Oracle® Application Server Repository Creation Assistant User's Guide
10g (9.0.4.0.2) for Microsoft Windows Part No. B13913-01 |
Instead of removing OracleAS Metadata Repository schemas and tablespaces from your database by running SQL statements manually, you can remove these objects by running the cleanMR script. The script executes the SQL statements in the repca_cleanup.sql file, located in the same directory as the cleanMR script.
Contents:
You cannot run the cleanMR script directly from the "Oracle Application Server Metadata Repository Creation Assistant and Utilities" CD-ROM or the Oracle Application Server DVD because the script needs to create a file in the directory containing the script.
Copy the entire clean directory from the CD-ROM or DVD to your hard disk. Ensure that you can access the hard disk from the computer where the database is installed, because you must run the cleanMR script on the computer that is running the database.
Table 3-1 Location of the clean Directory on CD-ROM and DVD
| Media | Location of the clean Directory |
| CD-ROM | "Oracle Application Server Metadata Repository Creation Assistant and Utilities" CD-ROM (assumes E: is your CD-ROM drive): E:\repCA\repca\clean\
| DVD | (assumes E: is your DVD-ROM drive): E:\repca_utilities\repca\clean\
The following example copies the directory to the C:\oracle directory.
C:\> xcopy /e /i E:\repCA\repca\clean C:\oracle\clean
DVD (assumes E: is your DVD-ROM drive):
C:\> xcopy /e /i E:\repca_utilities\repca\clean C:\oracle\clean
You must run the cleanMR script on the computer that is running the database.
The cleanMR script is located in the clean directory that you copied to your hard disk (see Section 3.1, "Copy the Directory to Your Hard Disk").
Run the script from the clean directory that you copied to your hard disk. The following example assumes you copied the clean directory to the C:\oracle directory.
C:\> cd C:\oracle\clean C:\> cleanMR -OH db_OH -DBSID sid [-DBUSER dbuser] -DBPASSWD password [-DBROLE dbrole]
Table 3-2 Parameters for the cleanMR Command
| Parameter | Optional or Required | Description |
-OH db_OH
Required | Specifies the ORACLE_HOME directory for the database. |
-DBSID sid
Required | Specifies the SID of the database. |
-DBUSER dbuser
Optional | Specifies the database user that the script will use to connect to the database. If not specified, the default user is "SYS". |
-DBPASSWD password
Required | Specifies the password for DBUSER. |
-DBROLE dbrole
Optional | Specifies the database user role. If not specified, the default role is "SYSDBA". |
Example:
cleanMR -OH C:\oracle\oradb -DBSID hrdb -DBPASSWD topsecret
Notes:
The script does not remove the ODS schema, and it does not remove these tablespaces: OLTS_ATTRSTORE, OLTS_BATTRSTORE, OLTS_CT_STORE, OLTS_DEFAULT, OLTS_SVRMGSTORE. These objects pertain to Oracle Internet Directory.
If you want the script to remove these objects, search for the object names and uncomment the corresponding lines in the repca_cleanup.sql file (located in the same directory as the cleanMR script).
The script does not remove data files.
