Skip Headers
Oracle® Database Installation Guide
10g Release 1 (10.1) for hp OpenVMS Alpha
Part No. B13681-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
G Troubleshooting
This appendix contains information about troubleshooting. It includes information about the following topics:
G.1 Verifying Requirements
Before performing any of the troubleshooting steps in this appendix, ensure that the system meets the requirements and that you have completed all of the preinstallation tasks specified in Chapter 2, "Preinstallation Tasks".
Read the Release Notes
Read the Release Notes for the product before installing it. The Release Notes are available on the Oracle Database CD-ROM. The latest version of the Release Notes is also available on the Oracle Technology Network Web site at
http://www.oracle.com/technology/documentation/index.html
G.2 X Window Display Errors
If you are running Oracle Universal Installer on a remote system and you want to display the Oracle Universal Installer user interface on a local system, you may see error messages similar to the following:
%DECW-E-CANT_OPEN_DISPL, Can't open display
If you see the preceding error message, and the X server is running on a UNIX host, then:
  1. In a local terminal window, log in as the user that started the X Window session.
  2. Enter the following command:
    $ xhost +
  3. Enter the following commands, where workstation_name is the host name or IP address of your workstation:
    • Bourne, Bash, or Korn shell:
      $ DISPLAY=workstation_name:0.0
      $ export DISPLAY
    • C or tcsh shell:
      % setenv DISPLAY workstation_name:0.0
  4. To determine whether X Window applications display correctly on the local system, enter the following command:
    $ xclock
    The X clock should be displayed on the monitor.
  5. If the X clock is displayed, then close X clock and start Oracle Universal Installer again.
This procedure applies only to users of UNIX workstations. If you are using a PC or other system with X server software installed, refer to the X server documentation for information about how to permit remote systems to display X applications on the local system.
G.3 Errors During Installation
If you encounter an error during installation:
G.4 Reviewing the Log of an Installation Session
During an installation, Oracle Universal Installer records all the actions that it performs in a log file. If you encounter problems during the installation, review the log file for information about possible causes of the problem.
To view the log file:
  1. Determine the location of the oraInventory directory with the following command:
    sys$login:[hostname]oraInst.loc
    The inventory_loc parameter in this file specifies the location of the oraInventory directory.
  2. Navigate to Oracle Universal Installer log file directory, where orainventory_location is the location of the oraInventory directory:
    $ set default [orainventory_location.logs]
  3. Enter the following command to determine the file name of the log file:
    $ dir
    This command lists the files in the order of creation, with the most recent file shown last. Installer log files have names similar to the following, where date_time indicates the date and time that the installation started:
    installActionsdate_time.log
  4. If an error displayed by Oracle Universal Installer or listed in the log file indicates a relinking problem, refer to the following file for more information:
    ora_root:[install]make.log
G.5 Troubleshooting Configuration Assistants
To troubleshoot an installation error that occurs when a configuration assistant is running:
G.5.1 Configuration Assistant Failure
Oracle configuration assistant failures are noted at the bottom of the installation screen. The configuration assistant interface displays additional information if available. The configuration assistant execution status is stored in the following file:
device:[orainventory_location.logs]installActionsdate_time.log
The execution status codes are listed in Table G-1:
Table G-1 Execution Status Codes
Status Result Code
Configuration assistant succeeded 0
Configuration assistant failed 1
Configuration assistant canceled -1
G.5.2 Fatal Errors
If you receive a fatal error while a configuration assistant is running, you must remove the current installation and reinstall the Oracle software as follows:
  1. Remove the failed installation as described in Section G.7, "Cleaning Up After a Failed Installation".
  2. Correct the cause of the fatal error.
  3. Reinstall the Oracle software.
G.6 Silent Response File Error Handling
To determine whether a silent installation succeeds or fails, refer to the following log file:
device:[orainventory_location.logs]silentInstalldate_time.log
If necessary, refer to the previous section for information about determining the location of the oraInventory directory.
A silent installation fails if:
Oracle Universal Installer or configuration assistant validates the response file at run time. If the validation fails, then the silent installation or configuration process ends. Oracle Universal Installer treats values for parameters that are of the wrong context, format, or type as if no value was specified in the file.
G.7 Cleaning Up After a Failed Installation
If an installation fails, you must remove files that Oracle Universal Installer created during the attempted installation and remove the Oracle home directory. Perform the following steps to remove the files:
  1. Start Oracle Universal Installer as described in Section 3.3.1, "Installing Oracle Database from the Hard Drive".
  2. Click Deinstall Products on the Welcome screen or click Installed Products on any Installer screen.
    The Inventory screen is displayed, listing installed products.
  3. Select the Oracle home that contains the products that you want to remove, then click Remove.
  4. Manually remove the Oracle home directory created during the failed installation.
  5. Reinstall the Oracle software.
