Skip Headers
Oracle® Application Server Repository Creation Assistant User's Guide
10g (9.0.4.0.2) for Microsoft Windows
Part No. B13913-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous Next
Preface
This guide describes how to run the Oracle Application Server Repository Creation Assistant tool, which enables you to load OracleAS Metadata Repository into an existing database. You can also use the Oracle Application Server Repository Creation Assistant to register OracleAS Metadata Repository with Oracle Internet Directory.
Intended Audience
This guide is intended for database administrators. You need to be able to log in to your database as the SYS user. Steps that you might need to perform include changing the value of database initialization parameters, backing up schemas and tablespaces, and restarting the database.
Documentation Accessibility
Our goal is to make Oracle products, services, and supporting documentation accessible, with good usability, to the disabled community. To that end, our documentation includes features that make information available to users of assistive technology. This documentation is available in HTML format, and contains markup to facilitate access by the disabled community. Standards will continue to evolve over time, and Oracle is actively engaged with other market-leading technology vendors to address technical obstacles so that our documentation can be accessible to all of our customers. For additional information, visit the Oracle Accessibility Program Web site at
http://www.oracle.com/accessibility/
Accessibility of Code Examples in Documentation  JAWS, a Windows screen reader, may not always correctly read the code examples in this document. The conventions for writing code require that closing braces should appear on an otherwise empty line; however, JAWS may not always read a line of text that consists solely of a bracket or brace. Accessibility of Links to External Web Sites in Documentation  This documentation may contain links to Web sites of other companies or organizations that Oracle does not own or control. Oracle neither evaluates nor makes any representations regarding the accessibility of these Web sites.
Structure
This guide contains the following chapters:
Chapter 1, "Oracle Application Server Repository Creation Assistant Overview and Requirements"
This chapter provides an overview of Oracle Application Server Repository Creation Assistant and lists the space and database requirements.
Chapter 2, "Running Oracle Application Server Repository Creation Assistant"
This chapter describes the parameters that you need to specify to start up Oracle Application Server Repository Creation Assistant. It also describes the Oracle Application Server Repository Creation Assistant screens.
Chapter 3, "Running the cleanMR Script"
This chapter describes how to use the cleanMR script, which removes OracleAS Metadata Repository schemas and tablespaces from your database.
Chapter 4, "Deregistering a Metadata Repository"
This chapter shows how to remove entries from the Oracle Internet Directory where OracleAS Metadata Repository is registered.
Chapter 5, "Troubleshooting"
This chapter describes common problems and solutions.
Related Documents
For more information, see the following books:
Conventions
The following conventions are also used in this manual:
Convention Meaning
boldface text Boldface type in text indicates objects (such as buttons and fields) on screens.
code Text in the code font indicates filenames, commands, or contents of configuration files.
italicized code Italicized code font indicates placeholder text that you need to replace with an appropriate value.
[ ] Brackets enclose optional clauses from which you can choose one or none.
. . . Ellipses indicate that extraneous information have been omitted.
