Skip Headers
Oracle® Data Provider for .NET Developer's Guide
10g Release 1 (10.1.0.3)
Part No. B14164-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous Next
OracleDataAdapter Class
An OracleDataAdapter object represents a data provider object that populates the DataSet and updates changes in the DataSet to the Oracle database.
Class Inheritance
Object
  MarshalByRefObject
    Component
      DataAdapter
        DbDataAdapter
          OracleDataAdapter
Declaration
// C#
public sealed class OracleDataAdapter : DbDataAdapter, IDbDataAdapter
Thread Safety
All public static methods are thread-safe, although instance methods do not guarantee thread safety.
Example
The following example uses the OracleDataAdapter and the dataset to update the EMP table:
// C#
using System;
using System.Data;
using Oracle.DataAccess.Client;
class OracleDataAdapterSample
  static void Main()
    string constr = "User Id=scott;Password=tiger;Data Source=oracle";
    string cmdstr = "SELECT empno, sal from emp";
    // Create the adapter with the selectCommand txt and the
    // connection string
    OracleDataAdapter adapter = new OracleDataAdapter(cmdstr, constr);
    // Create the builder for the adapter to automatically generate
    // the Command when needed
    OracleCommandBuilder builder = new OracleCommandBuilder(adapter);
    // Create and fill the DataSet using the EMP
    DataSet dataset = new DataSet();
    adapter.Fill(dataset, "EMP");
    // Get the EMP table from the dataset
    DataTable table = dataset.Tables["EMP"];
    // Indicate DataColumn EMPNO is unique
    // This is required by the OracleCommandBuilder to update the EMP table
    table.Columns["EMPNO"].Unique = true;
    // Get the first row from the EMP table
    DataRow row = table.Rows[0];
    // Update the salary
    double sal = double.Parse(row["SAL"].ToString());
    row["SAL"] = sal + .01;
    // Now update the EMP using the adapter
    // The OracleCommandBuilder will create the UpdateCommand for the
    // adapter to update the EMP table
    adapter.Update(dataset, "EMP");
    Console.WriteLine("Row updated successfully");
Requirements
Namespace: Oracle.DataAccess.Client
Assembly: Oracle.DataAccess.dll
OracleDataAdapter Members
OracleDataAdapter members are listed in the following tables:
OracleDataAdapter Constructors
OracleDataAdapter constructors are listed in Table 4-31.
Table 4-31 OracleDataAdapter Constructors
Constructor Description
OracleDataAdapter Constructors Instantiates a new instance of OracleDataAdapter class (Overloaded)
OracleDataAdapter Static Methods
OracleDataAdapter static methods are listed in Table 4-32.
Table 4-32 OracleDataAdapter Static Methods
Methods Description
Equals Inherited from Object (Overloaded)
OracleDataAdapter Properties
OracleDataAdapter properties are listed in Table 4-33.
Table 4-33 OracleDataAdapter Properties
Name Description
AcceptChangesDuringFill Inherited from DataAdapter
Container Inherited from Component
ContinueUpdateOnError Inherited from DataAdapter
DeleteCommand A SQL statement or stored procedure to delete rows from an Oracle database
InsertCommand A SQL statement or stored procedure to insert new rows into an Oracle database
MissingMappingAction Inherited from DataAdapter
MissingSchemaAction Inherited from DataAdapter
Requery Determines whether the SelectCommand is reexecuted on the next call to Fill
SafeMapping Creates a mapping between column names in the result set to .NET types, to preserve the data
SelectCommand A SQL statement or stored procedure that returns a single or multiple result set
Site Inherited from Component
TableMappings Inherited from DataAdapter
UpdateCommand A SQL statement or stored procedure to update rows from the DataSet to an Oracle database
OracleDataAdapter Public Methods
OracleDataAdapter public methods are listed in Table 4-34.
Table 4-34 OracleDataAdapter Public Methods
Public Method Description
CreateObjRef Inherited from MarshalByRefObject
Dispose Inherited from Component
Fill Adds or refreshes rows in the DataSet to match the data in the Oracle database (Overloaded)
FillSchema Inherited from DbDataAdapter
GetFillParameters Inherited from DbDataAdapter
GetHashCode Inherited from Object
GetLifetimeService Inherited from MarshalByRefObject
GetType Inherited from Object
InitializeLifetimeService Inherited from MarshalByRefObject
ToString Inherited from Object
Update Inherited from DbDataAdapter
OracleDataAdapter Events
OracleDataAdapter events are listed in Table 4-35.
Table 4-35 OracleDataAdapter Events
Event Delegate Name Description
EventHandler Inherited from Component
FillErrorEventHandler Inherited from DbDataAdapter
OracleRowUpdatedEventHandler Event Delegate for the RowUpdated Event
OracleRowUpdatingEventHandler Event Delegate for the RowUpdating Event
OracleDataAdapter Event Delegates
OracleDataAdapter event delegates are listed in Table 4-36.
Table 4-36 OracleDataAdapter Event Delegates
OracleDataAdapter constructors create new instances of an OracleDataAdapter class.
Overload List:
OracleDataAdapter()
This constructor creates an instance of an OracleDataAdapter class with no arguments.
Declaration
// C#
public OracleDataAdapter();
Remarks
Initial values are set for the following OracleDataAdapter properties as indicated:
OracleDataAdapter(OracleCommand)
This constructor creates an instance of an OracleDataAdapter class with the provided OracleCommand as the SelectCommand.
Declaration
// C#
public OracleDataAdapter(OracleCommand selectCommand);
Parameters
Remarks
OracleDataAdapter(string, OracleConnection)
This constructor creates an instance of an OracleDataAdapter class with the provided OracleConnection object and the command text for the SelectCommand.
Declaration
// C#
public OracleDataAdapter(string selectCommandText, OracleConnection
    selectConnection);
Parameters
Remarks
The OracleDataAdapter opens and closes the connection, if it is not already open. If the connection is open, it must be explicitly closed.
OracleDataAdapter(string, string)
This constructor creates an instance of an OracleDataAdapter class with the provided connection string and the command text for the SelectCommand.
Declaration
// C#
public OracleDataAdapter(string selectCommandText, string
   selectConnectionString);
Parameters
Remarks
OracleDataAdapter static methods are listed in Table 4-37.
Table 4-37 OracleDataAdapter Static Methods
Methods Description
OracleDataAdapter properties are listed in Table 4-38.
Table 4-38 OracleDataAdapter Properties
Name Description
DeleteCommand
This property is a SQL statement or stored procedure to delete rows from an Oracle database.
Declaration
// C#
public OracleCommand DeleteCommand {get; set;}
Property Value
An OracleCommand used during the Update call to delete rows from tables in the Oracle database, corresponding to the deleted rows in the DataSet.
Remarks
Default = null
If there is primary key information in the DataSet, the DeleteCommand can be automatically generated using the OracleCommandBuilder, if no command is provided for this.
InsertCommand
This property is a SQL statement or stored procedure to insert new rows into an Oracle database.
Declaration
// C#
public OracleCommand InsertCommand {get; set;}
Property Value
An OracleCommand used during the Update call to insert rows into a table, corresponding to the inserted rows in the DataSet.
Remarks
Default = null
If there is primary key information in the DataSet, the InsertCommand can be automatically generated using the OracleCommandBuilder, if no command is provided for this property.
Requery
This property determines whether the SelectCommand is reexecuted on the next call to Fill.
Declaration
// C#
public Boolean Requery {get; set;}
Property Value
Returns true if the SelectCommand is reexecuted on the next call to Fill; otherwise, returns false.
SafeMapping
This property creates a mapping between column names in the result set to .NET types that represent column values in the DataSet, to preserve the data.
Declaration
// C#
public Hashtable SafeMapping {get; set;}
Property Value
A hashtable.
Remarks
Default = null
The SafeMapping property is used, when necessary, to preserve data in the following types:
Example
// C#
using System;
using System.Data;
class SafeMappingSample
  static void Main()
    // In this SELECT statement, EMPNO, HIREDATE and SALARY must be
    // preserved using safe type mapping.
    string cmdstr = "SELECT EMPNO, ENAME, HIREDATE, SAL FROM EMP";
    // Create the adapter with the selectCommand txt and the connection string
    // Get the connection from the adapter
    OracleConnection connection = adapter.SelectCommand.Connection;
    // Create the safe type mapping for the adapter
    // which can safely map column data to byte arrays, where
    // applicable. By executing the following statement, EMPNO, HIREDATE AND
    // SALARY columns will be mapped to byte[]
    adapter.SafeMapping.Add("*", typeof(byte[]));
    // Map HIREDATE to a string
    // If the column name in the EMP table is case-sensitive,
    // the safe type mapping column name must be case-sensitive.
    adapter.SafeMapping.Add("HIREDATE", typeof(string));
    // Map EMPNO to a string
    // the safe type mapping column name must also be case-sensitive.
    adapter.SafeMapping.Add("EMPNO", typeof(string));
    adapter.SafeMapping.Add("SAL", typeof(string));
    // Print out the row info
    Console.WriteLine("EMPNO Column: type = " + row["EMPNO"].GetType() +
      "; value = " + row["EMPNO"]);
    Console.WriteLine("ENAME Column: type = " + row["ENAME"].GetType() +
      "; value = " + row["ENAME"]);
    Console.WriteLine("HIREDATE Column: type = " + row["HIREDATE"].GetType()+
      "; value = " + row["HIREDATE"]);
    Console.WriteLine("SAL Column: type = " + row["SAL"].GetType() +
      "; value = " + row["SAL"]);
SelectCommand
This property is a SQL statement or stored procedure that returns single or multiple result sets.
Declaration
// C#
public OracleCommand SelectCommand {get; set;}
Property Value
An OracleCommand used during the Fill call to populate the selected rows to the DataSet.
Remarks
Default = null
If the SelectCommand does not return any rows, no tables are added to the dataset and no exception is raised.
If the SELECT statement selects from a VIEW, no key information is retrieved when a FillSchema() or a Fill() with MissingSchemaAction.AddWithKey is invoked.
UpdateCommand
This property is a SQL statement or stored procedure to update rows from the DataSet to an Oracle database.
Declaration
// C#
public OracleCommand UpdateCommand {get; set;}
Property Value
An OracleCommand used during the Update call to update rows in the Oracle database, corresponding to the updated rows in the DataSet.
Remarks
Default = null
If there is primary key information in the DataSet, the UpdateCommand can be automatically generated using the OracleCommandBuilder, if no command is provided for this property.
OracleDataAdapter public methods are listed in Table 4-39.
Table 4-39 OracleDataAdapter Public Methods
Fill
Fill populates or refreshes the specified DataTable or DataSet.
Overload List:
Fill(DataTable, OracleRefCursor)
This method adds or refreshes rows in the specified DataTable to match those in the provided OracleRefCursor object.
Declaration
// C#
public int Fill(DataTable dataTable, OracleRefCursor refCursor);
Parameters
Return Value
The number of rows added to or refreshed in the DataTable.
Exceptions
ArgumentNullException - The dataTable or refCursor parameter is null.
InvalidOperationException - The OracleRefCursor is already being used to fetch data.
NotSupportedException - The SafeMapping type is not supported.
Remarks
No schema or key information is provided, even if the Fill method is called with MissingSchemaAction set to MissingSchemaAction.AddWithKey.
Fill(DataSet, OracleRefCursor)
This method adds or refreshes rows in the DataSet to match those in the provided OracleRefCursor object.
Declaration
// C#
public int Fill(DataSet dataSet, OracleRefCursor refCursor);
Parameters
Return Value
Returns the number of rows added or refreshed in the DataSet.
Exceptions
ArgumentNullException - The dataSet or refCursor parameter is null.
InvalidOperationException - The OracleRefCursor is ready to fetch data.
Remarks
If there is no DataTable to refresh, a new DataTable named Table is created and populated using the provided OracleRefCursor object.
Fill(DataSet, string, OracleRefCursor)
This method adds or refreshes rows in the specified source table of the DataSet to match those in the provided OracleRefCursor object.
Declaration
// C#
public int Fill(DataSet dataSet, string srcTable, OracleRefCursor
   refCursor);
Parameters
Return Value
Returns the number of rows added or refreshed into the DataSet.
Exceptions
InvalidOperationException - The OracleRefCursor is already being used to fetch data or the source table name is invalid.
Remarks
Fill(DataSet, int, int, string, OracleRefCursor)
This method adds or refreshes rows in a specified range in the DataSet to match rows in the provided OracleRefCursor object.
Declaration
// C#
public int Fill(DataSet dataSet, int startRecord, int maxRecords,
   string srcTable, OracleRefCursor refCursor);
Parameters
Return Value
This method returns the number of rows added or refreshed in the DataSet. This does not include rows affected by statements that do not return rows.
Exceptions
Remarks
OracleDataAdapter events are listed in Table 4-40.
Table 4-40 OracleDataAdapter Events
Event Name Description
Disposed Inherited from Component
FillError Inherited from DbDataAdapter
RowUpdated This event is raised when row(s) have been updated by the Update() method
RowUpdating This event is raised when row data are about to be updated to the database
RowUpdated
This event is raised when row(s) have been updated by the Update() method.
Declaration
// C#
public event OracleRowUpdatedEventHandler RowUpdated;
Event Data
The event handler receives an OracleRowUpdatedEventArgs object which exposes the following properties containing information about the event.
Example
The following example shows how to use the RowUpdating and RowUpdated events.
// C#
using System;
using System.Data;
class RowUpdatedSample
  // Event handler for RowUpdating event
  protected static void OnRowUpdating(object sender,
                                      OracleRowUpdatingEventArgs e)
    Console.WriteLine("Row updating.....");
    Console.WriteLine("Event arguments:");
    Console.WriteLine("Command Text: " + e.Command.CommandText);
    Console.WriteLine("Command Type: " + e.StatementType);
    Console.WriteLine("Status: " + e.Status);
  // Event handler for RowUpdated event
  protected static void OnRowUpdated(object sender,
                                     OracleRowUpdatedEventArgs e)
    Console.WriteLine("Row updated.....");
  static void Main()
    string cmdstr = "SELECT EMPNO, ENAME, SAL FROM EMP";
    // Set the event handlers for the RowUpdated and the RowUpdating event
    // the OnRowUpdating() method will be triggered before the update, and
    // the OnRowUpdated() method will be triggered after the update
    adapter.RowUpdating += new OracleRowUpdatingEventHandler(OnRowUpdating);
    adapter.RowUpdated += new OracleRowUpdatedEventHandler(OnRowUpdated);
    // The OnRowUpdating() and the OnRowUpdated() methods will be triggered
RowUpdating
This event is raised when row data are about to be updated to the database.
Declaration
// C#
public event OracleRowUpdatingEventHandler RowUpdating;
Event Data
The event handler receives an OracleRowUpdatingEventArgs object which exposes the following properties containing information about the event.
Example
The example for the RowUpdated event also shows how to use the RowUpdating event. See RowUpdated event "Example".
OracleDataAdapter event delegates are listed in Table 4-41.
Table 4-41 OracleDataAdapter Event Delegates
This event delegate handles the RowUpdated Event.
This event delegate handles the RowUpdating Event.
