Skip Headers
Oracle® Database Installation Guide
10g Release 1 (10.1) for hp OpenVMS Alpha
Part No. B13681-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
B Noninteractive Installation and Configuration
This chapter describes how to install and configure Oracle products noninteractively using response files. It includes information about the following topics:
B.1 Silent Mode Installation
A silent installation with Oracle Universal Installer is noninteractive, meaning that it takes place without using the Java graphical user interface (GUI). Oracle Universal Installer gets its information from a text file that is specified at the command line by using the -responseFile argument instead of interactive GUI input and output. If the -responseFile flag is given, then the installation is assumed to be a silent mode type.
Because the design of Oracle Universal Installer causes GUI classes to be loaded (but not displayed), a silent installation still requires an X connection.
A silent installation can also be performed in BATCH mode, as long as the process has established an X connection through the SET DISPLAY command.
This section discusses the following topics:
B.1.1 What Is a Response File?
A response file contains answers to installation questions that otherwise would be provided by the user in an interactive installation session. Each answer is stored as a value for a variable that is identified in the response file. For example, values for ORACLE_HOME or Install Type can be set automatically within the response file. Response file templates are generated by the installation developer. The response file template for the installation of the product can be found on the ship set (CD-ROM number 1) under the device:[Disk1.response] directory. You should be able to find one for your choice of install type (for example, enterprise.rsp for an Enterprise Edition server installation, or custom.rsp for a custom installation).
B.1.2 Why Perform a Silent Installation?
Silent installations can be useful if you need to install an Oracle product multiple times on multiple computers, or if you prefer not to use the GUI because of performance reasons over a slow remote X connection. If the options that you select while installing on each computer are always the same, then you save the time of reviewing each installation screen and selecting the various installation options.
Silent installations can also ensure that multiple users in your organization use the same installation options when they install Oracle products. You can therefore more easily support those users because you already know what components and options have been installed on each computer.
Before you perform a silent installation, you should review the settings in the response file template that is provided with the Oracle product.
B.1.3 Modifying a Response File
If the product installation includes a response file template, then you can find it on the ship set (CD-ROM) in the device:[Disk1.response] directory. For a list of response files, refer to Section B.1.3.1, "List of Response File Names". Mandatory items have the following comment just before the definition:
# OPENVMS_VALUE_REQUIRED
Three values must be provided:
  • FROM_LOCATION
  • ORACLE_HOME
  • ORACLE_HOME_NAME
FROM_LOCATION is the complete path of the source of the products to be installed (in other words, to the [.Disk1.stage]products.xml file) from CD-ROM number 1. If contents of CDs were copied to a local device, then specify that path. ORACLE_HOME is the directory into which the Oracle software will be installed. The account from which Oracle Universal Installer is run must have appropriate privileges to create a root-level directory if the directory that was specified for ORACLE_HOME does not already exist.
  • FROM_LOCATION must be in UNIX-style syntax.
  • ORACLE_HOME must be on an ODS-5 disk
To modify the response file:
  1. Make a copy of the response file for the product, and open it in a text editor.
  2. Search for the three items that are listed in the preceding paragraph (or for the string OPENVMS_VALUE_REQUIRED), and provide values for those items.
  3. Modify other fields as applicable (refer to comments within the response file that you are modifying).
B.1.3.1 List of Response File Names
The following table lists the response file names and their descriptions:
File Name Description
enterprise.rsp: Enterprise Edition Installation of Oracle Database Server
custom.rsp Custom Edition Installation of Oracle Database Server
clientadmin.rsp Administrator installation of Oracle Database Client
clientruntime.rsp Run time installation of Oracle Database Client
clientcustom.rsp Custom installation of Oracle Database Client
dbca.rsp Database Configuration Assistant
B.2 Performing Silent Installation
You can install Oracle software noninteractively by specifying a response file when you start Oracle Universal Installer. The Installer uses the values contained in the response file to provide answers to some or all of Oracle Universal Installer prompts. If you include responses for all of Oracle Universal Installer prompts in the response file, then you can run a completely noninteractive installation.
To install and configure Oracle products noninteractively, complete the following steps:
These steps are described in the following sections.
B.2.1 Creating the oraInst.loc File
If you plan to install Oracle products noninteractively, then you must manually create the oraInst.loc file, if it does not already exist. This file specifies the location of the Oracle Inventory directory where Oracle Universal Installer creates the inventory of Oracle products that are installed on the system.
If Oracle software has been installed previously on the system, then the oraInst.loc file may already exist. If the file does exist, then you do not need to create a new file.
To create the oraInst.loc file, perform the following steps:
  1. Set default directory to the Oracle oraInventory directory.
    set def disk:[oraInventory_dir]
  2. Use a text editor to create the oraInst.loc file, containing the following lines:
    inventory_loc=oraInventory_location
    inst_group=group_id
    In this example, oraInventory_location is the locationof the Oracle Inventory directory, and group_id is the group ID of the Oracle OpenVMS account.
  3. Set the file protection on the oraInst.loc file as follows:
    $ set file/prot=(o:rwed,s:rwed,g:rwe,w:re) oraInventory_directory:oraInst.loc
B.2.2 Preparing Response Files
Oracle provides response file templates for each product and installation type and for each configuration tool. These files are located in the response directory on the CD-ROM or the [.db.response] directory on the DVD.
If you copy the software to a hard disk, then the response files are located in the [.Disk1.response] directory.
Table B-1 lists the response files that are provided with Oracle Database 10g.
Table B-1 Response Files
Response File Description
enterprise.rsp Enterprise Edition installation of Oracle Database
netca.rsp Oracle Net Services Configuration Assistant
To prepare a response file:
  1. Copy the response file from the response file directory to a directory on the system:
    $ copy [src_path]response_file dest_path
    In this example, src_path is the CD-ROM mount point directory or the db directory on the DVD. If you have copied the software to a hard drive, then you can edit the file in the response directory if you prefer.
  2. Open the response file in a text editor:
    $ ed [dest_path]response_file
  3. Edit the file by following the instructions in the file.
    Oracle Universal Installer or the configuration assistant fails if you do not correctly configure the response file. Refer to Section G.6, "Silent Response File Error Handling" for more information about troubleshooting a failed noninteractive installation.
B.2.3 Running Oracle Universal Installer Noninteractively
To run Oracle Universal Installer noninteractively, enter a command similar to the following:
$ [directory_path]runInstaller [-silent] -responseFile filename
In this command:
  • directory_path is either the disc directory path, or the path of the Disk1 directory on the hard drive
  • -silent specifies a completely noninteractive installation
  • filename is the full path and file name of the installation response file that you configured
Do not specify a relative path to the response file. If you specify a relative path, then Oracle Universal Installer stops.
B.3 Running Oracle Universal Installer in Silent Mode or Suppressed Mode
To run Oracle Universal Installer in silent mode or suppressed mode, use the following steps:
  1. Complete the preinstallation tasks listed in Chapter 2, "Preinstallation Tasks".
  2. Log in as the Oracle software owner user (typically, oracle).
  3. If you are performing a suppressed-mode installation, set the DISPLAY.
    You do not need to set the DISPLAY if you are performing a silent-mode installation (as opposed to a suppressed-mode installation).
  4. To start Oracle Universal Installer in silent mode or suppressed mode, enter a command similar to the following command:
    • $ [directory_path]runInstaller [-silent] -responseFile filename
    Do not specify a relative path to the response file. If you specify a relative path, then Oracle Universal Installer fails.
    In the example:
    • directory_path is either the CD-ROM directory, the path of the db directory on the DVD, or the path of the Disk1 directory on the hard drive.
    • -silent indicates that you want to run Oracle Universal Installer in silent mode.
    • filename is the full path and file name of the installation response file that you configured.
    For more information about other options for the runInstaller command, enter the following command:
    $ [directory_path]runInstaller -help
B.4 Running NetCA in Silent Mode
You can run Network Configuration Assistant (NetCA) in silent mode to configure and start an Oracle Net Services listener on the system, to configure naming methods, and to configure Oracle Net Services service names. To run NetCA in silent mode, you must copy and edit a response file template. Oracle provides a response file template named netca.resp in the response directory on the CD-ROM or in the db/response directory on the DVD.
If you copied the software to a hard disk, then the response file template is located in the [.Disk1.response] directory.
To run NetCA in silent mode, perform the following steps:
  1. Copy the netca.rsp response file template from the response file directory to a directory on the system.
    $ copy [directory_path.response]netca.rsp local_directory
    In this example, directory_path is the CD-ROM mount point directory or the db directory on the DVD. If you have copied the software to a hard drive, then you can edit the file in the response directory if you prefer.
  2. Open the response file in a text editor. For example:
    $ ed [logical_directory]netca.rsp
    NetCA stops if you do not correctly configure the response file.
  4. Log in as the Oracle software owner (typically oracle) and set the ORACLE_HOME logical to specify the correct Oracle home directory.
  5. Enter a command similar to the following to run NetCA in silent mode:
    $ @ORA_ROOT:[bin]netca /silent /responsefile=/local_dir/netca.rsp
    In this example:
    • /silent option indicates that you want to run NetCA in silent mode.
    • local_dir is the full path of the directory where you copied the netca.rsp response file template.
B.5 Running DBCA in Noninteractive or Silent Mode
You can run Database Configuration Assistant (DBCA) in noninteractive or silent mode to configure and start Oracle Database on the system. To run DBCA in noninteractive or silent mode, you must copy and edit a response file template. Oracle provides a response file template named dbca.resp in the response directory on the CD-ROM or in the [.db.response] directory on the DVD.
If you copy the software to a hard disk, then the response file template is located in the [.Disk1.response] directory.
Silent mode or noninteractive mode requires an appropriate response file. The following sections discuss how to use and run DBCA in silent mode or noninteractive mode:
B.5.1 Using DBCA in Noninteractive Mode
In noninteractive mode, DBCA uses values that you specify in the response file or as command line options to create a database. As DBCA configures and starts the database, it displays a screen that contains status messages and a progress bar. The screen that it displays is the same screen that is displayed when you create a preconfigured database during an Enterprise Edition installation.
To run DBCA in noninteractive mode, you must use a graphical display and set the DISPLAY.
B.5.2 Using DBCA in Silent Mode
In silent mode, DBCA uses values that you specify in the response file or as command-line options to create a database. DBCA does not display any screens or information while it creates the database. It logs all messages (including information, errors, and warnings) in a log file.
From the command line, enter the following command to see all of the DBCA options that are available when you use the silent mode:
$ @ora_root:[bin]dbca.com -help
B.5.3 Running DBCA in Noninteractive or Silent Mode
To run DBCA in noninteractive or silent mode, use the following steps:
As an alternative to editing the response file template, you can also create a database by specifying all required information as command-line options when you run DBCA. For information about the supported options, enter the following command:
$ @ORA_ROOT:[bin]dbca
Because of the DCL limit of eight command-line parameters on OpenVMS, it is not possible to specify all the required parameters to create a database directly at the command line. Therefore, as a workaround, DBCA command-line arguments may be placed in a file called SYS$SCRATCH:DBCA.ARGS. The dbca.com script looks for this file, and if present, passes the specified arguments to the DBCA Java application. The dbca.com script ignores all arguments that are specified at at the command line except: -silent, -responseFile response_file, and -help. To avoid inadvertently applying the same arguments to the next invocation of DBCA when DBCA.ARGS exits, if an arguments file was used, then it is renamed to SYS$SCRATCH:DBCA.ARGS_OLD.
Because the DBCA design causes GUI classes to be loaded (even in silent mode), a silent installation requires an X connection.
  1. Copy the dbca.rsp response file template from the response file directory to a directory on the system:
    $ copy [src_path]dbca.rsp dest_path
    In this example, src_path is the CD-ROM directory or the db directory on the DVD. If you have copied the software to a hard drive, then you can edit the file in the response directory if you prefer.
  2. Open the response file in a text editor as follows:
    $ ed netca.rsp
    DBCA stops if you do not correctly configure the response file.
  4. Log in as the Oracle software owner user (typically oracle) and set the ORACLE_HOME logical to specify the correct Oracle home directory.
  5. If you intend to run DBCA in noninteractive mode, then set the DISPLAY.
  6. Enter a command similar to the following to run DBCA in noninteractive or silent mode with a response file:
    $ @ORA_ROOT:[bin]dbca {-progressOnly | -silent} [-cloneTemplate] -
    [-datafileDestination /datafilepath] -responseFile /local_dir/dbca.rsp
    In the example:
    • -silent indicates that you want to run DBCA in silent mode.
    • -progressOnly indicates that you want to run DBCA in noninteractive mode.
    • -cloneTemplate is required if you want to create one of the following preconfigured databases:
      • General Purpose
      • Transaction Processing
      • Data Warehouse
    • -datafileDestination specifies the parent directory where you want to create the database files. If you do not specify this option, then the parent directory for database files is the ora_root:[oradata] directory.
    • local_dir is the full path of the directory where you copied the dbca.rsp response file template.
The following sections contain examples that illustrate the use of silent mode.
DBCA Silent Mode Example 1: Creating a Clone Database
To create a clone database, enter the following in SYS$SCRATCH:DBCA.ARGS:
-silent
-createDatabase
-templateName Transaction_Processing.dbc
-gdbname ora10
-sid ora10
-datafileJarLocation /disk$disk1/oracle10g/ora10/assistants/dbca/templates
-datafileDestination /disk$disk1/oracle10g/ora10/oradata
-responseFile NO_VALUE
-characterset WE8ISO8859P1
Either OpenVMS-based arguments or UNIX-based arguments may be used in the arguments that are contained in an argument file.
Then, ensure that the ORACLE_HOME environment is set up by running:
$ @ORACLE_HOMEorauser
For example:
$ @Disk$disk1:[oracle10g.ora10]orauser
Next, start DBCA. Log files are located in the same place as with an interactive install. In this example:
Disk$disk1:[oracle10g.ora10.admin.ora10.create]
In addition, check the ORA_ROOT:[assistants.dbca.logs] directory.
DBCA Silent Mode Example 2: Creating a Seed Template
To create a seed template, enter the following in SYS$SCRATCH:DBCA.ARGS:
-silent
-createCloneTemplate
-sourceDB ora10
-sysDBAUserName sys
-sysDBAPassword change_on_install
-templateName copy_of_ora10
Then, ensure that the ORACLE_HOME environment is set up by running the orauser script, start DBCA. Log files for creating a seed template are located in the ORA_ROOT:[assistants.dbca.logs] directory.
