Skip Headers
Oracle® Transparent Gateway for DB2 Installation and User's Guide
10g Release 1 (10.1) for IBM z/OS (OS/390)
Part No. B13531-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous Next
B The Oracle SMF Interface
The IBM System Management Facility (SMF) provides a facility for users to collect and record a variety of system and job-related information.  SMF formats the information into a number of different records.  By creating analysis and report routines, installations can use the information in SMF records to track system usage.
The gateway service uses the standard SMF interface to write user records to SMF data sets.  These user records contain gateway service accounting and information allowing gateway installation sites to charge individual users for the resources they use
DB2 also uses SMF to collect and record data.  DB2 uses record types 100, 101, and 102.  Refer to your DB2 documentation for more information.
The following topics are included:
Activating SMF Records
Events Generating SMF Records
Interpreting an Oracle SMF Record
ORAFMTO Sample Formatting Program
B.1 Activating SMF Records
SMF recording is activated by updating the SMFPRMxx member of SYS1.PARMLIB to include the SYS or SUBSYS option.  These options record the gateway user record type.  If the SUBSYS option is used, then the SUBSYS name must match the OSDI subsystem name specified by the OSDI startup parameter.  Refer to the IBM documentation on System Management Facilities for information abut implementing SMF.
B.1.1 Specifying the Oracle Gateway Record Type
The default gateway user record type is 0 (zero).  A zero for this parameter indicates that no SMF statistics record is to be written.  You can override the default to any value between 128 and 255 by adding the SMF_STAT_RECNO (abbreviation is SMFSTRCN) to the OSDI gateway region parameter file.  The SMF record number that is chosen must not be the same as the number that is used by any other z/OS software.
Oracle Corporation recommends using SFM record number 199, but any available record number between 128 and 255 may be used.  Due to the differences in the report formatting programs, OSDI gateways and MPM gateway should use different SMF record numbers.
If this parameter is not specified, or if zero is specified, then no SMF statistics connection or recording is done.  This saves some CPU overhead and saves the overhead of the SMF write itself (which is mostly asynchronous work done by the SMF address space, and the in-line overhead is mostly just moving data into SMF buffers).
B.1.1.1 Using the OSDI SMF_STAT_RECNO Parameter
To override the default record type in the SMFPRMxx member, use the following syntax:
SMF_STAT_RECNO | SMFSTRCN
SMF_STAT_RECNO can be added as an OSDI parameter to the OSDI gateway region parameter data set to override the default record number 0. In the following example, 199 is the new SMF record type:
SMF_STAT_RECNO(199)
B.1.2 Starting SMF Recording
SMF recording of gateway accounting information starts automatically at startup if SMF is activated and the gateway record type is specified in the SMFPRMxx member
Because the standard system default record types activated for SMF are 128 through 255, and because the recommended value for the gateway service (199) is within this range, many sites automatically begin SMF recording of gateway records when the gateway is installed
If the SMF_STAT_RECNO is added or modified in the OSDI gateway region parameter file while the gateway is active, the service must be stopped and restarted for the parameter to take effect.
B.1.3 Stopping SMF Recording
The OSDI SMF_STAT_RECNO parameter can be used to stop SMF recording for Oracle.  To stop SMF recording for Oracle regardless of what your system tables specify, use:
SMF_STAT_RECNO (0)
or take the default of 0 (zero).  The service must be stopped and restarted for this parameter to take effect.
B.2 Events Generating SMF Records
After SMF recording is turned on, an SMF record is written each time a user logs off (normal termination or SMFINV set to SMFNORM), provided SMF is activated when the user logs on.
SMF records are also written on an abend or cancellation of a job if SMFINV=SMFABORT.
If the z/OS system crashes, then SMF records are not written and the information is lost.
B.3 Interpreting an Oracle SMF Record
To interpret a Oracle SMF record, you first need to dump the SMF data set to a sequential data set.  You can then write a program that does all of the following:
A sample program named ORAFMTO is provided in the SRCLIB library that you can customize for your installation.  Refer to "ORAFMTO Sample Formatting Program" for more information
The Assembler copy file, ORASMFO, contains DSECTS that map and document the gateway SMF record fields.  The ORASMFO data set member resides in the gateway SRCLIB library.
The ORASMF file is divided into the following sections:
Not all sections are present in all SMF records.  For example, the z/OS accounting section is present only in SMF records for batch and TSO users.  When a section is present, the SMF record header contains the correct length for that section, which might be release dependent, and the count field, which contains 1.  The length field for nonexistent sections contains 0.
B.3.1 Contents of the SMF Header Section
Table C-1 contains brief descriptions for the labels in the SMF header section.  For a complete layout of the contents of the SMF header section, refer to the DSECT.
Table B-1 Contents of the SMF Header Section
ORASMF0 Label Description
SMFHDR Standard SMF header
SMFHLEN Total length of the SMF record
SMFHSEG Segment descriptor = 0
SMFHSIN SYS IND = X'80' Subsystem information to follow SYS IND = x'40' Subtype format record
SMFHREC Record type default = 204 (decimal)
SMFHTIM Timestamp, time (.01 seconds since midnight)
SMFHDAT Timestamp, date (0cyyydddf) c=0 for 19xx, c=1 for 20xx
SMFHSYS System id
SMFHSSI OSDI Subsystem id
SMFHSUB Record subtype; 1 = accounting record
SMFSRVC OSDI service name
SMFSESID OSDI session id
SMFHRV1 Reserved
SMFNETO Offset to Net section
SMFACTO Offset to z/OS accounting section
SMFHRV2 Reserved
SMFNETL Length of Net section
SMFACTL Length of z/OS accounting section
SMFHRV3 Reserved
B.3.2 Contents of the SMF Correlation Section
Table 9-2 contains brief descriptions for the labels in the SMF correlation section.
Table B-2 Contents of the SMF Correlation Section
ORASMF Label Description
SMFAUTH Authorization id = TSO logon id Batch userid on jobcard CICS USERID, TERM-ID,TRANS-ID, PROGRAM-ID, or OPID
SMFCORI Correlation id = for TSO, logon id for batch, jobname for CICS, jobname NOt valid for Oracle Net
SMFCONN Connection type (TSO,BATCH,CICS,VTAM,TCP/IP,IMS)
SMFASID Users address space id (not valid for Oracle Net)
SMFOUSR Gateway logon id
SMFTNAME Originating terminal id (if available)
SMFPNAME Originating program name (if available)
SMFGRPN RACF group name (if available)
SMFJBID JES job identifier
SMFENTRY RDR jobcard entry date (batch and TSO only). This field is equivalent to the SMF5RST field in the SMF job termination (type 5) record.
SMFEDATE RDR jobcard entry date (batch and TSO only). This field is equivalent to the SMF5RSD field in the SMF job termination (type 5) record.
B.3.3 Contents of the SMF OSDI Data Section
Table B-3 Contents of the SMF OSDI Data Section
SMFTIM Beginning timestamp, time (.01 second since midnight)
SMFDAT Beginning timestamp, date (00yydddf), ending time and date in header
SMFDTAI Data in
SMFDTAO Data out
SMFXMCPU Cross memory CPU time (TOD format)
SMFRPCS RPC count
SMFHWST High-water mark of storage used
SMFINV Reason for invocation
SMFNORM Normal termination
SMFabort Clean up done
B.3.4 Contents of the SMF Database Engine Data Section
The database engine section is not applicable for Oracle Transparent Gateway for DB2.
Table B-4 Contents of the Database Engine Section
SMFLRC Logical read count
SMFPRC Physical read count
SMFLWC Logical writes
SMFDMC DML COMMITs
SMFDMR DML ROLLBACKs
SMFDED DEADLOCKs
SMFHDLN Length of SMF header
B.3.5 Contents of the SMF Oracle Net Data Section
Table B-5 Contents of the SMF Oracle Net Data Section
SMFNET Oracle Net section header
SMFNETL Length of Net NIV information. The information contained in this section is specific to the Oracle Net driver in use. This information is variable length.
SMFNETA Start of variable-length information
B.4 ORAFMTO Sample Formatting Program
A sample program, ORAFMTO, is provided with the gateway SMF interface to format gateway SMF records.  ORAFMTO is an Assembler program that reads and formats SMF accounting records with the default gateway type of 199.  It reads records from a variable-blocked sequential data set and writes the formatted records to a fixed block sequential data set with a logical record length of 132.
The sample ORAFMTO program is in the gateway SRCLIB library.  The following members are included:
Member Description
ORAFMTCL contains sample JCL to compile and link ORAFMTO.
ORAFMTGO contains sample JCL to run ORAFMTO.
ORAFMTO extracts and prints the following values from the gateway SMF records:
Table B-6 SMF Record Values
Value Description
SSN OSDI Subsystem name
SERVICE OSDI Service name
SMFAUTH Oracle userid assigned to the session using the database link.
SMFCONN Connection type (TSO, BATCH, VTAM, TCP/IP)
ORACLE ID User id assigned to the database link when the link is created.  If the dblink is created without an associated userid, it defaults to the Oracle userid.
DATE Start date of Oracle session
TIME Start time of Oracle session
CPU SECONDS Total CPU seconds used in the gateway address space.  This number does not include time spent in the Oracle server address space, nor in the DB2 address space.
LOG READS Not applicable to the gateway
PHY READS Not applicable to the gateway
LOG WRITES Not applicable to the gateway
DMC Not applicable to the gateway
DMR Not applicable to the gateway
DED Not applicable to the gateway
HI STG High-water mark of main storage used by the session
If any of the values are too large for the precision of their column, then they are shown as a series of asterisks.
Sample output from the ORAFMTO program:
SSN SMFAUTH SMFCONN ORACLE ID  DATE   TIME    TOTAL CPU SEC LOG READS LOG WRITES DMC DMR DDC DDR DED
ORA1 SSMITH BATCH   SCOTT    95.070 13:46:17.74       .755       152        23    6   2   1   1   0 ORA1 SSMITH BATCH   SCOTT    95.070 13:47:34.41       .193        88        23    6   2   1   1   0 ORA1 TJONES BATCH   SYSTEM   95.070 13:48:06.27       .269        95        23    6   2   1   1   0 ORA1 SSMITH BATCH   SCOTT    95.070 13:49:08.98       .084        36        10    3   2   0   0   0 ORA1 SSMITH BATCH   SCOTT    95.070 13:50:19.60       .120        21         2    1   0   0   0   0 ORA1        BATCH   SCOTT    95.070 13:52:04.67       .105        10        16    2   2   0   0   0 ORA1        BATCH   SCOTT    95.070 13:52:36.61      1.028       115         9    3   1   0   0   0 ORA1        BATCH   SCOTT    95.070 13:52:42.47       .576        71        23    5   3   1   1   0 ORA1        BATCH   SYSTEM   95.070  13:54:14.83      .110        10        16    2   2   0   0   0
