Skip Headers
Oracle® Database Installation Guide
10g Release 1 (10.1) for hp OpenVMS Alpha
Part No. B13681-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
6 Configuring RAC
This chapter provides an overview of the procedures for configuring Oracle Database 10g Real Application Clusters (RAC) on OpenVMS.
You may also need to refer to the following RAC documents for more complete information about installing and administering RAC on OpenVMS:
This chapter includes the following topics:
6.1 Creating Directories
If you decide to place the Oracle Cluster Ready Services (CRS), database, or recovery files on a file system, then use the following guidelines when deciding where to place them.
6.1.1 Guidelines for Placing Oracle CRS Files on a File System
Oracle Universal Installer does not suggest a default location for the Oracle Cluster Registry (OCR) or the Oracle CRS voting disk. If you choose to create these files on a file system, use the following guidelines when deciding where to place them:
  • You must choose a disk mounted and available on all the nodes in the RAC cluster.
  • It must have at least 100 MB of free disk space for the OCR and 20 MB of free disk space for the CRS voting disk.
  • For improved reliability, you should choose a file system on a highly available storage device, for example, a RAID device that implements mirroring.
  • The oracle user must have write permissions to create the files in the path that you specify.
6.1.2 Guidelines for Placing Oracle Database Files on a File System
If you choose to place the Oracle Database files on a file system, use the following guidelines when deciding where to place them:
  • You must select a disk that is accessible across all the nodes in the RAC cluster.
  • The default path suggested by Oracle Universal Installer for the database file directory is a subdirectory of the Oracle home directory. This default location is not recommended for production databases.
  • Choose a set of disks dedicated to the database.
    For best performance and reliability, choose a RAID device or a logical volume on more than one physical device and implement the stripe-and-mirror-everything (SAME) methodology.
    This method enables you to distribute physical I/O and create separate control files on different devices for increased reliability. You must choose either the Advanced database creation option or the Custom installation type during the installation to implement this method.
  • If you intend to create a preconfigured database during the installation, the file system (or file systems) that you choose must have at least 1.2 GB of free disk space.
    For production databases, you must estimate the disk space requirement depending on the use that you want to make of the database.
  • For optimum performance, the file systems that you choose should be on physical devices that are used only by the database.
6.1.3 Guidelines for Placing Oracle Database Recovery Files on a File System
You must choose a location for recovery files only if you intend to enable automated backups during the installation.
If you choose to place the Oracle Database recovery files on a file system, use the following guidelines for placement of Oracle Database recovery files on the file system:
  • To prevent disk failure from making both the database files and the recovery files unavailable, place the recovery files in a file system on a different physical disk from the database files.
  • You should choose a device that is accessible on all the nodes of the RAC cluster.
  • The device that you choose should have at least 2 GB of free disk space.
    The disk space requirement is the default disk quota configured for the flash recovery area (specified by the DB_RECOVERY_FILE_DEST_SIZE initialization parameter).
    If you choose the Custom installation type, then you can specify a different disk quota value. After you create the database, you can also use Oracle Enterprise Manager Grid Control to specify a different value.
    See Also:
    For more information about sizing the flash recovery area, refer to Oracle Database Backup and Recovery Basics (B10735-01)
  • The default path suggested by Oracle Universal Installer for the flash recovery area is a subdirectory of the Oracle home directory. You can choose this path only if you are using an Oracle Database base directory that is on a shared file system. This default location is not recommended for production databases.
6.1.4 Creating Required Directories
You must perform this procedure only if you want to place the Oracle CRS, database, or recovery files on a file system other than where the corresponding installations were created.
To create directories for the Oracle CRS, database, or recovery files on separate file systems from the installations:
  1. If necessary, configure the disks that you want to use and mount them on each node.
  2. Use the show device command to determine the free disk space on each mounted file system.
  3. From the display, identify the file systems that you want to use. Table 6-1 lists the disk space requirements for each file type.
    Table 6-1 File Types and Their Disk Space Requirements
    File Type File System Requirements
    CRS files Choose a file system with at least 120 MB of free disk space
    Database files Choose either:
    • A single file system with at least 1.2 GB of free disk space
    • Two or more file systems with at least 1.2 GB of free disk space in total
    Recovery files Choose a file system with at least 2 GB of free disk space.
    If you are using the same disk for more than one type of file, then add the disk space requirements for each type to determine the total disk space requirement.
  4. Note the names of the root device directories for the disks that you identified.
  5. Enter commands similar to the following to create the recommended subdirectories in each of the root device directories:
    • CRS file directory
      $ create/dir/own=oinstall root_device:[oracrs]
    • Database file directory
      $ create/dir/own=oinstall root_device:[oradata]
    • Recovery file directory (flash recovery area)
      $ create/dir/own=oinstall root_device:[flash_recovery_area]
6.2 Using DBCA for RAC
The primary functions of the Database Configuration Assistant (DBCA) processing include:
6.3 Benefits of Using DBCA
Oracle recommends that you use DBCA to create a RAC database, because DBCA preconfigured databases optimize the environment for features such as the server parameter file and automatic undo management.
By using DBCA, you can create site-specific tablespaces as a part of database creation. If you have data file requirements that differ from those offered by DBCA templates, then create the database with DBCA and modify the data files later. You can also run user-specified scripts athes part of the database creation process.
DBCA also configures the RAC environment for various Oracle Database high-availability features such as services and cluster administration tools. It also starts any database instances required to support the defined configuration.
6.4 Real Application Clusters High-Availability Services
When you configure high-availability services with DBCA Database Services screen, you can also configure service instance preferences and transparent application failover (TAF) policies. These are described in the following subsections:
6.4.1 Service Configuration and Instance Preferences
Use the Database Services screen button in the column labeled Not Used, Preferred, or Available to configure service instance preferences as described in the following list:
  • Preferred: The service runs primarily on the selected instance
  • Available: The service may run on the instance if a preferred instance fails
  • Not Used: The service never runs on the instance
6.4.2 Transparent Application Failover Policies
Use the DBCA Database Services screen to configure TAF failover policies. The DBCA Database Services screen also has a TAF policy selector row under the instance preference display. Make a selection in this row for your failover and reconnection policy preference as described in the following list:
  • None: Do not use TAF
  • Basic: Establish connections at failover time
  • Preconnect: Establish one connection to a preferred instance and another connection to a backup instance that you have selected to be available
6.5 Creating the Database After Installation By Using DBCA
To create a database by using DBCA in standalone mode, you must run the Oracle Net Configuration Assistant to configure the Oracle Net listener.ora file. To start DBCA, connect to one of the nodes with Oracle Real Application Clusters (RAC) installed and then enter the dbca command from the command line.
6.6 Creating a RAC Database By Using DBCA
The first screen that DBCA displays is the Welcome screen for RAC. DBCA displays this RAC-specific Welcome screen only if the Oracle Database home from which it is started is cluster installed.
If DBCA does not display the Welcome screen for RAC, then DBCA was not able to detect whether or not the Oracle home is cluster installed. In this case, verify that oraInventory is not damaged and that Oracle Universal Installer inventory, oraInst.loc, is present. By default, this file is placed in a directory that has the same name as the node from where the installation was performed, which, in most cases, is the primary node of the RAC cluster. This directory is in the login directory of the user who carried out the installation. Otherwise, perform the following steps to create a RAC database:
  1. Select Real Application Clusters database, click Next, and DBCA displays the Operations screen. DBCA enables the Configure Database Options, Delete a database, Instance Management, and Services Management options only if there is at least one RAC database configured on the cluster that runs from the Oracle Database home.
  2. Select Create a database and click Next, and DBCA displays the Node Selection screen.
  3. DBCA highlights the local node by default. Select the other nodes that you want to configure as members of the cluster database, click Next, and DBCA displays the Database Templates screen. If nodes that are part of the cluster installation are not displayed on the Node Selection screen, then perform inventory diagnostics and CRS diagnostics by running the olsnodes command.
  4. The templates on the Database Templates screen are Custom Database, Transaction Processing, Data Warehouse, and General Purpose. The Custom Database template does not include data files or options specially configured for a particular type of application. Use one of the other templates, which include data files, if you want to create a database with specifically configured options. Select the template from which you wish to create the cluster database, click Next, and DBCA displays the Database Identification screen.
  5. Enter the global database name and the Oracle Database system identifier (SID) prefix for the cluster database, click Next, and DBCA displays the Management Options screen.
    The global database name can be up to 30 characters in length and must begin with an alphabetic character. The SID prefix must begin with an alphabetic character and contain no more than 5 characters on OpenVMS-based systems. DBCA uses the SID prefix to generate a unique value for the ORACLE_SID for each instance.
  6. On the Management Options screen, you can choose to manage the database with Enterprise Manager. Despite choosing the Grid Control option, this will only configure EMAgent on OpenVMS. The Console component of Grid Control is not supported on OpenVMS platform. Refer to Appendix E, "Installing, Configuring, and Running EMAgent" for more information about how to configure the EMagent for use with the Grid Control Enterprise Manager, and how to manage and maintain the EMAgent for the OpenVMS platform.
    Click Next, and DBCA displays the Database Credentials screen.
  7. Enter the passwords for the database on the Database Credentials screen. You can enter the same or different passwords for the users SYS and SYSTEM, plus DBSNMP and SYSMAN if you selected Enterprise Manager on the Management Options screen. Select the Use the Same Password for All Accounts option to assign the same password to the listed users. Alternatively, provide a different password for each of these users by selecting the Use Different Passwords option. Enter the password information, click Next, and DBCA displays the Storage Options screen.
  8. Use the Storage Options screen to select a storage type for database creation. The Cluster File System option is the default. Select a storage option and click Next to proceed to the next screen. If you select Cluster File System, the Database File Locations screen is displayed.
  9. The Database File Locations screen enables you to select the file storage for the database files: locations provided in a template, a common location for all database files (the files will not be Oracle Database-managed files), or Oracle Database-managed files in a common location. If you do not select the template option, then you can enter an existing directory path name in the space provided, or click Browse to open a selection list.
    If you wish to multiplex the database redo log files and control files, click Multiplex Redo Logs and Control Files and provide the location for each copy you want. Click Ok when you have defined the multiplex locations to return to the Database File Locations screen.
    You can also define variables for the file locations if you plan to use the Database Storage screen, explained in Step 14, to define individual file locations.
  10. On the Recovery Configuration screen, you can select redo log archiving by selecting Enable Archiving. You can also select the flash recovery area and size on the Recovery Configuration screen. The flash recovery area defaults to @ora_root:[flash_recovery_area].
    You can also define variables for the file locations if you plan to use the Database Storage screen, explained in Step 14, to define individual file locations. When you have completed the entries, click Next, and the Database Content screen is displayed.
  11. On the Database Content screen, if you chose the Custom Database option, you can select or deselect the database components and their corresponding tablespace assignment. For a seed database, you can select whether to include the sample schemas in the database and to run custom scripts as part of the database creation processing. After completing the selections, click Next to display the Databases Services screen.
  12. To create services on the Database Services screen, expand the Services tree. Oracle Database displays the global database name in the top left corner of the screen. Select the global database name and click Add to add services to the database. Enter a service name in the Add a Service dialog box, and click OK to add the service and return to the Database Services screen.
    The service name is displayed under the global database name. Select the service name and DBCA displays the service preferences for the service on the right side of the DBCA Database Services screen. Change the instance preference (Not Used, Preferred, or Available) and transparent application failover (TAF) policies for the service as needed.
    Repeat this procedure for each service and when you are done configuring services for the database, click Next. DBCA displays the Initialization Parameters screen.
  13. By default, the Initialization Parameters screen shows only the basic parameters and only enables you to change the parameter file definition if you are using raw storage. Each tab on the Initialization Parameters screen provides different sets of information that you can add or modify as follows:
    1. Memory Tab
      Click Typical for default values based on the database type you selected or Custom to set values for the memory parameters. You can also see values for the advanced parameters by clicking All Initialization Parameters.
      Carefully review the parameter settings displayed in this dialog box because DBCA configures these settings in the server parameter file. Instance-specific parameter settings for the RAC database are displayed at the bottom of this dialog box. The sid prefixes for these entries are displayed in the left column.
      To review the instance-specific parameter settings, scroll downward using the scroll bar on the right side of the dialog box. Use the check box in the Override Default column to indicate that DBCA should place the parameter setting in the server parameter file. DBCA only places a parameter entry into the server parameter file if the entry displays a check mark in the Override Default column of the All Initialization Parameters dialog box.
      • You cannot modify the value of sid in the Instance columnYou can alter self-tuning parameters with this dialog box. However, setting these parameters to inappropriate values may disable Oracle Database self-tuning features.You cannot specify instance-specific values for global parameters with DBCA.
      • You should set the value of the CLUSTER_DB_INSTANCES parameter to the number of instances you intend to use in the cluster if you are not including all the related nodes during the current DBCA session.
      • If the global database name is longer than eight characters, then the database name value (in the db_name parameter) is truncated to the first eight characters and the DB_UNIQUE_NAME parameter value is set to the global name.
    2. Sizing Tab
      Use this screen to select the database standard block size and process count.
    3. Character Sets Tab
      Use this screen to set the database character set value.
    4. Connection Mode Tab
      You can use this tab to select either dedicated or shared database connections to the database.
    When you have specified all the information on the Initialization Parameters screen, click Next, and the Database Storage screen is displayed.
  14. If you selected a preconfigured database template, such as the General Purpose template, then DBCA displays the control files, data files, and redo logs on the Database Storage screen. Select the folder and the file name underneath the folder to edit the file name. However, if you selected the Custom Database template, the template without data files, then DBCA displays the control files, tablespaces, data files, and redo logs. To change the tablespace properties, such as the data file or the tablespace size, click the tablespaces icon to expand the object tree on the left side of the screen and click the tablespace. The tablespace property dialog box is displayed on the right side. Make the changes, and click Ok.
    After you specify all the information on the Database Storage screen, click Next, and DBCA displays the Creation Options screen.
  15. On the Creation Options screen, select one of the following database options and click Finish.
    • Create Database: Creates the database
    • Save as a Database Template: Creates a template that records the database structure, including user-supplied inputs, initialization parameters, and so on. You can later use this template to create a database.
    • Generate Database Creation Scripts: Generates database creation scripts. DBCA only displays this option if you selected the Custom Database template.
    After you click Finish, DBCA displays a Summary dialog box.
  16. Review the Summary dialog box information and click Ok to create the database.
After you complete Step 16, DBCA performs the following steps:
6.7 Deleting a RAC Database By Using DBCA
This section explains how to delete a RAC database by using DBCA. This process deletes a database and removes the initialization parameter files, instances, and Oracle net configuration of the database.
To delete a database by using DBCA:
  1. Start DBCA on one of the nodes by running the dbca command at the DCL command prompt.
  2. Select Oracle Real Application Clusters and click Next.
    After you click Next, DBCA displays the Operations screen.
  3. Select Delete a database, click Next, and DBCA displays the List of Cluster Databases screen.
  4. If your user ID and password are not authenticated by the operating system, then the List of Cluster Databases screen displays the user name and password fields. If these fields are displayed, then enter a user ID and password that has SYSDBA privileges.
  5. Select the database to delete and click Finish.
    After you click Finish, DBCA displays a dialog box to confirm the database and instances that DBCA is going to delete.
  6. Click Ok to begin the deletion of the database and its associated files, services, and environment settings, or click Cancel to stop the operation.
When you click Ok, DBCA continues the operation and deletes all of the associated instances for this database. The DBCA also removes the parameter files, password files, and oratab entries.
At this point, you have accomplished the following:
6.8 Configuring RAC
The following sections describe how to use the server parameter file (spfile) in Oracle Database 10g Real Application Clusters (RAC) as well as how to configure RAC once it has been installed.
See Also:
The Oracle Real Application Clusters Administration and Deployment Guide (B14197-01) for more information about parameters and the Oracle Real Application Clusters Deployment and Performance Guide (B10768-02) for a discussion of parallel execution-related parameters in RAC data warehouse environments
6.9 Parameter Files and RAC
Oracle Database uses parameter settings in parameter files to determine how to control various database resources. You can use two types of files for parameter administration: the server parameter file (spfile) or one or more traditional client-side parameter files.
Oracle recommends that you administer parameters using spfile. If you use client-side parameter files, then Oracle Database does not preserve parameter changes made for self-tuning after shutdown.
See Also:
The Oracle Database 10g Real Application Clusters documentation for more information about using client-side parameter files
6.10 Using Server Parameter Files in RAC
By default, Oracle Database creates the server parameter file based on one spfile. You can change parameter settings in the server parameter file only by using Oracle Enterprise Manager or ALTER SYSTEM SET SQL statements; the server parameter file is a binary file that you should not edit.
Oracle recommends that you avoid modifying the values for self-tuning parameters. Overriding these settings can adversely affect performance.
If you are upgrading from a previous Oracle Database release, then create and configure the server parameter file for RAC using the procedures described in the following section.
6.10.1 Location of the Server Parameter File
The default location of the server parameter file on a OpenVMS-based system is:
ORA_ROOT:[DBS]spfilesid.ora
Oracle recommends that you use a PFILE in this directory:
ORA_ROOT:[dbs]init$ORACLE_SID.ora
To use DBCA to create the database and to use the server parameter file, on the Initialization Parameters screen select Create server parameter file (spfile) under the File Locations tab, which is visible only if you are using raw storage. Then enter a shared file system file name in the Server Parameters Filename field.
When you use DBCA to create the server parameter file, the default PFILE file name is ORA_ROOT:[dbs]init$ORACLE_SID.ora on OpenVMS-based systems. This is the default PFILE name.
6.11 Parameter File Search Order in RAC
Oracle Database searches for the parameter file in the following order:
  1. ORA_ROOT:[oradata.$ORACLE_SID]spfilesid.ora
  2. ORA_ROOT:[oradata.$ORACLE_SID]spfile.ora
  3. ORA_ROOT:[DBS]initsid.ora
6.12 Upgrading to the Server Parameter File in RAC Environments
Upgrade to the server parameter file by creating and editing the server parameter file using the procedures described in this section.
6.12.1 Server Parameter File Placement in Real Application Clusters
For single-node cluster-enabled configurations, or if you are using a cluster file system, place the server parameter file on a file system.
6.12.2 Procedures for Upgrading to the Server Parameter File
Upgrade to the server parameter file by completing the following procedures:
  1. Combine the initialization parameter files for all instances into one initdbname.ora file by copying all shared IFILE contents as is. All parameters defined in the IFILE parameter files are global. Therefore, create them as parameter=value without sid prefixes.
  2. Copy all instance-specific parameter definitions from initsid.ora files using the following syntax where sid is the sid of the instance:
    sid.parameter=value
  3. Create the server parameter file using the CREATE SPFILE statement as in the following example:
    CREATE SPFILE='ORA_DB:spfile_dbname.ora'
    FROM PFILE='ora_root:[dbs]initdbname.ora'
  4. Oracle recommends that you use the server parameter file by running the STARTUP command as in this example:
    STARTUP PFILE=ORA_ROOT:[DBS]initsid.ora
    If you use this STARTUP command syntax, then Oracle Database uses the server parameter file entry specified in initsid.ora.
6.13 Server Parameter File Errors in RAC
Oracle Database reports errors that occur during server parameter file creation or while reading the file during startup. If an error occurs during a parameter update, then Oracle Database records the error in the ALERT.LOG file and ignores subsequent parameter updates to the file. If this happens, then do either of the following:
Oracle Database displays errors for parameter changes that you attempt when you incorrectly use the ALTER SYSTEM SET statement. Oracle Database does this when an error occurs while reading from or writing to the server parameter file.
See Also:
Oracle Real Application Clusters Administration and Deployment Guide (B14197-01) for more information about backing up the server parameter file
6.14 Understanding the RAC Installed Configuration
The following sections describe the RAC installed configuration:
6.14.1 Understanding the Configured Environment in RAC
The Oracle Net Configuration Assistant (NetCA) and DBCA configure the environment to meet the requirements for database creation and Enterprise Manager discovery of Real Application Cluster databases.
Configuration files are created on each node in the cluster database.
6.14.2 Oracle Cluster Registry in RAC
The DBCA uses the Oracle Cluster Registry (OCR) for storing the configurations for the cluster databases that it creates. Oracle Universal Installer automatically initializes the OCR during the CRS installation.
6.14.3 OpenVMS oratab Configurations for Real Application Clusters
Oracle Database creates an entry for each RAC database in the oratab configuration file. Oracle Enterprise Manager uses this file during service discovery to determine the name of the RAC database as well as whether or not the database should be automatically started on restart. The database entry has the following syntax:
db_unique_name:ORACLE_HOME:N
where db_unique_name is the database name for the RAC database, ORACLE_HOME is the UNIX-style directory path to the database, and N indicates that the database should not be started at startup time. A sample entry for a database named db is:
db:/private/system/db:N
The notation db_name displayed in the preceding example and throughout this chapter refers to the database name you enter when prompted by DBCA, or it refers to the entry you made for the DATABASE keyword of the CREATE DATABASE statement.
6.15 Database Components Created Using DBCA
This section describes the database components that DBCA creates, which include:
6.15.1 Tablespaces and Data Files
For both single-instance and cluster database environments, Oracle Database is divided into smaller logical areas of space known as tablespaces. Each tablespace corresponds to one or more data files stored on a disk. Table 6-2 shows the tablespace names used by a RAC database and the types of data they contain:
Table 6-2 Tablespace Names Used by RAC Databases
Tablespace Name Contents
SYSTEM Consists of the data dictionary, including definitions of tables, views, and stored procedures needed by the database. Oracle Database automatically maintains information in this tablespace.
SYSAUX An auxiliary system tablespace that contains the DRSYS (contains data for OracleText), ODM (for Oracle Data Mining), TOOLS (contains Enterprise Manager tables), INDEX, and EXAMPLE tablespaces.
USERS Consists of application data. As you create and enter data into tables, Oracle Database fills this space with your data.
TEMP Contains temporary tables and indexes created during SQL statement processing. You may need to expand this tablespace if you are running a SQL statement that involves significant sorting, such as ANALYZE COMPUTE STATISTICS on a very large table, or the constructs GROUP BY, ORDER BY, or DISTINCT.
UNDOTBSn These are the undo tablespaces for each instance that DBCA creates for automatic undo management.
RBS If you do not use automatic undo management, then Oracle Database uses the RBS tablespace for the rollback segments.
You cannot alter these tablespace names when using the preconfigured database configuration options from Oracle Universal Installer. However, you can change the names of the tablespaces if you use the advanced database creation method.
As mentioned, each tablespace has one or more data files. The data file names created by the preconfigured database configuration options vary by operating system. Microsoft Windows-based platforms use the symbolic link names for the data file and other database files shown in Table 6-3.
Table 6-3 Microsoft Windows-Based Platforms Symbolic Link Names and Files
Microsoft Windows-Based Platforms Symbolic Link Names Tablespace or Other Database Files
db_name_system SYSTEM
db_name_SYSAUX SYSAUX
db_name_users USERS
db_name_temp TEMP
db_name_undotbs1 UNDOTBS1
db_name_undotbs2 UNDOTBS2
db_name_rbs RBS (optional)
db_name_example EXAMPLE
db_name_indx INDX
db_name_spfile SPFILE
db_name_control1 Control File 1
db_name_control2 Control File 2
db_name_redo_instance_number log_number
Where instance_number is the number of the instance and log_number is the log number (1 or 2) for the instance.
Redo Log Files
Each instance must have at least two redo log files. If the database name is db, then the link names for the first instance are:
db_redo1_1
db_redo1_2
The link names of the redo log files of the second instance are:
db_redo2_1
db_redo2_2
6.15.2 Control Files
The database is configured with two control files that are stored on shared storage.
6.15.3 Redo Log Files
Each instance is configured with at least two redo log files that are stored in the shared storage. If you selected cluster file system, then these files are shared file system files. The file names of the redo log files that are created with the preconfigured database configuration options vary by storage type.
6.16 Managing Undo Tablespaces in RAC
Oracle Database stores rollback or undo information in undo tablespaces. To manage undo tablespaces, Oracle recommends that you use automatic undo management. Automatic undo management is an automated undo tablespace management mode that is easier to administer than manual undo management.
See Also:
Oracle Real Application Clusters Administration and Deployment Guide (B14197-01) for more information about managing undo tablespaces
6.17 Configuring Service Registration-Related Parameters in RAC
Two key benefits of RAC are connection load balancing and failover. RAC extends the ability of single-instance Oracle Database load balancing, where connections are distributed among local dispatchers, to the balancing of connections among all instances in a cluster database. In addition, RAC provides failover by configuring multiple listeners on multiple nodes to manage client connection requests for the same database service. Connection load balancing and failover increase availability by taking advantage of the redundant resources within a cluster database. These features, however, require cross-instance registration.
Cross-instance registration in RAC occurs when the PMON process of an instance registers with the local listener and with all other listeners. Therefore, all instances in the cluster database register with all listeners running on nodes that run instances of the cluster database. This enables all listeners to manage connections across all instances for both load balancing and failover.
Cross-instance registration requires configuring the LOCAL_LISTENER and REMOTE_LISTENER initialization parameters. The LOCAL_LISTENER parameter identifies the local listener, and the REMOTE_LISTENER parameter identifies the global list of listeners. The REMOTE_LISTENER parameter is dynamic. Oracle Database changes the setting for REMOTE_LISTENER dynamically when you reconfigure the cluster database, for example, when you add or delete instances.
By default, DBCA configures the environment with dedicated servers. However, if you select the Shared server option on DBCA, then Oracle Database configures the shared server. In this case, Oracle Database uses both dedicated and shared server processing. When shared servers are configured, the DISPATCHERS parameter is specified as in the following example:
DISPATCHERS="(protocol=tcp)"
If the DISPATCHERS initialization parameter does not specify the LISTENER attribute as in the previous example, then the PMON process registers information for all dispatchers with the listeners specified by the LOCAL_LISTENER and REMOTE_LISTENER parameters.
However, when the LISTENER attribute is specified, the PMON process registers dispatcher information with the listeners specified by the LISTENER attribute. In this case, setting the LISTENER attribute overrides REMOTE_LISTENER settings for the specified dispatchers as in the following example:
DISPATCHERS="(protocol=tcp)(listener=listeners_db_name)"
See Also:
Oracle Database Net Services Administrator's Guide (B10775-01) for more information about cross-instance registration, shared and dedicated server configurations, and connection load balancing
6.18 Configuring the Listener File (listener.ora)
You can configure two types of listeners in the listener.ora file as described under the following headings:
6.18.1 Local Listeners
If you configured dedicated server mode by using the DBCA Connection Mode tab on the Initialization Parameters screen, then DBCA automatically configures the LOCAL_LISTENER parameter when the listener uses a nondefault address port.
If you configured the dedicated server mode by setting the REMOTE_LISTENER initialization parameter, then you must also configure the instance-specific LOCAL_LISTENER initialization parameter.
For example, to configure the LOCAL_LISTENER parameter, add the following entry to the initialization parameter file, where listener_sid is resolved to a listener address through either a tnsnames.ora file or through the Oracle Names Server:
sid.local_listener=listener_sid
The following entry should be in the tnsnames.ora file:
listener_sid=(address=(protocol=tcp)(host=node1-vip)(port=1522))
6.18.2 Multiple Listeners
If DBCA detects more than one listener on the node, it displays a list of the listeners. You can select one or all of these listeners with which to register the database.
6.18.3 How Oracle Database Uses the Listener (listener.ora)
Services coordinate their sessions using listener file entries by running a process on the server that receives connection requests on behalf of a client application. Listeners are configured to respond to connection requests sent to protocol addresses for a database service or nondatabase service.
Protocol addresses are configured in the listener configuration file, listener.ora, for a database service or a nondatabase service. Clients configured with the same addresses can connect to a service through the listener.
During a preconfigured database configuration installation, the Oracle Net Configuration Assistant creates and starts a default listener called LISTENER_NODENAME. The listener is configured with a default protocol listening addresses for the database and external procedures. The advanced installation process prompts you to create at least one listener with the Oracle Net Configuration Assistant. The listener is configured to respond to connection requests that are directed at one protocol address that you specify, as well as an address for external procedures.
Both installation modes configure service information about the RAC database and external procedures. A database service automatically registers its information with the listener, such as its service name, instance names, and load information. This feature, called service registration, does not require configuration in the listener.ora file. After listener creation, the Oracle Net Configuration Assistant starts the listener. A sample listener.ora file with an entry for an instance named node1 is:
listener_node1=
  (description=
    (address=(protocol=ipc)(key=extproc))
    (address=(protocol=tcp)(host=node1-vip)(port=1521))
    (address=(protocol=tcp)(host=node1-ip)(port=1521)))
sid_list_listener_node1=
  (sid_list=
    (sid_desc=
      (sid_name=plsextproc)
      (oracle_home=/private/system/db)
      (program=extproc)
6.18.3.1 Listener Registration and PMON Discovery
When a listener starts after the Oracle Database instance starts, and the listener is listed for service registration, registration does not occur until the next time the PMON discovery routine runs. By default, PMON discovery occurs every 60 seconds.
To override the 60-second delay, use the SQL ALTER SYSTEM REGISTER statement. This statement forces PMON to register the service immediately.
Oracle recommends that you create a script to process this statement immediately after starting the listener. If you run this statement while the listener is up and the instance is already registered, or while the listener is down, then the statement has no effect.
See Also:
Oracle Database Net Services Administrator's Guide (B10775-01) for more information about the listener and the listener.ora file
6.19 Directory Server Access (ldap.ora File)
If you configure access to a Lightweight Directory Access Protocol (LDAP)-compliant directory server with the Oracle Net Configuration Assistant during a Custom installation, then an ldap.ora file is created. The ldap.ora file contains the following types of information:
6.20 Net Service Names (tnsnames.ora File)
A tnsnames.ora file is created on each node with net service names. A connect identifier is an identifier that maps to a connect descriptor. A connect descriptor contains the following information:
The DBCA creates net service names for connections as follows:
Database Connections
Clients that connect to any instance of the database use the net service name entry for the database. This entry also enables Oracle Enterprise Manager to discover a RAC database.
A listener address is configured for each node that runs an instance of the database. The LOAD_BALANCE option causes Oracle Database to choose the address randomly. If the chosen address fails, then the FAILOVER option causes the connection request to fail over to the next address. Therefore, if an instance fails, then clients can still connect using another instance.
In the following example, db.us.oracle.com is used by the client to connect to the target database, db.us.oracle.com.
db.us.acme.com=
 (description=
  (load_balance=on)
   (address=(protocol=tcp)(host=node2-vip)(port=1521)
  (connect_data=
     (service_name=db.us.acme.com)))
FAILOVER=ON is set by default for a list of addresses. Therefore, you do not need to explicitly specify the FAILOVER=ON parameter.
When you set DB_UNIQUE_NAME by entering a global database name that is longer than eight characters, excluding DB_DOMAIN, then a net service entry similar to the following is created:
mydatabase.us.acme.com=
  (description =
     (address = (protocol = tcp)(host = node1-vip)(port = 1521))
     (address = (protocol = tcp)(host = node2-vip)(port = 1521))
  (load_balance = yes)
     (connect_data =
   (server = dedicated)
   (service_name = mydatabase.us.acme.com)
Instance Connections
Clients that connect to a particular instance of the database use the net service name entry for the instance. This entry, for example, enables Oracle Enterprise Manager to discover the instances in the cluster. These entries are also used to start and stop instances.
In the following example, db1.us.acme.com, is used by Oracle Enterprise Manager to connect to an instance named db1 on db1-server:
db1.us.acme.com=
 (description=
  (connect_data=
    (instance_name=db1)))
Remote Listeners
As discussed in Section 6.17, "Configuring Service Registration-Related Parameters in RAC", the REMOTE_LISTENER parameter identifies the global list of listeners and it is dynamic. Oracle Database changes the setting for REMOTE_LISTENER when you reconfigure the cluster database.
Whether using shared servers or dedicated servers, the list of remote listeners is supplied using the REMOTE_LISTENERS parameter, for example:
REMOTE_LISTENERS=listeners_db_unique_name
This enables the instance to register with remote listeners on the other nodes; listeners_db_unique_name is resolved through a naming method such as a tnsnames.ora file.
In the following example, listeners_db.us.acme.com is resolved to a list of listeners available on the nodes on which the cluster database has instances:
listeners_db.us.acme.com=
(address_list=
   (address=(protocol=tcp)(host=node2-vip)(port=1521)))
The instance uses this list to determine the addresses of the remote listeners with which to register its information.
Nondefault Listeners
As discussed in Section 6.18.1, "Local Listeners" and Section 6.18.2, "Multiple Listeners", the LOCAL_LISTENER parameter is set in the initsid.ora file if a nondefault listener is configured. For example:
Where listener_sid is resolved to a listener address through a naming method such as a tnsnames.ora file.
In the following example, listener_db1.us.acme.com is resolved to the nondefault listener address:
listener_db1.us.acme.com=
Services Entries
When you configure high-availability services using the DBCA Services screen, then DBCA creates net service entries similar to the following. The three services in the following examples, db_svc1, db_svc2, and db_svc3, have TAF policies of NONE, BASIC and PRECONNECT, respectively.
db_svc1.us.acme.com=
  (description =
    (load_balance=yes)
    (connect_data=
        (service_name = db_svc1.us.acme.com)
db_svc2.us.acme.com=
  (description=
    (load_balance=yes)
    (connect_data =
        (service_name=db_svc2.us.acme.com)
        (failover_mode =
        (type=select)
        (method=basic)
           (retries=180)
           (delay=5)
db_svc3.us.acme.com=
    (description=
      (load_balance=yes)
      (connect_data=
        (server=dedicated)
        (service_name=db_svc3.us.acme.com)
        (failover_mode=
        (backup=db_svc3_preconnect.us.acme.com)
        (type=select)
        (method=preconnect)
        (retries=180)
        (delay=5)
When a service has a TAF policy of PRECONNECT, then a service_name_preconnect net service entry is also created as in the following example:
db_svc3_preconnect.us.acme.com =
  (description =
    (connect_data =
      (service_name = db_svc3_preconnect.us.amce.com)
      (failover_mode =
        (backup = db_svc3.us.acme.com)
        (type = select)
        (method = basic)
        (retries = 180)
        (delay = 5)
External Procedures
An entry for connections to external procedures. This enables an Oracle Database to connect to external procedures.
extproc_connection_data.us.acme.com=
 (description=
  (address_list=
    (address=(protocol=ipc)(key=extproc0))
  (connect_data=
    (sid=plsextproc)))
Example 6-1 Example tnsnames.ora File
The following is a sample tnsnames.ora file that is created during a preconfigured database configuration installation:
db.us.acme.com=
 (description=
  (load_balance=on)
  (connect_data=
db1.us.acme.com=
 (description=
  (connect_data=
db2.us.acme.com=
 (description=
  (connect_data=
    (instance_name=db2)))
(address_list=
 (description=
  (address_list=
    (address=(protocol=ipc)(key=extproc)))
  (connect_data=
    (sid=plsextproc)
    (presentation=RO)))
See Also:
Oracle Database Net Services Administrator's Guide (B10775-01) for more information about the tnsnames.ora file
6.21 Profile (sqlnet.ora File)
The sqlnet.ora file is automatically configured with:
The following is a sample sqlnet.ora file created during a preconfigured database configuration install:
names.default_domain=us.acme.com
names.directory_path=(tnsnames, onames,hostname)
See Also:
Oracle Database Net Services Administrator's Guide (B10775-01) for more information about the sqlnet.ora file
