Skip Headers
Oracle® Data Provider for .NET Developer's Guide
10g Release 1 (10.1.0.3)
Part No. B14164-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous Next
OracleFailoverEventHandler Delegate
The OracleFailoverEventHandler represents the signature of the method that handles the OracleConnection.Failover event.
Declaration
// C#
public delegate FailoverReturnCode OracleFailoverEventHandler(object sender,
    OracleFailoverEventArgs eventArgs);
Parameter
Return Type
An int.
Remarks
To receive failover notifications, a callback function can be registered as follows:
ConObj.Failover += new OracleFailoverEventHandler(OnFailover);
The definition of the callback function OnFailover can be as follows:
public FailoverReturnCode OnFailover(object sender, OracleFailoverEventArgs eventArgs)
Example
// Transparent Application Failover (TAF) Setup
// Refer Oracle® Database Net Services Administrator's Guide
// C#
using System;
using System.Threading;
using Oracle.DataAccess.Client;
using Oracle.DataAccess.Types;
class OracleFailoverEventHandlerSample
  static void Main(string[] args)
    string constr = "User Id=scott;Password=tiger;Data Source=oracle";
    OracleConnection con = new OracleConnection(constr);
    con.Open();
    // Register the event handler OnFailover
    con.Failover += new OracleFailoverEventHandler(OnFailover);
    con.Close();
    con.Dispose();
  // TAF callback function
  static FailoverReturnCode OnFailover(object sender,
    switch (eventArgs.FailoverEvent)
      case FailoverEvent.Begin:
        Console.WriteLine("FailoverEvent.Begin - Failover is starting");
        Console.WriteLine("FailoverType = " + eventArgs.FailoverType);
        break;
      case FailoverEvent.End:
        Console.WriteLine("FailoverEvent.End - Failover was successful");
        break;
      case FailoverEvent.Reauth:
        Console.WriteLine("FailoverEvent.Reauth - User reauthenticated");
        break;
      case FailoverEvent.Error:
        Console.WriteLine("FailoverEvent.Error - Failover was unsuccessful");
        // Sleep for 3 sec and Retry
        Thread.Sleep(3000);
        return FailoverReturnCode.Retry;
      case FailoverEvent.Abort:
        Console.WriteLine("FailoverEvent.Abort - Failover was unsuccessful");
        break;
      default:
        Console.WriteLine("Invalid FailoverEvent : " + eventArgs.FailoverEvent);
        break;
    return FailoverReturnCode.Success;
