Oracle® Transparent Gateway for iWay Installation and User's Guide
10g Release 1 (10.1) for IBM z/OS (OS/390) Part No. B13682-01 |
![]() Previous |
![]() Next |
The following is a list of the Oracle SQL functions in alphabetic order.
Table E-1 Oracle SQL Functions in Alphabetic Order
| ABS | ACOS | ADD_MONTHS | ASIN |
| ASCII | ATAN | ATAN2 | CEIL |
| CHAR_TO_ROWID | CHR | CONVERT | COS |
| COSH | DECODE | DUMP | EXP |
| FLOOR | GREATEST | HEXTORAW | INITCAP |
| INSTR | INSTRB | LAST_DAY | LEAST |
| LENGTH | LENGTHB | LN | LOG |
| LOWER | LPAD | LTRIM | MOD |
| MONTHS_BETWEEN | NEW_TIME | NEXT_DAY | NLS_INITCAP |
| NLS_LOWER | NLS_UPPER | NLSSORT | POWER |
| RAWTOHEX | REPLACE | ROUND | ROWIDTOCHAR |
| RPAD | RTRIM | SIGN | SIN |
| SINH | SOUNDEX | SQRT | STDDEV |
| SUBSTR | SUBSTRB | SYSDATE | TAN |
| TANH | TO_CHAR | TO_DATE | TO_LABEL |
| TO_MULTI_BYTE | TO_NUMBER | TO_SINGLE_BYTE | TRANSLATE |
| TRUNC | UID | UPPER | USER |
| USERENV | VARIANCE | VSIZE |
