Skip Headers
Oracle® Database Installation Guide
10g Release 1 (10.1) for IBM z/OS (OS/390)
Part No. B13525-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
B Installation Reference
This appendix documents additional installation information that is referenced in the installation sections. It includes information on the following topics:
B.1 Choosing Data Set Name Qualifiers
The Oracle Database for z/OS installation setup and initialization process creates the first of several z/OS data sets. Later in the installation, you can specify the high-level and second-level data set name qualifiers that are used for subsequently created data sets.
Oracle recommends that you use the same qualifiers for all of the installation-related data sets. At this time, you need to choose and use the qualifiers that were selected during the installation process.
While choosing qualifiers, remember the following requirements:
B.2 Oracle Library Data Sets
This section describes the Oracle library data sets that were created during the installation process. You might not have all of these data sets on your system, depending on which products you selected to install.
Oracle Library Data Sets and their sizes are described in the following table:
Name CYLS Dsorg Recfm Lrecl Blksz
AUTHLOAD 300 PDSE U 0 27998
CMDLOAD 450 PDSE U 0 27998
H 6 PDS FB 80 8880
INSTLIB 2 PDSE FB 80 27920
MACLIB 2 PDS FB 80 27920
MESG 125 PDS U 0 27998
OBJLIB 1 PDS FB 80 27920
SQL 5 PDSE VB 2048 27998
SQLLIB 1 PDSE U 0 27798
SRCLIB 2 PDSE FB 80 27920
The following Oracle libraries can be created on your system depending on which products you select during the installation process.
