Oracle® Application Server Repository Creation Assistant User’s Guide
10g (9.0.4.0.1) for UNIX Part No. B12260-02 |
If you need to deregister a metadata repository with Oracle Internet Directory, or if Oracle Application Server Repository Creation Assistant failed to register the metadata repository with Oracle Internet Directory, use the procedure described in this chapter to clean up the entries in Oracle Internet Directory.
You have to clean up the entries in Oracle Internet Directory before trying to register the metadata repository again.
Connect to Oracle Internet Directory using Oracle Directory Manager.
Start up Oracle Directory Manager.
prompt> $ORACLE_HOME/bin/oidadmin
In the Connect screen, enter the connect information. Log in as the Oracle Internet Directory superuser (cn=orcladmin).
Clean up the database registration entries in Oracle Internet Directory:
Expand the following entries (shown in Figure 4-1):
Expand "Entry Management".
Expand "cn=OracleContext".
Expand "cn=your_database_name".
Delete all the child entries under cn=your_database_name, starting with the bottom-most child entry.
Before deleting the cn=DESCRIPTION_0 entry, expand it until you reach the last child. Then delete each child starting with the innermost child.
To delete an entry, right-click each child entry and select Delete from the pop-up menu. Click Yes in the Confirmation dialog. When deleting some child entries, you may get some error messages. You can ignore these error messages.
Right-click cn=your_database_name and delete it.
Clean up the metadata repository registration entries in Oracle Internet Directory:
Expand the following entries (shown in Figure 4-2):
Expand "cn=Products".
Expand "cn=IAS".
Expand "cn=IAS Infrastructure Databases".
Expand "orclReferenceName=your_database_name".
Delete each child entry under orclReferenceName=your_database_name.
Delete the orclReferenceName=your_database_name entry.
Figure 4-2 Clean up Metadata Repository Registration Entries
