Skip Headers
Oracle® Application Server Reports Services Publishing Reports to the Web
10g Release 2 (10.1.2)
B14048-02
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
B Environment Variables
Environment variables are parameters that configure the Oracle Reports environment. The Oracle Application Server installer automatically defines default values for relevant environment variables. Edit the environment variable settings to change the default behavior:
The information in this appendix is also documented in the Oracle Reports online Help, which is available in Reports Builder or hosted on the Oracle Technology Network (OTN), as described in the Preface under "Related Documentation".
B.1 Environment Variables
Table B-1 provides an alphabetical summary list of all the Oracle Reports environment variables alphabetically, showing valid and default value.
Table B-1 Oracle Reports Environment Variables
Kewords Valid Values Default
CA_GPREFS
Any directory on any drive
ORACLE_HOME
CA_UPREFS
YES|NO
YES
DELIMITED_LINE_END
YES|NO
YES
DOC
ORACLE_HOME\tools\doc
DEVELOPER_NLS_LANG
See Chapter 18, "Implementing Globalization and Bidirectional Support"
NLS_CALENDAR
NLS_CREDIT
NLS_CURRENCY
NLS_DATE_FORMAT
NLS_DATE_LANGUAGE
NLS_DEBIT
NLS_ISO_CURRENCY
NLS_LANG
AMERICAN_AMERICA.WE8ISO8859P1
NLS_LIST_SEPARATOR
NLS_MONETARY_CHARACTERS
NLS_NUMERIC_CHARACTERS
NLS_SORT
ORACLE_AFM
Not defined
ORACLE_HOME
C:\orawin
ORACLE_HPD
Not defined
ORACLE_PATH
Not defined
ORACLE_PPD
Not defined
ORACLE_TFM
Not defined
ORAINFONAV_DOCPATH
Not defined
PRINTER
Name of default printer
Not defined
REMOTE
Any valid SQL* Net driver prefix and parameters
Not defined
REPORTS_ADD_HWMARGIN
YES|NO
NO
REPORTS_ARABIC_NUMERAL
ARABIC|HINDI\CONTEXT
ARABIC (Indo-Arabic)
REPORTS_BIDI_ALGORITHM
ORACLE|UNICODE
ORACLE
REPORTS_CGIDIAGBODYTAGS
Any valid HTML attributes for the <BODY> tag.
Not defined
REPORTS_CGIDIAGHEADTAGS
Any HTML tags that are valid between <HEAD> and </HEAD>.
Not defined
REPORTS_CGIHELP
Any valid URL to a Web page or a HTML file.
A default help screen is displayed in the browser.
REPORTS_CGIMAP
A valid path to the map file.
ORACLE_HOME\reports\conf\cgicmd.dat
REPORTS_CGINODIAG
YES|NO
NO
REPORTS_CLASSPATH
The default values are mandatory. If any of the entries are removed, the Oracle Reports executables may not behave correctly. Any additional user-defined directory or JAR file that contains Java Classes may be appended to the path.
%ORACLE_HOME%\reports\jlib\rwbuilder.jar;%ORACLE_HOME%\reports\jlib\rwrun.jar;%ORACLE_HOME%\jlib\zrclient.jar;%ORACLE_HOME%\j2ee\home\oc4j.jar;%ORACLE_HOME%\j2ee\home\lib\ojsp.jar
REPORTS_CONTAINSHTMLTAGS
YES|NO
YES
REPORTS_COOKIE_EXPIRE
Any number of minutes
30
REPORTS_DB_AUTH
Any HTML file that contains special authentication actions. It is recommended that you keep the default.
dbauth.htm
REPORTS_DEFAULT_DISPLAY
YES|NO
YES
REPORTS_DEFAULT_PIXEL_SIZE
Any value ranging from 72 through 200.
Surface resolution determined by Oracle Reports.
REPORTS_ENABLE_RTF_SPACING
YES|NO
NO
REPORTS_ENCRYPTION_KEY
Any encryption key.
reports9.0
REPORTS_ENHANCED_SUBSET
YES|NO
YES
REPORTS_GRAPH_IMAGE_DPI
72 through 300
72
REPORTS_IGNORE_IMAGE_TAG_RES
YES|NO
NO
REPORTS_JPEG_QUALITY_FACTOR
1 through 100
100
REPORTS_JVM_OPTIONS
List of JVM options in the JVM command line syntax.
-Xmx256M
REPORTS_NETWORK_CONFIG
Valid custom network configuration file name in ORACLE_HOME/reports/conf/
rwnetwork.conf
REPORTS_NLS_XML_CHARSETS
Set of mapping pairs separated by semicolons. The first value is the encoding that is being produced and the second mapped value is the value that should be used for these cases.
<old_name>=<new_name>[;<old_name>=<new_name>][;<old_name>=<new_name>]...
Not defined.
REPORTS_NO_DUMMY_PRINTER
TRUE|not set
TRUE
REPORTS_NO_HTML_SPACE_REPLACE
YES|not set
not set
REPORTS_OUTPUTIMAGEFORMAT
GIF|JPEG|JPG|PNG|BMP
JPEG
REPORTS_PATH
Any directory on any drive.
%ORACLE_HOME%\REPORT\DEMO; %ORACLE_HOME%\REPORT\DEMO\BITMAP; %ORACLE_HOME%\REPORT\DEMO\REQFILES
REPORTS_RESOURCE
%ORACLE_HOME%\reports\res\US
REPORTS_SERVER
Any Reports Server service entry name.
REPORTS_SOLARIS_9
YES|NO
YES on Solaris 2.9; NO on other platforms
REPORTS_SPACE_BREAK
YES|NO
YES
REPORTS_SRWRUN_TO_SERVER
YES|not set
not set
REPORTS_SSLPORT
Any valid port number.
443
REPORTS_SYS_AUTH
sysauth.htm
REPORTS_TAGLIB_URI
Any "uri" that references the Oracle Reports tag library.
/WEB-INF/lib/reports_tld.jar
REPORTS_TMP
Not defined.
REPORTS_USEREXITS
Any user exit dynamic link library (along with its absolute path).
Not defined.
REPORTS_UTF8_XMLOUTPUT
YES|NO
YES
RW
A valid directory name.
%ORACLE_HOME\reports (Windows)
$ORACLE_HOME/reports (UNIX)
TK_PRINT
The PRINT command and all necessary keywords for your flavor of UNIX, including the following elements:
  • %n is the printer name string.
  • %c is the number of copies.
This string is much like a printf() format. If this environment variable is not set, Oracle Reports 6i uses the standard default value for the platform. Examples of default values on various platforms are as follows:
System V: lp -s -d'%n' -n%c
Solaris: lpr -P'%n' -#%c -s
Not defined.
TK_PRINT_STATUS
Should include %n for the printer name (see also TK_PRINT).
If this environment variable is not set, Oracle Reports uses the built-in default values:
System V: /usr/bin/lpstat -p'%n' 2>&1
Other: /usr/etc/lpc status '%n' 2>&1
Not defined.
TK_PRINTER
Name of default printer.
Not defined.
TK_AFM
Not defined.
TK_HPD
Not defined.
TK_PPD
Not defined.
TK_TFM
Not defined.
USERNAME
Any valid Oracle username (without the OPS$ prefix).
Not defined.
USER_NLS_LANG
B.1.1 CA_GPREFS
Description  This environment variable specifies the location of the global preferences file, CAGPREFS.ORA. Global preferences are shared among networked users. In addition to searching the directory specified by CA_GPREFS, products will also search the current directory for the CAGPREFS.ORA file.
The CAGPREFS.ORA file is automatically created by the Oracle Installer. To modify the global preference settings, use a text editor such as Notepad to manually edit this file. Global preferences set in the CAGPREFS.ORA file can be overridden by the local preference file, CAUPREFS.ORA, which is defined by CA_UPREFS.
Valid Values Any directory on any drive.
Default ORACLE_HOME
Example CA_GPREFS=C:\orawin
B.1.2 CA_UPREFS
Description This environment variable specifies the location of the user preferences file, CAUPREFS.ORA. The CAUPREFS.ORA file maintains the preferences that you set through Tools >Tools Options within your products. In addition to searching the directory specified by CA_UPREFS, the product will also search the current directory for the CAUPREFS.ORA file.
Several Oracle products write their preference information to the CAUPREFS.ORA file. To manually modify the user preference settings, use a text editor such as Notepad to edit this file. User preferences set in the CAUPREFS.ORA file override global preferences set in the CAGPREFS.ORA file, which is defined by CA_GPREFS.
Default ORACLE_HOME
Example CA_UPREFS=C:\orawin
B.1.3 DELIMITED_LINE_END
Description This environment variable specifies whether to print the delimited character at the end of the line for delimited output.
Valid Values YES|NO
Default YES
Usage Notes
  • Set this environment variable to NO to ensure that the delimited character is not printed at the end of the line.
B.1.4 DOC
Description This environment variable specifies the location of the online documentation files, including online Help.
Default ORACLE_HOME\tools\doc
Example DOC=C:\myreports_1012\tools\doc
B.1.5 DEVELOPER_NLS_LANG
Description This environment variable specifies the language for the report. Chapter 18, "Implementing Globalization and Bidirectional Support" contains additional detailed information about this environment variable, including a table of valid values.
B.1.6 NLS_CALENDAR
Description This environment variable specifies the calendar system used.
B.1.7 NLS_CREDIT
Description This environment variable specifies the string used to indicate a positive monetary value.
B.1.8 NLS_CURRENCY
Description This environment variable specifies the local currency symbol.
B.1.9 NLS_DATE_FORMAT
Description This environment variable specifies the default format used for dates.
B.1.10 NLS_DATE_LANGUAGE
Description This environment variable specifies the default language used for dates.
B.1.11 NLS_DEBIT
Description This environment variable specifies the string used to indicate a negative monetary value.
B.1.12 NLS_ISO_CURRENCY
Description This environment variable specifies the ISO currency symbol.
B.1.13 NLS_LANG
Description This environment variable specifies the language, settings used, including:
  • The language used to display messages to the user, for example the 'Working...' message.
  • The default format masks used for dates and numbers.
  • The sorting sequence.
  • The characters that make up the character set.
Syntax NLS_LANG= language_territory:charset
Valid Values
  • language Specifies the language and its conventions for displaying messages and day and month names.
  • territory Specifies the territory and its conventions for calculating week and day numbers.
  • charset Specifies the character set used for the UPPER, LOWER, and INITCAP functions, and the type of sort used by an ORDER BY query. This argument also controls the character set used for displaying messages.
Also see the Oracle Application Server Globalization Guide on the Oracle Technology Network (http://www.oracle.com/technology/index.html).
Default AMERICAN_AMERICA.WE8ISO8859P1
Usage Notes
  • To change locales, you must modify this environment variable, in addition to the REPORTS_RESOURCE environment variable.
Examples Suppose you want your application to run in French. The application will be used in France and data will be displayed using the WE8ISO8895P1 character set. You would set NLS_LANG as follows:
NLS_LANG=French_France.WE8ISO8895P1
Now, suppose you still want your application to run in French, but this time it will be used in Switzerland. You would set NLS_LANG as follows:
NLS_LANG=French_Switzerland.WE8ISO8895P1
More examples:
NLS_LANG=Norwegian_Norway.NDK7DEC
NLS_LANG=Norwegian_Norway.WE8ISO8895P1
NLS_LANG=Japanese_Japan.JA16SJIS
NLS_LANG=Arabic_Egypt.AR8MSWIN1256
NLS_LANG=American_America.AR8MSWIN1256NLS_LANG=American_America.WE8ISO8859P1
B.1.14 NLS_LIST_SEPARATOR
Description This environment variable specifies the character used to separate items in a list.
B.1.15 NLS_MONETARY_CHARACTERS
Description This environment variable specifies the decimal character and thousands separator for monetary values.
B.1.16 NLS_NUMERIC_CHARACTERS
Description This environment variable specifies the decimal character and grouping separator for numeric values.
B.1.17 NLS_SORT
Description This environment variable specifies the type of sort used for character data.
B.1.18 ORACLE_AFM
Description This environment variable specifies the location of AFM files. TK_AFM is considered first, then ORACLE_AFM.
Default Not defined.
Usage Notes
  • If you do not specify values for either of these variables, Oracle Reports looks for AFM files in:
    ORACLE_HOME/guicommon/tk/admin/AFM
  • Printing on UNIX requires some setup and configuration to create the proper printing environment. For detailed information, refer to Chapter 5, "Printing on UNIX with Oracle Reports".
B.1.19 ORACLE_HOME
Description This environment variable specifies the home directory in which Windows Oracle products are installed. This directory is the top directory in the Oracle directory hierarchy.
Default C:\orawin
Usage Notes
  • If you are using Reports Runtime (rwrun), the combined length of ORACLE_HOME and ORACLE_PATH should not exceed 255 characters.
Example ORACLE_HOME=C:\orawin
B.1.20 ORACLE_HPD
Description This environment variable specifies the location of HPD files. TK_HPD is considered first, then ORACLE_HPD.
Usage Notes
  • If you do not specify values for either these variables, Oracle Reports looks for HPD files in:
    ORACLE_HOME/guicommon/tk/admin/HPD
B.1.21 ORACLE_PATH
Description This environment variable specifies the search path for files referenced by Reports Runtime. Note that the directories specified by ORACLE_PATH are searched after those specified by REPORTS_PATH.
ORACLE_PATH can specify multiple directories. Use a semi-colon (;) to separate directory names in a list of paths.
Usage Notes
  • If you are using Reports Runtime(rwrun), the combined length of ORACLE_HOME and ORACLE_PATH should not exceed 255 characters.
Example ORACLE_PATH=C:\oracle\apps\forms;C:\oracle\apps\reports
B.1.22 ORACLE_PPD
Description This environment variable specifies the location of PPD files. TK_PPD is considered first, then ORACLE_PPD.
Usage notes
  • If you do not specify values for either of these variables, Oracle Reports looks for PPD files in:
    ORACLE_HOME/guicommon/tk/admin/PPD
B.1.23 ORACLE_TFM
Description This environment variable specifies the location of TFM files. TK_TFM is considered first, then ORACLE_TFM.
Usage notes
  • If you do not specify values for either of these variables, Oracle Reports looks for TFM files in
    ORACLE_HOME/guicommon/tk/admin/TFM
  • Printing on UNIX requires some setup and configuration to create the proper printing environment. For information about printing on UNIX with Oracle Reports, refer to Chapter 5, "Printing on UNIX with Oracle Reports".
B.1.24 ORAINFONAV_DOCPATH
Description This environment variable specifies the location of the table of contents and index for your online documentation.
Example ORAINFONAV_DOCPATH=C:\orawin\oin
B.1.25 PRINTER
Description This environment variable specifies the default printer's name.
Valid Values  Name of default printer
Usage Notes
  • TK_PRINTER takes precedence over PRINTER; that is, if both variables are set, TK_PRINTER is considered first and PRINTER is considered only if TK_PRINTER does not specify a valid printer. If neither TK_PRINTER nor PRINTER is set to a valid printer, Oracle Reports uses the first entry in your uiprint.txt file. If REPORTS_NO_DUMMY_PRINTER is set, but the uiprint.txt file does not contain a valid entry, then screenprinter.ppd specified in uiscreenprint.txt is used.
    REPORTS_NO_DUMMY_PRINTER is set by default and is required to be set at all times. If it is not set (as a result of being user-modified), then the REP-1800 error is raised.
    See Also:
    Section 3.10.1, "ScreenPrinter" for more information on the PostScript printer driver, screenprinter.ppd.
B.1.26 REMOTE
Description This environment variable specifies the default and remote SQL*Net driver to use when connecting through a local database. The parameter can include the default SQL*Net parameters (complete database string).
If a user logs on and specifies a connection with an explicit driver prefix matching the one specified in REMOTE, but specifies no SQL*Net parameters, the parameters specified in REMOTE are used. This parameter enables the DBA to define a "normal" network connection for which the SQL*Net user need not specify connection parameters. You can reset this parameter on the command line at any time.
If you use a DOS SQL*Net driver for Windows, check to see whether the REMOTE parameter is set in your CONFIG.ORA file located in the DOS Oracle home directory. If REMOTE is set in CONFIG.ORA, you must set it to the same value in the registry.
Syntax REMOTE= netPrefix:databaseName
Valid Values
  • netPrefix Any valid SQL*Net driver prefix.
  • databaseName The name of the local database.
Example REMOTE=P:PIPER
where
P: is the network prefix for Named Pipes
PIPER is the database name
B.1.27 REPORTS_ADD_HWMARGIN
Description (Windows only) This environment variable specifies whether to include the printer hardware-based left margin. By default, this margin is ignored. The printing origin starts from the top-left corner (0,0) of the physical paper and not the printable area. This is to facilitate the design of of reports independent of the printer hardware margin. These reports can then be deployed across various printers.
In the past, the printer's printable area was used, causing inconsistencies in the location of the report output when moving across different printer models.
If required, you can revert to the previous behavior by setting the registry variable REPORTS_ADD_HWMARGIN to YES.
To set the REPORTS_ADD_HWMARGIN registry variable:
  1. Edit the Windows registry using a registry editor (for example, regedit.exe).
    Before you edit the registry, back it up.
  2. Navigate to the following key:
    HKEY_LOCAL_MACHINE\SOFTWARE\ORACLE\HOMEn
    where n is the number of the ORACLE_HOME containing the installation.
  3. Add a new String value named REPORTS_ADD_HWMARGIN and set the value to YES.
Valid Values YES|NO
Default NO
Usage Note
  • When printing reports without hardware-based left margins on Windows, you must ensure that your report's layout contains enough margin spacing such that your data falls within the printable area. Margin fields in the Page Setup dialog box of Reports Builder have been disabled to ensure consistency with OracleAS Reports Services.
B.1.28 REPORTS_ARABIC_NUMERAL
Description This environment variable specifies the numeric format for Arabic PDF output. Valid values for this environment are: ARABIC (Arabic numerals), HINDI (Hindi numerals), or CONTEXT (Arabic or Hindi depending on the context). This environment variable is case insensitive.
Valid Values ARABIC|HINDI|CONTEXT
Default ARABIC (Indo-Arabic)
B.1.29 REPORTS_BIDI_ALGORITHM
Description This environment variable switches the bidirectional (BiDi) layout algorithm for BiDi languages (for example, Arabic or Hebrew). This environment variable is case insensitive.
Valid Values
  • ORACLE Oracle Reports follows the Oracle BiDi algorithm.
  • UNICODE Oracle Reports follows the Unicode BiDi algorithm.
Refer to http://www.unicode.org/reports/tr9/ for more information on the Unicode BiDi algorithm.
Default ORACLE
B.1.30 REPORTS_CGIDIAGBODYTAGS
Description This environment variable specifies the HTML attributes to add to the <BODY> tag in the rwcgi diagnostic and debugging output. For example, you can use this environment variable to set up text and background color or image.
This environment variable is backward compatible.
Valid Values Any valid HTML attributes for the <BODY> tag.
Usage Notes
This environment variable is supported in Oracle Reports for backward compatibility for Common Gateway Interface (CGI) reports, or when Single Sign-On is not used.
The functionality of JavaServer Pages (JSPs) or servlets replaces support for CGI.
Example REPORTS_CGIDIAGBODYTAGS="bgcolor="#CC3366""
B.1.31 REPORTS_CGIDIAGHEADTAGS
Description This environment variable specifies the HTML tags to insert between the <HEAD> and </HEAD> tags in the rwcgi diagnostic and debugging output. For example, you can use this environment variable to set up <TITLE> or <META> tags.
Valid Values Any HTML tags that are valid between the <HEAD> and </HEAD> tags.
Usage Notes
  • This environment variable is supported in Oracle Reports for backward compatibility for Common Gateway Interface (CGI) reports, or when Single Sign-On is not used.
Example REPORTS_CGIDIAGHEADTAGS="<title>Employee List</title>"
B.1.32 REPORTS_CGIHELP
Description This environment variable specifies the URL and URI of the rwcgi help file that should display when rwcgi is invoked with the following empty request:
http://your_webserver/rwcgi?
Valid Values Any valid URL to a Web page or HTML file.
Default A default help screen is displayed in your browser.
Usage Notes
Examples
To display the www.yahoo.com page in your browser:
REPORTS_CGIHELP=http://www.yahoo.com
To display an HTML file named myhelpfile.htm in your browser:
REPORTS_CGIHELP=http://your_webserver/myhelpfile.htm
B.1.33 REPORTS_CGIMAP
Description This environment variable specifies the fully qualified file name and location of the rwcgi map file, if map file configuration is used.
Valid Values  A valid path to the map file.
Default  ORACLE_HOME\reports\conf\cgicmd.dat
Usage Notes
Example REPORTS_CGIMAP=c:\orawin\reports\conf\cgicmd.dat
B.1.34 REPORTS_CGINODIAG
Description This environment variable specifies whether to disable all debugging and diagnostic output, such as help and showmap, from rwcgi.
Valid Values YES|NO
Default NO
Usage Notes
Example The following request does not work when REPORTS_CGINODIAG=YES:
http://your_webserver/rwcgi/help?
B.1.35 REPORTS_CLASSPATH
Description This environment variable specifies the list of JAR files and directories for the Java Virtual Machine (JVM) when started by the Oracle Reports executables. You would typically add to this list when you need to include your own classes when designing reports (for example, when adding additional pluggable data sources (PDSs) or using the PL/SQL to Java bridge).
Caution:
Reports Builder will fail if the value of the REPORTS_CLASSPATH environment variable (registry) exceeds 511 characters. To work around this issue, you can use the CLASSPATH environment variable (system) to specify a value in excess of 511 characters.
Valid Values The default values are mandatory. If any of the entries are removed, the Oracle Reports executables may not behave correctly. Any additional user-defined directory or JAR file that contains Java Classes may be appended to the path.
Default  %ORACLE_HOME%\reports\jlib\rwbuilder.jar;%ORACLE_HOME%\reports\jlib\rwrun.jar;%ORACLE_HOME%\jlib\zrclient.jar;%ORACLE_HOME%\j2ee\home\oc4j.jar;%ORACLE_HOME%\j2ee\home\lib\ojsp.jar
Usage Notes
  • The default value for the environment variable is required for Oracle Reports executables to function correctly. Additional user classes may be appended, but the list must conform to the platform-specific Java CLASSPATH definition.
    Example
    REPORTS_CLASSPATH=%ORACLE_HOME%\reports\jlib\rwbuilder.jar; %ORACLE_HOME%\reports\jlib\rwrun.jar;%ORACLE_HOME%\jlib\zrclient.jar;%ORACLE_HOME%\j2ee\home\oc4j.jar;%ORACLE_HOME%\j2ee\home\lib\ojsp.jar
  • Reports Builder will fail if the value of the REPORTS_CLASSPATH environment variable (registry) exceeds 511 characters. To work around this issue, you can use the CLASSPATH environment variable (system) to specify a value in excess of 511 characters.
B.1.36 REPORTS_CONTAINSHTMLTAGS
Description This environment variable specifies whether Oracle Reports interprets the HTML formatting tags for all the supported output formats.
Oracle Reports' interpretation of inline HTML tags may be different from the browser's interpretation. As a result, a report designed with inline HTML tags in Oracle Reports 6i, Oracle9i Reports, or Oracle Reports 10g Release 1 (9.0.4) may generate a different HTML or HTMLCSS output in Oracle Reports 10g Release 2 (10.1.2).
Valid Values
  • YES Oracle Reports interprets the HTML tags for those objects whose Contains HTML Tags property is set to Yes.
  • NO Oracle Reports does not interpret the HTML tags for the report, regardless of the object's Contains HTML Tags property setting. For HTML and HTMLCSS ouput, the browser will interpret the HTML formatting tags; for other output formats, the HTML tags themselves will appear as is in the report output. Set this environment variable to NO if you do not wish for Oracle Reports to interpret HTML formatting tags, and thus retain the behavior of prior releases.
See Also:
Section A.3.16, "CONTAINSHTMLTAGS" for more information on the implementation of inline HTML formatting tags.
Default YES
Usage Note
The command line keyword CONTAINSHTMLTAGS overrides the value of this environment variable.
B.1.37 REPORTS_COOKIE_EXPIRE
Description This environment variable specifies the lifetime of a cookie within a given Reports Server session.
If Single Sign-On is not being used, then any user accessing a secured instance of the Reports Server is challenged to identify themselves by rwservlet through its own authentication mechanism (identical to the behavior of Oracle Reports 6i). Because the HTTP 1.0 protocol is stateless (that is, each call to the server is effectively independent of all others), users might need to authenticate themselves for each report request unless a cookie is maintained.
To allow users to authenticate themselves only once per session, rwservlet has its own client-side cookie, the authid cookie, in which it stores the required authentication information for the current session. Once the user is authenticated, an encrypted cookie is created in the browser to enable the user to submit multiple report jobs without re-authenticating for each request. The authid cookies are terminated when the user closes their browser session, but you should not rely strictly on this method of terminating the cookie. You should limit the lifetime of the cookie within a given session using the REPORTS_COOKIE_EXPIRE environment variable. For example, a user might log on and then go to lunch, leaving the browser session open. To minimize the potential for a security breach in this situation, the administrator may define the REPORTS_COOKIE_EXPIRE environment variable on the Reports Server. When rwservlet receives a job request, it compares the time saved in the cookie with the current system time. If the time is longer than the number of minutes defined in the environment variable (for example, 30 minutes), the cookie is rejected and the user is challenged to provide authentication information.
If you want to force users to authenticate themselves for a specific report, you can use the SHOWAUTH command line keyword. Alternatively, you can include a %S in the corresponding report entry in the key map file. This file is usually called cgicmd.dat and is located in ORACLE_HOME\reports\conf. %S forces users to enter their user name and password each time the report is called.
Valid Values  Any number of minutes.
Default  30
Usage Note
Example REPORTS_COOKIE_EXPIRE=30
B.1.38 REPORTS_DB_AUTH
Description This environment variable specifies the database authentication template used to log on to the database. This environment variable is backward compatible.
Valid Values Any HTML file that contains special authentication actions. It is recommended that you keep the default.
Default dbauth.htm
Usage Note
Example REPORTS_DB_AUTH=dbauth.htm
B.1.39 REPORTS_DEFAULT_DISPLAY
Description This environment variable specifies whether to implement the following features introduced with Oracle Reports 10g Release 1 (9.0.4):
  • The elimination of the dependency on the DISPLAY variable (UNIX only)
  • Using ScreenPrinter (screenprinter.ppd) for surface resolution for images and font information, which eliminates the dependency on having a valid printer defined (PRINTER and TK_PRINTER environment variables set to a valid printer, or a valid entry in uiprint.txt) for Reports Runtime (UNIX only).
  • Advanced imaging support (all platforms)
    Refer to Section 3.10.2, "Advanced Imaging Support" for more information.
Valid Values  YES|NO
Default  YES
Usage Notes
  • The Reports Server must be started in batch mode to suppress the UI.
  • REPORTS_DEFAULT_DISPLAY=YES enables the enhanced imaging support introduced with the REPORTS_OUTPUTIMAGEFORMAT environment variable and OUTPUTIMAGEFORMAT command line keyword. The surface resolution can be controlled with the entry in the screenprinter.ppd file. If REPORTS_DEFAULT_DISPLAY=NO, imaging support is limited to GIF format (for PDF output, HTML, HTMLCSS) and BMP format (for RTF output).
  • On UNIX, REPORTS_DEFAULT_DISPLAY=YES overrides any value set for the DISPLAY variable. Even if the DISPLAY variable is defined, the X-Windows display surface will not be used by default. The surface resolution can be controlled with the entry in the screenprinter.ppd. For users upgrading from releases prior to Oracle Reports 10g Release 1 (9.0.4), this change may impact the appearance, number of pages, output file size, or performance of existing reports.
  • This feature is not available on the IBM AIX platform due to lack of functionality in the IBM JDK 1.4 (does not support headless option). For this reason, the dependency on DISPLAY still exists on AIX.
  • To revert to the dependency on DISPLAY and use screen fonts (old font look up algorithm):
    • Set REPORTS_DEFAULT_DISPLAY=NO
    • Remove the screenprinter.ppd entry in the uiscreenprint.txt file.
    • Set the DISPLAY variable to the active X-Windows display surface.
B.1.40 REPORTS_DEFAULT_PIXEL_SIZE
Description This environment variable specifies a pixel size that overrides the display server's default pixel size when generating a report to HTML output. Normally, Oracle Reports takes its pixel size from the display server. If you are working with older reports that rely upon a pixel size that is different from that of the display server (for example, a pixel size of 80), you can use this variable to maintain the same behavior in your older reports.
Valid Values  Any value ranging from 72 through 200.
Default  Surface resolution determined by Oracle Reports.
Usage Notes
  • For Windows, REPORTS_DEFAULT_PIXEL_SIZE is set in the registry. For UNIX, it is set from the command prompt or in a shell script.
  • If REPORTS_DEFAULT_DISPLAY = YES (default), Oracle Reports still uses the value specified for REPORTS_DEFAULT_PIXEL_SIZE for HTML output. However, if a value is not explicitly set for REPORTS_DEFAULT_PIXEL_SIZE , the surface resolution is can be controlled with the entry in the screenprinter.ppd file, as described in Chapter 5, "Printing on UNIX with Oracle Reports".
B.1.41 REPORTS_ENABLE_RTF_SPACING
This environment variable specifies whether to enable functionality that prevents truncation of multiline text in RTF output. This environment variable may not be needed in most circumstances, and should be set to YES only if you see truncation of multiline text in RTF output.
Valid Values
  • YES Oracle Reports enables functionality to prevent truncation of multiline text in RTF output.
  • NO Oracle Reports does not enable functionality to prevent truncation of multiline text in RTF output. Truncation may occur.
Default  NO
B.1.42 REPORTS_ENCRYPTION_KEY
Description This environment variable specifies the encryption key used to encrypt the user name and password.
Valid Values  Any encryption key
Default reports9i
Usage Note
Example REPORTS_ENCRYPTION_KEY=oraclereports10g
B.1.43 REPORTS_ENHANCED_SUBSET
Description This environment variable specifies whether to include the enhanced TTF font subsetting feature when generating a report. This environment variable is set to YES by default to ensure that the PDF file generated is accessible and searchable.
Valid Values YES|NO
Default YES
Usage Note
Oracle Reports uses the enhanced font subsetting implementation, by default. If you set REPORTS_ENHANCED_SUBSET=NO, Oracle Reports will to revert to the Type 3 font subsetting implementation used in releases prior to Oracle Reports 10g Release 2 (10.1.2).
For more information on PDF font subsetting, refer to Section 6.1.2.2, "Font Subsetting".
B.1.44 REPORTS_GRAPH_IMAGE_DPI
Description This environment variable specifies a dots per inch (DPI) value for graphs output to a PDF file or a printer. The default value for this environment variable is set at 72 DPI to minimize the time taken to generate the report as well as to reduce the report file size.
If you specify a value higher than 72 DPI, you will see an improvement in the image resolution for graphs sent to a PDF file or a printer. However, this affects the time taken to generate the report output as well as the file size.
With the value of REPORTS_GRAPH_IMAGE_DPI=250:
  • The time taken to generate a report with a graph increases 5 to 6 times when compared to the time taken to generate the same report with the value set to 72 DPI.
  • The PDF file size also increases 5 to 6 times.
Valid Values  72 through 300
Default  72
Usage Notes
  • On Windows, use the registry to specify the value. On Unix/Linux, set the environment variable in reports.sh.
  • When you set a higher DPI value, you may also need to change the JVM heap size value through REPORTS_JVM_OPTIONS to avoid the Out Of Memory error for the JVM.
  • This environment variable is not supported in Oracle Reports distribution functionality, as it is specific to PDF and printer outputs only.
B.1.45 REPORTS_IGNORE_IMAGE_TAG_RES
Description This environment variable is useful when a report includes certain image formats that have the ability to store the physical size of the image, which usually includes resolution and pixel dimensions. To ensure the image is not scaled to the physical dimensions, you can set this environment variable to YES to specify that Oracle Reports should ignore image resolution information and only use the pixel dimensions of the image. This ensures that this type of image from a database column is displayed correctly instead of displaying as a thumbnail.
Valid Values
  • YES Oracle Reports ignores image resolution information, and uses only the pixel dimensions of the image.
  • NO Oracle Reports does not ignore the image resolution information in the image.
Default NO
B.1.46 REPORTS_JPEG_QUALITY_FACTOR
Description This environment variable specifies the level of image quality desired for JPEG images. It provides control over the trade-off between JPEG image quality and size of the image. The better the quality of the image, the greater the image file size.
Valid Values  0 through 100
Default  100 (highest quality)
Usage Notes
  • If REPORTS_JPEG_QUALITY_FACTOR is not specified or incorrectly specified (for example, set to a string or an out of range value), the default value is used.
  • A value of 75 provide a good quality image, while ensuring a good compression ratio.
B.1.47 REPORTS_JVM_OPTIONS
Description This environment variable specifies any JVM options that you want Reports Builder, Reports Runtime, or Reports Converter to consider when it starts its JVM. For example, you can use this environment variable to specify the starting heap size and maximum heap size for the JVM, additional classpath entries, and so on.
Valid Values  List of JVM options in the JVM command line syntax.
Default  -Xmx256M
Usage Notes
  • The default value -Xmx256M specifies the JVM heap size of 256 MB to avoid the Out Of Memory error when running reports with large graphs or running big reports.
  • When the Reports Engine starts up, it checks for JVM options specified in the server_name.conf file in the jvmoptions attribute of the engine element. For more information, see Section 3.2.1.4, "engine". If specified, the JVM options set in server_name.conf override the value of the REPORTS_JVM_OPTIONS environment variable. If not specified in server_name.conf, Oracle Reports uses the JVM options specified by the REPORTS_JVM_OPTIONS environment variable.
  • When running reports with Reports Server, JVM options cannot be set using the REPORTS_JVM_OPTIONS environment variable. For Reports Server, set JVM options on the command line using the JVMOPTIONS command line keyword. For more information, see Section A.3.46, "JVMOPTIONS".
  • When running reports with Reports Builder, Reports Runtime, and Reports Converter, JVM options specified on the command line with the JVMOPTIONS command line keyword override JVM options specified by the REPORTS_JVM_OPTIONS environment variable.
B.1.48 REPORTS_NETWORK_CONFIG
Description This environment variable should be set only if you want rwclient, rwrqm, rwcgi, or OracleAS Forms Services to use a custom network configuration file. If this environment variable is not set, then these executables will use the default network configuration file (rwnetwork.conf). For more information about rwnetwork.conf, see Section 3.3.1, "Network Configuration Elements (rwnetworkconf.dtd)".
Valid Values A valid custom network configuration file in ORACLE_HOME\reports\conf
Default rwnetwork.conf
B.1.49 REPORTS_NLS_XML_CHARSETS
Description This environment variable provides an override option to enable you to define the character set encoding used when saving a report in XML format. This is only necessary when the required character set mapping for NLS_LANG to XML IANA-defined character sets do not produce the required results.
To enable your XML parser to understand the characters within the XML files, Oracle Reports does the following:
  1. Adds an encoding attribute to the XML declaration based on the value in NLS_CHARACTERSET, the character set part of the NLS_LANG variable.
  2. Translates the value set as the NLS_LANG character set (for example, JA16SJIS) to what is expected in the XML specification (for example, Shift_JIS).
You can override this mapping by adding entries to the REPORTS_NLS_XML_CHARSET.
Valid Values  Set of mapping pairs separated by semicolons. The first value is the encoding that is being produced and the second mapped value is the value that should be used for these cases.
Example
WISO-8859-8=ISO-8859-8-1;CSEUCKR=EUC-KR;WINDOWS-949=EUC-KR;EUC-CN=GBK;WINDOWS-936=GBK
B.1.50 REPORTS_NO_DUMMY_PRINTER
Description This environment variable, together with other printer and display environment variables and settings, specifies whether the system's surface and fonts should be used instead of the printer's.
Valid Values  TRUE|not set
Default  TRUE
Usage Notes
  • REPORTS_NO_DUMMY_PRINTER is set by default and is required to be set at all times. If it is not set (as a result of being user-modified), and there is no valid printer, error REP-1800 error is raised. Alternatively, you could use TK_PRINT_STATUS when you have no valid printer. A valid printer response is required by Oracle Reports to generate output, even if you are generating to a file.
    Beginning with Oracle Reports 10g, if the uiprint.txt file does not contain a valid entry (that is, no valid printer is defined), but REPORTS_NO_DUMMY_PRINTER is set, Oracle Reports uses screenprinter.ppd specified in uiscreenprint.txt. You should unset this environment variable only if you do not want the screenprinter.ppd driver to be used by Oracle Reports when there is no valid printer.
    See Also:
  • The limitation of this approach is that these reports might lose their formatting when viewed from another system if it is not identical to the system where the report was designed. Furthermore, when this report is printed, the formatting would not be correct because the fonts and their metrics differ.
B.1.51 REPORTS_NO_HTML_SPACE_REPLACE
Description
This environment variable specifies whether spaces should not be replaced with &nbsp; in HTML or HTMLCSS output.
Oracle Reports maps HTML metadata characters in the data retrieved for a field to the appropriate encoding. That is, Oracle Reports automatically maps:
  • < to &lt;
  • " to &quot;
In most cases, the browser produces the correct results and handles the spaces correctly. In some cases, the browser's handling of spaces does not produce the required output. This happens in such cases as where the user has padded the front of the data to produce indentation. Since the browser will treat multiple spaces as single space, the indentation is lost.
Valid Values  YES|not set
Default  not set
Usage Notes
  • If the value is not set, all spaces are replaced by &nbsp;. This could cause problems in your output where you want the browsers to handle line breaks on spaces. It will also increase the size of the generated HTML file.
  • If a field's Contains HTML Tags property is set to Yes, then no encoding will take place since Oracle Reports just passes the field's value through to the output.
Example
If REPORTS_NO_HTML_SPACE_REPLACE is set to YES, then the output for the sentence [Typical data output] will be:
[ Typical data output]
and display as (ignoring preceding spaces):
Not setting the environment variable will cause the output to change to:
[&nbsp;&nbsp;Typical&nbsp;data&nbsp;output]
and display as (maintaining preceding spaces):
Brackets in the preceding example are used to show preceding spaces; they are not part of the sentence.
B.1.52 REPORTS_OUTPUTIMAGEFORMAT
Description This environment variable specifies the default image format used in the report.
Valid Values  GIF|JPEG|JPG|PNG|BMP
Default  JPEG
Usage Notes
  • You must ensure the format that you specify matches the output type. For example, BMP only works for RTF and spreadsheet output. It will not work for HTML, HTMLCSS, or PDF output.
  • This environment variable setting is overridden by the value of the OUTPUTIMAGEFORMAT command line keyword.
B.1.53 REPORTS_PATH
Description This environment variable specifies the search path for files referenced by Reports Runtime. The directories specified by REPORTS_PATH are searched first, then those specified by ORACLE_PATH. This environment variable is used to locate reports and external objects that you use in your reports, such as PL/SQL libraries, external queries, and external boilerplate. It enables you to create reports that are easily portable across operating systems by preventing the need to hard-code directory paths.
Define REPORTS_PATH in the same fashion you define other environment variables on your operating system, keeping in mind such platform-specific rules as path length, and so on.
In addition to directory paths, you can specify the keyword DB when you define REPORTS_PATH. This instructs Reports Builder to search the database to which you are currently connected.
Suppose you specified the following on a UNIX platform:
setenv REPORTS_PATH /home/tkostin/pay:/home/tkostin/receive:DB
Reports Builder will first search the directory /home/tkostin/pay. If it cannot find the file in question, it will search /home/tkostin/receive. If it still cannot find the file, it will search the database to which you connected when you began your Reports Builder session.
Default  %ORACLE_HOME%\REPORT\DEMO; %ORACLE_HOME%\REPORT\DEMO\BITMAP; %ORACLE_HOME%\REPORT\DEMO\REQFILES
Usage Note
  • REPORTS_PATH is limited to 256 characters.
  • If you specify a path for the sourceDir attribute of the engine element in the Reports Server configuration file (server_name.conf), the sourceDir value will override the values you set here.
Example
REPORTS_PATH=C:\oracle\apps\reports;C:\myfiles
B.1.54 REPORTS_RESOURCE
This environment variable specifies the location of the resource files required for reports. This path must include the globalization support directory extension when specifying the location of the resource files.
Default  %ORACLE_HOME%\reports\res\US\
Usage Note
To change locales, you must modify this environment variable, in addition to NLS_LANG.
Examples For US files:
REPORTS_RESOURCE = %ORACLE_HOME%\reports\res\US\
For Japanese files:
REPORTS_RESOURCE = %ORACLE_HOME%\reports\res\JA\
B.1.55 REPORTS_SERVER
Description This environment variable specifies the default Reports Server for Web Cartridge or Web CGI requests. When this environment variable is set, you can omit the SERVER command line keyword in report requests to process them using the default Reports Server, or you can include the SERVER command line keyword to override the default.
Valid Values  Any Reports Server service entry name.
Usage Note
The functionality of Java Server Pages (JSPs) or servlets replaces support for CGI. The default Reports Server name is defined in the Reports Servlet (rwservlet) configuration file (rwservlet.properties), as described in Section 3.4.11, "Identifying the In-process Server".
Example REPORTS_SERVER=my_rep_server
B.1.56 REPORTS_SOLARIS_9
Description This environment variable resolves a synchronization issue between native Motif libraries and JDK UI packages on Solaris 2.9. When REPORTS_SOLARIS_9=YES, Reports Builder responds as expected. If you set REPORTS_SOLARIS_9=NO in a Solaris 2.9 environment, Reports Builder may stop responding when invoking either the Report Wizard or Data Wizard.
Valid Values YES|NO
Default YES on Solaris 2.9; NO on other platforms.
B.1.57 REPORTS_SPACE_BREAK
Description This environment variable specifies whether to consider white spaces as a delimiter. Oracle Reports employs an algorithm to properly wrap a line, when a word cannot fit in the same line. By default the word wrapping algorithm considers white spaces as a delimiter.
Valid Values YES|NO
Default YES
Usage Note
Set this environment variable to NO only for Asian languages with multibyte character sets, such as Chinese. This ensures that Oracle Reports does not consider white spaces as delimiters and will enable appropriate word wrapping functionality required by languages with multibyte character sets.
B.1.58 REPORTS_SRWRUN_TO_SERVER
Description
This environment variable specifies whether to allow the SERVER or USERID keywords when running a report using the SRW.RUN_REPORT built-in procedure.
Default  not set
Usage Notes
  • In Oracle Reports 10g Release 2 (10.1.2), the use of keywords SERVER and USERID with SRW.RUN_REPORT is deprecated. If you have reports created in prior releases that use these keywords with SRW.RUN_REPORT, you can set REPORTS_SRWRUN_TO_SERVER=YES to continue to run these reports with Oracle Reports 10g Release 2 (10.1.2).
  • You may encounter issues when attempting to run reports created in prior releases asynchronously. For this reason, it is important to migrate your reports to Oracle Reports 10g Release 2 (10.1.2) as soon as possible.
For a description of the SRW built-in package, including the SRW.RUN_REPORT built-in procedure, see the Oracle Reports online Help.
B.1.59 REPORTS_SSLPORT
Description This environment variable specifies the port number when using SSL.
Valid Values  Any valid port number.
Default  443
Usage Note
Example REPORTS_SSLPORT=442
B.1.60 REPORTS_SYS_AUTH
Description This environment variable specifies the authentication template used to authenticate the username and password when users run report requests to a restricted Reports Server.
Valid Value  Any HTML file that contains special authentication actions. It is recommended that you keep the default.
Default  sysauth.htm
Usage Note
Example REPORTS_SYS_AUTH=sysauth.htm
B.1.61 REPORTS_TAGLIB_URI
Description This environment variable specifies the location of the tag prefix used in the Web source of a JSP-based report. It defines the Reports URI of the tag library (TAGLIB) declarations of the .jsp file. This is typically:
<%@ taglib uri="/WEB-INF/lib/reports_tld.jar" prefix="rw" %>
When Oracle Reports finds a "uri" that matches the environment variable, it will use the corresponding "prefix" attribute to identify Oracle Reports tags within the .jsp file.
Valid Values  Any "uri" that references the Oracle Reports tag library.
Default  /WEB-INF/lib/reports_tld.jar
Usage Note
The default value is typically unchanged. It is the same for both reports files in both JDeveloper and Oracle Reports. The "prefix" attribute can be changed to avoid naming conflicts independent of the "uri" attribute.
B.1.62 REPORTS_TMP
Description This environment variable specifies the directory in which you wish to store Reports Builder temporary files. Reports Builder will use only one directory for this purpose; do not define more than one.
Define REPORTS_TMP in the same fashion you define other environment variables on your base operating system, keeping in mind such platform-specific rules as path length, and so on. If you don't define REPORTS_TMP, it will default to the current working directory.
Example REPORTS_TMP=C:\tmp
B.1.63 REPORTS_USEREXITS
Description This environment variable specifies the libraries for use by Oracle Reports. These libraries are program modules created by you to be called by Oracle Reports.
REPORTS_USEREXITS can specify multiple libraries. On Windows, use a backslash (\) to separate directories in a path, and a semicolon (;) to separate complete paths. On UNIX, use a forward slash (/) to separate directories in a path, and a colon (:) to separate complete paths.
If this value is not explicitly set, Oracle Reports looks for rwxtb.dll according to the path variable of the system.
With Oracle Reports 10g, you can call Java methods using the ORA_JAVA built-in package and the Java Importer. This reduces the need to have user exits in a report and allows for a more open and portable deployment. You may also use the ORA_FFI built-in package, which provides a foreign function interface for invoking C functions in a dynamic library. With the availability of these built-in packages, the use of user exits is deprecated in Oracle Reports, though makefiles are still be supplied to permit you to continue to work with existing user exits.
For backward compatibility, the prior name REPORTS_USEREXIT is allowed for this environment variable.
Valid Values  Any user exit library (along with its absolute path).
Example
On Windows:
REPORTS_USEREXITS=C:\mydll.dll;d:\mynew.dll;e:\bin\speed.dll
On UNIX:
REPORTS_USEREXITS=/usr/oracle/mylib.so:/usr/oracle/myfolder/speed.so
B.1.64 REPORTS_UTF8_XMLOUTPUT
Description This environment variable specifies whether the UTF8 character set is used instead of the NLS_LANG character set. This environment variable is in effect only when the encoding attribute is not specified by the XML Prolog Value property (see the Oracle Reports online Help for a description of the XML Prolog Value property).
Valid Values
YES Assigns the UTF8 character set (when the XML Prolog Value property is not set).
NO Assigns the NLS_LANG (or IANA-defined) character set (when the XML Prolog Value property is not set).
Default YES
B.1.65 RW
This environment variable specifies the reports-specific directory within the ORACLE_HOME.
Valid Values  A valid directory name.
Default
%ORACLE_HOME%\reports (Windows)
B.1.66 TK_PRINT
Description (UNIX only) This environment variable specifies the print command to be executed on UNIX for Oracle Reports 6i. In later releases of Oracle Reports, TK_PRINT is obsolete; you can achieve the same results by using the printing script file: ORACLE_HOME/bin/rwlpr.sh. This script supports lp and lpr commands by default. If you use some other printing command for your machine, this file needs to be modified accordingly.
Valid Values  The PRINT command and all necessary keywords for your flavor of UNIX, including the following elements:
Usage Notes
  • In most cases, the default print commands will meet your needs. We recommend that you only set this environment variable when you have a specific need to alter the default value. For example, if you want duplexed output, you need to set TK_PRINT.
B.1.67 TK_PRINT_STATUS
Description (UNIX only) This environment variable specifies the command executed to validate the printer. To ensure that the printer is valid, this command is executed and its output is searched for the strings unknown, non-existent, or invalid. If one of these strings appears in the output, the printer is considered invalid and cannot be selected. Otherwise, the printer is accepted by Oracle Reports.
Valid Values  Should include %n for the printer name (see also TK_PRINT).
Usage Notes
  • You should only use this environment variable in cases where the printer status command on your platform differs from the default values, or when you have no valid printer. If you have no valid printer, you can set TK_PRINT_STATUS=echo and specify a dummy entry in the uiprint.txt file. This workaround ensures that Oracle Reports gets a valid response when checking for a printer.
  • If REPORTS_NO_DUMMY_PRINTER is set, but the uiprint.txt file does not contain a valid entry, then screenprinter.ppd specified in uiscreenprint.txt is used.
    REPORTS_NO_DUMMY_PRINTER is set by default and is required to be set at all times. If it is not set (as a result of being user-modified), error REP-1800 error is raised.
    See Also:
B.1.68 TK_PRINTER
Description (UNIX only) This environment variable specifies the default printer's name.
Valid Values  Name of default printer.
Usage Notes
    See Also:
B.1.69 TK_AFM
Usage Notes
B.1.70 TK_HPD
Usage Notes
B.1.71 TK_PPD
Usage notes
B.1.72 TK_TFM
Usage notes
B.1.73 USERNAME
Description This environment variable specifies the default logon account. See your database documentation for more information on setting USERNAME.
Valid Values Any valid Oracle username (without the OPS$ prefix).
Example USERNAME=dsanvita
B.1.74 USER_NLS_LANG
Description This environment variable specifies the language for the Oracle Reports Runtime component. Chapter 18, "Implementing Globalization and Bidirectional Support" contains additional detailed information about this environment variable, including a table of valid values.
