Skip Headers
Oracle® Data Provider for .NET Developer's Guide
10g Release 1 (10.1.0.3)
Part No. B14164-01
  Go To Table Of Contents
Contents
Go To Index
Index
Previous Next
OracleRowUpdatedEventHandler Delegate
The OracleRowUpdatedEventHandler delegate represents the signature of the method that handles the OracleDataAdapter.RowUpdated event.
Declaration
// C#
public delegate void OracleRowUpdatedEventHandler(object sender,
   OracleRowUpdatedEventArgs eventArgs);
Parameters
Remarks
Event callbacks can be registered through this event delegate for applications that wish to be notified after a row is updated.
In the .NET framework, the convention of an event delegate requires two parameters: the object that raises the event and the event data.
