Skip Headers
Oracle® Data Provider for .NET Developer's Guide
10g Release 1 (10.1.0.3)
Part No. B14164-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous Next
OracleConnection Class
An OracleConnection object represents a connection to an Oracle database.
Class Inheritance
Object
  MarshalByRefObject
    Component
      OracleConnection
Declaration
// C#
public sealed class OracleConnection : Component,
   IDbConnection, ICloneable
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
// C#
using System;
using System.Data;
using Oracle.DataAccess.Client;
class OracleConnectionSample
  static void Main()
    // Connect
    string constr = "User Id=scott;Password=tiger;Data Source=oracle";
    OracleConnection con = new OracleConnection(constr);
    con.Open();
    // Execute a SQL SELECT
    OracleCommand cmd = con.CreateCommand();
    cmd.CommandText = "select * from emp";
    OracleDataReader reader = cmd.ExecuteReader();
    // Print all employee numbers
    while (reader.Read())
      Console.WriteLine(reader.GetInt32(0));
    // Clean up
    reader.Dispose();
    cmd.Dispose();
    con.Dispose();
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
OracleConnection Members
OracleConnection members are listed in the following tables:
OracleConnection Constructors
OracleConnection constructors are listed in Table 4-19.
Table 4-19 OracleConnection Constructors
Constructor Description
OracleConnection Constructors Instantiates a new instance of the OracleConnection class (Overloaded)
OracleConnection Static Methods
OracleConnection static methods are listed in Table 4-20.
Table 4-20 OracleConnection Static Methods
Methods Description
Equals Inherited from Object (Overloaded)
OracleConnection Properties
OracleConnection properties are listed in Table 4-21
Table 4-21 OracleConnection Properties
Name Description
ConnectionString Specifies connection information used to connect to an Oracle database
ConnectionTimeout Specifies the maximum amount of time that the Open() method can take to obtain a pooled connection before terminating the request
Container Inherited from Component
DataSource
Specifies the Oracle Net Service Name (also known as TNS alias) that identifies an Oracle database instance
ServerVersion Specifies the version number of the Oracle database to which the OracleConnection has established a connection
Site Inherited from Component
State Specifies the current state of the connection
OracleConnection Public Methods
OracleConnection public methods are listed in Table 4-22.
Table 4-22 OracleConnection Public Methods
Public Method Description
BeginTransaction Begins a local transaction (Overloaded)
ChangeDatabase Not Supported
Clone Creates a copy of an OracleConnection object
Close Closes the database connection
CreateCommand Creates and returns an OracleCommand object associated with the OracleConnection object
CreateObjRef Inherited from MarshalByRefObject
Dispose Inherited from Component
EnlistDistributedTransaction
Enables applications to explicitly enlist in a specified distributed transaction
GetHashCode Inherited from Object
GetLifetimeService Inherited from MarshalByRefObject
GetSessionInfo Returns or refreshes the property values of the OracleGlobalization object that represents the globalization settings of the session (Overloaded)
GetType Inherited from Object
InitializeLifetimeService Inherited from MarshalByRefObject
Open Opens a database connection with the property settings specified by the ConnectionString
OpenWithNewPassword Opens a new connection with the new password
PurgeStatementCache
Flushes the Statement Cache by closing all open cursors on the server, when Statement Caching is enabled
SetSessionInfo Alters the session's globalization settings with the property values provided by the OracleGlobalization object
ToString Inherited from Object
OracleConnection Events
OracleConnection events are listed in Table 4-23.
Table 4-23 OracleConnection Events
Event Name Description
Disposed Inherited from Component
Failover An event that is triggered when an Oracle failover occurs
InfoMessage An event that is triggered for any message or warning sent by the database
StateChange An event that is triggered when the connection state changes
OracleConnection Event Delegates
OracleConnection event delegates are listed in Table 4-24.
Table 4-24 OracleConnection Event Delegates
Event Delegate Name Description
OracleFailoverEventHandler An event delegate that handles the Failover event
OracleInfoMessageEventHandler An event delegate that handles the InfoMessage event
StateChangeEventHandler An event delegate that handles the StateChange event
OracleConnection constructors instantiate new instances of the OracleConnection class.
Overload List:
OracleConnection()
This constructor instantiates a new instance of the OracleConnection class using default property values.
Declaration
// C#
public OracleConnection();
Remarks
The properties for OracleConnection are set to the following default values:
OracleConnection(String)
This constructor instantiates a new instance of the OracleConnection class with the provided connection string.
Declaration
// C#
public OracleConnection(String connectionString);
Parameters
Remarks
The ConnectionString property is set to the supplied connectionString. The ConnectionString property is parsed and an exception is thrown if it contains invalid connection string attributes or attribute values.
The properties of the OracleConnection object default to the following values unless they are set by the connection string:
OracleConnection static methods are listed in Table 4-25.
Table 4-25 OracleConnection Static Methods
Methods Description
OracleConnection properties are listed in Table 4-26
Table 4-26 OracleConnection Properties
Name Description
DataSource
ConnectionString
This property specifies connection information used to connect to an Oracle database.
Declaration
// C#
public string ConnectionString{get; set;}
Property Value
If the connection string is supplied through the constructor, this property is set to that string.
Implements
IDbConnection
Exceptions
ArgumentException - An invalid syntax is specified for the connection string.
InvalidOperationException - ConnectionString is being set while the connection is open.
Remarks
The default value is an empty string.
ConnectionString must be a string of attribute name and value pairings, separated by a semi-colon, for example:
"User Id=scott;password=tiger;data source=oracle"
If the ConnectionString is not in a proper format, an exception is thrown. All spaces are ignored unless they are within double quotes.
When the ConnectionString property is set, the OracleConnection object immediately parses the string for errors. An ArgumentException is thrown if the ConnectionString contains invalid attributes or invalid values. Attribute values for User Id, Password, Proxy User Id, Proxy Password, and Data Source (if provided) are not validated until the Open method is called.
The connection must be closed to set the ConnectionString property. When the ConnectionString property is reset, all previously set values are reinitialized to their default values before the new values are applied.
The Oracle database supports case-sensitive user names. To connect as a user whose name is of mixed case, for example, "MySchema", the User Id attribute value must be surrounded by double quotes, as follows:
"User Id=\"MySchema\";Password=MYPASSWORD;Data Source=oracle"
However, if the Oracle user name is all upper case, the User Id connection string attribute can be set to that user name without the use of the double quotes since User Ids that are not doubled-quoted are converted to all upper case when connecting. Single quotes are not supported.
For a complete example, see "Example".
If a connection string attribute is set more than once, the last setting takes effect and no exceptions are thrown.
Boolean connection string attributes can be set to either true, false, yes, or no.
Supported connection string attributes:
Table 4-27 lists the supported connection string attributes.
Table 4-27 Supported Connection String Attributes
Connection String Attribute Default value Description
Connection Lifetime 0 Maximum life time (in seconds) of the connection
This attribute specifies the lifetime of the connection in seconds. Before the Connection is placed back into the pool, the lifetime of the connection is checked. If the lifetime of the connection exceeds this property value, the connection is closed and disposed. If this property value is 0, the connection lifetime is never checked. Connections that have exceeded their lifetimes are not closed and disposed of, if doing so brings the number of connection in the pool below the Min Pool Size.
Connection Timeout 15 Maximum time (in seconds) to wait for a free connection from the pool
This attribute specifies the maximum amount of time (in seconds) that the Open() method can take to obtain a pooled connection before it terminates the request. This value comes into effect only if no free connection is available from the connection pool and the Max Pool Size is reached. If a free connection is not available within the specified time, an exception is thrown. Connection Timeout does not limit the time required to open new connections.
This attribute value takes effect for pooled connection requests and not for new connection requests.
Data Source empty string Oracle Net Service Name that identifies the database to connect to
This attribute specifies the Oracle Net Service Name (formerly known as TNS alias) that identifies an Oracle database instance. This attribute must be set to connect to a remote database.
DBA Privilege empty string Administrative privileges SYSDBA or SYSOPER
This connection string attribute only accepts SYSDBA or SYSOPER as the attribute value. It is case insensitive.
Decr Pool Size 1 Number of connections that are closed when an excessive amount of established connections are unused.
This connection string attribute controls the maximum number of unused connections that are closed when the pool regulator makes periodic checks. The regulator thread is spawned every 3 minutes and closes up to Decr Pool Size amount of pooled connections if they are not used. The pool regulator never takes the total number of connections below the Min Pool Size by closing pooled connections.
Enlist True Serviced Components automatically enlist in distributed transactions
If this attribute is set to true, the connection is automatically enlisted in the thread's transaction context. If this attribute is false, no enlistments are made. This attribute can be set to either true, false, yes, or no.
Incr Pool Size 5 Number of connections established when all connections in pool are used
This connection string attribute determines the number of new connections that are established when a pooled connection is requested, but no unused connections are available and Max Pool Size is not reached. If new connections have been created for a pool, the regulator thread skips a cycle and does not have an opportunity to close any connections for 6 minutes. Note, however, that some connections can be still be closed during this time if their lifetime has been exceeded.
Max Pool Size 100 Maximum number of connections in a pool
This attribute specifies the maximum number of connections allowed in the particular pool used by that OracleConnection. Simply changing this attribute in the connection string does not change the Max Pool Size restriction on a currently existing pool. Doing so simply creates a new pool with a different Max Pool Size restriction. This attribute must be set to a value greater than the Min Pool Size. This value is ignored unless Pooling is turned on.
Min Pool Size 1 Minimum number of connections in a pool
This attribute specifies the minimum number of connections to be maintained by the pool during its entire lifetime. Simply changing this attribute in the connection string does not change the Min Pool Size restriction on a currently existing pool. Doing so simply creates a new pool with a different Min Pool Size restriction. This value is ignored unless Pooling is turned on.
Password empty string Password for the user specified by User Id
This attribute specifies an Oracle user's password. Password is case insensitive.
Persist Security Info False Enables or disables the retrieval of password in the connection string
If this attribute is set to false, the Password value setting is not returned when the application requests the ConnectionString after the connection is successfully opened by the Open() method. This attribute can be set to either true, false, yes, or no.
Pooling True Enables or disables connection pooling
This attribute specifies whether connection pooling is to be used. Pools are created using an attribute value matching algorithm. This means that connection strings which only differ in the number of spaces in the connection string use the same pool. If two connection strings are identical except that one sets an attribute to a default value while the other does not set that attribute, both requests obtain connections from the same pool. This attribute can be set to either true, false, yes, or no.
Proxy User Id empty string User name of the proxy user
This connection string attribute specifies the middle-tier user, or the proxy user, who establishes a connection on behalf of a client user specified by the User Id attribute. ODP.NET attempts to establish a proxy connection if either the Proxy User Id or the Proxy Password attribute is set to a non-empty string.
For the proxy user to connect to an Oracle database using operating system authentication, the Proxy User Id must be set to "/". The Proxy Password is ignored in this case. The User Id cannot be set to "/" when establishing proxy connections. The case of this attribute value is preserved if it is surrounded by double quotes.
Proxy Password empty string Password of the proxy user
This connection string attribute specifies the password of the middle-tier user or the proxy user. This user establishes a connection on behalf of a client user specified by the User Id attribute. ODP.NET attempts to establish a proxy connection if either the Proxy User Id or the Proxy Password attribute is set to a non-empty string.
Statement Cache Purge False Purges the Statement Cache
If Statement Caching is enabled, setting this attribute to True purges the Statement Cache when the connection goes back to the pool.
Statement Cache Size 0 Enables Statement Cache and sets the cache size
Statement Cache Size is the maximum number of statements that can be cached. A value greater than zero enables Statement Caching and sets the cache size to itself. This value should not be greater than the value of the OPEN_CURSORS parameter set in the init.ora database configuration file.
User Id empty string Oracle user name
This attribute specifies the Oracle user name. The case of this attribute value is preserved if it is surrounded by double quotes. For the user to connect to an Oracle database using operating system authentication, set the User Id to "/". Any Password attribute setting is ignored in this case.
Validate Connection False Enables or disables validation of connections coming from the pool
Validation causes a round-trip to the database for each connection. Therefore, it should only be used when necessary.
Example
This code example shows that the case of the User Id attribute value is not preserved unless it is surrounded by double quotes. The example also demonstrates when connection pools are created and when connections are drawn from the connection pool.
/* Database Setup
grant connect , resource to "MYSCHEMA" identified by MYPWD;
grant connect , resource to "MySchema" identified by MYPWD;
// C#
using System;
class ConnectionStringSample
  static void Main()
    string constr1 = "User Id=myschema;Password=mypwd;Data Source=oracle";
    string constr2 = "User Id=MySchema;Password=MyPwd;Data Source=oracle";
    string constr3 = "User Id=\"MYSCHEMA\";Password=MYPWD;Data Source=oracle";
    string constr4 = "User Id=\"MySchema\";Password=MYPWD;Data Source=oracle";
    string constr5 = " User Id=myschema;Password=mypwd;Data Source=oracle; ";
    string constr6 =
      "User Id=myschema;Password=mypwd;Data Source=oracle;pooling=true";
    // Connect as "MYSCHEMA/MYPWD"
    // NOTE: the password is case insensitive
    // A new connection and a new connection pool X is created
    OracleConnection con1 = new OracleConnection(constr1);
    con1.Open();
    // Place connection back into connection pool X
    con1.Dispose();
    // The connection from pool X is obtained.  No new connection created.
    OracleConnection con2 = new OracleConnection(constr2);
    con2.Open();
    con2.Dispose();
    OracleConnection con3 = new OracleConnection(constr3);
    con3.Open();
    con3.Dispose();
    // Connect as "MySchema/MYPWD"
    // A new connection and connection pool Y is created
    OracleConnection con4 = new OracleConnection(constr4);
    con4.Open();
    // Place connection back into connection pool Y
    con4.Dispose();
    // Extra spaces or semi-colons in the connection string do not force
    //   new pools to be created
    OracleConnection con5 = new OracleConnection(constr5);
    con5.Open();
    con5.Dispose();
    // A connection is obtained from Connection Pool X.
    // It's important to note that different connection strings do
    // not necessarily mean that ODP.NET will create different
    // connection pools for them.  In other words, ODP.NET does not
    // use exact string matching alogrithm to determine whether
    // a new connection pool needs to be created or not.
    // Instead, it creates connection pools based on the uniqueness
    // of attribute values settings in the connection string.
    OracleConnection con6 = new OracleConnection(constr6);
    con6.Open();
    con6.Dispose();
ConnectionTimeout
This property specifies the maximum amount of time that the Open() method can take to obtain a pooled connection before terminating the request.
Declaration
// C#
public int ConnectionTimeout {get;}
Property Value
The maximum time allowed for a pooled connection request, in seconds.
Implements
IDbConnection
Remarks
The default value is 15.
Setting this property to 0 allows the pooled connection request to wait for a free connection without a time limit. The timeout takes effect only for pooled connection requests and not for new connection requests.
DataSource
This property specifies the Oracle Net Service Name (formerly known as TNS alias) that identifies an Oracle database instance.
Declaration
// C#
public string DataSource {get;}
Property Value
The Oracle Net Service Name.
Remarks
The default value of this property is an empty string
ServerVersion
This property specifies the version number of the Oracle database to which the OracleConnection has established a connection.
Declaration
// C#
public string ServerVersion {get;}
Property Value
The version of the Oracle database, for example "9.2.0.1.0."
Exceptions
InvalidOperationException - The connection is closed.
Remarks
The default is an empty string.
State
This property specifies the current state of the connection.
Declaration
// C#
public ConnectionState State {get;}
Property Value
The ConnectionState of the connection.
Implements
IDbConnection
Remarks
ODP.NET supports ConnectionState.Closed and ConnectionState.Open for this property. The default value is ConnectionState.Closed.
OracleConnection public methods are listed in Table 4-28.
Table 4-28 OracleConnection Public Methods
PurgeStatementCache
BeginTransaction
BeginTransaction methods begin local transactions.
Overload List
BeginTransaction()
This method begins a local transaction.
Declaration
// C#
public OracleTransaction BeginTransaction();
Return Value
An OracleTransaction object representing the new transaction.
Implements
IDbConnection
Exceptions
InvalidOperationException - A transaction has already been started.
Remarks
The transaction is created with its isolation level set to its default value of IsolationLevel.ReadCommitted. All further operations related to the transaction must be performed on the returned OracleTransaction object.
BeginTransaction(IsolationLevel)
This method begins a local transaction with the specified isolation level.
Declaration
// C#
public OracleTransaction BeginTransaction(IsolationLevel isolationLevel);
Parameters
Return Value
Implements
IDbConnection
Exceptions
ArgumentException - The isolationLevel specified is invalid.
Remarks
The following two isolation levels are supported:
Requesting other isolation levels causes an exception.
Example
// C#
using System;
using System.Data;
class BeginTransactionSample
  static void Main()
    con.Open();
    // Create an OracleCommand object using the connection object
    // Start a transaction
    OracleTransaction txn = con.BeginTransaction(IsolationLevel.ReadCommitted);
    // Update EMP table
    cmd.CommandText = "update emp set sal = sal + 100";
    cmd.ExecuteNonQuery();
    // Rollback transaction
    txn.Rollback();
    Console.WriteLine("Transaction rolledback");
    // Clean up
    txn.Dispose();
    cmd.Dispose();
    con.Dispose();
Clone
This method creates a copy of an OracleConnection object.
Declaration
// C#
public object Clone();
Return Value
An OracleConnection object.
Implements
ICloneable
Remarks
The cloned object has the same property values as that of the object being cloned.
Example
// C#
using System;
class CloneSample
  static void Main()
    con.Open();
    // Need a proper casting for the return value when cloned
    OracleConnection clonedCon = (OracleConnection)con.Clone();
    // Cloned connection is always closed, regardless of its source,
    //   But the connection string should be identical
    clonedCon.Open();
    // Close and Dispose OracleConnection object
    clonedCon.Dispose();
Close
This method closes the connection to the database.
Declaration
// C#
public void Close();
Implements
IDbConnection
Remarks
Performs the following:
The connection can be reopened using Open().
CreateCommand
This method creates and returns an OracleCommand object associated with the OracleConnection object.
Declaration
// C#
public OracleCommand CreateCommand();
Return Value
The OracleCommand object.
Implements
IDbConnection
Example
// C#
using System;
using System.Data;
class CreateCommandSample
  static void Main()
    // Connect
    con.Open();
    // Clean up
    reader.Dispose();
    cmd.Dispose();
    con.Dispose();
This method enables applications to explicitly enlist in a specific distributed transaction after a connection has been opened.
Declaration
// C#
public void EnlistDistributedTransaction(ITransaction transaction);
Parameters
Exception
InvalidOperationException - The connection is part of a local transaction.
Remarks
EnlistDistributedTransaction enables objects to enlist in a specific transaction that is passed to the method. The ITransaction interface can be obtained by applying an (ITransaction) cast to the ContexUtil.Transaction property within the component that started the distributed transaction.
The connection must be open before calling this method or an InvalidOperationException is thrown.
If a connection is part of a local transaction that was started implicitly or explicitly while attempting to enlist in a distributed transaction, the local transaction is rolled back and an exception is thrown.
By default, distributed transactions roll back, unless the method-level AutoComplete declaration is set.
Invoking the commit on the ITranasction raises an exception.
Invoking the rollback on the ITransaction method and calling ContextUtil.SetComplete on the same distributed transaction raises an exception.
Example
Application:
// C#
// This is the class that will utilize the Enterprise Services
//   component.  This module needs to be built as an executable.
using System;
using System.EnterpriseServices;
using ConnectionSample_Comp;
class EnlistDistributedTransactionSample_App
  static void Main()
    ESComponent comp = new ESComponent();
    comp.DoWork();
Component:
// C#
// This module needs to be
//   1) built as a component DLL/Library
//   2) built with a strong name
using System;
using System.Data;
[Transaction(TransactionOption.RequiresNew)]
public class EnlistDistributedTransactionSample_Comp : ServicedComponent
  public void DoWork()
    string constr =
      "User Id=scott;Password=tiger;Data Source=oracle;enlist=false";
    con.Open();
    // Enlist in a distrubuted transaction
    con.EnlistDistributedTransaction((ITransaction)ContextUtil.Transaction);
    // Update EMP table
    cmd.CommandText = "UPDATE emp set sal = sal + .01";
    // Commit
    ContextUtil.SetComplete();
    // Dispose OracleConnection object
    con.Dispose();
See Also:
GetSessionInfo
GetSessionInfo returns or refreshes an OracleGlobalization object that represents the globalization settings of the session.
Overload List:
GetSessionInfo()
This method returns a new instance of the OracleGlobalization object that represents the globalization settings of the session.
Declaration
// C#
public OracleGlobalization GetSessionInfo();
Return Value
The newly created OracleGlobalization object.
Example
// C#
using System;
class GetSessionInfoSample
  static void Main()
    con.Open();
    // Get session info from connection object
    OracleGlobalization info = con.GetSessionInfo();
    // Execute SQL SELECT
    cmd.CommandText = "select TO_CHAR(hiredate) from emp";
    Console.WriteLine("Hire Date ({0}): {1}",
      info.DateFormat, cmd.ExecuteScalar());
    // Update session info
    info.DateFormat = "YYYY-MM-DD";
    con.SetSessionInfo(info);
    // Execute SQL SELECT again
    // Clean up
    cmd.Dispose();
    con.Dispose();
GetSessionInfo(OracleGlobalization)
This method refreshes the provided OracleGlobalization object with the globalization settings of the session.
Declaration
// C#
public void GetSessionInfo(OracleGlobalization oraGlob);
Parameters
Open
This method opens a connection to an Oracle database.
Declaration
// C#
public void Open();
Implements
IDbConnection
Exceptions
ObjectDisposedException - The object is already disposed.
InvalidOperationException - The connection is already opened or the connection string is null or empty.
Remarks
The connection is obtained from the pool if connection pooling is enabled. Otherwise, a new connection is established.
It is possible that the pool does not contain any unused connections when the Open() method is invoked. In this case, a new connection is established.
If no connections are available within the specified connection timeout value, when the Max Pool Size is reached, an OracleException is thrown.
OpenWithNewPassword
This method opens a new connection with the new password.
Declaration
// C#
public void OpenWithNewPassword(string newPassword);
Parameters
Remarks
This method uses the ConnectionString property settings to establish a new connection. The old password must be provided in the connection string as the Password attribute value.
This method can only be called on an OracleConnection in the closed state.
PurgeStatementCache
This method flushes the Statement Cache by closing all open cursors on the server, when Statement Caching is enabled.
Declaration
// C#
public void PurgeStatementCache();
Remarks
Flushing the statement cache repetitively results in decreased performance and may negate the performance benefit gained by enabling the statement cache.
Statement Caching remains enabled after the call to PurgeStatementCache.
Example
// C#
using System;
using System.Data;
class PurgeStatementCacheSample
  static void Main()
    string constr = "User Id=scott;Password=tiger;Data Source=oracle;" +
      "Statement Cache Size=20";
    con.Open();
    OracleCommand cmd = new OracleCommand("select * from emp", con);
    cmd.CommandType = CommandType.Text;
    // Purge Statement Cache
    con.PurgeStatementCache();
    Console.WriteLine("Statement Cache Flushed");
    con.Close();
    con.Dispose();
SetSessionInfo
This method alters the session's globalization settings with all the property values specified in the provided OracleGlobalization object.
Declaration
// C#
public void SetSessionInfo(OracleGlobalization oraGlob);
Parameters
An OracleGlobalization object.
Remarks
Calling this method is equivalent to calling an ALTER SESSION SQL on the session.
Example
// C#
using System;
class SetSessionInfoSample
  static void Main()
    con.Open();
    // Clean up
    cmd.Dispose();
    con.Dispose();
OracleConnection events are listed in Table 4-29.
Table 4-29 OracleConnection Events
Failover
This event is triggered when an Oracle failover occurs.
Declaration
// C#
public event OracleFailoverEventHandler Failover;
Event Data
The event handler receives an OracleFailoverEventArgs object which exposes the following properties containing information about the event.
InfoMessage
This event is triggered for any message or warning sent by the database.
Declaration
// C#
public event OracleInfoMessageEventHandler InfoMessage;
Event Data
The event handler receives an OracleInfoMessageEventArgs object which exposes the following properties containing information about the event.
Remarks
In order to respond to warnings and messages from the database, the client should create an OracleInfoMessageEventHandler delegate to listen to this event.
StateChange
This event is triggered when the connection state changes.
Declaration
// C#
public event StateChangeEventHandler StateChange;
Event Data
The event handler receives a StateChangeEventArgs object which exposes the following properties containing information about the event.
Remarks
The StateChange event is raised after a connection changes state, whenever an explicit call is made to Open, Close or Dispose.
OracleConnection event delegates are listed in Table 4-30.
Table 4-30 OracleConnection Event Delegates
This event delegate handles the Failover event.
This event delegate handles the InfoMessage event.
This event delegate handles the StateChange event.
See Also:
