Oracle9i Application Server Certified Configuration Deployment and Cloning Guide
Release 2.0.6.0.1 for Solaris Operating Environment (SPARC 64-bit) Part No. B12185-01 |
Use this appendix for information about the deinstalling Oracle9i Application Server Certified Configuration (Oracle9iAS CC).
Use the following procedure to deinstall Oracle9iAS CC components:
Log in as the oracle user
Using the following command, start the Oracle Universal Installer:
$ /opt/oracle/oui/install/runInstaller.sh
The Welcome screen appears. Click Deinstall Product.
Select the ORACLE_HOME that you want to deinstall. The Oracle Universal Installer completes the deinstallation procedure
Delete all remaining files under the deinstalled ORACLE_HOME directory.
Run the following command to remove the entry for the deinstalled ORACLE_HOME from the Certified Configuration oraInventory file:
$ /admin/mwcc/registry/scripts/cc.inventory.sh delete OH_Path
where the variable OH_Path represents the path for the ORACLE_HOME that you deinstalled.
