 10051 |
Table A-4 Support Agent Environment Port Numbers
| Port | Number |
| Oracle HTTP Server Port | 7778 |
| Oracle HTTP Server using HTTPS | 4443 |
| Port for issuing commands | 1813 |
In the event that the five basic environment types, IGOLD, TEST, DEV, STAGE and PROD, are not sufficient, there are an additional eighteen sets secondary ports available. To make use of these ports, use the letter assigned in place of the actual environment type ‘T’ or ‘D’. For example, to use slot 2 of the secondary Test ports, you would name your environment BABCDI, where abcd is the customer short code.
Table A-5 lists the secondary port numbers for the TEST environment.
Table A-5 Secondary TEST Environment Ports
| Port |
A (Slot 1) |
B (Slot 2) |
C (Slot 3) |
E (Slot 4) |
F (Slot 5) |
G (Slot 6) |
H (Slot 7) |
I (Slot 8) |
K (Slot 9) |
| Forms Start Port | 11501 | 12501 | 13501 | 14501 | 15501 | 16501 | 17501 | 18501 | 19501 |
| JTF Fulfillment Server Port | 11502 | 12502 | 13502 | 14502 | 15502 | 16502 | 17502 | 18502 | 19502 |
| iMeeting Collaboration Server Port | 11503 | 12503 | 13503 | 14503 | 15503 | 16503 | 17503 | 18503 | 19503 |
| iMeeting Recording Server Port | 11504 | 12504 | 13504 | 14504 | 15504 | 16504 | 17504 | 18504 | 19504 |
| iMeeting Monitor Port | 11505 | 12505 | 13505 | 14505 | 15505 | 16505 | 17505 | 18505 | 19505 |
| Map Viewer Servlet Port | 11506 | 12506 | 13506 | 14506 | 15506 | 16506 | 17506 | 18506 | 19506 |
| OEM Web Utility Port | 11507 | 12507 | 13507 | 14507 | 15507 | 16507 | 17507 | 18507 | 19507 |
| VisiBroker OrbServer Agent Port | 11508 | 12508 | 13508 | 14508 | 15508 | 16508 | 17508 | 18508 | 19508 |
| MCSA Server Port | 11509 | 12509 | 13509 | 14509 | 15509 | 16509 | 17509 | 18509 | 19509 |
| Listener Port | 11510 | 12510 | 13510 | 14510 | 15510 | 16510 | 17510 | 18510 | 19510 |
| RPC Port | 11511 | 12511 | 13511 | 14511 | 15511 | 16511 | 17511 | 18511 | 19511 |
| MCSA Dispatcher Port | 11512 | 12512 | 13512 | 14512 | 15512 | 16512 | 17512 | 18512 | 19512 |
| Forms Port | 11513 | 12513 | 13513 | 14513 | 15513 | 16513 | 17513 | 18513 | 19513 |
| Reports Port | 11514 | 12514 | 13514 | 14514 | 15514 | 16514 | 17514 | 18514 | 19514 |
| Web Port | 11515 | 12515 | 13515 | 14515 | 15515 | 16515 | 17515 | 18515 | 19515 |
| Web Servlet Port | 11516 | 12516 | 13516 | 14516 | 15516 | 16516 | 17516 | 18516 | 19516 |
| Web PL/SQL Port | 11517 | 12517 | 13517 | 14517 | 15517 | 16517 | 17517 | 18517 | 19517 |
| Metric Server Data Port | 11518 | 12518 | 13518 | 14518 | 15518 | 16518 | 17518 | 18518 | 19518 |
| Metric Server Req Port | 11519 | 12519 | 13519 | 14519 | 15519 | 16519 | 17519 | 18519 | 19519 |
| Oproc Manager Port | 11520 | 12520 | 13520 | 14520 | 15520 | 16520 | 17520 | 18520 | 19520 |
| VisiBroker Gatekeeper Port | 11552 | 12552 | 13552 | 14552 | 15552 | 16552 | 17552 | 18552 | 19552 |
| OACORE Servlet Port Range | 21520- 21529 |
22520- 22529 |
23520- 23529 |
24520- 24529 |
25520- 25529 |
26520- 26529 |
27520- 27529 |
28520- 28529 |
29520- 29529 |
| Discoverer Servlet Port Range | 21530- 21539 |
22530- 22539 |
23530- 23539 |
24530- 24539 |
25530- 25539 |
26530- 26539 |
27530- 27539 |
28530- 28539 |
29530- 29539 |
| Forms Servlet Port Range | 21500- 21519 |
22500- 22519 |
23500- 23519 |
24500- 24519 |
25500- 25519 |
26500- 26519 |
27500- 27519 |
28500- 28519 |
29500- 29519 |
| Web Xmls Port Range | 21540- 21549 |
22540- 22549 |
23540- 23549 |
24540- 24549 |
25540- 25549 |
26540- 26549 |
27540- 27549 |
28540- 28549 |
29540- 29549 |
Table A-6, lists the secondary port numbers for the DEV environment.
Table A-6 Secondary DEV Environment Ports
| Port |
L (Slot 1) |
M (Slot 2) |
N (Slot 3) |
O (Slot 4) |
Q (Slot 5) |
R (Slot 6) |
U (Slot 7) |
W (Slot 8) |
X (Slot 9) |
| Forms Start Port | 11701 | 12701 | 13701 | 14701 | 15701 | 16701 | 17701 | 18701 | 19701 |
| JTF Fulfillment Server Port | 11702 | 12702 | 13702 | 14702 | 15702 | 16702 | 17702 | 18702 | 19502 |
| iMeeting Collaboration Server Port | 11703 | 12703 | 13703 | 14703 | 15703 | 16703 | 17703 | 18703 | 19703 |
| iMeeting Recording Server Port | 11704 | 12704 | 13704 | 14704 | 15704 | 16704 | 17704 | 18704 | 19704 |
| iMeeting Monitor Port | 11705 | 12705 | 13705 | 14705 | 15705 | 16705 | 17705 | 18705 | 19705 |
| Map Viewer Servlet Port | 11706 | 12706 | 13706 | 14706 | 15706 | 16706 | 17706 | 18706 | 19706 |
| OEM Web Utility Port | 11707 | 12707 | 13707 | 14707 | 15707 | 16707 | 17707 | 18707 | 19707 |
| VisiBroker OrbServer Agent Port | 11708 | 12708 | 13708 | 14708 | 15708 | 16708 | 17708 | 18708 | 19708 |
| MCSA Server Port | 11709 | 12709 | 13709 | 14709 | 15709 | 16709 | 17709 | 18709 | 19709 |
| Listener Port | 11710 | 12710 | 13710 | 14710 | 15710 | 16710 | 17710 | 18710 | 19710 |
| RPC Port | 11711 | 12711 | 13711 | 14711 | 15711 | 16711 | 17711 | 18711 | 19711 |
| MCSA Dispatcher Port | 11712 | 12712 | 13712 | 14712 | 15712 | 16712 | 17712 | 18712 | 19712 |
| Forms Port | 11713 | 12713 | 13713 | 14713 | 15713 | 16713 | 17713 | 18713 | 19713 |
| Reports Port | 11714 | 12714 | 13714 | 14714 | 15714 | 16714 | 17714 | 18714 | 19714 |
| Web Port | 11715 | 12715 | 13715 | 14715 | 15715 | 16715 | 17715 | 18715 | 19715 |
| Web Servlet Port | 11716 | 12716 | 13716 | 14716 | 15716 | 16716 | 17716 | 18716 | 19716 |
| Web PL/SQL Port | 11717 | 12717 | 13717 | 14717 | 15717 | 16717 | 17717 | 18717 | 19717 |
| Metric Server Data Port | 11718 | 12718 | 13718 | 14718 | 15718 | 16718 | 17718 | 18718 | 19718 |
| Metric Server Req Port | 11719 | 12719 | 13719 | 14719 | 15719 | 16719 | 17719 | 18719 | 19719 |
| Oproc Manager Port | 11720 | 12720 | 13720 | 14720 | 15720 | 16720 | 17720 | 18720 | 19720 |
| VisiBroker Gatekeeper Port | 11752 | 12752 | 13752 | 14752 | 15752 | 16752 | 17752 | 18752 | 19752 |
| OACORE Servlet Port Range | 21720- 21729 |
22720- 22729 |
23720- 23729 |
24720- 24729 |
25720- 25729 |
26720- 26729 |
27720- 27729 |
28720- 28729 |
29720- 29729 |
| Discoverer Servlet Port Range | 21730- 21739 |
22730- 22739 |
23730- 23739 |
24730- 24739 |
25730- 25739 |
26730- 26739 |
27730- 27739 |
28730- 28739 |
29730- 29739 |
| Forms Servlet Port Range | 21700- 21719 |
22700- 22719 |
23700- 23719 |
24700- 24719 |
25700- 25719 |
26700- 26719 |
27700- 27719 |
28700- 28719 |
29700- 29719 |
| Web Xmls Port Range | 21740- 21749 |
22740- 22749 |
23740- 23749 |
24740- 24749 |
25740- 25749 |
26740- 26749 |
27740- 27749 |
28740- 28749 |
29740- 29749 |
Table A-7 lists the URLs for logging into the Oracle Applications 11i environments:
Table A-8 and Table A-9 list the Oracle Database and Oracle Applications 11i users and the corresponding initial passwords.
Table A-8 Initial Database 11i Passwords
| User | Password |
| Apps schema:
simple4u |
SYSTEM
simple4u
BOLINF
welcome
OHS_ACCNT
welcome |
RAC_ACCNT
welcome
WF_ACCNT
welcome
| BOL_BILLING | bol_billing
EUL4_US
eul4_us
portal30
portal30
portal30_sso
portal30_sso
sys
change_on_install
Table A-10 lists groups, and Table A-11 lists users that you create during installation.
Table A-10 Groups Created During Installation
| Group | Group ID |
dba
200
oaa
210
ocomsup
1122
usigroup
default |
Table A-11 Users Created During Installation
Note: For security reasons, the installation process deletes the following operating system users and groups:
