Skip Headers
Oracle® Application Server Reports Services Publishing Reports to the Web
10g (9.0.4)
Part Number B13673-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous Next
A Command Line Options
This appendix contains descriptions and examples of command line options that can be used with one or more of the following commands: rwclient, rwrun, rwbuilder, rwconverter, rwservlet, rwcgi, and rwserver. Each option description includes a table that indicates which commands can use which option keywords.
For examples of using command line options in your runtime URL, see Running Report Requests .
The following topics are discussed in this appendix:
A.1 Command Overview
This section provides a brief description of the commands whose keywords/options are discussed in this appendix, including:
Each command description includes a list of the keywords that can be used with it. In the command line, you must use the keyword along with its option. When you enter a command line, you can use the keywords in any order.
A.1.1 Keywords and applicable commands
This section lists the various keywords and their applicability to the 7 commands in Oracle Reports.
Table A-1 Keywords and the commands they can be used with
Kewords rwclient
rwrun
rwbuilder
rwconverter
rwservlet
rwcgi
rwserver
ACCESSIBLE
yes yes yes no yes yes no
ARRAYSIZE
AUTHID
yes yes no no yes yes yes
AUTOCOMMIT
AUTOSTART
no no no no no no yes
BACKGROUND
yes no no no yes yes no
BATCH
no no no yes no no yes
BCC
yes yes no no yes yes no
BLANKPAGES
BUFFERS
CACHELOB
CC
CELLWRAPPER
CMDFILE
yes yes yes yes no no no
CMDKEY
no no no no yes no no
COLLATE
CONTENTAREA
COPIES
CUSTOMIZE
yes yes no yes yes yes no
DATEFORMATMASK
DELAUTH
no no no no yes yes no
DELIMITED_HDR
DELIMITER
DESFORMAT
DESNAME
DEST
no no no yes no no no
DESTINATION
DESTYPE
DISTRIBUTE
DTYPE
DUNIT
ENGINERESPONSETIMEOUT
EXPIRATION
EXPIREDAYS
EXPRESS_SERVER
FORMSIZE
FROM
GETJOBID
GETSERVERINFO
HELP
INSTALL
ITEMTITLE
JOBNAME
JOBTYPE
JVMOPTIONS
no yes yes yes no no yes
KILLJOBID
LONGCHUNK
MIMETYPE
MODE
MODULE|REPORT
NONBLOCKSQL
NOTIFYFAILURE
NOTIFYSUCCESS
NUMBERFORMATMASK
OLAP_CON
ONFAILURE
ONSUCCESS
ORIENTATION
OUTPUTFOLDER
OUTPUTIMAGEFORMAT
OUTPUTPAGE
OVERWRITE
P_AVAILABILITY
P_DESCRIPTION
P_FORMATS
P_NAME
P_OWNER
P_PFORMTEMPLATE
P_PRINTERS
P_PRIVILEGE
P_SERVERS
P_TRIGGER
P_TYPES
PAGEGROUP
PAGESIZE
yes yes yes yes yes yes no
PAGESTREAM
PARAMFORM
PARSEQUERY
PDFCOMP
PDFEMBED
PRINTJOB
no no yes no no no no
READONLY
RECURSIVE_LOAD
REPLACEITEM
REPLYTO
REPORT|MODULE
ROLE
RUNDEBUG
SAVE_RDF
no yes yes no no no no
SCHEDULE
SERVER
yes no no no yes yes yes
SHOWAUTH
SHOWENV
SHOWJOBID
SHOWJOBS
SHOWMAP
SHOWMYJOBS
SHUTDOWN
SITENAME
SOURCE
SQLTRACE
SSOCONN
STATUSFOLDER
STATUSFORMAT
STATUSPAGE
STYPE
SUBJECT
SUPPRESSLAYOUT
TOLERANCE
TRACEFILE
yes yes yes no no no no
TRACEMODE
TRACEOPTS
yes yes yes no yes yes yes
UNINSTALL
UPGRADE_PLSQL
URLPARAMETER
USERID
WEBSERVER_DEBUG
WEBSERVER_DOCROOT
WEBSERVER_PORT
A.1.2 rwclient
The rwclient command parses and transfers a command line to the specified (or default) Reports Server. All file names and paths specified in rwclient refer to files and directories on the server machine, except for files specified in the CMDFILE keyword. In this case, the CMDFILE specified will be read and appended to the original command line (of which CMDFILE is a part) before being sent to the Reports Server. The runtime engine will not re-read the CMDFILE.
Examples
Example 1:
Running a paper report to a browser (cache)
rwclient server=myrepserv report=test.rdf userid=scott/tiger@mydb DESFORMAT=pdf DESTYPE=cache
Example 2:
Sending a report output to a file
rwclient server=myrepserv report=test.rdf userid=scott/tiger@mydb desformat=pdf DESTYPE=file DESNAME=c:\mydir\test
Example 3:
Sending a report output to a printer
rwclient server=myrepserv report=test.rdf userid=scott/tiger@mydb desformat=pdf DESTYPE=printer DESNAME=myprinter
Example 4:
Sending a report output via e-mail
rwclient server=myrepserv report=test.rdf userid=scott/tiger@mydb desformat=pdf DESTYPE=mail DESNAME="emp1@comp.com, emp2@comp.com" cc="emp3@comp.com" bcc="mgr@comp.com" replyto="me@comp.com" from="me@comp.com"
Example 5:
Sending a report output to WebDAV (any WebDAV server or OracleAS Portal WebDAV)
rwclient server=myrepserv report=test.rdf userid=scott/tiger@mydb desformat=htmlcss DESTYPE=webdav DESNAME="http://myusername:mypassword@mywebdavserv.com/mydir/test.html"
Example 6:
Sending a report output to OracleAS Portal
rwclient server=myrepserv report=test.rdf userid=scott/tiger@mydbDESTYPE=oracleportal desformat=PDF PAGEGROUP=mypagegrp OUTPUTPAGE=reports_output ITEMTITLE=pushtoportal STATUSPAGE=result
Example 7:
Sending an XML PDS report output to a file
rwclient server=myrepserv report=myxmlpdstest.rdf destype=file desformat=PDF desname=c:\mydir\my.pdf
Example 8:
Sending a JDBC PDS report output to a file
rwclient server=myrepserv report=myjdbcpdstest.rdf destype=file desformat=PDF desname=c:\mydir\myxml.pdf p_jdbcpds=sybuser/sybpwd@server1.mydomain.com:1300
Example 9:
Distributing a report output to multiple destinations:
rwclient server=myrepserv report=test.rdf userid=scott/tiger@mydbDISTRIBUTE=yes DESTINATION=c:\mydistribute.xml
Example 10:
Running scheduled reports
rwclient server=myrepserver report=test.rdfSCHEDULE="every first fri of month from 15:53 Oct 23, 1999 retry 3 after 1 hour"destype=file desformat=pdf desname=test.pdf
Example 11:
Using a secured Reports Server
AUTHIDrwclient server=myrepserv report=test.rdf userid=scott/tiger@mydb desformat=pdf destype=file desname=test.pdf =myadmin/myadmin
Example 12:
Running a report with e-mail notification
rwclient server=myrepserver report=test.rdf userid=scott/tiger@mydb destype=file desformat=pdf desname=test.pdfNOTIFYSUCCESS="emp@comp.com" NOTIFYFAILURE="admin@comp.com"
Example 13:
Running a report that specifies a URL to be fetched with the URL engine:
rwclient server=myrepserver report=test.rdf userid=scott/tiger@mydb destype=file desformat=pdf desname=test.pdfJOBTYPE=rwurl URLPARAMETER="http://www.oracle.com"
Example 14:
Running a report with the traceopts enabled
rwclient server=myrepserver report=test.rdf userid=scott/tiger@mydb destype=file desformat=pdf desname=test.pdfTRACEOPTS=trace_prf TRACEMODE=trace_replace
A.1.3 rwrun
The rwrun command runs a report using the OracleAS Reports Services in-process server. When you run a .rep file, the PL/SQL is already compiled and will not be recompiled. If you are running an .rdf file, the PL/SQL is automatically recompiled, if necessary. It becomes necessary if the report wasn't compiled and saved from Reports Builder or the platform or version on which you were running the report is incompatible with the platform on which it was last compiled and saved.
Examples
Example 1:
Customizing a report
rwrun userid=scott/tiger@mydb report=emp.rdfCUSTOMIZE=empcustomize.xml destype=file desformat=pdf desname=emp.pdf
Example 2:
rwrun report=test.rdf userid=scott/tiger@mydb desformat=pdf destype=cache
Example 3:
Sending report output to a file
rwrun report=test.rdf userid=scott/tiger@mydb desformat=pdf DESTYPE=file DESNAME=c:\mydir\test.pdf
Example 4:
rwrun report=test.rdf userid=scott/tiger@mydb desformat=pdfDESTYPE=printer DESNAME=myprinter
Example 5:
rwrun report=test.rdf userid=scott/tiger@mydb desformat=pdfDESTYPE=mail DESNAME="emp1@comp.com, emp2@comp.com"cc="emp3@comp.com"bcc="mgr@comp.com" replyto="me@comp.com" from="me@comp.com"
Example 6:
rwrun report=test.rdf userid=scott/tiger@mydb desformat=htmlcssDESTYPE=webdav DESNAME="http://myusername:mypassword@mywebdavserv.com/mydir/test.html"
Example 7:
rwrun report=test.rdf userid=scott/tiger@mydbDESTYPE=oracleportal desformat=PDF PAGEGROUP=mypagegrp OUTPUTPAGE=reports_output ITEMTITLE=pushtoportal STATUSPAGE=result
Example 8:
rwrun report=myxmlpdstest.rdf destype=file desformat=PDF desname=c:\mydir\my.pdf
Example 9:
rwrun report=myjdbcpdstest.rdf destype=file desformat=PDF desname=c:\mydir\myxml.pdf p_jdbcpds=sybuser/sybpwd@server1.mydomain.com:1300
Example 10:
rwrun report=test.rdf userid=scott/tiger@mydbDISTRIBUTE=yes DESTINATION=c:\mydistribute.xml
Example 11:
rwrun report=test.rdf userid=scott/tiger@mydb desformat=pdf destype=file desname=test.pdfAUTHID=myadmin/myadmin
Example 12:
rwrun report=test.rdf userid=scott/tiger@mydb destype=file desformat=pdf desname=test.pdfNOTIFYSUCCESS="emp@comp.com" NOTIFYFAILURE=Òadmin@comp.com"
Example 13:
rwrun report=test.rdf userid=scott/tiger@mydb destype=file desformat=pdf desname=test.pdf TRACEOPTS=trace_prf TRACEMODE=trace_replace
A.1.4 rwbuilder
The rwbuilder command invokes Reports Builder. When you include a REPORT|MODULE keyword with the rwbuilder command at the command prompt, then press Enter, Reports Builder opens with the specified report highlighted in the Object Navigator. When no report is specified, Reports Builder opens with a Welcome dialog offering you the choice of opening an existing report or creating a new one.
Example
rwbuilder report=myrep.rdf userid=scott/tiger@mydb
A.1.5 rwconverter
The rwconverter command enables you to convert one or more report definitions or PL/SQL libraries from one storage format to another. For example, you can use rwconverter to:
  • Combine a report file with an XML file to create a new report
  • Convert a report stored in an .rdf file to a .rep,.rex,.jsp, or .tdf (template) file.
    When a report is converted to a template, only objects in the report's header and trailer sections and margin area are used in the template. Objects in the main section are ignored.
  • Convert a report stored in a .rex file to an .rdf or a template (.tdf file)
  • Convert a library stored in the database to a .pld or .pll file
  • Convert a library stored in a .pld file into a database library or a .pll file
  • Convert a library stored in a .pll file into a database library of a .pld file
    When you convert a report that has an attached library, convert the .pll files attached to the report before converting the .rdf/.rex file.
  • Batch create a PL/SQL script that batch registers reports in OracleAS Portal
In some cases, rwconverter will automatically compile the report's PL/SQL as part of the conversion process. Provided your conversion destination is not a .rex file, rwconverter automatically compiles PL/SQL under the following conditions:
  • Converting to a .rep file. If there are compile errors, rwconverter displays an error message and the .rep file is not created.
  • Using a .rex file as the source
  • Using a report created on another platform as the source
In all other situations, you must compile the report's PL/SQL yourself (e.g., using Program >> Compile >> All in Reports Builder).
Fonts are mapped when a report is opened by Reports Builder or Reports Runtime, not during the conversion.
Example:
rwconverter scott/tiger@mydb stype=rdffile source=inven1.rdf dtype=xmlfile dest=inven1_new.xml
A.1.6 rwservlet
rwservlet translates and delivers information between either a Web server or a J2EE Container (for example, OC4J) and the Reports Server, enabling you to run a report dynamically from your Web browser. Optionally, it can use the In-Process Server, which reduces the maintenance and administration of the Reports Server by providing a means for starting the server automatically, whenever it receives the first request from the client.
When you use the rwservlet command to run a JSP, you can use all keywords applicable to rwservlet. For more information on running a JSP with rwservlet, see Running Report Requests .
The following keywords are commands rather than keyword-value pairs, i.e., commands are entered by themselves without a corresponding value: SHOWENV, SHOWJOBSSHOWMAP, , SHOWMYJOBS, KILLJOBID, PARSEQUERYDELAUTH, , GETJOBID, and GETSERVERINFO.
Examples
http://myiasFoot .mycomp.com:7779Foot /reports/rwservlet?server=myrepserver+report=myrepo.rdf+desname=sample.pdf+desformat=pdf+destype=filehttp://myias.mycomp.com:7779/reports/rwservlet?server=myrepserver+authidFoot =myrepuser/myreppassword+report=myrepo.rdf+desname=sample.pdf+desformat=pdf+destype=file
Example 1:
http://myias.mycomp.com:7779/reports/rwservlet?server=myrepserv+report=test.rdf+userid=scott/tiger@mydb+desformat=pdf+DESTYPE=cache
Example 2:
http://myias.mycomp.com:7779/reports/rwservlet?server=myrepserv+report=test.rdf+userid=scott/tiger@mydb+desformat=pdf+DESTYPE=file+DESNAME=c:\mydir\test.
Example 3:
http://myias.mycomp.com:7779/reports/rwservlet?server=myrepserv+report=test.rdf+userid=scott/tiger@mydb+desformat=pdf+DESTYPE=printer+DESNAME=myprinter
Example 4:
http://myias.mycomp.com:7779/reports/rwservlet?server=myrepserv+report=test.rdf+userid=scott/tiger@mydb+desformat=pdf+DESTYPE=mail+DESNAME="emp1@comp.com,emp2@comp.com"+CC="emp3@comp.com"+BCC="mgr@comp.com"+REPLYTO="me@comp.com"+FROM=me@comp.com"
Example 5:
http://myias.mycomp.com:7779/reports/rwservlet?server=myrepserv+report=test.rdf+userid=scott/tiger@mydb+desformat=htmlcss+DESTYPE=webdav+DESNAME="http://myusername:mypassword@mywebdavserv.com/mydir/test.html"
Example 6:
http://myias.mycomp.com:7779/reports/rwservlet?server=myrepserv+report=test.rdf+userid=scott/tiger@mydb+destype=oracleportal+desformat=PDF+PAGEGROUP=mypagegrp+OUTPUTPAGE=reports_output+ITEMTITLE=pushtoportal+STATUSPAGE=result
Example 7:
http://myias.mycomp.com:7779/reports/rwservlet?server=myrepserv+report=myxmlpdstest.rdf+destype=file+desformat=PDF+DESNAME=c:\mydir\my.pdf
Example 8:
http://myias.mycomp.com:7779/reports/rwservlet?server=myrepserv+report=myjdbcpdstest.rdf+destype=file+desformat=PDF+desname=c:\mydir\myxml.pdf+p_jdbcpds=sybuser/sybpwd@server1.mydomain.com:1300
Example 9:
http://myias.mycomp.com:7779/reports/rwservlet?server=myrepserv+report=test.rdf+userid=scott/tiger@mydb+DISTRIBUTE=yes+DESTINATION=c:\mydistribute.xml
Example 10:
http://myias.mycomp.com:7779/reports/rwservlet?server=myrepserver+report=test.rdf+SCHEDULE="every first fri of month from 15:53 Oct 23, 1999 retry 3 after 1 hour"+destype=file+desformat=pdf+desname=test.pdf
Example 11:
http://myias.mycomp.com:7779/reports/rwservlet?server=myrepserv+report=test.rdf+userid=scott/tiger@mydb+desformat=pdf+destype=file+desname=test.pdf+AUTHID=myadmin/myadmin
Example 12:
Using a key file
http://myias.mycomp.com:7779/report/rwservlet?key1
where
key1=key defined in the cgicmd.dat file (the keyname should be the first parameter)
or
http://myias.mycomp.com:7779/report/rwservlet?server=myrepserv+userparam=12+CMDKEY*=keyname
*when used with cmdkey, it can be anywhere in the URL
Example 13:
Running a report with a Parameter Form
http://myias.mycomp.com:7779/rwservlet?server=myrepserver+report=test.rdf+userid=scott/tiger@mydb+destype=cache+desformat=htmlcss+PARAMFORM=yes
Example 14:
http://myias.mycomp.com:7779/rwservlet?server=myrepserver+report=test.rdf+userid=scott/tiger@mydb+destype=file+desformat=pdf+desname=test.pdf+NOTIFYSUCCESS="emp@comp.com"+NOTIFYFAILURE="admin@comp"
Example 15:
http://myias.mycomp.com:7779/rwservlet?server=myrepserver+report=test.rdf+userid=scott/tiger@mydb+destype=file+desformat=pdf+desname=test.pdf+JOBTYPE=rwurl+URLPARAMETER="http://www.oracle.com"
Example 16:
http://myias.mycomp.com:7779/rwservlet?server=myrepserver+report=test.rdf+userid=scott/tiger@mydb+destype=file+desformat=pdf+desname=test.pdf+TRACEOPTS=trace_prf+TRACEMODE=trace_replace
A.1.7 rwcgi
Like rwservlet, rwcgi (the Common Gateway Interface (CGI) translates and delivers information between either a Web server or a J2EE Container (for example, OC4J) and the Reports Server, enabling you to run a report dynamically from your Web browser.
With Oracle Reports 10g, rwcgi is deprecated (maintained only for backward compatibility); instead, use JSPs or servlets (rwservlet).
Examples
http://mywebserver.comFoot :7779Foot /cgi-bin/rwcgi.exeFoot ?server=myrepserver+report=myrepo.rdf+desname=sample.pdf+desformat=pdf+destype=file
http://mywebserver.com:7779/cgi-bin/rwcgi.shFoot ?server=myrepserver+authidFoot =myrepuser/myreppassword+report=myrepo.rdf+desname=sample.pdf+desformat=pdf+destype=file
Example 1:
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserv+report=test.rdf+userid=scott/tiger@mydb+DESFORMAT=pdf+DESTYPE=cache
Example 2:
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserv+report=test.rdf+userid=scott/tiger@mydb+desformat=pdf+DESTYPE=file+DESNAME=c:\mydir\test
Example 3:
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserv+report=test.rdf+userid=scott/tiger@mydb+desformat=pdf+DESTYPE=printer+DESNAME=myprinter
Example 4:
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserv+report=test.rdf+userid=scott/tiger@mydb+desformat=pdf+DESTYPE=mail+DESNAME="emp1@comp.com, emp2@comp.com+CC=emp3@comp.com"+BCC="mgr@comp.com"+REPLYTO="me@comp.com+from=me@comp.com"
Example 5:
Sending report output to WebDAV (any WebDAV server or OracleAS Portal WebDAV)
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserv+report=test.rdf+userid=scott/tiger@mydb+desformat=htmlcss+DESTYPE=webdav+DESNAME="http://myusername:mypassword@mywebdavserv.com/mydir/test.html"
Example 6:
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserv+report=test.rdf+userid=scott/tiger@mydb+DESTYPE=oracleportal+desformat=PDF+PAGEGROUP=mypagegrp+OUTPUTPAGE=reports_output+ITEMTITLE=pushtoportal+STATUSPAGE=result
Example 7:
Sending XML PDS report output to a file
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserv+report=myxmlpdstest.rdf+DESTYPE=file+desformat=PDF+desname=c:\mydir\my.pdf
Example 8:
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserv+report=myjdbcpdstest.rdf+destype=file+desformat=PDF+desname=c:\mydir\myxml.pdf+p_jdbcpds=sybuser/sybpwd@server1.mydomain.com:1300
Example 9:
Distributing report output to multiple destinations
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserv+report=test.rdf+userid=scott/tiger@mydb+DISTRIBUTE=yes+DESTINATION=c:\mydistribute.xml
Example 10:
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserver+report=test.rdf+SCHEDULE="every first fri of month from 15:53 Oct 23, 1999 retry 3 after 1 hour"+destype=file+desformat=pdf+desname=test.pdf
Example 11:
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserv+report=test.rdf+userid=scott/tiger@mydb+desformat=pdf+destype=file+desname=test.pdf+AUTHID=myadmin/myadmin
Example 12:
Using a key file
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?key1
where key1=key defined in the cgicmd.dat file (the keyname should be the first parameter)
or
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserv+userparam=12+CMDKEY=key1
Example 13:
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserver+report=test.rdf+userid=scott/tiger@mydb+destype=cache+desformat=htmlcss+PARAMFORM=yes
Example 14:
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserver+report=test.rdf+userid=scott/tiger@mydb+destype=file+desformat=pdf+desname=test.pdf+NOTIFYSUCCESS="emp@comp.com"+NOTIFYFAILURE="admin@comp.com"
Example 15:
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserver+report=test.rdf+userid=scott/tiger@mydb+destype=file+desformat=pdf+desname=test.pdf+JOBTYPE=rwurl+URLPARAMETER="http://www.oracle.com"
Example 16:
http://mywebserver.com:7779/cgi-bin/rwcgi.exe?server=myrepserver+report=test.rdf+userid=scott/tiger@mydb+destype=file+desformat=pdf+desname=test.pdf+TRACEOPTS=trace_prf+TRACEMODE=trace_replace
A.1.8 rwserver
The rwserver command invokes the Reports Server. The Reports Server processes client requests, which includes ushering them through its various services, such as authentication and authorization checking, scheduling, caching, and distribution (including distribution to custom or pluggable output destinations). Reports Server also spawns runtime engines for generating requested reports, fetches completed reports from the Reports cache, and notifies the client that the job is ready.
Example: rwserver -install myrepserver batch=yes autostart=yes
A.2 Command Line Syntax
Following is the syntax for a command line, where keyword=value is a valid command line option:
rwclient REPORT|MODULE=runfile USERID=username/password@database[ [keyword=]value|(value1, value2, ...) ] SERVER=server_name
Keywords must be specified and can be used in any order following the command.
A.3 General Usage Notes
A.4 Command Line Keywords
This section describes the various command line keywords that can be used in Oracle Reports.
A.4.1 ACCESSIBLE
Table A-2 indicates which commands can use the ACCESSIBLE keyword.
Table A-2 Commands that can use ACCESSIBLE
rwclient rwrun rwbuilder rwconverter rwservlet rwcgi rwserver
Description
Use ACCESSIBLE to specify whether accessibility-related features offered through Oracle Reports are enabled (YES) or disabled (NO) for PDF output.
Syntax
ACCESSIBLE={YES|NO}
Values
  • YES Accessibility features are enabled for PDF output.
  • NO Accessibility feature is not enabled for PDF output.
Default
NO
A.4.2 ARRAYSIZE
Table A-3 indicates which commands can use the ARRAYSIZE keyword.
Table A-3 Commands that can use ARRAYSIZE
Description
Use ARRAYSIZE to specify the size (in kilobytes) for use with Oracle9i array processing. Generally, the larger the array size, the faster the report will run.
Syntax
ARRAYSIZE=n
Values
n A number from 1 through 9999 (no comma is used with thousands). This means that Reports Runtime can use this number of kilobytes of memory per query in your report.
Default
10
Usage Notes
ARRAYSIZE can be used when running JSP-based Web reports from the command line.
A.4.3 AUTHID
Table A-4 indicates which commands can use the AUTHID keyword.
Table A-4 Commands that can use AUTHID
Description
Use AUTHID to specify the user name and the password to be used to authenticate users to the restricted Reports Server. User authentication ensures that the users making report requests have access privileges to run the requested report.
Syntax
AUTHID=username/password
Values
username/password Any valid user name and password created in OracleAS Portal. See your DBA to create new users accounts in OracleAS Portal.
Default
None
Usage Notes
  • AUTHID can be used when running JSP-based Web reports from the command line.
  • If you have a Single Sign-On environment, then the Oracle Application Server Single Sign-On Server will perform the authentication step and pass only the user name to the Reports Server in AUTHID.
A.4.4 AUTOCOMMIT
Table A-5 indicates which commands can use the AUTOCOMMIT keyword.
Table A-5 Commands that can use AUTOCOMMIT
Description
Use AUTOCOMMIT to specify whether database changes (for example, CREATE) should be automatically committed to the database. Some non-Oracle databases (for example, SQL Server) require that AUTOCOMMIT=YES.
Syntax
AUTOCOMMIT={YES|NO}
Values
  • YES Data changes are committed to the database automatically.
  • NO Data changes are not committed to the database until the COMMIT command runs or one of the PL/SQL commands that cause the data to be committed runs.
Default
NO
Usage Notes
AUTOCOMMIT can be used when running JSP-based Web reports from the command line.
A.4.5 AUTOSTART
Table A-6 indicates which commands can use the AUTOSTART keyword.
Table A-6 Commands that can use AUTOSTART
Description
Use AUTOSTART to specify that the Reports Server will automatically start after initial installation and after a reboot, without requiring a user logon.
Syntax
AUTOSTART={YES|NO}
Values
  • YES The service will automatically start at reboot, without requiring a user logon.
  • NO The service will not automatically start at reboot, requiring a user logon.
Default
NO
Usage Notes
The AUTOSTART keyword is only recognized on Microsoft Windows platforms.
A.4.6 BACKGROUND
Table A-7 indicates which commands can use the BACKGROUND keyword.
Table A-7 Commands that can use BACKGROUND
Description
BACKGROUND specifies whether a report on the server should be run synchronously (NO) or asynchronously (YES).
The BACKGROUND system parameter is deprecated in Oracle Reports. BACKGROUND is used only on the command line.
Syntax
BACKGROUND={YES|NO}
Values
  • YES Runs the report asynchronously. The client sends the call to the server, then continues with other processes without waiting for the report job to complete. If the client process is killed, the job is canceled.
  • NO Runs the report synchronously. The client waits for the report to queue, be assigned to a runtime engine, run, and finish.
Default
NO
Usage Notes
If BACKGROUND=YES is used with rwbuilder or rwrun, a warning is issued and the keyword is ignored.
A.4.7 BATCH
Table A-8 indicates which commands can use the BATCH keyword.
Table A-8 Commands that can use BATCH
Description
For all relevant commands, the BATCH option tells the server to run in no-UI mode. How it is used across commands is similar in that no UI is produced by the application when running from a command line that includes BATCH=YES. For example, for rwserver this allows the server to be run from scripts and remote agents so that no server dialog comes up while it is running.
With rwconverter, BATCH suppresses all terminal input and output in order to convert reports/libraries without user intervention. With rwserver, BATCH turns the server window dialog off (YES) or on (NO) to display or suppress process messages.
Syntax
BATCH={YES|NO}
Values
  • YES Suppresses all terminal input and output (report is run in the background). This is the default for rwrun.
  • NO Allows special terminal input and output. For rwconverter, the Convert dialog box is displayed, and when you accept the dialog box, the conversion is performed.
Default
NO
Usage Notes
  • If BATCH=YES, error messages are sent to SYSOUT. For more information on SYSOUT, see DESNAME.
  • If BATCH=YES, PARAMFORM=YES is invalid because it is not meaningful to have the Runtime Parameter Form appear in batch mode.
A.4.8 BCC
Table A-9 indicates which commands can use the BCC keyword.
Table A-9 Commands that can use BCC
Description
Use BCC to specify e-mail recipient(s) of a blind courtesy copy (that is, one in which the names of specified recipients are not visible (published) to other recipients).
A blind copy is one in which the names of specified recipients are not visible (published) to other recipients.
Syntax
BCC=emailid | ("emailid","emailid", ...)
Values
emailid A valid e-mail address in the form someone@foo.com.
Default
None
Usage Notes
  • To specify more than one e-mail address, enclose the list of addresses in quotation marks and separate each address in the list with a comma.
  • Related keywords include BCC, CC, FROM, REPLYTO, and SUBJECT. Note that DESNAME is used to specify the main recipient(s) of the e-mail.
  • BCC can be used when running JSP-based Web reports from the command line.
A.4.9 BLANKPAGES
Table A-10 indicates which commands can use the BLANKPAGES keyword.
Table A-10 Commands that can use BLANKPAGES
Description
Use BLANKPAGES to specify whether to suppress blank pages when you print a report. Use this keyword when there are blank pages in your report output that you do not want to print.
Syntax
BLANKPAGES={YES|NO}
Values
  • YES Print all blank pages.
  • NO Do not print blank pages.
Default
YES
Usage Notes
BLANKPAGES is especially useful if your logical page spans multiple physical pages (or panels), and you wish to suppress the printing of any blank physical pages.
A.4.10 BUFFERS
Table A-11 indicates which commands can use the BUFFERS keyword.
Table A-11 Commands that can use BUFFERS
Description
Use BUFFERS to specify the size of the virtual memory cache in kilobytes. You should tune this setting to ensure that you have enough space to run your reports, but not so much that you are using too much of your system's resources.
Syntax
BUFFERS=n
Values
n A number from 1 through 9999 (note that thousands are not expressed with any internal punctuation, e.g., a comma or a decimal point). For some operating systems, the upper limit might be lower.
Default
640
Usage Notes
  • If this setting is changed in the middle of your session, then the change does not take effect until the next time the report is run.
  • BUFFERS can be used when running JSP-based Web reports from the command line.
A.4.11 CACHELOB
Table A-12 indicates which commands can use the CACHELOB keyword.
Table A-12 Commands that can use CACHELOB
Description
Use CACHELOB to specify whether to cache retrieved ORACLE large object or objects in the temporary file directory on the Reports Server (specified in the environment variable REPORTS_TMP or by the tempDir property of the engine element in the Reports Server configuration file, server_name.conf; note that a tempDir setting overrides a REPORTS_TMP setting.).
Syntax
CACHELOB={YES|NO}
Values
  • YES The LOB will be cached in the temporary file directory.
  • NO The LOB will not be cached in the temporary file directory.
Default
YES
Usage Notes
  • You can only set this option on the command line.
  • If the location of the temporary file directory on the server does not have sufficient available disk space, then it is preferable to set this value to NO. Setting the value to NO, however, might decrease performance, as the LOB might need to be fetched from the database multiple times.
  • CACHELOB can be used when running JSP-based Web reports from the command line.
A.4.12 CC
Table A-13 indicates which commands can use the CC keyword.
Table A-13 Commands that can use CC
Description
Use CC to specify e-mail recipient(s) of a courtesy copy.
Syntax
Values
Default
None
Usage Notes
A.4.13 CELLWRAPPER
Table A-14 indicates which commands can use the CELLWRAPPER keyword.
Table A-14 Commands that can use CELLWRAPPER
Description
Use CELLWRAPPER to specify the character or characters that displays around the delimited cells in your report output.
Syntax
CELLWRAPPER=value
Values
value Any alphanumeric character or string of alphanumeric characters.
Table A-15 Valid Values - General
Value Description
" A double quotation mark displays on each side of the cell
' A single quotation mark displays on each side of the cell
Table A-16 Valid Values - Reserved
Value Description
tab A tab displays on each side of the cell
space A single space displays on each side of the cell
return A new line displays on each side of the cell
none No cell wrapper is used
Table A-17 Valid Values - Escape Sequences based on the ASCII Character set
Value Description
\t A tab displays on each side of the cell
\n A new line displays on each side of the cell
Default
None
Usage Notes
  • This keyword can only be used if you have specified DESFORMAT=DELIMITED or DESFORMAT=DELIMITEDDATA.
  • The cell wrapper is different from the actual delimiter. The cell wrapper specifies what character appears around delimited data. The delimiter indicates the boundary or break point between two pieces of data.
A.4.14 CMDFILE
Table A-18 indicates which commands can use the CMDFILE keyword.
Table A-18 Commands that can use CMDFILE
Description
Use CMDFILE to call a file that contains one report's command line options. The file called must be an ASCII file, either .txt or any other ASCII-type file.
CMDFILE differs from the cgicmd.dat file, in that CMDFILE can contain one command line for one report, where the cgicmd.dat file can contain multiple key-identified commands for multiple reports. Additionally, the CMDFILE keyword can be used along with other arguments in a command line; while, when you use the key argument associated with cgicmd.dat, it is the only argument that appears in the command line.
The CMDFILE keyword enables you to run a report without specifying a large number of options each time you invoke a run command.
Syntax
CMDFILE=filename
Values
filename Any valid command file name.
Default
None
Usage Notes
  • With rwservlet and rwcgi, use the CMDKEY keyword to refer to a key in the cgicmd.dat file in lieu of using the CMDFILE keyword.
  • A command file can reference another command file.
  • The syntax for a command line you specify in the command file is identical to that used on the command line.
  • Values entered on the command line override values specified in command files. For example, suppose you specify rwclient from the command line with COPIES set to 1 and CMDFILE set to RUNONE (a command file). The RUNONE file also specifies a value for COPIES, but it is set to 2. The value specified for COPIES in the command line (1) overrides the value specified for COPIES in the RUNONE file (2). Only one copy of the report will be generated.
  • The value for this keyword might be operating system-specific.
A.4.15 CMDKEY
Table A-19 indicates which commands can use the CMDKEY keyword.
Table A-19 Commands that can use CMDKEY
Description
Use CMDKEY to call a key-identified command line in the cgicmd.dat file. For example:
http://yourwebserver/reports/rwservlet?cmdkey=key& …
Syntax
CMDKEY=key
Values
key The name of any key associated with a command line specified in the cgicmd.dat file.
Default
None
Usage Notes
  • When you use CMDKEY with rwservlet, you can use it in any order in the command line (or the URL, following the question mark). With rwservlet, you can use additional command line keywords along with CMDKEY.
  • CMDKEY can be used when running JSP-based Web reports from the command line.
A.4.16 COLLATE
Table A-20 indicates which commands can use the COLLATE keyword.
Table A-20 Commands that can use COLLATE
Description:
Use COLLATE to control the collating behavior when a report is output to a printer.
For example, printing three copies of a three page document with COLLATE set to YES would result in output similar to the following:
1 2 3|1 2 3| 1 2 3
The order specified is the page numbers being printed. This behavior is similar to selecting the Collate check box in the Print dialog box.
Printing three copies of a three page document with COLLATE set to NO would result in output similar to the following:
1 1 1| 2 2 2| 3 3 3
Syntax
COLLATE={YES|NO}
Values
  • YES Collates the pages when output to a printer.
  • NO Does not collate the pages when output to a printer.
Default
YES
A.4.17 CONTENTAREA
Table A-21 indicates which commands can use the CONTENTAREA keyword.
Table A-21 Commands that can use CONTENTAREA
Description
Use CONTENTAREA to specify the Oracle9iAS Portal Release 1 content area to which report output should be pushed. This keyword is maintained for backward compatibility with Oracle9iAS Portal Release 1; for backward compatibility with Oracle WebDB Release 2.2, see SITENAME. Beginning with OracleAS Portal Release 2, use PAGEGROUP.
Syntax
CONTENTAREA=name
Values
name The name (internal name) of any valid Oracle9iAS Portal Release 1 content area.
Default
None
Usage Notes
  • Use of this keyword is required to push Oracle Reports output to Oracle9iAS Portal Release 1.
  • The CONTENTAREA name should be the internal name and not the display name. The internal name is used to uniquely identify the Oracle9iAS Portal Release 1 component instance.
  • Relevant keywords include CONTENTAREA*, EXPIREDAYS, ITEMTITLE, OUTPUTFOLDER *, OUTPUTPAGE, PAGEGROUP, REPLACEITEM, SITENAME*, STATUSFOLDER*, STATUSPAGE.
    * maintained for backward compatibility with Oracle9iAS Portal Release 1 and/or Oracle WebDB Release 2.2.
A.4.18 COPIES
Table A-22 indicates which commands can use the COPIES keyword.
Table A-22 Commands that can use COPIES
Description
Use COPIES to specify the number of copies of the report output to print.
Syntax
COPIES=n
Values
n Any valid integer from 1 through 9999 (note that thousands are not expressed with any internal punctuation, e.g., a comma or a decimal point).
Default
Taken from the Initial Value property of the COPIES parameter (the Initial Value was defined in Reports Builder at design time).
Usage Notes
  • This keyword is ignored if DESTYPE is not PRINTER.
  • If COPIES is left blank on the Runtime Parameter Form, then it defaults to one.
A.4.19 CUSTOMIZE
Table A-23 indicates which commands can use the CUSTOMIZE keyword.
Table A-23 Commands that can use CUSTOMIZE
Description
Use CUSTOMIZE to specify an Oracle Reports XML file to be run against the current report. The XML file contains customizations (for example, changes to the layout or data model) that change the report definition in some way.
Syntax
CUSTOMIZE=filename.xml | (filename1.xml, filename2.xml, …)
Values
filenamen.xml The names of the files that contain a valid XML report definition, with path information prefixed to the name(s) if necessary. (if the files are not located in a path specified in the REPORTS_PATH registry or SourceDir property for the engine element).
For more information on customizing reports at runtime with XML customization files, see Customizing Reports with XML.
Default
None
Usage Notes
  • Typically, the file extension of an XML report definition is .xml, but it does not have to be when it is used with the CUSTOMIZE keyword.
  • CUSTOMIZE can be used when running JSP-based Web reports from the command line.
A.4.20 DATEFORMATMASK
Table A-24 indicates which commands can use the DATEFORMATMASK keyword.
Table A-24 Commands that can use DATEFORMATMASK
Description
Use DATEFORMATMASK to specify how date values display in your delimited report output.
Syntax
DATEFORMATMASK=mask
Values
mask Any valid date format mask.
Default
None
Usage Notes
    For valid DATEFORMATMASK values see the Reports Builder online help topic, "Date and Time Format Mask Syntax."
  • DATEFORMATMASK can be used when running JSP-based Web reports from the command line.
A.4.21 DELAUTH
Table A-25 indicates which commands can use the DELAUTH keyword.
Table A-25 Commands that can use DELAUTH
Description
Use DELAUTH to delete rwservlet or rwcgi user ID cookies.
Syntax
http://yourwebserver/reports/rwservlet/delauth[?][server=servername][&authid=username/password]
Values
See Syntax.
Default
None
Usage Notes
  • This keyword is a command that does not require a value; i.e., commands are entered by themselves without a corresponding value.
  • Related keywords are SERVER and AUTHID.
A.4.22 DELIMITED_HDR
Table A-26 indicates which commands can use the DELIMITED_HDR keyword.
Table A-26 Commands that can use DELIMITED_HDR
Description
Use DELIMITED_HDR to turn off boilerplate text (such as the report header) when running a report with DESFORMAT=DELIMITED or DESFORMAT=DELIMITEDDATA.
Syntax
DELIMITED_HDR={YES|NO}
Values
  • YES Turn off all boilerplate text in the delimited output file.
  • NO Leave boilerplate text as is in the delimited output file.
Default
YES
Usage Notes
This keyword can be used only if you have specified DESFORMAT=DELIMITED or DESFORMAT=DELIMITEDDATA.
A.4.23 DELIMITER
Table A-27 indicates which commands can use the DELIMITER keyword.
Table A-27 Commands that can use DELIMITER
Description
Use DELIMITER to specify the character or characters to use to separate the cells in your report output.
Syntax
DELIMITER=value
Values
value Any alphanumeric character or string of alphanumeric characters, such as:
Table A-28 Valid Values - General
Values Description
, A comma separates each cell
. A period separates each cell
Any of these reserved values:
Table A-29 Valid Values - Reserved
Values Description
tab A tab separates each cell
space A space separates each cell
return A new line separates each cell
none No delimiter is used
Table A-30 Valid Values - Escape Sequence based on the ASCII Character set
Values Description
\t A tab separates each cell
\n A new line separates each cell
Default
Tab
Usage Notes
A.4.24 DESFORMAT
Table A-31 indicates which commands can use the DESFORMAT keyword.
Table A-31 Commands that can use DESFORMAT
Description
Use DESFORMAT to specify the format for the job output. Use DESFORMAT to specify the printer driver to be used when DESTYPE is FILE and DESNAME=filename.
Syntax
DESFORMAT=desformat
Values
Any valid destination format not to exceed 1 kilobyte in length. Examples of valid values for this keyword are listed and described in Table A-32.
Table A-32 Valid values for DESFORMAT
Value Description
DELIMITED The report output is sent to a file that can be read by standard spreadsheet utilities, such as Microsoft Excel. If you do not specify a delimiter (via the DELIMITER keyword), the default delimiter is a TAB. See Usage Notes.
DELIMITEDDATA Provides the same functionality as DELIMITED, and is used when you have problems running large volume reports with DESFORMAT=DELIMITED. See Usage Notes.
HTML This report output is sent to a file that is in HTML format.
HTMLCSS This report output is sent to a file that includes style sheet extensions.
PDF This report output is sent to a file that is in PDF format and can be read by a PDF viewer, such as Adobe Acrobat. PDF output is based upon the currently configured printer for your system. The drivers for the currently selected printer are used to produce the output; you must have a printer configured for the machine on which you are running the report.
POSTSCRIPT This report output is sent to a file that is in PostScript format.
PRINTER DEFINITION The printer definition to use when formatting the report when DESTYPE=FILE and DESNAME=filename:
If MODE=BITMAP, this is the name of the printer.
If MODE=CHARACTER, this is the character-mode printer definition file (.prt file), such as hpl, hplwide, dec, decwide, decland, dec180, dflt, or wide. Ask your System Administrator for a list of valid printer definitions.
RTF The report output is sent to a file that can be read by word processors (such as Microsoft Word). When you open the file in Microsoft Word, you must choose View > Page Layout to view all the graphics and objects in your report.
XML This report output is saved as an XML file. This report can be opened and read in an XML-supporting browser, or your choice of XML viewing application.
Default
Taken from the Initial Value property of the DESFORMAT parameter (the Initial Value was defined in Reports Builder at design time). When you run a report via Reports Builder and DESFORMAT is blank or dflt, then the current printer driver (specified in File > Printer ) is used. If a Printer Name has not been selected using the drop down list, then Reports Builder defaults to PostScript.
Usage Notes
  • The value or values for this keyword might be case sensitive, depending on your operating system.
  • When DESFORMAT=HTML or DESFORMAT=HTMLCSS, spaces are replaced with  . This default behavior eliminates alignment issues for number values that are right-aligned. If you do not want spaces replaced with   in your HTML and HTMLCSS output, then you must set REPORTS_NO_HTML_SPACE_REPLACE to YES. This removes the functionality of the DELIMITER command line keyword for HTML and HTMLCSS output (DELIMITER is still valid when DESFORMAT=DELIMITED).
  • DESFORMAT=DELIMITED is not supported in a .dst file. In this case, Oracle Reports displays error:
    REP-34305: Invalid keyword setting for the destid='DEST1'
  • When DESFORMAT=DELIMITEDDATA, the DelimitedData driver runs off the data model and operates in much the same way as the XML driver. Since the driver runs off the data model, any formatting changes defined in the layout are not reflected in the DelimitedData output. You can set the following column properties to alter column names and exclude columns from the DelimitedData output file:
    • The XML Tag property can be used to enter a column alias.
    • The Exclude from XML Output property can be used to exclude the column from the DelimitedData output.
    The DelimitedData functionality also honors the DELIMITER, CELLWRAPPER, NUMBERFORMATMASK, and DATEFORMATMASK command line options just as the DELIMITED does.
  • When you open RTF output generated by Oracle Reports in Microsoft Word 95 for Japanese, you may encounter anomalies in the output, such as dashes not appearing correctly. These issues are specific to Microsoft Word 95 and do not occur in Microsoft Word 97 for Japanese.
A.4.25 DESNAME
Table A-33 indicates which commands can use the DESNAME keyword.
Table A-33 Commands that can use DESNAME
Description
Use DESNAME to specify the name of the cache, file, printer, OracleAS Portal, or e-mail ID (or distribution list) to which the report output will be sent.
Syntax
DESNAME=desname
Values
desname Any valid cache destination, file name, printer name, e-mail ID, or OraclePortal, not to exceed 1K in length. For printer names, you can optionally specify a port. For example:
DESNAME=printer,LPT1:DESNAME=printer,FILE:
Default
Taken from the Initial Value property of the DESNAME parameter (the Initial Value was defined in Reports Builder at design time). If DESTYPE = FILE and DESNAME is an empty string, then it defaults to reportname.lis at runtime.
Usage Notes
  • The value(s) for this keyword might be case sensitive, depending on your operating system.
  • To send the report output by e-mail, specify the e-mail ID as you do in your e-mail application (any SMTP-compliant application). You can specify multiple user names by separating them with commas, and without spaces. For example:
    name,name,name
  • In some cases, this keyword may be overridden by your operating system.
A.4.26 DEST
Table A-34 indicates which commands can use the DEST keyword.
Table A-34 Commands that can use DEST
Description
Use DEST to specify the name(s) of the converted reports or libraries.
Syntax
DEST={dest_name|(dest_name1, dest_name2, …)|pathname}
Values
dest_name Any valid report/library name or filename, or a list of valid report/library names of filenames enclosed in parentheses and separated by commas (e.g., (qanda,text,dmast)).
Default
If the DEST keyword is not specified, rwconverter uses the following default names:
  • If DTYPE is PLDFILE, then the DEST default name is source.pld.
  • If DTYPE is PLLFILE, then the DEST default name is source.pll.
  • If DTYPE is RDFFILE, then the DEST default name is source.rdf.
  • If DTYPE is REPFILE, then the DEST default name is source.rep.
  • If DTYPE is REXFILE, then the DEST default name is source.rex.
  • If DTYPE is XMLFILE, then the DEST default name is source.xml.
  • If DTYPE is REGISTER, then the DEST default name is the name of the SQL*Plus script output file (e.g., output.sql).
Usage Notes
  • A list of report/library names of filenames must be enclosed in parentheses with commas separating each entry. For example:
    (qanda,test,dmast) or (qanda, test, dmast)
  • If you have more destination names than there are source names, the extra destination names are ignored. If you have fewer destination names than there are source names, default names will be used after the destination names run out.
  • The value(s) for the DEST keyword may be operating system-specific.
  • When DTYPE = REGISTER, multiple destinations are not required. If you list more than one SQL*Plus script file name for DEST, only the first one is recognized. The others are ignored.
A.4.27 DESTINATION
Table A-35 indicates which commands can use the DESTINATION keyword.
Table A-35 Commands that can use DESTINATION
Description
Use the DESTINATION keyword to specify the name of an XML file that defines the distribution for the current run of the report.
XML based distribution files must have the.xml extension.
Syntax
DESTINATION=filename.xml
Values
filename.xml The name of an XML file that defines a report or report section distribution.
Default
None
Usage Notes
To enable the DESTINATION keyword, you must specify DISTRIBUTE=YES on the command line. If both these keywords are specified, DESTYPE, DESNAME, and DESFORMAT are ignored if they are also specified.
For more information about creating advanced distributions, see Chapter 15, " Creating Advanced Distributions".
A.4.28 DESTYPE
Table A-36 indicates which commands can use the DESTYPE keyword.
Table A-36 Commands that can use DESTYPE
Description
Use DESTYPE to specify the type of device that will receive the report output. If you have created your own pluggable destination via the Oracle Reports Destination API, this is how the destination you created gets called.
Syntax
DESTYPE={CACHE|LOCALFILE|FILE|PRINTER|SYSOUT|MAIL|ORACLEPORTAL|FTP|WEBDAV|name_of_pluggable_destination}
Values
Table A-37 lists and describes the valid values for the DESTYPE keyword.
Table A-37 Valid values for the DESTYPE keyword
Value Description
CACHE Sends the output directly to the Reports Server cache.
LOCALFILE Valid only for rwclient, rwcgi, and rwservlet. Sends the output to a file on the client machine, synchronously or asynchronously.
FILE Sends the output to the file on the server named in DESNAME.
PRINTER Sends the output to the printer on the server named in DESNAME. You must have a printer that the OracleAS Reports Services can recognize installed and running.
SYSOUT Valid only for rwcgi. Sends the output to the client machine's default output device and forces a synchronous call.
MAIL Sends the output to the mail users specified in DESNAME. You can send mail to any mail system that works with SMTP.
Note: The configuration file rwbuilder.conf must include the pluginParam mailServer with the outgoing mail server name. This applies in both Windows and Solaris environment
ORACLEPORTAL Valid for rwservlet, rwcgi, and rwclient.
Sends the output to OracleAS Portal. Relevant keywords include CONTENTAREA*, EXPIREDAYS, ITEMTITLE, OUTPUTFOLDER *, OUTPUTPAGE, PAGEGROUP, REPLACEITEM, SCHEDULE, SITENAME*,STATUSFOLDER*,STATUSPAGE.
FTPFoot  Valid for rwservlet,rwclient,rwcgi,and rwrun. Sends the output to the specified FTP server.
WEBDAVFoot
Valid for rwservlet,rwclient,rwcgi,and rwrun. Sends the output to the specified WebDAV URL so that the report can be published directly.
name_of_pluggable_destination If you have created your own pluggable destination via the Oracle Reports Destination API, this is what you use to call the destination you created.
Footnote For more information about this pluggable destination, see the Oracle Reports Plugin Exchange on OTN (http://otn.oracle.com/products/reports/pluginxchange/content.html)
Default
Taken from the Initial Value property of the DESTYPE parameter (the Initial Value was defined in Reports Builder at design time).
Usage Notes
  • With Oracle Reports, DESTYPE values of SCREEN and PREVIEW are no longer valid because the Reports Runtime (rwrun) user interface is obsolete. In Reports Builder (rwbuilder), you can still set the DESTYPE system parameter to SCREEN or PREVIEW to format a report to display screen fonts or printer (preview) fonts in the Reports Builder user interface.
  • DESTYPE=printer: On Windows the hardware-based left margin is ignored, by default. The printing origin starts from the top left corner (0,0) of the physical paper and not the printable area. This is to facilitate the design of printer hardware-based margin independent reports. Printing reports without hardware-based left margins on Windows You must ensure that your report's layout contains enough margin spacing such that your data falls within the printable area. Margin fields in the Page Setup dialog have been disabled to ensure consistency with OracleAS Reports Services. To revert to the old behavior of including the hardware margin, set the REPORTS_ADD_HWMARGIN environment variable to YES.
  • DESTYPE=oraclePortal:
    The ORACLEPORTAL destination cannot be used with distribution. Instead, you can use DESTYPE=WEBDAV for advanced XML based distribution to OracleAS Portal.
    Ensure that the OracleAS Portal instance should be WebDAV-enabled. Refer to the OracleAS Portal online help for more information on how to enable WebDAV.
    For more information on how to use WebDAV for distribution to OracleAS Portal, refer to the Tech note at:
    http://webiv.oraclecorp.com/cgi-bin/webiv/do.pl/Get?WwwID=note:241821
    The DESTYPE=ORACLEPORTAL destination cannot be used with the rwrun executable as it causes Reports Server to stop responding. Use this destination only with rwservlet, rwclient, or rwcgi.
    Before you push Oracle Reports output to Oracle9iAS Portal Release 1 ensure that you have created the following:
    • A valid OUTPUTPAGE containing at least one item region
    • A valid PAGEGROUP containing at least one item region
    Additionally, you need to edit the Reports Server configuration file as follows:
    1. Uncomment the destype=oraclePortal element.
      <destination
         destype="oraclePortal"
         class="oracle.reports.server.DesOraclePortal">
         <!--property name="portalUserid"
                   value="%PORTAL_DB_USERNAME%/%PORTAL_DB_
                           PASSWORD%@%PORTAL_DB_TNSNAME%"
                   confidential="yes"
                   encrypted="no"/-->
      </destination>
      In Oracle9i Reports 9.0.2, by default, the portalUserid property is uncommented and the connection string in the property points to the infrastructure database. In order to be able to push your reports output to Oracle9iAS Portal Release 1 the portalUserid must remain uncommented.
      In Oracle Reports 10g (9.0.4), by default, the portalUserid is commented out. Reports Server will determine the connection string and push the report to Oracle9iAS Portal Release 1. You need to uncomment this only if you are using a different OracleAS Portal instance.
    2. Substitute the values in the portalUserid property with your OracleAS Portal connection information if you do not want to push an Oracle Reports output to the default Oracle9iAS Portal Release 1 instance.
      If you do not substitute the values or uncomment the destype entry, you will get the following error:
      REP-56092: No class defined for destination type oracleportal
    Running the request is very similar to any other out-of-the-box destinations. For example:
    http://your_server:port/reports/rwservlet? report=test.rdf&userid=scott/tiger@repportal&authid=pushportal/trial&destype=oracleportal&desformat=PDF&pagegroup=PORTAL_REPORTS&outputpage=reports_output&itemtitle=pushtoportal&statuspage=result
  • DESTYPE=FTP: Running the request is very similar to any other out-of-the-box destinations. You need to specify the complete FTP URL location along with the file name. If the FTP server needs an authentication, that also needs to be part of the URL as shown in the following example:
    http://your_server:port/reports/rwservlet?report=rep.jsp&destype=FTP&desname=ftp://user:pwd@ftpServer/dir/myreport.pdf&desformat=pdf
    In the above example, the DESTYPE is FTP and the DESNAME value is a complete FTP URL location along with the report name myreport.pdf.
    To use a proxy server, edit the destination element (configured for FTP out-of-the-box) in the Reports Server configuration file:
    <destination destype="ftp" class="oracle.reports.plugin.destination.ftp.DesFTP"> <!--property name="proxy" value="proxyinfo.xml"/--> </destination>
    To specify the proxy information, edit the proxyinfo.xml file available in the default location (ORACLE_HOME\reports\conf). Uncomment the previous property entry and specify the complete path to the proxyinfo.xml file as the value.
    For example, if your ORACLE_HOME is located in D:\9iAS, then the default location for proxyinfo.xml can be specified as:
    <destination destype="ftp" class="oracle.reports.plugin.destination.ftp.DesFTP"> <property name="proxy" value="D:\\9iAS\\reports\\conf\\proxyinfo.xml"/>
    </destination>
  • DESTYPE=WEBDAV: Running the request is very similar to any other out-of-the-box destinations. You need to specify the complete WEBDAV URL location along with the file name. If the WEBDAV server needs an authentication, that also needs to be part of the URL as shown in the following example:
    http://your_server:port/reports/rwservlet?report=rep.jsp&destype=WebDAV&desname=http://user:pwd@webdavServer/myreport.pdf&desformat=pdf
    In the above example, the DESTYPE is WEBDAV and the DESNAME value is a complete WEBDAV URL location along with the report name myreport.pdf.
    To use a proxy server, edit the destination element (configured for WEBDAV out-of-the-box) in the Reports Server configuration file:
    <destination destype="WebDav" class="oracle.reports.plugin.destination.webdav.DesWebDAV"> <!--property name="proxy" value="proxyinfo.xml"/--> </destination>
    To specify the proxy information, edit the proxyinfo.xml file available in the default location (ORACLE_HOME\reports\conf). Uncomment the property entry above and specify the complete path to the proxyinfo.xml file as the value.
    <destination destype="WebDav" class="oracle.reports.plugin.destination.webdav.DesWebDAV"> <property name="proxy" value="D:\\9iAS\\reports\\conf\\proxyinfo.xml"/
    </destination>
A.4.29 DISTRIBUTE
Table A-38 indicates which commands can use the DISTRIBUTE keyword.
Table A-38 Commands that can use DISTRIBUTE
Description
Use DISTRIBUTE to enable or disable distributing the report output to multiple destinations, as specified by the distribution list defined in the report distribution definition (defined in Reports Builder at design time) or a distribution XML file.
Syntax
DISTRIBUTE={YES|NO}
Values
  • YES Distribute the report to the distribution list.
  • NO Ignore the distribution list and output the report as specified by the DESNAME, DESTYPE, and DESFORMAT parameters. This is fundamentally a debug mode to allow running a report set up for distribution without actually executing the distribution.
Default
NO
Usage Notes
The DISTRIBUTE keyword works in close association with the DESTINATION keyword. DISTRIBUTE must have a value of YES for the DESTINATION keyword to take effect. If both these keywords are specified, DESTYPE, DESNAME, and DESFORMAT are ignored if they are also specified.
For more information about creating advanced distributions, see Creating Advanced Distributions.
A.4.30 DTYPE
Table A-39 indicates which commands can use the DTYPE keyword.
Table A-39 Commands that can use DTYPE
Description
Use DTYPE to specify the format to which to convert the reports or libraries.
Syntax
DTYPE={PLDFILE|PLLFILE|RDFFILE|REPFILE|REXFILE|TDFFILE|XMLFILE|JSPFILE|REGISTER}
Values
The following values apply:
  • PLDFILE The converted PL/SQL libraries will be stored in files in ASCII format.
  • PLLFILE The converted PL/SQL libraries will be stored in files containing source code and P-code (compiled PL/SQL).
  • RDFFILE The converted report(s) will be stored in one or more report definition files (files with the .rdf extension).
  • REPFILE The converted report(s) will be stored in one or more binary runfiles (files with the .rep extension).
  • REXFILE The converted report(s) will be stored in one or more text files (files with the .rex extension).
  • TDFFILE The report will be converted to a template file (files with the .tdf extension).
  • XMLFILE The converted report(s) will be stored in an XML file (files with the .xml extension).
  • JSPFILE The converted report(s) will be stored in a JSP file (files with the .jsp extension).
  • REGISTER A script file is created to load each report specified by SOURCE into OracleAS Portal with the RWWWVREG.REGISTER_REPORT function. Each load function is populated with the necessary information to register the report in OracleAS Portal. By running the resulting script file in SQL*Plus against the Oracle Application Server DB Provider, you can batch register multiple reports in OracleAS Portal.
Default
REPFILE
Usage Notes
  • When you try to create a .rep file using rwconverter, the source report's PL/SQL is automatically compiled. If there are compile errors, an error message is displayed and the .rep file is not created. To avoid this problem, make sure you compile the source report's PL/SQL using File > Administration > Compile Report in Reports Builder, before you try to create a .rep file.
  • When converting a report to a template, only objects in the report's header and trailer sections and the margin area are used in the template. Objects in the main section are ignored.
A.4.31 DUNIT
Table A-40 indicates which commands can use the DUNIT keyword.
Table A-40 Commands that can use DUNIT
Description
Use DUNIT to specify the destination unit of measurement to which the report should be converted. If specified, DUNIT must differ from the SOURCE report's unit of measurement. If unspecified, the SOURCE report's unit of measurement is used.
Syntax
DUNIT={CENTIMETER|CHARACTER|INCH|POINT}
Values
  • CENTIMETER The converted reports will initially use centimeters as the unit of measurement
  • CHARACTER The converted reports will initially use characters as the unit of measurement.
  • INCH The converted reports will initially use inches as the unit of measurement.
  • POINT The converted reports will initially use points as the unit of measurement
Default
Null (the report’s unit of measurement is used).
A.4.32 ENGINERESPONSETIMEOUT
Table A-41 indicates which command can use the ENGINERESPONSETIMEOUT keyword.
Table A-41 Commands that can use ENGINERESPONSETIMEOUT
Description
Use ENGINERESPONSETIMEOUT to specify the maximum amount of time (in minutes) for an engine to update the status of the job while running a report in your environment. If it takes longer than this amount of time to update the job status for some reason (e.g., due to the engine hanging or a long blocking SQL query), then Reports Server terminates the job.
This parameter overrides the engineResponseTimeOut attribute of the engine element in the Reports Server configuration file. Refer to engine for further information about the engine element.
Syntax
ENGINERESPONSETIMEOUT=number
Values
number A number of minutes (e.g., 5).
Default
None
A.4.33 EXPIRATION
Table A-42 indicates which command can use the EXPIRATION keyword.
Table A-42 Commands that can use EXPIRATION
Description
Use EXPIRATION to define how long report output can exist in cache before it is deleted.
See Reusing Report Output from Cache for more information on duplicate job detection.
Syntax
EXPIRATION=time_string
Values
time_string Is in one of two formats:
  • n{unit}, for a number with an optional unit. The unit can be minute(s), hour(s), or day(s). The default unit is minute(s) if no unit is specified.
  • {Mon DD, YYYY} hh:mi:ss am|pm {timezone}, for a date/time format. Date information is optional. If it isn’t specified, today is assumed. Time zone is also optional. If it isn’t specified, the Reports Server’s timezone is used. The date/time is always in a US locale. This format is the same as defined in the Java DateFormat.MEDIUM type.
Default
None
A.4.34 EXPIREDAYS
Table A-43 indicates which commands can use the EXPIREDAYS keyword.
Table A-43 Commands that can use EXPIREDAYS
no no no no yes yes no
Description
Use EXPIREDAYS to specify the number of days after which the Oracle Reports output pushed to Oracle9iAS Portal Release 1 should be expired.
Syntax
EXPIREDAYS={PERMANENT|1 day|2 days|3 days|7 days|14 days|31 days|60 days|90 days|120 days}
Values
  • PERMANENT Does not expire.
  • ndaysExpires after n days.
Default
None
Usage Notes
A.4.35 EXPRESS_SERVER
Table A-44 indicates which commands can use the EXPRESS_SERVER keyword.
Table A-44 Commands that can use EXPRESS_SERVER
yes yes yes no yes yes no
Description
Use EXPRESS_SERVER to specify the Express Server to which you want to connect.
Syntax
EXPRESS_SERVER="server=server/domain=domain/user=userid/password=passwd"
Syntax with RAM
EXPRESS_SERVER="server=server/domain=domain/user=userid/password=passwd/ramuser=ramuserid/rampassword=rampasswd/ramexpressid=ramexpid/ramserverscript=ramsscript/rammasterdb=ramdb/ramconnecttype=ramconn"
Values
A valid connect string enclosed in double quotes (") where:
Table A-45 Connect String Values
Values Description
server The Express Server string (for example, ncacn_ip_tcp:olap2-pc/sl=x/st=x/ct=x/sv=x/). See below for more details on the server string.
domain The Express Server domain.
user The user ID to log on to the Express Server.
password The password for the user ID.
ramuser The user ID to log into the RDBMS.
rampassword The password for the RDBMS.
ramexpressid The Oracle Sales Analyzer database user ID. This is required for Oracle Sales Analyzer databases only.
ramserverscript The complete file name (including the full path) of the remote database configuration file (RDC) on the server. This file specifies information such as the location of code and data databases. Using UNC (Universal Naming Convention) syntax allows multiple users to use the same connection to access the data without having to map the same drive letter to that location. UNC syntax is \\ServerName\ShareName\ followed by any subfolders or files.
rammasterdb The name of the Relational Access Manager database to attach initially. You must specify only the database file name. This database must reside in a directory that is included in the path list in ServerDBPath for Express Server. You can check the ServerDBPath in the File I/O tab of the Express Configuration Manager dialog box.
ramconnecttype The type of Express connection. Always specify 0 for a direct connection.
Parameters
The server value contains four parameters that correspond to settings that are made in the Oracle Express Connection Editor and stored in connection (XCF) files. All four parameters are required and can be specified in any order. Table A-46 describes the parameters and their settings:
Table A-46 Settings for parameters used with EXPRESS_SERVER’s server value
Parameter Description Setting
sl Server Login -2: Host (Domain Login)
-1: Host (Server Login)
0: No authentication required
1: Host (Domain Login) and Connect security
2: Host (Domain Login) and Call security
3: Host (Domain Login) and Packet security
4: Host (Domain Login) and Integrity security
5: Host (Domain Login) and Privacy security
Note: Windows NT uses all the settings. UNIX systems use only the settings 0, -1, and -2. See the Express Connection Editor Help system for information on these settings.
st Server Type :1: Express Server
ct Connection Type 0: Express connection
sv Server Version 1: Express 6.2 or greater
Default
None
Usage Notes
  • You can have spaces in the string if necessary (for example, if the user ID is John Smith) because the entire string is enclosed in quotes.
  • If a forward slash (/) is required in the string, then you must use another forward slash as an escape character. For example, if the domain were tools or reports, then the command line should be as follows:
    EXPRESS_SERVER="server=ncacn_ip_tcp:olap2-pc/sl=0/st=1/ct=0/sv=1/domain=tools//reports"
  • You can use single quotes within the string. They are not treated specially because the entire string is enclosed in double quotes.
A.4.36 FORMSIZE
Table A-47 indicates which commands can use the FORMSIZE keyword.
Table A-47 Commands that can use FORMSIZE
no no no yes no no no
Description
Use FORMSIZE to specify the size of the Runtime Parameter Form for the converted report in terms of the destination unit of measurement (specified using DUNIT).
Syntax
FORMSIZE=width x height
Values
width/height Any valid values in the specified unit of measurement.
Default
None
Usage Notes
  • For non-character DUNITs, you can use a decimal to specify fractions (e.g., 8.5 x 11).
  • For more information on the Runtime Parameter Form, see the PARAMFORM keyword.
A.4.37 FROM
Table A-48 indicates which commands can use the FROM keyword.
Table A-48 Commands that can use FROM
yes yes no no yes yes no
Description
Use FROM to specify the e-mail address of the sender of an e-mail.
Syntax
FROM=emailid
Values
emailid Any valid e-mail address in the form someone@foo.com.
Default
loginid@machine_name
Usage Notes
Related keywords include BCC,CC, FROM, REPLYTOSUBJECT, and . Note that DESNAME is used to specify the main recipient(s) of the e-mail.
A.4.38 GETJOBID
Table A-49 indicates which commands can use the GETJOBID keyword.
Table A-49 Commands that can use GETJOBID
Description
Use GETJOBID to retrieve the result output of the Reports Server job with job ID n.
Syntax
http://yourwebserver/reports/rwservlet/getjobidn[?][server=server_name][&authid=username/password]
Values
See Syntax.
Default
None
Usage Notes
  • Job must be successfully finished and present in the Reports Server cache. Use SHOWJOBS to see the current list of jobs.
A.4.39 GETSERVERINFO
Table A-50 indicates which commands can use the GETSERVERINFO keyword.
Table A-50 Commands that can use GETSERVERINFO
no no no no yes no no
Description
Use GETSERVERINFO to display Reports Server information. You can choose the format (HTML or XML) in which the information is returned via &statusformat.
Syntax
http://yourwebserver/reports/rwservlet/getserverinfo[?][server=server_name][&authid=username/password][&statusformat={html|xml}]
Values
See Syntax.
Default
None
Usage Notes
A.4.40 HELP
Table A-51 indicates which commands can use the HELP keyword.
Table A-51 Commands that can use HELP
Description
Use HELP to display a help topic that lists the keywords you can use with the rwservlet command. For example:
http://yourwebserver/reports/rwservlet/help?command=keyword
Syntax
or
Values
See Syntax.
Default
None
A.4.41 INSTALL
Table A-52 indicates which commands can use the INSTALL keyword
Table A-52 Commands that can use INSTALL
no no no no no no yes
Description
Use INSTALL to configure an instance of the Reports Server on Microsoft Windows as a service. This keyword does not work on UNIX platforms.
Syntax
INSTALLreports_server_name
Values
reports_server_name A valid name for the Reports Server instance.
Default
None
Usage Notes
  • If you use the AUTOSTART keyword with INSTALL, the Reports Server service will be started automatically after installation and whenever the system is restarted.
  • If you use BATCH=YES with INSTALL, then none of the prompts and dialogs that normally display during installation will appear.
A.4.42 ITEMTITLE
Table A-53 indicates which commands can use the ITEMTITLE keyword.
Table A-53 Commands that can use ITEMTITLE
Description
Use ITEMTITLE to specify the display name Oracle9iAS Portal Release 1 should use for Oracle Reports output. The name will display in Oracle9iAS Portal Release 1 and link to Oracle Reports output.
Syntax
ITEMTITLE=title
Values
title Any text. Put quotation marks around the value if the value has any character spaces in it or you are specifying the option in the cgicmd.dat file.
Default
The report file name
USage Notes
A.4.43 JOBNAME
Table A-54 indicates which commands can use the JOBNAME keyword.
Table A-54 Commands that can use JOBNAME
yes no no no yes yes no
Description
Use JOBNAME to specify the name for a job to appear in Reports Queue Manager. It is treated as a comment and has nothing to do with running the job. If JOBNAME is not specified, then Reports Queue Manager shows the report name as the job name.
Syntax
JOBNAME=string
Values
Any job name.
Default
None
Usage Notes
JOBNAME can be used when running JSP-based Web reports from the command line.
A.4.44 JOBTYPE
Table A-55 indicates which commands can use the JOBTYPE keyword.
Table A-55 Commands that can use JOBTYPE
Description
Use JOBTYPE to specify the type of job to be processed by the server. You can enter any type of job, as long as the Reports Server has an engine to process it.
Syntax
JOBTYPE=jobtype
Values
jobtype A job for which the Reports Server has an engine.
Default
REPORT
A.4.45 JVMOPTIONS
Table A-56 indicates which commands can use the JVMOPTIONS keyword.
Table A-56 Commands that can use JVMOPTIONS
no yes yes yes no no yes
Description:
Use JVMOPTIONS to set options for either Reports Runtime, Reports Builder, Reports Converter, or Reports Server's Java Virtual Machine (JVM). For example, you could use the following command line to start the Reports Server with a 512Mb heap space:
rwserver server= servername jvmoptions=-Xmx512M
Multiple options can be passed, in which case the options must be enclosed in quotes:
rwserver server=servername jvmoptions="-Xmx256M -Xms=128M"
You could also use the following command line to start Reports Builder with a 512Mb heap space:
rwbuilder jvmoptions=-Xmx512M
Syntax
JVMOPTIONS={options in the server’s JVM}
rwbuilder jvmoptions="-Xmx256M -Xms=128M"
A.4.46 KILLJOBID
Table A-57 indicates which commands can use the KILLJOBID keyword.
Table A-57 Commands that can use KILLJOBID
Description
Use KILLJOBID to kill a Reports Server job with the specified job ID n.
Syntax
http://yourwebserver/reports/rwservlet/killjobidn[?][server=server_name][&authid=username/password][&statusformat={html|xml|xmldtd}]
Values
See Syntax.
Default
None
Usage Notes
  • The job must be current (enqueued or scheduled).
  • Use SHOWJOBS to see the current list of jobs. The STATUSFORMAT can be set to html (default), xml , or xmldtd to return status in that format. The status information is generated in html, xml, or xmldtd (with an internal dtd subset).
  • Related keywords are SHOWJOBS,SERVER, AUTHID, and STATUSFORMAT.
  • The STATUSFORMAT parameter is only valid for rwservlet, not for rwcgi.
A.4.47 LONGCHUNK
Table A-58 indicates which commands can use the LONGCHUNK keyword.
Table A-58 Commands that can use LONGCHUNK
Description
LONGCHUNK is the size (in kilobytes) of the increments in which Reports Builder retrieves a LONG column value. When retrieving a LONG value, you might want to retrieve it in increments rather than all at once because of memory size restrictions. LONGCHUNK applies only to Oracle databases.
Syntax
LONGCHUNK=n
Values
Default
10
Usage Notes
LONGCHUNK can be used when running JSP-based Web reports from the command line.
A.4.48 MIMETYPE
Table A-59 indicates which commands can use the MIMETYPE keyword.
Table A-59 Commands that can use MIMETYPE
Description
Use MIMETYPE to override the MIME type assigned by the Reports Server when it returns output for the Web. In most cases, the default MIME type is correct, but, in cases where it is not, you can override it with this keyword. For example:
mimetype=application/vnd.ms-excel
Syntax
MIMETYPE=string
Values
string A valid MIME type specification.
Default
None
Usage Notes
OracleAS Reports Services does not verify the string you enter for MIMETYPE. You must ensure yourself that the string is correct for the returned report output.
A.4.49 MODE
Table A-60 indicates which commands can use the MODE keyword.
Table A-60 Commands that can use MODE
Description
Use MODE to specify whether to run the report in character mode or bitmap. This enables you to run a character-mode report from Reports Builder.
Syntax
MODE={BITMAP|CHARACTER|DEFAULT}
Values
  • BITMAP Run the report in bitmap mode.
  • DEFAULT Run the report in the mode of the current executable being used.
  • CHARACTER On Windows - the Reports Builder ASCII driver will be used to produce editable ASCII output.
Default
DEFAULT
A.4.50 MODULE|REPORT
Table A-61 indicates which commands can use the MODULE|REPORT keyword.
Table A-61 Commands that can use MODULE|REPORT
Description
Use MODULE or REPORT to specify the name of the report to run.
Syntax
Values
runfile Any valid runfile (that is, a file with an extension of .rep,.rdf,.jsp, or .xml).
Default
None
Usage Notes
  • If you specify a character-mode report, Reports Builder displays a warning, then opens the report using a page size of 8.5" x 11" and a form size of 7" x 6".
  • To run the report (e.g., display it in the Paper Design View), it must be a complete report definition (i.e., contain its own data model and layout definition). You cannot run a partial report definition.
  • An XML report definition must have an .xml file extension when specified with the MODULE|REPORT keyword.
  • If you do not enter a file extension, the executable searches first for a file with extension .rep, then extension .rdf, then .jsp, and then no extension, using the file path search order to find the file.
A.4.51 NONBLOCKSQL
Table A-62 indicates which commands can use the NONBLOCKSQL keyword.
Table A-62 Commands that can use NONBLOCKSQL
Description
Use NONBLOCKSQL to specify whether to allow other programs to execute while data is fetched from the database.
Syntax
NONBLOCKSQL={YES|NO}
Values
  • YES Other programs can execute while data is being fetched.
  • NO Other programs cannot execute while data is being fetched.
Default
YES
Usage Notes
NONBLOCKSQL can be used when running JSP-based Web reports from the command line.
A.4.52 NOTIFYFAILURE
Table A-63 indicates which commands can use the NOTIFYFAILURE keyword.
Table A-63 Commands that can use NOTIFYFAILURE
Description
Use NOTIFYFAILURE to specify the recipient(s) of a notification e-mail should a report request fail. Use this keyword when you configure your Reports Server to use the notification class. For more information, see the notification discussion in Configuring OracleAS Reports Services.
Refer to notificationfor more information on the sender property. This property rectifies the issue faced with some SMTP servers on validating the domain name.
Syntax
NOTIFYFAILURE=emailid|(emailid,emailid,...)
Values
Default
None
Usage Notes
  • The default notification e-mail templates that are used for the body of the notification e-mail are included with your installation of Oracle Application Server. The NOTIFYFAILURE template is named failnote.txt, and is located at ORACLE_HOME\reports\template.
  • NOTIFYFAILURE can be used when running JSP-based Web reports from the command line.
A.4.53 NOTIFYSUCCESS
Table A-64 indicates which commands can use the NOTIFYSUCCESS keyword.
Table A-64 Commands that can use NOTIFYSUCCESS
Description
Use NOTIFYSUCCESS to specify the recipient(s) of a notification e-mail should a report request succeed. Use this keyword when you configure your Reports Server to use the notification class. For more information, see the notification discussion in Configuring OracleAS Reports Services.
Refer to the notificationfor more information on the sender property. This property rectifies the issue faced with some SMTP servers on validating the domain name.
Syntax
NOTIFYSUCCESS=emailid|(emailid,emailid,...)
Values
Default
None
Usage Notes
  • The default notification e-mail templates that are used for the body of the notification e-mail are included with your installation of Oracle Application Server. The NOTIFYSUCCESS template is named succnote.txt, and is located at ORACLE_HOME\reports\template.
  • NOTIFYSUCCESS can be used when running JSP-based Web reports from the command line.
A.4.54 NUMBERFORMATMASK
Table A-65 indicates which commands can use the NUMBERFORMATMASK keyword.
Table A-65 Commands that can use NUMBERFORMATMASK
Description
Use NUMBERFORMATMASK to specify how number values display in your delimited report output.
Syntax
NUMBERFORMATMASK=mask
Values
Any valid number format mask.
Default
None
Usage Notes
    For valid NUMBERFORMATMASK values see the Reports Builder online help topic, "Number Format Mask Syntax."
  • NUMBERFORMATMASK can be used when running JSP-based Web reports from the command line.
A.4.55 OLAP_CON
Table A-66 indicates which commands can user the OLAP_CON keyword.
Table A-66 Commands that can use OLAP_CON
Description
OLAP_CON specifies the Oracle OLAP (on-line analytical processing) connection string to connect to a database that contains multidimensional Oracle OLAP data.
Syntax
OLAP_CON=userid/password/hostname/SID/portnumber
Values
A valid OLAP connection string where:
  • userid The user ID for connecting to Oracle OLAP.
  • password The password for the user ID.
  • hostname The host name for the database.
  • SID The system identifier (SID) for connecting to the database.
  • portnumber The port number for connecting to the database.
For example:
OLAP_Con="user1/secret1/mypc.us.oracle.com/mySID/9201
A.4.56 ONFAILURE
Table A-67 indicates which commands can use the ONFAILURE keyword.
Table A-67 Commands that can use ONFAILURE
Description
Use ONFAILURE to specify whether you want a COMMIT or ROLLBACK performed if an error occurs and the report fails to complete.
Syntax
ONFAILURE={COMMIT|ROLLBACK|NOACTION}
Values
  • COMMIT Perform a COMMIT if the report fails.
  • ROLLBACK Perform a ROLLBACK if the report fails.
  • NOACTION Do nothing if the report fails.
Default
  • ROLLBACK, if a USERID is provided.
  • NOACTION, if called from an external source (for example, OracleAS Forms Services) with no USERID provided.
Usage Notes
  • The COMMIT or ROLLBACK for ONFAILURE is performed after the report fails. Other COMMITs and ROLLBACKs can occur prior to this one. For more information, see the READONLY command.
  • ONFAILURE can be used when running JSP-based Web reports from the command line.
A.4.57 ONSUCCESS
Table A-68 indicates which commands can use the ONSUCCESS keyword.
Table A-68 Commands that can use ONSUCCESS
Description
Use ONSUCCESS to specify that either a COMMIT or ROLLBACK should be performed when a report is finished running.
Syntax
ONSUCCESS={COMMIT|ROLLBACK|NOACTION}
Values
  • COMMIT Perform a COMMIT when a report is done.
  • ROLLBACK Perform a ROLLBACK when a report is done.
  • NOACTION Do nothing when a report is done.
Default
  • COMMIT, if a USERID is provided.
Usage Notes
  • The COMMIT or ROLLBACK for ONSUCCESS is performed after the after-report trigger fires. Other COMMITs and ROLLBACKs can occur prior to this one. For more information, see the READONLY command.
  • ONSUCCESS can be used when running JSP-based Web reports from the command line.
A.4.58 ORIENTATION
Table A-69 indicates which commands can use the ORIENTATION keyword.
Table A-69 Commands that can use ORIENTATION
rwclient rwrun rwbuilder rwconverter rwservlet rwcgi rwserver
Description
ORIENTATION controls the direction in which the pages of the report will print.
Syntax
ORIENTATION={DEFAULT|LANDSCAPE|PORTRAIT}
Values
DEFAULT Use the current printer setting for orientation.
LANDSCAPE Landscape orientation (long side at top and bottom).
PORTRAIT Portrait orientation (short side at top and bottom).
Default
DEFAULT
Usage Notes
  • If ORIENTATION=LANDSCAPE for a character mode report, then you must ensure that your printer definition file contains a landscape clause.
  • Not supported when output to a PCL printer on Motif.
A.4.59 OUTPUTFOLDER
Table A-70 indicates which commands can use the OUTPUTFOLDER keyword.
Table A-70 Commands that can use OUTPUTFOLDER
Description
Use OUTPUTFOLDER to specify the name of the Oracle WebDB Release 2.2 or OracleAS Portal folder to push Oracle Reports output. This keyword is maintained for backward compatibility with Oracle WebDB Release 2.2 and Oracle9iAS Portal Release 1. Beginning with OracleAS Portal 10g (9.0.4), use OUTPUTPAGE.
Syntax
OUTPUTFOLDER=folder
Values
folder Any valid folder name (internal name) used in Oracle WebDB Release 2.2 or Oracle9iAS Portal Release 1.
Default
Oracle_Reports_Output
Usage Notes
A.4.60 OUTPUTIMAGEFORMAT
Table A-71 indicates which commands can use the OUTPUTIMAGEFORMAT keyword.
Table A-71 Commands that can use OUTPUTIMAGEFORMAT
Description
Use OUTPUTIMAGEFORMAT to choose the format for images in your report output.
Syntax
OUTPUTIMAGEFORMAT={PNG|JPEG|JPG|GIF|BMP}
Values
  • PNG,JPEG,JPG Supported image formats when DESFORMAT value is PDF, HTML, HTMLCSS, or RTF
  • GIF Supported image format when DESFORMAT value is PDF, HTML, or HTMLCSS
  • BMP Supported image formats when DESFORMAT value is RTF
Usage Notes
  • This command line keyword overrides the setting of the REPORTS_OUTPUTIMAGEFORMAT environment variable.
  • This command line keyword is not supported if the REPORTS_DEFAULT_DISPLAY environment variable is explicitly set to NO (default is YES). In this case, image rendering defaults to GIF for HTML, HTMLCSS, and PDF output, and BMP for RTF output.
  • You must ensure the format that you specify matches the output type. For example, BMP only works for RTF output. It will not work for HTML, HTMLCSS or PDF output.
Examples
Example 1
The following command lines generate PNG images with HTML output:
rwclient server=my_rep_server report=images.rdf destype=file desformat=html desname=images.html userid=user_id outputimageformat=PNG
rwrun report=images.rdf destype=file desformat=html desname=images.html userid=user_id outputimageformat=PNG
Similarly when DESFORMAT=pdf, images are embedded in PNG format in the generated PDF document.
Example 2
An error is displayed if an invalid value is specified for the OUTPUTIMAGEFORMAT. The following command lines generate an error message:
rwclient server=my_rep_server report=images.rdf destype=file desformat=html desname=images.html userid=user_id outputimageformat=ABCD
rwrun report=images.rdf destype=file desformat=html desname=images.html userid=user_id outputimageformat=ABCD
The invalid image format ABCD generates the following error message:
REP-35000: The image output format specified is not supported.
A.4.61 OUTPUTPAGE
Table A-72 indicates which commands can use the OUTPUTPAGE keyword.
Table A-72 Commands that can use OUTPUTPAGE
Description
Use OUTPUTPAGE to specify the name of the Oracle Reports page to push a report output information to. For backward compatibility with earlier versions (Oracle WebDB Release 2.2 and Oracle9iAS Portal Release 1), see OUTPUTFOLDER .
Syntax
OUTPUTPAGE=page
Values
page Any valid page name (internal name) used in Oracle9iAS Portal Release 1.
Default
Usage Notes
  • Use of this keyword is optional to push Oracle Reports output to Oracle9iAS Portal Release 1:
    • If you do not specify an output page, OracleAS Portal will create a default page named Oracle_Reports_Output.
    • If you specify an output page, use the internal name and not the display name. The internal name is used to uniquely identify the OracleAS Portal component instance.
  • The value for this keyword is case sensitive.
  • The page should contain at least one item region when used with DESTYPE=ORACLEPORTAL.
A.4.62 OVERWRITE
Table A-73 indicates which commands can use the OVERWRITE keyword.
Table A-73 Commands that can use OVERWRITE
Description
Use OVERWRITE to specify whether to overwrite existing files with the converted files.
Syntax
OVERWRITE={YES|NO|PROMPT}
Values
  • YES Automatically overwrite any existing files of the same name.
  • NO Do not to convert reports if there are existing files of the same name and display a warning message
  • PROMPT Prompt you before overwriting any existing files.
Default
NO
A.4.63 P_AVAILABILITY
Table A-74 indicates which commands can use the P_AVAILABILITY keyword.
Table A-74 Commands that can use P_AVAILABILITY
Description
Use P_AVAILABILITY to specify the name of the availability calendar that determines when the reports specified will be available for processing. This keyword is only used when DTYPE=REGISTER.
Syntax
P_AVAILABILITY=calendar_name
Values
calendar_name Any valid availability calendar name.
Default
None
Usage Notes
The availability calendar must exist in OracleAS Portal before running the SQL*PLUS script. If it does not, an invalid package may be created.
A.4.64 P_DESCRIPTION
Table A-75 indicates which commands can use the P_DESCRIPTION keyword.
Table A-75 Commands that can use P_DESCRIPTION
Description
Use P_DESCRIPTION to specify the text that provides additional information about the report. This keyword is only used when DTYPE=REGISTER.
Syntax
P_DESCRIPTON=description_text
Values
description_textAny text string.
Default
None
A.4.65 P_FORMATS
Table A-76 indicates which commands can use the P_FORMATS keyword.
Table A-76 Commands that can use P_FORMATS
Description
Use P_FORMATS to specify the allowable destination formats for the specified reports. This keyword is only used when DTYPE=REGISTER.
Syntax
P_FORMATS=destination_format|(destination_format1,destination_format2,...)
Values
destination_format Any valid destination format (e.g., HTML), or a list of valid destination formats enclosed by parentheses with a comma separating the names (e.g., HTMLCSS,PDF,RTF).
Default
None
A.4.66 P_NAME
Table A-77 indicates which commands can use the P_NAME keyword.
Table A-77 Commands that can use P_NAME
Description
Use P_NAME to specify the report name displayed in OracleAS Portal. This keyword is only used when DTYPE=REGISTER.
Syntax
P_NAME=report_name
Values
report_name Any report name.
Default
If P_NAME is not specified, the PL/SQL function is populated with the report definition file name.
Usage Notes
  • If P_NAME is not specified, the PL/SQL function is populated with the report definition file name.
  • Specify P_NAME only when you want to use the same report name for each report definition file being registered in OracleAS Portal. This option is typically left blank.
  • The report name cannot be prefaced with numeric characters (e.g., 401K_ report is an invalid file name and my_401K_report is valid).
A.4.67 P_OWNER
Table A-78 indicates which commands can use the P_OWNER keyword.
Table A-78 Commands that can use P_OWNER
Description
Use P_OWNER to specify the OracleAS Portal DB Provider that owns a report's package, which is created when the report definition files are registered. This keyword is only used when DTYPE=REGISTER.
Syntax
P_OWNER=portal_dbprovider
Values
portal_dbprovider Any valid OracleAS Portal DB Provider name.
Default
The name of the OracleAS Portal DB Provider to which you are connected when you run the SQL*PLUS script file.
A.4.68 P_PFORMTEMPLATE
Table A-79 indicates the commands that can use the P_PFORMTEMPLATE keyword.
Table A-79 Commands that can use P_PFORMTEMPLATE
Description
Use P_PFORMTEMPLATE to specify the name of the OracleAS Portal template that determines the style of the Runtime Parameter Form. This keyword is only used when DTYPE=REGISTER.
Syntax
P_PFORMTEMPLATE=template_name
Values
template_name Any valid OracleAS Portal template name.
Default
None
A.4.69 P_PRINTERS
Table A-80 indicates the commands that can use the P_PRINTERS keyword.
Table A-80 Commands that can use P_PRINTERS
Description
Use P_PRINTERS to specify the allowable printers for the specified reports. This keyword is only used when DTYPE=REGISTER.
Syntax
P_PRINTERS=printer_name
Values
printer_name Any valid printer (e.g., PRT1), or a list of valid printers enclosed by parentheses with a comma separating the names (e.g., (PRT1,PRT2,PRT3)).
Default
None
Usage Note
Access to the printer(s) should already exist in OracleAS Portal before running the SQL*Plus script.
A.4.70 P_PRIVILEGE
Table A-81 indicates which commands can use the P_PRIVILEGE keyword.
Table A-81 Commands that can use P_PRIVILEGE
Description
Use P_PRIVILEGE to specify the users or roles who have access privileges to run the specified reports. This keyword is only used when DTYPE=REGISTER.
Syntax
P_PRIVILEGE=user_name
Values
user_name Any user name or role that OracleAS Portal can recognize (e.g., SCOTT), or a list of user names or roles enclosed by parentheses with a comma separating the names (e.g., (SCOTT,JABERS,PMARTIN)).
Default
None
A.4.71 P_SERVERS
Table A-82 indicates which commands can use the P_SERVERS keyword.
Table A-82 Commands that can use P_SERVERS
Description
Use P_SERVERS to specify the names of the restricted Reports Servers that can run the report. This keyword is only used when DTYPE=REGISTER.
Syntax
P_SERVERS=tnsname
Values
tnsname Any valid TNS name of the Reports Server (e.g., repserver), or a list of valid Reports Server TNS names enclosed by parentheses with a comma separating the names (e.g., repserver, acct_server, sales_server).
Default
None
Usage Notes
Access to the Reports Server(s) should already exist in OracleAS Portal.
A.4.72 P_TRIGGER
Table A-83 indicates the commands that can use the P_TRIGGERS keyword.
Table A-83 Commands that can use P_TRIGGER
Description
Use P_TRIGGER to specify the PL/SQL function that is executed when parameter values are specified on the command line and when users accept the Runtime Parameter Form. The function must return a boolean value (TRUE or FALSE). For example:
P_TRIGGER=Is begin IF UPPER(DESTYPE) = 'PRINTER' AND EMPNAME = 'SMITH' THEN RETURN(TRUE); ELSE RETURN(FALSE); END IF; end;
Syntax
P_TRIGGER=plsql_function
Values
plsql_function Any valid PL/SQL function that returns a boolean value.
Default
None
A.4.73 P_TYPES
Table A-84 indicates which commands can use the P_TYPES keyword.
Table A-84 Commands that can use P_TYPES
Description
Use P_TYPES to specify the allowable destination types for the specified reports. This keyword is only used when DTYPE=REGISTER.
Syntax
P_TYPES=destination_type
Values
destination_type Any valid destination type (e.g., CACHE), or a list of valid destination types enclosed by parentheses with a comma separating the names (e.g., CACHE,MAIL,PRINTER).
Default
None
A.4.74 PAGEGROUP
Table A-85 indicates which commands can use the PAGEGROUP keyword.
Table A-85 Commands that can use PAGEGROUP
Description
Use PAGEGROUP to specify the name of the Oracle9iAS Portal Release 1 page group to which report output should be pushed. For backward compatibility with earlier versions, see SITENAME (for Oracle WebDB Release 2.2) and CONTENTAREA (for Oracle9iAS Portal Release 1). The page group must be created in Oracle9iAS Portal Release 1 before you can use this keyword.
Syntax
PAGEGROUP=pagegroup
Values
pagegroup Any valid page group name (internal name) used in Oracle9iAS Portal Release 1.
Default
None
Usage Notes
  • The page group name should be the internal name and not the display name. The internal name is used to uniquely identify the Oracle9iAS Portal Release 1 page instance.
A.4.75 PAGESIZE
Table A-86 indicates which commands can use the PAGESIZE keyword.
Table A-86 Commands that can use PAGESIZE
yes yes yes yes yes yes no
Description
Use PAGESIZE to set the dimensions of the physical page (that is, the size of the page that the printer outputs). The page must be large enough to contain the report. For example, if a frame in a report expands to a size larger than the page dimensions, then the report is not run.
Syntax
PAGESIZE=width x height
Values
Any valid page dimensions of the form: page width x page height, where page width and page height are more than zero. The maximum width and height depends which unit of measurement was set in Reports Builder (Edit > Preferences > General tab). For inches, the maximum width and height is 512 inches. For centimeters, it is 1312 centimeters. For picas, it is 36,864 picas.
Default
For bitmap, 8.5 x 11 inches. For character mode, 80 x 66 characters. If the report was designed for character mode and is being run or converted on bitmap, then the following formula is used to determine page size if none is specified: (default page size * character page size)/default character page size. For example, if the character page size is 80 x 20, then the bit-mapped page size would be: ( (8.5 * 80)/80) x ((11 * 20)/66) = (680/80) x (220/66) = 8.5 x 3.33.
Usage Notes
  • On some printers the printable area of the physical page is restricted. For example, the sheet of paper a printer takes might be 8.5 x 11 inches, but the printer might only be able to print on an area of 8 x 10.5 inches. If you define a page width x page height in Reports Builder that is bigger than the printable area your printer allows, then clipping might occur in your report output. To avoid clipping, you can either increase the printable area for the printer (if your operating system allows it), or you can set the page width x page height to be the size of the printable area of the page.
  • Letter size is 8.5 inches x 11 inches. A4 size is 210mm x 297mm, or 8.25 inches x 11.75 inches.
  • If you use the PAGESIZE keyword, then its value overrides the page dimensions of the report definition.
  • A PAGESIZE value entered on the Runtime Parameter Form overrides any PAGESIZE value entered on the command line.
A.4.76 PAGESTREAM
Table A-87 indicates which commands can use the PAGESTREAM keyword.
Table A-87 Commands that can use PAGESTREAM
Description
PAGESTREAM enables or disables page streaming (pagination) for the report when formatted as HTML or HTMLCSS output, using the navigation controls set by either of the following:
  • The Page Navigation Control Type and Page Navigation Control Value properties in the Report Property Palette.
  • PL/SQL in a Before Report trigger (SRW.SET_PAGE_NAVIGATION_HTML)
Syntax
PAGESTREAM={YES|NO}
Values
  • YES Paginate the report output.
  • NO Output the report without pagination.
Default
NO
A.4.77 PARAMFORM
Table A-88 indicates which commands can use the PARAMFORM keyword.
Table A-88 Commands that can use PARAMFORM
Description
Use PARAMFORM to specify whether to display the Runtime Parameter Form when you execute a report via CGI or a servlet. PARAMFORM is used only to supply parameters to paper layout reports, not Web source reports.
Syntax
PARAMFORM=YES|NO|HTML
Values
  • YES Display the Parameter Form.
  • NO Do not display the Parameter Form.
  • HTML Display the Parameter Form in HTML format.
Default
NO
Usage Notes
  • PARAMFORM=YES is incompatible with BATCH=YES because it is not meaningful to have the Runtime Parameter Form appear in batch mode.
  • Do not use this keyword when running a report in an OracleAS Portal environment. This is because OracleAS Portal allows you to set up a Reports runtime parameter form, which may conflict with a form you specify with the PARAMFORM keyword.
A.4.78 PARSEQUERY
Table A-89 indicates which commands can use the PARSEQUERY keyword.
Table A-89 Commands that can use PARSEQUERY
Description
Use PARSEQUERY to parse an rwservlet query and display the constructed Reports Server command line.
Syntax
http://yourwebserver/reports/rwservlet/parsequery[?][server=servername][&authid=username/password]
Values
See Syntax.
Default
None
Usage Notes
A.4.79 PDFCOMP
Table A-90 indicates which commands can use the PDFCOMP keyword.
Table A-90 Commands that can use PDFCOMP
Description
Use PDFCOMP to specify whether PDF output should be compressed.
Syntax
PDFCOMP=value|{YES|NO}
Values
  • value Any value 0 though 9. A value of 0 means PDF output will not be compressed. A value of 1 through 9 will compress the PDF output and permit users to control the compression level.
  • YES Compresses output at compression level 6.
  • NO Compresses output at compression level 0 (no compression).
Default
6
A.4.80 PDFEMBED
Table A-90 indicates which commands can use the PDFEMBED keyword.
Table A-91 Commands that can use PDFEMBED
Description
Use PDFEMBED to specify whether Oracle Reports will embed the Type1 PostScript font file(s) specified in the uifont.ali file into PDF output.
Syntax
PDFEMBED={YES|NO}
Values
  • YES The PDF driver will embed the font(s) specified in the [PDF:Embed] header of the uifont.ali file into the PDF output.
  • NO The font(s) will not be added to PDF output.
Default
YES
A.4.81 PRINTJOB
Table A-92 indicates which commands can use the PRINTJOB keyword.
Table A-92 Commands that can use PRINTJOB
no no yes no no no no
Description
Use PRINTJOB to specify whether the Print Job dialog box should be displayed before running a report.
Syntax
PRINTJOB={YES|NO}
Values
  • YES The Print Job dialog box is displayed before the report is run.
  • NO The report is run without displaying the Print Job dialog box.
Default
NO
Usage Notes
  • When a report is run as a spawned process (that is, one executable, such as rwrun, is called from within another executable, such as rwbuilder), the Print Job dialog box does not appear, regardless of PRINTJOB.
  • When DESTYPE=MAIL, the Print Job dialog box does not appear, regardless of PRINTJOB.
A.4.82 READONLY
Table A-93 indicates which commands can use the READONLY keyword.
Table A-93 Commands that can use READONLY
Description
Use READONLY to request read consistency across multiple queries in a report. When accessing data from Oracle 9i, read consistency is accomplished by a SET TRANSACTION READ ONLY statement.
Refer to Oracle9i SQL documentation (available on the Oracle Technology Network, (http://otn.oracle.com) for more information on SET TRANSACTION READ ONLY.
Syntax
READONLY={YES|NO}
Values
YES Requests read consistency.
NO Do not provide read consistency.
Default
NO
Usage Notes
  • This keyword is only useful for reports using multiple queries. Oracle 9i automatically provides read consistency, without locking, for single query reports.
  • In the Report trigger order of execution, SET TRANSACTION READ ONLY must be set up before the data fetch occurs.
  • READONLY can be used when running JSP-based Web reports from the command line.
A.4.83 RECURSIVE_LOAD
Table A-94 indicates which commands can use the RECURSIVE_LOAD keyword.
Table A-94 Commands that can use RECURSIVE_LOAD
yes yes no yes yes yes no
Description
Use RECURSIVE_LOAD to specify whether to validate external references in program units when running a report. If any of the references become invalid, the program unit is automatically recompiled. Setting RECURSIVE_LOAD to NO is useful when running your report against a different database than the one against which its PL/SQL was originally compiled.
Syntax
RECURSIVE_LOAD={YES|NO}
Values
  • YES Validates external references when running a report. If any of the references become invalid, the program unit is recompiled (whether it be in .rdf or .pll).
  • NO Does not validate external references when running a report. This setting is useful when running a report against a different database than the one against which its PL/SQL was originally compiled.
Default
YES
A.4.84 REPLACEITEM
Table A-95 indicates which commands can use the REPLACEITEM keyword.
Table A-95 Commands that can use REPLACEITEM
Description
Use REPLACEITEM to specify that the current report output being pushed to Oracle9iAS Portal Release 1 should replace an earlier version of the same item stored in the same output target.
Syntax
REPLACEITEM={YES|NO}
Values
  • YES Earlier report output should be replaced.
  • NO Do not replace previous version. In this case, a link to the new output will be added to a list of links to previous versions of the same report.
Default
None
Usage Notes
A.4.85 REPLYTO
Table A-96 indicates which commands can use the REPLYTO keyword.
Table A-96 Commands that can use REPLYTO
Description
Use REPLYTO to specify the e-mail address to which replies should be sent when the sender wants replies to go to someone other than the sender (specified by the FROM keyword).
Syntax
REPLYTO=emailid
Values
emailid A valid e-mail address in the form of someone@foo.com.
Default
None
Usage Notes
Related keywords include BCC,CC,FROM,REPLYTO, and SUBJECT. Note that DESNAME is used to specify the main recipient(s) of the e-mail.
A.4.86 REPORT|MODULE
See MODULE|REPORT.
A.4.87 ROLE
Table A-97 indicates which commands can use the ROLE keyword.
Table A-97 Commands that can use ROLE
Description
Use ROLE to specify the database role to be checked for the report at runtime. This keyword is useful for giving you the ability to run reports that query database tables to which you would not normally have access privileges.
Syntax
ROLE={rolename[/rolepassword]}
Values
  • rolename A valid role.
  • rolepassword (Optional) The matching role password.
Default
None
Usage Notes
ROLE can be used when running JSP-based Web reports from the command line.
A.4.88 RUNDEBUG
Table A-98 indicates which commands can use the RUNDEBUG keyword.
Table A-98 Commands that can use RUNDEBUG
Description
Use RUNDEBUG to specify that you want extra runtime checking for logical errors in the report. RUNDEBUG checks for things that are not errors but might result in undesirable output, and displays these as warnings at runtime, before displaying the report output. Using RUNDEBUG to run a report in debug mode is not the same as debugging a report using the PL/SQL Interpreter.
RUNDEBUG checks for the following:
  • Frames or repeating frames that overlap but do not enclose another object. This can lead to objects overwriting other objects in the output.
  • Layout objects with page-dependent references that do not have fixed sizing. Such objects will be fixed in size regardless of the Vertical Elasticity and Horizontal Elasticity property settings.
  • Bind variables referenced at the wrong frequency in PL/SQL.
Syntax
RUNDEBUG={YES|NO}
Values
  • YES Perform extra runtime error checking.
  • NO Do not perform extra runtime error checking.
Default
YES
Usage Notes
RUNDEBUG can be used when running JSP-based Web reports from the command line.
A.4.89 SAVE_RDF
Table A-99 indicates which commands can use the SAVE_RDF keyword.
Table A-99 Commands that can use SAVE_RDF
no yes yes no no no no
Description
Use SAVE_RDF to specify a filename for a combined RDF file and XML customization file. This keyword is useful when you combine an existing RDF file with a Oracle Reports XML customization file using the CUSTOMIZE keyword, and you wish to save the combination to a new RDF file.
Syntax
SAVE_RDF=filename.rdf
Values
filename.rdf Any valid file name.
Default
None
Usage Notes
You can use SAVE_RDF with a JSP file, but only the paper layout part, not the Web source.
A.4.90 SCHEDULE
Table A-100 indicates which commands can use the SCHEDULE keyword.
Table A-100 Commands that can use SCHEDULE
Description
Use SCHEDULE to set the day, time, and frequency a report should be run. The default is to run the report once, now. Time values are expressed according to a 24-hour day (i.e., one o'clock is expressed 13:00). To eliminate the need for quoting the scheduling command, use underscores (_) instead of spaces. You can also specify an expiration for a report job after a number of runs or on a particular date/time. For example, use:
SCHEDULE=every_first_fri_of_month_from_15:53_Oct_23,_1999_retry_3_after_1_hour_expires_on_15:53_Oct_23,_2003
SCHEDULE=last_weekday_before_15_from_15:53_Oct_23,_1999_retry_after_1_hour_expires_after_100
Or:
SCHEDULE="every first fri of month from 15:53 Oct 23, 1999 retry 3 after 1 hour expires on 15:53 Oct 23, 2003"
SCHEDULE="last weekday before 15 from 15:53 Oct 23, 1999 retry after 1 hour expires after 100"
Syntax
SCHEDULE=string
where the string is:
[FREQ from] TIME [retry {n} after LEN expires {on|after} time|n]
Table A-101 lists and explains the values used in this string.
Table A-101 Values for string used with the SCHEDULE keyword
FREQ hourly | daily | weekly | monthly | {every {LEN | DAYREPEAT}} | {last {WEEKDAYS | weekday | weekend} before {n}+}
LEN {n}+ {minute[s] | hour[s] | day[s] | week[s] | month[s]}
DAYREPEAT {first | second | third | fourth | fifth} WEEKDAYS of month
WEEKDAYS mon | tue | wed | thu | fri | sat | sun
TIME now | CLOCK [DATE]
CLOCK h:m | h:mm | hh:m | hh:mm
DATE today | tomorrow | {MONTHS {d | dd} [,year]}
MONTHS jan | feb | mar | apr | may | jun | jul | aug | sep | oct | nov | dec
EXPIRES on {today | tomorrow | {MONTHS {d | dd} [,year]}}|after n
Default
None
A.4.91 SERVER
Table A-102 indicates which commands can use the SERVER keyword.
Table A-102 Commands that can use SERVER
yes no no no yes yes yes
Description
Use SERVER to specify the name of the Reports Server you want to use to run this report.
Syntax
SERVER=servername
Values
The server name or a TNS service entry name if you're using a 6i compatible server.
Default
The server name specified in the REPORTS_SERVER environment variable for rwcgi.
Usage Notes
  • For jobs run with rwcgi, you can set the REPORTS_SERVER environment variable on your Web server machine and omit the SERVER keyword to process requests using the default server, or you can include the SERVER keyword to override the default. For jobs run with rwservlet or as a JSP, you can omit the SERVER keyword if you have specified a default server in the servlet configuration file, rwservlet.properties; or you can include the SERVER keyword to override the default.
  • SERVER can be used when running JSP-based Web reports from the command line.
A.4.92 SHOWAUTH
Table A-103 indicates which commands can use the SHOWAUTH keyword.
Table A-103 Commands that can use SHOWAUTH
Description
Use SHOWAUTH to display the Reports Server logon page and runs the report .
Syntax
http://yourwebserver/reports/rwservlet/showauth[?][server=servername][&authid=username/password]][&nextpage=run report URL][&authtype={s|d}]
Values
See Syntax.
Default
None
Usage Notes
  • This keyword is a command that does not require a value; i.e., commands are entered by themselves without a corresponding value.
  • When authtype=s the Reports System User Authentication dialog box is displayed. The Reports Database User Authentication dialog box is displayed when authtype=d.
  • Related keywords are SERVER and AUTHID.
A.4.93 SHOWENV
Table A-104 indicates which commands can use the SHOWENV keyword.
Table A-104 Commands that can use SHOWENV
Description
Use SHOWENV to display the rwservlet configuration file (rwservlet.properties).
Syntax
http://yourwebserver/reports/rwservlet/showenv[?][server=servername][&authid=username/password]
Values
See Syntax.
Default
None
Usage Notes
A.4.94 SHOWJOBID
Table A-105 indicates which commands can use the SHOWJOBID keyword.
Table A-105 Commands that can use SHOWJOBID
Description
SHOWJOBID shows the status of the Reports Server job with job ID n.
Syntax
http://yourwebserver/reports/rwservlet/showjobidn[?][server=server_name][&authid=username/password][&statusformat={html|xml|xmldtd}]
Values
See Syntax.
Default
None
Usage Notes
A.4.95 SHOWJOBS
Table A-106 indicates which commands can use the SHOWJOBS keyword.
Table A-106 Commands that can use SHOWJOBS
Description
Use SHOWJOBS to display a Web view of Reports Server queue status.
Syntax
http://yourwebserver/reports/rwservlet/showjobs[n][?][server=server_name][&authid=username/password][&queuetype=current | past |future][&startrow=start_position_in_job_queue][&count=number_of_jobs_to_display][&statusformat={html|xml|xmldtd}]
Values:
See Syntax
Default
None
Usage Notes
  • The name of the Reports Server must be specified implicitly by environment variable or servlet configuration file, or explicitly in the URL request. The refresh number n is optional. When it is specified, the report’s queue status will be updated every n seconds.
  • The STATUSFORMAT can be set to html (default), xml , or xmldtd to return status in that format. The status information is generated in html, xml, or xmldtd (with an internal dtd subset).
  • The QUEUETYPE,STARTROW,COUNT, and STATUSFORMAT parameters are valid only for rwservlet and not for rwcgi.
  • Related keywords are SERVER, AUTHID, and STATUSFORMAT.
A.4.96 SHOWMAP
Table A-107 indicates which commands can use the SHOWMAP keyword.
Table A-107 Commands that can use SHOWMAP
no no no no yes
